23-Segment Routing Configuration Guide
HomeSupportRoutersMSR5600 Series(Comware V7)Configure & DeployConfiguration GuidesH3C MSR 5600 Routers Configuration Guides(V7)-R6749-6W10123-Segment Routing Configuration Guide
01-SR-MPLS configuration
01-SR-MPLS configuration 1.25 MB
Configuring SR-MPLS·· 1
About SR-MPLS· 1
SR-MPLS characteristics· 1
Basic concepts· 1
How SR-MPLS works· 2
Traffic steering to an SR-MPLS tunnel 2
Static segment configuration· 3
Dynamic SID allocation through an IGP· 4
Dynamic SID allocation through BGP· 4
SID allocation through BGP EPE· 4
Label forwarding entry installation based on SIDs· 6
SRLSP setup· 8
Packet forwarding in SR-MPLS· 8
IGP SR and LDP interworking· 11
SR to LDP· 12
LDP to SR· 13
SR over LDP· 13
BGP SR and LDP interworking· 14
SR to LDP· 15
LDP to SR· 16
TI-LFA FRR· 16
TI-LFA FRR background· 17
TI-LFA FRR concepts· 17
TI-LFA FRR path calculation· 18
TI-LFA FRR forwarding process· 19
Microloop avoidance after a network failure· 19
Microloop avoidance after a failure recovery· 20
Protocols and standards· 21
Restrictions and guidelines for SR-MPLS· 21
SR-MPLS tasks at a glance· 21
IP traffic forwarding over SRLSPs tasks at a glance· 21
MPLS TE traffic forwarding over static SRLSPs tasks at a glance· 22
MPLS TE traffic forwarding over explicit paths tasks at a glance· 22
MPLS TE traffic forwarding over PCE-calculated SRLSPs tasks at a glance· 22
Configuring MPLS SRGBs· 23
Configuring the MPLS SRLB· 23
Configuring static segments· 24
Prerequisites· 24
Configuring a static adjacency segment 24
Configuring a static prefix segment 25
Configuring IGP-based SID advertisement 25
IGP-based SID advertisement tasks at a glance· 25
Prerequisites for configuring IGP-based SID advertisement 26
Configuring the IGP to support SR-MPLS· 26
Configuring prefix SIDs· 27
Enabling SR-MPLS adjacency label allocation for the IGP· 27
Assigning adjacency SIDs· 28
Configuring BGP-based SID advertisement 29
BGP-based SID advertisement tasks at a glance· 29
Prerequisites for configuring BGP-based SID advertisement 29
Configuring BGP to support SR-MPLS· 29
Configuring BGP prefix SIDs· 29
Specifying the type of label to advertise to the penultimate hop· 31
Configuring BGP EPE· 31
About BGP EPE· 31
Configuring SID allocation through BGP EPE· 31
Configuring a BGP EPE peer set 32
Configuring the device to prefer SRLSPs in traffic forwarding· 33
Configuring an MPLS TE tunnel to use static SRLSPs· 34
Tasks at a glance· 34
Configuring a static SRLSP· 34
Binding a static SRLSP to an MPLS TE tunnel interface· 34
Configuring an MPLS TE tunnel over an explicit-path SRLSP· 35
Tasks at a glance· 35
Prerequisites· 35
Configuring an explicit path for the MPLS TE tunnel 35
Configuring an MPLS TE tunnel over the explicit path· 35
Configuring an MPLS TE tunnel over a PCE-calculated SRLSP· 36
Tasks at a glance· 36
Configuring an MPLS TE tunnel interface to use PCE to calculate the SRLSP· 36
Configuring IGP SR and LDP interworking· 37
Restrictions and guidelines for IGP SR and LDP interworking· 37
SR to LDP tasks at a glance· 37
LDP to SR tasks at a glance· 37
SR over LDP tasks at a glance· 37
Prerequisites for SR-MPLS and LDP internetworking· 37
Enabling advertisement of locally configured prefix-SID mappings· 38
Configuring prefix-SID mappings· 38
Enabling reception of advertised prefix-SID mappings· 39
Configuring BGP SR and LDP interworking· 39
Restrictions and guidelines for BGP SR and LDP interworking· 39
SR to LDP tasks at a glance· 39
LDP to SR tasks at a glance· 40
Enabling prefix-SID mappings· 40
Configuring TI-LFA FRR· 40
Restrictions and guidelines for TI-LFA FRR· 40
TI-LFA FRR tasks at a glance· 41
Enabling TI-LFA FRR· 41
Disabling an interface from participating in TI-LFA calculation· 42
Configuring microloop avoidance· 42
Display and maintenance commands for SR-MPLS· 44
SR-MPLS configuration examples· 45
Example: Configuring an SR-based MPLS TE tunnel over an explicit path· 45
Example: Configuring an MPLS TE tunnel over a PCE-calculated SRLSP· 50
Example: Configuring SR-MPLS inter-AS option C (I) 56
Example: Configuring SR-MPLS inter-AS option C (II) 63
Example: Configuring SR-MPLS to LDP (IS-IS) 70
Example: Configuring SR-MPLS to LDP (OSPF) 72
Example: Configuring SR-MPLS over LDP· 75
Example: Configuring IS-IS TI-LFA FRR· 80
Configuring SR-MPLS
About SR-MPLS
Segment Routing (SR) is a source routing technology. The source node selects a path for the packets, and then encodes the path in the packet header as an ordered list of segments. Each segment is identified by the segment identifier (SID). The SR nodes along the path forward the packets based on the SIDs in the packets. Only the source node needs to maintain the path status.
SR can operate with MPLS. In an MPLS network, SR uses MPLS labels as SIDs to forward packets on an LSP.
SR-MPLS has the following characteristics:
·     SR-MPLS forwards packets based on the existing MPLS infrastructure. No infrastructure modifications are needed to implement SR on an MPLS network. For more information about the MPLS infrastructure, see MPLS basics configuration in MPLS Configuration Guide.
·     SR-MPLS expands and optimizes existing IGPs and BGP and uses the IGPs and BGP to distribute labels.
·     SR-MPLS implements network features such as MPLS TE in a simpler way, eliminating issues such as heavy and complicated routing protocol deployment.
Basic concepts
·     SR node—A node enabled with the SR-MPLS feature. The ingress node (source node) adds labels to packets. The transit nodes forward packets based on labels. The egress node removes labels and forwards packets to the destination networks. SR nodes form an SR domain.
·     Segment—An instruction an SR node executes on the incoming packet.
·     SID—Segment ID, which is MPLS label in SR-MPLS.
·     Segment type—The following types of segments are available:
¡     Prefix segment—SIDs are assigned to nodes based on destination address prefix. The nodes create prefix-specific forwarding entries.
¡     Adjacency segment—SIDs are assigned to nodes based on adjacency.
·     SRLSP—Segment routing label switched path, an LSP along which SR uses MPLS labels as SIDs to forward packets.
·     SRGB—Segment routing global block, a range of global labels dedicated for SR-MPLS prefix SIDs. Different nodes can have different SRGBs. The minimum label value of an SRGB label range is referred to as the base value of the SRGB.
·     SRLB—Segment routing local block, a range of local labels dedicated for SR-MPLS adjacency SIDs. All nodes share the same SRLB. The minimum label value of the SRLB label range is referred to as the base value of the SRLB.
·     MPLS Segment Routing Best Effort (SR-MPLS BE)—Uses IGP to compute the optimal SRLSP by using the shortest path algorithm, and uses SIDs to instruct data forwarding. The SRLSP establishment and data forwarding are similar to the LDP LSP establishment and data forwarding. SR-MPLS BE does not use tunnel interfaces.
·     MPLS Segment Routing Traffic Engineering (SR-MPLS TE)—A TE tunnel technology that uses SR as the control protocol. SR-MPLS BE and SR-MPLS TE both need to establish SRLSPs, but the ways they establish SRLSPs are different. An SRLSP used by an SR-MPLS TE tunnel can be established manually through explicit path configuration. Or, it can be computed by the controller, which then deploys the label stack to the device for establishment of the SRLSP. The tunnel interface must be created on the ingress node of the SR-MPLS TE tunnel. The device encapsulates the label stack into the packets so as to control the forwarding path of the packets on the network.
How SR-MPLS works
SR-MPLS involves the following steps:
1.     Label allocation for all nodes and links along the packet forwarding paths.
The following methods are available: static segment configuration and dynamic SID allocation.
2.     Label forwarding entry installation based on SIDs. All SR-MPLS devices in the SR domain use the allocated labels to create label forwarding entries.
3.     SRLSP setup. You can manually configure SRLSPs, or use an IGP, BGP, or a controller to dynamically create SRLSPs.
When the ingress node of an SRLSP receives a packet, it adds labels to the packet and forwards the packet to the egress node through the SRLSP. After receiving a packet from the SRLSP, the egress node removes the label and forwards the packet based on the routing table.
You can bind a higher layer application (for example, MPLS TE) to an SRLSP to forward traffic of the application through the SRLSP.
SR-MPLS tunnels include SR-MPLS BE tunnels and SR-MPLS TE tunnels.
After an SR-MPLS BE or SR-MPLS TE tunnel is established, traffic cannot be forwarded automatically through the tunnel. You can use the following methods to steer traffic to an SR-MPLS BE or SR-MPLS TE tunnel:
Static route
The static route method is a simple, direct method for steering traffic to an SR-MPLS BE or SR-MPLS TE tunnel.
This method configures a static route destined for the destination address through the tunnel interface and allows the static route to recurse to LSP tunnels established by SR-MPLS BE or SR-MPLS TE. For more information about static route recursion to LSP tunnels, see static route configuration in Layer 3—IP Routing Configuration Guide.
Tunnel policy
When traffic of a VPN is forwarded through a tunnel, the traffic is forwarded through an LDP LSP tunnel by default. To direct the traffic to an SR-MPLS BE or SR-MPLS TE tunnel, you can apply a tunnel policy or tunnel selector to the VPN.
Based on the service requirements, you can configure one of the following types of tunnel policy to direct traffic of a VPN to an SR-MPLS BE or SR-MPLS TE tunnel:
·     Tunnel binding—Bind a destination IP address to a tunnel in a tunnel policy. After the tunnel policy is applied to a VPN, the VPN traffic to the destination IP address will be forwarded by the bound tunnel.
·     Preferred tunnel—Specify an SR-MPLS TE tunnel as a preferred tunnel in a tunnel policy. After the tunnel policy is applied to a VPN, the VPN traffic will be forwarded by the preferred tunnel. This method explicitly specifies a tunnel for a VPN, facilitating traffic planning.
·     Load sharing—Specify the tunnel types (SR-MPLS BE or SR-MPLS TE tunnels) and selection order and the number of tunnels for load sharing in a tunnel policy.
For more information about tunnel policies, see MPLS Configuration Guide.
PBR
The policy-based routing (PBR) method defines a PBR policy to specify the output interface for packets that match an ACL as an SR-MPLS TE tunnel interface, and then applies the PBR policy to the incoming interface of packets. In this way, traffic is redirected to the SR-MPLS TE tunnel.
The PBR method can match the packets to be forwarded by a tunnel interface by packet destination IP address, source IP address, and protocol type. Compared with the static route method, the PBR method is more flexible but its configuration is more complicated. For more information about PBR, see policy-based routing configuration in Layer 3—IP Routing Configuration Guide.
Automatic route advertisement
Automatic route advertisement distributes the SR-MPLS TE tunnel to the IGP (OSPF or IS-IS), so the SR-MPLS TE tunnel can participate in IGP routing calculation.
Automatic route advertisement can be implemented by using the following methods:
·     IGP shortcut—Also known as AutoRoute Announce. It considers the SR-MPLS TE tunnel as a link that directly connects the tunnel ingress node (source node) and the egress node (endpoint node). Only the ingress node uses the SR-MPLS TE tunnel during IGP route calculation.
·     Forwarding adjacency—Considers the SR-MPLS TE tunnel as a link that directly connects the tunnel ingress node and the egress node, and advertises the link to the network through an IGP. Every node in the network uses the SR-MPLS TE tunnel during IGP route calculation.
As shown in Figure 1, an SR-MPLS TE tunnel exists from Device D to Device C. IGP shortcut enables only the ingress node Device D to use the SR-MPLS TE tunnel in the IGP route calculation. Device A cannot use this tunnel to reach Device C. With forwarding adjacency enabled, Device A can learn this SR-MPLS TE tunnel and transfer traffic to Device C by forwarding the traffic to Device D.
Figure 1 IGP shortcut and forwarding adjacency
Static SR-MPLS provides the following methods for configuring static segments for a destination:
·     Prefix segment method—Manually configure the incoming label, outgoing label, and next hop for the destination address prefix on each SR node.
·     Adjacency segment method—Manually configure the incoming label and next hop for the adjacency to the neighbor on each SR node.
SR-MPLS expands IGP protocols such as IS-IS and OSPF to advertise SIDs in IGP protocol packets. SR-MPLS provides the following methods for dynamically allocating and advertising SIDs:
·     Prefix SID.
·     Adjacency SID.
Prefix SID
After you configure an SID for the loopback address on each SR node, the SIDs uniquely identify the SR nodes. All SR nodes in the SR domain use an IGP to advertise their own prefix SIDs. After receiving advertised prefix SIDs, each SR node calculates the prefix SIDs to the advertisers.
The prefix SID advertisement can be one of the following types:
·     Absolute value advertisement—Each SR node advertises the prefix SID absolute value and the SRGB.
·     Index value advertisement—Each SR node advertises the prefix SID index and the SRGB.
Each SR node is assigned a globally unique index value for the node's prefix. The prefix SID an SR node allocates to a prefix equals the SRGB base of the SR node plus the index for that prefix.
The device supports only the index value advertisement in the current software release.
Adjacency SID
SR nodes use an IGP to advertise SIDs allocated to the IGP adjacencies (that is, the links to its IGP neighbors). The SIDs are used to identify the links.
The adjacency SIDs can be allocated automatically or manually.
·     Automatic adjacency SID allocation—SR nodes allocate labels in SRLBs to the IGP adjacencies as SIDs.
·     Manual adjacency SID allocation—You can assign adjacency SIDs by using absolute values or index values. If you use index values, the adjacency SID of a link is the base value of the SRLB plus the index value for the link.
SR-MPLS expands BGP to advertise prefix SIDs in BGP protocol packets. BGP uses routing policies to assign SIDs to prefixes when redistributing routes. The SIDs uniquely identify the SR nodes. All SR nodes in the SR domain use BGP to advertise their own prefix SIDs, including the SIDs and SID index values. From received advertisement packets, each SR node derives the prefix SIDs for the advertisers.
BGP prefix SIDs can be exchanged between BGP peers only through IPv4 unicast routes.
Dynamic SID allocation through BGP applies to MPLS VPN inter-AS option C networks.
