01-HH3C-DHCP4-MIB | 352.95 KB |
hh3cDhcpServer2AlwaysBroadcast
hh3cDhcpServer2BootpReplyRfc1048
hh3cDhcpServer2BootpRequestNum
hh3cDhcpServer2IfApplyPoolTable
hh3cDhcpServer2PoolStaticTable
hh3cDhcpServer2PoolOptionTable
hh3cDhcpServer2RuleHwAddrTable
HH3C-DHCP4-MIB
About this MIB
Use this MIB to configure DHCP, obtain DHCP address allocation information, and configure alarm settings.
MIB file name
hh3c-dhcp4.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDhcp4(122)
Scalar objects
hh3cDhcpServer2Enabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2Enabled (1.3.6.1.4.1.25506.2.122.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AlwaysBroadcast (1.3.6.1.4.1.25506.2.122.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the DHCP server to broadcast responses. |
As per the MIB. |
hh3cDhcpServer2IgnoreBootp
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IgnoreBootp (1.3.6.1.4.1.25506.2.122.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Whether to ignore BOOTP requests. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BootpReplyRfc1048 (1.3.6.1.4.1.25506.2.122.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the sending of BOOTP responses in RFC 1048 format. |
As per the MIB. |
hh3cDhcpServer2Opt82Enabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2Opt82Enabled (1.3.6.1.4.1.25506.2.122.1.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the DHCP server to handle Option 82. |
As per the MIB. |
hh3cDhcpServer2PingNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PingNumber (1.3.6.1.4.1.25506.2.122.1.1.6) |
read-write |
Unsigned32 |
Unsigned32(0..10) |
Maximum number of attempts that the DHCP server pings an IP address before assigning the IP address to a DHCP client. |
As per the MIB. |
hh3cDhcpServer2PingTimeout
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PingTimeout (1.3.6.1.4.1.25506.2.122.1.1.7) |
read-write |
Unsigned32 |
Unsigned32(0..10000) |
Ping response timeout time for the DHCP server to ping an IP address. |
As per the MIB. |
hh3cDhcpServer2AllocThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AllocThreshold (1.3.6.1.4.1.25506.2.122.1.1.8) |
read-write |
Unsigned32 |
Unsigned32(0..100) |
IP address allocation success rate threshold. The success rate is the rate of successfully allocated IP addresses to received DHCP requests within a specific time period. |
As per the MIB. |
hh3cDhcpServer2BadNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BadNum (1.3.6.1.4.1.25506.2.122.1.2.1) |
read-only |
Counter64 |
INTEGER(0..18446744073709551615) |
Number of error packets received by the DHCP server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BootpRequestNum (1.3.6.1.4.1.25506.2.122.1.2.2) |
read-only |
Counter64 |
Number of BOOTP-REQUEST messages received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2DiscoverNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2DiscoverNum (1.3.6.1.4.1.25506.2.122.1.2.3) |
read-only |
Counter64 |
Number of DHCP-DISCOVER messages received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2RequestNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2RequestNum (1.3.6.1.4.1.25506.2.122.1.2.4) |
read-only |
Counter64 |
Number of DHCP-REQUEST messages received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2DeclineNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2DeclineNum (1.3.6.1.4.1.25506.2.122.1.2.5) |
read-only |
Counter64 |
Number of DHCP-DECLINE messages received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2ReleaseNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ReleaseNum (1.3.6.1.4.1.25506.2.122.1.2.6) |
read-only |
Counter64 |
Number of DHCP-RELEASE messages received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2InformNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2InformNum (1.3.6.1.4.1.25506.2.122.1.2.7) |
read-only |
Counter64 |
Number of DHCP-INFORM messages received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2BootpReplyNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2BootpReplyNum (1.3.6.1.4.1.25506.2.122.1.2.8) |
