08-MPLS Configuration Guide
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration GuidesH3C S12500R Switch Router Series Configuration Guides(R52xx)-6W10208-MPLS Configuration Guide
10-MPLS OAM configuration
10-MPLS OAM configuration 290.65 KB
Configuring MPLS OAM
About MPLS OAM
MPLS Operation, Administration, and Maintenance (OAM) provides fault management tools for the following purposes:
·     MPLS data plane connectivity verification.
·     Data plane and control plane consistency verification.
·     Fault locating.
Fault management tools
The fault management tools include the following types:
·     On-demand tools—Tools that must be triggered manually, such as MPLS ping and MPLS tracert.
·     Proactive tools—Tools that are triggered by the system automatically, such as BFD for MPLS, and periodic MPLS tracert.
You can use these tools to detect and locate faults of LSPs.
MPLS ping
MPLS ping tests the connectivity of an LSP tunnel, MPLS TE tunnel, or SR-MPLS TE policy tunnel. At the ingress node, MPLS ping adds the label associated with a tunnel into an MPLS echo request and sends it to the egress node over the tunnel. The egress node processes the request and returns an MPLS echo reply to the ingress node. An MPLS echo reply with a success notification indicates that the tunnel is available for data forwarding. An MPLS echo reply with an error code indicates that the tunnel has failed.
MPLS tracert
MPLS tracert displays the path that an LSP tunnel, MPLS TE tunnel, or SR-MPLS policy tunnel travels from the ingress to the egress to locate errors on the tunnel. MPLS tracert consecutively sends MPLS echo requests along the LSP tunnel, with the TTL increasing from 1 to a specific value. Each hop along the tunnel returns an MPLS echo reply to the ingress due to TTL timeout so the ingress can collect information about each hop along the tunnel. This information allows you to locate the failed node or access information for each hop, for example, the label allocated by each downstream hop.
BFD for MPLS
BFD for MPLS uses a BFD session to proactively verify the connectivity of an LSP tunnel or an MPLS TE tunnel.
BFD can be implemented in control packet mode or echo packet mode.
BFD control packet mode
In control packet mode, BFD for MPLS performs the following operations:
1.     Establishes a BFD session between the ingress and egress of the tunnel to be inspected.
2.     Adds the label associated with the tunnel into a BFD control packet at the ingress.
3.     Sends the packet to the egress node over the tunnel.
4.     Determines the tunnel status according to the BFD control packet returned by the egress.
When BFD detects a connectivity failure, it triggers the pre-configured action, such as FRR or path protection switching, to ensure uninterrupted traffic forwarding.
A BFD session for LSP or MPLS TE tunnel connectivity verification can be established in one of the following modes:
·     Static mode—You manually specify the local and remote discriminators through command lines to establish the BFD session.
·     Dynamic mode—The system automatically runs MPLS ping to negotiate the discriminators to establish the BFD session.
In static mode, the egress node returns a BFD control packet to the ingress node through the reverse tunnel. If no reverse tunnel exists, the ingress node cannot receive the BFD control packet, resulting in a verification failure.
In dynamic mode, the egress node returns a BFD control packet to the ingress node through the reverse tunnel. If no reverse tunnel exists, the egress mode returns a BFD packet through IP routing.
Use the static mode to test the connectivity of a pair of LSPs or MPLS TE tunnels in opposite directions between two devices. Use the dynamic mode to test the connectivity of one LSP or MPLS TE tunnel from the local device to the remote device.
BFD echo packet mode
In echo packet mode, BFD for MPLS performs the following operations:
1.     Establishes a BFD session at the ingress of the tunnel to be inspected.
2.     Adds the label associated with the tunnel into a BFD echo packet at the ingress.
3.     Sends the echo packet to the egress node over the tunnel.
4.     Without establishing a BFD session at the egress node, makes the egress node forward the echo packet back to the ingress node.
5.     Determines the tunnel status according to whether the ingress node receives the BFD echo packet
SBFD for MPLS
SBFD for MPLS uses SBFD sessions to proactively verify the connectivity of LSP tunnels, MPLS TE tunnels, or SR-MPLS TE policy tunnels. When a tunnel fails, SBFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the backup tunnel.