The BGP Egress Peer Engineering (BGP EPE) feature assigns BGP peering SIDs to segments across ASs. The device sends BGP peering SIDs to the controller through BGP-LS extensions. The controller orchestrates IGP SIDs and BGP peering SIDs for inter-AS forwarding over optimal paths.
You can manually specify the BGP peering SIDs to be assigned to the BGP peers or peer groups or let the device randomly assign these SIDs.
BGP EPE supports the following types of BGP peering SIDs:
·     PeerNode SID—Identifies a peer node. Each BGP session is assigned a PeerNode SID. An EBGP peer session established based on a loopback interface might use multiple physical links. The PeerNode SID for the EBGP peer therefore might have multiple outgoing interfaces. The device will load-share traffic among these outgoing interfaces when it forwards the traffic based on the PeerNode SID.
·     PeerAdj SID—Identifies an adjacency to a peer. An EBGP peer session established based on a loopback interface might use multiple physical links. Each physical link will be assigned a PeerAdj SID. The device forwards traffic through a specific outgoing interface when it forwards the traffic based on a PeerAdj SID.
·     PeerNode-Adj SID—Identifies a peer node or one or multiple adjacencies to a peer.
·     PeerSet SID—Identifies a set of peers. BGP EPE supports adding a group of peers to a set and assigning the set a PeerSet SID. The device will load-share traffic among the peers in the set when it forwards the traffic based on a PeerSet SID. A PeerSet SID identifies the set of which PeerNode SIDs or PeerAdj SIDs are members.
Figure 2 BGP EPE diagram
As shown in Figure 2, BGP EPE allocates SID labels as follows:
·     ASBR 1 and ASBR 3 are directly connected through two physical links. The two ASBRs establish an EBGP peer relationship with each other through loopback interfaces. BGP EPE assigns PeerNode SID 28001 to the peer node and assigns PeerAdj SIDs 18001 and 18002 to the two physical links. Traffic between the two ASBRs will be load-shared on the two physical links when it is forwarded based on the PeerNode SID.
·     An EBGP peer relationship is established over a physical link between ASBR 1 and ASBR 5, ASBR 2 and ASBR 4, and ASBR 2 and ASBR 5. BGP EPE only assigns labels (PeerNode SIDs 28002, 28003, and 28004) to the peer nodes.
·     ASBR 4 and ASBR 5 both establish an EBGP peer relationship with ASBR 2. BGP EPE adds ASBR 4 and ASBR 5 to a BGP EPE peer set and assigns the set PeerSet SID 29001. Traffic will be sent to the devices in the peer set for load sharing when it is forwarded based on the PeerSet SID.
SIDs that BGP EPE assigns are locally significant. These SIDs are not advertised to other devices and are not affected by route types exchanged between BGP peers.
SID allocation through BGP EPE is typically used for MPLS VPN inter-AS option B.
Label forwarding entry installation based on IGP prefix SIDs
Label forwarding entries based on prefix SIDs can be static or dynamic.
·     Static label forwarding entries—The device creates local label forwarding entries based on manually configured incoming labels, outgoing labels, and next hops.
·     Dynamic label forwarding entries—The device uses the IGP to flood in the SR domain the local SRGB and the index of the prefix SID for the local loopback interface. Based on the flooded information, the other devices in the domain calculates their local label forwarding entries by using the following rules:
¡     Incoming label = Local SRGB base value + Index
¡     Outgoing label = SRGB base value of the next hop + Index
Figure 3 Creating label forwarding entries based on prefix SIDs
Figure 3 shows how dynamic label forwarding entries are created. After you assign index value 201 to loopback address 1.1.1.1/32 on Device C, Device C uses an IGP packet to advertise the index value and its local SRGB. Then, the devices calculate incoming and outgoing labels according to the previously mentioned label calculation rules.
·     Devices C calculates its incoming label, which is 16201.
·     Device B calculates its incoming label and outgoing label and creates a label forwarding entry. The incoming label is 16201. The outgoing label is 16201. The next hop is Device C.
·     Device A calculates its incoming label and outgoing label and creates a label forwarding entry. The incoming label is 16201. The outgoing label is 16201. The next hop is Device B.
Label forwarding entry installation based on BGP prefix SIDs
The device redistributes routes to BGP and assigns prefix SIDs to redistributed routes based on routing policies. Then, the device uses BGP to flood in the SR domain the prefix SIDs and the indexes of the prefix SIDs. Based on the flooded information, the other devices in the domain calculates their local label forwarding entries by using the following rules:
·     Incoming label = Local SRGB base value + Index
·     Outgoing label = Received SID
Figure 4 Creating label forwarding entries based on BGP prefix SIDs
Figure 4 shows how label forwarding entries are created. After you assign index value 201 to loopback address 1.1.1.1/32 on Device D, Device D redistributes the route of the address and assigns it an SID (16201 in this example). Then, the device uses a BGP packet to advertise the SID and index value. The devices in the SR domain calculate incoming and outgoing labels according to the previously mentioned label calculation rules and create label forwarding entries.
·     Devices D calculates its incoming label, which is 16201.
·     Device C calculates its incoming label and outgoing label and creates a label forwarding entry. The incoming label is 16201. The outgoing label is 16201. The next hop is Device D.
Label forwarding entry installation based on BGP EPE
Configure BGP EPE on border routers to assign SIDs to specific peers or peer groups.
Figure 5 Creating label forwarding entries by using BGP EPE
As shown in Figure 5, you can configure BGP EPE on Device B to assign BGP peering SIDs to EBGP neighbors Device C and Device D. BGP peering SIDs are locally significant and are not advertised to neighbors.
Label forwarding entry installation based on adjacency SIDs
When using adjacency SIDs, each device allocates a static or dynamic incoming label to the link to its neighbor. The label has local significance. Multiple devices can use the same adjacency SID.
Figure 6 Creating label forwarding entries based on adjacency SIDs
As shown in Figure 6, the devices are running the same IGP. After IGP adjacencies are established between the devices, Device A, Device B, and Device C allocates labels and creates label forwarding entries as follows:
·     Device A allocates label 203 to the link to its neighbor Device B.
·     Device B allocates label 202 to the link to its neighbor Device C.
·     Device C allocates label 201 to the link to its neighbor Device D.
·     Device A creates a label forwarding entry with incoming label 203 and next hop Device B.
·     Device B creates a label forwarding entry with incoming label 202 and next hop Device C.
·     Device C creates a label forwarding entry with incoming label 201 and next hop Device D.
SRLSP setup
You can use the following methods to create SRLSPs:
·     Manually configure an SRLSP.
To configure an SRLSP, you must specify the label stack for packets to be forwarded along the SRLSP on the ingress node. Each label in the stack corresponds to a prefix SID or adjacency SID. The system can look for the outgoing label and next hop based on the prefix SID or adjacency SID.
·     Configure SR nodes to use BGP or an IGP to dynamically establish an SRLSP.
SR nodes follow these steps to establish SRLSPs:
a.     Use BGP or an IGP to collect prefix SID information from the SR-MPLS network.
b.     Calculate the shortest paths to other SR nodes based on the collected prefix SID information and the BGP or IGP network topology.
c.     Establish SRLSPs based on the shortest paths.
·     Configure a controller to deploy SRLSP configuration to the device so the device creates SRLSPs.
For more information about controller configuration, see the user guide for the controller.
Based on the SID allocation method, SR-MPLS uses one of the following packet forwarding methods:
·     Prefix SID-based packet forwarding—The ingress node encapsulates the prefix SID for the egress node to a packet. The transit nodes forward the packet based on label forwarding entries.
·     Adjacency SID-based packet forwarding—The ingress node encapsulates the label stack that contains the adjacency SIDs of all links along the forwarding path to a packet. Each transit node uses the top label in the label stack to determine the next hop and pops the top label before forwarding the packet to the next hop.
·     Prefix and adjacency SID-based packet forwarding—The nodes use prefix SID-based packet forwarding in combination with adjacency-based packet forwarding.
Prefix SID-based packet forwarding within the same AS
Figure 7 shows how a packet is forwarded along the SRLSP from Device A to Device E based on prefix SIDs. In this example, the outgoing label for the packet is 16201 on Device A.
1.     Ingress node Device A searches for a forwarding entry for label 16201, adds outgoing label 16201 to the packet and sends the packet to the next hop (Device B).
2.     When transit node Device B receives the packet, it searches for a label forwarding entry that matches the label in the packet. Then, Device B uses the outgoing label of the matched entry (16201) to replace the label in the packet and forwards the packet to the next hop (Device C).
3.     Transit nodes Device C and Device D process the packet in the same way Device B does.
4.     When egress node Device E receives the packet, it removes the label and forwards the packet by IP address.
Figure 7 Prefix SID-based packet forwarding
Prefix SID-based packet forwarding across ASs
Figure 8 shows how a packet is forwarded along the SRLSP from Device A to Device D based on prefix SIDs. In this example, the outgoing label for the packet is 16201 on Device A.
1.     Ingress node Device A searches for a forwarding entry for label 16201, adds outgoing label 16201 to the packet, and sends the packet to the next hop (Device B).
2.     When transit node Device B receives the packet, it searches for a label forwarding entry that matches the label in the packet (16201). Then, Device B uses the outgoing label of the matched entry (16201) to replace the label in the packet and forwards the packet to the next hop (Device C).
3.     Transit nodes Device C processes the packet in the same way Device B does.
4.     When egress node Device D receives the packet, it removes the label and forwards the packet by IP address.
Figure 8 Prefix SID-based packet forwarding across ASs
BGP EPE-based packet forwarding across ASs
As shown in Figure 9, you can configure BGP EPE and an SRLSP used for the MPLS TE tunnel on Device B to steer packets to travel through Device C or Device D to Device E. In this example, packets travel from Device A through Device B and Device D to Device E. Device B uses BGP EPE to assign SID 6000 to Device D. A static SRLSP is established between Device B and Device D for the MPLS TE tunnel and Device B also assigns SID 6000 to the SRLSP.
1.     Within AS 100, source node Device A adds label 16204 to the packet according to the SRLSP, and sends the packet to Device B.
2.     When Device B receives the packet, it searches for a label forwarding entry and finds that it should forward the packet through the MPLS TE tunnel. Then, Device B removes label 16204 from the packet, and forwards the packet through the MPLS TE tunnel to Device D.
3.     Within AS 200, Device D searches for a label forwarding entry based on the SRLSP, adds label  16201 to the packet, and sends the packet to Device E.
4.     When egress node Device E receives the packet, it removes label 16201 and forwards the packet by IP address.
Figure 9 BGP EPE-based packet forwarding across ASs
Figure 10 shows how a packet is forwarded along the SRLSP from Device A to Device E based on adjacency SIDs. In this example, the label stack for the packet is configured as (200, 201, 202, and 203) on Device A.
1.     Ingress node Device A searches for a forwarding entry for the top label (200) to determine the next hop. Then, Device A adds label stack (201, 202, and 203) to the packet, and forwards the packet to the next hop (Device B).
2.     When transit node Device B receives the packet, it searches for a forwarding entry for the top label (201) to determine the next hop. Then, Device B removes the top label from the stack and forwards the packet to the next hop (Device C).
3.     When transit node Device C receives the packet, it searches for a forwarding entry for the top label (202) to determine the next hop. Then, Device C removes the top label from the stack and forwards the packet to the next hop (Device D).
4.     When transit node Device D receives the packet, it searches for a forwarding entry for the label (203) to determine the next hop. Then, Device D removes the label stack from the packet and forwards the packet to the next hop (Device E).
5.     When egress node Device E receives the packet, it forwards the packet by IP address.
Figure 10 Adjacency SID-based packet forwarding
Figure 11 shows how a packet is forwarded along the SRLSP from Device A to Device E based on prefix SIDs and adjacency SIDs. In this example, the index value for the prefix SID of Device C is 1. The prefix SIDs for Device A, Device B, and Device C are 16001, 16001, and 16001, respectively. The Adjacency SIDs that Device C and Device D allocate for the adjacent links are 16 and 17, respectively. On Device A, the label stack for the packet is (16001, 16, 17).
1.     Ingress node Device A searches for a forwarding entry for label 16001 to determine the outgoing label (16001) and next hop (Device B). Device A swaps label 16001 with 16001. Then, it adds label stack (16001, 16, 17) to the packet and sends the packet to the next hop (Device B).
2.     When transit node Device B receives the packet, it searches for a label forwarding entry that matches the top label in the label stack (16001). Then, Device B uses the outgoing label of the matched entry (16001) to replace the top label and forwards the packet to the next hop (Device C).
3.     When transit node Device C receives the packet, it removes the top label 16001 and searches for a forwarding entry for the next label (16) to determine the next hop. Then, Device C removes label 16 from the stack and forwards the packet to the next hop (Device D).
4.     When transit node Device D receives the packet, it searches for a forwarding entry for the label (17) to determine the next hop. Then, Device D removes the label stack from the packet and forwards the packet to the next hop (Device E).
Figure 11 Prefix and adjacency SID-based packet forwarding
IGP SR and LDP interworking enables SR-MPLS networks and MPLS LDP networks to communicate and cooperate for MPLS forwarding.
SR-MPLS and LDP interworking supports the following modes:
·     SR to LDP—Maps prefixes on an LDP network to SR-MPLS SIDs to forward traffic from an SR-MPLS network to an MPLS LDP network.
·     LDP to SR—Uses an IGP protocol to advertise SIDs and associates SIDs with LDP labels to forward traffic from an MPLS LDP network to an SR-MPLS network.
·     SR over LDP—Enables SR-MPLS networks to communicate through an LDP network.
SR to LDP
The SR to LDP mode defines the following roles:
·     Segment Routing Mapping Server (SRMS)—Advertises prefix-SID mappings on behalf of SR-incapable devices (LDP devices). You need to configure prefix-SID mappings on the SRMS.
·     Segment Routing Mapping Client (SRMC)—Receives prefix-SID mappings advertised by the SRMS and creates SR-MPLS label forwarding entries.
As shown in Figure 12, Device A and Device B are running SR-MPLS, and Device B, Device C, and Device D are running LDP. After Device D assigns a label for destination address 3.3.3.3/32, Device B and Device C each install an LDP label forwarding entry.
The following steps establish a mapping between the SRLSP and the LDP LSP:
1.     Device B acts as an SRMS. It assigns SID index value 201 to the IP address of loopback interface 0 on Device D (3.3.3.3/32), and then advertises an IP prefix-SID mapping TLV to Device A.
2.     Device A acts as an SRMC. After receiving the advertised mapping TLV, it creates an SR-MPLS label forwarding entry.
A mapping is established between the SRLSP and the LDP LSP.
Figure 12 SR to LDP packet forwarding
If Device A uses an SRLSP to send a packet to Device D, the packet is forwarded as follows:
1.     Ingress node Device A adds label 16201 to the packet and then sends the packet to transit node Device B.
2.     When transit node Device B receives the packet, it searches for a label forwarding entry that matches incoming label 16201. Because the entry does not have an outgoing label, Device B searches for a valid LDP outgoing label for destination address 3.3.3.3/32. Then, Device B adds the LDP label (20) to the packet as the SR outgoing label and forwards the packet to the next hop (Device C).
