02-QoS commands | 663.85 KB |
display qos policy control-plane
display qos policy control-plane pre-defined
qos apply policy (Ethernet service instance view, interface view, control plane view)
reset qos policy control-plane
QoS and ACL resource usage displaying commands
Traffic policing, GTS, and rate limit commands
qos car percent (interface view)
Congestion management commands
display qos queue sp interface
display qos queue wrr interface
qos wrr { byte-count | weight }
display qos queue wfq interface
qos wfq { byte-count | weight }
Queue scheduling profile commands
display qos qmprofile configuration
display qos qmprofile interface
qos wred queue weighting-constant
Queue-based accounting commands
QoS policy commands
Traffic class commands
description
Use description to configure a description for a traffic class.
Use undo description to delete the description of a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
display traffic classifier
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display all user-defined traffic classes.
User-defined classifier information:
Classifier: 1 (ID 100)
Operator: AND
Rule(s) :
If-match acl 2000
Classifier: 2 (ID 101)
Operator: AND
Rule(s) :
If-match protocol ipv6
Classifier: 3 (ID 102)
Operator: AND
Rule(s) :
-none-
Classifier |
Traffic class name and its match criteria. |
Operator |
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria. |
Rule(s) |
Match criteria. |
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option |
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ inner ] |
Matches an ACL. The value range for the acl-number argument is as follows: · 2000 to 3999 for IPv4 ACLs. · 2000 to 3999 for IPv6 ACLs. · 4000 to 4999 for Layer 2 MAC ACLs. · 5000 to 5999 for user-defined ACLs. The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all. If you use the rule [ rule-id ] { deny | permit } command to match packets, the inner keyword matches the inner header information of VXLAN packets. If you do not specify this keyword, the ACL matches the header information of non-encapsulated packets or the outer header information of VXLAN packets. If you use the rule [ rule-id ] { deny | permit } vxlan command to match inner header information of VXLAN packets, you cannot specify the inner keyword in the if-match acl command. If you do not specify a VPN instance, whether the rule applies to VPN packets varies by feature. See the description for the feature that uses ACLs. |
any |
Matches all packets. |
control-plane protocol protocol-name&<1-8> |
Matches control plane protocols. The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3. |
control-plane protocol-group protocol-group-name |
Matches a control plane protocol group. The protocol-group-name argument can be critical, exception, important, management, monitor, normal, or redirect. |
customer-dot1p dot1p-value&<1-8> |
Matches 802.1p priority values in inner VLAN tags of double-tagged packets. The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7. |
customer-vlan-id vlan-id-list |
Matches VLAN IDs in inner VLAN tags of double-tagged packets. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. |
destination-mac mac-address |
Matches a destination MAC address. This option takes effect only on Ethernet interfaces. |
[ ipv6 ] dscp dscp-value&<1-8> |
Matches DSCP values. If you specify the ipv6 keyword, this option matches the DSCP value of only IPv6 packets. If you do not specify the ipv6 keyword, this option matches the DSCP value of both IPv4 packets and IPv6 packets. The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5. This option matches only IPv4 packets. To match IPv6 packets by DSCP value, configure an IPv6 advanced ACL and reference the ACL by using the if-match acl ipv6 { acl-number | name acl-name } command. |
forwarding-layer { bridge | route } |
Matches untagged packets. · bridge—Matches Layer 2 untagged packets. · route—Matches Layer 3 untagged packets. |
inbound-interface interface-type interface-number |
Matches an input interface specified by its type and number. |
[ ipv6 ] ip-precedence ip-precedence-value&<1-8> |
Matches IP precedence values. If you specify the ipv6 keyword, this option matches the IP precedence value of only IPv6 packets. If you do not specify the ipv6 keyword, this option matches the IP precedence value of both IPv4 packets and IPv6 packets. The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7. |
mpls { l2vpn | l3vpn } |
Matches the MPLS VPN type: · l2vpn—Matches L2VPN packets. · l3vpn—Matches L3VPN packets. |
protocol protocol-name |
Matches a protocol. The protocol-name argument can be ip or ipv6. |
qos-local-id local-id-value |
Matches a local QoS ID in the range of 1 to 1000. |
rocev2 { opcode opcode-value | dst-qpair dst-qpair-value | src-qpair src-qpair-value | nack nack-value } * |
Matches an RoCEv2 protocol: · opcode opcode-value: Matches the OpCode field in the BTH header. The opcode-value argument specifies an OpCode value in the range of 0 to 255. · dst-qpair dst-qpair-value: Matches the Destination QP field in the BTH header. The dst-qpair-value argument specifies a destination QP value in the range of 0 to 16777215. · src-qpair src-qpair-value: Matches the Source QP field in the DETH header. The src-qpair-value argument specifies a source QP value in the range of 0 to 16777215. · nack nack-value: Matches the lowest five bits in the Syndrome field in the NACK packets. The nack-value argument specifies a value for the lowest five bits in the Syndrome field, in the range of 0 to 31. |
sdwan-tte site-id site-id [ device-id device-id [ interface-id interface-id ] ] |
Matches transport tunnel endpoint (TTE) information in SDWAN. · site-id site-id: Specifies a site ID in the range of 1 to 65535. · device-id device-id: Specifies a device ID in the range of 1 to 255. If you do not specify a device ID, all devices in the site can be matched. · interface-id interface-id: Specifies an interface ID in the range of 1 to 255. If you do not specify an interface ID, all SDWAN tunnel interface on the device can be matched. For more information about SDWAN, see SDWAN Configuration Guide. |
service-dot1p dot1p-value&<1-8> |
Matches 802.1p priority values in outer VLAN tags. The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7. |
service-vlan-id vlan-id-list |
Matches VLAN IDs in outer VLAN tags. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. You can use this option to match single-tagged packets. |
source-mac mac-address |
Matches a source MAC address. This option takes effect only on Ethernet interfaces. |
traffic-type { unicast | unknown-unicast | broadcast | multicast } |
Matches the packet type: · unicast—Matches Layer 2 and Layer 3 known unicast packets. · unknown-unicast—Matches Layer 2 and Layer 3 unknown unicast packets. · broadcast—Matches broadcast packets. · multicast—Matches multicast packets. For a traffic class to match multiple packet types, you must specify the OR operator when creating the class. |
vlan-tag { double | none | single } |
Matches the VLAN tagging mode: · double—Matches double-tagged packets. · none—Matches packets with no tags. · single—Matches single-tagged packets. |
vpn-instance vpn-name |
Matches a VPN instance. |
vxlan { any | vxlan-id } |
Matches a VXLAN ID. |
Table 3 Available system-defined control plane protocols
Protocol |
default |
Protocol packets other than the following packet types |
arp |
ARP packets |
arp-snooping |
ARP snooping packets |
bfd |
BFD packets |
bgp |
BGP packets |
bgp4+ |
IPv6 BGP packets |
dhcp |
DHCP packets |
dhcp-snooping |
DHCP snooping packets |
dhcp6 |
IPv6 DHCP packets |
dldp |
DLDP packets |
dot1x |
802.1X packets |
drcp |
DRCP packets |
hoplimit-expires |
Hop-limit expire packets |
icmp |
ICMP packets |
icmp6 |
ICMPv6 packets |
igmp |
IGMP packets |
ip-option |
IPv4 packets with the Options field |
ipv6-option |
IPv6 packets with the Options field |
isis |
IS-IS packets |
lacp |
LACP packets |
lldp |
LLDP packets |
mvrp |
MVRP packets (including GVRP packets) |
nd |
ND packets |
oam |
OAM packets |
ospf-multicast |
OSPF multicast packets |
ospf-unicast |
OSPF unicast packets |
ospf3-multicast |
OSPFv3 multicast packets |
ospf3-unicast |
OSPFv3 unicast packets |
pim-multicast |
PIM multicast packets |
pim-unicast |
PIM unicast packets |
pim6-multicast |
IPv6 PIM multicast packets |
pim6-unicast |
IPv6 PIM unicast packets |
radius |
RADIUS packets |
snmp |
SNMP packets |
ssh |
SSH packets |
stp |
STP packets |
tacacs |
TACACS packets |
telnet |
Telnet packets |
ttl-expires |
TTL expire packets |
vrrp |
VRRP packets |
vrrp6 |
IPv6 VRRP packets |
In a traffic class with the logical OR operator, you can configure multiple if-match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
· You can specify up to eight values for any of the following match criteria in one if-match command:
¡ Control plane protocol.