SBFD is unidirectional and quicker than BFD. SBFD verifies the connectivity of one tunnel from the local device to the remote device.
SBFD for MPLS performs the following operations:
1.     Establishes an SBFD session between the ingress and egress nodes of the tunnel to be inspected.
2.     Adds the label associated with the tunnel into an SBFD control packet at the ingress (the initiator).
3.     Sends the control packet to the egress node (the reflector) over the tunnel.
4.     Determines the tunnel status according to whether the ingress node receives the SBFD control response from the egress node.
An SBFD session can be established only in static mode. You must specify the remote discriminator values for the SBFD sessions.
Periodic MPLS tracert
The periodic MPLS tracert feature automatically traces an LSP tunnel at intervals. It locates errors on the LSP tunnel, verifies the consistency of the data plane and control plane, and records the detected errors in system logs. You can check the logs to monitor LSP connectivity.
If both BFD and periodic MPLS tracert are configured for an LSP, and the periodic tracert feature detects a data plane and control plane inconsistency, the device performs the following tasks:
5.     Deletes the BFD session for the LSP.
6.     Re-establishes the BFD session based on the control plane.
Protocols and standards
·     RFC 4379, Detecting Multi-Protocol Label Switched (MPLS) Data Plane Failures
·     RFC 5085, Pseudowire Virtual Circuit Connectivity Verification (VCCV): A Control Channel for Pseudowires
·     RFC 5885, Bidirectional Forwarding Detection (BFD) for the Pseudowire Virtual Circuit Connectivity Verification (VCCV)
Verifying LSP connectivity
About LSP connectivity verification
To verify LSP connectivity, you can use one of the following methods:
·     Use the ping mpls ipv4 command or the tracert mpls ipv4 command to trigger LSP connectivity verification as needed.
·     Configure BFD or periodic MPLS tracert for the system to automatically verify LSP connectivity.
Performing MPLS ping for LSPs
Pinging the LSPs for an IPv4 prefix
To verify MPLS LSP connectivity for an IPv4 prefix, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * ipv4 ipv4-address mask-length [ destination start-address [ end-address [ address-increment ] ] ] [ fec-type { generic | isis | ldp | ospf } ]
Pinging the LSPs of the specified outgoing labels
To verify MPLS LSP connectivity by specifying the outgoing labels, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * out-labels out-label-value&<1-n> interface interface-type interface-number [ nexthop nexthop-address ]
Performing MPLS tracert for LSPs
Tracing the path of the LSPs for an IPv4 prefix
To trace the path that the LSPs for an IPv4 prefix take from the ingress node to the egress node, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | ddmap | fec-check ] * ipv4 ipv4-address mask-length [ destination start-address [ end-address [ address-increment ] ] ] [ fec-type { generic | isis | ldp | ospf } ]
Tracing the path of the LSPs of the specified outgoing labels
To trace the path that the LSPs of the specified outgoing labels take from the ingress node to the egress node, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | fec-check ]* out-labels out-label-value&<1-n> interface interface-type interface-number [ nexthop nexthop-address ]
Configuring BFD for LSPs (control packet mode)
To configure BFD for an LSP, configure both the local and remote devices as described in Table 1.
Table 1 Configurations on the local and remote devices
BFD session establishment mode
Node type
Execute the "mpls bfd enable" command?
Execute the "mpls bfd" command?
Configure the discriminator keyword?
Static mode
Local
Yes
Yes
Yes
Remote
Yes
Yes
Yes
Dynamic mode
Local
Yes
Yes
No
Remote
Yes
No
N/A
Follow these guidelines to configure BFD for an LSP tunnel:
·     To establish a static BFD session, ensure that the local and remote discriminators configured locally are identical with the remote and local discriminators configured on the remote device, respectively.
·     On a BFD session established in static mode, the ingress node and egress node both operate in active mode. On a BFD session established in dynamic mode, the egress node operates in active mode and the ingress node operates in passive mode. Executing the bfd session init-mode command on the ingress or egress node does not change the node's operating mode.
The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring BFD for an LSP, make sure a route is available on the remote device to reach the source address of the BFD session.
2.     Enable BFD for MPLS.
mpls bfd enable
By default, BFD for MPLS is disabled.
