H3C S5135S-EI Switch Series Installation Guide-6W101
HomeSupportSwitchesS5135 SeriesS5135S-EI SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C S5135S-EI Switch Series Installation Guide-6W101
01-text
01-text 3.25 MB
1 Product models and technical specifications
Product models
Table1-1 describes the S5135S switch series models.
Table1-1 S5135S switch series models
Model
Product code (PID)
Non-PoE switch models
S5135S-8T4S-EI-Q
LS-5135S-8T4S-EI-Q
S5135S-8T4XS-EI-Q
LS-5135S-8T4XS-EI-Q
S5135S-10T2S2X-EI-Q
LS-5135S-10T2S2X-EI-Q
S5135S-16T4S-EI-Q
LS-5135S-16T4S-EI-Q
S5135S-16T4X-EI-Q
LS-5135S-16T4X-EI-Q
S5135S-24S8T4X-EI
LS-5135S-24S8T4X-EI
S5135S-24T4S-EI-Q
LS-5135S-24T4S-EI-Q
S5135S-24T4X-EI-Q
LS-5135S-24T4X-EI-Q
S5135S-48S2T4X-EI
LS-5135S-48S2T4X-EI
S5135S-48ST4X-EI
LS-5135S-48ST4X-EI
S5135S-48T4S-EI-Q
LS-5135S-48T4S-EI-Q
S5135S-48T4X-EI-Q
LS-5135S-48T4X-EI-Q
PoE switch models
S5135S-8FP4S-EI-Q
LS-5135S-8FP4S-EI-Q
S5135S-8FP4XS-EI-Q
LS-5135S-8FP4XS-EI-Q
S5135S-16FP4S-EI
LS-5135S-16FP4S-EI
S5135S-16FP4X-EI
LS-5135S-16FP4X-EI
S5135S-24FP4S4X-EI
LS-5135S-24FP4S4X-EI
S5135S-24FP4T4S-EI
LS-5135S-24FP4T4S-EI
S5135S-24P4S-EI
LS-5135S-24P4S-EI
S5135S-24P4X-EI
LS-5135S-24P4X-EI
S5135S-48FP4S-EI
LS-5135S-48FP4S-EI
S5135S-48FP4X-EI
LS-5135S-48FP4X-EI
S5135S-48P4S-EI
LS-5135S-48P4S-EI
S5135S-48P4X-EI
LS-5135S-48P4X-EI
·     To obtain the purchase information, see the product data sheet at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch product lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/.
·     For information about product and software compatibility, see the release notes.
Technical specifications for non-PoE switch models
Table1-2 Technical specifications for non-PoE switch models (1)
Item
S5135S-8T4S-EI-Q
S5135S-8T4XS-EI-Q
S5135S-10T2S2X-EI-Q
S5135S-16T4S-EI-Q
S5135S-16T4X-EI-Q
Physical specifications
Dimensions (H × W × D, without package materials)
44 × 266 × 161 mm (1.73 × 10.47 × 6.34 in)
44 × 330 × 230 mm (1.73 × 12.99 × 9.06 in)
44 × 440 × 160 mm (1.73 × 17.32 × 6.30 in)
Dimensions (H × W × D, with package materials)
85 × 368 × 275 mm (3.35 × 14.49 × 10.83 in)
90 × 425 × 365 mm (3.54 × 16.73 × 14.37 in)
86 × 540 × 280 mm (3.39 × 21.26 × 11.02 in)
Weight
≤ 1.1 kg (2.43 lb)
≤ 1.1 kg (2.43 lb)
≤ 1.2 kg (2.65 lb)
≤ 2.0 kg (4.41 lb)
≤ 1.8 kg (3.97 lb)
Memory (RAM)
1 GB
Flash
512 MB
Port types and quantity
Console port
1 × serial console port
10/100/1000BASE-T autosensing Ethernet port
8
8
10 (The two highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively)
16
16
SFP port
4
2
2 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
4
N/A
SFP+ port
N/A
2
2
N/A
4
Power supply specifications
Power input
AC input
·     Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max voltage range: 90 VAC to 264 VAC @ 47 Hz to 63 Hz
Melting current of power supply fuse
3.15 A/250 V
3.15 A/250 V
2 A/250 V
2 A/250 V
10 A/250 V
Power consumption
Power consumption (static)
Data collection standard: no load
5 W
5 W
5 W
7 W
6 W
Power consumption (with typical configuration)
Data collection standard: fully configured with DAC cables or twisted pair cables, 30% loaded
8 W
8 W
10 W
13 W
13 W
Power consumption (fully configured)
Data collection standard: fully configured with transceiver modules or twisted pair cables, 100% loaded
11 W
16 W
16 W
19 W
17 W
Thermal consumption
Static thermal consumption
15 BTU/hr
15 BTU/hr
18 BTU/hr
21 BTU/hr
20 BTU/hr
Typical thermal consumption
28 BTU/hr
28 BTU/hr
35 BTU/hr
42 BTU/hr
43 BTU/hr
Maximum thermal consumption
37 BTU/hr
53 BTU/hr
55 BTU/hr
63 BTU/hr
57 BTU/hr
Heat dissipation
Heat dissipation method
Fanless, passive cooling
Mean Time Between Failure (MTBF) (Year)
141.230741
141.230741
136.689728
141.230741
145.53
Mean Time Between Failure (MTBF) (Hour)
1237181.29116
1237181.29116
1197402.01728
1237181.29116
1274860
Mean time to repair (MTTR) (Hour)
1
Availability
99.999919%
99.999919%
99.999916%
99.999919%
99.9999%
Environment specifications
Altitude
5000 m (16404.20 ft)
Operating temperature
–5°C to +45°C (23°F to 113°F)
Note:
The maximum acceptable temperature decreases by 0.33°C (32.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft).