¡ 802.1p priority.
¡ DSCP.
¡ IP precedence.
¡ MPLS EXP.
¡ MPLS label.
¡ VLAN ID.
· If a packet matches one of the specified values, it matches the if-match command.
· To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
To use an ACL match criterion, the ACL must already exist.
To match the outer header information of VXLAN packets, you can directly use the options supported by an if-match command (excluding if-match acl).
To match the inner header information of VXLAN packets by using an ACL, perform one of the following tasks:
· Use the rule vxlan command to specify the inner fields to match. The used ACL must be an IPv4 advanced ACL or Layer 2 ACL.
· Use the if-match vxlan { any | vxlan-id } command in a traffic class with the AND operator, and Use the rule command without the vxlan keyword in the same traffic class.
For an IPv4 advanced ACL, only the inner 5-tuple is supported.
If a traffic class includes two ACL match criteria that match inner and outer packet information, follow these restrictions:
· Each ACL can contain only one rule.
· The rule in the ACL for matching the outer packet information can match only source IP addresses.
To match the 5-tuple and DSCP priority of MPLS packets, use the following if-match commands in a traffic class with the AND operator:
1. if-match mpls { l2vpn | l3vpn }
2. if-match acl
When you define a match criterion to match the fields in RoCEv2 packets, because the opcode field values represent different RoCEv2 packet service types and only some types of RoCEv2 packets contain the src-qpair and nack fields, make sure their mappings are valid:
· If you specify both the opcode field and src-qpair field, the value for the opcode field must be 100 or 101, which specifies the UD service type. Otherwise, packets cannot be matched.
· If you specify both the opcode field and nack field, the value for the opcode field must be 17 (RC service) or 177 (XRC service). Otherwise, packets cannot be matched.
An ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
When matching IPv6 packets, an if match source-mac clause can match only the last 24 bits of the source IPv6 address.
The if-match any command cannot match MPLS packets. To match MPLS packets, use the if-match mpls { l2vpn | l3vpn } command.
# Define a match criterion for traffic class class1 to match the inner packet information of VXLAN packets.
[Sysname-classifier-class1] if-match vxlan any
[Sysname-classifier-class1] if-match acl 3000 inner
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the IPv6 packets with a DSCP value of 1, 6, or 9.
[Sysname-classifier-class1] if-match ipv6 dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match the IPv6 packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ipv6 ip-precedence 1 6
# Define a match criterion for traffic class class1 to match the packets with a local precedence value of 1 or 6.
[Sysname-classifier-class1] if-match local-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class1 to match the packets of the application 3link.
[Sysname-classifier-class1] if-match application 3link
# Define a match criterion for traffic class class1 to match packets with MPLS labels in the range of 1 to 10000.
[Sysname-classifier-class1] if-match mpls-label 1 to 10000
# Define a match criterion for traffic class class1 to match MPLS L2VPN packets.
[Sysname-classifier-class1] if-match mpls l2vpn
# Define a match criterion for traffic class class1 to match Layer 2 forwarded packets.
[Sysname-classifier-class1] if-match forwarding-layer bridge
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
Traffic behavior commands
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting [ byte | packet ]
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
If you do not specify the byte or packet keyword, traffic is counted in packets.
If you enable storm control and set thresholds for broadcast packets by using the storm-constrain command on an interface, do not configure an action of counting broadcast packets on the interface. The action might fail to take effect.
In the same direction of an interface, Layer 3 packet statistics counting (enabled by using the statistics l3-packet enable command and class-based accounting cannot both take effect. Only the configuration performed first takes effect.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir [ pps ] committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir [ pps ] committed-information-rate [ cbs committed-burst-size ] pir [ pps ] peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 8 to 160000000 kbps or pps, in increments of 8. If you specify the pps keyword, the CIR is specified in pps. If you do not specify the pps keyword, the CIR is specified in kbps. The pps keyword is supported only in Release 5212P06 and later versions and is supported only when a QoS policy is applied to a control plane.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 8 to 160000000 kbpsor pps, in increments of 8. If you specify the pps keyword, the CIR is specified in pps. If you do not specify the pps keyword, the CIR is specified in kbps. The pps keyword is supported only in Release 5212P06 and later versions and is supported only when a QoS policy is applied to a control plane.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7. This option is not supported in the current software version.
· remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. This option is not supported in the current software version.
· remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7. This option is not supported in the current software version.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database: Set the CIR to 200 kbps and the CBS to 51200 bytes.
[Sysname-behavior-database] car cir 200 cbs 51200
display traffic behavior
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
# Display all user-defined traffic behaviors.
User-defined behavior information:
Behavior: 1 (ID 100)
Marking:
Remark dscp 3
Committed Access Rate:
CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Behavior: 2 (ID 101)
Accounting enable: Packet
Filter enable: Permit
Redirecting:
Redirect to the CPU
Behavior: 3 (ID 102)
-none-
Behavior |
Name and contents of a traffic behavior. |
Marking |
Information about priority marking. |
Remark dscp |
Action of setting the DSCP value for packets. |
Committed Access Rate |
Information about the CAR action. |
Green action |
Action to take on green packets. |
Yellow action |
Action to take on yellow packets. |
Red action |
Action to take on red packets. |
Accounting enable |
Class-based accounting action. |
Filter enable |
Traffic filtering action. |
Redirecting |
Information about traffic redirecting. |
Mirroring |
Information about traffic mirroring. |
none |
No other traffic behavior is configured. |
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets. The permitted packets can be processed by other class-behavior associations in the same QoS policy.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure an outer VLAN tag adding action in a traffic behavior.
Use undo nest top-most to restore the default.
nest top-most vlan vlan-id
undo nest top-most
No outer VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added in the outer VLAN tag, in the range of 1 to 4094.
If a QoS policy contains an outer VLAN tag adding action, apply it only to the incoming traffic of an interface.
If you execute the nest top-most command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior b1 to add an outer VLAN tag with VLAN ID 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
packet-rate
Use packet-rate to configure a protocol packet rate limiting action in a traffic behavior.
Use undo packet-rate to restore the default.
packet-rate value
undo packet-rate
No protocol packet rate limiting action is configured.
value: Specifies the protocol packet rate in the range of 1 to 1048575 pps.
Protocol packet rate limiting can protect the CPU against protocol packet attacks.
If you execute this command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior copp to rate limit the protocol packets sent to the CPU to 1600 pps.
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number | tunnel-group group-id }
undo redirect { cpu | interface interface-type interface-number | tunnel-group }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number.
tunnel-group group-id: Redirects traffic to a tunnel group specified by its ID. The value range for the group-id argument is 1 to 32. For information about tunnel groups, see tunneling in Layer 3—IP Services Configuration Guide.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure redirecting traffic to HundredGigE 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface hundredgige 1/0/1
# Configure redirecting traffic to tunnel group 1 in traffic behavior aa.
[Sysname] traffic behavior aa
[Sysname-behavior-aa] redirect tunnel-group 1
classifier behavior
group (Interface Command Reference)
qos policy
traffic behavior
remark customer-vlan-id
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to restore the default.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No 802.1p priority marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag.
The remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands override each other in the same traffic behavior. The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
If you execute the remark dot1p dot1p-value command multiple times for the same color, the most recent configuration takes effect.