3.     (Optional.) Remove the Router Alert option in BFD packets.
undo bfd ip-router-alert
By default, the Router Alert option is carried in BFD packets for LSP connectivity verification.
Execute this command on the local device if the peer device cannot identify the Router Alert option in BFD packets.
This command takes effect only on BFD sessions that come up after this command is executed.
4.     (Optional.) Configure the deletion delay time for a dynamic passive-mode BFD session when the BFD session goes down.
mpls bfd passive delete-delay delay-time
By default, a dynamic passive-mode BFD session will be deleted in 60 seconds after it goes down.
5.     (Optional.) Set the delay time for the system to notify the application module of MPLS BFD session up events.
mpls bfd up-delay delay-time
By default, the delay time for the system to notify the application module of MPLS BFD session up events is 5 seconds.
6.     Configure BFD to verify LSP connectivity for an FEC.
¡     Use static BFD session mode:
mpls bfd dest-addr mask-length nexthop nexthop-address discriminator local local-id remote remote-id [ bgp-lsp | isis-srlsp | ldp-lsp | ospf-srlsp | static-lsp ] [ template template-name ]
¡     Use dynamic BFD session mode:
mpls bfd dest-addr mask-length nexthop nexthop-address [ nil-fec ] [ template template-name ] [ source-ip ipv4-address ]
mpls bfd dest-addr mask-length [ template template-name ] [ source-ip ipv4-address ]
By default, BFD is not configured to verify LSP connectivity for an FEC.
If you specify the next hop of an LSP, the device creates a BFD session for the LSP. If you do not specify a next hop, the device creates BFD sessions for all LSPs destined for the FEC.
You cannot specify the next hop of an LSP when configuring nested LSP connectivity verification.
Configuring BFD for LSPs (echo packet mode)
If both BFD and FRR are enabled for an LSP, set the BFD detection interval for LSP connectivity verification to be longer than that for FRR. Otherwise, the BFD session for LSP connectivity verification will be down during an FRR switchover.
·     The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring BFD for an LSP, make sure a route is available on the remote device to reach the source address of the BFD session.
·     Configure the bfd echo-source-ip command on the local device to specify a source IP address for echo packets.
mpls bfd enable
3.     (Optional.) Set the delay time for the system to notify the application module of MPLS BFD session up events.
4.     Configure the BFD echo packet mode to verify LSP connectivity.
mpls bfd dest-addr mask-length nexthop nexthop-address echo [ template template-name ] [ source-ip ipv4-address ]
mpls bfd dest-addr mask-length echo [ template template-name ] [ source-ip ipv4-address ]
By default, the BFD echo packet mode is not configured to verify LSP connectivity.
Configuring tunnel BFD for LSPs
The mpls bfd command can detect only the primary LSP failure. When the primary LSP fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup LSP. When both the primary and backup LSPs fail, the BFD detection mechanism fails. Traffic is lost until another mechanism detects the failures and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR).
To resolve this issue, you can execute the mpls tunnel-bfd command to configure tunnel BFD, which detects failures on the primary LSP and all the backup LSPs. When both the primary LSP and current backup LSP fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup LSP.
To configure tunnel BFD for an LSP, configure both the local and remote devices as described in Table 2.
Table 2 Configurations on the local and remote devices
Node type
Execute the "mpls tunnel-bfd" command?
Static mode
Local
Yes
Yes
Yes
Remote
Yes
Yes
Yes
Dynamic mode
Local
Yes
Yes
No
Remote
Yes
No
N/A
Follow these guidelines to configure tunnel BFD for an LSP tunnel:
The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring tunnel BFD for an LSP, make sure a route is available on the remote device to reach the source address of the BFD session.
Before configuring echo packet mode tunnel BFD, use the bfd echo-source-ip command on the local device to specify a source IP address for echo packets.
Configuring control packet mode tunnel BFD for LSPs
mpls bfd enable
6.     Configure control packet mode tunnel BFD to verify LSP connectivity for an FEC.
¡     To use a static BFD session:
mpls tunnel-bfd dest-addr mask-length discriminator local local-id remote remote-id [ bgp-lsp | isis-srlsp | ldp-lsp | ospf-srlsp | static-lsp ] [ template template-name ]
¡     To use a dynamic BFD session:
mpls tunnel-bfd dest-addr mask-length [ nil-fec ] [ template template-name ] [ source-ip ipv4-address ]
By default, tunnel BFD is not configured to verify LSP connectivity for an FEC.