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Relative humidity
5% RH to 95% RH, noncondensing
Product compliance
Product compliance
·     Safety standards
·     EMC standards
·     Environmental protection and eco-friendly standards
Table1-3 Technical specifications for non-PoE switch models (2)
Item
S5135S-24T4S-EI-Q
S5135S-24T4X-EI-Q
S5135S-48T4S-EI-Q
S5135S-48T4X-EI-Q
44 × 440 × 260 mm (1.73 × 17.32 × 10.24 in)
125 × 550 × 380 mm (4.92 × 21.65 × 14.96 in)
Weight
≤ 2 kg (4.41 lb)
≤ 2 kg (4.41 lb)
≤ 3.6 kg (7.94 lb)
≤ 3.6 kg (7.94 lb)
Memory (RAM)
1 GB
Flash
512 MB
Console port
24
24
48
48
SFP port
4
N/A
4
N/A
SFP+ port
N/A
4
N/A
4
Power input
AC input
10 A/250 V
10 A/250 V
3.15 A/250 V
3.15 A/250 V
Power consumption
6 W
6 W
13 W
13 W
16 W
16 W
30 W
31 W
18 W
21 W
37 W
42 W
Thermal consumption
20 BTU/hr
20 BTU/hr
45 BTU/hr
45 BTU/hr
52 BTU/hr
54 BTU/hr
103 BTU/hr
106 BTU/hr
61 BTU/hr
70 BTU/hr
127 BTU/hr
144 BTU/hr
Heat dissipation
122.1
122.12
114.784351
114.784351
1069633
1069748
1005510.91476
1005510.91476
1
Availability
99.9999%
99.9999%
99.999901%
99.999901%
Altitude
Note:
Storage temperature
Relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-4 Technical specifications for non-PoE models switch (3)
Item
S5135S-24S8T4X-EI
S5135S-48S2T4X-EI
S5135S-48ST4X-EI
44 × 440 × 360 mm (1.73 × 17.32 × 14.17 in)
125 × 562 × 550 mm (4.92 × 22.13 × 21.65 in)
Weight
≤ 5.4 kg (11.90 lb)
≤ 5.5 kg (12.13 lb)
≤ 5.5 kg (12.13 lb)
Memory (RAM)
1 GB
Flash
512 MB
Console port
8 (Each and its corresponding SFP port form a combo interface.)
2 (Each and its corresponding SFP port form a combo interface.)
24
SFP port
16 (The eight highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.)
48 (The two highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.)
24
SFP+ port
4
4
4
Power input
·     Removable AC power supply input (no support for HVDC input)
·     Removable DC power supply input
·     RPS input (RPS1600-A)
See "Removable power supplies"
Power consumption
Single AC: 11 W
Dual AC: 13 W
Single DC: 15 W
Dual DC: 22 W
Single AC: 19 W
Dual AC: 21 W
Single DC: 21 W
Dual DC: 29 W
Single AC: 17 W
Dual AC: 19 W
Single DC: 20 W
Dual DC: 27 W
Single AC: 12 W
Dual AC: 14 W
Single DC: 16 W
Dual DC: 23 W
Single AC: 20 W
Dual AC: 23 W
Single DC: 23 W
Dual DC: 31 W
Single AC: 27 W
Dual AC: 29 W
Single DC: 29 W
Dual DC: 29 W
Single AC: 35 W
Dual AC: 37 W
Single DC: 37 W
Dual DC: 44 W
Single AC: 54 W
Dual AC: 55 W
Single DC: 55 W
Dual DC: 61 W
Single AC: 47 W
Dual AC: 49 W
Single DC: 47 W
Dual DC: 53 W
Thermal consumption
Single AC: 37 BTU/hr
Dual AC: 44 BTU/hr
Single DC: 49 BTU/hr
Dual DC: 74 BTU/hr
Single AC: 62 BTU/hr
Dual AC: 69 BTU/hr
Single DC: 72 BTU/hr
Dual DC: 97 BTU/hr
Single AC: 57 BTU/hr
Dual AC: 64 BTU/hr
Single DC: 65 BTU/hr
Dual DC: 90 BTU/hr
Single AC: 41 BTU/hr
Dual AC: 48 BTU/hr
Single DC: 54 BTU/hr
Dual DC: 77 BTU/hr
Single AC: 68 BTU/hr
Dual AC: 76 BTU/hr
Single DC: 78 BTU/hr
Dual DC: 103 BTU/hr
Single AC: 91 BTU/hr
Dual AC: 99 BTU/hr
Single DC: 98 BTU/hr
Dual DC: 99 BTU/hr
Single AC: 118 BTU/hr
Dual AC: 127 BTU/hr
Single DC: 124 BTU/hr
Dual DC: 149 BTU/hr
Single AC: 184 BTU/hr
Dual AC: 187 BTU/hr
Single DC: 185 BTU/hr
Dual DC: 206 BTU/hr
Single AC: 158 BTU/hr
Dual AC: 167 BTU/hr
Single DC: 160 BTU/hr
Dual DC: 180 BTU/hr
