01-Text | 2.84 MB |
Hardware requirements (deployment on physical server)
Client configuration requirements
Application installation packages
Required Unified Platform application installation packages
NSM application installation packages
Installing NSM on the convergence deployment page of Matrix
Installing the license on the license server
Obtaining the license authorization
Upgrading and uninstalling software
Upgrading the NSM component on the convergence deployment page of Matrix
Uninstalling the NSM component on the convergence deployment page of Matrix
Overview
NSM is a basic network management component that offers basic functions such as network device management, configuration management, performance monitoring, network topology, and asset management. Additionally, NSM offers value-added service functions such as device panel, open programmable framework, automatic device access, VLAN management, SSH proxy login tool, and MIB browser tool.
As a standalone component package, the installation and operation of NSM depend on Unified Platform. This document describes the hardware and software requirements dedicated to NSM. During actual deployment, calculate the total requirements of Unified Platform, NSM, and other service components.
Preparing for installation
Server requirements
Operating system requirements
For the specific operating system requirements, see the release notes for the version of Unified Platform you want to install and use. As a best practice, use a 64-bit operating system. For more information about support for operating systems, see H3C Unified Platform Deployment Guide.
Disk partitioning
The disk partitioning data is used for reference only, which might vary in actual situations.
Mount point |
Default capacity |
Applicable modes |
File system |
Remarks |
/var/lib/docker |
400 GiB |
BIOS mode/UEFI mode |
xfs |
Expand the capacity as needed if disk space is sufficient. |
/boot |
1024 MiB |
xfs |
N/A |
swap |
1024 MiB |
swap |
N/A |
/var/lib/ssdata |
450 GiB |
xfs |
400 GiB |
xfs |
Expand the capacity as needed if disk space is sufficient. As a best practice, do not store service data in the root directory. |
/opt/matrix/app/data/base-service/backupRecovery |
50 GiB |
xfs |
Partition for storing service backup data. · If this partition is not created, service backup data is stored in the root partition. · If this partition is created, service backup data is stored in this partition. If this partition is created, the disk space for this partition must be assigned from the root partition. For example, if you set the size for this partition to 50 GiB, the root partition size must be adjusted from 400 GiB to 350 GiB. The partition size configuration might vary by service scenario requirements. |
/boot/efi |
200 MiB |
UEFI mode |
EFI System Partition |
You must create this partition if the UEFI mode is selected. |
/var/lib/etcd |
50 GiB |
xfs |
· As a best practice to avoid manual partitioning failure, mount a separate disk with a capacity of no less than 51 GB. · This partition is required for master nodes, and not required for worker nodes. |
Reserved disk space |
N/A |
N/A |
N/A |
· Used for GlusterFS. For Unified Platform in standard mode (that uses 140 GB), make sure the reserved space is more than 140 GB. Expand or reduce the capacity based on this configuration for other components whose disk capacity usage might vary. This partition must be a standard partition. · This partition is required for master nodes, and not required for worker nodes. |
Total system disk capacity: 1.7 TB+50 GB. Capacity for the above mount points: 1.23 TB+50 GB. The remaining capacity is automatically reserved for GlusterFS. |
NOTE: For information about disk partitioning for various service scenarios, see the hardware deployment guidance or deployment guide for each scenario. Description for the partitions and their capacity: · /var/lib/docker/: Related with the operation of Docker. The capacity must be determined based on actual operating conditions. Theoretically, the capacity is based on the actual service scenario, and then expanded or reduced according to the incremental disk usage after component deployment. · /var/lib/ssdata/: Used by PXC, Kafka, and ZooKeeper. Theoretically, only Unified Platform uses this partition. Expand or reduce the capacity based on this configuration for other components · /: Used by Matrix, including K8s, Harbor, and installation packages uploaded by various components. The capacity of this partition is related to the size of images uploaded by each component, and then expanded or reduced based on the disk capacity required by each component. · /opt/matrix/app/data/base-service/backupRecovery: Used for storing service backup data. The capacity is related to the size of the backup data for each component, and then expanded or reduced based on the amount of disk space occupied by each component. · GlusterFS: Unified Platform in standard mode uses 140 GB. Make sure the reserved size is greater than 140 GB. Expand or reduce the capacity based on this configuration for other components according to their disk capacity usage. This partition must be a standard partition. If the snapshot management feature (BMP_Snapshot_version_platform.zip) is used, 10 GB of the 140 GB GFS storage is allocated for snapshot management by default. |
The controller is clientless. You can access the controller from a browser.
As a best practice, use Chrome 70 (or higher) or Firefox 78 (or higher), and do not use any other browsers.
