- 19-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-NQA-MIB
- 05-HH3C-NTP-MIB
- 06-HH3C-RMON-EXT2-MIB
- 07-HH3C-SNMP-EXT-MIB
- 08-RMON-MIB
- 09-RMON2-MIB
- 10-SFLOW-MIB
- 11-SNMP-FRAMEWORK-MIB
- 12-SNMP-MPD-MIB
- 13-SNMP-NOTIFICATION-MIB
- 14-SNMP-TARGET-MIB
- 15-SNMP-USER-BASED-SM-MIB
- 16-SNMP-VIEW-BASED-ACM-MIB
- 17-SNMPv2-MIB
04-HH3C-NQA-MIB | 442.32 KB |
hh3cNqaMIBVersion (1.3.6.1.4.1.25506.8.3.1.1)
hh3cNqaAgentEnable (1.3.6.1.4.1.25506.8.3.1.5)
hh3cNqaServerEnable (1.3.6.1.4.1.25506.8.3.1.8)
hh3cNqaStatsMaxGroupNumber (1.3.6.1.4.1.25506.8.3.1.9)
hh3cNqaStatisticsReactionTable
HH3C-NQA-MIB
About this MIB
Use this MIB to implement the following functions:
· Configure the extended attributes for NQA operations.
· Display the statistical results of the NQA operations.
· Display the extended results of the jitter operations.
· Configure TCP/UDP server properties.
· Save the statistical results of an operation in a certain period and save multiple statistics groups.
· Save a certain number of history records for an operation.
· Configure the start and end time for each operation.
· Display the statistical results and history records in a certain period.
MIB file name
hh3c-nqa.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cNqa(3)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaMIBVersion (1.3.6.1.4.1.25506.8.3.1.1) |
read-only |
DisplayString |
OCTET STRING (0..255) |
MIB version. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaAgentEnable (1.3.6.1.4.1.25506.8.3.1.5) |
read-write |
INTEGER |
Enable(1), disable(2) |
Enables or disables the NQA client. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaServerEnable (1.3.6.1.4.1.25506.8.3.1.8) |
read-write |
INTEGER |
Enables or disables the NQA server. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaStatsMaxGroupNumber (1.3.6.1.4.1.25506.8.3.1.9) |
read-only |
Integer32 |
Standard MIB values. |
Maximum number of statistics groups that can be saved. |
As per the MIB. |
Tabular objects
hh3cNqaCtlTable
About this table
This table configures the NQA operations.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
· The parameters not supported by pingCtlType are not configurable.
· With configuration modified, the results, history records, and statistics of the corresponding entries will be cleared.
· The results, history records, and statistics must truly reflect the operation results of the current configuration.
· The users cannot obtain the probe results of the previous configuration.
· The result is invalid if a parameter not supported by pingCtlType is configured.
· The table displays the parameters supported by pingCtlType.
pingCtlType value |
Supported parameters |
pingIcmpEcho |
hh3cNqaCtlTTL hh3cNqaCtlHistoryKeptTime hh3cNqaCtlHistoryEnable hh3cNqaCtlVPNInstance |
pingUdpEcho hh3cNqaUdpEcho |
hh3cNqaCtlTargetPort hh3cNqaCtlSourcePort hh3cNqaCtlTTL hh3cNqaCtlHistoryKeptTime hh3cNqaCtlHistoryEnable hh3cNqaCtlVPNInstance |
pingSnmpQuery |
pingTcpConnectionAttempt hh3cNqaTcpconnect |
hh3cNqaCtlTargetPort hh3cNqaCtlTTL hh3cNqaCtlHistoryKeptTime hh3cNqaCtlHistoryEnable hh3cNqaCtlVPNInstance |
hh3cNqajitter (for UDP jitter operations) Note: The hh3cNqaCtlCodecType object is set to notDefined(1). |
hh3cNqaCtlTargetPort hh3cNqaCtlSourcePort hh3cNqaCtlTTL hh3cNqaCtlJitterAdminInterval hh3cNqaCtlJitterAdminNumPackets hh3cNqaCtlCodecType hh3cNqaCtlVPNInstance |
hh3cNqajitter (for voice operations) Note: The hh3cNqaCtlCodecType object is set to g711Alaw(2), g711Ulaw(3), or g729A(4). |
hh3cNqaCtlTargetPort hh3cNqaCtlSourcePort hh3cNqaCtlTTL hh3cNqaCtlJitterAdminInterval hh3cNqaCtlJitterAdminNumPackets hh3cNqaCtlICPIFAdvFactor hh3cNqaCtlCodecType hh3cNqaCtlVPNInstance |
hh3cNqajitter (for ICMP jitter operations) Note: The hh3cNqaCtlCodecType object is set to icmpTimestamp(5). |
hh3cNqaHttp |
hh3cNqaCtlTTL hh3cNqaCtlHistoryKeptTime hh3cNqaCtlHistoryEnable hh3cNqaCtlHttpOperationType hh3cNqaCtlHttpOperationString hh3cNqaCtlVPNInstance |
hh3cNqadlsw |
hh3cNqadhcp |
hh3cNqaftp |
hh3cNqaCtlTTL hh3cNqaCtlHistoryKeptTime hh3cNqaCtlHistoryEnable hh3cNqaCtlFtpOperationType hh3cNqaCtlFtpUsername hh3cNqaCtlFtpPassword hh3cNqaCtlFtpOperationString hh3cNqaCtlVPNInstance |
hh3cNqaHttp2 |
Columns
The table indexes are pingCtlOwnerIndex and pingCtlTestName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaCtlTargetPort (1.3.6.1.4.1.25506.8.3.1.2.1.1) |
read-create |
Integer32 |
Integer32 (0..65536) |
Destination port. |