3.     When transit node Device C receives the packet, it searches for an LDP label forwarding entry for incoming label 20. Then, it removes the label from the packet and forwards the packet to egress node Device D.
4.     The egress node forwards the packet by IP address.
LDP to SR
As shown in Figure 13, Device C and Device D are running SR-MPLS, and Device A, Device B, and Device C are running LDP. Each device running LDP assigns a label to destination address 3.3.3.3/32 and then installs an LDP label forwarding entry.
The following steps establish an association between the SR-MPLS label and the LDP label:
1.     After you assign SID index value 201 to the IP address of loopback interface 0 on Device D (3.3.3.3/32), Device D sends an IGP protocol packet to advertise the index value and the local SRGB.
2.     After receiving the packet, Device C creates an SR-MPLS label forwarding entry.
The SR-MPLS label and the LDP label are associated on Device C.
Figure 13 LDP to SR packet forwarding
A packet from Device A to Device D is forwarded as follows:
1.     Ingress node Device A adds an LDP label (20) to the packet and forwards the packets to the next hop (Device B).
2.     Device B searches for an LDP label forwarding entry, uses 30 as the outgoing label, and forwards the packet to the next hop (Device C).
3.     Device C searches for an LDP label forwarding entry for incoming label 30 and finds no outgoing label. Because valid SR-MPLS outgoing label 16201 exists for the destination address 3.3.3.3.32, Device C uses the label (16201) as the outgoing label and forwards the packet to Device D.
4.     Egress node Device D deletes label 16201 from the packet and forwards the packet by IP address.
SR over LDP
For SR-MPLS networks to communicate across an LDP network, the SR/LDP border devices must be able to connect the SR LSP and the LDP LSP as follows:
·     SR-MPLS to LDP interworking—The border device installs SR-to-LDP label forwarding entries. For a packet from the SR-MPLS network to the LDP network, the SR-MPLS label forwarding entry on the border device does not have an outgoing label. The border device uses the outgoing label of the LDP label forwarding entry for the same destination address as the outgoing label of the packet.
·     LDP to SR-MPLS interworking—The border device installs LDP-to-SR label forwarding entries. For a packet from the LDP network to the SR-MPLS network, the LDP forwarding entry on the border device does not have an outgoing label. The border device must use the outgoing label of the SR-MPLS forwarding entry for the same destination address as the outgoing label of the packet.
Figure 14 SR over LDP diagram
As shown in Figure 14, Device A, Device B, Device D, and Device E are running SR-MPLS. After you assign index value 201 to loopback interface address 3.3.3.3/32 on Device E, Device E will advertise the index value and the local SRGB. After Device A, Device B, and Device D receive the message, they will install their respective SR-MPLS label forwarding entries. Device B, Device C, and Device D are running LDP. They allocate labels to destination address 3.3.3.3/32 to generate the LDP label forwarding entries.
A packet that Device A sends to Device E will be forwarded as follows:
1.     Ingress node Device A encapsulates label 16201 to the packet and forwards the packet to transit node Device B.
2.     Transit node Device B searches for an SR-MPLS label forwarding entry for incoming label 16201 and finds that the entry does not have an outgoing label. Because an LDP label forwarding entry with outgoing label 20 exists for the destination address (3.3.3.3/32), Device B encapsulates outgoing label 20 in the packet. Then Device B sends the packet to transit node Device C.
3.     Device C forwards the packet to Device D based on its LDP label forwarding entries. The outgoing label is 30.
4.     Device D searches for an LDP label forwarding entry for incoming label 30 and finds that the entry does not have an outgoing label. Because an SR-MPLS label forwarding entry with outgoing label 16201 exists for the destination address (3.3.3.3/32), Device B encapsulates outgoing label 16201 in the packet. Then Device D sends the packet to egress node Device E.
5.     Egress node Device E deletes the incoming label and forwards the packet by IP address.
BGP SR and LDP interworking enables SR-MPLS networks that use BGP for SID advertisement to communicate and cooperate with MPLS LDP networks.
To support assigning SIDs to SR-incapable devices in the LDP network, BGP SR and LDP interworking defines the following roles:
·     Segment Routing Mapping Server (SRMS)—Advertises prefix-SID mappings on behalf of SR-incapable devices (LDP devices). You must configure prefix-SID mappings on the SRMS.
BGP SR and LDP interworking supports the following modes:
·     SR to LDP—Uses BGP IPv4 unicast routes to map prefixes on an LDP network to SR-MPLS SIDs to forward traffic from an SR-MPLS network to an MPLS LDP network.
·     LDP to SR—Uses BGP to advertise SIDs and associates SIDs with LDP labels to forward traffic from an MPLS LDP network to an SR-MPLS network.
SR to LDP
When the device uses BGP to implement SR to LDP, it assigns SIDs to the SR-incapable devices in the LDP network according to the locally configured prefix-SID mappings. A node enabled with both SR-MPLS and LDP must act as both an SRMS and an SRMC.
As shown in Figure 15, Device A and Device B are running BGP SR, and Device B, Device C, and Device D are running LDP. After Device D assigns a label for destination address 3.3.3.3/32, Device B, Device C, and Device D each install an LDP label forwarding entry.
1.     Acting as an SRMS, Device B assigns SID index value 201 to the IP address of loopback interface 0 on Device D (3.3.3.3/32).
2.     Acting as an SRMC, Device B installs an SR label forwarding entry based on the locally configured prefix-SID mapping.
3.     Device B establishes a mapping between the SRLSP and the LDP LSP.
4.     Device B advertises the prefix SID for 3.3.3.3/32 to Device A through BGP packets. Device A installs an SR label forwarding entry based on the received BGP packets.
Figure 15 BGP SR to LDP packet forwarding
2.     When transit node Device B receives the packet, it searches for an SR label forwarding entry that matches incoming label 16201. Because the entry does not have an outgoing label, Device B searches for a valid LDP outgoing label for destination address 3.3.3.3/32. Then, Device B adds the LDP label (600127) to the packet as the SR outgoing label and forwards the packet to the next hop (Device C).
3.     When transit node Device C receives the packet, it searches for an LDP label forwarding entry for incoming label 600127. Then, it removes the label from the packet and forwards the packet to egress node Device D.
LDP to SR
As shown in Figure 16, Device C and Device D are running SR-MPLS, and Device A, Device B, and Device C are running LDP. Each device running LDP assigns a label through LDP to destination address 3.3.3.3/32 and installs an LDP label forwarding entry.
1.     After you assign SID index value 201 to the IP address of loopback interface 0 on Device D (3.3.3.3/32), Device D uses a BGP IPv4 unicast route to advertise the index value.
2.     After receiving the packet, Device C installs an SR label forwarding entry.
The SR label and the LDP label are associated on Device C.
Figure 16 LDP to BGP SR packet forwarding
TI-LFA FRR
Topology-Independent Loop-Free Alternate Fast Re-Route (TI-LFA FRR) provides link and node protection. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
To minimize traffic loss during the route reconvergence process in SR-MPLS, you can enable the FRR feature on the device directly connected to the protected link or node. The device enabled with FRR is called the Point of Local Repair (PLR). The PLR calculates the shortest path to the destination and calculates an FRR backup path at the same time, and then writes the information into the FIB table. When a protected link or node fails, traffic is rerouted through the FRR backup path on the PLR node, without the need for the network topology to reconverge, significantly reducing traffic loss. FRR has the following mechanisms:
·     Loop-Free Alternate Fast Reroute (LFA FRR)—To calculate the backup path, LFA FRR identifies a protected neighboring node (LFA node) of the PLR, enabling traffic to be forwarded to the destination node without passing through the protected link or node. In some scenarios, especially in a ring network, LFA FRR cannot calculate a backup path, making it topology dependent. According to RFC 6571, LFA FRR has a topology coverage of 80% to 90%.
·     Remote Loop-Free Alternate Fast Reroute (RLFA FRR)—To improve the topology coverage of LFA FRR, RFC 7490 defines RLFA FRR, which enables traffic to be forwarded from the PLR to an RLFA FRR node and reach the destination node without passing through the protected link or node. Compared to LFA FRR, RLFA FRR does not restrict the protective node to being a neighbor of the PLR, providing more protection possibilities and increasing the topology coverage to 95% to 99%.
·     TI-LFA FRR suitable for SRv6 and SR-MPLS—Compared to LFA FRR and RLFA FRR, TI-LFA FRR is topology independent, meaning FRR backup path calculation is not restricted by the network topology. PLR can automatically calculate a TI-LFA FRR backup path as long as a bypass forwarding path is available.
TI-LFA FRR concepts
TI-LFA FRR uses the concepts of RLFA FRR defined in RFC 7490:
·     P space—A set of nodes reachable (using pre-convergence paths) from the PLR without using the protected link or node (including equal-cost path splits). Nodes in the P space are called P nodes.Calculation of P nodes typically involves building an SPF tree with the PLR as the root node, and then identifying nodes on the SPF tree that meet the loop-free requirement.
·     Extended P space—A set of nodes reachable (using pre-convergence paths) from the neighbors of the PLR (except for the protected node) without using the protected link or node (including equal-cost path splits). The P space is a subset of the extended P space. Nodes in the extended P space are also called P nodes. Neighbor nodes of the PLR are N nodes. As shown in Figure 17, the expanded P space contains nodes Src, B, C, and D. The P nodes meet the following loop-free requirement: Distance (N, P) < Distance (N, PLR) + Distance (PLR, P).
·     Q space—A set of nodes that can reach (using pre-convergence paths) the destination without using the protected link or node (including equal-cost path splits). Nodes in the Q space are called Q nodes.
Figure 17 TI-LFA FRR concepts
As shown in Figure 18, PE 1 is the source node. P 1 is the faulty node. PE 2 is the destination node. The numbers on links represent the link costs. A data flow traverses PE 1, P 1, and PE 2. To protect data against P 1 failure, TI-LFA FRR calculates the extended P space, Q space, shortest path tree converged after P 1 fails, repair list, and backup output interface, and creates the backup forwarding entry.
TI-LFA FRR calculates the backup path by using the following steps:
1.     Calculates the extended P space: P 2.
2.     Calculates the Q space: PE 2 and P 4.
3.     Calculates the shortest path tree converged after P 1 fails: PE 1 --> P 2 --> P 4 --> PE 2.
4.     Calculates the repair list: Node label of P 2 (16030), adjacency label of P 2 to P 3 (2168), and adjacency label of P 3 to P 4 (2178).
5.     Calculates the backup output interface, that is, the output interface to the next hop after the link from PE 1 to P 1 fails.
Figure 18 TI-LFA FRR diagram
After TI-LFA FRR finishes backup path calculation, traffic will be switched to the backup path in response to a primary path failure.
As shown in Figure 19, P 2 is a P node and P 4 is a Q node. When the next hop on the primary path (P 1) fails, TI-LFA FRR switches the traffic to the backup path. The following are the detailed steps:
1.     PE 1 encapsulates a label stack to a packet according to the repair list. The labels, from the outmost to inmost, are as follows:
¡     Node label of P node P2 (16030), which equals the SRGB base value of PE 1 (nexthop of the P node) plus the SID index value of P 2.
¡     Adjacency labels from P node P2 to Q node P 4, which are 2168 and 2178.
¡     The destination's node label 16010, which equals the SRGB base value of Q node P 4 plus the SID index value of destination node PE 2.
2.     P2 receives the packet, searches for a label forwarding entry based on the outmost label, pops label 2168, and forwards the packet to P 3.
3.     P3 receives the packet, searches for a label forwarding entry based on the outmost label, pops label 2178, and forwards the packet to P 4.
4.     P4 receives the packet, and searches for a label forwarding entry based on the outmost label. Because the outgoing label is 16010 and the next hop is PE 2, P 4 encapsulates 16010 as the outmost label and forwards the packet to PE 2.
Figure 19 Data forwarding over the TI-LFA FRR backup path
As shown in Figure 20, when Device B fails, traffic to Device C will be switched to the backup path calculated by TI-LFA. After Device A finishes route convergence, traffic will be switched to the post-convergence path. If Device D and Device F have not finished route convergence and still forward traffic along the pre-convergence path, a loop is formed between Device A and Device F. The loop exists until Device D and Device F finish route convergence.
FRR microloop avoidance and SR microloop avoidance can resolve this issue. After you configure TI-LFA, Device A first switches traffic to the backup path calculated by TI-LFA when Device B fails. Then, Device A waits for Device D and Device F to finish route convergence before starting route convergence. After Device A also finishes route convergence, Device A switches the traffic to the converged route.
Figure 20 Diagram for microloop avoidance after a network failure
As shown in Figure 21, before the link between Device B and Device C recovers, traffic traverses along the backup path. After the link recovers, Device A will forward the traffic to Device B if Device A finishes route convergence before Device B. Before Device B also finishes route convergence, Device B still forwards the traffic along the backup path. A loop is formed between Device A and Device B.
SR microloop avoidance can resolve this issue. After the link recovers, SR microloop avoidance automatically calculates the optimal path from Device A to Device C and forwards traffic along the path. To forward a packet along the newly calculated path, Device A adds, for example, the adjacency SID from Device B to Device C to the packet and then sends the packet to Device B. Then, Device B forwards the packet to Device C based on the path information.
When the microloop avoidance RIB-update-delay timer expires, Device B should have finished route convergence. Device A does not add path information to packets anymore, and it forwards packets to Device C as usual.
Figure 21 Diagram for microloop avoidance after a failure recovery
·     draft-bashandy-rtgwg-segment-routing-ti-lfa-04
·     draft-ietf-spring-segment-routing-mpls-00
·     draft-ietf-spring-segment-routing-02
·     draft-ietf-isis-segment-routing-extensions-06
·     draft-ietf-spring-segment-routing-11
·     draft-ietf-ospf-segment-routing-extensions-17
·     3draft-ietf-idr-bgpls-segment-routing-epe-15
·     draft-ietf-idr-bgp-prefix-sid-19
·     RFC 7684, OSPFv2 Prefix/Link Attribute Advertisement
·     RFC 7752, North-Bound Distribution of Link-State and Traffic Engineering (TE) Information Using BGP
For BGP-based SR, the SRGB range is fixed (16000 through 24000). To use both BGP and an IGP to advertise prefix SIDs, set the SRGB range for MPLS to 16000 through 24000.