read-only |
Counter64 |
Number of BOOTP-REPLY messages sent by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2OfferNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OfferNum (1.3.6.1.4.1.25506.2.122.1.2.9) |
read-only |
Counter64 |
Number of DHCP-OFFER messages sent by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2AckNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AckNum (1.3.6.1.4.1.25506.2.122.1.2.10) |
read-only |
Counter64 |
Number of DHCP-ACK messages sent by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2NakNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2NakNum (1.3.6.1.4.1.25506.2.122.1.2.11) |
read-only |
Counter64 |
Number of DHCP-NAK messages sent by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2TotalPoolUsage
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2TotalPoolUsage (1.3.6.1.4.1.25506.2.122.1.2.12) |
read-only |
Unsigned32 |
DHCP address pool usage. |
As per the MIB. |
hh3cDhcpServer2PoolNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolNumber (1.3.6.1.4.1.25506.2.122.1.2.13) |
read-only |
Unsigned32 |
Standard MIB values. |
Number of DHCP address pools. |
As per the MIB. |
h3cDhcpServer2ConflictNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3cDhcpServer2ConflictNum (1.3.6.1.4.1.25506.2.122.1.2.14) |
read-only |
Unsigned32 |
Total number of conflicting IP addresses on the DHCP server. |
As per the MIB. |
hh3cDhcpServer2AutoBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2AutoBindNum (1.3.6.1.4.1.25506.2.122.1.2.15) |
read-only |
Unsigned32 |
Number of dynamic DHCP bindings. |
As per the MIB. |
hh3cDhcpServer2ManualBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ManualBindNum (1.3.6.1.4.1.25506.2.122.1.2.16) |
read-only |
Unsigned32 |
Number of static DHCP bindings. |
As per the MIB. |
hh3cDhcpServer2ExpiredBindNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ExpiredBindNum (1.3.6.1.4.1.25506.2.122.1.2.17) |
read-only |
Unsigned32 |
Number of expired DHCP bindings. |
As per the MIB. |
hh3cDhcpServer2ReqCnt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ReqCnt (1.3.6.1.4.1.25506.2.122.1.2.18) |
read-only |
Counter64 |
Number of address requests received by the DHCP server. |
As per the MIB. |
hh3cDhcpServer2ReqSuccCnt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ReqSuccCnt (1.3.6.1.4.1.25506.2.122.1.2.19) |
read-only |
Counter64 |
Number of address requests that the DHCP server processed successfully. |
As per the MIB. |
Tabular objects
hh3cDhcpServer2PoolTable
About this table
This table records the address pool configuration on a DHCP server.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported. When you create a new address pool, this table automatically creates an instance for the pool. |
Supported |
Supported |
Supported |
Columns
The table index is h3cDhcpServer2PoolIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolIndex (1.3.6.1.4.1.25506.2.122.2.1.1.1) |
accessible-for-notify |
Unsigned32 |
DHCP address pool index. |
Implementation varies by product. |
hh3cDhcpServer2PoolName (1.3.6.1.4.1.25506.2.122.2.1.1.2) |
read-create |
OCTET STRING |
OCTET STRING (1..63) |
DHCP address pool name. |
As per the MIB. |
hh3cDhcpServer2PoolVpnName (1.3.6.1.4.1.25506.2.122.2.1.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..31) |
VPN to which the DHCP address pool is bound. |
As per the MIB. |
hh3cDhcpServer2PoolNetwork (1.3.6.1.4.1.25506.2.122.2.1.1.4) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Primary network address of the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolNetworkMask (1.3.6.1.4.1.25506.2.122.2.1.1.5) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Mask for the primary network address. |
As per the MIB. |
hh3cDhcpServer2PoolStartAddr (1.3.6.1.4.1.25506.2.122.2.1.1.6) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of an IP address range in the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolEndAddr (1.3.6.1.4.1.25506.2.122.2.1.1.7) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of an IP address range in the DHCP address pool. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseDay (1.3.6.1.4.1.25506.2.122.2.1.1.8) |
