15-Security Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R-48Y8C&S12500R-48C6D Switch Router Command References(R52xx)-6W10215-Security Command Reference
07-Packet filter commands
07-Packet filter commands 150.02 KB
If you do not specify a VPN instance, whether the rule applies to VPN packets varies by feature. See the description for the feature that uses ACLs.
acl logging interval
Use acl logging interval to enable logging for packet filtering and set the interval.
Use undo acl logging interval to restore the default.
acl logging interval interval
The interval is 0. The device does not generate log entries for packet filtering.
interval: Specifies the interval at which log entries are generated and output. It must be a multiple of 5, in the range of 0 to 1440 minutes. To disable the logging, set the value to 0.
The logging feature is available for IPv4 or IPv6 ACL rules that have the logging keyword.
You can configure the ACL module to generate log entries for packet filtering and output them to the information center at the output interval. The log entry records the number of matching packets and the matched ACL rules. When the first packet of a flow matches an ACL rule, the output interval starts, and the device immediately outputs a log entry for this packet. When the output interval ends, the device outputs a log entry for subsequent matching packets of the flow.
For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Configure the device to generate and output packet filtering log entries every 10 minutes.
[Sysname] acl logging interval 10
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
acl trap interval
Use acl trap interval to enable SNMP notifications for packet filtering and set the interval.
Use undo acl interval to restore the default.
acl trap interval interval
undo acl trap interval
The interval is 0. The device does not generate SNMP notifications for packet filtering.
interval: Specifies the interval at which SNMP notifications are generated and output. It must be a multiple of 5, in the range of 0 to 1440 minutes. To disable SNMP notifications, set the value to 0.
The SNMP notifications feature is available for IPv4 or IPv6 ACL rules that have the logging keyword.
You can configure the ACL module to generate SNMP notifications for packet filtering and output them to the SNMP module at the output interval. The notification records the number of matching packets and the matched ACL rules. When the first packet of a flow matches an ACL rule, the output interval starts, and the device immediately outputs a notification for this packet. When the output interval ends, the device outputs a notification for subsequent matching packets of the flow.
For more information about SNMP, see Network Management and Monitoring Configuration Guide.
# Configure the device to generate and output packet filtering SNMP notifications every 10 minutes.
[Sysname] acl trap interval 10
display packet-filter
Use display packet-filter to display ACL application information for packet filtering.
display packet-filter { global | interface [ interface-type interface-number ] } [ inbound | outbound ] [ slot slot-number ]
global: Specifies all physical interfaces.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command displays ACL application information for packet filtering on all interfaces.  If you specify an Ethernet interface, you do not need to specify the slot slot-number option.
l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ]: Specifies an Ethernet service instance on an interface. The interface-type interface-number argument represents the interface type and number. The instance-id argument represents the ID of the Ethernet service instance, in the range of 1 to 4096. If you do not specify an interface, this command displays ACL application information for all Ethernet service instances on all interfaces. If you specify an interface but do not specify an Ethernet service instance, this command displays ACL application information for all Ethernet service instances on the specified interface.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
If neither the inbound keyword nor the outbound keyword is specified, this command displays ACL application information for packet filtering in both directions.
# Display ACL application information for inbound packet filtering on interface HundredGigE 1/0/1.
<Sysname> display packet-filter interface hundredgige 1/0/1 inbound
Interface: HundredGigE1/0/1
 Inbound policy:
  IPv4 ACL 2001, Share-mode
  IPv6 ACL 2002 (Failed)
  MAC ACL 4003
# Display ACL application information for inbound and outbound packet filtering on all physical interfaces.
<Sysname> display packet-filter global
Global:
 Inbound policy:
  IPv4 ACL 2001
  IPv6 ACL 2001
  MAC ACL 4001
  IPv4 default action: Deny (Failed)
  IPv6 default action: Deny (Failed)
  MAC default action: Deny
 Outbound policy:
  MAC ACL 4001
# Display ACL application information for inbound packet filtering for Ethernet service instance 1 on interface  HundredGigE 1/0/1.
