08-Layer 3—IP Routing Configuration Guide
HomeSupportRoutersMSR5600 Series(Comware V7)Configure & DeployConfiguration GuidesH3C MSR 5600 Routers Configuration Guides(V7)-R6749-6W10108-Layer 3—IP Routing Configuration Guide
12-IPv6 policy-based routing configuration
12-IPv6 policy-based routing configuration 221.65 KB
Configuring IPv6 PBR
About IPv6 PBR
IPv6 policy-based routing (PBR) uses user-defined policies to route IPv6 packets. A policy can specify parameters for packets that match specific criteria such as ACLs or that have specific lengths. The parameters include the next hop, output interface, SRv6 TE policy, default next hop, default output interface, and default SRv6 TE policy.
IPv6 packet forwarding process
When the device receives an IPv6 packet, the device searches the IPv6 PBR policy for a matching node to forward that packet.
·     If a matching node is found and its match mode is permit, the device performs the following operations:
a.     Uses the next hops, output interfaces, or SRv6 TE policies specified on the node to forward the packet.
b.     Searches the routing table for a route (except the default route) to forward the packet if one of the following conditions exists:
-     No next hops, output interfaces, or SRv6 TE policies are specified on the node.
-     Forwarding failed based on the next hops, output interfaces, or SRv6 TE policies.
c.     Uses the default next hops, default output interfaces, or default SRv6 TE policies specified on the node to forward the packet if one of the following conditions exists:
-     No matching route was found in the routing table.
-     The routing table-based forwarding failed.
d.     Uses the default route to forward the packet if one of the following conditions exists:
-     No default next hops, default output interfaces, or default SRv6 TE policies are specified on the node.
-     The forwarding failed based on the default next hops, default output interfaces, or default SRv6 TE policies.
·     The device perfoms routing table lookup to forward the packet in either of the following conditions:
¡     No matching node is found.
¡     A matching node is found, but its match mode is deny.
IPv6 PBR types
IPv6 PBR includes the following types:
·     Local PBR—Guides the forwarding of locally generated packets, such as the ICMP packets generated by using the ping command.
·     Interface PBR—Guides the forwarding of packets received on an interface only.
Policy
An IPv6 policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
An IPv6 policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup for the packet.
Relationship between if-match clauses
On a node, you can specify multiple if-match clauses, but only one if-match clause for each type. A packet that matches all the if-match clauses of a node matches the node.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about the relationship between the apply clauses, see "Configuring actions for an IPv6 node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
In permit mode
In deny mode
Yes
·     If the node contains apply clauses, IPv6 PBR executes the apply clauses on the node.
¡     If IPv6 PBR-based forwarding succeeds, IPv6 PBR does not compare the packet with the next node.
¡     If IPv6 PBR-based forwarding fails and the apply continue clause is not configured, IPv6 PBR does not compare the packet with the next node.
¡     If IPv6 PBR-based forwarding fails and the apply continue clause is configured, IPv6 PBR compares the packet with the next node.
·     If the node does not contain apply clauses, the device performs a routing table lookup for the packet.
The device performs a routing table lookup for the packet.
No
A node that has no if-match clauses matches any packet.
IPv6 PBR and Track
IPv6 PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop, output interface, default next hop, or default output interface.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track and IPv6 PBR collaboration, see High Availability Configuration Guide.
Restrictions and guidelines: IPv6 PBR configuration
If a packet destined for the local device matches an IPv6 PBR policy, IPv6 PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure an IPv6 PBR policy, be careful to avoid this situation.
The device that supports fast forwarding uses the high-speed cache to process packets, and identifies a data flow with one or multiple packet fields. If the first packet of a data flow is successfully forwarded through IPv6 PBR, the associated forwarding information is generated in the high-speed cache. Subsequent packets of the data flow can then be forwarded through the IPv6 PBR fast forwarding table. This greatly reduces packet forwarding time and improves packet forwarding rate. For more information about fast forwarding, see fast forwarding configuration in Layer 3—IP Services Configuration Guide.
If a permit-mode IPv6 PBR policy node successfully forwards a packet, the device cannot generate a fast forwarding entry when the following conditions exist:
·     The match rules other than packet 5-tuple are configured for the IPv6 policy node, for example, the IPv6 packet length match rule configured with the if-match packet-length clause.
