17-Security
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10017-Security
03-HH3C-SSH-MIB
03-HH3C-SSH-MIB 104.09 KB
HH3C-SSH-MIB
About this MIB
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH can implement secure remote access and file transfer over an insecure network.
SSH uses the typical client-server model to establish a channel for secure data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
Use this MIB to configure the SSH service.
MIB file name
hh3c-ssh.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSSH(22)
Scalar objects
hh3cSSHServerVersion (1.3.6.1.4.1.25506.2.22.1.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
Standard MIB values.
The SSH protocol version of the SSH server.
The default value is 2.00. It is not compatible with SSH 1.x versions.
hh3cSSHServerCompatibleSSH1x (1.3.6.1.4.1.25506.2.22.1.1.1.2)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enableCompatibleSSH1x(1),
disableCompatibleSSH1x(2)
Compatibility with SSH  1.x versions.
The default value is disableCompatibleSSH1x(2).
hh3cSSHServerRekeyInterval (1.3.6.1.4.1.25506.2.22.1.1.1.3)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Time interval at which the SSH server key is regenerated.
Value range: 0 to 24.
The default value is 0, meaning that the key will not be refreshed.
hh3cSSHServerAuthRetries (1.3.6.1.4.1.25506.2.22.1.1.1.4)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Maximum number of SSH server authentication retries.
Range from 1 to 5.
The default value is 3.
hh3cSSHServerAuthTimeout (1.3.6.1.4.1.25506.2.22.1.1.1.5)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
SSH server authentication timeout time.
Range from 1 to 120.
The default value is 60.
hh3cSFTPServerIdleTimeout (1.3.6.1.4.1.25506.2.22.1.1.1.6)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
SFTP connection idle timeout time.
Range from 1 to 35791.
The default value is 10.
hh3cSSHServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.7)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enableSSHServer(1),
disableSSHServer(2)
Enable or disable the SSH server.
The default value is disableSSHServer(2).
hh3cSFTPServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.8)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enableSFTPService(1),
disableSFTPService(2)
Enable or disable the SFTP server.
The default value is disableSFTPService(2).
hh3cSTelnetServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.9)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enableSTelnetService(1),
disableSTelnetService(2)
Enable or disable Stelnet server.
As per the MIB.
hh3cSCPServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.10)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enableSCPServer(1),
disableSCPServer(2)
Enable or disable SCP server.
As per the MIB.
hh3cSSHAttemptUserName (1.3.6.1.4.1.25506.2.22.1.2.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
DisplayString
Name of the user who failed to connect to the server.
Length: 1 to 255 characters.
hh3cSSHAttemptIpAddrType (1.3.6.1.4.1.25506.2.22.1.2.2)
Object (OID)
Access
Value range
Implementation
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the user who failed to connect to the server.
As per the MIB.
hh3cSSHAttemptIpAddr (1.3.6.1.4.1.25506.2.22.1.2.3)
Object (OID)
Access
Value range
Implementation
InetAddress
OCTET STRING (0..255)
Address of user who failed to connect to the server.
As per the MIB.
hh3cSSHUserAuthFailureReason (1.3.6.1.4.1.25506.2.22.1.2.4)
Object (OID)
Access
Value range
Implementation
INTEGER
exceedRetries(1),
authTimeout(2),
otherReason(3)
Reason for the connection failure.
As per the MIB.
Tabular objects
hh3cSSHUserConfigTable
About this table
Use this table to configure or obtain SSH user information.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cSSHUserName.
Object (OID)
Access
Value range
Implementation
hh3cSSHUserName (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.1)
not-accessible
DisplayString
Name of an SSH user.
hh3cSSHUserServiceType (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.2)
read-create
INTEGER
invalid(1),
all(2),
stelnet(3),
sftp(4),
scp(5),
netconf(6)
Service type of the SSH user.
The default value is invalid(1).
hh3cSSHUserAuthType (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.3)
read-create
INTEGER
invalid(1),
password(2),
publicKey(3),
any(4),
publicKeyPassword(5),
keyboardInteractive(6)
Authentication type for the SSH user.
If the value is password, the user must pass password authentication of AAA.
If the value is publicKey, the user must pass the public key authentication of PKEY module.
If the value is any, the user must pass password or public key authentication.
If the value is publicKeyPassword, the user must pass both public key authentication and password authentication.
hh3cSSHUserPublicKeyName (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.4)
read-create
DisplayString
Name of the public key used for authentication of the SSH user.
Length: 1 to 64 characters.
The default value is a zero-length string.
The value for this object is obtained from the public key generated in the PKEY module.
hh3cSSHUserRowStatus (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
When the hh3cSSHUserRowStatus is set to active(1), no objects in the conceptual row can be modified.
In particular, a newly created user row which uses public key authentication cannot be made active(1) until the corresponding instance of `hh3cSSHUserAuthType' is 'publicKey' or 'publicKeyPassword', and the 'hh3cSSHUserPublicKeyName' or at least one of the 'hh3cSSHUserPublicKeyName[2-6]' is configured appropriately.
hh3cSSHSessionInfoTable
About this table
This table contains SSH session information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSSHSessionID.
Object (OID)
Access
Value range
Implementation
hh3cSSHSessionID (1.3.6.1.4.1.25506.2.22.1.1.3.1.1)
not-accessible
Integer32
VTY number of an SSH session.
As per the MIB.
hh3cSSHSessionUserName (1.3.6.1.4.1.25506.2.22.1.1.3.1.2)
read-only
DisplayString
User name of the SSH session.
hh3cSSHSessionUserIpAddrType (1.3.6.1.4.1.25506.2.22.1.1.3.1.3)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
User IP address type of the SSH session.
As per the MIB.
hh3cSSHSessionUserIpAddr (1.3.6.1.4.1.25506.2.22.1.1.3.1.4)
read-only
InetAddress
User IP address of the SSH session.
As per the MIB.
hh3cSSHSessionClientVersion (1.3.6.1.4.1.25506.2.22.1.1.3.1.5)
read-only
DisplayString
Client protocol version of the SSH session.
As per the MIB.
hh3cSSHSessionServiceType (1.3.6.1.4.1.25506.2.22.1.1.3.1.6)
read-only
INTEGER
invalid(1),
stelnet(2),
sftp(3),
scp(4),
netconf(5)
Service type of the SSH session.
As per the MIB.
hh3cSSHSessionEncry (1.3.6.1.4.1.25506.2.22.1.1.3.1.7)
read-only
INTEGER
invalid(1),
aes128CBC(2),
desCBC(3),
des3CBC(4),
aes128CTR(5),
aes192CTR(6),
aes256CTR(7),
aes128GCM(8),
aes256GCM(9),
aes256CBC(10),
other(11)
Encryption algorithm of the SSH session.
As per the MIB.
hh3cSSHSessionState (1.3.6.1.4.1.25506.2.22.1.1.3.1.8)
read-only
INTEGER
init(1),
verExchange(2),
keysExchange(3),
authRequest(4),
serviceRequest(5),
established(6),
disconnect(7)
Status of the SSH session.
As per the MIB.