Heat dissipation
Fan tray cooling
Fan tray cooling
Fan tray cooling
Ventilation aisles
Left to right (facing the front panel)
110.9488
70.8247
64.52
971911.8
620424.4
565195.3
1
Availability
99.9999%
99.9998%
99.9998%
Sound pressure level at 27°C (80.6°F)
35.2 dB
35.2 dB
35.2 dB
Altitude
Note:
Storage temperature
Operating relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
Technical specifications for PoE switch models
Table1-5 Technical specifications for PoE switch models (1)
Item
S5135S-8FP4S-EI-Q
S5135S-8FP4XS-EI-Q
S5135S-16FP4S-EI
S5135S-16FP4X-EI
S5135S-24FP4S4X-EI
S5135S-24FP4T4S-EI
44 × 266 × 160 mm (1.73 × 10.47 × 6.30 in)
135 × 555 × 385 mm (5.32 × 21.85 × 15.16 in)
Weight
≤ 1.5 kg (3.31 lb)
≤ 1.5 kg (3.31 lb)
≤ 2.3 kg (5.07 lb)
≤ 3.6 kg (7.94 lb)
≤ 3.6 kg (7.94 lb)
≤ 3.8 kg (8.38 lb)
Memory (RAM)
1 GB
Flash
512 MB
Console port
8
8
16
16
24 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
28 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
SFP port
4
2
4
N/A
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
SFP+ port
N/A
2
N/A
4
4
N/A
Power input
AC input
6.3 A/250 V
6.3 A/250 V
8 A/250 V
8 A/250 V
10 A/250 V
10 A/250 V
PoE power capacity
Maximum PoE power per port
30 W
Total PoE power
125 W
125 W
248 W
248 W
405 W
405 W
Power consumption
8 W
8 W
11 W
25 W
23 W
19 W
10 W
10 W
17 W
38 W
35 W
29 W
150 W
152 W
295 W
317 W
465 W
461 W
Thermal consumption
28 BTU/hr
28 BTU/hr
36 BTU/hr
86 BTU/hr
78 BTU/hr
65 BTU/hr
35 BTU/hr
35 BTU/hr
58 BTU/hr
130 BTU/hr
119 BTU/hr
99 BTU/hr
512 BTU/hr
519 BTU/hr
978 BTU/hr
1055 BTU/hr
1467 BTU/hr
1454 BTU/hr
Heat dissipation
Fan tray cooling
Fan tray cooling
Fan tray cooling
Fan tray cooling
Ventilation aisles
N/A
N/A
91.655825
91.655825
71.446818
111.9
69.3
72.3
802905.027
802905.027
625874.12568
980244
607068
633348
1
Availability
99.999875%
99.999875%
99.99984%
99.999898%
99.999836%
99.999842%
N/A
N/A
34.8dB
37.6dB
37.6dB
37.6dB
Altitude
Note:
Storage temperature
Relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-6 Technical specifications for PoE switch models (2)
Item
S5135S-24P4S-EI
S5135S-24P4X-EI
S5135S-48FP4S-EI
S5135S-48FP4X-EI
S5135S-48P4S-EI
S5135S-48P4X-EI
Weight
≤ 3.6 kg (7.94 lb)
≤ 3.6 kg (7.94 lb)
≤ 4.2 kg (9.26 lb)
≤ 4.2 kg (9.26 lb)
≤ 4.1 kg (9.04 lb)
≤ 4.1 kg (9.04 lb)
Memory (RAM)
1 GB
Flash
512 MB
Console port
24
24
48
48
48
48
SFP port
4
N/A
4
N/A
4
N/A
SFP+ port
N/A
4
N/A
4
N/A
4
Power input
AC input
8 A/250 V
8 A/250 V
16 A/250 V
16 A/250 V
10 A/250 V
10 A/250 V
PoE power capacity
30 W
Total PoE power
248 W
248 W
770 W
770 W
390 W
390 W
Power consumption
27 W
29 W
35 W
35 W
29 W
29 W
40 W
42 W
56 W
56 W
54 W
54 W
319 W
321 W
964 W
969 W
517 W
512 W
Thermal consumption
93 BTU/hr
99 BTU/hr
120 BTU/hr
120 BTU/hr
99 BTU/hr
99 BTU/hr
137 BTU/hr
144 BTU/hr
192 BTU/hr
192 BTU/hr
185 BTU/hr
185 BTU/hr
1062 BTU/hr
1069 BTU/hr
3187 BTU/hr
3204 BTU/hr
1696 BTU/hr
1679 BTU/hr
Heat dissipation
Fan tray cooling
Fan tray cooling
Fan tray cooling
Fan tray cooling
Fan tray cooling
Fan tray cooling
Ventilation aisles
103.8
100.1
59.2
58.2
59.5
58.2
909288
876876
518592
509832
521220
509832
1
Availability
99.99989%
99.999886%
99.999807%
99.999804%
99.999808%
99.999804%
37.6 dB
37.6 dB
32.9 dB
32.9 dB
37.6 dB
37.6 dB
Altitude
Note:
Storage temperature
