01-HH3C-L2VPN-MIB | 58.15 KB |
HH3C-L2VPN-MIB
About this MIB
Use this MIB to obtain L2VPN configuration information. This MIB also contains notifications about PW state changes.
MIB file name
hh3c-l2vpn.mib
Notifications
hh3cL2vpnPwSwitchPtoB
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.162.0.1 |
Traffic is switched from the primary PW to the backup PW. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.2(hh3cL2vpnPwSwitchBtoP) |
OFF |
Notification triggers
This notification is generated when the traffic is switched from the primary PW to the backup PW.
System impact
Milliseconds of packet loss might occur during the PW switchover process.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-switch command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-switch command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.3.4.1.1 (hh3cL2vpnXcgPwIndex) |
PW index associated with the cross-connect. |
hh3cL2vpnXcgPwIndex hh3cL2vpnXcgName hh3cL2vpnXcgConnName |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.5 (hh3cL2vpnXcgPwPeerIp) |
IP address of the PW associated with the cross-connect. |
IpAddress |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.6 (hh3cL2vpnXcgPwPwID) |
ID of the PW associated with the cross-connect. |
Unsigned32 |
As per the MIB. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.2 |
Traffic is switched from the backup PW to the primary PW. |
Recovery |
Warning |
OFF |
This notification is generated when the traffic is switched from the backup PW to the primary PW.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Unsigned32 |
As per the MIB. |
IpAddress |
As per the MIB. |
Unsigned32 |
As per the MIB. |
Recommended action
