12-MPLS
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10012-MPLS
09-MPLS-L3VPN-STD-MIB
09-MPLS-L3VPN-STD-MIB 223.60 KB
MPLS-L3VPN-STD-MIB
About this MIB
Use this MIB to obtain MPLS VPN information.
MIB file name
rfc4382-mpls-l3vpn-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsL3VpnMIB(11)
Scalar objects
mplsL3VpnConfiguredVrfs (1.3.6.1.2.1.10.166.11.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Standard MIB values.
Number of configured VRFs.
As per the MIB.
mplsL3VpnActiveVrfs (1.3.6.1.2.1.10.166.11.1.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
INTEGER(0..4294967295)
Number of VRFs in up state.
As per the MIB.
mplsL3VpnConnectedInterfaces (1.3.6.1.2.1.10.166.11.1.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
Number of interfaces bound to the VRF.
As per the MIB.
mplsL3VpnNotificationEnable (1.3.6.1.2.1.10.166.11.1.1.4)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether MPLS L3VPN notification is enabled.
As per the MIB.
mplsL3VpnVrfConfMaxPossRts (1.3.6.1.2.1.10.166.11.1.1.5)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Maximum number of routes that all VRFs on the device can have.
As per the MIB.
This object is not supported.
The return value is always 0.
mplsL3VpnVrfConfRteMxThrshTime (1.3.6.1.2.1.10.166.11.1.1.6)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Interval at which the route max threshold notification is regenerated after the maximum route number is exceeded (or reached if mplsL3VpnVrfConfMaxRoutes and mplsL3VpnVrfConfHighRteThresh are equivalent) and the initial notification is sent. If this value is set to 0, the agent generates only one notification when maximum route number is reached.
As per the MIB.
mplsL3VpnIllLblRcvThrsh (1.3.6.1.2.1.10.166.11.1.1.7)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Number of received incorrect labels.
Supports only the read operation.
The return value is always 32.
Tabular objects
mplsL3VpnIfConfTable
About this table
This table specifies MPLS capability and associated VPNs for an interface.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are mplsL3VpnVrfName and mplsL3VpnIfConfIndex.
Object (OID)
Access
Value range
Implementation
mplsL3VpnIfConfIndex(1.3.6.1.2.1.10.166.11.1.2.1.1.1)
not-accessible
InterfaceIndex
Integer32(1..2147483647)
Interface index.
As per the MIB.
mplsL3VpnIfVpnClassification(1.3.6.1.2.1.10.166.11.1.2.1.1.2)
read-create
INTEGER
carrierOfCarrier (1),
enterprise (2),
interProvider (3)
Interface category.
mplsL3VpnIfVpnRouteDistProtocol (1.3.6.1.2.1.10.166.11.1.2.1.1.3)
read-create
BITS
none (0),
bgp (1),
ospf (2),
rip(3),
isis(4),
static(5),
other (6)
Route distribution protocol.
mplsL3VpnIfConfStorageType (1.3.6.1.2.1.10.166.11.1.2.1.1.4)
read-create
StorageType
INTEGER {
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type of the interface.
mplsL3VpnIfConfRowStatus (1.3.6.1.2.1.10.166.11.1.2.1.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
mplsL3VpnVrfTable
About this table
This table contains VRF configuration information.
Create
Edit/Modify
Delete
Read
 Supported
Supported
Supported
Supported
Columns
The table index is mplsL3VpnVrfName.
Object (OID)
Access
Value range
Implementation
mplsL3VpnVrfName (1.3.6.1.2.1.10.166.11.1.2.2.1.1)
not-accessible
MplsL3VpnName
OCTET STRING (0..31)
VRF name.
As per the MIB.
mplsL3VpnVrfVpnId (1.3.6.1.2.1.10.166.11.1.2.2.1.2)
read-create
VPNIdOrZero
OCTET STRING (0 | 7)
VPN ID.
As per the MIB.
mplsL3VpnVrfDescription (1.3.6.1.2.1.10.166.11.1.2.2.1.3)
read-create
SnmpAdminString
OCTET STRING (0..255)
VRF description.
