- 20-Network Management and Monitoring Configuration Guide
- 01-Ping and tracert configuration
- 02-System debugging configuration
- 03-NQA configuration
- 04-SNMP configuration
- 05-RMON configuration
- 06-NETCONF configuration
- 07-Process monitoring and maintenance configuration
- 08-Mirroring configuration
- 09-UCC configuration
- 10-SQA configuration
- 11-Packet capture configuration
- 12-Email Notification Service Configuration
| 09-UCC configuration | 126.96 KB |
Restrictions: Hardware compatibility with UCC
UCC configuration tasks at a glance
Configuring UCC for an audio or video application
Enabling UCC for an audio or video application
Configuring priority marking for traffic from an audio or video application
Dropping packets of an application in the specified subcategory
Configuring packet rate limit for an application in the specified subcategory
Specifying packet priorities for an application in the specified subcategory
Configuring UCC AP and AP group whitelists
Bulk upgrading APR signature libraries for APs
Configuring UCC
About UCC
Unified Communication and Collaboration (UCC) can identify packets of specific protocols and increase the priority of the packets accordingly to accelerate packet forwarding and improve user experience.
Support for this feature depends on the device model.
To configure UCC, perform the following tasks:
· Configuring UCC for an audio or video application
¡ Configuring UCC for an audio or video application
¡ Enabling UCC for an audio or video application
¡ Configuring priority marking for traffic from an audio or video application
· Dropping packets of an application in the specified subcategory
· Configuring packet rate limit for an application in the specified subcategory
· Specifying packet priorities for an application in the specified subcategory
· Configuring UCC AP and AP group whitelists
· Bulk upgrading APR signature libraries for APs
With UCC enabled for an audio or video application, the wireless service bound to the UCC profile will preferentially forward traffic from that application for wireless users that use the application to obtain higher-quality services.
1. Enter system view.
2. Create a UCC profile and enter its view.
ucc profile profile-name
3. Enable UCC for an audio or video application.
application app-name enable
By default, UCC is disabled for audio and video applications.
4. Return to system view.
5. Create a service template and enter its view.
wlan service-template service-template
6. Bind the service template to a UCC profile.
ucc-profile profile-name
Priority marking marks the priority of uplink traffic for an audio or video application and sends the priority to other service modules for them to process the traffic as configured.
3. Configure priority marking for traffic from an audio or video application.
application app-name flow-mark
By default, priority marking is not configured for traffic from audio and video applications.
With this feature configured, the device drops application packets specified by the client. In this case, the wireless service bound to the UCC profile cannot provide the corresponding application services.
Restirctions an guidelines
After configuring the device to drop all packets of an application in the specified subcategory, you cannot configure a specific application any more.
3. Configure the device to drop packets of an application in the specified application subcategory.
application-subcategory appsubcategory [ app app-name ] drop
By default, the device does not drop application packets.
With this feature enabled, the wireless service bound to the UCC profile restricts the packet rate of a specified application. In a scenario featuring a large traffic volume, to ensure the service quality of key applications, you can set low rate limits for non-key application packets and high rate limits for key application packets.
After specifying a rate limit for packets of all applications in a specified subcategory, you cannot configure a specific application any more.
3. Enable and specify a packet rate limit for an application in the specified subcategory.
application-subcategory appsubcategory [ app app-name ] rate-limit rate
By default, rate limit for application packets is disabled.
With this feature configured, the wireless service bound to the UCC profile modifies the DSCP and 802.1p priorities for packets of an application in a specified subcategory.
If you configure this feature with UCC enabled for an audio or video application for the same UCC profile, packets whose priorities are modified by this feature take precedence.
After specifying packet priorities for all applications in the specified subcategory, you cannot configure a specific application any more.
3. Specify packet priorities for an application in the specified subcategory.
application-subcategory appsubcategory [ app app-name ] remark { dot1p dot1p-value | dscp dscp-value }
By default, DSCP and 802.1p priorities for packets of an application in the subcategory are defined by the application itself.
Perform this task to allow only APs that belong to the UCC AP or AP group whitelist to collect and report UCC statistics to AC, reducing AC pressure from too many AP reports. In this way, pressure is also released for APs that do not belong to the UCC AP or AP group whitelist, because they no longer collect or report UCC statistics to AC.
Only UCC APs for audio and video traffic are restricted by the whitelist.
Procedure (AP whitelist)
2. Configure the UCC AP whitelist.
ucc whitelist ap ap-name
Procedure (AP group whitelist)
2. Configure the UCC AP group whitelist.
ucc whitelist ap-group group-name
For the audio and video feature of the UCC module to take effect on an AP, you also need to configure the DPI application identification feature. DPI application identification depends on the APR signature library. To ensure correct audio and video operation, upgrade the APR signature library on the AP in time. In a distributed AP network environment with AC + fit AP deployed, one AC might manage multiple APs. If the audio and video feature of the UCC module is enabled for multiple APs, use this command to upgrade the APR signature library for the APs in bulk.
2. Bulk upgrade APR signature libraries for APs.
apr wlan-signature update { file-name | default }
Display and maintenance commands for UCC
Command |
Display APR signature library version information on the AC. |
display apr wlan-signature library |
Display UCC profile information. |
display ucc profile [ profile-name ] |
Display UCC AP whitelist information. |
display ucc whitelist ap |
Display UCC AP group whitelist information. |
display ucc whitelist ap-group |
UCC configuration examples
Example: Configuring UCC for an audio or video application
As shown in Figure 1, local forwarding is enabled in the network. Configure UCC for the Tencent Meeting application on the AC to optimize traffic between the clients to provide high-quality services.
Network diagram
Assign IP addresses to interfaces, and make sure the devices can reach each other.
Make sure the APs can associate with the AC and the clients can obtain an IP address.
# Create UCC profile 1, and enable UCC for the Tencent Meeting application.
<AC> system-view
[AC] ucc profile 1
[AC-ucc-profile-1] application tencentmeeting enable
[AC-ucc-profile-1] quit
# Bind the UCC profile to service template service1.
[AC] wlan service-template service1
[AC-wlan-st-service1] ucc-profile 1
# Specify APs as the client traffic forwarder.
[AC-wlan-st-service1] client forwarding-location ap
[AC-wlan-st-service1] quit
# Bind the UCC profile to service template service2.
[AC] wlan service-template service2
[AC-wlan-st-service2] ucc-profile 1
[AC-wlan-st-service2] client forwarding-location ap
[AC-wlan-st-service2] quit