Relative humidity
Product compliance
Product compliance
·     Safety standards
·     EMC standards
2 Chassis views
S5135S-8T4S-EI-Q
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) SFP port
(3) Console port
(4) USB port
(5) Mode button (Cloudnet management status LED)
(6) System status LED (SYS)
(7) Mode LED (MODE)
(8) Management Ethernet port LED (LINK/ACT)
(9) Management Ethernet port
(10) SFP port LED
(11) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-2 Rear panel
(1) Grounding screw
(2) AC power receptacle
S5135S-8T4XS-EI-Q
Figure2-3 Front panel
(2) SFP port
(3) SFP+ port
(4) Console port
(5) USB port
(6) Mode button (Cloudnet management status LED)
(7) System status LED (SYS)
(8) Mode LED (MODE)
(9) Management Ethernet port LED (LINK/ACT)
(10) Management Ethernet port
(11) SFP+ port LED
(12) SFP port LED
(13) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-4 Rear panel
(1) Grounding screw
S5135S-10T2S2X-EI-Q
Figure2-5 Front panel
(2) SFP port
(3) SFP+ port
(4) Console port
(5) USB port
(8) Mode LED (MODE)
(11) SFP+ port LED
(12) SFP port LED
Figure2-6 Rear panel
(1) Grounding screw
S5135S-16T4S-EI-Q
Figure2-7 Front panel
(2) SFP port
(3) Console port
(4) Management Ethernet port
(5) USB port
(8) Mode LED (MODE)
(10) SFP port LED
Figure2-8 Rear panel
(1) AC power receptacle
(2) Grounding screw
S5135S-16T4X-EI-Q
Figure2-9 Front panel
(2) SFP+ port
(3) Management Ethernet port
(4) Console port
(5) USB port
(7) Mode LED (MODE)
(8) Mode button (Cloudnet management status LED)
(10) SFP+ port LED
Figure2-10 Rear panel
(1) Grounding screw
S5135S-24S8T4X-EI
Figure2-11 Front panel
(1) SFP port
(2) 10/100/1000BASE-T autosensing Ethernet port
(3) SFP+ port
(4) Console port
(5) USB port
(7) Mode LED (MODE)
(8) Power supply 2 status LED (PWR2)
(9) Mode button (Cloudnet management status LED)
(10) Power supply 1 status LED (PWR1)
(11) Management Ethernet port LED (LINK/ACT)
(12) Management Ethernet port
(13) SFP+ port LED
(14) 10/100/1000BASE-T autosensing Ethernet port LED
(15) SFP port LED
Figure2-12 Rear panel
(1) Grounding screw
(2) Power supply 1 (PWR1)
(3) Power supply 2 (PWR2)
The S5135S-24S8T4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-12, two PSR75-12A AC power supplies are installed.
S5135S-24T4S-EI-Q
Figure2-13 Front panel
(2) SFP port
(3) Console port
(4) USB port
(5) System status LED (SYS)
(6) Mode LED (MODE)
(7) Mode button (Cloudnet management status LED)
(10) SFP port LED
Figure2-14 Rear panel
(1) Grounding screw
S5135S-24T4X-EI-Q
Figure2-15 Front panel
(2) SFP+ port
(3) Console port
(4) USB port
(6) Mode LED (MODE)
(10) SFP+ port LED
Figure2-16 Rear panel
(1) Grounding screw
S5135S-48S2T4X-EI
Figure2-17 Front panel
(1) SFP port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) 10/100/1000BASE-T autosensing Ethernet port
(4) USB port
(6) Mode LED (MODE)
(9) Power supply 1 status LED (PWR1)
(10) SFP+ port LED
(11) SFP+ port
(12) SFP port LED
Figure2-18 Rear panel
(1) Grounding screw
(2) Management Ethernet port LED (LINK)
(3) Management Ethernet port LED (ACT)
(4) Console port
(5) Power supply 1 (PWR1)
(6) Power supply 2 (PWR2)
(7) Management Ethernet port
The S5135S-48S2T4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-18, two PSR75-12A AC power supplies are installed.