As per the MIB.
mplsL3VpnVrfRD (1.3.6.1.2.1.10.166.11.1.2.2.1.4)
read-create
MplsL3VpnRouteDistinguisher
OCTET STRING(0..256)
Configured RD.
By default, a get operation obtains the global RD. If no global RD is configured, it obtains the RD for the IPv4 unicast address family. If the IPv4 unicast address family RD is not configured either, "0:0" is displayed.
As per the MIB.
mplsL3VpnVrfCreationTime (1.3.6.1.2.1.10.166.11.1.2.2.1.5)
read-only
TimeStamp
TimeTicks
Time when the VRF entry was created.
As per the MIB.
mplsL3VpnVrfOperStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.6)
read-only
INTEGER
up (1),
down (2)
Up/down state.
As per the MIB.
mplsL3VpnVrfActiveInterfaces (1.3.6.1.2.1.10.166.11.1.2.2.1.7)
read-only
Gauge32
Number of associated interfaces in up state.
As per the MIB.
mplsL3VpnVrfAssociatedInterfaces (1.3.6.1.2.1.10.166.11.1.2.2.1.8)
read-only
Unsigned32
Number of associated interfaces.
As per the MIB.
mplsL3VpnVrfConfMidRteThresh (1.3.6.1.2.1.10.166.11.1.2.2.1.9)
read-create
Unsigned32
The value for mplsL3VpnVrfConfMidRteThresh depends on the route limit set by using the routing-table limit command.
If the route limit is not configured, the value for mplsL3VpnVrfConfMidRteThresh is the system-defined route limit value.
If the route limit is configured as X and the action is configured as simply-alert, the value for mplsL3VpnVrfConfMidRteThresh is the configured route limit value X.
If the route limit is configured as X and a warning threshold is set to Y%, the value for mplsL3VpnVrfConfMidRteThresh is X*Y%.
The value for mplsL3VpnVrfConfMidRteThresh is the sum of the route limits for both IPv4 and IPv6 routes, calculated using the previous rules.
mplsL3VpnVrfConfHighRteThresh (1.3.6.1.2.1.10.166.11.1.2.2.1.10)
read-create
Unsigned32
The value for mplsL3VpnVrfConfHighRteThresh depends on the route limit set by using the routing-table limit command.
If the route limit is not configured or is configured with the simply-alert action, the value for mplsL3VpnVrfConfHighRteThresh is the system-defined route limit value.
If the route limit is configured as X and a warning threshold is set to Y%, the value for mplsL3VpnVrfConfHighRteThresh is X.
mplsL3VpnVrfConfMaxRoutes (1.3.6.1.2.1.10.166.11.1.2.2.1.11)
read-create
Unsigned32
Maximum number of routes that this VRF can hold.
mplsL3VpnVrfConfLastChanged (1.3.6.1.2.1.10.166.11.1.2.2.1.12)
read-only
TimeStamp
TimeTicks
Time when the entry changed most recently.
As per the MIB.
mplsL3VpnVrfConfRowStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.13)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
mplsL3VpnVrfConfAdminStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.14)
read-create
INTEGER
up(1),
down(2),
testing(3)
Administrative state of the VRF.
mplsL3VpnVrfConfStorageType (1.3.6.1.2.1.10.166.11.1.2.2.1.15)
read-create
StorageType
INTEGER {
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type of the VRF.
mplsL3VpnVrfRTTable
About this table
This table contains VPN RT information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mplsL3VpnVrfName, mplsL3VpnVrfRTIndex, and mplsL3VpnVrfRTType.
Object (OID)
Access
Value range
Implementation
mplsL3VpnVrfRTIndex (1.3.6.1.2.1.10.166.11.1.2.3.1.2)
not-accessible
Unsigned32
Unsigned32(1..4294967295)
RT index.
As per the MIB.
mplsL3VpnVrfRTType (1.3.6.1.2.1.10.166.11.1.2.3.1.3)
not-accessible
MplsL3VpnRtType
import (1), export (2),
or both (3).
Incoming and outgoing policies.