<Sysname> display packet-filter l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound
Interface: hundredgige 1/0/1  Service Instance ID: 1
 Inbound policy:
  IPv4 ACL 2001
  MAC ACL 4003, Hardware-count (Failed)
Interface to which the ACL applies.
Global
ACL application for packet filtering on all physical interfaces.
Inbound policy
ACL used for filtering incoming traffic.
Outbound policy
ACL used for filtering outgoing traffic.
IPv4 ACL 2001
IPv4 basic ACL 2001 has been successfully applied.
The device has failed to apply IPv6 basic ACL 2002.
Share-mode
Sharing mode for QoS and ACL resources.
This field appears in the command output only if an ACL is applied with the share-mode keyword.
IPv4 default action
Packet filter default action for packets that do not match any IPv4 ACLs:
·     Deny—The default action deny has been successfully applied for packet filtering.
·     Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions.
·     Permit—The default action permit has been successfully applied for packet filtering.
IPv6 default action
Packet filter default action for packets that do not match any IPv6 ACLs:
MAC default action
Packet filter default action for packets that do not match any Layer 2 ACLs:
display packet-filter statistics
Use display packet-filter statistics to display packet filtering statistics.
display packet-filter statistics { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] [ brief ]
global: Displays the statistics for all physical interfaces.
ipv6: Specifies the IPv6 ACL type.
mac: Specifies the Layer 2 ACL type.
user-defined: Specifies the user-defined ACL type.
acl-number: Specifies an ACL by its number. The following are available value ranges:
·     2000 to 2999 for basic ACLs.
·     3000 to 3999 for advanced ACLs.
·     4000 to 4999 for Layer 2 ACLs.
·     5000 to 5999 for user-defined ACLs.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
brief: Displays brief statistics.
If you do not specify any parameters, this command displays packet filtering statistics for all ACLs.
To specify the IPv4 ACL type, do not specify the ipv6 keyword.
# Display packet filtering statistics for all ACLs on incoming packets of HundredGigE 1/0/1.
<Sysname> display packet-filter statistics interface hundredgige 1/0/1 inbound
 Inbound policy:
  IPv4 ACL 2001, Hardware-count
   From 2019-06-04 10:25:21 to 2019-06-04 10:35:57
   rule 0 permit source 2.2.2.2 0 (2 packets)
   rule 5 permit source 1.1.1.1 0 (Failed)
   rule 10 permit vpn-instance test (No resource)
   Totally 2 packets permitted, 0 packets denied
   Totally 100% permitted, 0% denied
  IPv6 ACL 2000
  MAC ACL 4000
   rule 0 permit
   From 2011-06-04 10:25:21 to 2011-06-04 10:35:57
   Totally 7 packets
   From 2011-06-04 10:25:41 to 2011-06-04 10:35:57
   Totally 0 packets
   From 2011-06-04 10:25:34 to 2011-06-04 10:35:57
   Totally 0 packets
# Display packet filtering statistics for all ACLs on incoming packets for Ethernet service instance 1 on HundredGigE 1/0/1.
<Sysname> display packet-filter statistics l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound
Interface: HundredGigE1/0/1  Service Instance ID: 1
 Inbound policy:
   Totally 2 packets 256 bytes permitted, 0 packets denied
  MAC ACL 4000
   rule 0 permit
  IPv6 ACL 2000
Ethernet service instance to which the ACL applies. HundredGigE1/0/1 is the interface where the Ethernet service instance resides.
Inbound policy
Outbound policy
IPv4 ACL 2001
IPv4 ACL 2002 (Failed)
The device has failed to apply IPv4 basic ACL 2002.
Hardware-count
ACL rule match counting in hardware has been successfully enabled.
The device has failed to enable counting ACL rule matches in hardware.
Start time and end time of the statistics.
2 packets
Two packets matched the rule.
This field is not displayed when no packets matched the rule.
No resource
Resources are not enough for counting matches for the rule. In packet filtering statistics, this field is displayed for a rule when resources are not sufficient for rule match counting.
The device has failed to apply rule 5.