S5135S-48ST4X-EI
Figure2-19 Front panel
(2) SFP port
(3) Management Ethernet port LED (LINK/ACT)
(5) Console port
(6) USB port
(8) Mode LED (MODE)
(9) System status LED (SYS)
(10) Power supply 2 status LED (PWR2)
(11) Power supply 1 status LED (PWR1)
(12) SFP+ port LED
(13) SFP+ port
(14) SFP port LED
(15) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-20 Rear panel
(1) Grounding screw
The S5135S-48ST4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-20, two PSR75-12A AC power supplies are installed.
S5135S-48T4S-EI-Q
Figure2-21 Front panel
(3) Mode LED (MODE)
(4) Console port
(5) USB port
(8) SFP port LED
(9) SFP port
(10) Management Ethernet port LED (LINK/ACT)
Figure2-22 Rear panel
(1) Grounding screw
S5135S-48T4X-EI-Q
Figure2-23 Front panel
(3) Mode LED (MODE)
(4) Console port
(5) USB port
(8) SFP+ port LED
(9) SFP+ port
Figure2-24 Rear panel
(1) Grounding screw
S5135S-8FP4S-EI-Q
Figure2-25 Front panel
(2) SFP port
(3) Console port
(4) USB port
(7) Mode LED (MODE)
(10) SFP port LED
Figure2-26 Rear panel
(1) Grounding screw
S5135S-8FP4XS-EI-Q
Figure2-27 Front panel
(2) SFP port
(3) SFP+ port
(4) Console port
(5) USB port
(8) Mode LED (MODE)
(11) SFP+ port LED
(12) SFP port LED
Figure2-28 Rear panel
(1) Grounding screw
S5135S-16FP4S-EI
Figure2-29 Front panel
(2) SFP port
(3) Console port
(5) USB port
(8) Mode LED (MODE)
(10) SFP port LED
Figure2-30 Rear panel
(2) Grounding screw
S5135S-16FP4X-EI
Figure2-31 Front panel
(2) SFP+ port
(3) Console port
(4) USB port
(7) Mode LED (MODE)
(10) SFP+ port LED
Figure2-32 Rear panel
(1) Grounding screw
S5135S-24FP4S4X-EI
Figure2-33 Front panel
(2) SFP port
(3) SFP+ port
(4) Console port
(5) USB port
(8) Mode LED (MODE)
(11) SFP+ port LED
(12) SFP port LED
Figure2-34 Rear panel
(1) Grounding screw
S5135S-24FP4T4S-EI
Figure2-35 Front panel
(2) SFP port
(3) Console port
(4) USB port
(7) Mode LED (MODE)
(10) SFP port LED
Figure2-36 Rear panel
(1) Grounding screw
S5135S-24P4S-EI
Figure2-37 Front panel
(2) SFP port
(3) Console port
(4) USB port
(7) Mode LED (MODE)
(10) SFP port LED
Figure2-38 Rear panel
(1) Grounding screw
S5135S-24P4X-EI
Figure2-39 Front panel
(2) SFP+ port
(3) Console port
(4) USB port
(7) Mode LED (MODE)
(10) SFP+ port LED
Figure2-40 Rear panel
(1) Grounding screw
S5135S-48FP4S-EI
Figure2-41 Front panel
(3) Mode LED (MODE)
(4) Console port
(5) USB port
(8) SFP port LED
(9) SFP port
Figure2-42 Rear panel
(1) Grounding screw
S5135S-48FP4X-EI
Figure2-43 Front panel
(3) Mode LED (MODE)
(4) Console port
(5) USB port
(8) SFP+ port LED
(9) SFP+ port
Figure2-44 Rear panel
(1) Grounding screw
S5135S-48P4S-EI
Figure2-45 Front panel
(3) Mode LED (MODE)
(4) Console port
(5) USB port
(8) SFP port LED
(9) SFP port
Figure2-46 Rear panel
(1) Grounding screw
S5135S-48P4X-EI
Figure2-47 Front panel
(3) Mode LED (MODE)
(4) Console port
(5) USB port
(8) SFP+ port LED
(9) SFP+ port
Figure2-48 Rear panel
(2) Grounding screw
3 Removable components
Some switch models use removable power supplies. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between switches and removable components
Removable component model
S5135S-24S8T4X-EI
S5135S-48ST4X-EI
S5135S-48S2T4X-EI
CA-70A12
Supported
PSR75-12A
Supported
PSR180-12D-B
Supported
One power supply can meet the power requirement of the switch. You can install two power supplies on the switch for 1+1 redundancy. The device supports installation of both an AC power supply and a DC power supply.