If you do not specify a color, packets of all colors are marked.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to restore the default.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
A traffic behavior that includes a drop priority marking action can be applied only to the inbound direction.
If you execute the remark drop-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to delete the action.
undo remark [ green | red | yellow ] dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword |
DSCP value (binary) |
DSCP value (decimal) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
# Configure traffic behavior database to mark matching traffic with DSCP 6.
remark ip-precedence
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to delete the action.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to delete the action.
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 1000.
You can use one QoS policy to mark the local QoS ID for packets in the inbound direction. Then, you can use another QoS policy to apply other QoS features in the outbound direction based on the marked local QoS ID.
If you execute the remark qos-local-id command multiple times in the same traffic behavior, the most recent configuration takes effect.
If you configure SRv6 and the traffic class matches IPv6 packets, a local QoS ID marking action is not supported in the traffic behavior. For information about SRv6, see Segment Routing Configuration Guide.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
remark service-class
Use remark service-class to configure an action of marking the MPLS TE service class in a traffic behavior.
Use undo remark service-class to restore the default.
remark service-class service-class-value
No MPLS TE service class marking action is configured.
service-class-value: Specifies the MPLS TE service class in the range of 0 to 7.
If the remark service-class command is executed in a QoS policy:
· The action of marking the MPLS TE service class takes effect only when the QoS policy is applied to the inbound direction of an interface. To identify the traffic behaviors that do not take effect, use the display qos policy interface command.
· The traffic class can only match packets by the IP 5-tuple (source IP address, source port number, destination IP address, destination port number, and protocol type), DSCP priority, and MPLS EXP value. Only one MPLS TE service class marking action can be configured for packets with the same MPLS EXP value on an interface. To modify the MPLS TE service class to be marked, you must remove the existing service class setting and configure a new service class value.
· If any of the following commands is executed in a traffic class, the remark service-class command is not supported in the traffic behavior:
¡ if-match mpls { l2vpn | l3vpn }
¡ if-match mpls-label
¡ if-match second-mpls-label
If you execute the remark service-class command multiple times in the same traffic behavior, the most recent configuration takes effect.
You can use the mpls te service-class command to set the MPLS TE service class. For more information, see MPLS TE commands in MPLS Command Reference.
# Configure an action of marking the MPLS TE service class as 2.
[Sysname-behavior-data] remark service-class 2
remark service-vlan-id
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to restore the default.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ mode { loose | qppb-manipulation } | insert-before before-classifier-name ] *
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode loose: Specifies that a class-behavior association applies only to a QoS policy applied to a control plane.
mode qppb-manipulation: Specifies that the class-behavior association applies only to QPPB. The if-match qos-local-id command in the class sets the same local QoS ID as the apply qos-local-id command in the BGP routing policy. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
Use a class-behavior association in loose mode (with the mode loose keyword specified) to rate-limit packets of the specified protocol received on the specified interface and sent to a control plane as follows:
1. Create an ACL, and configure an ACL rule to match packets of the specified protocol in the ACL.
2. Create a traffic class with the operator AND, and configure the if-match acl and if-match inbound-interface match criteria in the traffic class.
3. Create a traffic behavior, and configure actions in the traffic behavior.
4. Create a QoS policy, and associate the traffic class with the traffic behavior with the mode loose keyword specified.
5. Apply the QoS policy to a control plane.
When packets of the specified protocol are received on the other interface and sent to the control plane, the packets are rate-limited by the protocol packet rate limiting action applied to the control plane.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
# Enter the control plane view of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy
Use display qos policy to display QoS policies.
display qos policy user-defined [ accounting | mirroring | remarking ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
user-defined: Specifies user-defined QoS policies.
accounting: Specifies accounting-type QoS policies.
mirroring: Specifies mirroring-type QoS policies.
remarking: Specifies marking-type QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
If you do not specify the accounting, mirroring, or remarking keyword, this command displays generic QoS policies.
# Display all user-defined generic QoS policies.
User-defined QoS policy information:
Policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
Green action : pass
Behavior: 2
Marking:
Remark dot1p 4
Behavior: 3
-none-
# Display user-defined accounting-type QoS policies.
<Sysname> display qos policy user-defined accounting
Accounting policy: 1 (ID 100)
Behavior: 1
# Display user-defined mirroring-type QoS policies.
<Sysname> display qos policy user-defined mirroring
Mirroring policy: 1 (ID 100)
Behavior: 1
Mirroring:
Mirror to the CPU
# Display user-defined marking-type QoS policies.
<Sysname> display qos policy user-defined remarking
Marking policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
Table 6 Command output
User-defined QoS policy information |
Information about a user-defined QoS policy. |
System-defined QoS policy information |
Information about a system-defined QoS policy. |
Policy |
User-defined generic QoS policy name or system-defined QoS policy name. |
Accounting policy |
User-defined accounting-type QoS policy name. |
Mirroring policy |
User-defined mirroring-type QoS policy name. |
Marking policy |
User-defined marking-type QoS policy name. |
For the output description, see Table 1 and Table 4.
Use display qos policy control-plane to display QoS policies applied to a control plane.
# Display the QoS policy applied to the control plane of slot 1.
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Yellow packets: 0 (Packets) 0 (Bytes)
Red packets : 0 (Packets) 0 (Bytes)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 7 Command output
Direction |
Direction in which the QoS policy is applied. |
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies.
# Display the predefined control plane QoS policy of slot 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
Protocol Priority Bandwidth Group
Default N/A 1000 (pps) N/A
IS-IS 5 2048 (pps) critical
VRRP 6 512 (pps) important
OSPF Multicast 5 4096 (pps) critical
OSPF Unicast 5 4096 (pps) critical
PIM Multicast 4 512 (pps) critical
PIM Unicast 4 512 (pps) critical
IGMP 3 512 (pps) important
PIMv6 Multicast 4 256 (pps) critical
PIMv6 Unicast 4 256 (pps) critical
OSPFv3 Unicast 5 2048 (pps) critical
OSPFv3 Multicast 5 2048 (pps) critical
VRRPv6 6 512 (pps) important
ARP 2 2048 (pps) normal
DHCP Snooping 3 384 (pps) redirect
DHCP 3 384 (pps) normal
802.1x 2 512 (pps) important
STP 6 384 (pps) critical
LACP 6 43 (pps) critical
MVRP 3 384 (pps) critical
BGP 4 3072 (pps) critical
ICMP 1 512 (pps) monitor
TTL Expires 3 256 (pps) important
IPOPTION 3 256 (pps) normal
BGPv6 4 3072 (pps) critical
Hop Limit Expires 3 256 (pps) important
IPOPTIONv6 3 256 (pps) normal
DHCPv6 3 256 (pps) normal
LLDP 4 384 (pps) important
DLDP 4 256 (pps) critical
TELNET 1 896 (pps) management
SSH 1 896 (pps) management
TACACS 1 896 (pps) management
RADIUS 1 896 (pps) management
SNMP 1 896 (pps) management
ARP Snooping 3 2048 (pps) redirect
ICMPv6 1 2048 (pps) monitor
BFD 5 2048 (pps) critical
Table 8 Command output
Pre-defined control plane policy |
Contents of the predefined control plane QoS policy. |
Default |
Protocols other than those listed. |
Group |
Protocol group of the protocol. |
For descriptions of other fields, see Table 4.
display qos policy global
Use display qos policy global to display QoS policies applied globally.
display qos [ accounting | mirroring | remarking ] policy global [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
If you do not specify the accounting, mirroring, or remarking keyword, this command displays information about generic QoS policies.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display generic QoS policies applied globally.
<Sysname> display qos policy global
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# Display information about accounting-type QoS policies applied globally.