Value range: 0 to 65535. If pingCtlType uses value pingUdpEcho or pingTcpConnectionAttempt, this object value must be 7. If pingCtlType uses value hh3cNqaUdpEcho or hh3cNqaTcpConnect, this object value cannot be 7. |
hh3cNqaCtlSourcePort (1.3.6.1.4.1.25506.8.3.1.2.1.2) |
read-create |
Integer32 |
Source port. |
Value range: 0 to 65535. |
hh3cNqaCtlTTL (1.3.6.1.4.1.25506.8.3.1.2.1.3) |
read-create |
Integer32 |
TTL for an NQA operation. |
Value range: 1 to 255. |
hh3cNqaCtlJitterAdminInterval (1.3.6.1.4.1.25506.8.3.1.2.1.4) |
read-create |
Integer32 |
Integer32 (0..60000) |
Time interval between two continuous probes in a jitter operation. |
Value range: 0 to 60000. |
hh3cNqaCtlJitterAdminNumPackets (1.3.6.1.4.1.25506.8.3.1.2.1.5) |
read-create |
Integer32 |
Number of packets in a jitter operation. |
For ICMP jitter and UDP jitter operations, the value range is 10 to 1000 and the default value is 10. For voice operations, the value range is 10 to 60000 and the default value is 1000. The object is applicable to only ICMP jitter, voice, and UDP jitter operations. |
hh3cNqaCtlHttpOperationType (1.3.6.1.4.1.25506.8.3.1.2.1.6) |
read-create |
INTEGER |
get(1), post(2), raw(3) |
HTTP operation type. |
As per the MIB. |
hh3cNqaCtlHttpOperationString (1.3.6.1.4.1.25506.8.3.1.2.1.7) |
read-create |
DisplayString |
OCTET STRING (0..1023) |
HTTP operation string. |
If hh3cNqaCtlHttpOperationType uses value raw(3), the URL length is 0 to 1023. If hh3cNqaCtlHttpOperationType uses value get(1) or post(2), the following information applies: The object contains resource and HTTP version, and the resource is part of the URL. The common format of URL is http://host/resource. The length of the resource is 0 to 246 and the resource is case sensitive. The HTTP version is case insensitive and supports HTTP/1.0 and HTTP/1.1. The default HTTP version is v1.0. The object value must contain and only contain one space that separates the resource and HTTP version. If the object value is a zero-length string, the default resource and HTTP version are used. |
hh3cNqaCtlFtpOperationType (1.3.6.1.4.1.25506.8.3.1.2.1.8) |
read-create |
INTEGER |
get(1), put(2) |
FTP operation type. |
As per the MIB. |
hh3cNqaCtlFtpUsername (1.3.6.1.4.1.25506.8.3.1.2.1.9) |
read-create |
DisplayString |
OCTET STRING (0..32) |
FTP username. |
As per the MIB. |
hh3cNqaCtlFtpPassword (1.3.6.1.4.1.25506.8.3.1.2.1.10) |
read-create |
DisplayString |
FTP password. |
As per the MIB. |
hh3cNqaCtlFtpOperationString (1.3.6.1.4.1.25506.8.3.1.2.1.11) |
read-create |
DisplayString |
File name transmitted between the FTP client and server. |
If hh3cNqaCtlFtpOperationType uses value put(2), the length of the object is 1 to 200. If hh3cNqaCtlFtpOperationType uses value get(1), the length of the object is 1 to 247. |
hh3cNqaCtlVPNInstance (1.3.6.1.4.1.25506.8.3.1.2.1.12) |
read-create |
DisplayString |
VPN name. |
Supported. The length of the object is 0 to 31. The object is not configurable if the device does not support VPN. |
hh3cNqaCtlICPIFAdvFactor (1.3.6.1.4.1.25506.8.3.1.2.1.15) |
read-create |
Integer32 |
Value of the advantage factor. |
Value range: 0 to 20. |
hh3cNqaCtlCodecType (1.3.6.1.4.1.25506.8.3.1.2.1.16) |
read-create |
INTEGER |
notDefined(1), g711Alaw(2), g711Ulaw(3), g729A(4), icmpTimestamp(5) |
Code type for jitter operations. |
The object is valid only if pingCtlType uses hh3cNqajitter. For UDP jitter operations, pingCtlType uses hh3cNqajitter and this object uses value notDefined. For voice operations, pingCtlType uses hh3cNqajitter and this object uses value g711Alaw, g711Ulaw, or g729A. For ICMP jitter operations, pingCtlType uses hh3cNqajitter and this object uses value icmpTimestamp. If this object uses another value to indicate a new operation type, the system performs the following tasks: · Delete the entries of the old operation type. · Use the default settings to create entries for the new operation type. Currently, the values notDefined, g711Alaw, g711Ulaw, g729A, and icmpTimestamp are supported. |
hh3cNqaResultsTable
About this table
This table displays the saved configuration of the NQA operations.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaResultsRttNumDisconnects (1.3.6.1.4.1.25506.8.3.1.3.1.1) |
read-only |
Unsigned32 |
Number of disconnections by the peer. |
As per the MIB. |
hh3cNqaResultsRttTimeouts (1.3.6.1.4.1.25506.8.3.1.3.1.2) |
read-only |
Unsigned32 |
Number of timeout occurrences in an operation.
