H3C Wi-Fi7 Indoor Access Points Installation Guide-5W108
HomeSupportInstall & UpgradeInstallation GuidesH3C Wi-Fi7 Indoor Access Points Installation Guide-5W108
05-Appendix C Optional transceiver modules
05-Appendix C Optional transceiver modules 200.03 KB
5 Appendix C  Optional transceiver modules
Common transceiver module
Transceiver module, fiber connector, and fiber view
You must use an SFP transceiver module and optical fiber with an LC connector to connect the fiber port on the AP.
Figure5-1 SFP transceiver module
Figure5-2 Optical fibers with LC connectors
(1) LC connector
(2) Optical fiber
Technical specifications
Table5-1 SFP-XG-CPRI-IR-SM1310 transceiver module specifications
Item
Central wavelength
1310 nm
Max transmission distance
1.4 km (0.87 miles)
Data rate
4920 to 10310 Mbps
Connector type
LC connector
Fiber mode
SMF
Fiber diameter
9/125 μm
Output power
8.2 to +0.5 dBm
Table5-2 SFP-2.5G-LX10-SM1310-DR-I transceiver module specifications
Item
Central wavelength
1310 nm
10 km (6.21 miles)
Data rate
1228.8 to 2457.6 Mbps
Connector type
LC connector
Fiber mode
SMF
Fiber diameter
9/125 μm
Output power
7 to +2 dBm
PoE optical transceiver module
PoE optical transceiver module and fiber PoE patch cord
Insert PoE optical transceiver modules only into the photoelectric hybrid ports (PSFP or PSFP+ ports). To connect the photoelectric hybrid ports, use hybrid copper-fiber cables with fiber PoE patch cords.
Figure5-3 PoE optical transceiver module
Figure5-4 Hybrid copper-fiber cable with fiber PoE patch cord
(1) Fiber PoE patch cord
(2) Hybrid copper-fiber cable
Table5-3 H3C-LS5M1SFPPOE-SFP GE PoE optical transceiver module specifications
Item
H3C-LS5M1SFPPOE-SFP
Central wavelength
1310 nm
10 km (6.21 miles)
Data rate
1.25 Gbps
Connector type
LC connector
Max power consumption
1.0 W
Operating temperature
–40ºC to +85ºC (–40°F to +185°F)
Output power
9 to –1 dBm
Table5-4 H3C-LS5M1SFPPOEA-SFP 10-GE multirate PoE optical transceiver module specifications
Item
H3C--LS5M1SFPPOEA-SFP
Central wavelength
1310 nm
1.4 km (0.87 miles)
Data rate
10.3125 Gbps
Connector type
LC connector
1.2 W
Output power
8.2 to +0.5 dBm
