H3C S12500R-48Y8C Switch Router Hardware Information and Specifications-6W101
HomeSupportSwitchesS12500R SeriesProduct LiteratureHardware Information & SpecificationsH3C S12500R-48Y8C Switch Router Hardware Information and Specifications-6W101
01-Hardware Information and Specifications
01-Hardware Information and Specifications 501.63 KB
1 Product models and technical specifications
Product models
This document is applicable to the S12500R-48Y8C (product code LS-12500R-48Y8C).
Technical specifications
Table1-1 Technical specifications
Item
S12500R-48Y8C
Dimensions (H × W × D)
44.0 × 440 × 460 mm (1.73 × 17.32 × 18.11 in)
Weight
≤ 10 kg (22.05 lb)
Console port
1
Management Ethernet port
1
USB port
1
SFP28 port
48
QSFP28 port
8
SMB clock input port
1
SMB clock output port
1
1PPS/ToD time synchronization port
1
Fan tray slot
4
Power supply slot
2
Minimum power consumption
(For the power consumption data collection standard, see Table1-2)
·     Single AC input: 218 W
·     Dual AC inputs: 229 W
·     Single DC input: 220 W
·     Dual DC inputs: 226 W
Typical power consumption
·     Single AC input: 360 W
·     Dual AC inputs: 374 W
·     Single DC input: 372 W
·     Dual DC inputs: 377 W
Maximum power consumption
·     Single AC input: 599 W
·     Dual AC inputs: 619 W
·     Single DC input: 625 W
·     Dual DC inputs: 629 W
Chassis leakage current compliance
·     GB 4943.1
·     IEC 60950-1
·     IEC 62368-1
·     EN 62368-1
·     UL 62368-1
Sound pressure level at 27°C (80.6°F)
66.7 dB(A)
Operating temperature
0°C to 40°C (32°F to 104°F)
Operating humidity
5% RH to 95% RH, noncondensing
Storage humidity
Fire resistance compliance
·     GB 4943.1
·     IEC 60950-1
·     IEC 62368-1
·     EN 62368-1
·     UL 62368-1
Table1-2 Power consumption data collection standard
Item
Configuration
·     Two power supplies
·     No transceiver modules/cables installed in ports
·     Fully configured with copper cables
·     Fully configured with transceiver modules
Load
N/A
50% load
100% load
2 Chassis views
Figure2-1 Front panel
(1) System status LED (SYS)
(2) Power status LED (PSU)
(3) Fan tray status LED (FAN)
(4) SFP28 port
(5) QSFP28 port
(6) QSFP28 port LED
(7) SFP28 port LED
Figure2-2 Rear panel
(1) Power supply 1
(2) Management Ethernet port LED (ACT)
(3) Management Ethernet port (MGMT)
(4) Management Ethernet port LED (LINK)
(5) SMB clock output port
(6) SMB clock input port
(7) Fan tray 1
(8) Fan tray 2
(9) Fan tray 3
(10) Fan tray 4
(11) Grounding screw 1
(12) Power supply 2
(13) Grounding screw 2
(14) Reset button
(15) System status LED (SYS)
(16) 1PPS/ToD time synchronization port
(17) Console port
(18) USB port
The S12500R-48Y8C came with power supply slot PSU1 empty and power supply slot PSU2 installed with a filler panel. You can install one or two power supplies for the device as needed. In Figure2-2, two LSVM1AC650 power supplies are installed in the power supply slots.
The S12500R-48Y8C came with the four fan tray slots empty. You must install four fan trays of the same model for the device. In Figure2-2, four FAN-40B-1-C fan trays are installed in the fan tray slots.
The S12500R-48Y8C provides a reset button on the rear panel for you to reset the device.
3 FRUs
The device uses modular design. Table3-1 describes the FRUs available for the device.
Table3-1 FRUs available for the device
FRUs
BOM code
S12500R-48Y8C
Power supplies
LSVM1AC650
0231A0QM
Yes
LSVM1DC650
0231A0QP
Yes
PSR650B-12A2-F
0231AK5E
Yes
PSR650B-12AHD-F
0231AG9Y
Yes
Fan trays
FAN-40B-1-C
9803A00F
Yes
FAN-40F-1-D
0231AKLC
Yes
You can install both LSVM1AC650 and LSVM1DC650 power supplies on the device.
The device can operate correctly with only one power supply. You can install two power supplies for 1+1 redundancy.
To ensure heat dissipation, make sure all fan tray slots on the device have fan trays installed and the fan trays are the same model.
Power supplies
CAUTION
CAUTION:
When the device has power supplies in redundancy, you can replace a power supply without powering off the device. Make sure the power supply to be replaced is powered off before you replace it.
Table3-2 Power supply specifications
Power supply model
Specifications
Remarks
LSVM1AC650
·     Rated AC input voltage: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Rated HVDC input voltage: 240 VDC
·     Max output power: 650 W
For more information about the power supplies, see H3C LSVM1AC650 & LSVM1DC650 Power Modules User Manual.
LSVM1DC650
·     Rated input voltage: –40 VDC to –60 VDC
PSR650B-12A2-F
For more information about the power supply, see H3C PSR650B-12A2-F Power Module User Manual.