Number of packets permitted and denied by the ACL.
Ratios of permitted and denied packets to all packets.
IPv4 default action
IPv6 default action
MAC default action
Totally 7 packets
The default action has been executed on seven packets.
reset packet-filter statistics
display packet-filter statistics sum
Use display packet-filter statistics sum to display accumulated packet filtering statistics for an ACL.
display packet-filter statistics sum { inbound | outbound } [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ brief ]
# Display accumulated packet filtering statistics for IPv4 basic ACL 2001 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2001
Sum:
 Inbound policy:
  IPv4 ACL 2001
# Display brief accumulated packet filtering statistics for IPv4 basic ACL 2000 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2000 brief
Sum:
 Inbound policy:
  IPv4 ACL 2000
Sum
Accumulated packet filtering statistics.
Inbound policy
Accumulated packet filtering statistics in the inbound direction.
Outbound policy
Accumulated packet filtering statistics in the outbound direction.
IPv4 ACL 2001
Accumulated packet filtering statistics of IPv4 basic ACL 2001.
2 packets
display packet-filter verbose
Use display packet-filter verbose to display ACL application details for packet filtering.
display packet-filter verbose { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] [ slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. The slot slot-number option is not available for an Ethernet interface.
If acl-number, name acl-name, ipv6, mac, or user-defined is not specified, this command displays application details of all ACLs for packet filtering.
# Display application details of all ACLs for inbound packet filtering on HundredGigE 1/0/1.
<Sysname> display packet-filter verbose interface hundredgige 1/0/1 inbound
 Inbound policy:
  IPv4 ACL 2001
   rule 0 permit
   rule 10 permit vpn-instance test (Failed)
  IPv6 ACL 2000
   rule 0 permit
  MAC ACL 4000
# Display application details of all ACLs for inbound packet filtering for Ethernet service instance 1 on HundredGigE 1/0/1.
<Sysname> display packet-filter verbose l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound
 Inbound policy:
  IPv4 ACL 2001
   rule 0 permit
  IPv6 ACL 2000
   rule 0 permit
  MAC ACL 4000
Global
ACL application details for packet filtering on all physical interfaces.
Inbound policy
Outbound policy
IPv4 ACL 2001
Hardware-count
IPv4 default action
IPv6 default action
MAC default action
packet-filter
Use packet-filter to apply an ACL to an interface to filter packets.
Use undo packet-filter to remove an ACL from an interface.
packet-filter [ ipv6 | mac | user-defined ] { acl-number | name acl-name } { inbound | outbound } [ hardware-count ] [ share-mode ]
undo packet-filter [ ipv6 | mac | user-defined ] { acl-number | name acl-name } { inbound | outbound }
No ACL is applied to an interface to filter packets.
Interface view
inbound: Filters incoming packets.
outbound: Filters outgoing packets.
hardware-count: Enables counting ACL rule matches performed in hardware. If you do not specify this keyword, rule matches for the ACL are not counted in hardware.
share-mode: Applies the ACL in sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all interfaces of the same type on an interface card with the same ACL applied in one direction share one ACL resource.
When specifying an ACL, follow these restrictions and guidelines:
·     If the specified ACL does not exist or does not have any rules, the ACL will not be referenced.
·     If the vpn-instance vpn-instance-name option is specified in an ACL rule, the rule takes effect only on VPN packets. If the vpn-instance vpn-instance-name option is not specified in an ACL rule, the rule takes effect only on non-VPN packets.
The hardware-count keyword in this command enables match counting in hardware for all rules in an ACL, and the counting keyword in the rule command enables match counting specific to rules.
To disable ACL rule match counting in hardware when resources are insufficient, you must execute the undo packet-filter command and then re-execute the packet-filter command without specifying the hardware-count keyword.
To disable ACL rule match counting in hardware when resources are sufficient, you can directly re-execute the packet-filter command without specifying the hardware-count keyword.
You can apply a maximum of four ACLs to the same direction of an interface: one IPv4 ACL, one IPv6 ACL, one Layer 2 ACL, and one user-defined ACL.