The removable components available for the switch are subject to change over time. For the most recent list of the removable components, see the release notes for the switch.
You can use the display device manuinfo power command to read the electrical label information of the power supplies. The CA-70A12 power supply does not support electrical label information reading.
4 Removable power supplies
70 W power supply (CA-70A12)
View
Figure4-1 CA-70A12 power supply view
Functions
The CA-70A12 is an AC and DC input and DC output power supply. It provides a maximum output of 70 W.
Table4-1 CA-70A12 power supply features
Feature
Protection function
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions.
Support for redundancy
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing.
Support for hot swapping
You can remove one of the power supplies in 1+1 redundancy when the switch is operating.
Table4-2 Technical specifications
Item
Specification
Dimensions (H × W × D, including the handle)
41.1 × 101.6 × 207 mm (1.62 × 4.00 × 8.15 in)
Weight
0.6 kg (1.32 lb)
Rated input voltage range
AC input: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
HVDC input: 240 VDC
Max input voltage range
AC input: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
HVDC input: 180 VDC to 320 VDC
Rated input current
N/A
Rated output current
5.83 A
Rated output voltage
12 V
Rated output power
70 W
10 A/250 V
75 W power supply (PSR75-12A)
View
Figure4-2 PSR75-12A power supply view
(1) Mounting screws
(2) Power input receptacle
(3) Latch
(4) Handle
Functions
The PSR75-12A is an AC and DC input and DC output power supply. It provides a maximum output of 75 W.
Table4-3 PSR75-12A power supply features
Feature
Protection function
Table4-4 Technical specifications
Item
Specification
Weight
0.72 kg (1.59 lb)
HVDC input: 240 VDC
Rated input current
N/A
6.3 A
12 V
Rated output power
75 W
3.15 A/250 V
180 W power supply (PSR180-12D-B)
View
Figure4-3 PSR180-12D-B power supply view
Functions
The PSR180-12D-B is a DC input and DC output power supply. It provides a maximum output of 180 W.
Table4-5 PSR180-12D-B power supply features (1)
Feature
Protection function
The power supply provides protection against output overvoltage, shortcircuit, current limiting, and overtemperature conditions.
You can remove one of the power supplies in 1+1 redundancy when the switch is operating. Before removing the power supply, disconnect the power supply from the external power supply system.
Table4-6 PSR180-12D-B power supply features (2)
Protection function
PSR180-12D-B
Protection state
Support for auto-recovery
Protection function
The power supply is locked and does not supply power.
Not supported.
Shortcircuit protection
Not supported.
Overcurrent protection
Not supported.
Overtemperature protection
The power supply does not supply power.
The power supply automatically restores power supply after the temperature decreases to an acceptable range.
After a power supply is locked, it cannot automatically restore power supply after the problems are resolved. Follow this procedure to restore the power supply operation:
1.     Disconnect the power cord from the external power supply system.
2.     Disconnect the power cord from the power supply and then reconnect it.
3.     Connect the power cord to the external power supply system.
Table4-7 Technical specifications
Item
Specification
101.6 × 41.1 × 177 mm (4.00 × 1.62 × 6.97 in)
Weight
0.8 kg (1.76 lb)
–48 VDC to –60 VDC
–36 VDC to –72 VDC
Rated input current
N/A
15 A
12 V
Rated output power
180 W
8 A/125 V
5 Ports and LEDs
Ports
Console port
Table5-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC running terminal emulation program
Compatible switch models
All switch models
The switch has one management Ethernet port on the front panel. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table5-2 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Transmission rate, duplex mode, and auto MDI/MDI-X
·     10 Mbps, half/full-duplex
·     100 Mbps, half/full-duplex
·     MDI/MDI-X, autosensing
Transmission medium
Category-5 or above twisted pair cable
Max transmission distance
100 m (328.08 ft)
Compliant standard
IEEE 802.3i
IEEE 802.3u
IEEE 802.3ab
Functions and services
Used for upgrading and managing applications and Boot ROM
All switch models
Table5-3 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     1000 Mbps, full-duplex
100 m (328.08 ft)
Transmission medium
Compliant standard
IEEE 802.3i
IEEE 802.3u
IEEE 802.3ab
All switch models
SFP port
Table5-4 SFP port specifications
Item
Specification
Available transceiver modules and cables
·     See FE SFP transceiver modules described in Table5-5.
·     See GE SFP transceiver modules and cables described in Table5-6.
