16-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10016-Network Management and Monitoring Command Reference
02-NQA commands
02-NQA commands 785.68 KB
NQA commands· 1
NQA client commands· 1
acct-app-id· 1
advantage-factor 1
auth-app-id· 2
codec-type· 3
data-fill 3
data-size· 5
description· 6
destination ip· 7
destination ipv6· 7
destination port 8
disconnect-mode· 9
display nqa agent 10
display nqa history· 11
display nqa reaction counters· 13
display nqa result 15
display nqa statistics· 24
display nqa template statistics· 33
exchange-port enable· 35
expect { data | hex-data } 36
expect { failed-data | hex-failed-data } 38
expect { hex-persistent-data | persistent-data } 39
expect failed-status· 41
expect ip· 41
expect ipv6· 42
expect status· 43
filename· 44
frequency· 44
frequency-adjustment 45
hex-data-fill 46
history-record enable· 47
history-record keep-time· 48
history-record number 48
init-ttl 49
key· 50
local-host-name· 50
local-realm-name· 51
lsr-path· 52
mailbox· 52
max-failure· 53
mode· 53
next-hop ip· 54
next-hop ipv6· 55
no-fragment enable· 56
nqa· 56
nqa agent enable· 57
nqa agent running-test limit 57
nqa schedule· 58
nqa template· 60
operation (FTP operation view) 61
operation (HTTP/HTTP2 operation view) 62
operation (HTTPS template view) 63
out interface· 64
password· 64
port-detect enable· 65
probe count 66
probe method incremental 68
probe packet-interval 68
probe packet-number 69
probe packet-timeout 70
probe timeout 70
product name· 71
proxy-url 72
raw-request 73
raw-request-hex· 74
reaction checked-element { jitter-ds | jitter-sd } 75
reaction checked-element { owd-ds | owd-sd } 76
reaction checked-element icpif 77
reaction checked-element mos· 78
reaction checked-element packet-loss· 79
reaction checked-element probe-duration· 80
reaction checked-element probe-fail (for trap) 82
reaction checked-element probe-fail (for trigger) 83
reaction checked-element rtt 84
reaction trap· 85
reaction trigger per-probe· 86
reaction trigger probe-fail 87
reaction trigger probe-pass· 88
request-method· 88
resolve-target 89
resolve-type· 90
resource-release { data-fill | hex-data-fill } 90
route-option bypass-route· 91
source interface (ICMP echo/UDP tracert operation view) 92
source ip· 93
source ipv6· 94
source port 95
ssl-client-policy· 96
statistics hold-time· 96
statistics interval 97
statistics max-group· 98
target-only· 98
tos· 99
transport-protocol 99
ttl 100
type· 101
url 102
username· 104
vendor-id· 105
vendor-specific-app-id· 105
version (HTTP/HTTPS operation view/HTTPS template view) 106
NQA server commands· 107
display nqa server 107
nqa server enable· 108
nqa server tcp-connect 108
nqa server udp-echo· 109
NQA commands
NQA client commands
acct-app-id
Use acct-app-id to configure an accounting application ID for Diameter probe packets.
Use undo acct-app-id to restore the default.
acct-app-id application-id
undo acct-app-id
No accounting application ID is configured for Diameter probe packets.
Diameter template view
application-id: Specifies an accounting application ID for Diameter probe packets, in the range of 1 to 4294967295.
Use this command to configure the value of the Acct-Application-Id Attribute-Value Pair(AVP) for Diameter probe packets. This value is used to identify the application ID supported by the local Diameter node.
# Configure accounting application ID 2000 for Diameter probe packets.
[Sysname] nqa template diameter diametertplt
[Sysname-nqatplt-diameter-diametertplt] acct-app-id 2000
advantage-factor
Use advantage-factor to set the advantage factor to be used for calculating Mean Opinion Scores (MOS) and Calculated Planning Impairment Factor (ICPIF) values.
Use undo advantage-factor to restore the default.
advantage-factor factor
The advantage factor is 0.
Voice operation view
factor: Specifies the advantage factor in the range of 0 to 20.
