01-RESTful configuration | 55.26 KB |
Configuring RESTful
About RESTful
The device provides the Representational State Transfer application programming interface (RESTful API). Based on this API, you can use programming languages such as Python, Ruby, or Java to write programs to perform the following tasks:
· Send RESTful requests to the device to pass authentication.
· Use RESTful API operations to configure and manage the device. RESTful API operations include Get, Put, Post, and Delete.
The device supports using HTTP or HTTPS to transfer RESTful packets.
Configuring RESTful over HTTP
1. Enter system view.
2. (Optional.) Specify the service port number for RESTful access over HTTP.
restful http port port-number
By default, the service port number for RESTful access over HTTP is 80.
3. Enable RESTful over HTTP.
restful http enable
By default, RESTful over HTTP is disabled.
4. Create a local user and enter local user view.
5. Configure a password for the local user.
6. (Optional.) Assign a user role to the local user.
The default user role is network-operator for a RESTful user.
7. Specify the HTTP service for the local user.
service-type http
By default, no service type is specified for a local user.
Configuring RESTful over HTTPS
2. (Optional.) Apply an SSL server policy to the RESTful access over HTTPS service.
restful https ssl-server-policy policy-name
By default, no SSL server policy is applied to the RESTful access over HTTPS service.
The RESTful access over HTTPS service will use the SSL server policy to enhance service security. For more information about SSL server policies, see SSL configuration in Security Configuration Guide.
3. (Optional.) Specify the service port number for RESTful access over HTTPS.
restful https port port-number
By default, the service port number for RESTful access over HTTPS is 443.
4. Enable RESTful over HTTPS.
restful https enable
By default, RESTful over HTTPS is disabled.
5. Create a local user and enter local user view.
6. Configure a password for the local user.
7. (Optional.) Assign a user role to the local user.
8. Specify the HTTPS service for the local user.
service-type https
