01-Text | 1.02 MB |
U-Center 2.0 deployment procedure at a glance
Single-stack IP address assignment
Dual-stack IP address assignment
(Optional.) Deploying the IOM component in convergence mode
(Optional.) Deploying the CMDB component in convergence mode
(Optional.) Deploying the BSM component in convergence mode
(Optional.) Deploying the ITSM component in convergence mode
(Optional.) Deploying the NTA component in convergence mode
(Optional.) Deploying the AOM component in convergence mode
(Optional.) Deploying the STM component in convergence mode
(Optional.) Deploying the QuickReport component in convergence mode
(Optional.) Deploying the ODA component in convergence mode
(Optional.) Deploying the APA component in convergence mode
Installing and obtaining licenses
Backing up and restoring the configuration
Rebuilding and recovering the cluster from failures
Upgrading U-Center 2.0 through convergence deployment
Uninstalling U-Center 2.0 through convergence deployment
Uninstalling U-Center 2.0 through application deployment
Shutting down and powering off servers
Shutting down and powering off part of nodes
Shutting down and powering off all nodes
Starting servers and checking the network
Verifying licenses and service functionalities
Overview
With an advanced containerized microservice architecture, U-Center 2.0 provides clustering and high availability capabilities, features easy deployment, and supports large-scale data storage. Based on the architecture, U-Center 2.0 integrates the monitoring, CMDB, automation, IT process management, and service management components to form a unified operations and maintenance (O & M) platform.
In the containerized microservice architecture, the installation and deployment of different components might vary. This document provides streamlined installation and deployment guidelines for correct deployment of U-Center 2.0.
U-Center 2.0 contains CMDB, IOM, BSM, ITSM, NTA, AOM, STM, NSM, ODA, and APA components. It supports standalone deployment on one master node and cluster deployment on three master nodes and N worker nodes (N ≥ 0).
Table 1 shows the U-Center 2.0 deployment workflow.
Table 1 U-Center 2.0 deployment workflow
Step |
Remarks |
Prepare servers. |
· The standalone mode requires one server. · The cluster mode requires a minimum of three servers. |
Required. For hardware and software requirements, see "Server requirements." |
Deploy Unified Platform. |
Install an operating system and dependencies. |
Required. For more information, see H3C Unified Platform Deployment Guide. |
Install Matrix. |
Required if a non-H3Linux 1.0 operating system is used. For more information, see H3C Unified Platform Deployment Guide. |
Configure cluster parameters. |
Create a cluster. |
Deploy Unified Platform installation packages. |
Deploy U-Center 2.0. |
Deploy various components of U-Center 2.0. |
Convergence deployment is supported. For more information, see “Installing U-Center 2.0.” |
Preparing for deployment
IMPORTANT: External DM database does not support IPv6 or dual-stack deployment. |
IMPORTANT: Follow these restrictions and guidelines when deploying, upgrading, or rebuilding a cluster in a scenario where multiple NICs exist: · Before deploying, upgrading, or rebuilding a cluster, make sure all NICs before the NIC whose IP is used as the node IP in the Matrix cluster have IPs assigned or the ONBOOT value set to no. For example, if the node uses the IP of NIC ens191 as the node IP in the Matrix cluster, and ens190 is before ens191 in order, make sure ens190 has an IP assigned. · You must use the ifconfig command to view the NIC order. · Make sure no abnormal NIC configuration file exists in the cluster. For example, the ONBOOT value is yes when the NIC is not connected or not configured with an IP. · If the cluster uses a bonding interface as the node IP in the Matrix cluster, make sure all NICs not the members of the bonding interface have IPs assigned or the ONBOOT value set to no. |
Table 2 shows the single-stack IP address assignment for U-Center 2.0 deployment. Table 3 shows the dual-stack IP address assignment U-Center 2.0 deployment.
The IP addresses can be IPv4 or IPv6 addresses.
IP address |
Remarks |
Master node 1 IP |
IP address assigned to the master node installed with an operating system. |
Required. (Only one master node is required in standalone mode.) IP addresses of master nodes in one cluster must be on the same subnet. |
Master node 2 IP |
Master node 3 IP |
Northbound service VIP |
The unified external access address for all applications deployed through Matrix. |
Required. The northbound service VIP must be on the same subnet as the subnet of the master nodes. |
Worker node IP addresses |
IP address assigned to a worker node. |
Optional. This IP address must be on the same subnet as those of the master nodes. |
IP address |
Remarks |
Master node 1 IP |
IPv4 and IPv6 addresses assigned to the master node installed with an operating system. |
Master node 2 IP |
Master node 3 IP |
Northbound service VIP (IPv4 or IPv6) |
Required. The northbound service VIPs must be on the same subnet as the master nodes, and are assigned IPv4 and IPv6 addresses separately. For the northbound service VIPs, you must specify a minimum of one IPv4 address or IPv6 address. You cannot configure two IP addresses of the same IP version. |
Installation packages
Table 4 describes the U-Center 2.0 installation packages when the H3C Linux operating system is used. If another operating system is used, H3Linux ISO files are not necessarily required. In this table, version indicates the version number and platform represents the CPU architecture type.
A required application package must be installed for U-Center 2.0 to operate normally. An optional application package can be installed if you need the corresponding function.