The evaluation of voice quality depends on users' tolerance for voice quality. For users with higher tolerance for voice quality, use the advantage-factor command to set an advantage factor. When the system calculates the ICPIF value, it subtracts the advantage factor to modify ICPIF and MOS values for voice quality evaluation.
# Set the advantage factor to 10 for the voice operation.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] advantage-factor 10
auth-app-id
Use auth-app-id to configure an authentication and authorization application ID for Diameter probe packets.
Use undo auth-app-id to restore the default.
auth-app-id application-id
undo auth-app-id
No authentication and authorization application ID is configured for Diameter probe packets.
application-id: Specifies an authentication and authorization application ID for Diameter probe packets, in the range of 1 to 4294967295.
Use this command to configure the value of the Auth-Application-Id AVP for Diameter probe packets. This value is used to identify the application ID supported by the local Diameter node.
# Configure authentication and authorization application ID 1000 for Diameter probe packets.
[Sysname-nqatplt-diameter-diametertplt] auth-app-id 1000
codec-type
Use codec-type to configure the codec type for the voice operation.
Use undo codec-type to restore the default.
codec-type { g711a | g711u | g729a }
undo codec-type
The codec type for the voice operation is G.711 A-law.
g711a: Specifies G.711 A-law codec type.
g711u: Specifies G.711 µ-law codec type
g729a: Specifies G.729 A-law codec type.
# Set the codec type to g729a for the voice operation.
[Sysname-nqa-admin-test-voice] codec-type g729a
data-fill
Use data-fill to configure the payload fill string for probe packets.
Use undo data-fill to restore the default.
data-fill string [ raw ]
undo data-fill
The default payload fill string is the hexadecimal string 00010203040506070809.
ICMP/UDP echo operation view
Path jitter/UDP jitter/voice operation view
ICMP/TCP/UDP template view
string: Specifies a case-sensitive string of 1 to 200 characters.
raw: Fills the packet payload with the specified payload fill string without truncation or repetition to fit the payload size. This keyword is available only in UDP template view.
How the string is filled depends on the operation type.
·     For the ICMP echo operation, the string fills the whole payload of an ICMP echo request.
·     For the UDP echo operation, the first five bytes in the payload of a UDP packet are for special purpose. The string fills the remaining part of payload.
·     For the UDP jitter operation, the first 68 bytes in the payload of a UDP packet are for special purpose. The string fills the remaining part of the payload.
·     For the voice operation, the first 16 bytes in the payload of a UDP packet are for special purpose. The string fills the remaining part of the payload.
·     For the path jitter operation, the first four bytes in the payload of an ICMP echo request are for special purpose. The string fills the remaining part of payload.
With the raw keyword specified, the payload fill string will be used exactly as specified to fill the packet payload.
Without the raw keyword, the payload fill string will be truncated at the end or cyclically repeated to fit the payload size of the probe packet.
For example, if you configure the payload fill string as abcd:
·     Probe packet with a payload size of 3 bytes will be filled with abc.
·     Probe packet with a payload size of 6 bytes will be filled with adcdab.
In UDP template view, the probe packets without the raw keyword specified contain special characters. For a destination device other than an H3C device, provide the raw keyword because it can identify only probe packets without any special characters contained. Make sure the payload fill string specified on the client can be identified by the destination device.
If the destination device is an H3C device, the raw keyword is not a must because the H3C device can identify the probe packets that contain special characters. As a best practice, do not specify the raw keyword.
# Specify abcd as the payload fill string for ICMP echo requests.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
# In TCP template view, specify abcd as the payload fill string for probe packets.
[Sysname] nqa template tcp tcptplt
[Sysname-nqatplt-tcp-tcptplt] data-fill abcd
data-size
Use data-size to set the payload size for each probe packet.
Use undo data-size to restore the default.
data-size size
undo data-size
The default payload size of a probe packet for different operations is described in Table 1.
