H3C G6 Servers AMD Genoa & Bergamo Platform Scenario-Based BIOS Configuration Guide-6W102
HomeSupportConfigure & DeployUser ManualsH3C G6 Servers AMD Genoa & Bergamo Platform Scenario-Based BIOS Configuration Guide-6W102
01-Text
01-Text 757.16 KB
About the BIOS
In order to meet the diverse needs of users under different workloads, this document introduces configuration guidance for setting BIOS parameters based on the services running on the server, and describes applicable scenarios and configuration instructions for related workload modes.
Introduction
The Basic Input and Output System (BIOS) is a non-volatile firmware stored in the system ROM of a server. It is used to perform hardware initialization during server booting and provide runtime services for the operating systems. As shown in Figure 1, the BIOS interacts between the server hardware and the operating system (OS).
The main functions of BIOS include:
·     Performing POST self-test.
·     Detecting input and output devices and bootable devices, including memory initialization, hardware scanning, finding boot devices, and starting the system.
·     Providing advanced power management ACPI.
·     Configuring RAID.
Figure 1 Layered architecture of a server system
Applicable products
This document is applicable to the following products:
·     H3C UniServer R3950 G6
·     H3C UniServer R4950 G6
·     H3C UniServer R5350 G6
·     H3C UniServer R5500 G6 AMD
Applicable versions
The BIOS version applicable to this article is BIOS-6.30.XX.
Using this document
The information in this document is subject to change over time.
The information in this document might differ from your product if it contains custom configuration options or features.
BIOS Recommended Configuration
Introduction
Configuration template is a collection of configuration options that deploys BIOS settings to suit the expected application of the server. BIOS provides multiple sets of configuration templates to help users deploy the most suitable BIOS settings according to different scenarios. The configuration parameters in the templates are suggested values for various application scenarios.
Recommended BIOS parameter configurations for various workload modes
The recommended BIOS parameter configurations for various workload patterns are shown in Table 1, Table 2, Table 3, and Table 4, illustrating the dependencies associated with scenario configuration templates. X indicates no requirement for that option in the configuration template and defaults to the default value of the current model. The meaning of X might vary among different models. When applying a configuration template, X values in the template will be restored to the default values of the current model.
IMPORTANT
IMPORTANT:
·     Not all options corresponding to the table are displayed in BIOS, but when using the configuration template, the corresponding option settings will default to the values shown in the table.
·     Selecting a configuration template other than Custom will gray out the relevant options in the template, making them unmodifiable. Modifying associated options using the out-of-band Redfish and in-band SCE tools will also not take effect.
For applicable scenarios and configuration explanations of various workload mdoes, see Introduction to workload mode.
Table 1 General-Purpose Workloads and configuration template dependencies
Dependencies
CPU intensive
Java throughput intensive
Java latency sensitive
Power efficiency
SMT Control
Enabled
Enabled
Enabled
Enabled
L1 Stream HW Prefetcher
Enabled
Enabled