read-create |
Integer32 |
Integer32(0..365) |
Lease duration in days. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseHour (1.3.6.1.4.1.25506.2.122.2.1.1.9) |
read-create |
Integer32 |
Integer32 (0..23) |
Lease duration in hours. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseMinute (1.3.6.1.4.1.25506.2.122.2.1.1.10) |
read-create |
Integer32 |
Integer32 (0..59) |
Lease duration in minutes. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseSecond (1.3.6.1.4.1.25506.2.122.2.1.1.11) |
read-create |
Integer32 |
Integer32 (0..59) |
Lease duration in seconds. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseUnlimit (1.3.6.1.4.1.25506.2.122.2.1.1.12) |
read-create |
TruthValue |
true(1), false(2) |
Whether the lease duration is unlimited. |
As per the MIB. |
hh3cDhcpServer2PoolLeaseTime (1.3.6.1.4.1.25506.2.122.2.1.1.13) |
read-create |
TimeTicks |
DHCP lease time in TimeTicks |
As per the MIB. |
hh3cDhcpServer2PoolDomainName (1.3.6.1.4.1.25506.2.122.2.1.1.14) |
read-create |
OCTET STRING |
Domain name assigned to DHCP clients. |
As per the MIB. |
hh3cDhcpServer2PoolGatewayIP (1.3.6.1.4.1.25506.2.122.2.1.1.15) |
read-create |
OCTET STRING |
OCTET STRING (0..127) |
Gateway IP address. |
As per the MIB. |
hh3cDhcpServer2PoolDNSIP(1.3.6.1.4.1.25506.2.122.2.1.1.16) |
read-create |
OCTET STRING |
DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolPrimaryDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.17) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Primary DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecondDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.18) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Secondary DNS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolNetbiosType (1.3.6.1.4.1.25506.2.122.2.1.1.19) |
read-create |
INTEGER |
null(0), bnode(1), pnode(2), mnode(4), hnode(8) |
NETBIOS node type. |
As per the MIB. |
hh3cDhcpServer2PoolNbnsIP(1.3.6.1.4.1.25506.2.122.2.1.1.20) |
read-create |
OCTET STRING |
SIZE(0..127) |
NETBIOS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolBootFileName (1.3.6.1.4.1.25506.2.122.2.1.1.21) |
read-create |
OCTET STRING |
SIZE(0..63) |
Name of a configuration file to be assigned to DHCP clients. |
As per the MIB. |
hh3cDhcpServer2PoolBimsIP(1.3.6.1.4.1.25506.2.122.2.1.1.22) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
BIMS server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolBimsPort (1.3.6.1.4.1.25506.2.122.2.1.1.23) |
read-create |
Unsigned32 |
Unsigned32(0..65534) |
BIMS server port number. |
As per the MIB. |
hh3cDhcpServer2PoolBimsKeyStr (1.3.6.1.4.1.25506.2.122.2.1.1.24) |
read-create |
OCTET STRING |
OCTET STRING (0..16) |
Shared key for the DHCP clients to encrypt packets sent to the BIMS server. |
Does not support GET. |
hh3cDhcpServer2PoolNextServer (1.3.6.1.4.1.25506.2.122.2.1.1.25) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the next DHCP server. |
As per the MIB. |
hh3cDhcpServer2PoolTftpDomName (1.3.6.1.4.1.25506.2.122.2.1.1.26) |
read-create |
OCTET STRING |
OCTET STRING (0..63) |
TFTP server domain name. |
As per the MIB. |
hh3cDhcpServer2PoolTftpIP (1.3.6.1.4.1.25506.2.122.2.1.1.27) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
TFTP server IP address. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceAsIP (1.3.6.1.4.1.25506.2.122.2.1.1.28) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the backup network calling processor. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceFailIP (1.3.6.1.4.1.25506.2.122.2.1.1.29) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Failover IP address. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceFailStr (1.3.6.1.4.1.25506.2.122.2.1.1.30) |
read-create |
OCTET STRING |
OCTET STRING (0..39) |
Failover dialer string. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceNCPIP (1.3.6.1.4.1.25506.2.122.2.1.1.31) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address of the primary network calling processor. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceVlanId (1.3.6.1.4.1.25506.2.122.2.1.1.32) |