As per the MIB.
mplsL3VpnVrfRT (1.3.6.1.2.1.10.166.11.1.2.3.1.4)
read-create
RT character string.
mplsL3VpnVrfRTDescr (1.3.6.1.2.1.10.166.11.1.2.3.1.5)
read-create
SnmpAdminString
RT description.
mplsL3VpnVrfRTRowStatus (1.3.6.1.2.1.10.166.11.1.2.3.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
mplsL3VpnVrfRTStorageType (1.3.6.1.2.1.10.166.11.1.2.3.1.7)
read-create
StorageType
INTEGER {
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
RT storage type.
mplsL3VpnVrfSecTable
About this table
This table contains MPLS VRF security statistics information about interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
mplsL3VpnVrfSecIllegalLblVltns (1.3.6.1.2.1.10.166.11.1.2.6.1.1)
read-only
Counter32
Number of invalid labels that are received.
As per the MIB.
mplsL3VpnVrfSecDiscontinuityTime (1.3.6.1.2.1.10.166.11.1.2.6.1.2)
read-only
TimeStamp
TimeTicks
Interruption time.
As per the MIB.
mplsL3VpnVrfPerfTable
About this table
This table contains MPLS L3VPN VRF table performance information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
mplsL3VpnVrfPerfRoutesAdded (1.3.6.1.2.1.10.166.11.1.3.1.1.1)
read-only
Counter32
Total number of added IPv4 and IPv6 routes.
As per the MIB.
mplsL3VpnVrfPerfRoutesDeleted (1.3.6.1.2.1.10.166.11.1.3.1.1.2)
read-only
Counter32
Total number of deleted IPv4 and IPv6 routes.
As per the MIB.
mplsL3VpnVrfPerfCurrNumRoutes (1.3.6.1.2.1.10.166.11.1.3.1.1.3)
read-only
Gauge32
Total number of active IPv4 and IPv6 routes.
As per the MIB.
mplsL3VpnVrfPerfRoutesDropped (1.3.6.1.2.1.10.166.11.1.3.1.1.4)
read-only
Counter32
Number of discarded routes.
As per the MIB.
mplsL3VpnVrfPerfDiscTime (1.3.6.1.2.1.10.166.11.1.3.1.1.5)
read-only
TimeStamp
TimeTicks
Interruption time. The value of this object is always 0.
As per the MIB.
mplsL3VpnVrfRteTable
About this table
This table contains information about routes configured for a VRF.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mplsL3VpnVrfName, mplsL3VpnVrfRteInetCidrDestType, mplsL3VpnVrfRteInetCidrDest, mplsL3VpnVrfRteInetCidrPfxLen, mplsL3VpnVrfRteInetCidrPolicy, mplsL3VpnVrfRteInetCidrNHopType, and mplsL3VpnVrfRteInetCidrNextHop.
Object (OID)
Access
Value range
Implementation
mplsL3VpnVrfRteInetCidrDestType (1.3.6.1.2.1.10.166.11.1.4.1.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Destination address type.
As per the MIB.
mplsL3VpnVrfRteInetCidrDest (1.3.6.1.2.1.10.166.11.1.4.1.1.2)
not-accessible
InetAddress
Destination IP address.
As per the MIB.
mplsL3VpnVrfRteInetCidrPfxLen (1.3.6.1.2.1.10.166.11.1.4.1.1.3)
not-accessible
InetAddressPrefixLength
Unsigned32(0..128)
Prefix length of the destination address.
As per the MIB.
mplsL3VpnVrfRteInetCidrPolicy (1.3.6.1.2.1.10.166.11.1.4.1.1.4)
not-accessible
OBJECT IDENTIFIER
Additional index that delineates between multiple entries to the same destination.
As per the MIB.
mplsL3VpnVrfRteInetCidrNHopType (1.3.6.1.2.1.10.166.11.1.4.1.1.5)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Next hop type.
As per the MIB.
mplsL3VpnVrfRteInetCidrNextHop (1.3.6.1.2.1.10.166.11.1.4.1.1.6)
not-accessible
InetAddress
Next hop.
