20-NVGRE
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10020-NVGRE
Table of Contents
Related Documents
01-HH3C-NVGRE-MIB
01-HH3C-NVGRE-MIB 73.67 KB
HH3C-NVGRE-MIB
About this MIB
Use this table to manage NVGRE configuration.
MIB file name
hh3c-nvgre.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNvgre(156)
Tabular objects
hh3cNvgreScalarGroup
About this table
Use this table to obtain global NVGRE information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cNvgreNextNvgreID (1.3.6.1.4.1.25506.2.156.1.1.1)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Next available VSID.
As per the MIB.
hh3cNvgreConfigured (1.3.6.1.4.1.25506.2.156.1.1.2)
read-only
Unsigned32
Total number of VSIDs in use on the device.
As per the MIB.
hh3cNvgreTable
About this table
Use this table to configure NVGRE.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cNvgreID.
Object (OID)
Access
Value range
Implementation
hh3cNvgreID (1.3.6.1.4.1.25506.2.156.1.2.1.1)
not-accessible
Unsigned32
VSID.
As per the MIB.
hh3cNvgreVsiIndex (1.3.6.1.4.1.25506.2.156.1.2.1.2)
read-create
Unsigned32
VSI index.
Cannot be modified after creation.
hh3cNvgreRemoteMacCount (1.3.6.1.4.1.25506.2.156.1.2.1.3)
read-only
Unsigned32
Number of remote MAC addresses for the VSID.
As per the MIB.
hh3cNvgreRowStatus (1.3.6.1.4.1.25506.2.156.1.2.1.4)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
hh3cNvgreTunnelTable
About this table
Use this table to configure NVGRE tunnels.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cNvgreID and hh3cNvgreTunnelID.
Object (OID)
Access
Value range
Implementation
hh3cNvgreTunnelID (1.3.6.1.4.1.25506.2.156.1.3.1.1)
not-accessible
Unsigned32
Tunnel ID.
As per the MIB.
hh3cNvgreTunnelRowStatus (1.3.6.1.4.1.25506.2.156.1.3.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cNvgreTunnelBoundTable
About this table
Use this table to obtain the number of VSIDs associated with an NVGRE tunnel.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cNvgreTunnelID.
Object (OID)
Access
Value range
Implementation
hh3cNvgreTunnelBoundNvgreNum (1.3.6.1.4.1.25506.2.156.1.4.1.1)
read-only
Unsigned32
Number of VSIDs.
As per the MIB.
hh3cNvgreMacTable
About this table
Use this table to obtain remote MAC address entries for NVGRE.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cNvgreVsiIndex and hh3cNvgreMacAddr.
Object (OID)
Access
Value range
Implementation
hh3cNvgreMacAddr (1.3.6.1.4.1.25506.2.156.1.5.1.1)
not-accessible
MacAddress
OCTET STRING (6)
MAC address.
As per the MIB.
hh3cNvgreMacTunnelID (1.3.6.1.4.1.25506.2.156.1.5.1.2)
read-only
Unsigned32
Tunnel ID.
As per the MIB.
hh3cNvgreMacType (1.3.6.1.4.1.25506.2.156.1.5.1.3)
read-only
INTEGER
selfLearned(1),
staticConfigured(2),
protocolLearned(3)
MAC address type.
As per the MIB.
hh3cNvgreStaticMacTable
About this table
Use this table to configure static remote MAC address entries for NVGRE.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cNvgreVsiIndex and hh3cNvgreStaticMacAddr.
Object (OID)
Access
Value range
Implementation
hh3cNvgreStaticMacAddr (1.3.6.1.4.1.25506.2.156.1.6.1.1)
not-accessible
MacAddress
OCTET STRING (6)
Remote MAC address.
As per the MIB.
hh3cNvgreStaticMacTunnelID (1.3.6.1.4.1.25506.2.156.1.6.1.2)
read-create
Unsigned32
Tunnel ID.
hh3cNvgreStaticMacRowStatus (1.3.6.1.4.1.25506.2.156.1.6.1.3)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