As per the MIB. |
hh3cNqaResultsRttNoConnections (1.3.6.1.4.1.25506.8.3.1.3.1.4) |
read-only |
Unsigned32 |
Number of failures to connect with the peer. |
As per the MIB. |
hh3cNqaResultsRttDrops (1.3.6.1.4.1.25506.8.3.1.3.1.5) |
read-only |
Unsigned32 |
Number of failures to allocate the system resources. |
As per the MIB. |
hh3cNqaResultsRttSequenceErrors (1.3.6.1.4.1.25506.8.3.1.3.1.6) |
read-only |
Unsigned32 |
Number of failures due to out-of-sequence packets. |
As per the MIB. |
hh3cNqaResultsRttStatsErrors (1.3.6.1.4.1.25506.8.3.1.3.1.7) |
read-only |
Unsigned32 |
Number of failures due to other errors. |
As per the MIB. |
hh3cNqaResultsMaxDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.8) |
read-only |
Unsigned32 |
Maximum delay from source to destination. |
As per the MIB. |
hh3cNqaResultsMaxDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.9) |
read-only |
Unsigned32 |
Maximum delay from destination to source. |
As per the MIB. |
hh3cNqaResultsLostPacketRatio (1.3.6.1.4.1.25506.8.3.1.3.1.10) |
read-only |
Unsigned32 |
Packet loss ratio. |
This object value reflects the packet loss ratio for all operations in DISMAN-PING-MIB and HH3C-NQA-MIB. |
hh3cNqaResultsPacketLateArrival (1.3.6.1.4.1.25506.8.3.1.3.1.11) |
read-only |
Unsigned32 |
Number of packets arrived after the timeout. |
As per the MIB. |
hh3cNqaResultsRttSum (1.3.6.1.4.1.25506.8.3.1.3.1.12) |
read-only |
Unsigned32 |
Sum of round-trip time. |
As per the MIB. |
hh3cNqaResultsNumOfDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.13) |
read-only |
Unsigned32 |
Number of delays from source to destination. |
As per the MIB. |
hh3cNqaResultsMinDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.14) |
read-only |
Unsigned32 |
Minimum delay from source to destination. |
As per the MIB. |
hh3cNqaResultsSumDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.15) |
read-only |
Unsigned32 |
Sum of delays from source to destination. |
As per the MIB. |
hh3cNqaResultsSum2DelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.16) |
read-only |
Unsigned32 |
Square sum of delays from source to destination. |
As per the MIB. |
hh3cNqaResultsNumOfDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.17) |
read-only |
Unsigned32 |
Number of delays from destination to source. |
As per the MIB. |
hh3cNqaResultsMinDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.18) |
read-only |
Unsigned32 |
Minimum delay from destination to source. |
As per the MIB. |
hh3cNqaResultsSumDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.19) |
read-only |
Unsigned32 |
Sum of delays from destination to source. |
As per the MIB. |
hh3cNqaResultsSum2DelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.20) |
read-only |
Unsigned32 |
Square sum of delays from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsTable
About this table
This table displays the saved jitter operations.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaJitterStatsNumOfRTT (1.3.6.1.4.1.25506.8.3.1.4.1.1) |
read-only |
Counter32 |
Number of received response packets. |
As per the MIB. |
hh3cNqaJitterStatsMinOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.2) |
read-only |
Gauge32 |
Minimum positive jitter from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsMaxOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.3) |
read-only |
Gauge32 |
Maximum positive jitter from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsNumOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.4) |
read-only |
Gauge32 |
Number of positive jitters from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsSumOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.5) |
read-only |
Gauge32 |
Sum of positive jitters from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsSum2PositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.6) |
read-only |
Gauge32 |
Square sum of positive jitters from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsMinOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.7) |
read-only |
Gauge32 |
Minimum absolute value among negative jitters from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsMaxOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.8) |
read-only |
Gauge32 |
Maximum absolute value among negative jitters from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsNumOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.9) |
read-only |
Gauge32 |
Number of negative jitters from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsSumOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.10) |
read-only |
Gauge32 |
Sum of negative jitters from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsSum2NegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.11) |
read-only |
Gauge32 |
Square sum of negative jitters from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsMinOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.12) |
read-only |
Gauge32 |
Minimum positive jitter from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsMaxOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.13) |
read-only |
Gauge32 |
Maximum positive jitter from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsNumOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.14) |
read-only |
Gauge32 |
Number of positive jitters from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsSumOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.15) |
read-only |
Gauge32 |
Sum of positive jitters from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsSum2PositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.16) |
read-only |
Gauge32 |
Square sum of positive jitters from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsMinOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.17) |
read-only |
Gauge32 |
Minimum absolute value among negative jitters from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsMaxOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.18) |
read-only |
Gauge32 |
Maximum absolute value among negative jitters from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsNumOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.19) |
read-only |
Gauge32 |
Number of negative jitters from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsSumOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.20) |
read-only |
Gauge32 |
Sum of absolute values of negative jitters from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsSum2NegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.21) |
read-only |
Gauge32 |
Square sum of negative jitters from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsPacketLossSD (1.3.6.1.4.1.25506.8.3.1.4.1.22) |
read-only |
Gauge32 |
Number of lost packets from source to destination. |
As per the MIB. |
hh3cNqaJitterStatsPacketLossDS (1.3.6.1.4.1.25506.8.3.1.4.1.23) |
read-only |
Gauge32 |
Number of lost packets from destination to source. |
As per the MIB. |
hh3cNqaJitterStatsAvePositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.24) |
read-only |
Gauge32 |
Average positive jitter from source to destination. |
If the time difference between two consecutive packets from source to destination is positive, the statistical time is added by 1 and the sum of jitters is added by the time difference.
hh3cNqaJitterStatsAveNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.25) |
read-only |
Gauge32 |
Average negative jitter from source to destination. |
If the time difference between two consecutive packets from source to destination is negative, the statistical time is added by 1 and the sum of jitters is added by the absolute value of the time difference.
hh3cNqaJitterStatsAvePositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.26) |
read-only |
Gauge32 |
Average positive jitter from destination to source. |
If the time difference between two consecutive packets from destination to source is positive, the statistical time is added by 1 and the sum of jitters is added by the time difference.
hh3cNqaJitterStatsAveNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.27) |
read-only |
Gauge32 |
Average negative jitter from destination to source. |
If the time difference between two consecutive packets from destination to source is negative, the statistical time is added by 1 and the sum of jitters is added by the absolute value of the time difference.
hh3cNqaJitterStatsPktLossUnknown (1.3.6.1.4.1.25506.8.3.1.4.1.28) |
read-only |
Gauge32 |
Number of lost packets for unknown reasons. |
hh3cNqaJitterStatsOperOfICPIF (1.3.6.1.4.1.25506.8.3.1.4.1.29) |
read-only |
Gauge32 |
ICPIF value of the operation. |
Supports only voice operations. |
hh3cNqaJitterStatsOperOfMOS (1.3.6.1.4.1.25506.8.3.1.4.1.30) |
read-only |
Gauge32 |
MOS value of the operation. |
Supports only voice operations. The object value is 100 times the actual value. |
hh3cNqaTcpServerTable
About this table
This table configures the TCP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cNQATcpServerIpAddress and h3cNQATcpServerPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaTcpServerIpAddress (1.3.6.1.4.1.25506.8.3.1.6.1.1) |
not-accessible |
InetAddress |
IP address of the TCP server. |
Supports both IPv4 and IPv6 addresses. |
hh3cNqaTcpServerPort (1.3.6.1.4.1.25506.8.3.1.6.1.2) |
not-accessible |
Integer32 |
Port number of the TCP server. |
Value range: 1 to 65535. |
hh3cNqaTcpServerRowStatus (1.3.6.1.4.1.25506.8.3.1.6.1.3) |
read-create |
RowStatus |
Row status. |
Supports only values active(1), createAndgo(4), and destroy(6). |
hh3cNqaUdpServerTable
About this table
This table configures the UDP server.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cNQAUdpServerIpAddress and h3cNQAUdpServerPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaUdpServerIpAddress (1.3.6.1.4.1.25506.8.3.1.7.1.1) |
not-accessible |
InetAddress |
IP address of the UDP server. |
hh3cNqaUdpServerPort (1.3.6.1.4.1.25506.8.3.1.7.1.2) |
not-accessible |
Integer32 |
Port number of the UDP server. |
hh3cNqaUdpServerRowStatus (1.3.6.1.4.1.25506.8.3.1.7.1.3) |
read-create |
RowStatus |
Row status. |
hh3cNqaStatisticsCtlTable
About this table
This table configures the collection of NQA operation statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaCtlStatisticsInterval (1.3.6.1.4.1.25506.8.3.1.10.1.1) |
read-create |
Unsigned32 |
Statistics collection interval, in minutes. |
Value range: 1 to 35791394. Default: 60. |
hh3cNqaCtlStatisticsGroupNumber (1.3.6.1.4.1.25506.8.3.1.10.1.2) |
read-create |
Unsigned32 |
Maximum number of statistics groups. |
Value range: 0 to the value of hh3cNqaStatsMaxGroupNumber. Default: 2. If the object value is 0, no statistics collection will be enabled. |
hh3cNqaCtlStatisticsKeptTime (1.3.6.1.4.1.25506.8.3.1.10.1.3) |
read-create |
Unsigned32 |
Unsigned32 (1..1440) |
Statistics lifetime, in minutes. |
Value range: 1 to 1440. Default: 120. |
hh3cNqaCtlBeginTime (1.3.6.1.4.1.25506.8.3.1.10.1.4) |
read-create |
DateAndTime |
Start time for saving statistics. |
Obeys the time format. Available year range: 2000 to 2035. |
hh3cNqaCtlLifeTime (1.3.6.1.4.1.25506.8.3.1.10.1.5) |
read-create |
Unsigned32 |
Operation lifetime, in seconds. |
Value range: 1 to 2147483647. The value 4294967295 indicates that the operation will never stop. |
hh3cNqaStatisticsResultsTable
About this table
This table displays NQA operation statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pingCtlOwnerIndex, pingCtlTestName, and h3cNQAStatResIndex.