Table 1 Default payload size of a probe packet
Operation type
Codec type
Default size (bytes)
ICMP echo
N/A
100
UDP echo
N/A
100
UDP jitter
N/A
100
UDP tracert
N/A
100
Path jitter
N/A
100
Voice
G.711 A-law
172
Voice
G.711 µ-law
172
Voice
G.729 A-law
32
ICMP/UDP/tracert template view
size: Specifies the payload size in bytes. The value range for the size argument varies by operation type.
·     For the ICMP echo, UDP echo, or UDP tracert operation, the value range is 20 to 65507.
·     For the UDP jitter or path jitter operation, the value range is 68 to 65507.
·     For the voice operation, the value range is 16 to 65507.
In ICMP echo and path jitter operations, the command sets the payload size for each ICMP echo request.
In UDP echo, UDP jitter, UDP tracert, and voice operations, the command sets the payload size for each UDP packet.
# Set the payload size to 80 bytes for each ICMP echo request.
[Sysname-nqa-admin-test-icmp-echo] data-size 80
# In ICMP template view, set the payload size to 80 bytes for each probe packet.
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] data-size 80
description
Use description to configure a description for an NQA operation, such as the operation type or purpose.
No description is configured for an NQA operation.
ICMP echo/UDP echo/TCP operation view
ARP/DHCP/DLSw/DNS/FTP/HTTP operation view
ICMP jitter/UDP jitter/path jitter/voice operation view
Any NQA template view
text: Specifies a description, a case-sensitive string of 1 to 200 characters.
# Configure the description as icmp-probe for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
# In ICMP template view, configure the description as icmp-probe for the NQA operation.
[Sysname-nqatplt-icmp-icmptplt] description icmp-probe
destination ip
Use destination ip to configure the destination IPv4 address for the operation.
Use undo destination ip to restore the default.
destination ip ip-address
undo destination ip
No destination IPv4 address is configured for an operation.
ICMP echo/TCP/UDP echo operation view
ARP/DHCP/DLSw/DNS operation view
ICMP jitter/path jitter/UDP jitter/voice operation view
ARP/DNS/ICMP/IMAP/POP3/RADIUS authentication/RADIUS accounting/SMTP/SSL/TCP/TCP half open/UDP/WAP/tracert template view
ip-address: Specifies the destination IPv4 address for the operation.
# Specify 10.1.1.1 as the destination IPv4 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# In ICMP template view, specify 10.1.1.1 as the destination IPv4 address for the ICMP echo operation.
[Sysname-nqatplt-icmp-icmptplt] destination ip 10.1.1.1
destination ipv6
Use destination ipv6 to configure the destination IPv6 address for the operation.
Use undo destination ipv6 to restore the default.
destination ipv6 ipv6-address
No destination IPv6 address is configured for an operation.
ICMP echo/TCP/UDP echo/UDP jitter operation view
DNS/ICMP/IMAP/POP3/RADIUS authentication/RADIUS accounting/SMTP/SIP/SSL/TCP/TCP half open/UDP/WAP template view
ipv6-address: Specifies the destination IPv6 address for the operation. IPv6 link-local addresses are not supported.
# Specify 1::1 as the destination IPv6 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] destination ipv6 1::1
# In ICMP template view, specify 1::1 as the destination IPv6 address for the operation.
[Sysname-nqatplt-icmp-icmptplt] destination ipv6 1::1
destination port
Use destination port to configure the destination port number for the operation.
Use undo destination port to restore the default.
destination port port-number
The destination port numbers for NQA operations are as follows:
·     33434 for the UDP tracert operation.
No destination port number is configured for other types of operations.
The destination port numbers for NQA templates are as follows:
·     53 for the DNS template.
·     143 for the IMAP template.
·     110 for the POP3 template.
·     1812 for the RADIUS authentication template.
·     1813 for the RADIUS accounting template.
·     5060 for the SIP template.
·     25 for the SMTP template.
·     9201 for the WAP template.
·     33434 for the UDP tracert template.
No destination port number is configured for other types of NQA templates.
DNS/IMAP/POP3/RADIUS authentication/RADIUS accounting/SIP/SMTP/SSL/TCP/TCP half open /UDP/WAP/tracert template view
port-number: Specifies the destination port number for the operation, in the range of 1 to 65535.