Deploy the application installation packages in this chapter as needed. The application installation packages can be deployed on x86 servers. Select the application installation packages according to the architecture type. For more information, see H3C Unified Platform Deployment Guide.
In an installation package name, the version parameter represents the software version number and the platform parameter represents the CPU architecture type.
When deploying Unified Platform, upload the application packages required by NSM as shown in Table 3.
Table 3 Application packages required by NSM
Installation package name |
Remarks |
Dependencies |
UDTP_Middle_version_platform.zip |
Middleware image repository, including databases and message queues. |
Required. |
N/A |
UDTP_GlusterFS_version_platform.zip |
Provides local shared storage functionalities, including: · Provides a universal tool for creating storage volumes. · Automatically repairs GFS anomalies caused by node anomalies and brain splits. |
Required. |
N/A |
UDTP_Core_version_platform.zip |
Provides portal, unified authentication, user management, service gateway, service data backup & restoration, application deployment management (installation, upgrade, expansion, and uninstallation), help center, permissions, operation groups, roles, role groups, unified resource UUIDs, license query and display, configuration center, and log service. |
Required. |
Middle, GlusterFS |
BMP_IMonitor_version_platform.zip |
Provides self-monitoring services, including: · Monitors hosts and containers, monitors the indexes of multiple middleware products, including etcd, GlusterFS, and MySQL, and provides a visual interface. · Provides the index alarm function. After you configure the level 1 and level 2 thresholds of the specified index, an alarm will be sent when the level 1 or level 2 threshold is reached. · Displays the list of K8s workloads, allows you to view basic information of the workloads, and supports multiple search options. |
Required. |
Core |
BMP_Report_version_platform.zip |
Provides the report function, allows other components to register report templates, and adds report tasks: · Report templates · Report tasks |
Required. |
N/A |
BMP_Alarm_version_platform.zip |
Provides basic alarm services, including receiving traps, upgrading to alarms, and forwarding alarms via SMS, email, WeChat, and WeCom. |
Required. |
Report |
BMP_Template_version_platform.zip |
Monitor template feature, which provides monitor setting management and template-based monitor index selection, threshold settings, and collection interval settings. You can select monitor templates in the monitor and auto discovery components. Access parameter template feature, which provides template-based management of the parameters used by the system to access networks, servers, storage devices, virtualization systems, containers, operating systems, databases, middleware products, or other resources. |
Required. |
N/A |
The NSM installation packages are as shown in Table 4.
Table 4 Application installation packages and dependencies
Installation package |
Dependencies |
Installation package for network resources |
NSM_FCAPS-Res_version.zip |
Required. |
Installation package for network topology |
NSM_FCAPS-Topo_version.zip |
Installation package for network performance monitoring |
NSM_FCAPS-Perf_version.zip |
Installation package for NMS intelligent configuration center |
NSM_FCAPS-ICC_version.zip |
Installation package for network assets |
NSM_FCAPS-Asset_version.zip |
Installation package for device panels |
NSM_FCAPS-Webdm_version.zip |
Installation package for automatic DHCP access |
NSM_VAS-ADA_version.zip |
Installation package for network resources, and installation package for NMS intelligent configuration center |
Installation package for open programmable framework |
NSM_VAS-OPF_version.zip |
Installation package for VLAN management |
NSM_VAS-VLAN_version.zip |
Installation package for network management tools |
NSM_Tools_version.zip |
NOTE: Support for the x86 and ARM installation packages varies by component and version. For more information, see the release notes. |
Pre-installation checklist
Table 5 Pre-installation checklist
Item |
Requirements |
Server |
Hardware |
The CPU, memory, disk, and NIC requirements are met. Unified Platform deployment is supported. |
Software |
The system time settings are configured correctly. As a best practice, configure NTP on each node and specify the same time source for all the nodes. |
Client |
The browser version meets the requirements. |
Server and OS compatibility |
To view the compatibility matrix between H3C servers and operating systems, access http://www.h3c.com/en/home/qr/default.htm?id=65 |
Software package verification
Before you install the software, execute the following commands to verify the MD5 value of each software package to ensure its integrity and correctness.
1. View the deployed installation packages.
[root@matrix145 ~]# cd /opt/matrix/app/install/packages/
[root@matrix145 packages]# ls
NSM_FCAPS-ICC_E0722_x86.zip NSM_FCAPS-Perf_E0722_x86.zip
2. View the MD5 values of the installation packages, for example, NSM_FCAPS-Perf_E0722_x86.zip.
[root@matrix145 packages]# md5sum NSM_FCAPS-Perf_E0722_x86.zip
c9212f2430db72b320161e569ca7ffa8 NSM_FCAPS-Perf_E0722_x86.zip
3. Compare the MD5 value obtained in the preceding steps with the MD5 value of the released software image file. If they match, the software package is correct.