·     Among the apply access-vpn, apply next-hop (with the inbound-vpn keyword), and apply output-interface (with broadcast or NBMA output interfaces specified) clauses, if one or multiple of the clauses are configured on the IPv6 policy node, the device determines whether the following conditions are met in descending order of priority:
¡     Multiple VPN instances are specified with the apply access-vpn clause, and the first VPN instance is unavailable. If the clause is not configured, the device proceeds to the next condition.
¡     A next hop with the inbound-vpn keyword is specified in the apply next-hop clause, but the next hop is unreachable. In load sharing mode, a minimum of one next hop with the inbound-vpn keyword is required. In non-load-sharing mode, before you configure a next hop with the inbound-vpn keyword, no other available next hops without the inbound-vpn keyword are configured. If the clause is not configured, the device proceeds to the next condition.
¡     A broadcast or NBMA output interface is specified with the apply output-interface clause on the IPv6 policy node, but the output interface is unavailable. In load sharing mode, a minimum of one broadcast or NBMA output interface is required. In non-load-sharing mode, before you specify a broadcast or NBMA output interface, no other available non-broadcast or non-NBMA output interfaces are specified.
·     The apply access-vpn vpn-instance, apply next-hop, apply output-interface, and apply srv6-policy clauses are not configured, but one or multiple of the following clauses are configured on the IPv6 policy node:
¡     apply default-next-hop
¡     apply default-output-interface
¡     apply default-srv6-policy
·     The apply precedence clause is configured on the IPv6 policy node.
If the permit-mode IPv6 PBR policy node fails to forward a packet, and the apply continue clause is configured on the IPv6 policy node, the device cannot generate a fast forwarding entry.
IPv6 PBR tasks at a glance
To configure IPv6 PBR, perform the following tasks:
1.     Configuring an IPv6 policy
a.     Creating an IPv6 node
b.     Setting match criteria for an IPv6 node
c.     Configuring actions for an IPv6 node
2.     Specifying a policy for IPv6 PBR
¡     Specifying an IPv6 policy for IPv6 local PBR
¡     Specifying an IPv6 policy for IPv6 interface PBR
2.     Create an IPv6 policy or policy node and enter its view.
2.     Enter IPv6 policy node view.
3.     Set match criteria.
¡     Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
¡     Set a packet length match criterion.
if-match packet-length min-len max-len
By default, no packet length match criterion is set.
¡     Set a source IPv6 address match criterion.
if-match source-ipv6 { interface interface-type interface-number | [ vpn-instance vpn-instance-name ] ipv6-address }
By default, no source IPv6 address match criterion is set.
¡     Set application group match criteria.
if-match app-group app-group-name&<1-6>
By default, no application group match criteria are set.
Application group match criteria apply only to interface PBR.
For more information about application groups, see APR configuration in Security Configuration Guide.
¡     Set service object group match criteria.
if-match object-group service object-group-name&<1-6>
By default, no service object group match criteria are set.
For more information about service object groups, see object group configuration in Security Configuration Guide.
The apply clauses allow you to specify actions to take on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
·     apply access-vpn
·     apply next-hop
·     apply output-interface
·     apply gateway
·     apply srv6-policy
·     apply default-next-hop
·     apply default-output-interface
·     apply default-gateway
·     apply default-srv6-policy
IPv6 PBR supports the apply clauses in Table 1.
Table 1 Apply clauses supported in IPv6 PBR
Clause
Meaning
Remarks
apply precedence
Sets an IP precedence.
This clause is always executed.
apply loadshare { default-next-hop | default-output-interface | default-srv6-policy | next-hop | output-interface | srv6-policy }
Enables load sharing among multiple next hops, output interfaces, SRv6 TE policies, default next hops, default output interfaces, or default SRv6 TE policies.
Multiple next hop, output interface, SRv6 TE policy, default next hop, default output interface, or default SRv6 TE policy options operate in either primary/backup or load sharing mode. The following description uses multiple next hops as an example:
·     Primary/backup mode—A next hop is selected from all next hops in configuration order for packet forwarding, with all remaining next hops as backups. When the selected next hop fails, the next available next hop takes over.
·     Load sharing mode—Matching traffic is distributed across the available next hops. If the traffic does not match any fast forwarding entries, per-packet load sharing is performed. If the traffic matches a fast forwarding entry, per-flow load sharing is performed.
By default, the primary/backup mode applies.
For the load sharing mode to take effect, make sure multiple next hops, output interfaces, SRv6 TE policies, default next hops, default output interfaces, or default SRv6 TE policies are set in the policy.
apply access-vpn
Specifies the forwarding tables that can be used for the matching packets.
