01-WLAN optimization configuration | 60.93 KB |
Restrictions and guidelines: WLAN optimization configuration
Configuring rejection of weak-signal clients
Configuring AP-triggered client reassociation
Configuring hidden node protection
Configuring software retransmission
Configuring WLAN optimization
About WLAN optimization
Proper channel planning and power control policies during WLAN deployment are important for good performance. However, in live WLAN networks, channel overlapping, collisions, and interference can easily occur because the none-overlapping channels are limited but the number of WLAN devices always increases.
The WLAN optimization features can help you improve the quality and stability of a WLAN.
Use WLAN optimization commands under the guidance of H3C Support.
There is no fixed combination of features for optimizing a specific WLAN. Select and adjust the features based on the application effect and WLAN performance.
The overall performance of a WLAN is determined by the network architecture as well as channel and power planning. Therefore, the WLAN optimization features cannot significantly increase the performance of a WLAN. In practice, if the features can improve the WLAN performance by 3%, the optimization is considered successful.
This feature enables an AP to reject clients with an RSSI lower than the specified threshold to release channel resources and enhance WLAN performance.
After you enable this feature, wireless clients with an RSSI lower than the threshold might fail to access the WLAN.
After a client accesses the WLAN, an AP will not log off the client with an RSSI lower than the threshold but will reject the client after it disconnects from the network.
To avoid client access failures, set an appropriate RSSI value when enabling this feature.
1. Enter system view.
2. Enter WLAN radio interface view.
interface wlan-radio interface-number
3. Configure rejection of weak-signal clients.
option client reject enable [ rssi rssi-value ]
By default, rejecting weak-signal clients is disabled.
A client with a low signal strength can roam to another AP only when its signal strength is lower than the manufacturer-defined signal strength for triggering roaming. Therefore, the client cannot obtain good network experience and service quality.
This feature enables an AP to send unsolicited deauthentication frames to a client when the signal strength of the client is lower than the specified RSSI threshold. Then, the client can reassociate with the AP or roam to another AP.
To avoid unexpected client logoff, set an appropriate RSSI value when enabling this feature.
3. Configure AP-triggered client reassociation.
option client reconnect enable [ rssi rssi-value ] [ interval interval ]
By default, AP-triggered client reassociation is disabled.
This feature enables clients to send RTS or CTS frames before transmitting frames to avoid interference from hidden nodes.
This feature takes effect only on 802.11g, 802.11n, 802.11ac, and 802.11ax clients.
3. Configure hidden node protection.
option client hide-node-protection enable
By default, hidden node protection is disabled.
Configuring channel reuse
This feature enables the AP to ignore packets with a signal strength lower than the specified channel reuse level. This mechanism enables the AP to obtain more radio resources and improves the performance of APs working on the same channel.
Enabling this feature might add hidden nodes.
3. Configure channel reuse.
option channel-reuse-optimization { disable | enable level level }
By default, channel reuse is disabled.
Perform this task to configure software retransmission and set the maximum number of software retransmissions for the specified type of packets.
3. Enable software retransmission and set the maximum number of software retransmissions.
rrop software-retry broadcast-multicast enable count count
By default, the maximum number of software retransmissions varies by device model.