Installation workflow
Installation of this version is based on the installation & deployment feature of Unified Platform, which adds the convergence deployment feature. This version can be installed on the Deploy > Convergence Deployment page of Matrix.
CAUTION: Before installing this version, first install Unified Platform of the corresponding version. |
The following example illustrates deploying NSM on the convergence deployment page of Matrix. The deployment workflow is shown in Table 6.
Table 6 NSM installation process
Step |
Task |
Remarks |
Prepare servers |
In standalone deployment mode, prepare one server. In cluster deployment mode, prepare at least three servers. |
Required. For hardware and software requirements, see: Hardware requirements (deployment on physical server) |
Deploy Unified Platform |
Deploy the operating system and Matrix |
Required. |
Configure Matrix cluster parameters |
Deploy the Matrix cluster |
Deploy NSM |
Required. |
Required. |
Required. |
Optional. |
Optional. |
Deploying Unified Platform
CAUTION: Before you deploy Unified Platform in a non-root environment, you must execute the following commands to manually create the log directory as the root user and edit the owner: mkdir -p /var/log/ucenter && chown admin:wheel /var/log/ucenter ll -d /var/log/ucenter If the cluster has multiple nodes, perform this operation on all nodes. To upgrade Unified Platform and its patch version, you must first install Unified Platform E0722 and NSM E0722. |
Before deploying the NSM component, you must first deploy Unified Platform of the corresponding version, and then deploy the NSM component on Unified Platform. For the Unified Platform deployment procedure, see H3C Unified Platform Deployment Guide.
If you use H3Linux 2.0, follow these steps to run the installation check script after deploying Unified Platform to ensure correct installation and use of the network performance monitoring feature of the NSM component:
1. Contact Technical Support to obtain the installation check script file CheckScript.zip.
2. Upload the script to the upgrade directory or specified directory on all master nodes.
¡ For root users, upload to the /root directory or create a specific directory under /root.
¡ For non-root users, upload to the /home/admin directory.
3. Execute the unzip CheckScript.zip command to decompress the script file, as shown in Figure 1.
Figure 1 Decompressing the script file
4. Access the CheckScript directory and execute the sudo bash python2_install.sh command to run the python2_install.sh script and install Python 2.7, as shown in Figure 2.
Figure 2 Running the python2_install.sh script
5. After successfully installing Python 2.7, you can proceed to install the NSM component.
Uploading the installation packages
1. Log in to Matrix. On the top navigation bar, click DEPLOY. From the navigation pane, select Convergence Deployment.
Figure 3 Convergence deployment page
2. Obtain the installation packages for NSM, with package name formats as shown in Table 4.
3. Click Packages Management to access the packages management page.
Figure 4 Uploading installation packages
4. Click Upload. In the dialog box that opens, click Select Files, and select component installation packages. Then, click Upload to upload the selected component installation packages to the system.
Figure 5 Uploading installation packages
5. After the upload is completed, return to the deployment management page, and click Install to access the page for selecting applications.
Selecting applications
Select the Basic Network Management checkbox, and then select the checkboxes for the components to be installed for basic network management. Click Next.
Figure 6 Selecting Basic Network Management
Figure 7 Selecting the checkboxes for components to be installed
Selecting installation packages
On this page, select the version of each component, E0722 in this example. Click Next.
Figure 8 Selecting the component versions
Configuring resources
On the resource configuration page, select an appropriate hardware resource level for product components based on the designed network and business scale. Then, click Next to access the parameter configuration page.
Figure 9 Basic network management business group
Configuring parameters
On the parameter configuration page, follow the navigation bar to configure the relevant parameters. As from version E0715, you can select the running nodes when installing components. Take the installation of the network management tools component as an example, as shown in Figure 10.
Figure 10 Selecting the nodes to run a component
In the current software version, only the Automatic DHCP Access feature (NSM_VAS-ADA) requires configuring a MACVLAN network at this step. If you have already configured a MACVLAN network when deploying other components, you can reuse the MACVLAN network.
This section describes the steps for setting up a new MACVLAN network.
1. Click Network Settings in the Subnet area. In the dialog box that opens, click Create Network.
Figure 11 Network settings
2. In the Create Network dialog box that opens, configure the following settings:
a. Specify a network name. The name can contain 1 to 64 lowercase letters and digits.
b. Create a subnet. Specify the subnet name, subnet CIDR, gateway, and other parameters.
c. In the Host area, the default entry is the current host and its uplink interface. You can add hosts as needed.
d. Click Apply.
Figure 12 Creating a network
3. After configuring the network, select it from the Select Network (IPv4) dropdown list in the Subnet area. Then, the Address Information area will be automatically populated.