Use this clause only in special scenarios that require sending packets received from one network to another network, for example, from a VPN to the public network, or from one VPN to another VPN.
If a packet matches the forwarding table for a specified VPN instance, it is forwarded in the VPN.
apply remark-vpn
Enables VPN remark action.
VPN remark action marks the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command. All subsequent service modules of IPv6 PBR handle the packets as belonging to the re-marked VPN instance.
If the VPN remark action is not enabled, the forwarded matching packets are marked as belonging to the VPN instance or the public network from which they were received.
VPN remark action applies only to packets that have been successfully forwarded based on the apply access-vpn vpn-instance command.
apply next-hop, apply output-interface, apply gateway, and apply srv6-policy
Sets next hops, output interfaces, gateway addresses, and SRv6 TE policies.
Only the apply clause with the highest priority is executed.
apply default-next-hop, apply default-output-interface, apply default-gateway, and apply default-srv6-policy
Sets default next hops, default output interfaces, default gateway addresses, and default SRv6 TE policies.
The clauses take effect only in the following cases:
·     No next hops, output interfaces, gateway addresses, or SRv6 TE polices are set or the next hops, output interfaces, gateway addresses, and SRv6 TE polices are invalid.
·     The IPv6 packet does not match any route in the routing table.
apply continue
Compares packets with the next node upon failure on the current node.
The apply continue clause applies when either of the the following conditions exist:
·     None of the clauses that determine the packet forwarding paths is configured.
·     A clause that determines the packet forwarding paths is configured, but it has become invalid. Then, a routing table lookup also fails for the matching packet.
A clause might become invalid because the specified next hop is unreachable, the specified gateway is unreachable, the specified SRv6 TE policy is unavailable, packets cannot be forwarded in the specified VPN instance, or the specified output interface is down.
Restrictions and guidelines for action configuration
If you specify a next hop or default next hop, IPv6 PBR periodically performs a lookup in the FIB table to determine its availability. Temporary service interruption might occur if IPv6 PBR does not update the route immediately after its availability status changes.
Setting an IP precedence
3.     Set an IP precedence.
By default, no IP precedence is specified.
Configuring actions to direct packet forwarding
3.     Configure actions for a node.
¡     Specify the forwarding tables that can be used for the matching packets.
apply access-vpn { public | vpn-instance vpn-instance-name&<1-4> }
By default, the device forwards matching packets by using the forwarding table for the network from which the packets are received.
You can repeat this command to specify the forwarding tables for the public network and VPN instances. The device forwards the matching packets by using the first available forwarding table selected in the order in which they are specified.
¡     Enable VPN remark action to mark the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command.
apply remark-vpn
By default, VPN remark action is not configured.
¡     Set next hops for permitted IPv6 packets.
apply next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ipv6-address [ direct ] [ track track-entry-number ] [ weight weight-value ] } &<1-4>
By default, no next hops are specified.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times. You can specify a maximum of four next hops for a node.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡     Enable load sharing among multiple next hops.
apply loadshare next-hop
By default, the next hops operate in primary/backup mode.
¡     Set output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, no output interfaces are specified.
You can specify multiple output interfaces for backup or load sharing in one command line or by executing this command multiple times. You can specify a maximum of four output interfaces for a node.
¡     Enable load sharing among multiple output interfaces.
apply loadshare output-interface
By default, the output interfaces operate in primary/backup mode.
¡     Set the next hop addresses for matching packets to the specified gateway addresses.
apply gateway { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, the next hop addresses for matching packets are not set to gateway addresses.
¡     Set SRv6 TE policies.
apply srv6-policy { endpoint color [ { sid | vpnsid } sid ] }&<1-2>
By default, no SRv6 TE policies are specified.
You can specify a maximum of two SRv6 TE policies in one command line or by executing this command multiple times. The first available SRv6 TE policy selected according to configuration order will be used to forward matching packets.
¡     Enable load sharing among multiple SRv6 TE policies.
apply loadshare srv6-policy
By default, the SRv6 TE policies operate in primary/backup mode.
¡     Set default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-4>
By default, no default next hops are specified.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times. You can specify a maximum of four default next hops for a node.
¡     Enable load sharing among multiple default next hops.
apply loadshare default-next-hop
By default, the default next hops operate in primary/backup mode.
¡     Set default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, no default output interfaces are specified.
You can specify multiple default output interfaces for backup or load sharing in one command line or by executing this command multiple times. You can specify a maximum of four default output interfaces for a node.