NOTE: Support for the x86 and ARM installation packages varies by component and version. For more information, see the release notes. |
Name |
Product package |
Remarks |
Dependencies |
common_Linux-version_platform.iso |
H3C Linux OS installation package |
N/A |
Required. |
N/A |
UDTP_Middle_version_platform.zip |
Middleware image repository, including databases and message queues. |
PLAT |
Required. Deployed on Matrix. |
N/A |
UDTP_GlusterFS_version_platform.zip |
Provides local shared storage functionalities: · Provides a universal tool for creating storage volumes. · Automatically repairs GFS anomalies caused by node anomalies and brain splits. |
PLAT |
N/A |
UDTP_Core_version_platform.zip |
Provides portal, unified authentication, user management, service gateway, service data backup & restoration, application deployment management (installation, upgrade, expansion, and uninstallation), help center, permissions, operation groups, roles, role groups, unified resource UUIDs, license query and display, configuration center, and log service. |
PLAT |
Middle, GlusterFS |
BMP_IMonitor_version_platform.zip |
Provides self-monitoring services, including: · Monitors hosts and containers, monitors the indexes of multiple middleware products, including etcd, GlusterFS, and MySQL, and provides a visual interface. · Provides the index alarm function. After you configure the level 1 and level 2 thresholds of the specified index, an alarm will be sent when the level 1 or level 2 threshold is reached. · Displays the list of K8s workloads, allows you to view basic information of the workloads, and supports multiple search options. |
PLAT |
Optional. Deployed on Matrix. The host and container monitoring function provided by the component corresponds to the host and pod monitoring function of Matrix versions earlier than Unified Platform E0713. |
Core |
BMP_Report_version_platform.zip |
Provides the IAR report function, allows other components to register report templates, and adds report tasks: · Report templates · Report tasks |
PLAT |
Optional. Deployed on Matrix. Corresponds to the report function in the general_PLAT_kernel-base_2.0_<version>.zip package for versions earlier than Unified Platform E0713. |
N/A |
BMP_QuickReport_version_platform.zip |
Provides more convenient report customization functions, allows service components to register data sources, and generates charts based on data source configuration. Including: · Data source management · Template management · Task management |
PLAT |
Optional. Deployed on Matrix. Corresponds to Unified Platform E0721 and earlier versions. |
N/A |
U-Center_Report _version_platform.zip |
Provides more comprehensive fast report functions, adding features such as datasets and charts: · Dataset management · Chart management · Custom inquiry · Report templates · Report tasks |
REPORT |
Optional. Deployed on Matrix. Corresponds to Unified Platform E0721 and later versions. |
UDTP_Middle_version_platform.zip UDTP_GlusterFS_version_platform.zip UDTP_Core_version_platform.zip |
BMP_Alarm_version_platform.zip |
Provides basic alarm services, including receiving traps, upgrading to alarms, and forwarding alarms via SMS, email, WeChat, and WeCom. |
PLAT |
Optional. Deployed on Matrix. Corresponds to the alarm function in the general_PLAT_kernel-base_2.0_<version>.zip package for versions earlier than Unified Platform E0713. |
Report (BMP_Report_version_platform.zip) |
BMP_Certificate_version_platform.zip |
Provides the certificate management services, including: · Requesting certificates · Uploading certificates · Downloading certificates |
PLAT |
Optional. Deployed on Matrix. |
Alarm |
BMP_Dashboard_version_platform.zip |
Provides the dashboard framework capabilities, including: · Dashboard management · Dashboard settings · Area dashboard · Default dashboard · Service component management |
PLAT |
The dashboard application requires installation of both the dashboard and widget packages, with the dashboard installed before the widget. |
BMP_Widget_version_platform.zip |
Provides Unified Platform dashboard- and alarm-related widgets, and backend data interfaces |
PLAT |
Dashboard The dashboard application requires installation of both the dashboard and widget packages, with the dashboard installed before the widget. |
BMP_NETCONF_version_platform.zip |
Provides NETCONF channel services, including NETCONF connection maintenance for Unified Platform systems and devices, and NETCONF message issuing and subscriptions. |
PLAT |
N/A |
BMP_OneClickCheck_version_platform.zip |
· Provides the one-click check function to check the basic CPU, memory, database status, and process service status of the operating system, the operation status of the basic services (such as cluster) on which the controller depends, and the operating status of user services such as network elements and vNetworks, and generate relevant check reports. · Supports setting the time for scheduled check and setting the thresholds for check items. |
PLAT |
Not supported in the current software version. |
Alarm |
BMP_RDR_version_platform.zip |
Remote disaster recovery system (RDRS), which provides primary/secondary disaster recovery between two remote sites located in different areas. The components in the primary and secondary sites back up each other. When the RDRS is operating properly, it synchronizes data from the in-service site to the remote site in real time. This ensures data consistency between the two sites. You can configure the switchover mode as manual switchover or auto switchover with arbitration. When the in-service site encounters failures (for example, power interruption, network failure, or link failure), the other site takes over to ensure service continuity and reduce losses. |
PLAT |
Alarm |
BMP_Snapshot_version_platform.zip |
· Snapshot management, which allows you to configure snapshots for tenant-specific or network-wide services, and compare and roll back snapshots. · Enables quick, fine-grained repairs during the configuration change process in case of configuration errors or omissions. |
PLAT |
N/A |
BMP_Subscription_version_platform.zip |
Subscription service, which provides capabilities of forwarding via SMS, email, WeChat, and WeCom. |
PLAT |
Optional. Deployed on Matrix. Corresponds to the forwarding function in the general_PLAT_kernel-base_2.0_<version>.zip package for versions earlier than Unified Platform E0713. |
Alarm |
BMP_Suspension_version_platform.zip |
Adds maintenance tags to resources, including network devices, servers, storage devices, virtualization systems, containers, operating systems, databases, middleware products, and other resources. Allows you to configure relevant parameters to enable the system to perform related operations on resources. |
PLAT |
Optional. |
Alarm |
BMP_Template_version_platform.zip |
· Monitor template feature, which provides monitor setting management and template-based monitor index selection, threshold settings, and collection interval settings. You can select monitor templates in the monitor and auto discovery components. · Access parameter template feature, which provides template-based management of the parameters used by the system to access networks, servers, storage devices, virtualization systems, containers, operating systems, databases, middleware products, or other resources. |
PLAT |
Optional. Deployed on Matrix. Corresponds to the template function in the general_PLAT_kernel-base_2.0_<version>.zip package for versions earlier than Unified Platform E0713. |
N/A |
BMP_WebSocket_version_platform.zip |
Southbound WebSocket channel service: · Manages the establishment, authentication, and termination of device WebSocket connections. · Delivers, responds to, and subscribes to messages. |
PLAT |
N/A |
BMP_RDRArbitrator_version_platform.zip |
Third-party arbitration system installation package for RDRS, which provides automatic primary/secondary switchover in the RDRS scenario. |
PLAT |
For the procedure of deploying the arbitration service, see H3C Unified Platform Deployment Guide. |
BMP_Region_version_platform.zip |
Provides hierarchical site management and hub channel service. |
PLAT |
For the module to send alarms, you need also install Alarm. |
BMP_Syslog_version_platform.zip |
Receives, parses, stores, and generates alarms for Syslog data from network devices. |
PLAT |
Alarm |
BMP_Incident_version_platform.zip |
Provides the alarm aggregation feature, including: · Configuring alarm aggregation rules: The system aggregates alarms according to the configured rules to generate aggregate alarms. · Viewing aggregate alarms: Displays aggregate alarms on the active alarms page. |
PLAT |
Alarm |
BMP_AIOPS_version_platform.zip |
Installation package for the time-series data trend prediction and anomaly detection services. |
PLAT |
N/A |
GAP_version_platform.zip |
Implements data transmission from the lower-level node to the upper-level node in a two-level network environment. |
PLAT |
Optional. For the installing procedures, see H3C GAP Component Deployment Guide. |