Configuring echo packet mode tunnel BFD for LSPs
mpls bfd enable
4.     (Optional.) Set the delay time for the system to notify the application module of MPLS BFD session up events.
5.     Configure echo packet mode tunnel BFD to verify LSP connectivity for an FEC.
mpls tunnel-bfd dest-addr mask-length echo [ template template-name ] [ source-ip ipv4-address ]
Configuring SBFD for LSPs
Perform this task on the SBFD session initiator. On the reflector, you must configure the sbfd local-discriminator command. Make sure the remote discriminator value configured on the initiator is the same as a local discriminator value configured on the reflector. If the two ends do not have a matching discriminator value, the reflector does not send responses to the initiator. For more information about the sbfd local-discriminator command, see High Availability Command Reference.
The source address of the SBFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring SBFD for an LSP, make sure a route is available on the remote device to reach the source address of the SBFD session.
Configuring the initiator
mpls bfd enable
3.     (Optional.) Set the delay time for the system to notify the application module of MPLS SBFD session up events.
By default, the delay time for the system to notify the application module of MPLS SBFD session up events is 5 seconds.
4.     Configure SBFD to verify LSP connectivity for an FEC.
mpls sbfd dest-addr mask-length [ nexthop nexthop-address ] [ remote remote-id ] [ template template-name ] [ source-ip ipv4-address ]
By default, SBFD is not configured to verify LSP connectivity for an FEC.
Configuring periodic MPLS tracert for LSPs
mpls bfd enable
3.     Enable periodic LSP tracert for an FEC.
mpls periodic-tracert dest-addr mask-length [ -a source-ip | -exp exp-value | -h ttl-value | -m wait-time | -rtos tos-value | -t time-out | -u retry-attempt | fec-check ] *
By default, periodic LSP tracert is disabled.
Verifying MPLS TE tunnel connectivity
About MPLS TE tunnel connectivity verification
To verify MPLS TE tunnel connectivity, you can use one of the following methods:
·     Use ping mpls te command or the tracert mpls te command to trigger MPLS TE tunnel connectivity verification as needed.
·     Configure BFD for the system to automatically verify MPLS TE tunnel connectivity.
Performing MPLS ping for MPLS TE tunnels
To use MPLS ping to verify MPLS TE tunnel connectivity, execute the following command in any view:
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * te tunnel interface-number
Performing MPLS tracert for MPLS TE tunnels
To use MPLS tracert to trace an MPLS TE tunnel, execute the following command in any view:
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | fec-check ] * te tunnel interface-number
Configuring BFD for MPLS TE tunnels (control packet mode)
This feature, if specified with a backup BFD template, enables the device to create a BFD session for the tunnel's the primary and backup CRLSPs, respectively. When the primary CRLSP fails, BFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the backup CRLSP. If the two CRLSPs fail at the same time, the device puts the MPLS TE tunnel to down state so the tunnel does not receive traffic.
To run BFD on an MPLS TE tunnel, configure both the local and remote devices as described in Table 3.
Table 3 Configurations on the local and remote devices
Node type
Static mode
Local
Yes
Yes
Yes
Remote
Yes
Yes
Yes
Dynamic mode
Local
Yes
Yes
No
Remote
Yes
No
N/A
Follow these guidelines to configure BFD for an MPLS TE tunnel:
·     If both BFD and FRR are enabled for an MPLS TE tunnel, set the BFD detection interval for tunnel connectivity verification to be longer than that for FRR. Otherwise, the BFD session for MPLS TE tunnel connectivity verification will be down during an FRR switchover.
The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring BFD for an MPLS TE tunnel, make sure a route is available on the remote device to reach the source address of the BFD session.
mpls bfd enable
3.     (Optional.) Configure the deletion delay time for a dynamic passive-mode BFD session when the BFD session goes down.