For a TCP half open template, this command is required only if the port-detect enable command is configured.
# Set the destination port number to 9000 for the UDP echo operation.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
# In TCP template view, set the destination port number to 9000 for the NQA operation.
[Sysname-nqatplt-tcp-tcptplt] destination port 9000
port-detect enable
disconnect-mode
Use disconnect-mode to set a TCP connection termination mode.
Use undo disconnect-mode to restore the default.
disconnect-mode { fin | rst }
The TCP operation uses the RST mode to terminate TCP connections.
TCP template view
fin: Sets the FIN mode for TCP connection termination.
rst: Sets the RST mode for TCP connection termination.
A TCP operation includes two processes: establishing a TCP connection through the three-way handshake and terminating the TCP connection. When both processes complete, the TCP operation succeeds.
You can use the command to set the connection termination mode for the TCP operation:
·     RST mode—The server terminates the TCP connection after receiving the RST request from the client.
·     FIN mode—The server terminates the TCP connection after the four-way handshake between the client and the server.
Use the FIN mode when the RST mode is not supported on the client.
# In TCP template view, set the FIN mode for TCP connection termination.
[Sysname] nqa template tcp test
[Sysname-nqatplt-tcp-test] disconnect-mode fin
display nqa agent
Use display nqa agent to display NQA client status information.
display nqa agent
The output from the display nqa agent command does not include the TWAMP or TWAMP Light test data.
# Display NQA client status information.
<Sysname> display nqa agent
NQA client status: Enable
Configured NQA entries: 5120
Configured NQA templates: 5120
Configured max number of running NQA operations: 4096
NQA operations in packet-sending state4000
Running NQA entries: 2048
Running NQA instances: 1024
NQA client status
NQA client status. Options include:
·     Enable—The NQA client feature is enabled.
·     Disable—The NQA client feature is disabled.
Number of configured NQA operations.
Number of configured NQA templates.
Maximum number of configured running NQA operations.
Number of NQA operations in packet sending state.
Running NQA entries
Number of NQA operations in running state, which can be the state of packet sending or the state for waiting to send packets.
Number of NQA instances in running state.
display nqa history
Use display nqa history to display the history records of NQA operations.
display nqa history [ admin-name operation-tag ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the history records of all NQA operations.
To successfully display history records with this command, first use the history-record enable command to enable the saving of history records for the NQA operation. By default, the saving of history records is enabled for the UDP tracert NQA operation and disabled for other types of NQA operations.
The display nqa history command does not display the results or statistics of the following operations:
·     ICMP jitter.
·     Path jitter.
·     UDP jitter.
·     Voice.
To view the results or statistics of the ICMP jitter, path jitter, UDP jitter, and voice operations, use the display nqa result or display nqa statistics command.
# Display the history records of the UDP tracert operation with administrator name administrator and operation tag tracert.
<Sysname> display nqa history administrator tracert
NQA entry (admin administrator, tag tracert) history records:
Index      TTL  Response  Hop IP          Status          Time
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:06.2
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:05.2
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:04.2
1          1    328       3.1.1.2         Succeeded       2013-09-09 14:46:03.2
1          1    328       3.1.1.1         Succeeded       2013-09-09 14:46:02.2
1          1    328       3.1.1.1         Succeeded       2013-09-09 14:46:01.2
# Display the history records of the NQA operation with administrator name administrator and operation tag test.
<Sysname> display nqa history administrator test
NQA entry (admin administrator, tag test) history records:
  Index      Response     Status           Time
  10         329          Succeeded        2011-04-29 20:54:26.5
  9          344          Succeeded        2011-04-29 20:54:26.2
  8          328          Succeeded        2011-04-29 20:54:25.8
  7          328          Succeeded        2011-04-29 20:54:25.5
  6          328          Succeeded        2011-04-29 20:54:25.1
  5          328          Succeeded        2011-04-29 20:54:24.8
  4          328          Succeeded        2011-04-29 20:54:24.5
  3          328          Succeeded        2011-04-29 20:54:24.1
  2          328          Succeeded        2011-04-29 20:54:23.8
  1          328          Succeeded        2011-04-29 20:54:23.4
Index
History record ID.