S5135S-8FP4S-EI-Q, S5135S-8FP4XS-EI-Q, S5135S-8T4XS-EI-Q, S5135S-8T4S-EI-Q, S5135S-10T2S2X-EI-Q, S5135S-16T4S-EI-Q, S5135S-24T4S-EI-Q, S5135S-48T4S-EI-Q, S5135S-16FP4S-EI, S5135S-24FP4S4X-EI, S5135S-24FP4T4S-EI, S5135S-24P4S-EI, S5135S-24S8T4X-EI, S5135S-48FP4S-EI, S5135S-48P4S-EI, S5135S-48S2T4X-EI, S5135S-48ST4X-EI
·     To use the SFP-GE-T, SFP-GE-T-D, or transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the following switch models, make sure the ambient temperature does not exceed 40°C (104°F).
¡     S5135S-8T4XS-EI-Q
¡     S5135S-8T4S-EI-Q
¡     S5135S-16FP4S-EI
¡     S5135S-16T4S-EI-Q
¡     S5135S-10T2S2X-EI-Q
¡     S5135S-8FP4S-EI-Q
¡     S5135S-8FP4XS-EI-Q
¡     S5135S-48T4S-EI-Q
¡     S5135S-48S2T4X-EI
¡     S5135S-48ST4X-EI
¡     S5135S-24S8T4X-EI
¡     S5135S-24T4S-EI-Q
·     When you use the following transceiver modules on an S5135S-48S2T4X-EI or S5135S-48ST4X-EI switch, make sure the number of the transceiver modules does not exceed 30.
¡     SFP-GE-T.
¡     SFP-GE-T-D.
¡     Transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles).
·     Only the SFP ports on the following switch models support FE SFP transceiver modules:
¡     S5135S-48S2T4X-EI
¡     S5135S-48ST4X-EI
¡     S5135S-24S8T4X-EI
¡     S5135S-24FP4S4X-EI
¡     S5135S-24FP4T4S-EI
The SFP ports only support 100 Mbps speed autonegotiation and you cannot configure the ports to operate at 100 Mbps by using the speed 100 command keywords.
Table5-5 FE SFP transceiver modules available for the SFP ports
Central wavelength (nm)
Connector
Fiber type and diameter (µm)
SFP-FE-SX-MM1310-A
1310
LC
Multi-mode, 50/125
2 km (1.24 miles)
Multi-mode, 62.5/125
SFP-FE-LX-SM1310-A
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
Single-mode, 9/125
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
Single-mode, 9/125
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
15 km (9.32 miles)
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module.
Table5-6 GE SFP transceiver modules and cables available for the SFP ports
GE SFP transceiver module/cable
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz*km)
Max. transmission distance
SFP copper transceiver modules
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP optical transceiver modules
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500/400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
SFP+ port
Table5-7 SFP+ port specifications
Item
Specification
·     See 10GE SFP+ transceiver modules and cables described in Table5-8 and Table5-9
S5135S-8FP4XS-EI-Q, S5135S-8T4XS-EI-Q, S5135S-10T2S2X-EI-Q, S5135S-16T4X-EI-Q, S5135S-24T4X-EI-Q, S5135S-48T4X-EI-Q, S5135S-16FP4X-EI, S5135S-24FP4S4X-EI, S5135S-24P4X-EI, S5135S-24S8T4X-EI, S5135S-48FP4X-EI, S5135S-48P4X-EI, S5135S-48S2T4X-EI, S5135S-48ST4X-EI
¡     S5135S-8T4XS-EI-Q
¡     S5135S-48T4X-EI-Q
¡     S5135S-48S2T4X-EI
¡     S5135S-48ST4X-EI
¡     S5135S-24S8T4X-EI
¡     S5135S-24T4X-EI-Q
¡     S5135S-16T4X-EI-Q
¡     SFP-GE-T.
¡     SFP-GE-T-D.
Table5-8 10GE SFP+ transceiver modules available for the SFP+ ports
Connector
SFP+ copper transceiver module
SFP-10GE-T
N/A
RJ-45
Category 6A shielded twisted pair cable or category 7 twisted pair cable
N/A
30 m (98.43 ft)
N/A
Category 5e twisted pair cable
N/A
100 m (328.08 ft)
SFP+ optical transceiver module
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310
LC
Single-mode
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, and SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table5-9 10GE SFP+ copper and fiber cables available for the SFP+ ports
10GE SFP+ cable
Cable length
SFP+ copper cable
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure5-1 SFP+ cable
(1) Connector
(2) Pull latch
Combo interface
An S5135S-10T2S2X-EI-Q or S5135S-48S2T4X-EI switch provides two fixed combo interfaces on the front panel. An S5135S-24FP4S4X-EI or S5135S-24FP4T4S-EI switch provides four fixed combo interfaces on the front panel. An S5135S-24S8T4X-EI switch provides eight fixed combo interfaces on the front panel.
Each combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports operates at a time.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table5-10 System status LED description
LED mark
Status
SYS
Steady yellow
Boot ROM booting stage.
Steady green
Linux kernel booting stage, or the switch has started up correctly.