Region |
NSM_FCAPS-Res_version_platform.zip |
Installation package for discovery, incorporation, and basic information management of network devices. |
NSM |
Optional. |
· portal (UDTP_Core_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · report (BMP_Report_version_platform.zip) · suspension (BMP_Suspension_version_platform.zip) · template (BMP_Template_version_platform.zip) |
NSM_FCAPS-Perf_version_platform.zip |
Installation package for network device performance monitoring and display. |
NSM |
Optional. |
· portal (UDTP_Core_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · report (BMP_Report_version_platform.zip) · res (NSM_FCAPS-Res_version_platform.zip) · template (BMP_Template_version_platform.zip) |
U-Center_UCP_version_platform.zip |
Installation package for the U-Center public platform component service. |
IOM |
Optional. |
N/A |
U-Center_CLICKHOUSE_version_platform.zip |
Installation package for the ClickHouse database service. |
IOM |
Optional. |
N/A |
U-Center_COLLECTPLAT_version_platform.zip |
Installation package for the collection platform service. |
IOM |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · accesstemp, monitortemp (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · register, etcd (U-Center_UCP_version_platform.zip) |
U-Center_IOM_version_platform.zip |
Installation package for the application monitoring service. |
IOM |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · accesstemp, monitortemp (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · dashboard (BMP_Dashboard_version_platform.zip) · glusterfs (UDTP_GlusterFS_version_platform.zip) · collectplat (U-Center_COLLECTPLAT_version_platform.zip) |
U-Center_ADDM_version_platform.zip |
Installation package for the auto-discovery service. |
IOM |
Optional. |
register, etcd(U-Center_UCP_version_platform.zip) |
U-Center_AGENT_version_platform.zip |
Installation package for the agent service. |
IOM |
Optional. |
· U-Center_COLLECTPLAT_version_platform.zip · register, etcd(U-Center_UCP_version_platform.zip) |
U-Center_VKVM_2.0_version_platform.zip |
Installation package for the server virtual remote console service. |
IOM |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · accesstemp, monitortemp (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · dashboard (BMP_Dashboard_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · U-Center_COLLECTPLAT_version_platform.zip · U-Center_IOM_version_platform.zip |
U-Center_LEARNWARE_version_platform.zip |
Provides management of dynamic threshold and capacity prediction tasks. |
IOM |
Optional. |
U-Center_CMDB_version_platform.zip |
Installation package for the configuration management database. |
CMDB |
Optional. |
· glusterfs (UDTP_GlusterFS_version_platform.zip) · common (UDTP_Middle_version_platform.zip) · UDTP_Core_version_platform.zip · alarm (BMP_Alarm_version_platform.zip) · BMP_Report_version_platform.zip |
U-Center_BSM_version_platform.zip |
Installation package for the service health analysis service. |
BSM |
Optional. |
· glusterfs (UDTP_GlusterFS_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · cmdb (U-Center_CMDB_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · collectplat (U-Center_COLLECTPLAT_version_platform.zip) · iop, iom (U-Center_IOM_version_platform.zip) |
U-Center_UEM_version_platform.zip |
Installation package for the user experience analysis service. |
BSM |
Optional. |
N/A |
U-Center_ITSM_version_platform.zip |
Installation package for the process management service. |
ITSM |
Optional. |
· glusterfs (UDTP_GlusterFS_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · common (UDTP_Middle_version_platform.zip) |
U-Center_NTA_version_platform.zip |
Installation package for the traffic monitoring service. |
NTA |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · accesstemp (BMP_Template_version_platform.zip) · network (NSM_FCAPS-Res_version_platform.zip) · zookeeper, clickhouse (U-Center_CLICKHOUSE_version_platform.zip) · etcd (U-Center_UCP_version_platform.zip) |
U-Center_STM_version_platform.zip |
Installation package for service dialing test management. |
STM |
Optional. |
· glusterfs (UDTP_GlusterFS_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · collectplat (U-Center_COLLECTPLAT_version_platform.zip) · iom (U-Center_IOM_version_platform.zip) |
U-Center_STM_Collector_version_platform.zip |
Installation package for the service dialing test collector |
STM |
Optional. |
· glusterfs (UDTP_GlusterFS_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · collectplat (U-Center_COLLECTPLAT_version_platform.zip) · iom (U-Center_IOM_version_platform.zip) |
U-Center_NQA_version_platform.zip |
Installation package for NQA dialing test management. |
STM |
Optional. |
· glusterfs (UDTP_GlusterFS_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · collectplat (U-Center_COLLECTPLAT_version_platform.zip) · iom (U-Center_IOM_version_platform.zip) · network (NSM_FCAPS-Res_version_platform.zip) · network (NSM_FCAPS-Perf_version_platform.zip) |
U-Center_NQA_Collector_version_platform.zip |
Installation package for the NQA dialing test collector. |
STM |
Optional. |
· glusterfs (UDTP_GlusterFS_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · collectplat (U-Center_COLLECTPLAT_version_platform.zip) · iom (U-Center_IOM_version_platform.zip) · network (NSM_FCAPS-Res_version_platform.zip) · network (NSM_FCAPS-Perf_version_platform.zip) |
U-Center_AOM_PLAT_version_platform.zip |
Installation package for the basic function service. |
AOM |
Optional. |
· gluster (UDTP_GlusterFS_version_platform.zip) · common (UDTP_Middle_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · network (NSM_FCAPS-Res_version_platform.zip) · network (NSM_FCAPS-Perf_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) |
U-Center_AOM_CCMS_version_platform.zip |
Installation package for CCMS. |
AOM |
Optional. |
· gluster (UDTP_GlusterFS_version_platform.zip) · common (UDTP_Middle_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · network (NSM_FCAPS-Res_version_platform.zip) · network (NSM_FCAPS-Perf_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · U-Center_AOM_PLAT_version_platform.zip |
U-Center_AOM_INI_version_platform.zip |
Installation package for INI. |
AOM |
Optional. |
U-Center_AOM_IPMS_version_platform.zip |
Installation package for IPMS. |
AOM |
Optional. |
U-Center_AOM_PROBE_version_platform.zip |
Installation package for the collection client Web service |
AOM |
Optional. |
· gluster (UDTP_GlusterFS_version_platform.zip) · common (UDTP_Middle_version_platform.zip) · portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · network (NSM_FCAPS-Res_version_platform.zip) · network (NSM_FCAPS-Perf_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · U-Center_AOM_PLAT_version_platform.zip (not dependent on this installation package for deployment through application deployment) |
U-Center_AOM_SFTP_version_platform.zip |
Installation package for the SFTP file server. |
AOM |
Optional. |
U-Center_ODA_Trino_version_platform.zip |
Installation package for the operation data analysis query federation component. |
ODA |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · metasevice (U-Center_ODA_MetaService_version_platform.zip) |
U-Center_ODA_Alarmize_version_platform.zip |
Installation package for the operation data analysis alarm generation service. |
ODA |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) |
U-Center_ODA_Capacity_version_platform.zip |
Installation package for the operation data analysis capacity management component. |
ODA |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · kernel-base (BMP_Template_version_platform.zip) · alarm (BMP_Alarm_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · collectplat (U-Center_COLLECTPLAT_version_platform.zip) · iom (U-Center_IOM_version_platform.zip) · learnware (U-Center_LEARNWARE_version_platform.zip) · alarmize (U-Center_ODA_Alarmize_version_platform.zip) |
U-Center_ODA_Scheduler_version_platform.zip |
Installation package for the operation data analysis scheduling engine. |
ODA |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) |
U-Center_ODA_Flink_version_platform.zip |
Installation package for the operation data analysis computing engine. |
ODA |
Optional. |
U-Center_ODA_Studio_version_platform.zip |
Installation package for the operation data analysis data development platform. |
ODA |
Optional. |
· portal, kernel (UDTP_Core_version_platform.zip) · ucp (U-Center_UCP_version_platform.zip) · metasevice (U-Center_ODA_MetaService_version_platform.zip) · scheduler (U-Center_ODA_Scheduler_version_platform.zip) · clickhouse (U-Center_CLICKHOUSE_version_platform.zip) |
U-Center_APA_version_platform.zip |
Installation package for the application performance monitoring service. |
APA |
Optional. |
· ucp (U-Center_UCP_version_platform.zip) · collectplat (U-Center_COLLECTPLAT_version_platform.zip) · clickhouse (U-Center_CLICKHOUSE_version_platform.zip) |
Server requirements
Hardware requirements
You can contact Technical Support for hardware configuration evaluation.