read-create |
Unsigned32 |
Unsigned32(2..4094|65535) |
Voice VLAN ID. |
As per the MIB. |
hh3cDhcpServer2PoolVoiceVlanEnbl (1.3.6.1.4.1.25506.2.122.2.1.1.33) |
read-create |
TruthValue |
true(1), false(2) |
Enabling status of the voice VLAN. |
As per the MIB. |
hh3cDhcpServer2PoolRowStatus (1.3.6.1.4.1.25506.2.122.2.1.1.34) |
read-create |
RowStatus |
Active(1) createAndGo(4) destroy(6) |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolVerifyClass(1.3.6.1.4.1.25506.2.122.2.1.1.35) |
read-create |
TruthValue |
true(1), false(2) |
Enabling status of the user class whitelist. |
As per the MIB. |
hh3cDhcpServer2PoolThreshold (1.3.6.1.4.1.25506.2.122.2.1.1.36) |
read-create |
Unsigned32 |
IP address usage threshold for the address pool. |
As per the MIB. |
About this table
This table records the address pool bound to an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IfApplyPoolName (1.3.6.1.4.1.25506.2.122.2.2.1.1) |
read-write |
OCTET STRING |
Name of the address pool bound to an interface. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwTable
About this table
This table records the secondary network configuration in the DHCP address pool.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex, h3cDhcpServer2PoolSecNw, and h3cDhcpServer2PoolSecNwMask.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolSecNw(1.3.6.1.4.1.25506.2.122.2.3.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Secondary network IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwMask (1.3.6.1.4.1.25506.2.122.2.3.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Mask of the secondary network IP address. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwGwIP (1.3.6.1.4.1.25506.2.122.2.3.1.3) |
read-create |
OCTET STRING |
Gateway IP address for the secondary network. |
As per the MIB. |
hh3cDhcpServer2PoolSecNwStatus (1.3.6.1.4.1.25506.2.122.2.3.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolClassTable
About this table
This table records address ranges for DHCP user classes in a DHCP address pool on a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolClassName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolClassName (1.3.6.1.4.1.25506.2.122.2.4.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2PoolClassStart (1.3.6.1.4.1.25506.2.122.2.4.1.2) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of an address range for a DHCP user class. |
As per the MIB. |
hh3cDhcpServer2PoolClassEnd (1.3.6.1.4.1.25506.2.122.2.4.1.3) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of an address range for a DHCP user class. |
As per the MIB. |
hh3cDhcpServer2PoolClassStatus (1.3.6.1.4.1.25506.2.122.2.4.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records static bindings in a DHCP address pool.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolStaticIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolStaticIP (1.3.6.1.4.1.25506.2.122.2.5.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
IP address in a static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticMask (1.3.6.1.4.1.25506.2.122.2.5.1.2) |
read-create |
InetAddressIPv4 |
OCTET STRING (4) |
IP address mask in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticCID (1.3.6.1.4.1.25506.2.122.2.5.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0|4..254) |
Client identifier in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticHAddr (1.3.6.1.4.1.25506.2.122.2.5.1.4) |
read-create |
OCTET STRING |
OCTET STRING (0|4..39) |
Hardware address in the static binding. |
As per the MIB. |
hh3cDhcpServer2PoolStaticHType (1.3.6.1.4.1.25506.2.122.2.5.1.5) |
read-create |
INTEGER |
default(1), ethernet(2), tokenRing(3) |
Hardware address type. |
As per the MIB. |
hh3cDhcpServer2PoolStaticStatus (1.3.6.1.4.1.25506.2.122.2.5.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table records user-defined options in the DHCP address pool.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolOptCode.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolOptCode (1.3.6.1.4.1.25506.2.122.2.6.1.1) |