<Sysname> display qos accounting policy global
Direction: Inbound
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
# Display information about mirroring-type QoS policies applied globally.
<Sysname> display qos mirroring policy global
Direction: Inbound
Mirroring policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Mirroring:
Mirror to the CPU
# Display information about marking-type QoS policies applied globally.
<Sysname> display qos remarking policy global
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Table 9 Command output
Direction |
Accounting policy |
Mirroring policy |
Marking policy |
Green packets |
Statistics about green packets. |
Yellow packets |
Statistics about yellow packets. |
Red packets |
Statistics about red packets. |
Use display qos policy interface to display the QoS policies applied to interfaces.
display qos [ accounting | mirroring | remarking ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify the accounting, mirroring, or remarking keyword, this command displays generic QoS policies applied.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
Outgoing red packets cannot be counted.
# Display the generic QoS policy applied to the incoming traffic of HundredGigE 1/0/1.
<Sysname> display qos policy interface hundredgige 1/0/1 inbound
Interface: HundredGigE1/0/1
Direction: Inbound
Policy: 1
Classifier: 1
Matched : 0 (Packets) 0 (Bytes)
5-minute statistics:
Forwarded: 0/0 (pps/bps)
Dropped : 0/0 (pps/bps)
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Classifier: 4
Matched : 10 (Packets) 8000 (Bytes)
Operator: AND
Rule(s) :
If-match acl 3001
Behavior: 4
Redirecting:
Redirect to SR-TE policy:
NID : 123464
Redirect to SRv6-TE policy:
Forwarding ID: 123464
SID : 25::5a
# Display information about the accounting-type QoS policy applied to the incoming traffic of HundredGigE 1/0/1.
<Sysname> display qos accounting policy interface hundredgige 1/0/1 inbound
Direction: Inbound
Accounting Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Accounting enable:
0 (Packets)
# Display information about the mirroring-type QoS policy applied to the incoming traffic of HundredGigE 1/0/1.
<Sysname> display qos mirroring policy interface hundredgige 1/0/1 inbound
Direction: Inbound
Mirroring policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Mirroring:
Mirror to the CPU
# Display information about the marking-type QoS policy applied to the incoming traffic of HundredGigE 1/0/1.
<Sysname> display qos remarking policy interface hundredgige 1/0/1 inbound
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
# Display the QoS policies applied to all interfaces.
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: HundredGigE1/0/2
CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Green action : pass
Interface: HundredGigE1/0/3
Direction: Inbound
Policy: b
Classifier: b
Operator: AND
Rule(s) :
If-match any
Behavior: b
Green action : pass
Green packets : 0(Packets)
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: HundredGigE1/0/4
Green action : pass
Table 10 Command output
Direction |
Accounting policy |
Mirroring policy |
Marking policy |
Mode |
Sharing mode for QoS and ACL resources. This field appears only if a QoS policy is applied with the share-mode keyword specified. |
Matched |
Number of matching packets. |
Forwarded |
Average rate of successfully forwarded matching packets in a statistics collection period. |
Dropped |
Average rate of dropped matching packets in a statistics collection period. |
Green packets |
Traffic statistics for green packets. |
Yellow packets |
Traffic statistics for yellow packets. |
Red packets |
Traffic statistics for red packets. |
display qos policy l2vpn-ac
Use display qos policy l2vpn-ac to display the QoS policies applied to Ethernet service instances.
display qos policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays QoS policies applied to all Ethernet service instances on an interface.
inbound: Specifies the QoS policies applied to incoming traffic.
If you do not specify a direction, this command displays both QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to the incoming traffic of Ethernet service instance 1 on HundredGigE 1/0/1.
<Sysname> display qos policy l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound
Interface: HundredGigE1/0/1 Service instance ID: 1
Direction: Inbound
Policy: p
Classifier: c
Operator: AND
Rule(s) :
If-match any
Behavior: b
CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
Green action : pass
For the description of fields, see Table 1 and Table 4.
display qos vlan-policy
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
inbound: Displays QoS policies applied to incoming traffic.
outbound: Displays QoS policies applied to outgoing traffic.
If you do not specify a direction, this command displays QoS policies applied to VLANs in both the inbound and outbound directions.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 11 Command output
Direction |
Green packets |
Yellow packets |
Red packets |
Use qos apply policy to apply a QoS policy to an Ethernet service instance view, interface, or control plane.
Use undo qos apply policy to remove an applied QoS policy.
qos apply [ accounting | mirroring | remarking ] policy policy-name { inbound | outbound } [ share-mode ]
undo qos apply [ accounting | mirroring | remarking ] policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view
Interface view
accounting: Specifies an accounting-type QoS policy. This keyword is supported only in interface view or system view.
mirroring: Specifies a mirroring-type QoS policy. This keyword is supported only in interface view or system view.
remarking: Specifies a marking-type QoS policy. This keyword is supported only in interface view or system view.
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic. This keyword is not supported in Ethernet service instance view or control plane view.
share-mode: Applies the QoS policy in sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all interfaces with the same QoS policy applied in one direction share one QoS and ACL resource.
The display qos policy interface command output for an interface also contains packet statistics for all interfaces that share the QoS and ACL resource with the interface.
A maximum of four QoS policies (one generic, one accounting-type, one mirroring-type, and one marking-type) can be applied to one direction of an interface. Different actions can be taken on the same traffic class if QoS policies of different types are applied to an interface.
If you specify the share-mode keyword when applying a QoS policy to an interface, follow these restrictions and guidelines:
· All interfaces with the QoS policy applied in one direction share one QoS and ACL resource.
If the share-mode keyword is not specified, each interface uses one QoS and ACL resource in one direction.
· All interfaces that share one QoS and ACL resource evenly share the set CIR if a traffic policing action is configured in the QoS policy.
If the share-mode keyword is not specified, the bandwidth of each interface can be limited to the CIR.
· You cannot specify the share-mode keyword when applying an ACL to the same direction of the interface. For more information about applying an ACL to an interface, see the packet-filter (interface view) command in ACL commands.
You cannot change the sharing mode dynamically after a QoS policy is applied to an interface. To change the sharing mode for an applied QoS policy, perform the following tasks:
1. Remove the QoS policy from the interface.
2. Reapply the QoS policy with or without the share-mode keyword specified.
On the same interface, if you perform more than one of the following tasks, the tasks performed later might do not take effect due to lack of hardware resources:
· Apply a QoS policy containing IPv6 address match criteria to the outbound direction.
· Enable IPv6 NetStream for outbound traffic by using the ipv6 netstream outbound command (see IPv6 NetStream commands in Network Management and Monitoring Command Reference)).
· Enable statistics counting for outgoing Layer 3 packets by using the statistics l3-packet enable outbound command (see IPv6 basics commands or IP performance optimization commands in Layer 3—IP Services Command Reference).
# Apply generic QoS policy USER1 to the outgoing traffic of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply policy USER1 outbound
# Apply accounting-type QoS policy USER2 to the outgoing traffic of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply accounting policy USER2 outbound
# Apply mirroring-type QoS policy USER3 to the outgoing traffic of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply mirroring policy USER3 outbound
# Apply marking-type QoS policy USER4 to the outgoing traffic of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply remarking policy USER4 outbound
# Apply generic QoS policy USER5 to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot3] qos apply policy USER5 inbound
# Apply generic QoS policy TEST9 to the incoming traffic of Ethernet service instance 200.
[Sysname-HundredGigE1/0/1] service-instance 200
[Sysname-HundredGigE1/0/1-srv200] qos apply policy TEST9 inbound
qos apply policy global
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply [ accounting | mirroring | remarking ] policy policy-name global { inbound | outbound }
undo qos apply [ accounting | mirroring | remarking ] policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy to the incoming packets on all interfaces.
outbound: Applies the QoS policy to the outgoing packets on all interfaces.
A global QoS policy takes effect on all incoming or outgoing traffic depending on the direction in which the QoS policy is applied.
A maximum of four QoS policies (one generic, one accounting-type, one mirroring-type, and one marking-type) can be applied to one direction globally.
If you do not specify the accounting, mirroring, or remarking keyword, this command applies a generic QoS policy globally.