To forward IP traffic over SRLSPs, perform the following configuration tasks:
1.     Configuring segments
Select one of the following tasks:
¡     Configuring static segments
¡     Configuring IGP-based SID advertisement
2.     (Optional.) Configuring the device to prefer SRLSPs in traffic forwarding
3.     (Optional.) Configuring SR-MPLS and LDP interworking
¡     Configuring IGP SR and LDP interworking
¡     Configuring BGP SR and LDP interworking
4.     (Optional.) Configuring TI-LFA FRR
To forward MPLS TE traffic over static SRLSPs, perform the following configuration tasks:
¡     Configuring BGP-based SID advertisement
¡     Configuring BGP EPE
2.     Configuring an MPLS TE tunnel to use static SRLSPs
To forward MPLS TE traffic over explicit paths, perform the following configuration tasks:
1.     Configuring IGP-based SID advertisement
2.     Configuring an MPLS TE tunnel over an explicit-path SRLSP
To forward MPLS TE traffic over PCE-calculated SRLSPs, perform the following configuration tasks:
1.     Configuring an MPLS TE tunnel over a PCE-calculated SRLSP
2.     (Optional.) Configuring SR-MPLS and LDP interworking
3.     (Optional.) Configuring TI-LFA FRR
The global MPLS SRGB is used for prefix segments and BGP prefix SIDs. If no MPLS SRGB is configured for a protocol process, the process uses the global MPLS SRGB.
If you have configured prefix SIDs when you configure an SRGB, the SRGB must contain the configured prefix SIDs.
In the following situations, a configured SRGB takes effect after a device reboot:
·     The SRGB contains a label that is already used by another protocol. For example, the SRGB contains a label that is already used by LDP.
·     The SRGB overlaps with the label range of another protocol. For example, the SRGB for OSPF process 1 overlaps with the SRGB for IS-IS process 1.
Configuring the global MPLS SRGB
2.     Enter segment routing view.
segment-routing
3.     Configure the global MPLS SRGB.
global-block minimum-value maximum-value
By default, the global MPLS SRGB is from 16000 to 24000.
Configuring the MPLS SRGB for IS-IS
2.     Enter IS-IS view.
isis process-id
3.     Configure the MPLS SRGB.
segment-routing global-block minimum-value maximum-value
By default, the MPLS SRGB is from 16000 to 24000.
Configuring the MPLS SRGB for OSPF
2.     Enter OSPF view.
ospf process-id
The segment routing local block (SRLB) is the range of local labels dedicated for SR-MPLS adjacency SIDs.
Before configuring the MPLS SRLB, use the display mpls label command to display MPLS label usage information. Make sure that all labels in the specified range are idle. If a label in the range is not idle, the configured MPLS SRLB takes effect only after you save the running configuration and reboot the device. For more information about the display mpls label command, see MPLS Command Reference.
segment-routing
3.     Configure the MPLS SRLB.
local-block minimum-value maximum-value
By default, the MPLS SRLB is from 15000 to 15999.
Before you configure static segments for a static SRLSP, perform the following tasks:
·     Determine the ingress node, transit nodes, and egress node of the static SRLSP.
·     Determine the incoming label for the adjacency segment from a node to next hop of the node. Determine the incoming label of the prefix segment for the destination IP address on each node. On a device, a static SRLSP, a static LSP, and a static CRLSP cannot use the same incoming label. For more information about CRLSP, see MPLS TE configuration in MPLS Configuration Guide.
·     Enable MPLS on all nodes and interfaces that will participate in MPLS forwarding. For information about enabling MPLS, see MPLS basics configuration in MPLS Configuration Guide.
This task is required on all nodes of a static SRLSP.
Multiple static SRLSPs can share an adjacency segment.
If you specify the next hop address for a static adjacency segment, make sure the following requirements are met:
·     The device has a route to the next hop address.
·     MPLS is enabled on the output interface of the route.
If you specify an output interface for a static adjacency segment, make sure the following requirements are met:
·     The interface is up.
·     The interface can receive direct routes.
·     MPLS is enabled on the interface.
A static adjacency segment must use a different incoming label than existing static LSPs, static PWs, and static CRLSPs. If not, the configured adjacency segment is unavailable. The adjacency segment cannot become available even if you change the incoming label of the static LSP, static PW, or static CRLSP. To resolve this problem, you must delete the existing adjacency segment and configure a new one with a different incoming label.
2.     Configure a static adjacency segment.
static-sr-mpls adjacency adjacency-path-name in-label label-value { nexthop ip-address | outgoing-interface interface-type interface-number }
The next hop address for a static adjacency segment cannot be a local public IP address.
Multiple static SRLSPs to the same destination can share a prefix segment.
A prefix segment must use the next hop or output interface of the optimal route (non-BGP route) to the destination address of the prefix segment. You can configure multiple prefix segments to the destination address for load sharing if the optimal route has more than one next hop or output interface. To avoid configuration failure, make sure all prefix segments use the same prefix segment name and incoming label.
If you specify only the prefix-path-name argument, the undo static-sr-mpls prefix command deletes all prefix segments with the specified name. If you specify all parameters, only the prefix segment that matches the specified name, destination IP address, and next hop or output interface is deleted.
2.     Configure a static prefix segment.
static-sr-mpls prefix prefix-path-name destination ip-address { mask-length | mask } in-label in-label-value [ { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value ]
The next hop address for a static prefix segment cannot be a local public IP address.
GP-based prefix SID advertisement tasks at a glance
Perform the following tasks on each node along an SRLSP:
1.     Configuring the IGP to support SR-MPLS
2.     Configuring prefix SIDs
3.     Configuring MPLS SRGBs
IGP-based adjacency SID advertisement tasks at a glance
2.     Enabling SR-MPLS adjacency label allocation for the IGP
The device will allocate SIDs to adjacencies randomly.
3.     (Optional.) Assigning adjacency SIDs
You can assign adjacency SIDs to adjacencies manually.
4.     Configuring the MPLS SRLB
Before you configure IGP-based SID advertisement, perform the following tasks:
·     Determine the ingress node, transit nodes, and egress node of an SRLSP.
·     Determine the SIDs, MPLS SRGBs, and MPLS SRLBs for nodes.
·     Enable MPLS on all nodes and interfaces that will participate in MPLS forwarding. For information about enabling MPLS, see basic MPLS configuration in MPLS Configuration Guide.
For SR-MPLS to take effect, perform the following tasks before configuring the IGP to support SR-MPLS:
·     If the IGP is IS-IS, set the cost style to wide, compatible, or wide-compatible. For more information about the cost style, see IS-IS configuration in Layer 3IP Routing Configuration Guide.
·     If the IGP is OSPF, enable opaque LSA reception and advertisement capability. For more information about the capability, see OSPF configuration in Layer 3IP Routing Configuration Guide.
Configuring IS-IS to support SR-MPLS
isis process-id
3.     Enter IS-IS IPv4 unicast address family view.
address-family ipv4
4.     Enable SR-MPLS.
segment-routing mpls
By default, SR-MPLS is disabled.
Configuring OSPF to support SR-MPLS
2.     Enter OSPF view.
ospf process-id
3.     Enable SR-MPLS.
Configuring a prefix SID in loopback interface view binds the SID with the IP address of the loopback interface.
To configure a prefix SID, use one of the following methods:
·     Specify an absolute value in the SRGB. The absolute value is used as the prefix SID.
·     Specify an index value. The sum of the index value and the SRGB base value is used as the prefix SID. The prefix SID must be in the SRGB.
To use a prefix SID for a group of SR nodes in anycast scenarios, specify the n-flag-clear keyword to set the Node-SID flag bit of the prefix SID to 0.
To configure an IS-IS prefix SID, you must enable an IS-IS process on the loopback interface.
A configured OSPF prefix SID takes effect only if the OSPF process enabled on the loopback interface is the same as the OSPF process associated with the prefix SID.
Configuring an IS-IS prefix SID
2.     Enter loopback interface view.
interface loopback interface-number
3.     Configure an IS-IS prefix SID.
isis prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
By default, no IS-IS prefix SID is configured.
Configuring an OSPF prefix SID
3.     Configure an OSPF prefix SID.
ospf process-id prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
By default, no OSPF prefix SID is configured.
For this feature to take effect, you must enable SR-MPLS.
Enabling SR-MPLS adjacency label allocation for IS-IS
isis process-id
address-family ipv4
4.     Enable SR-MPLS adjacency label allocation.
segment-routing adjacency enable
By default, SR-MPLS adjacency label allocation is disabled.
Enabling SR-MPLS adjacency label allocation for OSPF
2.     Enter OSPF view.
ospf process-id
3.     Enable SR-MPLS adjacency label allocation.
After you enable SR-MPLS adjacency label allocation, the device randomly allocates adjacency SIDs to the links to its IGP neighbors. If the link to an IGP neighbor flaps, the adjacency SID of the link keeps changing. For a link to always use the same adjacency SID, use this feature to assign a specific adjacency SID to the link.
To assign adjacency SIDs by using absolute values, make sure the SIDs are in the label range of the SRLB. To assign adjacency SIDs by using index values, make sure the index values plus the base value of the SRLB are in the label range of the SRLB.
The assigned adjacency SIDs take effect after you enable SR-MPLS and SR-MPLS adjacency label allocation.
Before assigning adjacency SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as adjacency SIDs. Make sure the labels are in Idle state.
A label that is not in Idle state is being used by another protocol. If you assign it to a link as an adjacency SID, the adjacency SID is not available even if the status of the label changes to Idle later. To use the adjacency SID, you must remove the adjacency SID assignment and assign the adjacency SID again.
Assigning adjacency SIDs to IS-IS adjacencies
2.     Enter interface view.
3.     Assign an adjacency SID to an IS-IS adjacency.
isis adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
By default, an IS-IS adjacency does not have an adjacency SID.
Assigning adjacency SIDs to OSPF adjacencies
3.     Assign an adjacency SID to an OSPF adjacency.
ospf adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
By default, an OSPF adjacency does not have an adjacency SID.
1.     Configuring BGP to support SR-MPLS
2.     Configuring BGP prefix SIDs
3.     (Optional.) Specifying the type of label to advertise to the penultimate hop
Before you configure BGP-based SID advertisement, perform the following tasks:
·     Determine the index value for the prefix SID of each node:
2.     Enable BGP and enter BGP instance view.
3.     Create the BGP IPv4 unicast address family and enter its view.
4.     Enable SR-MPLS.
To configure a BGP prefix SID, use the following methods:
·     Instead of specifying a routing policy for route redistribution, use the SID advertised by the IGP as the BGP prefix SID.
·     Specify a routing policy for route redistribution. Set the index value for the prefix SID in the routing policy to define the binding between the SID and the prefix.
To use BGP routes to exchange prefix SIDs, you must enable BGP peers to exchange labeled routes.
Configuring the device to use the SIDs advertised by the IGP
1.     Configure the IGP to support SR-MPLS.
For more information, see "Configuring the IGP to support SR-MPLS."
2.     Configure prefix SIDs.
For more information, see "Configuring prefix SIDs."
3.     Enter system view.
4.     Enter BGP instance view.
5.     Enter BGP IPv4 unicast address family view.
6.     Redistribute routes from IS-IS or OSPF.
import-route { isis | ospf } process-id
Specifying a routing policy for route redistribution
3.     Enter BGP IPv4 unicast address family view.
4.     Redistribute routes from IS-IS or OSPF and apply a routing policy to the redistributed routes.
import-route { isis | ospf } process-id route-policy route-policy-name
5.     Set the index value for the prefix SID:
a.     Return to BGP instance view.
b.     Return to system view.
c.     Enter the routing policy view.
d.     Specify a label index value.
apply label-index index-value
By default, a routing policy does not have a label index value.
As a best practice, configure the egress node to advertise an implicit null label to the penultimate hop if the penultimate hop supports PHP.
If you want to simplify packet forwarding on egress but keep labels to determine QoS policies, configure the egress node to advertise an explicit null label to the penultimate hop.
Use non-null labels only in particular scenarios. For example, when OAM is configured on the egress node, the egress node can get the OAM function entity status only through non-null labels. In this case, the egress node assigns an SID to the penultimate hop based on the prefix SID information in the BGP IPv4 unicast route.
If you change the type of label for the device to advertise to the penultimate hop, the device will close all SRLSPs established based on BGP IPv4 unicast routes. Then, the device will re-establish SRLSPs, using the new label type.
4.     Specify the type of label for the device to advertise to the penultimate hop when the device acts as the egress in an SR-MPLS network.
segment-routing label-advertise { explicit-null | non-null }
By default, the device advertises an implicit null label of 3 to the penultimate hop when it acts as the egress in an SR-MPLS network.
Configuring BGP EPE
About BGP EPE
BGP EPE assigns BGP peering SIDs to segments across ASs. The device sends BGP peering SIDs to the controller through BGP-LS extensions. The controller orchestrates IGP SIDs and BGP peering SIDs for inter-AS forwarding over optimal paths.
After you configure BGP EPE on a device, the device assigns SIDs to connected BGP peers or peer groups to identify the BGP neighbors or links.
Configuring SID allocation through BGP EPE
When you configure BGP EPE, follow these restrictions and guidelines:
·     By default, a BGP peering SID is node type.
·     If you do not specify a SID value or a routing policy when enabling BGP EPE, the system will assign labels to BGP peers randomly.
·     BGP EPE must be used together with MPLS TE, or static SRLSP. The MPLS TE tunnel requires using a static SRLSP. The outgoing label of the static SRLSP must be the same as the label specified during BGP EPE configuration.
When you use BGP EPE to apply a routing policy to a peer or peer group, follow these restrictions and guidelines:
·     You can use the apply label-value command to assign a SID value but cannot use the apply label-index command to assign a label index value.
·     You cannot apply a routing policy to assign the same label to multiple BGP peers or peer groups when you assign a PeerNode SID, PeerAdj SID, or PeerNode-Adj SID to the BGP peers or peer groups.
·     You can apply a routing policy to assign the same label to multiple BGP peers or peer groups only when you assign a PeerSet SID to the BGP peers or peer groups.
·     You can use if-match interface as a filtering condition only when you assign a PeerAdj SID to a BGP peer or peer group.
Before assigning BGP-EPE SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as BGP-EPE SIDs. Make sure the labels are in Idle state. A label that is not in Idle state is being used by another protocol. If you assign it to a peer or peer group as a BGP-EPE SID, the BGP-EPE SID is not available even if the status of the label changes to Idle later. To use the BGP-EPE SID, you must remove the BGP-EPE SID assignment and assign the BGP-EPE SID again.
3.     Enable BGP EPE and specify a routing policy for the peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } egress-engineering [ adjacency | node-adjacency | set ] [ label label-value | route-policy policy-name ]
By default, BGP EPE is disabled.
4.     (Optional.) Configure the label value in the routing policy.
a.     Return to system view.
b.     Enter the routing policy view.
c.     Specify a label value.
apply label-value label-value
By default, no label value is specified.
Configuring a BGP EPE peer set
If a device has established BGP peer relationships with multiple devices, you can manually add the BGP peers to a BGP EPE peer set and assign a PeerSet SID to the set. Then, the device can send traffic to the peers in the set for load sharing when it forwards the traffic based on the PeerSet SID.