5.     (Optional.) Enable the capability of MPLS BFD to trigger tunnel-down.
a.     Enter MPLS TE view.
mpls te
b.     Enable the capability of MPLS BFD to trigger tunnel-down.
mpls bfd trigger tunnel-down enable
By default, MPLS BFD is able to trigger tunnel-down.
If you configure static MPLS BFD in a primary/backup scenario, the device creates a BFD session for only the primary path. During a primary/backup switchover, the BFD session of the primary path might go down if a large number of MPLS TE tunnel interfaces exist, which results in traffic interruption. To resolve this issue, disable MPLS BFD from triggering tunnel-down. Then, the tunnel interface state remains unchanged when the BFD session of the MPLS TE tunnel interface goes down.
c.     Return to system view.
6.     Enter the view of an MPLS TE tunnel interface.
interface tunnel number mode mpls-te
7.     (Optional.) Configure the control packet mode BFD parameters for MPLS TE primary tunnel connectivity verification.
¡     Set the BFD detection time multiplier for the primary tunnel.
mpls bfd detect-multiplier value
By default, the BFD detection time multiplier is not set.
¡     Set the minimum interval for the primary tunnel to receive BFD packets.
mpls bfd min-receive-interval interval
By default, the minimum receive interval is not set.
¡     Set the minimum interval for the primary tunnel to transmit BFD packets.
mpls bfd min-transmit-interval interval
By default, the minimum transmit interval is not set.
8.     (Optional.) Configure the control packet mode BFD parameters for MPLS TE backup tunnel connectivity verification.
¡     Set the BFD detection time multiplier for the backup tunnel.
mpls bfd backup detect-multiplier value
¡     Set the minimum interval for the backup tunnel to receive BFD packets.
mpls bfd backup min-receive-interval interval
¡     Set the minimum interval for the backup tunnel to transmit BFD packets.
mpls bfd backup min-transmit-interval interval
9.     Configure the BFD control packet mode to verify MPLS TE tunnel connectivity.
¡     To use static BFD session mode:
mpls bfd discriminator local local-id remote remote-id [ template template-name ]
¡     To use dynamic BFD session mode:
mpls bfd [ template template-name ] [ backup-path template template-name ] [ source-ip ipv4-address ]
By default, the BFD control packet mode is not configured to verify MPLS TE tunnel connectivity.
If you specify a template for each CRLSP, specify greater interval settings for the template of the backup CRLSP than the primary CRLSP. This rule ensures that the BFD session for the new primary CRLSP is up after a primary/backup CRLSP switchover.
Configuring BFD for MPLS TE tunnels (echo packet mode)
·     The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring BFD for an MPLS TE tunnel, make sure a route is available on the remote device to reach the source address of the BFD session.
mpls bfd enable
4.     (Optional.) Enable the capability of MPLS BFD to trigger tunnel-down.
mpls te
5.     Enter the view of an MPLS TE tunnel interface.
6.     (Optional.) Configure the echo packet mode BFD parameters for MPLS TE primary tunnel connectivity verification.
7.     (Optional.) Configure the echo packet mode BFD parameters for MPLS TE backup tunnel connectivity verification.
8.     Enable the BFD echo packet mode to verify MPLS TE tunnel connectivity.
mpls bfd echo [ template template-name ] [ backup-path template template-name ] [ source-ip ipv4-address ]
mpls bfd reverse-lsp binding-sid label label-value [ template template-name ] [ backup-path [ template template-name ] ] [ source-ip ipv4-address ]
By default, the BFD echo packet mode is not configured to verify MPLS TE tunnel connectivity.
Configuring tunnel BFD for MPLS TE tunnels
In an MPLS TE CRLSP backup scenario, you can use the mpls bfd command to create a BFD session for the primary and backup CRLSPs, respectively. When the primary CRLSP fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup CRLSP. When both the primary and backup CRLSPs fail, the BFD detection mechanism fails. Traffic is lost until another mechanism detects the failure and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR) to take effect.
To resolve this issue, you can execute the mpls tunnel-bfd command to configure tunnel BFD, which detects failures on the primary CRLSP and all the backup CRLSPs. When both the primary CRLSP and the current backup CRLSP fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup CRLSP.
To run tunnel BFD on an MPLS TE tunnel, configure both the local and remote devices as described in Table 4.