# Globally apply generic QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
# Globally apply mirroring-type QoS policy user2 to the incoming traffic.
[Sysname] qos apply mirroring policy user2 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos [ accounting | mirroring | remarking ] policy policy-name
undo qos [ accounting | mirroring | remarking ] policy policy-name
No QoS policies exist.
accounting: Identifies the QoS policy as an accounting-type QoS policy.
mirroring: Identifies the QoS policy as a mirroring-type QoS policy.
remarking: Identifies the QoS policy as a marking-type QoS policy.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
If you do not specify the accounting, mirroring, or remarking keyword when creating a QoS policy, a generic QoS policy is created.
QoS policies of different types cannot use the same policy name.
Do not use the accounting, mirroring, or remarking word or the first letters of any one of them as a policy name. If you do so, no information is displayed when you execute the display qos policy user-defined policy-name command, because the system will recognize such a policy name as command keyword.
A generic QoS policy can be applied to all supported destinations and can contain all actions. An accounting-type QoS policy can be applied to only interfaces or globally and can contain only class-based accounting actions. A mirroring-type QoS policy can be applied to only interfaces or globally and can contain only mirroring actions. A marking-type QoS policy can be applied to only interfaces or globally and can contain only marking actions.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a generic QoS policy named user1.
# Create an accounting-type QoS policy named user2.
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# Create a marking-type QoS policy named user3.
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# Create a mirroring-type QoS policy named user4.
[Sysname] qos mirroring policy user4
[Sysname-qospolicy-user4]
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Clear the statistics of the QoS policy applied to the control plane of slot 1.
<Sysname> reset qos policy control-plane slot 1
reset qos policy global
Use reset qos policy global to clear the statistics of a global QoS policy.
reset qos [ accounting | mirroring | remarking ] policy global [ inbound | outbound ]
inbound: Clears the statistics of the global QoS policy applied to incoming traffic globally.
outbound: Clears the statistics of the global QoS policy applied to outgoing traffic globally.
If you do not specify the accounting, mirroring, or remarking keyword, this command clears statistics for generic QoS policies.
If you do not specify a direction, this command clears the statistics of the global QoS policies in both directions.
# Clear the statistics of the generic QoS policy applied to the incoming traffic globally.
<Sysname> reset qos policy global inbound
# Clear statistics for the mirroring-type QoS policy applied to the inbound direction globally.
<Sysname> reset qos mirroring policy global inbound
reset qos vlan-policy
Use reset qos vlan-policy to clear the statistics of the QoS policy applied in a certain direction of a VLAN.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
inbound: Clears the statistics of the QoS policy applied to the incoming traffic of the specified VLAN.
outbound: Clears the statistics of the QoS policy applied to the incoming traffic of the specified VLAN.
If you do not specify a direction, this command clears the statistics of the QoS policies in both directions of the VLAN.
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
QoS and ACL resource usage displaying commands
display qos-acl resource
Use display qos-acl resource to display QoS and ACL resource usage.
display qos-acl resource [ advance ] [ slot slot-number ]
advance: Displays the QoS and ACL resource usage in advanced mode. If you do not specify this keyword, this command displays the QoS and ACL resource usage in common mode.
# Display QoS and ACL resource usage in common mode.
<Sysname> display qos-acl resource
Interfaces: HGE3/0/1 to HGE3/0/48 (slot 3)
Type Total Reserved Configured Remaining Usage
VFP ACL 26624 0 0 26624 0%
IFP ACL 47104 8196 9 38899 17%
IFP Meter 8191 157 0 8034 1%
IFP Counter 8191 171 1 8019 2%
EFP ACL 30720 0 1 30719 0%
EFP Meter 8191 0 0 8191 0%
EFP Counter 8191 0 0 8191 0%
Table 12 Command output
Interfaces |
Interface range for the resources. |
Type |
Resource type. · VFP ACL—ACL resource usage for marking local QoS IDs before Layer 2 forwarding. · IFP ACL—Ingress ACL resources. · IFP Meter—Ingress traffic policing resources. · IFP Counter—Ingress traffic accounting resources. · EFP ACL—Egress ACL resources. · EFP Meter—Egress traffic policing resources. · EFP Counter—Egress traffic accounting resources. |
Total |
Total number of resources. |
Reserved |
Number of reserved resources. |
Configured |
Number of resources that have been applied. |
Remaining |
Number of resources that you can apply. |
Usage |
Configured and reserved resources as a percentage of total resources. If the percentage is not an integer, this field displays the integer part. For example, if the actual usage is 50.8%, this field displays 50%. |
# Display QoS and ACL resource usage in advanced mode.
<Sysname> display qos-acl resource advance
(Slot 3 Chip 0)
Slice Stage Total Configured Remaining Usage
0/1 IFP 3894 188 3706 4%
1 IFP 3706 0 3706 0%
2 IFP 4095 1 4094 0%
3 IFP 4093 1 4092 0%
4 IFP 4093 2 4091 0%
5 EFP 4095 0 4095 0%
6 -- 4096 0 4096 0%
7 -- 4096 0 4096 0%
8 -- 4096 0 4096 0%
9 -- 4096 0 4096 0%
9 -- 4096 0 4096 0%
10 -- 4096 0 4096 0%
11 -- 4096 0 4096 0%
12 -- 512 0 512 0%
13 -- 512 0 512 0%
14 -- 512 0 512 0%
15 -- 512 0 512 0%
Table 13 Command output
Stage |
Processing stage: · VFP—Layer 2 forwarding stage. · IFP—Receiving stage. · EFP—Sending stage. |
Slice |
Slice index of the ACL resource. |
Total |
Configured |
Remaining |
Usage |
Priority mapping commands
Priority map commands
display qos map-table
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-lp ]
The device provides the following types of priority map.
Priority mapping |
dot1p-dp |
802.1p-drop priority map. |
dot1p-lp |
802.1p-local priority map. |
dscp-dot1p |
DSCP-802.1p priority map. |
dscp-dp |
DSCP-drop priority map. |
dscp-dscp |
DSCP-DSCP priority map. |
dscp-exp |
DSCP-EXP priority map. |
exp-dot1p |
EXP-802.1p priority map. |
exp-dscp |
EXP-DSCP priority map. |
exp-lp |
EXP-local priority map. |
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
Table 15 Command output
MAP-TABLE NAME |
Name of the priority map. |
TYPE |
Type of the priority map. |
IMPORT |
Input values of the priority map. |
EXPORT |
Output values of the priority map. |
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-lp }
For the description of the keywords, see Table 14.
# Enter the 802.1p-local priority map view.
import
Priority trust mode commands
display qos trust interface
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of HundredGigE 1/0/1.
<Sysname> display qos trust interface hundredgige 1/0/1
Port priority trust information
Port priority: 4
Port priority trust type: dscp
Table 16 Command output
Interface type and interface number. |
Port priority |
Port priority set for the interface. |
Port priority trust type |
Priority trust mode on the interface: · dot1p—Uses the 802.1p priority of received packets for mapping. · dscp—Uses the DSCP precedence of received IP packets for mapping. |
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
Layer 2 Ethernet interfaces trust the 802.1p priority for mapping, and Layer 3 Ethernet interfaces trust the DSCP priority for mapping.
Interface view
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
For a VXLAN tunnel interface to trust the DSCP priority in the inner IP header of VXLAN packets, configure the qos trust dscp command on its physical interface.
# Set the priority trust mode to 802.1p priority on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos trust dot1p
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority priority-value
undo qos priority
The port priority is 0.
Interface view
priority-value: Specifies the port priority value in the range of 0 to 7.
# Set the port priority of HundredGigE 1/0/1 to 2.
[Sysname-HundredGigE1/0/1] qos priority 2
Traffic policing, GTS, and rate limit commands
Traffic policing commands
display qos car interface
Use display qos car interface to display the CAR information for interfaces.
display qos car interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the CAR information for all interfaces.