Figure 13 Configuring automatic DHCP access
4. Click Deploy to start deploying all selected components.
Figure 14 Deploying applications
If you use H3Linux 2.0, after installing the NSM component, access each master node in the cluster, and execute the sudo bash python2_remove.sh command to run the python2_remove.sh script for uninstalling Python 2.7.
Logging in to NSM
After you deploy NSM, the related menus will be displayed on Unified Platform. You can use NSM features after logging in to Unified Platform.
To log in to Unified Platform:
1. In the address bar of the browser, enter the login address (the default is http://ip_address:30000/central/index.html) of Unified Platform, and press Enter to access the login page as shown in Figure 15.
¡ The ip_address parameter specifies the northbound service VIP of the Unified Platform cluster.
¡ 30000 is the port number.
2. Enter the username and password to log in to Unified Platform. The default username is admin, and the default password is Pwd@12345. After you successfully log in, the main page opens.
Registering the software
The NSM feature provides the preinstalled license, allowing you to try the NSM feature for free for 90 days and manage up to 50 devices. After 90 days, purchase a license to continue using the NSM feature normally.
NOTE: The license server version for E0722 is E1210. |
For more information about requesting and installing the license, see H3C Software Product Remote Licensing Guide.
After installing the license for the product on the license server, you only need to connect to the license server from the license management page to obtain the license authorization. To do that, perform the following tasks:
1. Log in to Unified Platform. On the top navigation bar, click System. From the navigation pane, select License Management > License Information.
2. Configure the license server parameters on the page. Table 7 describes each parameter.
Parameter |
IP Address |
The IP address is configured on the license server and used for communication among nodes in the cluster. |
Port Number |
The default is 5555, which is the same as the port number of the license server authorization service. |
Client Name |
Client name set on the license server. |
Client Password |
Password for the client set on the license server. |
3. After configuration, click Connect to establish a connection to the license server. After the connection is established successfully, NSM can automatically obtain the license authorization in real time.
Backup and restoration
You can back up and restore components on Unified Platform. For more information, see H3C Unified Platform Deployment Guide.
When backing up and restoring the performance monitoring data, follow these restrictions and guidelines:
· In the scenario with NSM deployed in standalone mode: Before overwriting and installing the operating system on the InfluxDB node, manually back up the /var/lib/ssdata/perfinfluxdb0 directory to save history performance monitoring data. After overwriting and installing the operating system on the node, SSH to the back end and upload the backup files to overwrite the /var/lib/ssdata/perfinfluxdb0 directory.
· In the scenario with NSM deployed in cluster mode: After you overwrite and install the operating system on each InfluxDB node, rebuild the node, and assign it to the cluster, you must execute the /opt/matrix/app/install/metadata/UCENTER/kernel/network/perf/scripts/major2standby.py command on the node to restore the integrity of network monitoring data.
· After you perform the preceding action sequence on InfluxDB node 1 without executing the major2standby.py command, the performance data will be lost if you continue to overwrite and install the operating system and rebuild InfluxDB node 2.
For specific steps, see cluster failure recovery in H3C Unified Platform Deployment Guide.
This chapter describes the upgrade and uninstallation procedures of the NSM component. For information about the upgrade and uninstallation procedures of Unified Platform, see H3C Unified Platform Deployment Guide.
CAUTION: When upgrading components, follow the dependency order. For example, upgrade the network resource component before the network topology component, because the latter depends on the former. For more information about the dependencies, see Table 4. |
1. Log in to Matrix, and access the Deploy > Convergence Deployment page.
2. Click the icon to the left
of the basic network management component to expand the component information.
3. Click the icon in the Actions column for the component to be upgraded to access
the upgrade page.
Figure 16 Clicking the Upgrade icon
4. NSM supports upgrading a single component and bulk upgrading multiple components. Take bulk upgrade as an example. Click the Upload button. In the dialog box that opens, click the Select Files button. Select the installation packages you want to upgrade. Then, click the Upload button.
5. Select the installation packages to be upgraded, and then click Upgrade to upgrade the corresponding components.
Figure 17 Bulk upgrade
CAUTION: · When uninstalling applications on the application deployment page of Matrix, uninstall applications in the reverse dependency order. For example, because the network topology application depends on the network resource application, first uninstall the former and then the latter. For the dependencies, see Table 4. · When you uninstall an application on the convergence deployment page, other applications that depend on it will also be uninstalled. For example, if you select the network resource application, other applications that depend on it will also be selected. When you uninstall applications, the system will automatically uninstall applications one by one based on their dependencies. For the dependencies, see Table 4. |
2. Select the components to be uninstalled, and click Uninstall. In the dialog box that opens, click OK to uninstall the selected components.
Figure 18 Uninstalling components