Software requirements
Table 5 Available Operating systems
Architecture |
Operating system |
x86 |
H3Linux V2.0.2 |
Red Hat Enterprise Linux 7.6 |
Community Enterprise Operating System 7.6 |
Red Hat Enterprise Linux 8.4 |
Red Hat Enterprise Linux 8.6 |
Kylin-Server-10-SP2 |
ARM |
H3Linux V2.0.2 |
IMPORTANT: · You must install the same operating system version on all nodes in a cluster. · Support for the x86 and ARM installation packages varies by component and version. For more information, see the release notes. |
Disk partitioning
The following disk partitioning configuration is for illustration only. Configure disk partitioning based on the actual situation.
Table 6 Disk partitioning configuration
Mount point |
Preset capacity |
Boot mode |
File system |
/var/lib/docker |
400 GiB |
BIOS/UEFI |
xfs |
· Determine the capacity based on Docker operation. Expand or reduce the capacity based on the incremental disk capacity occupied by deploying components in the actual service scenario. · If the disk space is sufficient, you can expand the capacity appropriately. |
/boot |
1024 MiB |
BIOS/UEFI |
xfs |
N/A |
swap |
1024 MiB |
BIOS/UEFI |
swap |
N/A |
/var/lib/ssdata |
450 GiB |
BIOS/UEFI |
xfs |
· This partition is for PXC, Kafka, and ZooKeeper. Theoretically, only Unified Platform uses this partition. For other components to use it, expand or reduce the capacity. · If the disk space is sufficient, you can expand the capacity appropriately. |
400 GiB |
BIOS/UEFI |
xfs |
· This partition is for Matrix, including K8s, Harbor, and installation packages of other components. Expand or reduce the capacity based on the size of component images. · If the disk space is sufficient, you can expand the capacity appropriately. As a best practice, do not store service data in the root directory. |
/opt/matrix/app/data/base-service/backupRecovery |
The backup directory size requirements for U-Center components vary by deployment scale, as shown in Table 7. |
BIOS/UEFI |
xfs |
This partition is for service backup data. Expand or reduce the capacity based on the service backup data size of components. |
/boot/efi |
200 MiB |
UEFI |
EFI System Partition |
This partition is required in UEFI mode. |
/var/lib/etcd |
50 GiB |
BIOS/UEFI |
xfs |
· As a best practice to ensure successful manual partitioning, mount this partition on a separated disk with the capacity of 51 GB or more. · This partition is required for master nodes but not for worker nodes. |
Reserved disk space |
N/A |
N/A |
N/A |
· This partition is for GlusterFS. Unified Platform in standard mode requires 140 GB. Make sure the preserved capacity is greater than 140 GB. For other components to use it, expand or reduce the capacity based on the disk size required for the components. This partition must be a standard partition. · This partition is required for master nodes but not for worker nodes. |
Table 7 Size requirements for backup directories of components
Component |
Default scale |
Large scale |
Medium scale |
Small scale |
CMDB |
10 GiB |
10 GiB |
10 GiB |
10 GiB |
IOM |
400 GiB*6 |
400 GiB*6 |
100 GiB*6 |
20 GiB*6 |
STM |
8 GiB*6 |
8 GiB*6 |
3 GiB*6 |
1 GiB*6 |
AOM |
40 GiB*6 |
10 GiB*6 |
3 GiB*6 |
ITSM |
40 GiB*6 |
40 GiB*6 |
10 GiB*6 |
3 GiB*6 |
BSM |
10 GiB*6 |
10 GiB*6 |
5 GiB*6 |
2 GiB*6 |
NTA |
5 GiB*6 |
5 GiB*6 |
2 GiB*6 |
1 GiB*6 |
UEM |
10 GiB*6 |
10 GiB*6 |
5 GiB*6 |
2 GiB*6 |
QuickReport |
20 GiB*6 |
20 GiB*6 |
15 GiB*6 |
10 GiB*6 |
ODA |
5 GiB*6 |
5 GiB*6 |
2 GiB*6 |
1 GiB*6 |
APA |
N/A |
N/A |
N/A |
N/A |
Client requirements
You can use a browser to access U-Center 2.0 without installing client software. As a best practice, use Google Chrome 70 or Firefox 78 or higher with a minimum resolution width of 1600 pixels.
Pre-installation checklist
Table 8 shows the check list for the installation requirements. Make sure the U-Center 2.0 installation requirements are met.
Table 8 Pre-installation checklist
Item |
Requirements |
Server or VM |
Hardware |
The CPU, memory, disk, and NIC settings are as required. |
Software |
· The operating system meets the requirements. · The system time settings are configured correctly. As a best practice, configure NTP on each node to ensure time synchronization on the network, and make sure the NTP server time is the same as the current time. · RAID is configured. |
Client |
Make sure the browser version meets the requirement. |
CAUTION: · During the U-Center 2.0 deployment process, do not enable or disable firewall services. · To avoid exceptions, do not modify the system time after cluster deployment. |
IMPORTANT: · As a best practice, set the mode to UEFI for the next startup of the server or VM. Select EFI from the boot firmware list. Do not select Enable UEFI secure boot for the VM. · Do not use KVM to install the same image for multiple servers when installing an operating system. · H5 KVM is unstable in performance and issues such as slow or unsuccessful image loading might occur during installation. As a best practice, use Java KVM to mount the image and install the operating system. · To ensure successful installation, do not press Scroll Lock during the installation. · A power failure during the installation process might cause installation failure of some service components. For function integrity, perform a reinstallation when a power failure occurs during installation. · Do not enable or disable firewalls during the U-Center 2.0 deployment. · To avoid cluster exceptions, do not edit the system time after the completion of cluster deployment. |
Software package verification
Before installing the software, first perform MD5 verification on each software package to ensure its integrity and correctness.
1. Identify the uploaded installation packages.
[root@node1~]# cd /opt/matrix/app/install/packages/
[root@node1~]# ls
BMP_Report_E0722_x86.zip UDTP_Core_E0722_x86.zip
2. Obtain the MD5 value of an installation package, for example, UDTP_Core_E0722_x86.zip.
[root@node1~]# md5sum UDTP_Core_E0722_x86.zip
2b8daa20bfec12b199192e2f6e6fdeac UDTP_Core_E0722_x86.zip
3. Compare the obtained MD5 value with the MD5 value released with the software. If they are the same, the installation package is correct.
Installing Unified Platform
Before deploying U-Center 2.0, first deploy Unified Platform and then deploy U-Center 2.0 components on Unified Platform.
To deploy Unified Platform:
1. Install the operating system and dependencies.
2. Install Matrix.
3. Create a cluster and configure cluster parameters.
4. Deploy Unified Platform components.
For more information about the deployment procedure, see H3C Unified Platform Deployment Guide.
CAUTION: U-Center 2.0 components (IOM, CMDB, BSM, STM, ITSM, AOM, NTA, NSM, ODA, APA, and QuickReport) of version E0715 or later must be installed on the convergence deployment page. |
1. In the address bar of the browser, enter https://ip_address:8443/matrix/ui to log in to Matrix.
The default username is admin and the default password is Pwd@12345. If the operating system password has been set, enter the set password. The ip_address parameter specifies the northbound service VIP.
2. On the top navigation bar, click DEPLOY.
3. From the navigation pane, select Convergence Deployment.
4. Click Packages Management to access the page for uploading installation packages. On this page, you can upload and delete installation packages for convergence deployment.