# Display the CAR information for HundredGigE 1/0/1.
<Sysname> display qos car interface hundredgige 1/0/1
Direction: inbound
Rule: If-match any
CIR 128 (kbps), CBS 5120 (Bytes), PIR 128 (kbps), EBS 512 (Bytes)
Green action : pass
Green packets : 0 (Packets), 0 (Bytes)
Yellow packets: 0 (Packets), 0 (Bytes)
Red packets : 0 (Packets), 0 (Bytes)
# Display the CAR information on HundredGigE 1/0/2.
<Sysname> display qos car interface hundredgige 1/0/2
Interface: HundredGigE1/0/2
Direction: inbound
Rule: If-match any
CIR 50 (%), CBS 600 (ms), EBS 0 (ms), PIR 50 (%)
Green action : pass
Table 17 Command output
Interface name, including interface type and interface number. |
Direction |
Direction in which traffic policing is applied. |
Rule |
Match criteria. |
CIR |
CIR in kbps (if the CIR is specified in absolute value) or in percentage (if the CIR is specified in percentage). |
CBS |
CBS in bytes (if the CBS is specified in absolute value) or in ms (if the CBS is specified in milliseconds). When the CBS is specified in milliseconds, the actual CBS value is cbs-time × the actual CIR value. |
EBS |
EBS in bytes (if the EBS is specified in absolute value) or in ms (if the EBS is specified in milliseconds). When the EBS is specified in milliseconds, the actual EBS value is ebs-time × the actual CIR value. |
PIR |
PIR in kbps (if the PIR is specified in absolute value) or in percentage (if the PIR is specified in percentage). |
Green action |
Yellow action |
Red action |
qos car (interface view)
Use qos car to configure a CAR policy on an interface.
Use undo qos car to delete a CAR policy from an interface.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { inbound | outbound } any
No CAR policy is configured on an interface.
Interface view
inbound: Performs CAR for incoming packets on the interface.
outbound: Performs CAR for outgoing packets on the interface.
any: Performs CAR for all IP packets in the specified direction.
carl carl-index: Performs CAR for packets matching a CAR list specified by its number in the range of 1 to 199.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 0 to 4294967294.
cbs committed-burst-size: Specifies the CBS in bytes, which is the size of bursty traffic when the actual average rate is not greater than the CIR. The value range for committed-burst-size is 0 to 4294967294. The default value is the product of 62.5 and the CIR.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 4294967294. The default value is 0.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 0 to 4294967294.
To use two rates for traffic policing, configure the qos car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the qos car command without the pir peak-information-rate option.
If you execute this command multiple time in the same direction, the most recent configuration takes effect.
When specifying an ACL, follow these restrictions and guidelines:
· If the specified ACL does not exist or does not have any rules, the ACL will not be referenced.
· In the specified ACL, if a rule has the vpn-instance keyword specified, the rule takes effect only on VPN packets. If a rule does not have the vpn-instance keyword specified, the rule takes effect only on packets in the public network.
# Perform CAR for all packets in the outbound direction of HundredGigE 1/0/1. The CAR parameters are as follows:
· CIR is 200 kbps.
· CBS is 5120 bytes.
· EBS is 0.
· Conforming packets are transmitted.
· Excess packets are set with an IP precedence of 0 and transmitted.
[Sysname-HundredGigE1/0/1] qos car outbound any cir 200 cbs 5000 ebs 0 green pass red remark-prec-pass 0
qos carl
qos car percent (interface view)
Use qos car percent to configure a CAR policy in percentage on an interface.
qos car { inbound | outbound } any percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ]
qos car { inbound | outbound } any percent cir cir-percent [ cbs cbs-time ] pir pir-percent [ ebs ebs-time ]
No CAR policy is configured in percentage on an interface.
Interface view
any: Performs CAR for all IP data packets in the specified direction.
percent cir cir-percent: Specifies the CIR in percentage, in the range of 1 to 100. The actual CIR value is cir-percent × interface bandwidth.
cbs cbs-time: Specifies the CBS in milliseconds. The actual CBS value is cbs-time × the actual CIR value. The value range for cbs-time is 500 to 2000. The default value is 500.
ebs ebs-time: Specifies the EBS in milliseconds. The actual EBS value is ebs-time × the actual CIR value. The value range for excess-burst-size is 0 to 2000. The default value is 0.
pir pir-percent: Specifies the PIR in percentage, in the range of 1 to 100. The value for the pir-percent argument must be greater than or equal to the value for the cir-percent argument.
To use two rates for traffic policing, configure the qos car percent command with the pir pir-percent option. To use one rate for traffic policing, configure the qos car percent command without the pir pir-percent option.
# Perform CAR for all outgoing packets on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos car outbound any percent cir 50 cbs 1000
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration for all interfaces.
# Display the GTS configuration for all interfaces.
Rule: If-match queue 2
CIR 16 (kbps), CBS 51200 (Bytes)
Table 18 Command output
Interface name, including the interface type and interface number. |
Rule |
Match criteria. |
CIR |
CIR in kbps. |
CBS |
CBS in bytes. |
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured on an interface.
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 100000000.
cbs committed-burst-size: Specifies the CBS in the range of 512 to 16000000 bytes.
# Shape the packets in queue 0 on HundredGigE 1/0/1. The GTS parameters are as follows:
· The CIR is 200 kbps.
· The CBS is 51200 bytes.
[Sysname] hundredgige 1/0/1
[Sysname-HundredGigE1/0/1] qos gts queue 0 cir 200 cbs 51200
Rate limit commands
display qos lr interface
Use display qos lr interface to display the rate limit configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration for all interfaces.
# Display the rate limit configuration and statistics for all interfaces.
Direction: Outbound
CIR 2000 (kbps), CBS 20480 (Bytes)
Table 19 Command output
Direction |
Direction in which the rate limit configuration is applied. |
CIR |
CIR in kbps. |
CBS |
CBS in bytes. |
pps-level inbound
Use pps-level inbound to set the inbound rate limit level.
Use undo pps-level inbound to restore the default.
pps-level inbound level-value
The inbound rate limit level is 1000 on the S12500R-48Y8C switch and 675 on the S12500R-48C6D switch.
level-value: Specifies the inbound rate limit level in the range of 0 to 1000.
# Set the inbound rate limit level to 7.
[Sysname] pps-level inbound 7
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration.
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
No rate limit is configured on an interface.
outbound: Limits the rate of outgoing packets.
cbs committed-burst-size: Specifies the CBS in the range of 512 to 128000000 bytes. The default is the product of 62.5 and the CIR and must be a multiple of 512. When the product is not a multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 128000000 is converted to 128000000.
# Limit the rate of outgoing packets on HundredGigE 1/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-HundredGigE1/0/1] qos lr outbound cir 256 cbs 51200
qos lr percent
Use qos lr percent to configure percentage-based rate limiting on an interface.
Use undo qos lr to delete the rate limiting configuration on an interface.
qos lr outbound percent cir cir-percent [ cbs cbs-time ]
Percentage-based rate limiting is not configured on an interface.
Interface view
cbs cbs-time: Specifies the CBS in milliseconds. The actual CBS value is cbs-time × the actual CIR value. The value range for cbs-time is 50 to 2000.
# Limit the rate of outgoing packets on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos lr outbound percent cir 50 cbs 1000
Congestion management commands
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of HundredGigE 1/0/1.
<Sysname> display qos queue sp interface hundredgige 1/0/1
Output queue: Strict Priority queuing
Table 20 Command output
Output queue |
Type of the current output queue. |
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses SP queuing.
# Enable SP queuing on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos sp
WRR commands
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of HundredGigE 1/0/1.