Enabled
Enabled
L1 Stride Prefetcher
Enabled
Enabled
Enabled
Enabled
L1 Region Prefetcher
Enabled
Enabled
Enabled
Enabled
L1 Burst Prefetch Mode
Enabled
Enabled
Enabled
Enabled
L2 Stream HW Prefetcher
Enabled
Enabled
Enabled
Enabled
L2 Up/Down Prefetcher
Enabled
Enabled
Enabled
Enabled
BoostFmaxEn
Auto
Auto
Auto
Auto
Power Profile Selection
High Performance Mode
Efficiency Mode
Determinism Control
Auto
Auto
Auto
Auto
Determinism Enable
X
X
X
X
TDP Control
Manual
Manual
Manual
Manual
TDP
OPN Max
OPN Max
OPN Max
OPN Max
PPT Control
Manual
Manual
Manual
Manual
PPT
OPN Max
OPN Max
OPN Max
OPN Max
CPPC
Auto
Auto
Auto
Auto
ACPI SRAT L3 Cache As NUMA Domain
Disabled
Disabled
Disabled
Enable
NUMA Nodes per Socket
NPS1
NPS4
NPS2
NPS4
Memory Target Speed
DDR4800
DDR4800
DDR4800
DDR4800
Memory Interleaving
Enabled
Enabled
Enabled
Enabled
3-link xGMI max speed
32Gbps
32Gbps
32Gbps
32Gbps
4-link xGMI max speed
32Gbps
32Gbps
32Gbps
32Gbps
xGMI Link Width Control
Auto
Auto
Auto
Auto
xGMI Max Link Width
X
X
X
X
xGMI Max Link Width Control
X
X
X
X
xGMI Force Link Width Control
X
X
X
X
X
X
X
X
APBDIS
0
0
0
1
DF Cstates
Disabled
Disabled
Disabled
Disabled
Local APIC Mode
Auto
Auto
Auto
Auto
PCIE Speed PMM Control
Auto
Auto
Auto
Auto
SRIOV
Disabled
Disabled
Disabled
Disabled
PCIe Ten Bit Tag Support
Enabled
Enabled
Enabled
Enabled
IOMMU
Enabled
Enabled
Enabled
Enabled
TSME
Auto
Auto
Auto
Auto
Note: The OPN Max values of TDP and PPT options are related to the CPU model. For more information about the OPN Max value, see Table 5.
Table 2 Memory and I/O Intensive Workloads and configuration template dependencies
Dependencies
Memory throughput intensive
Storage I/O intensive
NIC throughput intensive
NIC latency sensitive
SMT Control
Enabled
Enabled
Disabled
Disabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
BoostFmaxEn
Auto
Auto
Auto
Auto
Determinism Control
Auto
Manual
Manual
Manual
Determinism Enable
X
Power
Performance
Performance
TDP Control
Manual
Auto
Auto
Auto
TDP
OPN Max
X
X
X
PPT Control
Manual
Auto
Auto
Auto
PPT
OPN Max
X
X
X
CPPC
Auto
Auto
Auto
Auto
Enabled
Disabled
Disabled
Disabled
NPS1
NPS1
NPS1
NPS1
Memory Target Speed
DDR4800
DDR4800
DDR4800
DDR4800
Memory Interleaving
Enabled
Enabled
Enabled
Enabled
32Gbps
32Gbps
32Gbps
32Gbps
32Gbps
32Gbps
32Gbps
32Gbps
Auto
Auto
Auto
Manual
xGMI Max Link Width
X
X
X
2
X
X
X
Manual
X
X
X
Unforce
X
X
X
X
APBDIS
0
1
0
0
DF Cstates
Disabled
Disabled
Disabled
Disabled
Local APIC Mode
Auto
Auto
Auto
Auto
Auto
Static Target Link Speed (GEN5)
SRIOV
Disabled
Disabled
Disabled
Disabled
Enabled
Enabled
Enabled
Enabled
IOMMU
Enabled
Enabled
Enabled
Enabled
TSME
Auto
Auto
Auto
Auto
Table 3 Database and Analytics and configuration template dependencies
Dependencies
RDBMS optimized
Big data analytics optimized
AI optimized
IOT gateway
SMT Control
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Auto
Enabled
Enabled
Enabled
Auto
Enabled
Enabled
Enabled
Auto
Enabled
Enabled
Enabled
Auto
Enabled
Enabled
Enabled
Auto
Enabled
Enabled
Enabled
Auto
Enabled
BoostFmaxEn
Auto
Auto
Auto
Auto
Maximum IO Performance Mode
Determinism Control
Manual
Auto
Manual
Auto
Determinism Enable
Power
X
Performance
X
TDP Control
Manual
Auto
Auto
Auto
TDP
OPN Max
X
X
X
PPT Control
Manual
Auto
Auto
Auto
PPT
OPN Max
X
X
X
CPPC
Auto
Auto
Auto
Auto
Disabled
Disabled
Auto
Disabled
NPS1
NPS1
Auto
NPS1
Memory Target Speed
DDR4800
DDR4800
Auto
DDR4800
Memory Interleaving
Enabled
Enabled
Auto
Enabled
32Gbps
32Gbps
Auto
32Gbps
32Gbps
32Gbps
Auto
32Gbps
Auto
Auto
Auto
Auto
xGMI Max Link Width