The history records in one UDP tracert operation have the same ID.
TTL
If the routing table bypass feature is not enabled in the operation, this field displays the TTL value in the probe packet.
If the routing table bypass feature is enabled, the value of this field varies by the init-ttl command. However, the actual TTL value in the probe packet is fixed at 1.
Response
Round-trip time if the operation succeeds, timeout time upon timeout, or 0 if the operation cannot be completed, in milliseconds.
Hop IP
IP address of the node that sent the reply packet.
Status
Status of the operation result:
·     Succeeded.
·     Unknown error. (This state triggers the Track state switchover in NQA-Track collaboration.)
·     Internal error. (This state does not trigger the Track state switchover in NQA-Track collaboration.)
·     Timeout. (This state triggers the Track state switchover in NQA-Track collaboration.)
Time
Time when the operation was completed.
Use display nqa reaction counters to display the current monitoring results of reaction entries.
display nqa reaction counters [ admin-name operation-tag [ item-number ] ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the current monitoring results of reaction entries for all NQA operations.
item-number: Specifies a reaction entry by its ID in the range of 1 to 10. If you do not specify a reaction entry, the command displays the results of all reaction entries.
The result fields display hyphens (-) if the threshold type is the average value or if the monitored performance metric is ICPIF or MOS of the voice operation.
The monitoring results of an operation are accumulated, and are not cleared after the operation completes.
# Display the monitoring results of all reaction entries of the ICMP echo operation with administrator name admin and operation tag test.
<Sysname> display nqa reaction counters admin test
NQA entry (admin admin, tag test) reaction counters:
  Index  Checked Element  Threshold Type  Checked Num  Over-threshold Num
  1      probe-duration   accumulate      12           4
  2      probe-duration   average         -            -
  3      probe-duration   consecutive     160          56
  4      probe-fail       accumulate      12           0
  5      probe-fail       consecutive     162          2
Index
ID of a reaction entry.
Checked Element
Monitored performance metric.
The available performance metrics vary by NQA operation type. For more information, see Table 5 and Table 6.
Threshold Type
Threshold type.
Checked Num
Number of targets that have been monitored for data collection.
Over-threshold Num
Number of threshold violations.
Table 5 Monitored performance metrics for ARP/DHCP/DLSw/DNS/FTP/HTTP/ICMP echo/TCP/UDP echo operations
Threshold type
Collect data in
Checked Num
Over-threshold Num
probe-duration
accumulate
Probes after the operation starts.
Number of completed probes.
Number of probes with duration exceeding the threshold.
average
N/A
N/A
N/A
consecutive
probe-fail
accumulate
Number of probe failures.
consecutive
Table 6 Monitored performance metrics for ICMP jitter/UDP jitter/voice operations
Threshold type
Collect data in
Checked Num
Over-threshold Num
RTT
accumulate
Packets sent after the operation starts.
Number of sent packets.
Number of packets with round-trip time exceeding threshold.
average
N/A
N/A
N/A
jitter-DS/jitter-SD
accumulate
Number of packets with the one-way jitter exceeding the threshold.
average
N/A
N/A
N/A
OWD-DS/OWD-SD
N/A
Number of packets with the one-way delay exceeding the threshold.
packet-loss
accumulate
Total packet loss.
ICPIF/MOS (available only for the voice operation)
N/A
N/A
N/A
N/A
display nqa result
Use display nqa result to display the most recent result of an NQA operation.
display nqa result [ admin-name operation-tag ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the most recent results of all NQA operations.