The OID of the table is 1.3.6.1.4.1.25506.8.3.1.11.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaStatResIndex (1.3.6.1.4.1.25506.8.3.1.11.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Statistics table index. |
As per the MIB. |
hh3cNqaStatResIpTargetAddressType (1.3.6.1.4.1.25506.8.3.1.11.1.2) |
read-only |
InetAddressType |
Type of destination IP address. |
As per the MIB. |
hh3cNqaStatResIpTargetAddress (1.3.6.1.4.1.25506.8.3.1.11.1.3) |
read-only |
InetAddress |
Destination IP address. |
As per the MIB. |
hh3cNqaStatResMinRtt (1.3.6.1.4.1.25506.8.3.1.11.1.4) |
read-only |
Gauge32 |
Minimum round-trip time. |
As per the MIB. |
hh3cNqaStatResMaxRtt (1.3.6.1.4.1.25506.8.3.1.11.1.5) |
read-only |
Gauge32 |
Maximum round-trip time. |
As per the MIB. |
hh3cNqaStatResAverageRtt (1.3.6.1.4.1.25506.8.3.1.11.1.6) |
read-only |
Gauge32 |
Average round-trip time. |
As per the MIB. |
hh3cNqaStatResProbeResponses (1.3.6.1.4.1.25506.8.3.1.11.1.7) |
read-only |
Counter32 |
Number of received packets. |
As per the MIB. |
hh3cNqaStatResSentProbes (1.3.6.1.4.1.25506.8.3.1.11.1.8) |
read-only |
Counter32 |
Number of sent probe packets. |
As per the MIB. |
hh3cNqaStatResRttSumOfSquares (1.3.6.1.4.1.25506.8.3.1.11.1.9) |
read-only |
Counter32 |
Square sum of round-trip time. |
As per the MIB. |
hh3cNqaStatResStartTime (1.3.6.1.4.1.25506.8.3.1.11.1.10) |
read-only |
DateAndTime |
Start time of the statistics. |
As per the MIB. |
hh3cNqaStatResInterval (1.3.6.1.4.1.25506.8.3.1.11.1.11) |
read-only |
Gauge32 |
End time of the statistics. |
As per the MIB. |
hh3cNqaStatResRttNumDisconnects (1.3.6.1.4.1.25506.8.3.1.11.1.12) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResRttTimeouts (1.3.6.1.4.1.25506.8.3.1.11.1.13) |
read-only |
Counter32 |
Number of timeout occurrences in an operation. |
As per the MIB. |
hh3cNqaStatResRttBusies (1.3.6.1.4.1.25506.8.3.1.11.1.14) |
read-only |
Counter32 |
Number of failures due to the busy system. |
As per the MIB. |
hh3cNqaStatResRttNoConnections (1.3.6.1.4.1.25506.8.3.1.11.1.15) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResRttDrops (1.3.6.1.4.1.25506.8.3.1.11.1.16) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResRttSequenceErrors (1.3.6.1.4.1.25506.8.3.1.11.1.17) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResRttErrors (1.3.6.1.4.1.25506.8.3.1.11.1.18) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResLostPacketRatio (1.3.6.1.4.1.25506.8.3.1.11.1.19) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatResPacketLateArrival (1.3.6.1.4.1.25506.8.3.1.11.1.20) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResRttSum (1.3.6.1.4.1.25506.8.3.1.11.1.21) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResNumOfDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.22) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResMinDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.23) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatResMaxDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.24) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatResSumDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.25) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResSum2DelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.26) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResNumOfDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.27) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResMinDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.28) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatResMaxDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.29) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatResSumDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.30) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatResSum2DelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.31) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaGroupStatsJitterTable
About this table
This table displays jitter operation statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pingCtlOwnerIndex, pingCtlTestName, and h3cNQAStatJitterIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNqaStatJitterIndex (1.3.6.1.4.1.25506.8.3.1.12.1.1) |
not-accessible |
Unsigned32 |
Statistics table index for a jitter operation. |
As per the MIB. |
hh3cNqaStatJitterMinOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.2) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatJitterMaxOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.3) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatJitterNumOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.4) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterSumOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.5) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterSumOfSquarePosSD (1.3.6.1.4.1.25506.8.3.1.12.1.6) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterMinOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.7) |
read-only |
Gauge32 |
Minimum negative jitter from source to destination. |
As per the MIB. |
hh3cNqaStatJitterMaxOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.8) |
read-only |
Gauge32 |
Maximum negative jitter from source to destination. |
As per the MIB. |
hh3cNqaStatJitterNumOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.9) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterSumOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.10) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterSumOfSquareNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.11) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterMinOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.12) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatJitterMaxOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.13) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatJitterNumOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.14) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterSumOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.15) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterSumOfSquarePosDS (1.3.6.1.4.1.25506.8.3.1.12.1.16) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterMinOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.17) |
read-only |
Gauge32 |
Minimum negative jitter from destination to source. |
As per the MIB. |
hh3cNqaStatJitterMaxOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.18) |
read-only |
Gauge32 |
Maximum negative jitter from destination to source. |
As per the MIB. |
hh3cNqaStatJitterNumOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.19) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterSumOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.20) |
read-only |
Counter32 |
Sum of negative jitters from destination to source. |
As per the MIB. |
hh3cNqaStatJitterSumOfSquareNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.21) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterPacketLossSD (1.3.6.1.4.1.25506.8.3.1.12.1.22) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterPacketLossDS (1.3.6.1.4.1.25506.8.3.1.12.1.23) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterAvePosSD (1.3.6.1.4.1.25506.8.3.1.12.1.24) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatJitterAveNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.25) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatJitterAvePosDS (1.3.6.1.4.1.25506.8.3.1.12.1.26) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatJitterAveNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.27) |
read-only |
Gauge32 |
As per the MIB. |
hh3cNqaStatJitterPktLossUnknown (1.3.6.1.4.1.25506.8.3.1.12.1.28) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatJitterMaxOfICPIF (1.3.6.1.4.1.25506.8.3.1.12.1.29) |
read-only |
Gauge32 |
Maximum ICPIF value. |
hh3cNqaStatJitterMinOfICPIF (1.3.6.1.4.1.25506.8.3.1.12.1.30) |
read-only |
Gauge32 |
Minimum ICPIF value. |
hh3cNqaStatJitterMaxOfMOS (1.3.6.1.4.1.25506.8.3.1.12.1.31) |
read-only |
Gauge32 |
Maximum MOS value. |
hh3cNqaStatJitterMinOfMOS (1.3.6.1.4.1.25506.8.3.1.12.1.32) |
read-only |
Gauge32 |
Minimum MOS value. |
hh3cNqaReactionTable
About this table
This table configures reaction entries for NQA operations.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cNqaReactOwnerIndex, h3cNqaReactTestName, and h3cNqaReactItemIndex.