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
APBDIS
1
0
Auto
0
DF Cstates
Disabled
Disabled
Disabled
Disabled
Local APIC Mode
Auto
Auto
Auto
Auto
Auto
Auto
Auto
Auto
SRIOV
Disabled
Disabled
Auto
Disabled
Enabled
Enabled
Auto
Enabled
IOMMU
Enabled
Enabled
Auto
Enabled
TSME
Auto
Auto
Auto
Auto
Global C-state Control
N/A
N/A
Disabled
N/A
Table 4 HPC and Telco settings
Dependencies
HPC optimized
OpenStack NFV
OpenStack for realtime Kernel
SMT Control
Disabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
BoostFmaxEn
Auto
Auto
Auto
Determinism Control
Manual
Manual
Manual
Determinism Enable
Performance
Performance
Performance
TDP Control
Manual
Auto
Auto
TDP
OPN Max
X
X
PPT Control
Manual
Auto
Auto
PPT
OPN Max
X
X
CPPC
Auto
Auto
Auto
Disabled
Disabled
Disabled
NPS4
NPS1
NPS1
Memory Target Speed
DDR4800
DDR4800
DDR4800
Memory Interleaving
Enabled
Enabled
Enabled
32Gbps
32Gbps
32Gbps
32Gbps
32Gbps
32Gbps
Auto
Auto
Auto
xGMI Max Link Width
X
X
X
X
X
X
X
X
X
X
X
X
APBDIS
0
0
0
DF Cstates
Disabled
Disabled
Disabled
Local APIC Mode
Auto
Auto
Auto
Auto
Auto
Auto
SRIOV
Disabled
Disabled
Disabled
Enabled
Enabled
Enabled
IOMMU
Enable
Enabled
Enabled
TSME
Auto
Auto
Auto
Note: The OPN Max value of TDP and PPT options is related to the CPU model. For more information about the OPN Max value, see Table 5.
Table 5 OPN MAX comparison table
CPU model
TDP value
PPT value
9654
400
400
9634
300
300
9554
400
400
9534
300
300
9474
400
400
9454
300
300
9374
400
400
9354
300
300
9334
240
240
9274
400
400
9254
240
240
9224
240
240
9174
400
400
9124
240
240
This chapter introduces the applicable scenarios and configuration instructions for each workload mode.
IMPORTANT
IMPORTANT:
In this document, the BIOS configuration solutions in different scenarios are general solutions. For special needs, configure it as needed.
BIOS provides the following configuration templates.
CPU intensive
CPU intensive mode is applicable to scenarios that require a large amount of processor computational power. Scientific calculations, graphics processing, and game servers all require high CPU performance. As a best practice, use a multi-core CPU with high-speed cache and high-performance memory to improve processing efficiency.
Java throughput intensive mode is applicable to Java applications that require high throughput data processing. Common scenarios include web services, large-scale data processing, and multimedia processing. It typically involves handling numerous requests and completing complex computations or data processing tasks.
Java latency sensitive mode is applicable to Java applications that require quick and accurate response to requests. It requires low-latency storage and network transmission mechanisms to support real-time use cases. It is commonly used in real-time data analysis, online gaming, healthcare, and other fields.
Power efficiency
Power efficiency mode is applicable to scenarios such as data centers, cloud computing, virtualization, and high-performance computing. Its main goal is to provide higher energy efficiency. It involves considering actual needs and hardware devices to maximize server energy efficiency.
Memory throughput intensive mode is applicable to scenarios that require high memory throughput. These scenarios involve extensive memory operations and data processing.
Common use cases include large-scale data processing, real-time data processing, and streaming and large-scale distributed systems. They require high-performance and high memory throughput hardware, as well as considerations for software architecture and technology.