not-accessible |
Integer32 |
Integer32(2..254), excluding 50..54, 56, 58, 59, 61, 82. |
Option code. |
As per the MIB. |
hh3cDhcpServer2PoolOptType (1.3.6.1.4.1.25506.2.122.2.6.1.2) |
read-create |
INTEGER |
ascii(1), hex(2), ip(3) |
Option type. |
As per the MIB. |
hh3cDhcpServer2PoolOptAscii (1.3.6.1.4.1.25506.2.122.2.6.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..255) |
ASCII string as the option content. |
As per the MIB. |
hh3cDhcpServer2PoolOptHexStr (1.3.6.1.4.1.25506.2.122.2.6.1.4) |
read-create |
OCTET STRING |
OCTET STRING (0..510) |
Hexadecimal number as the option content. |
The string length cannot exceed 256. |
hh3cDhcpServer2PoolOptIPStr (1.3.6.1.4.1.25506.2.122.2.6.1.5) |
read-create |
OCTET STRING |
IP address as the option content. |
As per the MIB. |
hh3cDhcpServer2PoolOptRowStatus (1.3.6.1.4.1.25506.2.122.2.6.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2ClassTable
About this table
This table records DHCP user class information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is h3cDhcpServer2ClassName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ClassName (1.3.6.1.4.1.25506.2.122.2.8.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2ClassRowStatus (1.3.6.1.4.1.25506.2.122.2.8.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2ForbidTable
About this table
This table records excluded IP address ranges.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2ForbidVpnName, h3cDhcpServer2ForbidStart, and h3cDhcpServer2ForbidEnd.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2ForbidVpnName (1.3.6.1.4.1.25506.2.122.2.10.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..31) |
Name of the VPN to which the excluded IP address belongs. |
As per the MIB. |
hh3cDhcpServer2ForbidStart (1.3.6.1.4.1.25506.2.122.2.10.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
Start IP address of the excluded IP address range. |
As per the MIB. |
hh3cDhcpServer2ForbidEnd (1.3.6.1.4.1.25506.2.122.2.10.1.3) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
End IP address of the excluded IP address range. |
As per the MIB. |
hh3cDhcpServer2ForbidRowStatus (1.3.6.1.4.1.25506.2.122.2.10.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2IPInUseTable
About this table
This table records binding information about IP addresses in use on a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2IPInUseIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2IPInUseIP (1.3.6.1.4.1.25506.2.122.2.14.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
IP address in use. |
As per the MIB. |
hh3cDhcpServer2IPInUseClientId (1.3.6.1.4.1.25506.2.122.2.14.1.2) |
read-only |
OCTET STRING |
Client ID of the IP address. |
As per the MIB. |
hh3cDhcpServer2IPInUseHardAddr (1.3.6.1.4.1.25506.2.122.2.14.1.3) |
read-only |
OCTET STRING |
Hardware address of the DHCP client. |
As per the MIB. |
hh3cDhcpServer2IPInUseHardType (1.3.6.1.4.1.25506.2.122.2.14.1.4) |
read-only |
INTEGER |
As per the MIB. |
hh3cDhcpServer2IPInUseVlanId (1.3.6.1.4.1.25506.2.122.2.14.1.5) |
read-only |
Unsigned32 |
Unsigned32(1..4094 | 65535) |
VLAN where the DHCP client resides. |
As per the MIB. |
hh3cDhcpServer2IPInUseEndLease (1.3.6.1.4.1.25506.2.122.2.14.1.6) |
read-only |
OCTET STRING |
OCTET STRING (1..19) |
Lease expiration time. |
As per the MIB. |
hh3cDhcpServer2IPInUseType (1.3.6.1.4.1.25506.2.122.2.14.1.7) |
read-only |
INTEGER |
staticUnallocated(1), staticOffered(2), staticCommitted(3), autoOffered(4), autoCommitted(5) |
Binding type. |
As per the MIB. |
hh3cDhcpServer2IPInUseIfIndex (1.3.6.1.4.1.25506.2.122.2.14.1.8) |
read-only |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Index of the interface that connects to the DHCP client. |
As per the MIB. |
hh3cDhcpServer2IPInUseRowStatus (1.3.6.1.4.1.25506.2.122.2.14.1.9) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpTable
About this table