As per the MIB.
mplsL3VpnVrfRteInetCidrIfIndex (1.3.6.1.2.1.10.166.11.1.4.1.1.7)
read-create
InterfaceIndexOrZero
Integer32(0..2147483647)
Egress interface index.
mplsL3VpnVrfRteInetCidrType (1.3.6.1.2.1.10.166.11.1.4.1.1.8)
read-create
INTEGER
other(1),
reject(2),
local(3),
remote (4),
blackhole(5)
Route type.
mplsL3VpnVrfRteInetCidrProto (1.3.6.1.2.1.10.166.11.1.4.1.1.9)
read-only
IANAipRouteProtocol
Routing protocol.
As per the MIB.
mplsL3VpnVrfRteInetCidrAge(1.3.6.1.2.1.10.166.11.1.4.1.1.10)
read-only
Gauge32
Route update time.
As per the MIB.
mplsL3VpnVrfRteInetCidrNextHopAS (1.3.6.1.2.1.10.166.11.1.4.1.1.11)
read-create
InetAutonomousSystemNumber
AS number of the next hop.
mplsL3VpnVrfRteInetCidrMetric1 (1.3.6.1.2.1.10.166.11.1.4.1.1.12)
read-create
Integer32
Integer32(-1 | 0..2147483647)
Primary route metric.
mplsL3VpnVrfRteInetCidrMetric2 (1.3.6.1.2.1.10.166.11.1.4.1.1.13)
read-create
Integer32
Optional route metric.
Set the value of this object to -1 if this object is not used.
mplsL3VpnVrfRteInetCidrMetric3 (1.3.6.1.2.1.10.166.11.1.4.1.1.14)
read-create
Integer32
mplsL3VpnVrfRteInetCidrMetric4 (1.3.6.1.2.1.10.166.11.1.4.1.1.15)
read-create
Integer32
mplsL3VpnVrfRteInetCidrMetric5 (1.3.6.1.2.1.10.166.11.1.4.1.1.16)
read-create
Integer32
mplsL3VpnVrfRteXCPointer (1.3.6.1.2.1.10.166.11.1.4.1.1.17)
read-create
MplsIndexType
mplsXCTable index.
The return value is always 00.00.00.00.
mplsL3VpnVrfRteInetCidrStatus (1.3.6.1.2.1.10.166.11.1.4.1.1.18)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Notifications
mplsL3VpnVrfUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.11.0.1
An interface associated with a VRF comes up.
Recovery
Informational
N/A
ON
Notification triggers
This notification is generated for a VPN instance (VRF) in the following conditions:
·     When the VPN instance is not bound to any interface, bind the VPN instance with an interface whose state (ifOperStatus) is up.
·     The VPN instance is bound to only one interface, and the bound interface's state (ifOperStatus) changes from down to up.
·     The VPN instance is bound to multiple interfaces. When all the interfaces are in down state (ifOperStatus), one of the interfaces changes from down state to up state.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable l3vpn command.
OFF
CLI: Use the undo snmp-agent trap enable l3vpn command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.10.166.11.1.2.1.1.5 (mplsL3VpnIfConfRowStatus)
Row status used to create, modify, and delete a row in this table.
mplsL3VpnVrfName
INTEGER
active(1)
1.3.6.1.2.1.10.166.11.1.2.2.1.6 (mplsL3VpnVrfOperStatus)
Operational state of the VPN.
mplsL3VpnVrfName
INTEGER
up(1)
down(2)
Recommended action
No action is required.
mplsL3VpnVrfDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.2
An interface associated with a VRF goes down.
Error
Major
1.3.6.1.2.1.10.166.11.0.1 (mplsL3VpnVrfUp)
ON
·     The VPN instance is bound to only one interface and the interface’s state (ifOperStatus) is up. The interface state changes from up to down or the interface is unbound from the VPN instance.
·     The VPN instance is bound to multiple interfaces. The ifOperStatus state of the last bound interface changes from up to down, or the last up interface is unbound from the VPN instance.
System impact
The VPN instance does not have an interface to forward IPv4 traffic.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
mplsL3VpnVrfName
INTEGER
active(1)
mplsL3VpnVrfName
INTEGER
up(1)
down(2)
Recommended action
To resolve this issue, perform the following tasks:
1.     Identify whether the VPN instance is in use. If the VPN instance is not in use, unbinding the VPN instance from interfaces is normal and no action is required. If the VPN instance is in use, execute the display ip vpn-instance instance-name vpn-instance-name command to view the Interfaces field in the output.
