- 20-DPI Configuration Guide
- 01-DPI overview
- 02-DPI engine configuration
- 03-IPS configuration
- 04-URL filtering configuration
- 05-Bandwidth management configuration
- 06-Anti-virus configuration
- 07-Data analysis center configuration
- 08-Data filtering configuration
- 09-File filtering configuration
00-Preface | 109.87 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures for Deep Packet Inspection (DPI) features, including IPS, URL, and bandwidth management.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
