08-Layer 2 - WAN Access
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10008-Layer 2 - WAN Access
Table of Contents
Related Documents
01-PPP-IP-NCP-MIB
01-PPP-IP-NCP-MIB 68.88 KB
PPP-IP-NCP-MIB
About this MIB
Use this MIB to get the PPP IPCP negotiation information and local negotiation configuration.
MIB file name
rfc1473-ppp-ip.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).ppp(23)
Tabular objects
pppIpTable
About this table
This table gets the PPP IPCP negotiation information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
pppIpOperStatus (1.3.6.1.2.1.10.23.3.1.1.1)
read-only
INTEGER
opened(1)
 not-opened(2)
PPP IPCP status.
As per the MIB.
pppIpLocalToRemoteCompressionProtocol (1.3.6.1.2.1.10.23.3.1.1.2)
read-only
INTEGER
none(1)
vj-tcp(2)
Remote compression protocol for PPP IPCP.
This object is not configurable and is fixed at 1.
pppIpRemoteToLocalCompressionProtocol (1.3.6.1.2.1.10.23.3.1.1.3)
read-only
INTEGER
none(1)
vj-tcp(2)
Local compression protocol for PPP IPCP.
pppIpRemoteMaxSlotId (1.3.6.1.2.1.10.23.3.1.1.4)
read-only
Integer32
Integer32 (0..255)
Maximum slot number on the remote end.
This object is not configurable and is fixed at 0.
pppIpLocalMaxSlotId (1.3.6.1.2.1.10.23.3.1.1.5)
read-only
Integer32
Integer32 (0..255)
Maximum slot number on the local end.
pppIpConfigTable
About this table
This table gets the local PPP IPCP negotiation configuration.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
pppIpConfigAdminStatus (1.3.6.1.2.1.10.23.3.2.1.1)
read-only
INTEGER
open(1)
close(2)
PPP IPCP negotiation status.
As per the MIB.
pppIpConfigCompression (1.3.6.1.2.1.10.23.3.2.1.2)
read-only
INTEGER
none(1)
vj-tcp(2)
PPP IPCP compression protocol.