Before adding a peer or peer group to a BGP EPE peer set, you must enable BGP EPE for the peer or peer group.
3.     Create a BGP EPE peer set.
egress-engineering peer-set peer-set-name [ label label-value ]
4.     Add a peer or peer group to the BGP EPE peer set.
peer { group-name | ipv4-address [ mask-length ] } peer-set peer-set-name
By default, a peer or peer group does not belong to a BGP EPE peer set.
This feature enables the device to preferentially use SRLSPs to forward traffic when both SRLSPs and LDP LSPs are available for traffic forwarding. If you do not configure this feature, the device prefers to use LDP LSPs for traffic forwarding.
This feature takes effect only when SR-MPLS is enabled and SRLSPs use prefix SIDs.
Configuring the device to prefer SRLSPs established by IS-IS in traffic forwarding
isis process-id
3.     Configure the device to prefer SRLSPs in traffic forwarding.
segment-routing sr-prefer [ prefix-list prefix-list-name ]
By default, the device prefers LDP LSPs to SRLSPs.
Configuring the device to prefer SRLSPs established by OSPF in traffic forwarding
2.     Enter OSPF view.
ospf process-id
Tasks at a glance
1.     Enable MPLS TE.
Perform this task on all nodes that the MPLS TE tunnel traverses. For more information, see MPLS TE configuration in MPLS Configuration Guide.
2.     Configuring a static SRLSP
Perform this task on the ingress node of the MPLS TE tunnel.
3.     Create the tunnel interface and specify the destination address of the tunnel.
Perform this task on the ingress node of the MPLS TE tunnel. For more information, see MPLS TE configuration in MPLS Configuration Guide.
4.     Binding a static SRLSP to an MPLS TE tunnel interface
5.     Configure static routes or policy-based routing to direct traffic to the MPLS TE tunnel.
2.     Configure a static SRLSP.
static-sr-mpls lsp lsp-name out-label out-label-value&<1-n>
2.     Enter MPLS TE tunnel interface view.
interface tunnel tunnel-number [ mode mpls-te ]
3.     Set the MPLS TE tunnel establishment mode to static.
mpls te signaling static
By default, MPLS TE uses RSVP-TE to establish a tunnel.
For more information about this command, see MPLS Command Reference.
4.     Bind a static SRLSP to the MPLS TE tunnel interface.
mpls te static-sr-mpls lsp-name [ backup ]
By default, an MPLS TE tunnel does not use a static SRLSP.
The specified SRLSP must be already created by using the static-sr-mpls lsp command.
You can specify the backup keyword to bind a backup static SRLSP only if both the main and backup SRLSPs are established by using the adjacency segment method.
Tasks at a glance
Perform the following tasks on the ingress node of the MPLS TE tunnel:
1.     Configuring an explicit path for the MPLS TE tunnel
2.     Creating an MPLS TE tunnel interface and specifying the destination address.
3.     Configuring an MPLS TE tunnel over the explicit path
Before you configure an MPLS TE tunnel over an explicit-path SRLSP, perform the following tasks:
·     Determine the ingress node of the SRLSP.
·     Determine the SIDs of the nodes along the SRLSP.
2.     Create an explicit path and enter its view.
explicit-path path-name
3.     Add or modify a node in the explicit path.
¡     Specify a node by its label.
nextsid [ index index-number ] label label-value type { adjacency | prefix }
For an adjacency or prefix SID node, specify the label assigned to the next hop for the label-value argument.
¡     Specify a node by its IP address.
nexthop [ index index-number ] ip-address [ exclude | include [ loose | strict ] ]
By default, an explicit path does not include any node.
interface tunnel tunnel-number mode mpls-te
3.     Set the MPLS TE tunnel establishment mode to SR.
mpls te signaling segment-routing
4.     Configure the MPLS TE tunnel interface to use an explicit path.
mpls te path preference value explicit-path path-name [ no-cspf ]
By default, MPLS TE uses the calculated path to establish an SRLSP.
Tasks at a glance
1.     Enabling MPLS TE
2.     Configuring PCE discovery
Perform this task on all nodes that the MPLS TE tunnel traverses. You can manually specify PCEs or configure dynamic PCE discovery. For more information, see MPLS TE configuration in MPLS Configuration Guide.
3.     Establishing a PCEP session that supports SR.
Perform this task on all nodes that the MPLS TE tunnel traverses. Set the PCEP device type to active stateful. For more information, see MPLS TE configuration in MPLS Configuration Guide.
4.     Creating an MPLS TE tunnel interface and specifying the destination address.
5.     Configuring an MPLS TE tunnel interface to use PCE to calculate the SRLSP
4.     Configure the MPLS TE tunnel interface to use PCE to calculate the SRLSP.
¡     Establish an SRLSP by using the path calculated by PCEs.
mpls te path preference value dynamic [ pce [ ip-address ]&<0-8> ]
By default, the automatically calculated path is used to establish an SRLSP.
¡     Establish an SRLSP by using SRLSP delegation.
mpls te delegation
By default, SRLSP delegation is disabled.
Restrictions and guidelines for IGP SR and LDP interworking
To configure IGP SR and LDP interworking, make sure the SRLSP uses prefix SIDs.
In the current software version, the SRMS and SRMC devices support only IS-IS-based SR-MPLS.
SR to LDP tasks at a glance
SRMS tasks at a glance
Perform the following tasks on an SRMS:
1.     Enabling SR-MPLS on the SRMS:
a.     Configuring the IGP to support SR-MPLS
b.     Configuring prefix SIDs
c.     Configuring MPLS SRGBs
2.     Enabling advertisement of locally configured prefix-SID mappings
3.     Configuring prefix-SID mappings
SRMC tasks at a glance
Perform the following tasks on each SRMC:
1.     Enabling SR-MPLS on the SRMC:
2.     Enabling reception of advertised prefix-SID mappings
LDP to SR tasks at a glance
SR over LDP tasks at a glance
Prerequisites for SR-MPLS and LDP internetworking
Before you configure SR-MPLS and LDP internetworking, perform the following tasks:
·     Determine the index value for the prefix SID of each node.
Configure this feature on the device that acts as the SRMS.
Configuring IS-IS to advertise locally configured prefix-SID mappings
isis process-id
address-family ipv4
4.     Enable advertisement of locally configured prefix-SID mappings.
segment-routing mapping-server advertise-local
By default, advertisement is disabled for locally configured prefix-SID mappings.
Configuring OSPF to advertise locally configured prefix-SID mappings
2.     Enter OSPF view.
ospf process-id
3.     Enable advertisement of locally configured prefix-SID mappings.
The specified prefixes must not belong to any existing prefix-SID mappings.
Before you configure prefix-SID mappings in bulk, plan the number of mappings carefully.
2.     Enable SR and enter segment routing view.
segment-routing
3.     Configure a prefix-SID mapping.
mapping-server prefix-sid-map ip-address mask-length start-value [ range range-value ] [ attached ]
By default, no prefix-SID mappings exist.
If you specify a value greater than 65535 for the range-value argument, the prefix-SID mappings cannot be advertised through IS-IS or OSPF.
Configure this feature on the devices that act as the SRMCs.
Configuring IS-IS to receive advertised prefix-SID mappings
isis process-id
address-family ipv4
4.     Enable reception of prefix-SID mappings.
segment-routing mapping-server receive
By default, reception of prefix-SID mappings is enabled.
Configuring OSPF to receive advertised prefix-SID mappings
2.     Enter OSPF view.
ospf process-id
3.     Enable reception of prefix-SID mappings.
Restrictions and guidelines for BGP SR and LDP interworking
To configure BGP SR and LDP interworking, make sure the SRLSP uses prefix SIDs.
An SR network node that is enabled with both SR-MPLS and LDP must act as both an SRMS and an SRMC.
1.     Configuring BGP SR:
¡     Configuring BGP to support SR-MPLS
¡     Configuring BGP prefix SIDs
2.     Enabling prefix-SID mappings
Perform this task on SRMSs.
4.     Enable prefix-SID mappings.
segment-routing prefix-sid-map
By default, prefix-SID mappings are disabled.
Restrictions and guidelines for TI-LFA FRR
TI-LFA FRR is not supported on static SR networks.
In SR-MPLS and LDP interworking scenarios, you must configure the device to prefer the IS-IS or OSPF SRLSP to the LDP LSP. This rule ensures the effectiveness of the TI-LFA FRR backup next hop.
By default, no backup path can be calculated by TI-LFA FRR if the next hops of equal-cost primary paths on the source node are different. To address this issue, you can add all equal-cost primary paths on the source node to the same SRLG.
As shown in Figure 22, three equivalent paths Link 1, Link 2, and Link 3 are available from source node Device A to destination node Device E, with their next hops different. For TI-LFA FRR to calculate backup paths, you must add Link 1, Link 2, and Link 3 to the same SRLG.
Figure 22 Using TI-LFA FRR to calculate backup paths in the IS-IS ECMP scenario
TI-LFA FRR tasks at a glance
1.     Enabling TI-LFA FRR
2.     (Optional.) Disabling an interface from participating in TI-LFA calculation
On the source node, disable TI-LFA on the route's output interface to the next hop on the primary path.
3.     (Optional.) Configuring microloop avoidance
Enabling TI-LFA FRR
Enabling TI-LFA FRR for IS-IS
isis process-id
address-family ipv4
4.     Enable LFA FRR for IS-IS.
fast-reroute lfa [ level-1 | level-2 ]
By default, LFA FRR is disabled for IS-IS.
5.     Enable TI-LFA FRR for IS-IS.
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
By default, TI-LFA FRR is disabled for IS-IS.
6.     (Optional.) Set the priority for the FRR backup path selection policy.
fast-reroute tiebreaker { lowest-cost | node-protecting | srlg-disjoint } preference preference [ level-1 | level-2 ]
By default, the priority values of the lowest-cost, node-protection, and SRLG-disjoint backup path selection policies are 20, 40, and 10, respectively.
Enabling TI-LFA FRR for OSPF
2.     Enter OSPF view.
ospf process-id
3.     Enable LFA FRR for OSPF.
fast-reroute { lfa [ abr-only ] | route-policy route-policy-name }
By default, LFA FRR is disabled for OSPF.
4.     Enable TI-LFA FRR for OSPF.
By default, TI-LFA FRR is disabled for OSPF.
5.     (Optional.) Set the priority for the FRR backup path selection policy.
fast-reroute tiebreaker { lowest-cost | node-protecting } preference preference
By default, the priority values of the lowest-cost and node-protection backup path selection policies are 20 and 40, respectively.
Disabling an IS-IS interface from participating in TI-LFA calculation
2.     Enter the view of IS-IS interface.
3.     Disable the interface from participating in TI-LFA calculation.
isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
By default, an IS-IS interface participates in TI-LFA calculation.
Disabling an OSPF interface from participating in TI-LFA calculation
2.     Enter the view of OSPF interface.
ospf fast-reroute ti-lfa disable
By default, an OSPF interface participates in TI-LFA calculation.
The following microloop avoidance methods are available:
·     FRR microloop avoidance—Provides microloop avoidance after a network failure.
On a network deployed with TI-LFA FRR, when a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. If devices on the backup path have not finished route convergence, a loop is formed between the source node (failed node or the previous node along the link) and a device on the backup path. The loop exists until the devices on the backup path finish route convergence.
To resolve this issue, FRR microloop avoidance first switches traffic to the backup path calculated by TI-LFA after the node or link failure. Then, the source node waits for the nodes on the backup path to finish route convergence before starting route convergence.
·     SR microloop avoidance—Provides microloop avoidance both after a network failure and after a failure recovery.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of non-simultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
To leave sufficient time for IGP to finish route convergence, set the SR microloop avoidance RIB-update-delay timer. Before the timer expires, failure relevant devices will forward traffic along the specified path. After the timer expires, IGP route convergence should have finished and traffic will traverse along the IGP-calculated path.
If you configure both FRR microloop avoidance and SR microloop avoidance, SR microloop avoidance takes effect.
Configuring FRR microloop avoidance for IS-IS
isis process-id
address-family ipv4
4.     Enable FRR microloop avoidance for IS-IS.
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
By default, FRR microloop avoidance is disabled for IS-IS.
5.     (Optional.) Set the FRR microloop avoidance RIB-update-delay time.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
By default, the FRR microloop avoidance RIB-update-delay time is 5000 ms.
Configuring FRR microloop avoidance for OSPF
2.     Enter OSPF view.
ospf process-id
3.     Enable FRR microloop avoidance for OSPF.
By default, FRR microloop avoidance is disabled for OSPF.
4.     (Optional.) Set the FRR microloop avoidance RIB-update-delay time.
Configuring SR microloop avoidance for IS-IS
isis process-id
address-family ipv4
4.     Enable SR microloop avoidance for IS-IS.
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
By default, SR microloop avoidance is disabled for IS-IS.
5.     (Optional.) Set the SR microloop avoidance RIB-update-delay time.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
By default, the SR microloop avoidance RIB-update-delay time is 5000 ms.
Display and maintenance commands for SR-MPLS
Display BGP EPE segment information.
display bgp [ instance instance-name ] egress-engineering ipv4 [ ipv4-address ] [ verbose ]
Display BGP EPE peer set information.
display bgp [ instance instance-name ] egress-engineering peer-set [ peer-set-name ]
Display BGP SR label ranges.
display bgp [ instance instance-name ] segment-routing label-range
Display BGP SR prefix-SID mappings.
display bgp [ instance instance-name ] segment-routing prefix-sid-map [ ip-address mask-length | verbose ]
Display IS-IS SR adjacency segment information.
display isis segment-routing adjacency [ process-id ]
Display IS-IS SRGB information.
display isis segment-routing global-block [ level-1 | level-2 ] [ process-id ]
Display IS-IS SR prefix-SID mappings.
display isis segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
Display static SRLSP and adjacency segment information.
display mpls static-sr-mpls { lsp [ lsp-name ] | adjacency [ adjacency-path-name ] }
Display static prefix segment information.
display mpls static-sr-mpls prefix [ path lsp-name | destination ip-address [ mask | mask-length ] ]
Display OSPF SRGB information.
display ospf [ process-id ] [ area area-id ] segment-routing global-block
Display OSPF SR prefix-SID mappings.
display ospf segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
Display SR label block information.
display segment-routing label–block [ protocol { isis | ospf } ]
Display prefix-SID mappings.
display segment-routing mapping-server prefix-sid-map [ ip-address mask-length | verbose ]
SR-MPLS configuration examples
Example: Configuring an SR-based MPLS TE tunnel over an explicit path
As shown in Figure 23, Router A, Router B, Router C, and Router D are running IS-IS.
Configure dynamic SID allocation on loopback interfaces of the routers. Then, create an explicit path from Router A to Router D and configure the MPLS TE tunnel interface to use SR to establish an MPLS TE tunnel over the explicit path.