<Sysname> display qos queue wrr interface hundredgige 1/0/1
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Weight
0 be 1 1
1 af1 1 1
2 af2 1 1
3 af3 1 1
4 af4 1 1
5 ef 1 1
6 cs6 1 1
7 cs7 sp N/A
Table 21 Command output
Output queue |
Group |
ID of the group a queue is assigned to. |
Weight |
Packet-count queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Byte count |
Byte-count scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
qos wrr
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
byte-count: Allocates bandwidth to queues in bytes.
weight: Allocates bandwidth to queues in packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-count WRR queuing on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wrr weight
# Enable byte-count WRR queuing on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
qos wrr queue-id group 1 { byte-count | weight } schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7 or keywords in Table 22.
Table 22 The number-keyword map for the queue-id argument
Number |
Keyword |
0 |
be |
1 |
af1 |
2 |
af2 |
3 |
af3 |
4 |
af4 |
5 |
ef |
6 |
cs6 |
7 |
cs7 |
group 1: Specifies WRR group 1. Only WRR group 1 is supported in the current software version.
schedule-value: Specifies a scheduling weight. The value range for this argument is 1 to 127.
# Enable byte-count WRR queuing on HundredGigE 1/0/1, assign queue 0 to WRR group 1, and specify scheduling weight 10 for queue 0.
[Sysname-HundredGigE1/0/1] qos wrr 0 group 1 byte-count 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues on a WRR-enabled interface are in WRR group 1.
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on HundredGigE 1/0/1, and assign queue 0 to the SP group.
[Sysname-HundredGigE1/0/1] qos wrr 0 group sp
qos wrr
WFQ commands
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of HundredGigE 1/0/1.
<Sysname> display qos wfq interface hundredgige 1/0/1
Output queue: Hardware Weighted Fair Queuing
Queue ID Queue name Group Byte count Min Bandwidth
0 be 1 1 64
1 af1 1 1 64
2 af2 1 1 64
3 af3 1 1 64
4 af4 1 1 64
5 ef 1 1 64
6 cs6 1 1 64
7 cs7 1 1 64
Table 23 Command output
Output queue |
Group |
ID of the group that holds the queue. |
Byte-count |
Byte-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Weight |
Packet-count queue scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Min Bandwidth |
Minimum guaranteed bandwidth for the queue. |
qos wrr
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth for a queue is 780 kbps.
min bandwidth-value: Sets the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 100000000.
The minimum guaranteed bandwidth is the amount of bandwidth guaranteed for a queue when the interface is congested.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
The granularity of the minimum guaranteed bandwidth is 776. If you set a bandwidth value between 8 and 776, the value 776 takes effect. If you set a bandwidth value between 777 and 1552, the value 1552 takes effect, and so on.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wfq weight
[Sysname-HundredGigE1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to restore the default.
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable packet-count WFQ on HundredGigE 1/0/1.
# Enable byte-count WFQ on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
All queues on a WFQ-enabled interface are in WFQ group 1 and have a weight of 1.
group 1: Specifies WFQ group 1. Only WFQ group 1 is supported in the current software version.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on HundredGigE 1/0/1, assign queue 0 to WFQ group 1, and specify scheduling weight 10 for queue 0.
[Sysname-HundredGigE1/0/1] qos wfq 0 group 1 byte-count 10
qos bandwidth queue
qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to remove a queue from the SP group.
qos wfq queue-id group sp
All queues on a WFQ-enabled interface are in WFQ group 1.
This command is available only on a WFQ-enabled interface. Queues in the SP group are scheduled with SP, instead of WFQ. The SP group has higher scheduling priority than the WFQ groups.
# Enable WFQ on HundredGigE 1/0/1, and assign queue 0 to the SP group.
[Sysname-HundredGigE1/0/1] qos wfq 0 group sp
qos bandwidth queue
qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to set the minimum guaranteed bandwidth for a queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
Queue scheduling profile view
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 100000000.
You must configure a queue as a WFQ queue before you set the minimum guaranteed bandwidth for the queue.
# Configure queue 0 as a WFQ queue, and set the minimum guaranteed bandwidth to 100 kbps for queue 0.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue scheduling profile: myprofile (ID 1)
Queue ID Type Group Schedule Schedule Min Max
unit value bandwidth bandwidth
be WFQ 1 weight 1 64 N/A
af1 SP N/A N/A N/A 64 N/A
af2 SP N/A N/A N/A 64 N/A
af3 SP N/A N/A N/A 64 N/A
af4 SP N/A N/A N/A 64 N/A
ef SP N/A N/A N/A 64 N/A
cs6 SP N/A N/A N/A 64 N/A
cs7 SP N/A N/A N/A 64 N/A
Table 24 Command output
Queue management profile |
Queue scheduling profile name. |
Type |
Queue scheduling type: · SP. · WRR. · WFQ. |
Group |
Priority group to which the queue belongs. N/A indicates this field is ignored. |
Schedule unit |
Scheduling unit: weight or byte-count. N/A indicates that this field is ignored. |
Schedule value |
This field indicates: · Number of packets for the weight scheduling unit. · Number of bytes for the byte-count scheduling unit. N/A indicates that this field is ignored. |
Min bandwidth |
Minimum guaranteed bandwidth for the queue. N/A indicates that this field is ignored. |
Max bandwidth |
Maximum allowed bandwidth for the queue. N/A indicates that this field is ignored. |
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to HundredGigE 1/0/1.
<Sysname> display qos qmprofile interface hundredgige 1/0/1
Direction: Outbound
Queue management profile: myprofile
Table 25 Command output
Direction |
Direction in which the queue scheduling profile is applied. |
Name of the queue scheduling profile applied to the interface. |
qos apply qmprofile
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
Interface view
You can apply only one queue scheduling profile to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id{ sp | wfq group 1 { weight | byte-count } schedule-value | wrr group 1 { weight | byte-count } schedule-value }
undo queue queue-id
All queues in a queue scheduling profile are SP queues.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID. The group ID can only be 1.
schedule-value: Specifies the scheduling weight. The value range for this argument is 1 to 127.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
· The WRR queuing is used.
· The WRR group is group 1.
· The scheduling weight is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
qos qmprofile
Congestion avoidance commands
WRED commands
NOTE: AI ECN is supported only in Release 5212P01 and later. |
ai-ecn
Use ai-ecn to enter AI ECN view.
ai-ecn
AI service view
To enable AI ECN, first enter AI service view and then enter AI ECN view.
# Enter AI ECN view.
[Sysname] ai-service
[Sysname-ai-service] ai-ecn
[Sysname-ai-service-ai-ecn]
ai-service
Use ai-service to enter AI service view.
ai-service
# Enter AI service view.
ai ai-ecn enable
Use ai ai-ecn enable to enable AI ECN and set the AI ECN mode.
Use undo ai ai-ecn enable to restore the default.
ai ai-ecn enable mode { centralized | distributed }
AI ECN is disabled.
AI ECN view
centralized: Specifies that the analyzer calculates the ECN triggering threshold and communicates it to devices.
distributed: Specifies that the device itself intelligently sets the optimal ECN triggering threshold.
This function enables the device to collect and send traffic characteristics to the AI service component on an analyzer or the local AI service component. The AI service component dynamically sets the optimal ECN triggering threshold for a queue to achieve low delay and high throughput.
After the device is rebooted, the ECN triggering thresholds set by the analyzer or AI service component are cleared.
# Enable AI ECN and set the AI ECN mode to centralized.
[Sysname-ai-service] ai ai-ecn enable mode centralized
queue (AI ECN view)
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
Current WRED configuration:
Applied WRED table name: q1
Table 26 Command output
qos wred apply
display qos wred table
Use display qos wred table to display the WRED table configuration.