¡     Enable load sharing among multiple default output interfaces.
apply loadshare default-output-interface
By default, the default output interfaces operate in primary/backup mode.
¡     Set the default next hop addresses for matching packets to the specified gateway addresses.
apply default-gateway { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, the default next hop addresses for matching packets are not set to gateway addresses.
¡     Set default SRv6 TE policies.
apply default-srv6-policy { endpoint color [ { sid | vpnsid } sid ] }&<1-2>
By default, no default SRv6 TE policies are specified.
You can specify a maximum of two default SRv6 TE policies in one command line or by executing this command multiple times. The first available default SRv6 TE policy selected according to configuration order will be used to forward matching packets.
¡     Enable load sharing among multiple default SRv6 TE policies.
apply loadshare default-srv6-policy
By default, the default SRv6 TE policies operate in primary/backup mode.
Comparing packets with the next node upon match failure on the current node
3.     Compare packets with the next node upon match failure on the current node.
apply continue
By default, IPv6 PBR does not compare packets with the next node upon match failure on the current node.
This command takes effect only when the match mode of the node is permit.
Perform this task to specify an IPv6 policy for IPv6 local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for IPv6 local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR might affect local services, such as ping and Telnet. When you use IPv6 local PBR, make sure you fully understand its impact on local services of the device.
2.     Specify an IPv6 policy for IPv6 local PBR.
By default, IPv6 local PBR is not enabled.
Perform this task to apply an IPv6 policy to an interface to guide the forwarding of packets received on the interface only.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2.     Enter interface view.
3.     Specify an IPv6 policy for IPv6 interface PBR.
By default, no IPv6 policy is applied to the interface.
Display and maintenance commands for IPv6 PBR
IMPORTANT
IMPORTANT:
The MSR 56-60 and MSR 56-80 routers installed with the MPU-100-G modules do not support parameters or commands that are available only in IRF mode.
Display IPv6 PBR policy information.
Display IPv6 interface PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
Display IPv6 local PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route local [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route local [ chassis chassis-number slot slot-number ]
Display IPv6 PBR configuration.
display ipv6 policy-based-route setup
Clear IPv6 PBR statistics.
IPv6 PBR configuration examples
Example: Configuring packet type-based IPv6 local PBR
As shown in Figure 1, Router B and Router C are connected through Router A. Router B and Router C do not have a route to reach each other.
Configure IPv6 PBR on Router A to forward all TCP packets to the next hop 1::2 (Router B).
Figure 1 Network diagram
1.     Configure Router A:
# Configure the IPv6 addresses of GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[RouterA-GigabitEthernet1/0/1] ipv6 address 1::1 64
[RouterA-GigabitEthernet1/0/2] ipv6 address 2::1 64
# Configure ACL 3001 to match TCP packets.
[RouterA] acl ipv6 advanced 3001
[RouterA-acl-ipv6-adv-3001] rule permit tcp
[RouterA-acl-ipv6-adv-3001] quit
# Configure Node 5 for policy aaa to forward TCP packets to next hop 1::2.
[RouterA] ipv6 policy-based-route aaa permit node 5
[RouterA-pbr6-aaa-5] if-match acl 3001
[RouterA-pbr6-aaa-5] apply next-hop 1::2
[RouterA-pbr6-aaa-5] quit
# Configure IPv6 local PBR by applying policy aaa to Router A.
[RouterA] ipv6 local policy-based-route aaa
2.     On Router B, configure the IPv6 address of GigabitEthernet 1/0/1.
<RouterB> system-view
[RouterB-GigabitEthernet1/0/1] ipv6 address 1::2 64
3.     On Router C, configure the IPv6 address of GigabitEthernet 1/0/2.
<RouterC> system-view
[RouterC-GigabitEthernet1/0/2] ipv6 address 2::2 64
1.     Perform telnet operations to verify that IPv6 local PBR on Router A operates as configured to forward the matching TCP packets to the next hop 1::2 (Router B), as follows:
# Verify that you can telnet to Router B from Router A successfully. (Details not shown.)
# Verify that you cannot telnet to Router C from Router A. (Details not shown.)
2.     Verify that Router A forwards packets other than TCP packets through GigabitEthernet 1/0/2. For example, verify that you can ping Router C from Router A. (Details not shown.)
Example: Configuring packet type-based IPv6 interface PBR
As shown in Figure 2, Router B and Router C do not have a route to reach each other.