Access |
Syntax |
Value range |
Implementation |
hh3cNqaReactOwnerIndex (1.3.6.1.4.1.25506.8.3.1.13.1.1) |
accessible-for-notify |
SnmpAdminString |
OCTET STRING(0..32) |
Administrator index. |
As per the MIB. |
hh3cNqaReactTestName (1.3.6.1.4.1.25506.8.3.1.13.1.2) |
SnmpAdminString |
Operation tag. |
As per the MIB. |
hh3cNqaReactItemIndex (1.3.6.1.4.1.25506.8.3.1.13.1.3) |
Unsigned32 |
Unsigned32 (1..10) |
A reaction entry is identified by its ID uniquely for an NQA operation. |
As per the MIB. |
hh3cNqaReactCheckedElement (1.3.6.1.4.1.25506.8.3.1.13.1.4) |
read-create |
INTEGER |
probetime(1) probefailure(2) jitterrtt(3) jitterpacketloss(4) jittersd(5) jiterds(6) icpif(7) mos(8) jitterOwdSD(9) jitterOwdDS(10) testfailure(11) testresultchangge(12) |
Monitored performance metric. |
As per the MIB. |
hh3cNqaReactThresholdUpperLimit (1.3.6.1.4.1.25506.8.3.1.13.1.5) |
read-create |
Unsigned32 |
Upper limit of the threshold. |
If hh3cNqaReactCheckedElement uses value icpif, the value range of this object is 1 to 100. If hh3cNqaReactCheckedElement uses value mos, the value range of this object is 1 to 500. If hh3cNqaReactCheckedElement uses value jittersd, jitterds, jitterOwdSD, jitterOwdDS, jitterrtt, or probetime, the value range of this object is 0 to 3600000 milliseconds. If hh3cNqaReactCheckedElement uses value testfailure or testresultchangge, the value range of this object is 1 to 15. In other cases, the value of this object should not be set. |
hh3cNqaReactThresholdLowerLimit (1.3.6.1.4.1.25506.8.3.1.13.1.6) |
read-create |
Unsigned32 |
Lower limit of the threshold. |
If hh3cNqaReactCheckedElement uses value icpif, the value range of this object is 1 to 100. If hh3cNqaReactCheckedElement uses value mos, the value range of this object is 1 to 500. If hh3cNqaReactCheckedElement uses value jittersd, jitterds, jitterOwdSD, jitterOwdDS, jitterrtt, or probetime, the value range of this object is 0 to 3600000 milliseconds. In other cases, the value of this object should not be set. |
hh3cNqaReactThresholdType (1.3.6.1.4.1.25506.8.3.1.13.1.7) |
read-create |
INTEGER |
invalid(0), average(1), consecutive(2), accumulative(3) |
Threshold type. |
If hh3cNqaReactCheckedElement uses value jittersd or jitterds, this object value can be average or accumulative. If hh3cNqaReactCheckedElement uses value jitterpacketloss, this object value can be accumulative. If hh3cNqaReactCheckedElement uses value probetime, this object value can be average, consecutive, or accumulative. If hh3cNqaReactCheckedElement uses value probefailure, this object value can be consecutive or accumulative. If hh3cNqaReactCheckedElement uses value jitterrtt, this object value can be average or ccumulative. In other cases, the value of this object should not be set. |
hh3cNqaReactThresholdConsecNum (1.3.6.1.4.1.25506.8.3.1.13.1.8) |
read-create |
Unsigned32 |
Consecutive threshold limit. If the threshold type is not set to consecutive, this object is meaningless. |
If hh3cNqaReactCheckedElement uses value probetime, probefailure, or test-failure, the value range of this object is 1 to 16. In other cases, the value of this object should not be set. |
hh3cNqaReactThresholdAccumNum (1.3.6.1.4.1.25506.8.3.1.13.1.9) |
read-create |
Unsigned32 |
Accumulative threshold limit. If the threshold type is not set to accumulate, this object is meaningless. |
If hh3cNqaReactCheckedElement uses value jittersd or jitterds and the operation type is set to ICMP-jitter or UDP-jitter, the value range of this object is 1 to 14999. If hh3cNqaReactCheckedElement uses value jittersd or jitterds and the operation type is set to voice, the value range of this object is 1 to 59999. If hh3cNqaReactCheckedElement uses value jitterpacketloss or jitterrtt and the operation type is set to ICMP-jitter or UDP-jitter, the value range of this object is 1 to 15000. If hh3cNqaReactCheckedElement uses value jitterpacketloss or jitterrtt and the operation type is set to voice, the value range of this object is 1 to 60000. If hh3cNqaReactCheckedElement uses value probetime or probefailure, the value range of this object is 1 to 15. In other cases, the value of this object should not be set. |
hh3cNqaReactActionType (1.3.6.1.4.1.25506.8.3.1.13.1.10) |
read-create |
INTEGER |