Storage I/O intensive mode is applicable to scenarios that involve a large volume of data read and write operations. Common use cases include databases, video processing, and big data analytics. It requires efficient I/O systems to ensure high efficiency and accuracy in data processing.
NIC throughput intensive mode is applicable to scenarios that require high NIC throughput. These scenarios typically involve handling a large number of I/O operations, concurrent operations, and network operations.
Common use cases include data centers, large-scale cloud service providers, and video streaming, which require high-speed and high-throughput network cards to ensure fast data transmission and efficient network operations.
NIC latency sensitive mode is applicable to scenarios that have high requirements for network latency/response time. For example, real-time video content delivery, high-frequency trading systems, and online gaming, which require a quick response to requests within a very short time. Any delay in these scenarios can have a negative impact on the system.
RDBMS optimized
Relational Database Management Systems (RDBMS) are often a critical component of data centers. Efficient RDBMS services are crucial for organizations handling massive data like large enterprises, financial institutions, and healthcare facilities. RDBMS optimization improves server configuration to enhance system performance and reliability in these scenarios.
The application of big data analytics optimized mode requires meeting the demands of data storage, data processing, data visualization, and other aspects. By appropriately adjusting server parameters in line with the characteristics of this scenario, performance improvements can be achieved in the aspect of Big Data analytics processing.
IOT gateway
IoT gateway is a crucial component of the IoT architecture, commonly used for data exchange, data collection, data processing, and more between IoT devices and cloud platforms.
HPC optimized
HPC Optimized is a mode that is optimized for high-performance computing (HPC) applications. HPC is commonly used in scenarios involving intensive computations, such as handling multiple concurrent tasks. As a best practice, enable hyper-threading technology for better CPU performance in this HPC scenario.
OpenStack NFV
OpenStack NFV provides higher scalability, flexibility, security and integration for telecom networks. It virtualizes network functions using virtualization and cloud computing technologies, providing operators with an advanced network management tool to meet evolving market demands.
OpenStack for realtime kernel
OpenStack for realtime kernel mode uses real-time kernel to make applications on OpenStack more real-time. This helps applications to quickly respond and process real-time data, thereby improving system performance and usability. Additionally, real-time kernel ensures a higher quality application experience.
AI Optimized
The AI Optimized mode is used for application scenarios that perform artificial intelligence inference or training on large-scale computational resources to meet performance requirements.
Similar to the high performance computing template, this mode boosts server performance in scenarios involving artificial intelligence inference or training by locking the CPU to its highest performance level.
Custom
Custom mode utilizes the default BIOS settings or the values of the most recent configuration template. Users can customize various parameters based on this template. For specific description of each option, see the user guide for the default BIOS settings.
Configure the template
The options for the scenario configuration template is called Workload Profile Configuration and can be found on the Miscellaneous Configuration tab within the Advanced page. The specific steps for configuring this option are described below.
Access to the BIOS Setup page
1.     Connect the keyboard, mouse, and monitor to the server, or access the remote console through the HDM web interface. For more information about detailed instructions on launching the remote console, see HDM user guide.
2.     Start or restart the server. Once you access to the BIOS startup interface, press Del or Esc.
Figure 2 Starting BIOS
3.     Enter the startup password in the dialog box that opens.
Figure 3 Entering the startup password
4.     If a BIOS administrator and user password is set, you can select the login role first when entering the BIOS Setup page. Only the BIOS administrator role can configure BIOS.
Figure 4 Selecting the login role
5.     Enter the password corresponding to the selected role.
Figure 5 Entering the password
6.     Enter the BIOS Setup page.
Figure 6 Entering the BIOS Setup page
Access to the Miscellaneous Configuration page
Click Miscellaneous Configuratio under the Advanced tab, and click Enter.
Figure 7 Miscellaneous Configuration
Selet a configuration template
Click the drop-down box and select a required workload configuration template as needed.
Figure 8 Selecting a configuration template
Restart to take effect
After you complete the settings, press F4. Click OK in the dialog box that opens, and save the settings and exit the BIOS interface. The settings will take effect after you restart the server.