Configure IPv6 PBR on Router A to forward all TCP packets received on GigabitEthernet 1/0/1 to the next hop 1::2 (Router B).
Figure 2 Network diagram
1.     Configure IPv6 addresses and unicast routing protocol settings to make sure Router B and Router C each have a route to reach Host A. (Details not shown.)
2.     Configure Router A:
# Configure IPv6 interface PBR by applying policy aaa to GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] undo ipv6 nd ra halt
[RouterA-GigabitEthernet1/0/1] ipv6 policy-based-route aaa
1.     Enable IPv6 and configure the IPv6 address 10::3 for Host A.
C:\>ipv6 install
Installing...
Succeeded.
C:\>ipv6 adu 4/10::3
2.     Perform telnet operations to verify that IPv6 interface PBR on Router A operates as configured to forward the matching TCP packets to the next hop 1::2 (Router B), as follows:
# Verify that you can telnet to Router B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Router C from Host A. (Details not shown.)
3.     Verify that Router A forwards packets other than TCP packets through GigabitEthernet 1/0/3. For example, verify that you can ping Router C from Host A. (Details not shown.)
Example: Configuring packet length-based IPv6 interface PBR
As shown in Figure 3, configure IPv6 interface PBR to guide the forwarding of packets received on GigabitEthernet 1/0/1 of Router A as follows:
·     Set the next hop of packets with a length of 64 to 100 bytes to 150::2/64.
·     Set the next hop of packets with a length of 101 to 1000 bytes to 151::2/64.
Figure 3 Network diagram
1.     Configure IPv6 addresses and unicast routing protocol settings to make sure the devices each have a route to reach one another. (Details not shown.)
# Configure Node 10 for policy lab1 to forward packets with a length of 64 to 100 bytes to the next hop 150::2/64.
[RouterA] ipv6 policy-based-route lab1 permit node 10
[RouterA-pbr6-lab1-10] if-match packet-length 64 100
[RouterA-pbr6-lab1-10] apply next-hop 150::2
[RouterA-pbr6-lab1-10] quit
# Configure Node 20 for policy lab1 to forward packets with a length of 101 to 1000 bytes to the next hop 151::2/64.
[RouterA] ipv6 policy-based-route lab1 permit node 20
[RouterA-pbr6-lab1-20] if-match packet-length 101 1000
[RouterA-pbr6-lab1-20] apply next-hop 151::2
[RouterA-pbr6-lab1-20] quit
# Configure IPv6 interface PBR by applying policy lab1 to GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] ipv6 policy-based-route lab1
[RouterA-GigabitEthernet1/0/1] return
# Execute the debugging ipv6 policy-based-route command on Router A.
<RouterA> debugging ipv6 policy-based-route
<RouterA> terminal logging level 7
<RouterA> terminal monitor
# Install IPv6 protocol suites on Host A, and configure the IPv6 address 192::3.
C:\>ipv6 install
Installing...
Succeeded.
C:\>ipv6 adu 4/192::3
# Ping Loopback 0 of Router B from Host A, and set the data length to 64 bytes.
C:\>ping –n 1 -l 64 10::1
Pinging 10::1 with 64 bytes of data:
Reply from 10::1: time=1ms
Ping statistics for 10::1:
    Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
The debugging information about IPv6 PBR displayed on Router A is as follows:
<RouterA>
*Jun  26 13:04:33:519 2012 RouterA PBR6/7/PBR Forward Info: -MDC=1; Policy:lab1, Node:
 10,match succeeded.
*Jun  26 13:04:33:519 2012 RouterA PBR6/7/PBR Forward Info: -MDC=1; apply next-hop 150
::2.
The output shows that Router A sets the next hop for the received packets to 150::2 according to IPv6 PBR. The packets are forwarded through GigabitEthernet 1/0/2.
# Ping Loopback 0 of Router B from Host A, and set the data length to 200 bytes.
C:\>ping –n 1 -l 200 10::1
Pinging 10::1 with 200 bytes of data:
<RouterA>
*Jun  26 13:20:33:619 2012 RouterA PBR6/7/PBR Forward Info: -MDC=1; Policy:lab1, Node:
 20,match succeeded.
*Jun  26 13:20:33:619 2012 RouterA PBR6/7/PBR Forward Info: -MDC=1; apply next-hop 151
::2.
The output shows that Router A sets the next hop for the received packets to 151::2 according to IPv6 PBR. The packets are forwarded through GigabitEthernet 1/0/3.