none(0), trapOnly(1), triggerOnly(2), trapAndTrigger(3) |
Sets the action for the threshold violation event. By default, no action is specified for the threshold violation event. |
The supported action type depends on the monitored performance metric. |
hh3cNqaReactCurrentStatus (1.3.6.1.4.1.25506.8.3.1.13.1.11) |
read-only |
INTEGER |
invalid(1),overThreshold(2),belowThreshold(3),overUpperThreshold(4),belowLowerThreshold(5) |
Obtain the alarm status for the threshold violation event. |
As per the MIB. |
hh3cNqaReactRowStatus (1.3.6.1.4.1.25506.8.3.1.13.1.12) |
read-create |
RowStatus |
An indication of the creation and deletion of reaction entries. |
As per the MIB. |
hh3cNqaReactCheckedNum (1.3.6.1.4.1.25506.8.3.1.13.1.13) |
read-only |
Unsigned32 |
Number of targets that have been monitored for data collection. |
As per the MIB. |
hh3cNqaReactThresholdNum (1.3.6.1.4.1.25506.8.3.1.13.1.14) |
read-only |
Unsigned32 |
Number of threshold violations. |
As per the MIB. |
About this table
This table records the number of monitored targets and number of threshold violations in a certain time period.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are h3cNqaStatReactOwnerIndex, h3cNqaStatReactTestName, h3cNqaStatReactIndex, and h3cNqaStatReactItemIndex.
Access |
Syntax |
Value range |
Implementation |
hh3cNqaStatReactOwnerIndex (1.3.6.1.4.1.25506.8.3.1.14.1.1) |
not-accessible |
SnmpAdminString |
As per the MIB. |
hh3cNqaStatReactTestName (1.3.6.1.4.1.25506.8.3.1.14.1.2) |
not-accessible |
SnmpAdminString |
Operation tag. |
As per the MIB. |
hh3cNqaStatReactIndex (1.3.6.1.4.1.25506.8.3.1.14.1.3) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cNqaStatReactItemIndex (1.3.6.1.4.1.25506.8.3.1.14.1.4) |
not-accessible |
Unsigned32 |
Number of monitored h3cNqaReactCheckedElement in a time period. |
As per the MIB. |
hh3cNqaStatReactCheckedNum (1.3.6.1.4.1.25506.8.3.1.14.1.5) |
read-only |
Counter32 |
As per the MIB. |
hh3cNqaStatReactThresholdNum (1.3.6.1.4.1.25506.8.3.1.14.1.6) |
read-only |
Counter32 |
Number of monitored threshold violations in a time period. |
As per the MIB. |
Notifications
hh3cNqaProbeTimeOverThreshold
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.8.3.3.1 |
Threshold violation of the probe duration. |
Informational |
Warning |
N/A |
OFF |
Notification triggers
For average or consecutive threshold type, this notification is generated if the threshold status changed when a operation was completed.
For accumulative threshold type, this notification is generated if the threshold status changed when a probe was completed.
System impact
No negative impact on services.
Status control
ON
CLI: Use the reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.3.1.13.1.1 (hh3cNqaReactOwnerIndex) |
Administrator name of an operation. |
hh3cNqaReactOwnerIndex hh3cNqaReactTestName hh3cNqaReactItemIndex |
SnmpAdminString |
1.3.6.1.4.1.25506.8.3.1.13.1.2 (hh3cNqaReactTestName) |
Operation tag of the operation. |
SnmpAdminString |
1.3.6.1.4.1.25506.8.3.1.13.1.3 (hh3cNqaReactItemIndex) |
Reaction entry number. |
Unsigned32 |
1.3.6.1.2.1.80.1.2.1.3 (pingCtlTargetAddressType) |
Type of destination address. |
pingCtlOwnerIndex pingCtlTestName |
InetAddressType |
1.3.6.1.2.1.80.1.2.1.4 (pingCtlTargetAddress) |
Destination address. |
InetAddress |
1.3.6.1.2.1.80.1.2.1.16 (pingCtlType) |
Operation type. |
OBJECT IDENTIFIER |
1.3.6.1.2.1.80.1.2.1.17 (pingCtlDescr) |
Description of the operation. |
SnmpAdminString |
OCTET STRING(0..255) |
1.3.6.1.4.1.25506.8.3.1.13.1.7 (hh3cNqaReactThresholdType) |
Threshold type. |
INTEGER |
1.3.6.1.4.1.25506.8.3.1.13.1.11 (hh3cNqaReactCurrentStatus) |
Alarm status. |
INTEGER |
invalid(1), overThreshold(2), belowThreshold(3), overUpperThreshold(4), belowLowerThreshold(5) |
Recommended action
To resolve the issue:
1. Execute the display this command in NQA operation view to identify whether the destination address configuration is correct.
¡ If the parameters are correctly configured, proceed to step 2.
¡ If the parameter configuration is incorrect, execute the destination ip command in NQA operation view to change the destination address. Restart the operation, and check whether the notification is still generated.
- If the notification is no longer generated, the issue is resolved.