If you specify the share-mode keyword when applying an ACL to an interface, follow these restrictions and guidelines:
·     You can apply multiple ACLs to one direction of an interface. However, you can apply only one ACL with the share-mode keyword specified to one direction of an interface.
·     You cannot change the sharing mode dynamically after an ACL is applied to an interface. To change the sharing mode for an applied ACL, you must remove the ACL from the interface, and then reapply the ACL with or without the share-mode keyword specified.
·     You cannot apply a QoS policy or PBR policy with the share-mode keyword to the same direction of an interface. For information about applying a QoS policy to an interface, see QoS in ACL and QoS Configuration Guide. For information about applying a PBR policy to an interface, see policy-based routing in Layer 3—IP Routing Configuration Guide.
In a scenario with a mixture of Layer 2 and Layer 3 traffic, when you apply ACLs to the outbound direction of a VLAN interface for packet filtering, the outbound traffic of Layer 3 aggregate subinterfaces with the same VLAN will also be matched.
# Apply IPv4 basic ACL 2001 to filter incoming traffic on HundredGigE 1/0/1, and enable counting ACL rule matches performed in hardware.
[Sysname-HundredGigE1/0/1] packet-filter 2001 inbound hardware-count
# Apply IPv4 basic ACL 2001 in sharing mode to filter outgoing traffic on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] packet-filter 2001 outbound share-mode
packet-filter default deny
Use packet-filter default deny to set the packet filtering default action to deny. The packet filter denies packets that do not match any ACL rule.
Use undo packet-filter default deny to restore the default.
The packet filtering default action is permit. The packet filter permits packets that do not match any ACL rule.
The packet filter applies the default action to all ACL applications for packet filtering. The default action appears in the display command output for packet filtering.
# Set the packet filter default action to deny.
[Sysname] packet-filter default deny
Use packet-filter global to apply an ACL to filter packets globally.
Use undo packet-filter global to remove an ACL for global packet filtering.
packet-filter [ ipv6 | mac | user-defined ] { acl-number | name acl-name } global { inbound | outbound } [ hardware-count ]
undo packet-filter [ ipv6 | mac | user-defined ] { acl-number | name acl-name } global { inbound | outbound }
No ACL is applied to filter packets globally.
To disable the extended mode or ACL rule match counting in hardware when resources are insufficient, you must execute the undo packet-filter command and then re-execute the packet-filter command without specifying the hardware-count keyword.
To disable the extended mode or ACL rule match counting in hardware when resources are sufficient, you can directly re-execute the packet-filter command without specifying the hardware-count keyword.
# Apply IPv4 basic ACL 2001 to filter incoming traffic on all physical interfaces, and enable counting ACL rule matches performed in hardware.
[Sysname] packet-filter 2001 global inbound hardware-count
Use reset packet-filter statistics to clear the packet filtering statistics.
reset packet-filter statistics { global | interface [ interface-type interface-number ] } { inbound | outbound } [ ipv6 | mac | user-defined ] { acl-number | name acl-name }
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command clears packet filtering statistics for all interfaces.
l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ]: Specifies an Ethernet service instance on an interface. The interface-type interface-number argument represents the interface type and number. The instance-id argument represents the ID of the Ethernet service instance, in the range of 1 to 4096. If you do not specify an interface, this command clears packet filtering statistics for all Ethernet service instances on all interfaces. If you specify an interface but do not specify an Ethernet service instance, this command clears packet filtering statistics for all Ethernet service instances on the specified interface.
If acl-number, name acl-name, ipv6, mac, or user-defined is not specified, this command clears the packet filtering statistics for all ACLs.
# Clear IPv4 basic ACL 2001 statistics for inbound packet filtering on HundredGigE 1/0/1.
<Sysname> reset packet-filter statistics interface hundredgige 1/0/1 inbound 2001
# Clear IPv4 basic ACL 2001 statistics for inbound packet filtering for Ethernet service instance 1 on HundredGigE 1/0/1.
<Sysname> reset packet-filter statistics l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound 2001