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID gmin gmax gpro ymin ymax ypro rmin rmax rpro exp ECN
0 250 1000 10 250 1000 10 250 1000 10 9 N
1 250 1000 10 250 1000 10 250 1000 10 9 N
2 250 1000 10 250 1000 10 250 1000 10 9 N
3 250 1000 10 250 1000 10 250 1000 10 9 N
4 250 1000 10 250 1000 10 250 1000 10 9 N
5 250 1000 10 250 1000 10 250 1000 10 9 N
6 250 1000 10 250 1000 10 250 1000 10 9 N
7 250 1000 10 250 1000 10 250 1000 10 9 N
Table 27 Command output
Table name |
Name of a WRED table. |
Table type |
Type of a WRED table. |
QID |
Queue ID. |
gmin |
Lower limit for green packets. |
gmax |
Upper limit for green packets. |
gpro |
Drop probability for green packets. |
ymin |
Lower limit for yellow packets. |
ymax |
Upper limit for yellow packets. |
ypro |
Drop probability for yellow packets. |
rmin |
Lower limit for red packets. |
rmax |
Upper limit for red packets. |
rpro |
Drop probability for red packets. |
exp |
Exponent for average queue length calculation. |
ECN |
Indicates whether ECN is enabled for the queue: · Y—Enabled. · N—Disabled. |
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
Interface view
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wred apply table1
qos wred queue table
qos wred queue
Use qos wred queue to configure the WRED parameters for a queue.
Use undo qos wred queue to restore the default.
qos wred queue queue-id low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ ecn ] [ weighting-constant exponent ]
qos wred queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo qos wred queue { queue-id [ drop-level drop-level ] | all }
No WRED parameters are configured.
Interface view
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7.
low-limit low-limit: Specifies the lower limit for the average queue length. The value range for low-limit is 0 to 268435455 bytes.
high-limit high-limit: Specifies the upper limit for the average queue length. The upper limit must be greater than the lower limit. The value range for high-limit is 0 to 268435455 bytes.
discard-probability discard-prob: Specifies the denominator for drop probability calculation. The greater the denominator, the greater the calculated drop probability. The value range for discard-prob is 0 to 100. The default is 10.
ecn: Enables ECN.
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation. The value range for exponent is 0 to 15.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
all: Specifies all queues.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
Specifying the ecn keyword in this command has the same effect as executing the qos wred queue ecn command.
Specifying the weighting-constant exponent keyword in this command has the same effect as executing the qos wred queue weighting-constant command.
This command and the qos wred apply command are mutually exclusive.
# Configure the following WRED parameters for queue 1 on HundredGigE 1/0/1:
· The drop level is 1.
· The lower limit for the average queue length is 10.
· The upper limit for the average queue length is 20.
· The drop probability is 30%.
[Sysname-HundredGigE1/0/1] qos wred queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
qos wred queue ecn
qos wred queue ecn
Use qos wred queue ecn to enable ECN for a queue.
Use undo qos wred queue ecn to restore the default.
qos wred queue queue-id ecn
undo qos wred queue queue-id ecn
ECN is disabled for a queue.
Interface view
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
Executing this command has the same effect as specifying the ecn keyword in the qos wred queue command.
# Enable ECN for queue 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wred queue 1 ecn
qos wred queue
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
table table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
You can use the display qos wred table command to display the default WRED table, which cannot be modified or deleted.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
Use qos wred queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo qos wred queue weighting-constant to restore the default.
qos wred queue queue-id weighting-constant exponent
undo qos wred queue queue-id weighting-constant
The exponent for average queue length calculation is 9 for a queue.
Interface view
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
Executing this command has the same effect as specifying the weighting-constant exponent option in the qos wred queue command.
# Set the exponent for average queue length calculation to 12 for queue 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wred queue 1 weighting-constant 12
qos wred queue
queue (AI ECN view)
Use queue to enable AI ECN for a queue.
Use undo queue to restore the default.
queue queue-id enable
undo queue queue-id
AI ECN is disabled for a queue.
AI ECN view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
This function is mutually exclusive with the following settings:
· Applying a WRED table to an interface.
· Configuring WRED parameters for a queue.
· Setting the WRED exponent for average queue size calculation.
· Enabling ECN for a queue.
· Enabling global WRED Smart ECN.
After the device is rebooted, the ECN triggering thresholds set by the AI service component are cleared.
# Enable AI ECN for queue 1.
[Sysname-ai-service-ai-ecn] queue 1 enable
queue (WRED table view)
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
undo queue { queue-id [ drop-level drop-level ] | all }
The lower limit is 1024000, the upper limit is 4096000, and the drop probability denominator is 10.
WRED table view
high-limit high-limit: Specifies the upper limit for the average queue length. The upper limit must be greater than the lower limit. The value range for low-limit is 0 to 268435455 bytes.
To use tail drop for a queue, set the lower limit and upper limit to the same value.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
WRED table view
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
Aggregate CAR commands
car name
Use car name to use an aggregate CAR action in a traffic behavior.
Use undo car to restore the default.
car name car-name
undo car
No aggregate CAR action is configured in a traffic behavior.
Traffic behavior view
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
display qos car name
display traffic behavior user-defined
Use display qos car name to display information about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command displays information about all aggregate CAR actions.
# Display information about all aggregate CAR actions.
<Sysname> display qos car name
Mode: aggregative
CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Slot 0:
Slot 1:
Slot 2:
Apply failed
Table 28 Command output
Name |
Name of the aggregate CAR action. |
Mode |
Type of the CAR action, which can be aggregative. |
CIR CBS PIR EBS |
Parameters for the CAR action. |
Green action |
Action to take on green packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Yellow action |
Action to take on yellow packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Red action |
Action to take on red packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Green packet |
Statistics about green packets. |
Yellow packet |
Statistics about yellow packets. |
Red packet |
Statistics about red packets. |
qos car
Use qos car aggregative to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
aggregative: Specifies the global CAR action as an aggregate CAR action.
cir committed-information-rate: Specifies the CIR in kbps, which is an average traffic rate. The value range for committed-information-rate is 8 to 160000000. The specified value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 8 to 160000000. The specified value must be an integral multiple of 8.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass.
action: Specifies the action to take on packets:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
To use two rates for aggregate CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for aggregate CAR, configure the qos car command without the pir peak-information-rate option.
An aggregate CAR action takes effect only after it is used in a QoS policy.
# Configure aggregate CAR action aggcar-1, where CIR is 25600, CBS is 512000, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name
Use reset qos car name to clear the statistics about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command clears statistics for all an aggregate CAR actions.
# Clear the statistics about aggregate CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics of HundredGigE 1/0/1.
<Sysname> display qos queue-statistics interface hundredgige 1/0/1 outbound
Interface: HundredGigE1/0/1
Direction: Outbound
Forwarded: 0 packets, 0 bytes
Dropped: 0 packets, 0 bytes
Queue 0
Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Forwarded(peak): 0 pps, 0 bps
Total queue length: 268435456 bytes
Current queue length: 0 bytes, 0% use ratio
Queue 7
Table 29 Command output
Interface for which queue-based traffic statistics are displayed. |
Direction |
Direction of traffic for which statistics are collected. |
Forwarded |
Counts forwarded traffic both in the number of packets, in the number of bytes, and in the number of packets or bits per second. |
Forwarded(peak) |
Peak forwarding rate during the time between the last execution of the reset qos queue-statistics interface outbound command and the current execution of the display qos queue-statistics interface outbound command. |
Dropped |
Counts dropped traffic both in packets and in bytes. |
Total queue length |
Total number of packets allowed in the queue. |
Current queue length |
Current number of packets in the queue. |
use ratio |
Utilization ratio of the queue. |
reset counters interface (Interface Command Reference)
Use reset qos queue-statistics interface outbound to clear outgoing queue-based traffic statistics for an interface.
reset qos queue-statistics interface [ interface-type interface-number ] outbound
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears the outgoing queue-based traffic statistics for all interfaces.
# Clear the outgoing queue-based traffic statistics for all interfaces.
<Sysname> reset qos queue-statistics interface outbound
# Clear the outgoing queue-based traffic statistics for HundredGigE 1/0/1.
<Sysname> reset qos queue-statistics interface hundredgige 1/0/1 outbound