5. Click Upload. In the window that opens, click Select Files, and upload installation packages.
You can bulk upload application installation packages.
When you install U-Center 2.0, follow these restrictions and guidelines:
· After uploading the installation package, see the following sections for the specific deployment procedures of each component in U-Center 2.0.
· On the convergence deployment page, you can view, expand, upgrade, and perform other operations on the specified applications.
· Registration of configuration data carried in the installation packages is required in the following scenarios:
¡ If you upload the installation packages without using the Web interface, select the packages and then click Register Data.
¡ If multiple versions exist for an installation package, register data for the version to be deployed.
· If the components that have been installed through application deployment do not support convergence deployment, perform the following tasks before performing operations such as viewing details, expanding, and upgrading:
a. Upload the convergence deployment packages of the related application components.
b. After the upload is completed, click Data Synchronization to synchronize the data from the Applications page to the Convergence Deployment page.
· If you want to use the upper-level and lower-level functions, install BMP_Region_version_platform.zip.
· To use HTTPS, log in to Unified Platform after the applications and components are installed and then select System > System Settings > Security Settings to enable HTTPS.
· After completing installation package upload, the system automatically synchronizes the installation packages to the following directory of each node: /opt/matrix/app/install/packages/
The installation packages listed as IOM in the Product Package column in Table 4 are IOM component-related installation packages. You can deploy the installation package as needed.
NOTE: You can select and install all of the following packages simultaneously: UCP, COLLECTPLAT, IOM, ADDM, and AGENT. |
To deploy the IOM component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_IOM_version_platform.zip as an example.
2. Verify the package information in the package management list.
3. Click Back.
4. Click Install.
5. On the application selection page, all scenarios are selected by default. If you select some scenarios, the page displays only applications for the selected scenarios and Unified Platform, and applications required for the selected scenarios are selected.
¡ All: Related applications of Unified Platform and all other components.
¡ U-Center Scenario: Related applications of Unified Platform and U-Center components.
6. In the U-Center scenario area, select the applications to be deployed.
If you select an application with dependent applications, its dependent applications will be automatically selected. If a dependent application is not deployed or not included in the current installation package, the system will prompt relevant information.
7. Click Next to access the package selection page, and select the convergence deployment packages to be installed.
The system will verify the packages.
8. After verification, click Next to access the resource configuration page. Select the resource scale for components based on the planned network and service scales.
9. Click Next to access the parameter configuration page.
Configure predefined parameters, and select nodes for deployment.
10. Click Deploy. In the dialog box that opens, confirm the applications to be installed.
11. After confirmation, click OK to start deployment.
The installation packages listed as CMDB in the Product Package column in Table 4 are CMDB component-related installation packages. You can deploy the installation package as needed.
To deploy the CMDB component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_CMDB_2.0_version_platform.zip as an example.
3. Click Back.
4. Click Install.
The installation packages listed as BSM in the Product Package column in Table 4 are BSM component-related installation packages. You can deploy the installation package as needed.
NOTE: You can select and install all of the following packages simultaneously: BSM, UEM, STM, and NQA. |
To deploy the BSM component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_BSM_version_platform.zip as an example.
3. Click Back.
4. Click Install.
9. Click Next to access the parameter configuration page. You do not need to configure any parameter for BSM.
The installation packages listed as ITSM in the Product Package column in Table 4 are ITSM component-related installation packages. You can deploy the installation package as needed.
NOTE: Deploy the ITSM component separately. Do not select ITSM together with other installation packages. |
To deploy the ITSM component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_ITSM_version_platform.zip as an example.
3. Click Back.
4. Click Install.
9. Click Next to access the parameter configuration page. You do not need to configure any parameter for ITSM.
The installation packages listed as NTA in the Product Package column in Table 4 are NTA component-related installation packages. You can deploy the installation package as needed.
NOTE: NTA depends on NTA, NSM_FCAPS-Res, UCP, and CLICKHOUSE installation packages. You must deploy them in the following order: NSM_FCAPS-Res, UCP, CLICKHOUSE, NTA. |
To deploy the NTA component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_NTA_version_platform.zip as an example.
3. Click Back.
4. Click Install.
9. Click Next to access the parameter configuration page. You do not need to configure any parameter for NTA.
The installation packages listed as AOM in the Product Package column in Table 4 are AOM component-related installation packages. You can deploy the installation package as needed.
NOTE: · To install AOM, first install the AOM_PLAT component, and then install the other components in any order. IPMS, INI, CCMS, and PROBE can be installed at different steps. In a scenario with low performance or low disk read or write speed, install them in multiple steps. · You can select the number of probes for AOM as needed. Select a minimum of one collector. As a best practice, add one collector for every 400 devices. · U-Center_AOM_JOB_version_platform.zip depends on U-Center_IOM_version_platform.zip, U-Center_AOM_SFTP_version_platform.zip and other installation packages, as described in "Installation packages." Deploy the JOB package together with its dependent packages. |
To deploy the AOM component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_AOM_PLAT_version_platform.zip as an example.
3. Click Back.
4. Click Install.
The installation packages listed as STM in the Product Package column in Table 4 are STM component-related installation packages. You can deploy the installation package as needed.
To deploy the STM component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_STM_version_platform.zip as an example.
3. Click Back.
4. Click Install.
9. Click Next to access the parameter configuration page. You do not need to configure any parameter for STM.
The installation packages listed as REPORT in the Product Package column in Table 4 are QuickReport component-related installation packages. You can deploy the installation package as needed.
To deploy the QuickReport component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_Report_version_platform.zip as an example.
3. Click Back.
4. Click Install.
6. In the Unified Platform scenario area, select the applications to be deployed.
8. After verification, click Next to access the resource configuration page. You do not need to configure the resource scale for QuickReport.
9. Click Next to access the parameter configuration page. You do not need to configure any parameter for QuickReport.
The installation packages listed as ODA in the Product Package column in Table 4 are ODA component-related installation packages. You can deploy the installation package as needed.
1. Upload the convergence deployment packages to be deployed. Take U-Center_ ODA _version_platform.zip as an example.
3. Click Back.
4. Click Install.
9. Click Next to access the parameter configuration page. You do not need to configure any parameter for ODA.
The installation packages listed as APA in the Product Package column in Table 4 are APA component-related installation packages. You can deploy the installation package as needed.
To deploy the APA component:
1. Upload the convergence deployment packages to be deployed. Take U-Center_APA_version_platform.zip as an example.
3. Click Back.
4. Click Install.
9. Click Next to access the parameter configuration page. You do not need to configure any parameter for APA.
Logging in to U-Center 2.0
1. Enter the URL of U-Center 2.0 http://ip_address:30000 in your browser. Replace ip_address with the northbound service VIP. The default port number is 30000. Figure 1 shows the login page.
Figure 1 U-Center 2.0 login page
2. Enter the username and password, and then click Login.
The default username is admin and the default password is Pwd@12345. If you have set the password when installing the operating system, enter the set password.
Registering the software
After you deploy U-Center 2.0, you must obtain licenses to use it. If you have purchased the product, obtain the relevant license key to complete the consequent registration process. To obtain a trial license, contact relevant H3C marketing personnel.
For more information about requesting and installing licenses, see H3C Software Products Remote Licensing Guide.