Table 4 Configurations on the local and remote devices
Node type
Static mode
Local
Yes
Yes
Yes
Remote
Yes
Yes
Yes
Dynamic mode
Local
Yes
Yes
No
Remote
Yes
No
N/A
Follow these guidelines to configure tunnel BFD for an MPLS TE tunnel:
·     As a best practice to avoid tunnel flappings, disable MPLS BFD from triggering tunnel-down if you configure tunnel BFD for MPLS TE tunnels. To disable MPLS BFD from triggering tunnel-down, execute mpls bfd trigger tunnel-down disable in tunnel interface view or undo mpls bfd trigger tunnel-down enable in MPLS TE view.
The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring tunnel BFD for an MPLS TE tunnel, make sure a route is available on the remote device to reach the source address of the BFD session.
To enable the BFD echo packet mode, you must first use the bfd echo-source-ip command on the local device to specify a source IP address for BFD echo packets.
Configuring control packet mode tunnel BFD for an MPLS TE tunnel
mpls bfd enable
6.     (Optional.) Configure BFD session parameters for verifying the MPLS TE tunnel connectivity.
¡     Configure tunnel BFD detection timer multiplier.
mpls tunnel-bfd detect-multiplier value
By default, the tunnel BFD detection time multiplier is not set.
¡     Configure the minimum receive interval for tunnel BFD packets.
mpls tunnel-bfd min-receive-interval interval
7.     Configure control packet mode tunnel BFD to verify MPLS TE tunnel connectivity.
mpls tunnel-bfd discriminator local local-id remote remote-id [ template template-name ]
mpls tunnel-bfd [ template template-name ] [ source-ip ipv4-address ]
By default, tunnel BFD is not configured to verify MPLS TE tunnel connectivity.
If you specify templates for both BFD and tunnel BFD, specify greater interval settings for the BFD template than the tunnel BFD template. This rule ensures that the tunnel BFD session for MPLS TE tunnel is up after a primary/backup LSP switchover.
Configuring echo packet mode tunnel BFD for an MPLS TE tunnel
mpls bfd enable
4.     Enter the view of an MPLS TE tunnel interface.
5.     (Optional.) Configure BFD session parameters for verifying the MPLS TE tunnel connectivity.
6.     Configure echo packet mode tunnel BFD to verify MPLS TE tunnel connectivity.
mpls tunnel-bfd echo [ template template-name ] [ source-ip ipv4-address ]
mpls tunnel-bfd reverse-lsp binding-sid label label-value [ template template-name ] [ source-ip ipv4-address ]
Configuring SBFD for MPLS TE tunnels
Perform this task on the initiator of an SBFD session.
To configure SBFD for MPLS TE tunnels, specify a local discriminator by using the sbfd local-discriminator command on the reflector of the session. For more information about the sbfd local-discriminator command, see BFD configuration in High Availability Configuration Guide.
The remote discriminator specified on the initiator must be the same as the local discriminator specified on the reflector. Otherwise, the reflector will not respond to the initiator.
The source address of the SBFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring SBFD for an MPLS TE tunnel, make sure a route is available on the remote device to reach the source address of the SBFD session.
mpls bfd enable
5.     (Optional.) Configure SBFD session parameters for verifying the MPLS TE tunnel connectivity.
¡     Configure SBFD detection timer multiplier.
By default, the SBFD detection time multiplier is not set.
¡     Configure the minimum transmit interval for SBFD packets.
6.     (Optional.) Configure SBFD session parameters for verifying the backup MPLS TE tunnel connectivity.
¡     Configure SBFD detection timer multiplier for the backup tunnel.
¡     Set the minimum interval for the backup tunnel to transmit SBFD packets.
7.     Configure SBFD to verify MPLS TE tunnel connectivity.
mpls sbfd [ remote remote-id ] [ template template-name ] [ backup-path template template-name ] [ source-ip ipv4-address ]
By default, SBFD is not configured to verify MPLS TE tunnel connectivity.
mpls bfd enable
¡     Set the tunnel SBFD detection timer multiplier.
By default, the tunnel SBFD detection time multiplier is not set.
¡     Set the minimum transmit interval for tunnel SBFD packets.