This table defines option information associated with the DHCP user class.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2DefOptGrpClass.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2DefOptGrpClass (1.3.6.1.4.1.25506.2.122.2.15.1.1) |
not-accessible |
OCTET STRING |
User class name. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpId (1.3.6.1.4.1.25506.2.122.2.15.1.2) |
read-create |
Integer32 |
Integer32(1..32768) |
Option group ID. |
As per the MIB. |
hh3cDhcpServer2DefOptGrpStatus(1.3.6.1.4.1.25506.2.122.2.15.1.3) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
About this table
This table defines the user class hardware address match rule.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleHwAddrNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2RuleHwAddrNumber (1.3.6.1.4.1.25506.2.122.2.17.1.1) |
not-accessible |
Integer32 |
Integer32 (1..16) |
Rule ID. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddress (1.3.6.1.4.1.25506.2.122.2.17.1.2) |
read-create |
OCTET STRING |
OCTET STRING (4..39) |
Hardware address. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrMask (1.3.6.1.4.1.25506.2.122.2.17.1.3) |
read-create |
OCTET STRING |
Hardware address mask. |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrType (1.3.6.1.4.1.25506.2.122.2.17.1.4) |
read-create |
Integer32 |
1, representing the Ethernet |
As per the MIB. |
hh3cDhcpServer2RuleHwAddrStatus (1.3.6.1.4.1.25506.2.122.2.17.1.5) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2OptionGroupTable
About this table
This table defines a DHCP option group for a DHCP user class.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is h3cDhcpServer2OptionGroupId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OptionGroupId (1.3.6.1.4.1.25506.2.122.2.18.1.1) |
not-accessible |
Integer32 |
Option group ID. |
As per the MIB. |
hh3cDhcpServer2OptionGroupStatus (1.3.6.1.4.1.25506.2.122.2.18.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2OptionTable
About this table
This table defines user option information in a DHCP option group.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpServer2OptionGroupId and h3cDhcpServer2OptionCode.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2OptionCode (1.3.6.1.4.1.25506.2.122.2.19.1.1) |
not-accessible |
Integer32 |
Integer32(2..254),excluding 50..54, 56, 58, 59, 61, 82 |
Option code. |
As per the MIB. |
hh3cDhcpServer2OptionType (1.3.6.1.4.1.25506.2.122.2.19.1.2) |
read-create |
INTEGER |
Option type. |
As per the MIB. |
hh3cDhcpServer2OptionAscii (1.3.6.1.4.1.25506.2.122.2.19.1.3) |
read-create |
OCTET STRING |
OCTET STRING(0..255) |
The value read from this object is 0 if ascii(1) is specified as the option type but no ASCII string is specified. |
hh3cDhcpServer2OptionHexStr (1.3.6.1.4.1.25506.2.122.2.19.1.4) |
read-create |
OCTET STRING |
OCTET STRING(0|2..256) |
The value read from this object is 0 if hex(2) is specified as the option type but no hexadecimal string is specified. |
hh3cDhcpServer2OptionIPStr (1.3.6.1.4.1.25506.2.122.2.19.1.5) |
read-create |
OCTET STRING |
OCTET STRING(0..127) |
As per the MIB. |
hh3cDhcpServer2OptionRowStatus (1.3.6.1.4.1.25506.2.122.2.19.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cDhcpServer2PoolStatTable
About this table
This table records DHCP address pool statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpServer2PoolUsage (1.3.6.1.4.1.25506.2.122.2.20.1.1) |
read-only |
Unsigned32 |
IP address usage of the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolReqCnt (1.3.6.1.4.1.25506.2.122.2.20.1.2) |
read-only |
Counter64 |
Number of address requests received by the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolReqSuccCnt (1.3.6.1.4.1.25506.2.122.2.20.1.3) |
read-only |
Counter64 |
Number of successfully processed received requests in the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolDiscoverCnt (1.3.6.1.4.1.25506.2.122.2.20.1.4) |
read-only |
Counter64 |
Number of DHCP-DISCOVER messages received by the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolOfferCnt (1.3.6.1.4.1.25506.2.122.2.20.1.5) |