License support
NOTE: The license server and U-Center 2.0 are one-to-one related. A license server can be used by only one U-Center 2.0. |
Table 9 describes the licenses for each component of U-Center 2.0.
Component |
License description |
Product code |
Product description |
NSM |
Network basic license |
LIS-IMC9-NSM |
H3C U-Center2.0, NSM Network Device Management License |
Network quantity license |
LIS-IMC9-NSMA-25 |
H3C U-Center2.0, NSM Network Device Management, 25 Licenses |
LIS-IMC9-NSMB-50 |
H3C U-Center2.0, NSM Network Device Management, 50 Licenses |
LIS-IMC9-NSMC-100 |
H3C U-Center2.0, NSM Network Device Management, 100 Licenses |
LIS-IMC9-NSMD-200 |
H3C U-Center2.0, NSM Network Device Management, 200 Licenses |
LIS-IMC9-NSME-500 |
H3C U-Center2.0, NSM Network Device Management, 500 Licenses |
LIS-IMC9-NSMF-1K |
H3C U-Center2.0, NSM Network Device Management, 1000 Licenses |
Table 10 U-Center 2.0 licenses
Component |
Product code |
CMDB |
U-Center basic license |
LIS-UCENTER2-IOP |
H3C U-Center2.0, Intelligent Operations Platform Software |
CMDB basic license |
LIS-UCENTER2-CMDB |
H3C U-Center2.0, CMDB License |
CMDB quantity license |
LIS-UCENTER2-CMDB-25 |
H3C U-Center2.0, CMDB, 25 Licenses |
LIS-UCENTER2-CMDB-50 |
H3C U-Center2.0, CMDB, 50 Licenses |
LIS-UCENTER2-CMDB-100 |
H3C U-Center2.0, CMDB, 100 Licenses |
LIS-UCENTER2-CMDB-200 |
H3C U-Center2.0, CMDB, 200 Licenses |
LIS-UCENTER2-CMDB-500 |
H3C U-Center2.0, CMDB, 500 Licenses |
LIS-UCENTER2-CMDB-1K |
H3C U-Center2.0, CMDB, 1000 Licenses |
LIS-UCENTER2-CMDB-1 |
H3C U-Center2.0, CMDB, 1 License |
LIS-UCENTER2-CMDB-100-A |
Report |
Report |
LIS-UCENTER2-IOM-IAR |
H3C U-Center2.0, IOM, Intelligent Analysis Report License |
IOM |
IOM basic license |
LIS-UCENTER2-IOM |
H3C U-Center2.0, IOM Licenses |
IOM quantity license |
LIS-UCENTER2-IOM-25 |
H3C U-Center2.0, IOM, 25 Licenses |
LIS-UCENTER2-IOM-50 |
H3C U-Center2.0, IOM, 50 Licenses |
LIS-UCENTER2-IOM-100 |
H3C U-Center2.0, IOM, 100 Licenses |
LIS-UCENTER2-IOM-200 |
H3C U-Center2.0, IOM, 200 Licenses |
LIS-UCENTER2-IOM-500 |
H3C U-Center2.0, IOM, 500 Licenses |
LIS-UCENTER2-IOM-1K |
H3C U-Center2.0, IOM, 1000 Licenses |
LIS-UCENTER2-IOM-1 |
H3C U-Center2.0, IOM, 1 License |
LIS-UCENTER2-IOM-100-A |
BSM |
BSM basic license |
LIS-UCENTER2-BSM |
H3C U-Center2.0, BSM License |
BSM quantity license |
LIS-UCENTER2-BSM-1 |
H3C U-Center2.0, BSM, 1 License |
LIS-UCENTER2-BSM-5 |
H3C U-Center2.0, BSM, 5 Licenses |
LIS-UCENTER2-BSM-10 |
H3C U-Center2.0, BSM, 10 Licenses |
UEM quantity license |
LIS-UCENTER2-BSM-UEM-1-B |
H3C U-Center2.0, BSM, UEM, 1 License |
LIS-UCENTER2-BSM-UEM-1 |
LIS-UCENTER2-BSM-UEM-2 |
H3C U-Center2.0, BSM, UEM, 2 License |
LIS-UCENTER2-BSM-UEM-5 |
H3C U-Center2.0, BSM, UEM, 5 License |
NTA |
NTA basic license |
LIS-UCENTER2-IOM-NTA |
H3C U-Center2.0, IOM, Network Traffic Analyzer License |
NTA quantity license |
LIS-UCENTER2-IOM-NTA-1-B |
H3C U-Center2.0, IOM, Network Traffic Analyzer, 1 License |
LIS-UCENTER2-IOM-NTA-1 |
LIS-UCENTER2-IOM-NTA-2 |
H3C U-Center2.0, IOM, Network Traffic Analyzer, 2 License |
LIS-UCENTER2-IOM-NTA-5 |
H3C U-Center2.0, IOM, Network Traffic Analyzer, 5 License |
ITSM |
ITSM basic license |
LIS-UCENTER2-ITSM |
H3C U-Center2.0, ITSM License |
ITSM quantity license |
LIS-UCENTER2-ITSM-1 |
H3C U-Center2.0, ITSM, 1 License |
LIS-UCENTER2-ITSM-5 |
H3C U-Center2.0-ITSM-5 License |
LIS-UCENTER2-ITSM-10 |
H3C U-Center2.0-ITSM-10 License |
LIS-UCENTER2-ITSM-20 |
H3C U-Center2.0-ITSM-20 License |
LIS-UCENTER2-ITSM-50 |
H3C U-Center2.0-ITSM-50 License |
LIS-UCENTER2-ITSM-100 |
H3C U-Center2.0-ITSM-100 License |
ITSM change release management license |
LIS-UCENTER2-ITSM-CRM |
H3C U-Center2.0, ITSM, Change and Release Management License |
ITSM service level management basic license |
LIS-UCENTER2-ITSM-SLM |
H3C U-Center2.0, ITSM, Service Level Management License |
ITSM knowledge base license |
LIS-UCENTER2-ITSM-KB |
H3C U-Center2.0, ITSM, Knowledge Base License |
ITSM self-service platform license |
LIS-UCENTER2-ITSM-SSD |
H3C U-Center2.0, ITSM, Self-Service Desk License |
CM |
Capacity management |
LIS-UCENTER2-CM |
H3C U-Center2.0 CM, Capacity Management License |
AOM |
IP address management |
LIS-UCENTER-AOM-IPMS-50 |
H3C UCenter, AOM, IP Address Management System, 50 Licenses |
LIS-UCENTER-AOM-IPA-100 |
H3C UCenter, AOM, IP Address Management System, 100 Licenses |
LIS-UCENTER-AOM-IPA-200 |
H3C UCenter, AOM, IP Address Management System, 200 Licenses |
LIS-UCENTER-AOM-IPA-500 |
H3C UCenter, AOM, IP Address Management System, 500 Licenses |
LIS-UCENTER-AOM-IPA-1000 |
H3C UCenter, AOM, IP Address Management System, 1000 Licenses |
LIS-UCENTER2-AOM-IPA-1 |
H3C U-Center2.0, AOM, IP Address Management System, 1 License |
LIS-UCENTER2-AOM-IPA-100-A |
H3C U-Center2.0, AOM, IP Address Management System, 100 Licenses |
Configuration and compliance intelligent management license |
LIS-UCENTER-AOM-CCI-50-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 50 Licenses |
LIS-UCENTER-AOM-CCI-100-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 100 Licenses |
LIS-UCENTER-AOM-CCI-200-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 200 Licenses |
LIS-UCENTER-AOM-CCI-500-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 500 Licenses |
LIS-UCENTER-AOM-CCI-1000-2 |
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 1000 Licenses |
LIS-UCENTER2-AOM-CCI-1 |
H3C U-Center2.0, AOM, Configuration And Compliance Intelligent Management, 1 License |
LIS-UCENTER2-AOM-CCI-100-A |
H3C U-Center2.0, AOM, Configuration And Compliance Intelligent Management, 100 Licenses |
Intelligent inspection |
LIS-UCENTER-AOM-IIE-50 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 50 Licenses |
LIS-UCENTER-AOM-IIE-100 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 100 Licenses |
LIS-UCENTER-AOM-IIE-200 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 200 Licenses |
LIS-UCENTER-AOM-IIE-500 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 500 Licenses |
LIS-UCENTER-AOM-IIE-1000 |