¡     Set the SBFD detection timer multiplier for the backup tunnel.
mpls sbfd echo [ template template-name ] [ backup-path [ template template-name ] ] [ source-ip ipv4-address ]
mpls sbfd reverse-lsp binding-sid label label-value [ template template-name ] [ backup-path [ template template-name ] ] [ source-ip ipv4-address ]
Configuring tunnel SBFD for MPLS TE tunnels
About the task
In an MPLS TE network, you can use the mpls sbfd command to create an SBFD session for the primary and backup paths of the MPLS TE tunnel, respectively. When the primary path fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup path. When both the primary and backup paths fail, the SBFD detection mechanism fails. Traffic is lost until another mechanism detects the failure and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR) to take effect.
To resolve this issue, you can execute the mpls tunnel-sbfd command to configure tunnel SBFD, which detects failures on the primary path and all the backup paths. When both the primary path and the current backup path fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup path.
Perform this task on the initiator of the SBFD session.
When the SBFD control packet mode is used, an SBFD session can be established in static mode.
·     If you specify a remote discriminator in the mpls tunnel-sbfd command, the device uses the specified remote discriminator to establish a static SBFD session.
·     If you do not specify a remote discriminator in the mpls tunnel-sbfd command, the device uses the tunnel's remote IP address as the remote discriminator to establish a static SBFD session.
·     The remote discriminator specified by the mpls tunnel-sbfd command on the initiator must be the same as the local discriminator specified by the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not respond to the initiator. For more information about the sbfd local-discriminator command, see BFD commands in High Availability Command Reference.
·     As a best practice to avoid tunnel flappings, disable MPLS BFD from triggering tunnel-down if you configure tunnel SBFD for MPLS TE tunnels. To disable MPLS BFD from triggering tunnel-down, execute mpls bfd trigger tunnel-down disable in tunnel interface view or undo mpls bfd trigger tunnel-down enable in MPLS TE view.
The source address of the SBFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring tunnel SBFD for an MPLS TE tunnel, make sure a route is available on the remote device to reach the source address of the SBFD session.
Configuring control packet mode tunnel SBFD for an MPLS TE tunnel
mpls bfd enable
¡     Configure tunnel SBFD detection timer multiplier.
¡     Configure the minimum transmit interval for tunnel SBFD packets.
mpls tunnel-bfd min-transmit-interval interval
6.     Configure tunnel SBFD to verify MPLS TE tunnel connectivity.
mpls tunnel-sbfd [ remote remote-id ] [ template template-name ] [ source-ip ipv4-address ]
By default, tunnel SBFD is not configured to verify MPLS TE tunnel connectivity.
Configuring echo packet mode tunnel SBFD for an MPLS TE tunnel
mpls bfd enable
¡     Set the minimum receive interval for tunnel SBFD packets.
mpls tunnel-sbfd echo [ template template-name ] [ source-ip ipv4-address ]
mpls tunnel-sbfd reverse-lsp binding-sid label label-value [ template template-name ] [ source-ip ipv4-address ]
Verifying the SR-MPLS TE policy tunnel connectivity
About verifying SR-MPLS TE policy tunnel connectivity
To verify SR-MPLS TE policy tunnel connectivity, you can use one of the following methods:
·     Use the ping mpls sr-policy command or the tracert mpls sr-policy command to trigger connectivity verification for the SR-MPLS TE policy tunnel as needed.
·     Configure SBFD for SR-MPLS TE policy to automatically verify the tunnel connectivity. For more information about SBFD for SR-MPLS TE policy, see SR-MPLS TE policy in Segment Routing Configuration Guide.
Performing MPLS ping for SR-MPLS TE policy tunnels
To use MPLS ping to verify SR-MPLS TE policy tunnel connectivity, execute the following command in any view:
ping mpls [ -a { source-ip | source-ipv6 } | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * sr-policy { policy-name sr-policy-name | end-point { ipv4 ip-address | ipv6 ipv6-address } color color-value | binding-sid bsid }
If the SR TE policy contains multiple SID lists, the command verifies the connectivity to all SID lists.