Flashing green (1 Hz)
Software image loading and decompressing stage, or software booting stage.
Steady red
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
Table5-11 Management Ethernet port LED description
LED mark
Status
ACT/LINK
Steady green
A link is present on the port.
Flashing green
The port is receiving or sending data.
Off
No link is present on the port.
Power supply status LED
The S5135S-24S8T4X-EI, S5135S-48S2T4X-EI, and S5135S-48ST4X-EI switches each provide two removable power supply slots on the rear panel. The power supply status LEDs on the front panel indicate the operating status of the power supplies.
Table5-12 Power supply status LED description
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or not powered on.
Off
No power supply is installed in the power supply slot.
Mode LED
The mode LED works in conjunction with the port LEDs to indicate the operating state of the ports and the switch.
·     The mode LED indicates the type of information that the port LEDs are showing.
·     You can use the mode button to change the indication of the mode LED. After you press the mode button for the mode LED to steady yellow, flashing green, or flashing yellow, the mode LED keeps that state for only 45 seconds and then turns steady green automatically.
·     You can use the mode button to change the indication of the mode LED. After you press the mode button for the mode LED to steady yellow, the LED for the uplink port turns off and is not displayed.
·     With the push-button mode enable command executed on the device, if you press the mode button for 5 to 10 seconds, the device will be deployed to Cloudnet or will be disconnected from Cloudnet based on the connection status with Cloudnet. Pressing the mode button for up to 5 seconds can change the port information for the port LED. Pressing the mode button for more than 10 seconds does not take effect, because the device is not managed by Cloudnet or has been disconnected from Cloudnet.
Table5-13 Mode LED description
LED mark
Status
MODE
Steady green
The port LEDs are showing link state of the ports.
Flashing green
The port LEDs are showing the PoE status of the ports.
Steady yellow
The port LEDs are showing the duplex status of the ports.
Flashing yellow
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 3 is steady green, the IRF member ID of the switch is 3.
Table5-14 Cloudnet management status LED description
LED status
Steady blue
The switch has been managed by Cloudnet.
Flashing blue (1 Hz)
The switch is being connected to Cloudnet.
Flashing blue (3 Hz)
Invalid action. The switch is not managed by Cloudnet or has been disconnected from Cloudnet.
Off
The switch is not connected to Cloudnet.
SFP/SFP+ port LED
Table5-15 SFP/SFP+ port LED description
LED status
Steady green
Flashing green
Off
·     No link is present on the port.
·     The mode LED is operating in PoE mode (available only for PoE switch models).
·     The mode LED is operating in duplex mode.
·     The mode LED is operating in IRF mode (available only for switch models that have a mode button).
10/100/1000BASE-T Ethernet port LED
The Ethernet port LEDs work in conjunction with the mode LED to indicate the operating state of the Ethernet ports and the switch from different aspects. Table5-16 describes the Ethernet port LEDs on a PoE switch. Table5-17 describes the Ethernet port LEDs on a non-PoE switch.
Table5-16 Ethernet port LED description for PoE switch models
Mode LED status (MODE)
Ethernet port LED status
Steady green (Link/Active mode)
Steady green
Flashing green
Off
Flashing green (PoE mode)
Steady green
PoE power supply is normal.
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or shortcircuit occurs.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Steady yellow
Steady green
The downlink port is operating in half duplex mode.
Flashing green
The downlink port is operating in full duplex mode.
Off
No link is present on the downlink port.
Flashing yellow (IRF mode)
Steady green
The Ethernet port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green, the IRF member ID of the switch is 5.
Table5-17 Ethernet port LED description for non-PoE switch models
Steady green
Flashing green
Off
Steady yellow
Steady green
Flashing green
Off
Steady green
6 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
Table6-1 Cooling system
Switch model
Fan tray type
Airflow direction
S5135S-8FP4S-EI-Q
S5135S-8FP4XS-EI-Q
S5135S-8T4XS-EI-Q
S5135S-8T4S-EI-Q
S5135S-10T2S2X-EI-Q
S5135S-16T4S-EI-Q
S5135S-16T4X-EI-Q
S5135S-24T4S-EI-Q
S5135S-24T4X-EI-Q
S5135S-48T4S-EI-Q
S5135S-48T4X-EI-Q
Fanless
Passive cooling
S5135S-16FP4S-EI
S5135S-16FP4X-EI
S5135S-24FP4S4X-EI
S5135S-24FP4T4S-EI
S5135S-24P4S-EI
S5135S-24P4X-EI
S5135S-24S8T4X-EI
S5135S-48FP4S-EI
S5135S-48FP4X-EI
S5135S-48P4S-EI
S5135S-48P4X-EI
S5135S-48S2T4X-EI
S5135S-48ST4X-EI
Fixed fan trays
From the left side to the right side
Figure6-1 Airflow through the S5135S-48S2T4X-EI chassis