¡     If the Interfaces field is not displayed, it indicates that no interface is bound to the VPN instance. In this case, identify the interface for the VPN instance, execute the ip binding vpn-instance command to bind the interface to the VPN instance, and then execute the ip address command to configure an IPv4 address for the interface.
¡     If the value of the Interfaces field is an interface or multiple interfaces, execute the display ip interface command to view interface state.
-     If the interface physical state (current state) is down, troubleshoot the physical link faults.
-     If the interface physical state (current state) is Administratively DOWN, execute the undo shutdown command to bring up the interface.
-     If the interface does not have an IPv4 address, execute the ip address command to assign an IPv4 address to the interface.
2.     If the issue persists, collect log messages, configuration data, and alarm information, and then contact Technical Support.
mplsL3VpnVrfRouteMidThreshExceeded
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.3
The number of routes in a VRF exceeds the value indicated by mplsL3VpnVrfMidRouteThreshold.
Informational
Warning
N/A
ON
This notification is generated when the number of route prefixes in the routing table of the VPN instance exceeds the warning threshold.
System impact
The number of routes in the routing table of the VPN instance has reached the warning threshold. New routes can still be added to the VPN routing table and no route loss or traffic disruption will occur currently.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.10.166.11.1.3.1.1.3 (mplsL3VpnVrfPerfCurrNumRoutes)
mplsL3VpnVrfName
Gauge32
1.3.6.1.2.1.10.166.11.1.2.2.1.9 (mplsL3VpnVrfConfMidRteThresh)
Mid-level water marker for the number of routes that this VRF supports.
mplsL3VpnVrfName
Unsigned32
Recommended action
1.     Execute the display ip routing-table vpn-instance vpn-instance-name summary command to view the values for the Max Active Route, Remain Active Route, and Threshold value percentage fields to identify whether the VPN instance route limit has reached the MidRoute warning threshold.
2.     Execute the display ip routing-table vpn-instance vpn-instance-name statistics command to view the number of routes of each protocol in the VPN instance. Identify whether the route counts satisfy the expected size.
¡     If yes, enter VPN instance view, edit the routing-table limit configuration with a bigger warning threshold value.
¡     If no, check the routing protocol whose route count exceeds the expected size and adjust the configuration to remove the exceeding routes. Then, execute the command in step 1 to identify whether the number of route prefixes has dropped below the warning threshold.
3.     If the issue persists, collect configuration data, log messages, and alarm information, and then contact Technical Support.
mplsL3VpnVrfNumVrfRouteMaxThreshExceeded
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.4
The number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by mplsL3VpnVrfMaxRouteThreshold.
Error
Warning
1.3.6.1.2.1.10.166.11.0.6 (mplsL3VpnNumVrfRouteMaxThreshCleared)
ON
This notification is generated when the number of prefixes in the routing table of a VPN instance exceeds the maximum allowed.
System impact
No new routes can be added to the routing table of the VPN instance, and thus some traffic might be interrupted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
mplsL3VpnVrfName
Gauge32
1.3.6.1.2.1.10.166.11.1.2.2.1.10 (mplsL3VpnVrfConfHighRteThresh)
High-level water marker for the number of routes that the VRF supports.
mplsL3VpnVrfName
Unsigned32
Recommended action
1.     Execute the display ip routing-table vpn-instance vpn-instance-name summary command to view the values for the Max Active Route, Remain Active Route, and Threshold value percentage fields to identify whether the number of route prefixes in the VPN instance has reached the maximum.
¡     If yes, enter VPN instance view, edit the routing-table limit configuration with a bigger maximum value.
Basic information
OID
Event
Severity
Default status
The number of routes in a VRF falls below the value of the mplsVrfMaxRouteThreshold object.
Recovery
Informational
N/A
ON
This notification is generated when the number of route prefixes in the routing table of a VPN instance drops below the maximum value.
System impact
The number of routes in the routing table of the VPN instance has dropped below the maximum value. New routes can be added to the VPN instance’s routing table again.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
mplsL3VpnVrfName
Gauge32
mplsL3VpnVrfName
Unsigned32
Recommended action