Performing MPLS tracert for SR-MPLS TE policy tunnels
To use MPLS tracert to trace an ST-TE policy tunnel, execute the following command in any view:
tracert mpls [ -a { source-ip | source-ipv6 } | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v ] * sr-policy { policy-name sr-policy-name | end-point { ipv4 ip-address | ipv6 ipv6-address } color color-value | binding-sid bsid }
Verifying and maintaining MPLS OAM
·     Display BFD information for LSP tunnels.
display mpls bfd [ ipv4 ipv4-address mask-length | sr-policy [ end-point { ipv4 ip-address | ipv6 ipv6-address } color color-value | name sr-policy-name ] | te tunnel tunnel-number ]
·     Display SBFD information for LSP tunnels.
display mpls sbfd [ ipv4 ipv4-address mask-length | sr-policy [ end-point { ipv4 ip-address | ipv6 ipv6-address } color color-value | name sr-policy-name ] | te tunnel tunnel-number ]
MPLS OAM configuration examples
Example: Configuring BFD for LSP
Use LDP to establish an LSP from 1.1.1.9/32 to 3.3.3.9/32 and an LSP from 3.3.3.9/32 to 1.1.1.9/32. Use BFD to verify LSP connectivity.
Figure 1 Network diagram
By default, the device interfaces are in Administratively Down (ADM) state. Use the undo shutdown command in interface view to bring up the corresponding interfaces.
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure OSPF to ensure IP connectivity between the routers:
# Configure Router A.
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[RouterA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterA-ospf-1] quit
# Configure Router B.
<RouterB> system-view
[RouterB] ospf
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure Router C.
<RouterC> system-view
[RouterC] ospf
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
3.     Enable MPLS and LDP:
[RouterA] mpls lsr-id 1.1.1.9
[RouterA] mpls ldp
[RouterA-ldp] quit
[RouterA] interface hundredgige 1/0/1
[RouterA-HundredGigE1/0/1] mpls enable
[RouterA-HundredGigE1/0/1] mpls ldp enable
[RouterA-HundredGigE1/0/1] quit
[RouterB] mpls lsr-id 2.2.2.9
[RouterB] mpls ldp
[RouterB-ldp] quit
[RouterB] interface hundredgige 1/0/1
[RouterB-HundredGigE1/0/1] mpls enable
[RouterB-HundredGigE1/0/1] mpls ldp enable
[RouterB-HundredGigE1/0/1] quit
[RouterB] interface hundredgige 1/0/2
[RouterB-HundredGigE1/0/2] mpls enable
[RouterB-HundredGigE1/0/2] mpls ldp enable
[RouterB-HundredGigE1/0/2] quit
[RouterC] mpls lsr-id 3.3.3.9
[RouterC] mpls ldp
[RouterC-ldp] quit
[RouterC] interface hundredgige 1/0/2
[RouterC-HundredGigE1/0/2] mpls enable
[RouterC-HundredGigE1/0/2] mpls ldp enable
[RouterC-HundredGigE1/0/2] quit
4.     Enable BFD for MPLS, and configure BFD to verify LSP connectivity:
[RouterA] mpls bfd enable
[RouterA] mpls bfd 3.3.3.9 32
[RouterC] mpls bfd enable
[RouterC] mpls bfd 1.1.1.9 32
# Display BFD information for LSPs on Router A and Router C, for example, on Router A.
[RouterA] display mpls bfd
 Total number of sessions: 2, 2 up, 0 down, 0 init
 FEC Type: LSP
 FEC Info:
   Destination: 1.1.1.9
   Mask Length: 32
 NHLFE ID: -
 Local Discr: 513                    Remote Discr: 513
 Source IP: 1.1.1.9                  Destination IP: 3.3.3.9
 Session State: Up                   Session Role: Active
 Template Name: -
 FEC Type: LSP
 FEC Info:
   Destination: 3.3.3.9
   Mask Length: 32
 NHLFE ID: 1042
 Local Discr: 514                    Remote Discr: 514
 Source IP: 1.1.1.9                  Destination IP: 127.0.0.1
 Session State: Up                   Session Role: Passive
 Template Name: -
The output shows that two BFD sessions have been established between Router A and Router C. One session verifies the connectivity of the LSP from 3.3.3.9/32 to 1.1.1.9/32, and the other session verifies the connectivity of the LSP from 1.1.1.9/32 to 3.3.3.9/32.
