03-HH3C-USER-MIB | 125.43 KB |
hh3cUserMaxNum (1.3.6.1.4.1.25506.2.12.1.3)
hh3cUserCurrNum (1.3.6.1.4.1.25506.2.12.1.4)
HH3C-USER-MIB
About this MIB
Use this MIB to manage local users.
MIB file name
hh3c-user.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUser(12)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserMaxNum (1.3.6.1.4.1.25506.2.12.1.3) |
read-only |
Integer32 |
Standard MIB values. |
Maximum number of local users can be created. |
Implementation varies by product. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserCurrNum (1.3.6.1.4.1.25506.2.12.1.4) |
read-only |
Integer32 |
Number of existing local users. |
As per the MIB. |
hh3cUserIndexIndicator (1.3.6.1.4.1.25506.2.12.1.5)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserIndexIndicator (1.3.6.1.4.1.25506.2.12.1.5) |
read-only |
Integer32 |
Index to be used for the next local user. |
As per the MIB. |
Tabular objects
hh3cUserInfoTable
About this table
Use this table to configure or obtain basic information of a local user.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
You must specify hh3cUserPassword and hh3cAuthMode in pairs in an SNMP request.
Columns
The table index is hh3cUserIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserName (1.3.6.1.4.1.25506.2.12.1.1.1.1) |
read-create |
DisplayString |
OCTET STRING (1..255) |
Name of a local user. |
Supported. The username is a case-sensitive string of up to 55 characters. It cannot be empty or be a, al, or all, and cannot contain the following special characters: backslashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), at signs (@). The username of each local user is unique. You cannot edit an existing username. |
hh3cUserPassword (1.3.6.1.4.1.25506.2.12.1.1.1.2) |
read-create |
DisplayString |
OCTET STRING (0..255) |
Password of the local user. |
When read, this object returns a zero-length string. |
hh3cAuthMode (1.3.6.1.4.1.25506.2.12.1.1.1.3) |
read-create |
Integer32 |
Encrypting type of the user password. |
Value range: 0 or 7. |
hh3cUserState (1.3.6.1.4.1.25506.2.12.1.1.1.5) |
read-create |
INTEGER |
active(0), block(1) |
Status of the local user. |
As per the MIB. |
hh3cUserInfoRowStatus (1.3.6.1.4.1.25506.2.12.1.1.1.6) |
read-create |
RowStatus |
active(1), createAndGo(4), destroy(6) |
Row status. |
As per the MIB. |
hh3cUserIndex (1.3.6.1.4.1.25506.2.12.1.1.1.7) |
not-accessible |
Integer32 |
Integer32 (1..2147483646) |
Index of the local user. |
Value range: 1 to 1024. |
hh3cUserAttributeTable
About this table
This table contains attributes of a local user.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAccessLimit (1.3.6.1.4.1.25506.2.12.1.2.1.1) |
read-write |
Integer32 |
Maximum number of concurrent users that can use a username to access the device. |
Default: No limit is placed on the maximum number of concurrent users that can use a username to access the device. Value range: 0 to 1024. |
hh3cIdleCut (1.3.6.1.4.1.25506.2.12.1.2.1.2) |
read-write |
Integer32 |
Idle timeout period, in seconds. |
This object will round the specified value to the nearest multiple of 60. |
hh3cIPAddress (1.3.6.1.4.1.25506.2.12.1.2.1.3) |
read-write |
IpAddress |
IP address of a user. |
Default: 0.0.0.0. |
hh3cMacAddress (1.3.6.1.4.1.25506.2.12.1.2.1.8) |
read-write |
MacAddress |
OCTET STRING (6) |
MAC address of the user. |
As per the MIB. |
hh3cVlan (1.3.6.1.4.1.25506.2.12.1.2.1.9) |
read-write |
Integer32 |
Integer32 (0..4094) |
ID of the VLAN to which the user belongs. |
As per the MIB. |
hh3cLanAccessService (1.3.6.1.4.1.25506.2.12.1.2.1.12) |
read-write |
ServiceType |
enable(1), disable(2) |
LAN access service. |
As per the MIB. |
hh3cUserGroup (1.3.6.1.4.1.25506.2.12.1.2.1.17) |
read-write |
DisplayString |
User group of the user. |
A user group name cannot exceed 32 characters. |
hh3cPortalService (1.3.6.1.4.1.25506.2.12.1.2.1.18) |
read-write |
ServiceType |
Portal service. |
As per the MIB. |
hh3cPPPService (1.3.6.1.4.1.25506.2.12.1.2.1.19) |
read-write |
ServiceType |
PPP service. |
As per the MIB. |
hh3cUserIfIndex (1.3.6.1.4.1.25506.2.12.1.2.1.22) |
read-write |
Integer32 |
Index of the user's access interface. |
As per the MIB. |
hh3cUserRoleTable
About this table
Use this table to configure or obtain basis information of a local user.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cUserIndex and hh3cUserRole.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserRole (1.3.6.1.4.1.25506.2.12.1.6.1.1) |
not-accessible |
DisplayString |
OCTET STRING (1..63)) |
User role. |
In MDCs, the default user role is mdc-operator. In non-MDCs, the default user role is network-operator. |
hh3cUserRoleStatus (1.3.6.1.4.1.25506.2.12.1.6.1.2) |
read-create |
RowStatus |
Row status. |
You must specify hh3cUserIndex when you create a local user. |
hh3cUserGroupInfoTable
About this table
Use this table to configure or obtain basic information of a user group.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cUserGroupName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserGroupName (1.3.6.1.4.1.25506.2.12.2.1.1.1) |
not-accessible |
DisplayString |
Name of a user group. |
As per the MIB. |
hh3cUserGroupInfoRowStatus (1.3.6.1.4.1.25506.2.12.2.1.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