PSR650B-12AHD-F
·     Rated HVDC input voltage: 240 VDC to 380 VDC
For more information about the power supply, see H3C SecPath PSR650B-12AHD-F Power Supply User Manual.
Fan trays
The device uses removable fan trays.
View
Figure3-1 FAN-40B-1-C/FAN-40F-1-D fan tray view
For information about the LED, see "Fan tray alarm LED."
Features
The FAN-40B-1-C fan tray draws air from the port side to the power supply side. The FAN-40F-1-D fan tray blows air from the power supply side to the port side. The FAN-40B-1-C or FAN-40F-1-D fan tray is small, hot swappable, and can automatically adjust the fan speed according to the device temperature.
Table3-3 Technical specifications
Item
FAN-40B-1-C
FAN-40F-1-D
Dimensions (H × W × D, including the handle)
40 × 40 × 136 mm (1.57 × 1.57 × 5.35 in)
Weight
0.15 kg (0.33 lb)
Airflow direction
Air exhausted from the fan tray faceplate
Air drawn in from the fan tray faceplate
Max fan speed
29000 R.P.M
Max airflow
38 CFM (1.08 m3/min)
Input voltage
12 V
Max power consumption
45 W
4 Ports and LEDs
As a best practice, use H3C transceiver modules and cables for the device. H3C transceiver modules and cables are subject to change over time. For the most up-to-date list of H3C transceiver modules and cables, contact H3C Support or marketing staff. For information about the specifications and views of H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
Ports
Console port
The device has one serial console port.
Table4-1 Console port specifications
Item
Console port
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local PC running terminal emulation program.
The device has one management Ethernet port. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table4-2 Management Ethernet port specifications
Item
Specifications
Connector type
RJ-45/LC
Port transmission rate
10/100/1000BASE-T management port:
·     10/100 Mbps, half/full duplex, MDI/MDI-X auto-sensing.
·     1000 Mbps, full duplex, MDI/MDI-X auto-sensing.
Transmission medium and max transmission distance
100 m (328.08 ft) over category 5 UTP cable.
Functions and services
Software upgrade and network management.
USB port
The device has one OHCI-compliant USB 2.0 port that can upload and download data at a rate up to 480 Mbps. You can use this USB port to access the file system on the Flash of the device, for example, to upload or download application and configuration files.
The USB port supplies power as per USB 2.0 specifications. Use only USB 2.0-compliant USB devices for the USB port. The port might not identity USB devices that are not compliant with USB 2.0.
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the device. If a USB device fails to operate on the device, replace it with one from another vendor.
QSFP28 port
The device provides eight QSFP28 ports on the front panel.
You can install the following transceiver modules and cables in the QSFP28 ports:
·     QSFP28 transceiver modules in Table4-3.
·     QSFP28 copper cables in Table4-4.
·     QSFP28 fiber cables in Table4-5.
Table4-3 QSFP28 transceiver modules available for the QSFP28 ports
Central wavelength (nm)
Connector
Fiber type and diameter (µm)
Modal bandwidth (MHz*km)
Maximum transmission distance
QSFP-100G-SR4-MM850
850
MPO (PC polished, 12-fiber)
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-eSR4-MM850
850
Multi-mode, 50/125
4700
300 m (984.25 ft)
QSFP-100G-PSM4-SM1310
1295 to 1325
MPO (APC polished, 12-fiber)
Single-mode, 9/125
N/A
500 m (1640.42 ft)
QSFP-100G-LR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-SWDM4-MM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
75 m (246.06 ft)
4700
100 m (328.08 ft)
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
Table4-4 QSFP28 copper cables available for the QSFP28 ports
QSFP28 copper cable
Cable length
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
Table4-5 QSFP28 fiber cables available for the QSFP28 ports
QSFP28 fiber cable
Cable length
QSFP-100G-D-AOC-7M
7 m (22.97 ft)
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
SFP28 port
The device provides 48 SFP28 ports and supports the following transceiver modules and cables:
·     SFP28 transceiver modules in Table4-6.
·     SFP28 copper cables in Table4-7.
·     SFP28 fiber cables in Table4-8.
·     10-GE SFP+ transceiver modules in Table4-9.
·     10-GE SFP+ copper cables in Table4-10.
·     10-GE SFP+ fiber cables in Table4-11.
IMPORTANT
IMPORTANT:
·     To use an SFP28 or SFP+ copper cable to connect an SFP28 port on an S12500R-48Y8C to a peer port that does not support speed and duplex autonegotiation, you must configure the same duplex mode and speed for the two ports. The speed must be the same as that of the transceiver module installed in the port.
·     On an S12500R-48Y8C, only ports 1 to 24 and 41 to 48 can operate at 1 Gbps. Follow these restrictions and guidelines if you configure a port to operate at 1 Gbps:
¡     When the port operates at 1 Gbps, autonegotiation is disabled on it by default. To ensure normal communication, disable autonegotiation on the peer port.
¡     If you install a copper transceiver module on the port, the peer port might still be up after the local port is shut down.
