- 18-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-NTP commands
- 05-PTP commands
- 06-SNMP commands
- 07-RMON commands
- 08-Event MIB commands
- 09-Sampler commands
- 10-Mirroring commands
- 11-NetStream commands
- 12-IPv6 NetStream commands
- 13-NetAnalysis commands
- 14-sFlow commands
- 15-Packet capture commands
| 09-Sampler commands | 47.41 KB |
Sampler commands
display sampler
Use display sampler to display configuration information for a sampler.
display sampler [ sampler-name ] [ slot slot-number ]
sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a sampler, this command displays configuration information for all samplers.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays sampler configuration information for the active MPU.
# Display the configuration information about sampler 256.
<Sysname> display sampler 256
Sampler name: 256
Mode: random; Packet-interval: 8; IsNpower: Y
Sampler name |
Name of the sampler. |
Mode |
Sampling mode. In the current software version, only the random mode is supported. . |
Packet-interval |
Sampling rate. |
IsNpower |
Whether the sampling rate is 2 to the nth power: Y for Yes. |
sampler
Use sampler to create a sampler.
Use undo sampler to delete a sampler.
sampler sampler-name mode random packet-interval n-power rate
undo sampler sampler-name
No samplers exist.
sampler-name: Specifies a sampler by its name, a string of 1 to 31 characters. In versions earlier than Release 5212P06, the sampler name is case insensitive. In Release 5212P06 and versions, the sampler name is case sensitive. When other service modules reference a sampler, the sampler name is case-sensitive.
random: Specifies the random sampling mode. A sampler in this mode randomly selects a packet out of a group of packets. Which packet is selected for each sampling varies.
n-power: Specifies the sampling rate as 2 to the nth power.
rate: Specifies the sampling rate. One packet is selected from 2 to the rateth power packets in each sampling. For example, if n-power 8 is specified, one packet is selected from 256 (2 to the 8th power) packets in each sampling.
This command takes effect on all cards.
If you execute this command multiple times and specify different sampler names, multiple samplers are configured. If only the letter case of sampler names is different, the sampler name in the first configuration is used, and the sampling rate in the most recent configuration is used.
# Create sampler abc in random sampling mode. Set the sampling rate to 8 to select one packet from 256 packets in each sampling.
[Sysname] sampler abc mode random packet-interval n-power 8