read-only |
Counter64 |
Number of DHCP-OFFER messages sent by the address pool. |
As per the MIB. |
hh3cDhcpServer2PoolAckCnt (1.3.6.1.4.1.25506.2.122.2.20.1.6) |
read-only |
Counter64 |
Number of DHCP-ACK messages sent by the address pool. |
As per the MIB. |
hh3cDhcpRelay2ConfigGroup
About this table
This table configures global DHCP relay agent settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2UserInfoRecord (1.3.6.1.4.1.25506.2.122.3.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of recording client information in relay entries. |
As per the MIB. |
hh3cDhcpRelay2UserInfoRefresh (1.3.6.1.4.1.25506.2.122.3.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of refreshing relay entries. |
As per the MIB. |
hh3cDhcpRelay2UserInfoFlushTime (1.3.6.1.4.1.25506.2.122.3.1.3) |
read-write |
Unsigned32 |
Unsigned32(0..120) |
Interval at which the DHCP relay agent refreshes relay entries. |
As per the MIB. |
hh3cDhcpRelay2ReleaseAddr (1.3.6.1.4.1.25506.2.122.3.1.4) |
read-write |
OCTET STRING |
OCTET STRING (0..47) |
IP address release request sent to the server. |
The set operation enables the relay agent to send a release request for the specified IP address to the DHCP server. When you perform a get operation on this object, a value of 0 is returned. |
hh3cDhcpRelay2StatisticsGroup
About this table
This table records the global statistics on a DHCP relay agent.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2RxClientNum (1.3.6.1.4.1.25506.2.122.3.2.1) |
read-only |
Counter64 |
Number of received packets that are sent by the DHCP clients. |
As per the MIB. |
hh3cDhcpRelay2TxClientNum (1.3.6.1.4.1.25506.2.122.3.2.2) |
read-only |
Counter64 |
Number of packets sent to the DHCP clients. |
As per the MIB. |
hh3cDhcpRelay2RxServerNum (1.3.6.1.4.1.25506.2.122.3.2.3) |
read-only |
Counter64 |
Number of received packets sent by DHCP servers. |
As per the MIB. |
hh3cDhcpRelay2TxServerNum (1.3.6.1.4.1.25506.2.122.3.2.4) |
read-only |
Counter64 |
Number of packets sent to the DHCP servers. |
As per the MIB. |
hh3cDhcpRelay2BadNum (1.3.6.1.4.1.25506.2.122.3.2.5) |
read-only |
Counter64 |
Number of error packets processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2BootpRequestNum (1.3.6.1.4.1.25506.2.122.3.2.6) |
read-only |
Counter64 |
Number of BOOTP requests processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2DiscoverNum (1.3.6.1.4.1.25506.2.122.3.2.7) |
read-only |
Counter64 |
Number of DHCP-DISCOVER messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2RequestNum (1.3.6.1.4.1.25506.2.122.3.2.8) |
read-only |
Counter64 |
Number of DHCP-REQUEST messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2DeclineNum (1.3.6.1.4.1.25506.2.122.3.2.9) |
read-only |
Counter64 |
Number of DHCP-DECLINE messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2ReleaseNum (1.3.6.1.4.1.25506.2.122.3.2.10) |
read-only |
Counter64 |
Number of DHCP-RELEASE messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2InformNum (1.3.6.1.4.1.25506.2.122.3.2.11) |
read-only |
Counter64 |
Number of DHCP-INFORM messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2BootpReplyNum (1.3.6.1.4.1.25506.2.122.3.2.12) |
read-only |
Counter64 |
Number of BOOTP replies processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2OfferNum (1.3.6.1.4.1.25506.2.122.3.2.13) |
read-only |
Counter64 |
Number of DHCP-OFFER messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2AckNum (1.3.6.1.4.1.25506.2.122.3.2.14) |
read-only |
Counter64 |
Number of DHCP-ACK messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2NakNum (1.3.6.1.4.1.25506.2.122.3.2.15) |
read-only |
Counter64 |
Number of DHCP-NAK messages processed by the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2IfConfigTable
About this table
This table records the DHCP relay agent configuration on an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2IfSelectRelay (1.3.6.1.4.1.25506.2.122.4.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the DHCP relay agent. |
As per the MIB. |