- If the notification is still generated, proceed to step 2.
2. Execute the ping command in NQA operation view to identify whether the route is reachable.
¡ If the route is reachable, proceed to step 3.
¡ If the route is unreachable, locate the cause for the reachability issue first. For example, you can execute the display ip routing-table command to display the routing table information and troubleshoot the route issue.
3. Execute the probe timeout command in NQA operation view to edit the timeout timer based on the network condition. Restart the operation, and check whether the notification is still generated.
¡ If the notification is no longer generated, the issue is resolved.
¡ If the notification is still generated, proceed to step 4.
4. Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element probe-duration command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
5. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaJitterRTTOverThreshold
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.3.3.2 |
Threshold violation of the probe round-trip time. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when the round-trip time of test packets in a UDP-jitter or voice operation exceeds the specified threshold.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object) |
Index nodes |
Type |
Value range |
SnmpAdminString |
SnmpAdminString |
Unsigned32 |
InetAddressType |
InetAddress |
Operation type. |
OBJECT IDENTIFIER |
SnmpAdminString |
Threshold type. |
INTEGER |
Alarm status. |
INTEGER |
Recommended action
1. Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element rtt command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
2. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaProbeFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.3.3.3 |
Threshold violation of the probe failure. |
Informational |
Warning |
N/A |
OFF |
For consecutive threshold type, this notification is generated if the threshold status changed when an operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } action-type none command or the undo reaction item-number command.
Objects
OID (object) |
Index nodes |
Type |
Value range |
SnmpAdminString |
SnmpAdminString |
Unsigned32 |
InetAddressType |
InetAddress |
Operation type. |
OBJECT IDENTIFIER |
SnmpAdminString |
Threshold type. |
INTEGER |
Alarm status. |
INTEGER |
Recommended action
4. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaJitterPacketLoss
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.3.3.4 |
Threshold violation of the packet loss ratio. |
Informational |
Warning |
N/A |
OFF |
This notification is generated if the threshold status changed when a UDP jitter or voice operation for monitoring threshold violation of the packet loss ratio was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences action-type none command or the undo reaction item-number command.
Objects
OID (object) |
Index nodes |
Type |
Value range |
SnmpAdminString |
SnmpAdminString |
Unsigned32 |
InetAddressType |
InetAddress |
Operation type. |
OBJECT IDENTIFIER |
SnmpAdminString |
Threshold type. |
INTEGER |
Alarm status. |
INTEGER |
Recommended action
1. Find out the cause of packet loss on the link.
2. If the issue persists, contact H3C Support.
hh3cNqaJitterSDOverThreshold
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.3.3.5 |
Threshold violation of the one-way jitter from source to destination. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when the threshold violation of the one-way jitter from source to destination for UDP jitter and voice operations occurs. The object supports only accumulate and average threshold types. This notification is generated if the threshold status changed when a UDP jitter or voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element jitter-sd threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element jitter-sd threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
SnmpAdminString |
SnmpAdminString |
Unsigned32 |
1.3.6.1.2.1.80.1.2.1.3 (PingCtlTargetAddressType) |
InetAddressType |
1.3.6.1.2.1.80.1.2.1.4 (PingCtlTargetAddress) |
InetAddress |
1.3.6.1.2.1.80.1.2.1.16 (PingCtlType) |
Operation type. |
OBJECT IDENTIFIER |
1.3.6.1.2.1.80.1.2.1.17 (PingCtlDescr) |
SnmpAdminString |
Threshold type. |
INTEGER |
Alarm status. |
INTEGER |
Recommended action
1. Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element { jitter-ds | jitter-sd } command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
hh3cNqaJitterDSOverThreshold
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.3.3.6 |
Threshold violation of the one-way jitter from destination to source. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when the threshold violation of the one-way jitter from destination to source for UDP jitter and voice operations occurs. The object supports only accumulate and average threshold types. This notification is generated if the threshold status changed when a UDP jitter or voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element jitter-ds threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element jitter-ds threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
SnmpAdminString |
SnmpAdminString |
Unsigned32 |
InetAddressType |
InetAddress |
Operation type. |
OBJECT IDENTIFIER |
SnmpAdminString |
Threshold type. |
INTEGER |
Alarm status. |
INTEGER |
Recommended action
hh3cNqaICPIFOverThreshold
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.3.3.7 |
Threshold violation of the ICPIF value. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when the ICPIF value of a voice operation exceeds the threshold. This notification is generated if the threshold status changed when a voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
SnmpAdminString |
SnmpAdminString |
Unsigned32 |
InetAddressType |
InetAddress |
Operation type. |
OBJECT IDENTIFIER |
SnmpAdminString |
Alarm status. |
INTEGER |
invalid(1), overThreshold(2),, belowThreshold(3), overUpperThreshold(4), belowLowerThreshold(5) |
Recommended action
1. Find out the cause of the ICPIF value changes on the probe link.
hh3cNqaMOSOverThreshold
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.3.3.8 |
Threshold violation of the MOS value. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when the MOS value of a voice operation exceeds the threshold. This notification is generated if the threshold status changed when a voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element mos threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element mos threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
SnmpAdminString |
SnmpAdminString |
Unsigned32 |
InetAddressType |
InetAddress |
Operation type. |
OBJECT IDENTIFIER |
SnmpAdminString |
Alarm status. |
INTEGER |
Recommended action
1. Find out the cause of the MOS value changes on the probe link.