Figure 23 Network diagram
Device
IP address
Device
IP address
Router A
Loop1
1.1.1.1/32
Router B
Loop1
2.2.2.2/32
GE1/0/1
10.0.0.1/24
GE1/0/1
10.0.0.2/24
GE1/0/2
11.0.0.1/24
Router C
Loop1
3.3.3.3/32
Router D
Loop1
4.4.4.4/32
GE1/0/1
11.0.0.2/24
GE1/0/1
12.0.0.2/24
GE1/0/2
12.0.0.1/24
GE1/0/2
100.1.2.1/24
1.     Configure IP addresses and masks for interfaces. (Details not shown.)
2.     Configure LSR IDs, and enable MPLS and MPLS TE:
# Configure Router A.
[RouterA] mpls lsr-id 1.1.1.1
[RouterA] mpls te
[RouterA-te] quit
[RouterA-GigabitEthernet1/0/1] mpls enable
# Configure Router B.
[RouterB] mpls lsr-id 2.2.2.2
[RouterB] mpls te
[RouterB-te] quit
[RouterB-GigabitEthernet1/0/1] mpls enable
[RouterB-GigabitEthernet1/0/2] mpls enable
# Configure Router C.
[RouterC] mpls lsr-id 3.3.3.3
[RouterC] mpls te
[RouterC-te] quit
[RouterC-GigabitEthernet1/0/1] mpls enable
[RouterC-GigabitEthernet1/0/2] mpls enable
# Configure Router D.
[RouterD] mpls lsr-id 4.4.4.4
[RouterD] mpls te
[RouterD-te] quit
[RouterD-GigabitEthernet1/0/1] mpls enable
[RouterD-GigabitEthernet1/0/1] quit
3.     Configure IS-IS on the routers to achieve network level connectivity and set the IS-IS cost style to wide:
[RouterA] isis 1
[RouterA-isis-1] network-entity 00.0000.0000.0001.00
[RouterA-isis-1] cost-style wide
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] mpls te enable
[RouterA-isis-1] quit
[RouterA-GigabitEthernet1/0/1] isis enable 1
[RouterA] interface loopback 1
[RouterA-LoopBack1] isis enable 1
[RouterA-LoopBack1] quit
[RouterB] isis 1
[RouterB-isis-1] network-entity 00.0000.0000.0002.00
[RouterB-isis-1] cost-style wide
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] mpls te enable
[RouterB-isis-1] quit
[RouterB-GigabitEthernet1/0/1] isis enable 1
[RouterB-GigabitEthernet1/0/2] isis enable 1
[RouterB] interface loopback 1
[RouterB-LoopBack1] isis enable 1
[RouterB-LoopBack1] quit
[RouterC] isis 1
[RouterC-isis-1] network-entity 00.0000.0000.0003.00
[RouterC-isis-1] cost-style wide
[RouterC-isis-1] is-level level-1
[RouterC-isis-1] mpls te enable
[RouterC-isis-1] quit
[RouterC-GigabitEthernet1/0/1] isis enable 1
[RouterC-GigabitEthernet1/0/2] isis enable 1
[RouterC] interface loopback 1
[RouterC-LoopBack1] isis enable 1
[RouterC-LoopBack1] quit
[RouterD] isis 1
[RouterD-isis-1] network-entity 00.0000.0000.0004.00
[RouterD-isis-1] cost-style wide
[RouterD-isis-1] is-level level-1
[RouterD-isis-1] mpls te enable
[RouterD-isis-1] quit
[RouterD-GigabitEthernet1/0/1] isis enable 1
[RouterD] interface gigabitethernet 1/0/2
[RouterD-GigabitEthernet1/0/2] isis enable 1
[RouterD-GigabitEthernet1/0/2] quit
[RouterD] interface loopback 1
[RouterD-LoopBack1] isis enable 1
[RouterD-LoopBack1] quit
4.     Enable SR-MPLS on the routers:
[RouterA] isis 1
[RouterA-isis-1] address-family ipv4
[RouterA-isis-1-ipv4] segment-routing mpls
[RouterA-isis-1-ipv4] quit
[RouterB] isis 1
[RouterB-isis-1] address-family ipv4
[RouterB-isis-1-ipv4] segment-routing mpls
[RouterB-isis-1-ipv4] quit
[RouterC] isis 1
[RouterC-isis-1] address-family ipv4
[RouterC-isis-1-ipv4] segment-routing mpls
[RouterC-isis-1-ipv4] quit
[RouterD] isis 1
[RouterD-isis-1] address-family ipv4
[RouterD-isis-1-ipv4] segment-routing mpls
[RouterD-isis-1-ipv4] quit
5.     Configure IS-IS prefix SIDs for the routers:
[RouterA-LoopBack1] isis prefix-sid index 10
[RouterB-LoopBack1] isis prefix-sid index 20
[RouterC-LoopBack1] isis prefix-sid index 30
[RouterD-LoopBack1] isis prefix-sid index 40
6.     Configure an explicit path on Router A.
# Create an explicit path to Router D and specify the nodes by their prefix labels.
[RouterA] explicit-path 1
[RouterA-explicit-path-1] nextsid label 16020 type prefix
[RouterA-explicit-path-1] nextsid label 16030 type prefix
[RouterA-explicit-path-1] nextsid label 16040 type prefix
[RouterA-explicit-path-1] quit
7.     Configure an MPLS TE tunnel on Router A:
# Configure MPLS TE tunnel interface Tunnel 1.
[RouterA] interface tunnel 1 mode mpls-te
[RouterA-Tunnel1] ip address unnumbered interface LoopBack 1
# Set the tunnel destination address to the IP address of the loopback interface on Router D.
[RouterA-Tunnel1] destination 4.4.4.4
# Configure the MPLS TE tunnel interface to use SR to establish a tunnel over the explicit path.
[RouterA-Tunnel1] mpls te signaling segment-routing
[RouterA-Tunnel1] mpls te path preference 1 explicit-path 1
[RouterA-Tunnel1] quit
# Display MPLS LSP information on Router A.
[RouterA] display mpls lsp
FEC                         Proto       In/Out Label    Out Inter/NHLFE/LSINDEX
10.0.0.2                    Local       -/-             GE1/0/1
Tunnel1                     Local       -/-             NHLFE6
1.1.1.1/32                  ISIS        16010/-         -
2.2.2.2/32                  ISIS        16020/3         GE1/0/1
2.2.2.2/32                  ISIS        -/3             GE1/0/1
3.3.3.3/32                  ISIS        16030/16030     GE1/0/1
3.3.3.3/32                  ISIS        -/16030         GE1/0/1
4.4.4.4/32                  ISIS        16040/16040     GE1/0/1
4.4.4.4/32                  ISIS        -/16040         GE1/0/1
1.1.1.1/1/17700             SR-TE       -/16030         GE1/0/1
                                          16040
# Display information about MPLS TE tunnel interface Tunnel 1 on Router A.
[RouterA] display mpls te tunnel-interface tunnel 1
Tunnel Name            : Tunnel 1
Tunnel State           : Up (Main CRLSP up.
                             Main Shared-resource CRLSP down.
                             Backup CRLSP down.)
Tunnel Attributes      :
  LSP ID               : 17700           Tunnel ID            : 1
  Admin State          : Normal
  Ingress LSR ID       : 1.1.1.1         Egress LSR ID        : 4.4.4.4
  Signaling            : Segment-Routing Static CRLSP Name    : -
  Resv Style           : SE
  Tunnel mode          : -
  Reverse-LSP name     : -
  Reverse-LSP LSR ID   : -               Reverse-LSP Tunnel ID: -
  Class Type           : CT0             Tunnel Bandwidth     : 0 kbps
  Reserved Bandwidth   : 0 kbps
  Setup Priority       : -               Holding Priority     : -
  Affinity Attr/Mask   : 0/0
  Explicit Path        : 1
  Backup Explicit Path : -
  Metric Type          : TE
  Record Route         : Disabled        Record Label         : Disabled
  FRR Flag             : Disabled        Bandwidth Protection : Disabled
  Backup Bandwidth Flag: Disabled        Backup Bandwidth Type: -
  Backup Bandwidth     : -
  Bypass Tunnel        : No              Auto Created         : No
  Route Pinning        : Disabled
  Retry Limit          : 3               Retry Interval       : 2 sec
  Reoptimization       : Disabled        Reoptimization Freq  : -
  Backup Type          : None            Backup LSP ID        : -
  Backup Restore Time  : -
  Auto Bandwidth       : Disabled        Auto Bandwidth Freq  : -
  Min Bandwidth        : -               Max Bandwidth        : -
  Collected Bandwidth  : -               Service-Class        : -
  Traffic Policy       : Disable
  Path Setup Type      : EXPLICIT/-
  Last Down Reason     : Signal Error
  Down Time            : 18-11-13 14:34:06:232
# Display the NHLFE entry information.
[RouterA] display mpls forwarding nhlfe
Total NHLFE entries: 3
Flags: T - Forwarded through a tunnel
       N - Forwarded through the outgoing interface to the nexthop IP address
       B - Backup forwarding information
       A - Active forwarding information
       M - P2MP forwarding information
NID        Tnl-Type   Flag OutLabel Forwarding Info
5          LOCAL      NA   -        GE1/0/1                  10.0.0.2
6          SRLSP      NA   16030    GE1/0/1                  10.0.0.2
                           16040
268435457  TE         TA   -        6
The output shows that there are two tiers of outgoing labels to the destination. The traffic is forwarded through the explicit path.
Example: Configuring an MPLS TE tunnel over a PCE-calculated SRLSP
As shown in Figure 24, Router A, Router B, Router C, and Router D are running IS-IS.
Configure Router B, Router C, and Router D as PCEs. Configure Router A as a PCC and specify the PCEs for the PCC. Configure Router A to request the PCEs to calculate the path to Router D.
Figure 24 Network diagram
Device
IP address
Device
IP address
Router A
Loop1
1.1.1.1/32
Router B
Loop1
2.2.2.2/32
GE1/0/1
10.0.0.1/24
GE1/0/1
10.0.0.2/24
GE1/0/2
11.0.0.1/24
Router C
Loop1
3.3.3.3/32
Router D
Loop1
4.4.4.4/32
GE1/0/1
11.0.0.2/24
GE1/0/1
12.0.0.2/24
GE1/0/2
12.0.0.1/24
GE1/0/2
100.1.2.1/24
[RouterA] mpls te
[RouterA-te] quit
[RouterA-GigabitEthernet1/0/1] mpls te enable
[RouterB] mpls te
[RouterB-te] quit
[RouterB-GigabitEthernet1/0/1] mpls te enable
[RouterB-GigabitEthernet1/0/2] mpls te enable
[RouterC] mpls te
[RouterC-te] quit
[RouterC-GigabitEthernet1/0/1] mpls te enable
[RouterC-GigabitEthernet1/0/2] mpls te enable
[RouterD] mpls te
[RouterD-te] quit
[RouterD-GigabitEthernet1/0/1] mpls te enable
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterD] isis 1
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterD] isis 1
5.     Configure Router B, Router C, and Router D as PCEs.
[RouterB] mpls te
[RouterB-te] pce address 2.2.2.2
[RouterC] mpls te
[RouterC-te] pce address 3.3.3.3
[RouterD] mpls te
[RouterD-te] pce address 4.4.4.4
6.     Configure Router A as a PCC and specify the PCEs.
[RouterA] mpls te
[RouterA-te] pcep type active-stateful
[RouterA-te] pce static 2.2.2.2
[RouterA-te] pce static 3.3.3.3
[RouterA-te] pce static 4.4.4.4
[RouterA-Tunnel1] ip address unnumbered interface LoopBack1
# Configure the MPLS TE tunnel interface to use SR and stateful PCE to establish the tunnel over the SRLSP calculated in PCE delegation mode.
[RouterA-Tunnel1] mpls te delegation
# Display discovered PCEs on each router. This example uses Router A.
[RouterA] display mpls te pce discovery verbose
PCE address: 2.2.2.2
  Discovery methods: Static
  Path scopes:
    Path scope                                                  Preference
    Compute intra-area paths                                    7
    Act as PCE for inter-area TE LSP computation                6
  Capabilities:
    Bidirectional path computation
    Support for request prioritization
    Support for multiple requests per message
PCE address: 3.3.3.3
  Path scopes:
  Capabilities:
PCE address: 4.4.4.4
  Path scopes:
  Capabilities:
# Verify that PCEP sessions have been established on each router. This example uses Router A.
[RouterA] display mpls te pce peer verbose
Peer address: 2.2.2.2
  TCP connection           : 1.1.1.1:36818 -> 2.2.2.2:4189
  Peer type                : PCE
  Session type             : Stateless
  Session state            : UP
  Mastership               : Normal
  Role                     : Active
  Session up time          : 0000 days 00 hours 15 minutes
  Session ID               : Local 0, Peer 0
  Keepalive interval       : Local 30 sec, Peer 30 sec
  Recommended DeadTimer    : Local 120 sec, Peer 120 sec
  Tolerance:
    Min keepalive interval : 10 sec
    Max unknown messages   : 5
  Request timeout          : 10 sec
  Capability for Initiate       : No
  Capability for Segment-Routing: No
Peer address: 3.3.3.3
  TCP connection           : 1.1.1.1:36821 -> 3.3.3.3:4189
  Peer type                : PCE
  Session state            : UP
  Mastership               : Normal
  Role                     : Active
  Session up time          : 0000 days 00 hours 13 minutes
  Session ID               : Local 1, Peer 0
  Tolerance:
Peer address: 4.4.4.4
  TCP connection           : 1.1.1.1:36822 -> 4.4.4.4:4189
  Peer type                : PCE
  Session state            : UP
  Mastership               : Normal
  Role                     : Active
  Session ID               : Local 2, Peer 0
  Tolerance:
Example: Configuring SR-MPLS inter-AS option C (I)
As shown in Figure 25, complete the following tasks:
·     Start OSPF and enable OSPF-based SR-MPLS on the PEs in the same AS.
·     Configure PE 1 and ASBR-PE 1 to exchange labeled IPv4 routes through IBGP.
·     Configure PE 2 and ASBR-PE 2 to exchange labeled IPv4 routes through IBGP.
·     Establish an MP-EBGP peer relationship between PE 1 and PE 2 to exchange VPNv4 routes.
·     Configure ASBR-PE 1 and ASBR-PE 2 to exchange labeled IPv4 routes through EBGP. Enable BGP-based SR-MPLS.
·     Configure dynamic SID allocation on loopback interfaces of the devices. Then, establish an SRLSP based on the allocated SIDs and configure an MPLS TE tunnel over the SRLSP to transmit data.