hh3cDhcpRelay2IfCheckMac (1.3.6.1.4.1.25506.2.122.4.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of MAC address check. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82Enable (1.3.6.1.4.1.25506.2.122.4.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of support for option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82Strategy (1.3.6.1.4.1.25506.2.122.4.1.1.4) |
read-write |
INTEGER |
drop(1), keep(2), replace(3) |
Strategy for handling DHCP requests that contain Option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDMode (1.3.6.1.4.1.25506.2.122.4.1.1.5) |
read-write |
INTEGER |
normal(1), verbose(2), userDefine(3) |
Mode of the circuit ID sub-option in option 82. |
The return value is normal(1) if the system reads an unsupported mode. |
hh3cDhcpRelay2IfOpt82CIDNodeType (1.3.6.1.4.1.25506.2.122.4.1.1.6) |
read-write |
INTEGER |
invalid(1), mac(2), sysname(3), userDefine(4) |
Access node identifier for the circuit ID sub-option in verbose mode. |
If no access node identifier is specified, the value read from this object is invalid(1). |
hh3cDhcpRelay2IfOpt82CIDNodeStr (1.3.6.1.4.1.25506.2.122.4.1.1.7) |
read-write |
OCTET STRING |
OCTET STRING (0..50) |
User-defined string as the access node identifier for the circuit ID sub-option in verbose mode. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDStr (1.3.6.1.4.1.25506.2.122.4.1.1.8) |
read-write |
OCTET STRING |
OCTET STRING (0|3..63) |
User-defined string as the access node identifier for the circuit ID sub-option in userDefine mode. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82CIDFormat (1.3.6.1.4.1.25506.2.122.4.1.1.9) |
read-write |
INTEGER |
hex(1), ascii(2), undefine(3) |
Padding format of the circuit ID sub-option in option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82RIDMode (1.3.6.1.4.1.25506.2.122.4.1.1.10) |
read-write |
INTEGER |
normal(1), sysname(2), userDefine(3) |
Mode of the remote ID sub-option in option 82. |
As per the MIB. |
hh3cDhcpRelay2IfOpt82RIDStr (1.3.6.1.4.1.25506.2.122.4.1.1.11) |
read-write |
OCTET STRING |
User-defined string as the access node identifier for the remote ID sub-option in userDefine mode. |
If the mode of the remote ID sub-option is sysname(2), the value read from this object is 0. |
hh3cDhcpRelay2IfOpt82RIDFormat (1.3.6.1.4.1.25506.2.122.4.1.1.12) |
read-write |
INTEGER |
hex(1), ascii(2) |
Padding format of the remote ID sub-option in normal mode. |
As per the MIB. |
hh3cDhcpRelay2SrvAddrTable
About this table
This table obtains the IP address of a DHCP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and h3cDhcpRelay2SrvAddrIP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2SrvAddrIP (1.3.6.1.4.1.25506.2.122.4.2.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
DHCP server IP address. |
As per the MIB. |
hh3cDhcpRelay2SrvAddrRowStatus (1.3.6.1.4.1.25506.2.122.4.2.1.2) |
read-create |
RowStatus |
Active, createAndGo, destroy |
Row status. |
As per the MIB. |
hh3cDhcpRelay2UserInfoTable
About this table
Use this table to delete DHCP relay entries.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpRelay2UserInfoVpnIndex and h3cDhcpRelay2UserInfoIpAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpRelay2UserInfoVpnIndex (1.3.6.1.4.1.25506.2.122.4.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (0 . 65534), 0 represents the public network. |
VPN to which the IP address of the relay entry belongs. |
As per the MIB. |
hh3cDhcpRelay2UserInfoIpAddr (1.3.6.1.4.1.25506.2.122.4.3.1.2) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (0.255) |
Client IP address in the relay entry. |
As per the MIB. |
hh3cDhcpRelay2UserInfoMacAddr (1.3.6.1.4.1.25506.2.122.4.3.1.3) |
read-only |
MacAddress |
OCTET STRING (6) |
Client MAC address in the relay entry. |
As per the MIB. |
hh3cDhcpRelay2UserInfoIfIndex (1.3.6.1.4.1.25506.2.122.4.3.1.4) |
read-only |
Index of the Layer 3 interface that connects to the DHCP client. |
As per the MIB. |
hh3cDhcpRelay2UserInfoRowStatus (1.3.6.1.4.1.25506.2.122.4.3.1.5) |
read-create |
RowStatus |
destroy |
Row status. |
As per the MIB. |