H3C U-Center, AOM, Intelligent Inspection Expert Provider Edition, 1000 Licenses |
LIS-UCENTER2-AOM-IIE-1 |
H3C U-Center2.0, AOM, Intelligent Inspection Expert Provider Edition, 1 License |
LIS-UCENTER2-AOM-IIE-100-A |
H3C U-Center2.0, AOM, Intelligent Inspection Expert Provider Edition, 100 Licenses |
Job platform |
LIS-UCENTER2-AOM-JOB |
H3C U-Center2.0 AOM-Job Platform License |
LIS-UCENTER2-AOM-JOB-1 |
H3C U-Center2.0 AOM-Job Platform, 1 License |
LIS-UCENTER2-AOM-JOB-25 |
H3C U-Center2.0 AOM-Job Platform, 25 Licenses |
LIS-UCENTER2-AOM-JOB-50 |
H3C U-Center2.0 AOM-Job Platform, 50 Licenses |
LIS-UCENTER2-AOM-JOB-100 |
H3C U-Center2.0 AOM-Job Platform, 100 Licenses |
LIS-UCENTER2-AOM-JOB-200 |
H3C U-Center2.0 AOM-Job Platform, 200 Licenses |
LIS-UCENTER2-AOM-JOB-500 |
H3C U-Center2.0 AOM-Job Platform, 500 Licenses |
LIS-UCENTER2-AOM-JOB-1K |
H3C U-Center2.0 AOM-Job Platform, 1000 Licenses |
APA |
Application performance analytics |
LIS-UCENTER2-APA |
H3C U-Center2.0 APA-Application Performance Analytics License |
LIS-UCENTER2-APA-1 |
H3C U-Center2.0 APA-Application Performance Analytics, 1 License |
LIS-UCENTER2-APA-25 |
H3C U-Center2.0 APA-Application Performance Analytics, 25 Licenses |
LIS-UCENTER2-APA-50 |
H3C U-Center2.0 APA-Application Performance Analytics, 50 Licenses |
LIS-UCENTER2-APA-100 |
H3C U-Center2.0 APA-Application Performance Analytics, 100 Licenses |
LIS-UCENTER2-APA-200 |
H3C U-Center2.0 APA-Application Performance Analytics, 200 Licenses |
LIS-UCENTER2-APA-500 |
H3C U-Center2.0 APA-Application Performance Analytics, 500 Licenses |
LIS-UCENTER2-APA-1K |
H3C U-Center2.0 APA-Application Performance Analytics, 1000 Licenses |
ODA |
Operational data analytics |
LIS-UCENTER2-ODA |
H3C U-Center2.0 ODA-Operational Data Analytics License |
STM |
STM quantity license |
LIS-UCENTER2-IOM-STM-1 |
H3C U-Center2.0, IOM, STM, 1 License |
STM license |
LIS-UCENTER2-IOM-STM |
H3C U-Center2.0, IOM, STM License |
For more information about license request and installation, see H3C Software Products Remote Licensing Guide. After importing a license file to the H3C license management system, configure U-Center 2.0 as the license client to access the license server.
NOTE: When you install the license server in H3Linux 2.0, you can install it on the same node as U-Center 2.0 or install it on a separate node. As a best practice, install them on different nodes. For more information about installing the license server, see H3C License Server Installation Guide. |
Creating a license client
1. Log in to the license server, and navigate to the Configuration > License Clients page.
2. Click Add. On the page that opens, configure the client name and password.
3. Click OK.
Configuring the client connection
This function allows you to connect the client to the license server to obtain licenses.
1. Log in to U-Center 2.0.
2. Navigate to the System > License Management > License Information page.
3. In the License Server Info area, configure the following parameters of the license server, and then click Connect:
¡ Address—Specify the IP address of the license server.
¡ Port Number—Enter the service port number of the license server. The default value is 5555.
¡ Username—Enter the client name configured on the license server.
¡ Password—Enter the client password configured on the license server.
4. You can obtain the license if the client is connected to the license server. When the connection status is Connected, click Refresh in 5 minutes to view the latest license information.
IMPORTANT: · To avoid failure to connect to the license server, make sure the firewall is disabled for the license server when you start the client service. · To obtain licenses successfully, make sure the license server has available licenses when you start the client service. |
Viewing the license usage
1. Log in to the license server.
2. Navigate to the Clients > Client Connections page.
On the page that opens, you can view and manage clients connected to the license server.
To bulk disconnect clients from the license server, select them and then click Bulk Disconnect. To disconnect all clients, click Disconnect All.
To reclaim all licenses from a client, click Details in the Actions column for the client and then click Reclaim All on the page that opens. To reclaim a license from the client, click Reclaim for the license.
You can back up and restore configuration for U-Center 2.0 components on Unified Platform. For more information, see H3C Unified Platform Deployment Guide.
When a cluster node server operates abnormally and cannot recover due to hardware failures, replace the server. When the operating system of a node server is abnormal, reinstall the operating system and Matrix on the server. On Unified Platform, you can recover the cluster when a failure occurs. For more information, see H3C Unified Platform Deployment Guide.
CAUTION: U-Center 2.0 components (IOM, CMDB, BSM, STM, ITSM, AOM, NTA, and NSM, ODA, APA, and QuickReport) of version E0715 or later must be upgraded on the convergence deployment page. |
· Before upgrade, you must back up your data.
· Before upgrading U-Center 2.0, upgrade Matrix and Unified Platform to the corresponding version. For more information about upgrading Matrix and Unified Platform, see H3C Unified Platform Deployment Guide.
· Before upgrade, first clear the browser cache and sessions.
· Follow the installation sequence of application packages to upgrade the applications.
4. Click Install. The installation package-uploading page opens.
5. Click Upload, select Choose File in the pop-up window, and then upload the installation packages for convergence deployment. You can upload multiple application packages in bulk.
6. After the uploading is complete, click Cancel to return to the convergence deployment page.
7. Click Data Synchronization. The components to be upgraded are displayed in the list.
8. Click the icon in the Actions column for a component to be upgraded to access
the upgrade page.