Figure 25 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
PE 1
Loop1
2.2.2.9/32
PE 2
Loop1
5.5.5.9/32
GE1/0/1
30.0.0.1/24
GE1/0/1
20.0.0.1/24
GE1/0/5
1.1.1.2/8
GE1/0/5
9.1.1.2/8
ASBR-PE 1
Loop1
3.3.3.9/32
ASBR-PE 2
Loop1
4.4.4.9/32
GE1/0/5
1.1.1.1/8
GE1/0/5
9.1.1.1/8
GE1/0/4
11.0.0.2/8
GE1/0/4
11.0.0.1/8
CE 1
GE1/0/1
30.0.0.2/24
CE 2
GE1/0/1
20.0.0.2/24
2.     Configure CE 1:
# Assign an IP address to interface GigabitEthernet 1/0/1.
<CE1> system-view
[CE1] interface gigabitethernet 1/0/1
[CE1-GigabitEthernet1/0/1] ip address 30.0.0.2 24
[CE1-GigabitEthernet1/0/1] quit
# Configure PE 1 as an EBGP peer and redistribute the VPN route.
[CE1] bgp 65001
[CE1-bgp-default] peer 30.0.0.1 as-number 100
[CE1-bgp-default-ipv4] peer 30.0.0.1 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
3.     Configure PE 1:
# Start OSPF on PE 1, set the LSR ID, and enable MPLS and MPLS TE.
<PE1> system-view
[PE1] ospf 1 router-id 2.2.2.9
[PE1-ospf-1] quit
[PE1-GigabitEthernet1/0/1] mpls enable
[PE1] interface gigabitethernet 1/0/5
[PE1-GigabitEthernet1/0/5] ospf 1 area 0
[PE1-GigabitEthernet1/0/5] mpls enable
[PE1-GigabitEthernet1/0/5] quit
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 2.2.2.9 32
[PE1-LoopBack1] ospf 1 area 0
[PE1-LoopBack1] quit
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls te
[PE1-te] quit
# Enable SR-MPLS in OSPF view and configure an OSPF prefix SID.
[PE1] ospf 1
[PE1-ospf-1] segment-routing mpls
[PE1-ospf-1] quit
[PE1-LoopBack1] ospf 1 prefix-sid index 20
# Create VPN instance vpn1. Configure an RD and both import and export route targets for the VPN instance.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] quit
# Bind VPN instance vpn1 to interface GigabitEthernet 1/0/1 and assign an IP address to the interface.
[PE1-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet1/0/1] ip address 30.0.0.1 24
# Start BGP on PE 1.
[PE1] bgp 100
# Enable the capability to exchange labeled routes with IBGP peer 3.3.3.9.
[PE1-bgp-default] peer 3.3.3.9 connect-interface loopback 1
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-ipv4] peer 3.3.3.9 label-route-capability
# Enable SR-MPLS.
[PE1-bgp-default-ipv4] segment-routing mpls
[PE1-bgp-default-ipv4] quit
# Configure the maximum number of hops from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp-default] peer 5.5.5.9 as-number 600
[PE1-bgp-default] peer 5.5.5.9 connect-interface loopback 1
[PE1-bgp-default] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv4 peer.
[PE1-bgp-default-vpnv4] peer 5.5.5.9 enable
[PE1-bgp-default-vpnv4] quit
# Configure CE 1 as an EBGP peer of PE 1 and install the learned BGP routes in the routing table of the VPN instance.
4.     Configure ASBR-PE 1:
# Start OSPF on ASBR-PE 1, set the LSR ID, and enable MPLS and MPLS TE.
<ASBR-PE1> system-view
[ASBR-PE1] ospf 1 router-id 3.3.3.9
[ASBR-PE1-ospf-1] quit
[ASBR-PE1] interface gigabitethernet 1/0/4
[ASBR-PE1-GigabitEthernet1/0/4] mpls enable
[ASBR-PE1-GigabitEthernet1/0/4] quit
[ASBR-PE1] interface gigabitethernet 1/0/5
[ASBR-PE1-GigabitEthernet1/0/5] ospf 1 area 0
[ASBR-PE1-GigabitEthernet1/0/5] mpls enable
[ASBR-PE1-GigabitEthernet1/0/5] quit
[ASBR-PE1] interface loopback 1
[ASBR-PE1-LoopBack1] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack1] ospf 1 area 0
[ASBR-PE1-LoopBack1] quit
[ASBR-PE1] mpls te
[ASBR-PE1-te] quit
[ASBR-PE1] ospf 1
[ASBR-PE1-ospf-1] segment-routing mpls
[ASBR-PE1-LoopBack1] ospf 1 prefix-sid index 30
# Create a routing policy and specify a label index value.
[ASBR-PE1]ip prefix-list 1 permit 2.2.2.9 32
[ASBR-PE1]route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] if-match ip address prefix-list 1
[ASBR-PE1-route-policy-policy1-1] apply label-index 20
[ASBR-PE1-route-policy-policy1-1] quit
# Start BGP on ASBR-PE 1. Enable the capability to exchange labeled routes with IBGP peer 2.2.2.9.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 1
[ASBR-PE1-bgp-default] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 label-route-capability
# Redistribute routes from OSPF process 1 to BGP and apply the routing policy.
[ASBR-PE1-bgp-default-ipv4] import-route ospf 1 route-policy policy1
# Enable SR-MPLS.
[ASBR-PE1-bgp-default-ipv4] segment-routing mpls
[ASBR-PE1-bgp-default-ipv4] quit
# Enable the capability to exchange labeled routes with EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 label-route-capability
5.     Configure ASBR-PE 2:
# Start OSPF on ASBR-PE 2, set the LSR ID, and enable MPLS and MPLS TE.
<ASBR-PE2> system-view
[ASBR-PE2] ospf 1 router-id 4.4.4.9
[ASBR-PE2-ospf-1] quit
[ASBR-PE2] interface gigabitethernet 1/0/4
[ASBR-PE2-GigabitEthernet1/0/4] mpls enable
[ASBR-PE2-GigabitEthernet1/0/4] quit
[ASBR-PE2] interface gigabitethernet 1/0/5
[ASBR-PE2-GigabitEthernet1/0/5] ospf 1 area 0
[ASBR-PE2-GigabitEthernet1/0/5] mpls enable
[ASBR-PE2-GigabitEthernet1/0/5] quit
[ASBR-PE2] interface loopback 1
[ASBR-PE2-LoopBack1] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack1] ospf 1 area 0
[ASBR-PE2-LoopBack1] quit
[ASBR-PE2] mpls te
[ASBR-PE2-te] quit
[ASBR-PE2] ospf 1
[ASBR-PE2-ospf-1] segment-routing mpls
[ASBR-PE2-LoopBack1] ospf 1 prefix-sid index 40
[ASBR-PE2]ip prefix-list 1 permit 5.5.5.9 32
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy-policy1-1] if-match ip address  prefix-list  1
[ASBR-PE2-route-policy-policy1-1] apply label-index 50
[ASBR-PE2-route-policy-policy1-1] quit
# Start BGP on ASBR-PE 2. Enable the capability to exchange labeled routes with IBGP peer 5.5.5.9.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] peer 5.5.5.9 connect-interface loopback 1
[ASBR-PE2-bgp-default] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 label-route-capability
[ASBR-PE2-bgp-default-ipv4] import-route ospf 1 route-policy policy1
# Enable SR-MPLS.
[ASBR-PE2-bgp-default-ipv4] segment-routing mpls
[ASBR-PE2-bgp-default-ipv4] quit
# Enable the capability to exchange labeled routes with EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 label-route-capability
6.     Configure PE 2:
# Start OSPF on PE 2, set the LSR ID, and enable MPLS and MPLS TE.
<PE2> system-view
[PE2] ospf 1 router-id 5.5.5.9
[PE2-ospf-1] quit
[PE2] interface gigabitethernet 1/0/1
[PE2-GigabitEthernet1/0/1] mpls enable
[PE2-GigabitEthernet1/0/1] quit
[PE2] interface gigabitethernet 1/0/5
[PE2-GigabitEthernet1/0/5] ospf 1 area 0
[PE2-GigabitEthernet1/0/5] mpls enable
[PE2-GigabitEthernet1/0/5] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip address 5.5.5.9 32
[PE2-LoopBack1] ospf 1 area 0
[PE2-LoopBack1] quit
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls te
[PE2-te] quit
[PE2] ospf 1
[PE2-ospf-1] segment-routing mpls
[PE2-ospf-1] quit
[PE2-LoopBack1] ospf 1 prefix-sid index 50
# Create VPN instance vpn1, and configure the RD and route target attributes.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2-vpn-instance-vpn1] quit
# Associate GigabitEthernet 1/0/1 with VPN instance vpn1, and assign an IP address to the interface.
[PE2-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet1/0/1] ip address 20.0.0.1 24
# Start BGP on PE 2.
[PE2] bgp 600
# Enable the capability to exchange labeled routes with IBGP peer 4.4.4.9.
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 1
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-ipv4] peer 4.4.4.9 label-route-capability
# Enable SR-MPLS.
[PE2-bgp-default-ipv4] segment-routing mpls
[PE2-bgp-default-ipv4] quit
# Configure the maximum number of hops from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp-default] peer 2.2.2.9 as-number 100
[PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 1
[PE2-bgp-default] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv4 peer.
[PE2-bgp-default-vpnv4] peer 2.2.2.9 enable
[PE2-bgp-default-vpnv4] quit
# Configure CE 2 as an EBGP peer and install the learned BGP route in the routing table of the VPN instance.
[PE2-bgp-default-vpn1] peer 20.0.0.2 as-number 65002
[PE2-bgp-default-ipv4-vpn1] peer 20.0.0.2 enable
7.     Configure CE 2:
<CE2> system-view
[CE2] interface gigabitethernet 1/0/1
[CE2-GigabitEthernet1/0/1] ip address 20.0.0.2 24
[CE2-GigabitEthernet1/0/1] quit
# Establish an EBGP peer relationship with PE 2, and redistribute VPN routes.
[CE2] bgp 65002
[CE2-bgp-default] peer 20.0.0.1 as-number 600
[CE2-bgp-default-ipv4] peer 20.0.0.1 enable
[CE2-bgp-default-ipv4] import-route direct
# Execute the display ip routing-table command on CE 1 and CE 2 to verify that they have a route to each other. (Details not shown.)
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
# Display MPLS LSP information on PE 1.
[PE1] display mpls lsp
2.2.2.9/32                  BGP         -/16020         NHLFE1
5.5.5.9/32                  BGP         -/16050         NHLFE1
5.5.5.9                     BGP         -/-             GE1/0/5
1.1.1.1                     Local       -/-             GE1/0/5
2.2.2.9/32                  OSPF        16020/-         -
3.3.3.9/32                  OSPF        16030/3         GE1/0/5
3.3.3.9/32                  OSPF        -/3             GE1/0/5
Example: Configuring SR-MPLS inter-AS option C (II)
As shown in Figure 26, complete the following tasks:
·     Configure PE 1 and ASBR-PE 1 to exchange labeled IPv4 routes through IBGP. Enable BGP-based SR-MPLS.
·     Configure PE 2 and ASBR-PE 2 to exchange labeled IPv4 routes through IBGP. Enable BGP-based SR-MPLS.
Figure 26 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
PE 1
Loop1
2.2.2.9/32
PE 2
Loop1
5.5.5.9/32
GE1/0/1
30.0.0.1/24
GE1/0/1
20.0.0.1/24
GE1/0/5
1.1.1.2/8
GE1/0/5
9.1.1.2/8
ASBR-PE 1
Loop1
3.3.3.9/32
ASBR-PE 2
Loop1
4.4.4.9/32
GE1/0/5
1.1.1.1/8
GE1/0/5
9.1.1.1/8
GE1/0/4
11.0.0.2/8
GE1/0/4
11.0.0.1/8
CE 1
GE1/0/1
30.0.0.2/24
CE 2
GE1/0/1
20.0.0.2/24
2.     Configure CE 1:
<CE1> system-view
# Establish an EBGP peer relationship with PE 1, and redistribute VPN routes.
[CE1] bgp 65001
3.     Configure PE 1:
<PE1> system-view
[PE1-ospf-1] quit
[PE1-GigabitEthernet1/0/1] ospf 1 area 0
[PE1] mpls te
[PE1-te] quit
# Assign an IP address to GigabitEthernet 1/0/5. Start OSPF and enable MPLS on the interface.
[PE1-GigabitEthernet1/0/5] ip address 1.1.1.2 255.0.0.0
[PE1] ospf 1
[PE1-ospf-1] quit
[PE1] route-policy policy1 permit node 1
[PE1-route-policy-policy1-1] apply label-index 20
[PE1-route-policy-policy1-1] quit
[PE1] bgp 100
# Enable SR-MPLS.
# Redistribute the route of loopback interface 1 to BGP and apply the routing policy.
[PE1-bgp-default-ipv4] network 2.2.2.9 32 route-policy policy1
[PE1-bgp-default-vpn1] peer 30.0.0.2 as-number 65001
[PE1-bgp-default-ipv4-vpn1] peer 30.0.0.2 enable
[ASBR-PE1] mpls te
[ASBR-PE1-te] quit
[ASBR-PE1] ospf 1
[ASBR-PE1] bgp 100
# Enable SR-MPLS.
[ASBR-PE2] mpls te
[ASBR-PE2-te] quit
[ASBR-PE2] ospf 1
[ASBR-PE2] bgp 600
# Enable SR-MPLS.
6.     Configure PE 2:
<PE2> system-view
[PE2-ospf-1] quit
[PE2-GigabitEthernet1/0/1] ospf 1 area 0
[PE2] mpls te
[PE2-te] quit
[PE2-GigabitEthernet1/0/5] ip address 9.1.1.2 255.0.0.0
[PE2] ospf 1
[PE2-ospf-1] quit
[PE2] route-policy policy1 permit node 1
[PE2-route-policy-policy1-1] apply label-index 50
[PE2-route-policy-policy1-1] quit
# Start BGP on PE 2. Enable the capability to exchange labeled routes with IBGP peer 4.4.4.9.
[PE2] bgp 600
# Enable SR-MPLS.
[PE2-bgp-default-ipv4] network 5.5.5.9 32 route-policy policy1
# Configure CE 2 as an EBGP peer of PE 2 and install the learned BGP routes in the routing table of the VPN instance.
[PE2-bgp-default-vpn1] peer 20.0.0.2 as-number 65001
7.     Configure CE 2:
<CE2> system-view
[CE2] bgp 65002
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# Display MPLS LSP information on PE1.
2.2.2.9/32                  BGP         3/-             -
Example: Configuring SR-MPLS to LDP (IS-IS)
As shown in Figure 27, complete the following tasks so Router A and Router C can communicate with each other:
·     Configure Router A, Router B, and Router C to run IS-IS.
·     Configure Router A and Router B to run SR-MPLS and establish an SRLSP between Router A and Router B.
·     Configure Router B and Router C to run LDP to establish a dynamic LSP between Router B and Router C.
·     Configure Router B as the SRMS, map the prefix address of the LDP network to an SID, and advertise the mapping to Router A.