Table4-6 SFP28 transceiver modules available for the SFP28 ports
Connector
SFP-25G-SR-MM850
850
LC
Multi-mode, 50/125
2000
·     FEC negotiation disabled: 30 m (98.43 ft)
·     FEC negotiation enabled: 70 (229.66 ft)
4700
·     FEC negotiation disabled: 40 m (131.23 ft)
·     FEC negotiation enabled: 100 m (328.08 ft)
SFP-25G-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
For more information about FEC negotiation, see Ethernet interface configuration in H3C S12500R Switch Router Series Layer 2LAN Switching Configuration Guide.
Table4-7 25G SFP28 copper cables available for the SFP28 ports
Max transmission distance
SFP-25G-D-CAB-1M
1 m (3.28 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
Table4-8 25G SFP28 fiber cables available for the SFP28 ports
SFP-25G-D-AOC-3M
3 m (9.84 ft)
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
Table4-9 10-GE SFP+ transceiver modules available for the SFP28 ports
Connector
Modal bandwidth (MHz × km)
SFP-XG-SX-MM850-A
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
Multi-mode, 62.5/125
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
·     TX: 1270
·     RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
·     TX: 1330
·     RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
·     TX: 1270
·     RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
·     TX: 1330
·     RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1490-BIDI
·     TX: 1490
·     RX: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-BIDI
·     TX: 1550
·     RX: 1490
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
Table4-10 10-GE SFP+ copper cables available for the SFP28 ports
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table4-11 10-GE SFP+ fiber cables available for the SFP28 ports
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
IMPORTANT
IMPORTANT:
You must use two BIDI transceiver modules in pairs. For example, if one end uses the SFP-XG-LX-SM1270-BIDI transceiver module, the peer end must use the SFP-XG-LX-SM1330-BIDI transceiver module.
Clock ports
SMB clock input/output port
Table4-1 SMB clock input/output port specifications
Item
Specifications
Connector type
SMB coaxial
Port standard
GJB681
Supported services
Sends and receives 2.048 MHz clocks and 2.048 Mbps signals to synchronize clocks between the device and other network devices or endpoints.
Table4-2 1PPS/ToD time synchronization port specifications
Item
Specifications
Connector type
RJ-45
Port standard
QB-B-016-2010
Supported services
·     You can configure the port as an input port or output port at the CLI.
·     Synchronizes clocks of the device and other network devices, such as GPS receivers and endpoints.
LEDs
System status LED
The system status LED shows the operating status of the device.
Table4-3 System status LED description
LED mark
Status
SYS
Steady green
The device is operating correctly.
Flashing green
The device is performing power-on self test (POST).
Steady red
The system POST has failed or a system failure has occurred.
Flashing red
Some ports failed in POST and do not work.
The system does not perform POST if the BootWare boot mode is fast mode.
Flashing blue (3 Hz)
Helps you to locate the device.
To locate the device in the rack, execute the locator blink blink-time command. The LED then flashes blue at 3 Hz.
Off
The device is powered off or has failed to start up.
QSFP28 port LED
Table4-4 QSFP28 port LED description
LED status
Steady green
A transceiver module or cable has been correctly installed and a link is present on the port.
Flashing green
The port is sending or receiving data.
Off
No transceiver module or cable has been installed or no link is present on the port.
SFP28 port LED
Table4-5 SFP28 port LED description
LED status
Steady green
Flashing green
Off
Management Ethernet port LEDs
The device provides two status LEDs LINK and ACT for the management Ethernet port.
Table4-6 Management Ethernet port LED description
LED mark
Status
LINK
Off
No link is present on the port
Steady green
The port is operating at 10/100/1000 Mbps.
ACT
Off
The port is not receiving or sending data.
Flashing yellow
Power status LED
The device provides a power status LED to indicate the operating status of the power supplies.
Table4-7 Power status LED description
Mark
Status
PSU
Steady green
Both power supplies are operating correctly.
Steady yellow
A power supply has failed or is not present.
Off
Both power supplies have failed or are not present.
Fan tray status LED
The device provides a fan tray status LED to indicate the operating status of the fan trays.
Table4-8 Fan tray status LED description
Mark
Status
FAN
Steady green
All fan trays are operating correctly.
Steady yellow
A fan tray has failed or is not present.
Steady red
A minimum of two fan trays have failed or are not present.
Fan tray alarm LED
Each fan tray provides an alarm LED.
Table4-9 Description for the alarm LEDs on the fan trays
Status
Steady green
The fan tray is operating correctly.
Steady red
The fan tray has failed.
Off
The fan tray is not installed securely or no power is present.
5 Cooling system
CAUTION
CAUTION:
The chassis and power supplies use separate air aisles. Make sure the two aisles are not blocked when the device is operating.
To dissipate heat timely and ensure system stability, the device uses the front-rear air aisle cooling system. Consider the site ventilation design when you plan the installation site for the device.
Table5-1 Cooling system for the device
Device model
Available fan trays
Airflow direction
S12500R-48Y8C
FAN-40B-1-C
From the port side to the power supply side
FAN-40F-1-D
From the power supply side to the port side