9. Select the installation packages to be upgraded.
If a selected installation package does not meet the dependencies and version verification of the current application, the system will prompt an error.
10. After selecting the installation packages that comply with the upgrade rules, click Upgrade to proceed with upgrade and deployment.
After you uninstall and reinstall U-Center 2.0, you must clear the content in the /var/lib/ssdata/ directory on each node.
To retain the component configuration and data, use the backup function before uninstallation. For more information about the backup function, see "Backing up and restoring the configuration."
4. Select the applications to be uninstalled in the list, and click Uninstall.
NOTE: · The system supports bulk uninstallation. · If other applications depend on the application to be uninstalled, the system will also select all applications that depend on the application to ensure the integrity of the application operation. In this case, you cannot uninstall the application separately. · If no application depends on the selected application, you can uninstall the application separately. |
5. In the confirmation dialog box that opens, click OK.
CAUTION: Uninstalling a single component or application might affect the operation of other components or applications. Uninstall applications with caution. For the application dependencies, see "Installation packages." |
To uninstall an application through application deployment:
1. Enter https://ip_address:8443/matrix/ui in the browser to log in to Matrix. Replace ip_address with the northbound service VIP.
3. From the navigation pane, select Applications.
4. Click the icon in the Actions column for an application.
5. In the dialog box that opens, click OK.
Backing up the configuration
1. In the address bar of the browser, enter http://ip_address:30000. Then, enter the username and password.
¡ Both HTTP and HTTPS are supported. The default protocol is HTTP and the default port number is 30000. If the protocol and port number have been set, enter the set protocol and port number.
¡ The default username and password are admin and Pwd@12345, respectively. If the username and password have been set, enter the set username and password.
2. Navigate to the System > Backup & Restore page.
3. Manually back up the configuration and save the backup files locally.
For more information about the backup procedure and restrictions and guidelines, see the online help and configuration backup and restoration in H3C Unified Platform Deployment Guide.
Perform this task to shut down and power off one or multiple nodes to ensure that the system is still operating correctly when U-Center is deployed in cluster mode. This task applies to scenarios such as software upgrade and hardware replacement for nodes and routine inspection.
To shut down and power off part of nodes:
1. In the address bar of the browser, enter https://ip_address:8443/matrix/ui to log in to Matrix. Then, enter the username, password, and verification code.
The default username and password are admin and Pwd@12345, respectively. If the Matrix username and password has been set, enter the set username and password.
2. Navigate to the DEPLOY > Clusters > Deploy Cluster page, select a node. To shut down and power off multiple nodes, disable these nodes one by one. That is, perform operations on a node only after the operations such as backup and restoration have been completed on another node.
3. To disable a node, click the set icon in the upper right corner of the node and click Disable.
4. After a node is disabled, execute the shutdown -h now command to shut down the node.
5. Before you power off a node, make sure the node power status is off on HDM or the power LED of the node indicates that the node is in standby state.
Perform this task to shut down and power off the system. This task applies to scenarios such as emergency power outages and equipment room relocations.
To shut down and power off all nodes:
2. Navigate to the DEPLOY > Clusters > Deploy Cluster page. Disable all master nodes in the cluster.
Starting servers
1. Power on and start up servers.
2. After the servers start up, execute the ip addr command to verify that the nodes and the service networks are up.
3. Verify network connectivity. Make sure a node can reach the other nodes in different network segments and the client can reach the service networks of all nodes in the cluster.
Starting the system service
1. Access Matrix from the browser.
2. Navigate to the DEPLOY > Clusters > Deploy Cluster page, and then enable nodes.
Wait for about 30 minutes. The actual waiting time might vary by data volume being processed.
3. On the top navigation pane, click DASHBOARD to view system operation statistics to identify whether the system service has started up.
4. On the top navigation pane, click OBSERVE to view workload information about Pods.
1. Access U-Center from the browser.
3. Verify that the license information is synchronized from the license server and the authorization status is normal.
4. Verify that the features of U-Center are operating correctly.
FAQ
How can I prepare a disk partition for GlusterFS on a node?
Prepare a disk partition for GlusterFS on each node in the cluster, and record the disk partition name for future use.
To prepare a disk partition for GlusterFS on a node, perform one of the following tasks:
Manually create a new disk partition
1. Reserve sufficient disk space for GlusterFS when you install the operating system.
2. After the operating system is installed, execute the fdisk command to create a disk partition.
Figure 2 gives an example of how to create a 250 GB disk partition /dev/sda7 on disk sda. If the system fails to obtain the partition list, execute the reboot command to restart the node.
Figure 2 Creating a disk partition
Use an existing disk partition
If an existing disk partition with 250 GB or more capacity has not been used or mounted, you can clear the disk partition and use it for GlusterFS, for example, /dev/sda7 as shown in Figure 3. To clear the disk partition, execute the wipefs -a /dev/sda7 command.
Figure 3 Disk partition information
Prepare an independent disk for GlusterFS
Execute the wipefs -a command to clear the disk before using it for GlusterFS.
Figure 4 Clearing disk
I have activated IOM basic and quantity licenses, but the application incorporation fails. An error massage is displayed that the number of monitors exceeds license limit. Why does this happen?
IOM depends on COLLECTPLAT. You need to activate CMDB quantity license of COLLECTPLAT.
Is there any additional information that I should pay attention to?
After the IOP license (H3C U-Center2.0, Intelligent Operations Platform Software) is registered, two license names, UCENTER-UCENTER-UCD and UCENTER-UCENTER2, are generated.
How can I manually modifying the ES values in the back end?
1. Execute the kubectl edit sts elasticsearch-node-1 -n service-software command.
3. Locate memory in the limits entry, and change its value from 2G to 12G. You can adjust the value 12G as needed. Make sure the value is at least 3G greater than the value following Xms or Xmx.
4. Save the configuration and exit.
5. Execute the kubectl edit sts elasticsearch-node-2 -n service-software command. Repeat steps 2 through 4.
6. Execute the kubectl edit sts elasticsearch-node-3 -n service-software command. Repeat steps 2 through 4.
7. After modification, enter any elasticsearch pod, and execute the curl ‘elasticsearch-http-service:9200/_cat/health?v’ command to view the cluster state. When the status is green or yellow in the returned value, the cluster is available. If a large amount of data exist, ES takes a certain period of time to restore data after you complete the preceding steps.
How can I identify the enabling status for the RAID controller cache policies when configuring a RAID array for servers if the IOPS of a disk is as low as 1k?
When configuring a RAID array for servers, you must enable the RAID controller cache policies. Table 11 shows only some parameters in the RAID configuration. In the actual configuration, see the storage controller user guide for the corresponding server model.
Parameter |
Array Label |
Name of the RAID array. The default is DefaultValue0. |
Stripe Size |
Strip size, which determines the data block size of a stripe on each drive. |
Array Size Selection |
RAID array capacity. |
Read Cache |
Read cache policy status. Options include Enabled and Disabled. |
Write Cache |
Write cache policy status. Options include: · Enable Always—Always enables the write cache. Without a supercapacitor installed, this status might cause data loss if power supply fails. · Enable With Backup Unit—Disables the write cache when the supercapacitor is absent or not ready. · Disabled—Disables the write cache. |
Create RAID via |
Operation after the RAID array is created. Options include Quick Init, Skip Init, Build/Verify, and Clear. |