Figure 27 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
Router A
Loop1
1.1.1.1/32
Router B
Loop1
2.2.2.2/32
GE1/0/1
10.0.0.1/24
GE1/0/1
10.0.0.2/24
Router C
Loop1
3.3.3.3/32
GE1/0/2
11.0.0.1/24
GE1/0/1
11.0.0.2/24
2.     Configure IS-IS on the routers to achieve network level connectivity and set the IS-IS cost style to wide:
[RouterA] isis 1
<RouterB> system-view
[RouterB] isis 1
<RouterC> system-view
[RouterC] isis 1
3.     Configure LSR IDs on the routers:
4.     Configure LDP on Router B and Router C:
[RouterB] mpls ldp
[RouterB-ldp] quit
[RouterB-GigabitEthernet1/0/2] mpls ldp enable
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterC-GigabitEthernet1/0/1] mpls ldp enable
5.     Enable SR-MPLS on Router A and Router B:
[RouterA] isis 1
# Configure an IS-IS prefix SID.
[RouterB] isis 1
6.     Configure the SRMS:
# On Router B, configure the IGP to advertise locally configured prefix-SID mappings.
[RouterB] isis 1
[RouterB-isis-1-ipv4] segment-routing mapping-server advertise-local
# On Router B, configure a prefix-SID mapping.
[RouterB] segment-routing
[RouterB-segment-routing] mapping-server prefix-sid-map 3.3.3.3 32 100
[RouterB-segment-routing] quit
# Display IS-IS SRLSP information on Router A.
[RouterA] display mpls lsp protocol isis
3.3.3.3/32                  ISIS        16100/16100     GE1/0/1
3.3.3.3/32                  ISIS        -/16100         GE1/0/1
The output shows that the outgoing label of the IS-IS SRLSP entry for Router C is using the SID assigned to Router C.
Example: Configuring SR-MPLS to LDP (OSPF)
As shown in Figure 28, complete the following tasks so Router A and Router C can communicate with each other:
·     Configure Router A, Router B, and Router C to run OSPF.
Figure 28 Network diagram
Device
IP address
Device
IP address
Router A
Loop1
1.1.1.1/32
Router B
Loop1
2.2.2.2/32
GE1/0/1
10.0.0.1/24
GE1/0/1
10.0.0.2/24
Router C
Loop1
3.3.3.3/32
GE1/0/2
11.0.0.1/24
GE1/0/1
11.0.0.2/24
2.     Configure OSPF on the routers to achieve network level connectivity:
[RouterA] ospf 1 router-id 1.1.1.1
[RouterA-ospf-1] quit
[RouterA-GigabitEthernet1/0/1] ospf 1 area 0
[RouterA-LoopBack1] ospf 1 area 0
[RouterB] ospf 1 router-id 2.2.2.2
[RouterB-ospf-1] quit
[RouterB-GigabitEthernet1/0/1] ospf 1 area 0
[RouterB-GigabitEthernet1/0/2] ospf 1 area 0
[RouterB-LoopBack1] ospf 1 area 0
[RouterC] ospf 1 router-id 3.3.3.3
[RouterC-ospf-1] quit
[RouterC-GigabitEthernet1/0/1] ospf 1 area 0
[RouterC-LoopBack1] ospf 1 area 0
[RouterB] mpls ldp
[RouterB-ldp] quit
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterA] ospf 1
[RouterA-ospf-1] segment-routing mpls
# Configure an OSPF prefix SID.
[RouterA-LoopBack1] ospf prefix-sid index 10
[RouterB] ospf 1
[RouterB-ospf-1] segment-routing mpls
[RouterB] ospf 1
[RouterB-ospf-1] segment-routing mapping-server advertise-local
# Display OSPF SRLSP information on Router A.
[RouterA] display mpls lsp protocol ospf
3.3.3.3/32                  OSPF        16100/16100     GE1/0/1
3.3.3.3/32                  OSPF        -/16100         GE1/0/1
The output shows that the outgoing label of the OSPF SRLSP entry for Router C is using the SID assigned to Router C.
Example: Configuring SR-MPLS over LDP
As shown in Figure 29, complete the following tasks so the two SR networks can communicate across the LDP network:
·     Configure Router A, Router B, Router C, Router D, and Router E to run IS-IS.
·     Configure Router B, Router C, and Router D to run LDP.
·     Configure Router A, Router B, Router D, and Router E to run SR-MPLS.
Figure 29 Network diagram
Table 7 Interface and IP address assignment
Device
IP address
Device
IP address
Router A
Loop1
1.1.1.1/32
Router B
Loop1
2.2.2.2/32
GE1/0/1
10.0.0.1/24
GE1/0/1
10.0.0.2/24
Router C
Loop1
3.3.3.3/32
GE1/0/2
11.0.0.1/24
GE1/0/1
11.0.0.2/24
Router D
Loop1
4.4.4.4/32
GE1/0/2
12.0.0.1/24
GE1/0/1
12.0.0.2/24
Router E
Loop1
5.5.5.5/32
GE1/0/2
13.0.0.1/24
GE1/0/1
13.0.0.2/24
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
<RouterD> system-view
[RouterD] isis 1
# Configure Router E.
<RouterE> system-view
[RouterE] isis 1
[RouterE-isis-1] network-entity 00.0000.0000.0005.00
[RouterE-isis-1] cost-style wide
[RouterE-isis-1] quit
[RouterE] interface gigabitethernet 1/0/1
[RouterE-GigabitEthernet1/0/1] isis enable 1
[RouterE-GigabitEthernet1/0/1] quit
[RouterE] interface loopback 1
[RouterE-LoopBack1] isis enable 1
[RouterE-LoopBack1] quit
[RouterE] mpls lsr-id 5.5.5.5
4.     Configure LDP on Router B, Router C, and Router D:
[RouterB] mpls ldp
[RouterB-ldp] quit
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterC-GigabitEthernet1/0/2] mpls ldp enable
[RouterD] mpls ldp
[RouterD-ldp] quit
[RouterD-GigabitEthernet1/0/1] mpls ldp enable
5.     Enable SR-MPLS on Router A, Router B, Router D, and Router E:
[RouterA] isis 1
[RouterB] isis 1
[RouterD] isis 1
[RouterE] isis 1
[RouterE-isis-1] address-family ipv4
[RouterE-isis-1-ipv4] segment-routing mpls
[RouterE-isis-1-ipv4] quit
6.     Configure IS-IS prefix SIDs for Router A, Router B, Router D, and Router E:
[RouterE-LoopBack1] isis prefix-sid index 50
# Display LDP LSP information on Router B.
[RouterB] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A - unavailable
FECs: 5           Ingress: 3           Transit: 3           Egress: 2
FEC                In/Out Label        Nexthop         OutInterface
1.1.1.1/32         2173/-
                   -/2173(L)
2.2.2.2/32         3/-
                   -/2175(L)
3.3.3.3/32         -/3                 11.0.0.2        GE1/0/2
                   2175/3              11.0.0.2        GE1/0/2
4.4.4.4/32         -/2174              11.0.0.2        GE1/0/2
                   2174/2174           11.0.0.2        GE1/0/2
5.5.5.5/32         -/2172              11.0.0.2        GE1/0/2
                   2172/2172           11.0.0.2        GE1/0/2
# Display IS-IS SRLSP information on Router B.
[RouterB] display mpls lsp protocol isis
FEC                         Proto       In/Out Label    Interface/Out NHLFE
1.1.1.1/32                  ISIS        16010/3         GE1/0/1
1.1.1.1/32                  ISIS        -/3             GE1/0/1
2.2.2.2/32                  ISIS        16020/-         -
4.4.4.4/32                  ISIS        16040/2174      GE1/0/2
4.4.4.4/32                  ISIS        -/2174          GE1/0/2
5.5.5.5/32                  ISIS        16050/2172      GE1/0/2
5.5.5.5/32                  ISIS        -/2172          GE1/0/2
The output shows that the IS-IS SRLSP entries for Router D and Router E are using LDP outgoing labels.
Example: Configuring IS-IS TI-LFA FRR
As shown in Figure 30, complete the following tasks to implement TI-LFA FRR:
·     Configure IS-IS on Device A, Device B, and Device C to achieve network level connectivity.
·     Configure SR-MPLS on Device A, Device B, and Device C.
·     Configure TI-LFA FRR to remove the loop that exists on Link B and to implement fast traffic switchover to Link B when Link A fails.
Figure 30 Network diagram
Table 8 Interface and IP address assignment
Device
IP address
Device
IP address
Device A
Loop1
1.1.1.1/32
Device B
Loop1
2.2.2.2/32
GE1/0/1
12.12.12.1/24
GE1/0/1
24.24.24.1/24
GE1/0/2
13.13.13.1/24
GE1/0/2
13.13.13.2/24
Device C
Loop1
3.3.3.3/32
GE1/0/1
12.12.12.2/24
GE1/0/2
24.24.24.2/24
2.     Configure IS-IS on the switches to achieve network level connectivity and set the IS-IS cost style to wide:
# Configure Device A.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] quit
[DeviceA-GigabitEthernet1/0/1] isis enable 1
[DeviceA-GigabitEthernet1/0/1] isis cost 10
[DeviceA-GigabitEthernet1/0/2] isis enable 1
[DeviceA-GigabitEthernet1/0/2] isis cost 10
[DeviceA] interface loopback 1
[DeviceA-LoopBack1] isis enable 1
[DeviceA-LoopBack1] quit
# Configure Device B.
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] quit
[DeviceB-GigabitEthernet1/0/1] isis enable 1
[DeviceB-GigabitEthernet1/0/1] isis cost 20
[DeviceB-GigabitEthernet1/0/2] isis enable 1
[DeviceB-GigabitEthernet1/0/2] isis cost 10
[DeviceB] interface loopback 1
[DeviceB-LoopBack1] isis enable 1
[DeviceB-LoopBack1] quit
# Configure Device C.
<DeviceC> system-view
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] quit
[DeviceC-GigabitEthernet1/0/1] isis enable 1
[DeviceC-GigabitEthernet1/0/1] isis cost 10
[DeviceC-GigabitEthernet1/0/2] isis enable 1
[DeviceC-GigabitEthernet1/0/2] isis cost 20
[DeviceC] interface loopback 1
[DeviceC-LoopBack1] isis enable 1
[DeviceC-LoopBack1] quit
3.     Configure MPLS TE settings:
[DeviceA] mpls lsr-id 1.1.1.1
[DeviceA] mpls te
[DeviceA-te] quit
[DeviceA-GigabitEthernet1/0/1] mpls enable
[DeviceA-GigabitEthernet1/0/1] mpls te enable
[DeviceA-GigabitEthernet1/0/2] mpls enable
[DeviceA-GigabitEthernet1/0/2] mpls te enable
[DeviceB] mpls lsr-id 2.2.2.2
[DeviceB] mpls te
[DeviceB-te] quit
[DeviceB-GigabitEthernet1/0/1] mpls enable
[DeviceB-GigabitEthernet1/0/1] mpls te enable
[DeviceB-GigabitEthernet1/0/2] mpls enable
[DeviceB-GigabitEthernet1/0/2] mpls te enable
[DeviceC] mpls lsr-id 3.3.3.3
[DeviceC] mpls te
[DeviceC-te] quit
[DeviceC-GigabitEthernet1/0/1] mpls enable
[DeviceC-GigabitEthernet1/0/1] mpls te enable
[DeviceC-GigabitEthernet1/0/2] mpls enable
[DeviceC-GigabitEthernet1/0/2] mpls te enable
4.     Enable SR-MPLS and SR-MPLS adjacency label allocation:
[DeviceA] isis 1
[DeviceA-isis-1] address-family ipv4
[DeviceA-isis-1-ipv4] segment-routing mpls
[DeviceA-isis-1-ipv4] segment-routing adjacency enable
[DeviceA-isis-1-ipv4] quit
[DeviceB] isis 1
[DeviceB-isis-1] address-family ipv4
[DeviceB-isis-1-ipv4] segment-routing mpls
[DeviceB-isis-1-ipv4] segment-routing adjacency enable
[DeviceB-isis-1-ipv4] quit
[DeviceC] isis 1
[DeviceC-isis-1] address-family ipv4
[DeviceC-isis-1-ipv4] segment-routing mpls
[DeviceC-isis-1-ipv4] segment-routing adjacency enable
[DeviceC-isis-1-ipv4] quit
5.     Configure IS-IS prefix SIDs for Device A, Device B, and Device C:
[DeviceA-LoopBack1] isis prefix-sid index 10
[DeviceB-LoopBack1] isis prefix-sid index 20
[DeviceC-LoopBack1] isis prefix-sid index 30
6.     Configure TI-LFA FRR:
[DeviceA] isis 1
[DeviceA-isis-1-ipv4] fast-reroute lfa
[DeviceA-isis-1-ipv4] fast-reroute ti-lfa
[DeviceA-isis-1-ipv4] fast-reroute microloop-avoidance enable
[DeviceA-isis-1-ipv4] segment-routing microloop-avoidance enable
[DeviceB] isis 1
[DeviceB-isis-1-ipv4] fast-reroute lfa
[DeviceB-isis-1-ipv4] fast-reroute ti-lfa
[DeviceB-isis-1-ipv4] fast-reroute microloop-avoidance enable
[DeviceB-isis-1-ipv4] segment-routing microloop-avoidance enable
[DeviceC] isis 1
[DeviceC-isis-1-ipv4] fast-reroute lfa
[DeviceC-isis-1-ipv4] fast-reroute ti-lfa
[DeviceC-isis-1-ipv4] fast-reroute microloop-avoidance enable
[DeviceC-isis-1-ipv4] segment-routing microloop-avoidance enable
# Display IPv4 IS-IS routing information for 2.2.2.2/32.
[DeviceA] display isis route ipv4 2.2.2.2 32 verbose level-1 1
                         Level-1 IPv4 Forwarding Table
IPv4 Dest : 2.2.2.2/32          Int. Cost  : 10               Ext. Cost  : NULL
Admin Tag : -                   Src Count  : 1                Flag       : R/L/-
InLabel   : 16020               InLabel Flag: -/N/-/-/-/-
NextHop   :                     Interface  :                  ExitIndex  :
    13.13.13.2                          GE1/0/2                   0x00000103
Nib ID    : 0x14000005          OutLabel   : 16020            OutLabelFlag: I
LabelSrc  : SR
TI-LFA:
  Interface : GE1/0/1
  BkNextHop : 12.12.12.2         LsIndex    : 0x00000002
  Backup label stack(top->bottom): {16030, 2175}
  Route label: 16020
      InLabel flags: R-Readvertisement, N-Node SID, P-no PHP
                     E-Explicit null, V-Value, L-Local
      OutLabelFlags: E-Explicit null, I-Implicit null, N-Normal, P-SR label prefer
The output shows TI-LFA backup next hop information.