# Display the most recent result of the ARP operation with administrator name admin and operation tag test.
<Sysname> display nqa result admin test
NQA entry (admin admin, tag test) test results:
    Send operation times: 1              Receive response times: 1
    Min/Max/Average round trip time: 35/35/35
    Square-Sum of round trip time: 1225
    Last succeeded probe time: 2011-05-29 10:50:33.2
  Extended results:
    Packet loss ratio: 0%
    Failures due to timeout: 0
    Failures due to internal error: 0
    Failures due to other errors: 0
# Display the most recent result of the TCP operation with administrator name admin and operation tag test.
  Extended results:
    Failures due to disconnect: 0
    Failures due to no connection: 0
# Display the most recent result of the ICMP jitter operation with administrator name admin and operation tag test.
    Send operation times: 10             Receive response times: 10
    Min/Max/Average round trip time: 1/2/1
    Square-Sum of round trip time: 13
    Last packet received time: 2015-03-09 17:40:29.8
  Extended results:
    Packet loss ratio: 0.0%
    Packets out of sequence: 0
    Packets arrived late: 0
  ICMP-jitter results:
   RTT number: 10
    Min positive SD: 0                     Min positive DS: 0
    Max positive SD: 0                     Max positive DS: 0
    Positive SD number: 0                  Positive DS number: 0
    Positive SD sum: 0                     Positive DS sum: 0
    Positive SD average: 0                 Positive DS average: 0
    Positive SD square-sum: 0              Positive DS square-sum: 0
    Min negative SD: 1                     Min negative DS: 2
    Max negative SD: 1                     Max negative DS: 2
    Negative SD number: 1                  Negative DS number: 1
    Negative SD sum: 1                     Negative DS sum: 2
    Negative SD average: 1                 Negative DS average: 2
    Negative SD square-sum: 1              Negative DS square-sum: 4
    SD average: 1                          DS average: 2
  One way results:
    Max SD delay: 1                        Max DS delay: 2
    Min SD delay: 1                        Min DS delay: 2
    Number of SD delay: 1                  Number of DS delay: 1
    Sum of SD delay: 1                     Sum of DS delay: 2
    Square-Sum of SD delay: 1              Square-Sum of DS delay: 4
    Lost packets for unknown reason: 0
# Display the most recent result of the UDP jitter operation with administrator name admin and operation tag test.
    Min/Max/Average round trip time: 15/46/26
    Square-Sum of round trip time: 8103
    Last packet received time: 2011-05-29 10:56:38.7
  Extended results:
  UDP-jitter results:
   RTT number: 10
    Min positive SD: 8                     Min positive DS: 8
    Max positive SD: 18                    Max positive DS: 8
    Positive SD number: 5                  Positive DS number: 2
    Positive SD sum: 75                    Positive DS sum: 32
    Positive SD average: 15                Positive DS average: 16
    Positive SD square-sum: 1189           Positive DS square-sum: 640
    Min negative SD: 8                     Min negative DS: 1
    Max negative SD: 24                    Max negative DS: 30
    Negative SD number: 4                  Negative DS number: 7
    Negative SD sum: 56                    Negative DS sum: 99
    Negative SD average: 14                Negative DS average: 14
    Negative SD square-sum: 946            Negative DS square-sum: 1495
    SD average: 14                         DS average: 14
  One way results:
    Max SD delay: 22                       Max DS delay: 23
    Min SD delay: 7                        Min DS delay: 7
    Number of SD delay: 10                 Number of DS delay: 10
    Sum of SD delay: 125                   Sum of DS delay: 132
    Square-Sum of SD delay: 1805           Square-Sum of DS delay: 1988
    SD lost packets: 0                     DS lost packets: 0
# Display the most recent result of the voice operation with administrator name admin and operation tag test.
    Send operation times: 1000           Receive response times: 0
    Min/Max/Average round trip time: 0/0/0
    Square-Sum of round trip time: 0
    Last packet received time: 0-00-00 00:00:00.0
  Extended results:
    Packet loss ratio: 100.0%
    Failures due to timeout: 1000
  Voice results:
   RTT number: 0
    Min negative SD: 0                     Min negative DS: 0
    Max negative SD: 0                     Max negative DS: 0
    Negative SD number: 0                  Negative DS number: 0
    Negative SD sum: 0                     Negative DS sum: 0
    Negative SD average: 0                 Negative DS average: 0
    Negative SD square-sum: 0              Negative DS square-sum: 0
    SD average: 0                          DS average: 0
  One way results:
    Max SD delay: 0                        Max DS delay: 0
    Min SD delay: 0                        Min DS delay: 0
    Number of SD delay: 0                  Number of DS delay: 0
    Sum of SD delay: 0                     Sum of DS delay: 0
    Square-Sum of SD delay: 0              Square-Sum of DS delay: 0
    Lost packets for unknown reason: 1000
  Voice scores:
    MOS value: 0.99                        ICPIF value: 87
# Display the most recent result of the path jitter operation with administrator name admin and operation tag test.
  Hop IP 192.168.40.210
    Basic Results:
      Min/Max/Average round trip time: 1/1/1
      Square-Sum of round trip time: 10
    Extended Results:
    Path-Jitter Results:
      Jitter number: 9
        Min/Max/Average jitter: 0/0/0
      Positive jitter number: 0
        Min/Max/Average positive jitter: 0/0/0
        Sum/Square-Sum positive jitter: 0/0
      Negative jitter number: 0
        Min/Max/Average negative jitter: 0/0/0
        Sum/Square-Sum negative jitter: 0/0
  Hop IP 192.168.50.209
    Basic Results:
    Extended Results:
      Jitter number: 9
# Display the most recent result of the UDP tracert operation with administrator name admin and operation tag test.
    Send operation times: 6              Receive response times: 6
    Last succeeded probe time: 2013-09-09 14:23:24.5
  Extended results:
  UDP-tracert results:
    TTL    Hop IP             Time
    1      3.1.1.1            2013-09-09 14:23:24.5
    2      4.1.1.1            2013-09-09 14:23:24.5
Table 7 Command output
NQA entry (admin admin-name, tag operation-tag) test results
NQA operation results. The administrator name (admin-name) and operation tag (operation-tag) are configured in the nqa command.
Data collecting in progress
The operation is in progress.
Path jitter result is not available
No result is generated for the operation.
Number of operations.
Number of response packets received.
Minimum/maximum/average round-trip time in milliseconds.
Square sum of round-trip time.
Time when the last successful probe was completed. If no probes are successful in an operation, the field displays 0.
This field is not available for UDP jitter, path jitter, and voice operations.
Time when the last response packet was received. If no response packets in a probe were received, the field displays 0.
This field is available only for UDP jitter and voice operations.
Extended results
Results of extended items.
Packet loss ratio
Average packet loss ratio. For ICMP jitter, UDP jitter, and voice operations, the accuracy of the field value is 0.1%.
Number of timeout occurrences in an operation.
Number of disconnections by the peer.
Number of failures to connect with the peer.
Number of failures due to internal errors.
Failures due to other errors.
Number of failures due to out-of-sequence packets.
ICMP-jitter results
ICMP jitter operation results.
This field is available only for the ICMP jitter operation.
Number of response packets received after a probe times out.
UDP-jitter results
UDP jitter operation results.
This field is available only for the UDP jitter operation.
Voice results
Voice operation results.
This field is available only for the voice operation.
RTT number
Min positive SD
Minimum positive jitter from source to destination.
Min positive DS
Minimum positive jitter from destination to source.
Max positive SD
Maximum positive jitter from source to destination.
Max positive DS
Maximum positive jitter from destination to source.
Positive SD number
Number of positive jitters from source to destination.
Positive DS number
Number of positive jitters from destination to source.
Positive SD sum
Sum of positive jitters from source to destination.
Positive DS sum
Sum of positive jitters from destination to source.
Positive SD average
Average positive jitters from source to destination.
Positive DS average
Average positive jitters from destination to source.
Square sum of positive jitters from source to destination.
Square sum of positive jitters from destination to source.
Min negative SD
Minimum absolute value among negative jitters from source to destination.
Min negative DS
Minimum absolute value among negative jitters from destination to source.
Max negative SD
Maximum absolute value among negative jitters from source to destination.
Max negative DS
Maximum absolute value among negative jitters from destination to source.
Negative SD number
Number of negative jitters from source to destination.
Negative DS number
Number of negative jitters from destination to source.
Negative SD sum
Sum of absolute values of negative jitters from source to destination.
Negative DS sum
Sum of absolute values of negative jitters from destination to source.
Negative SD average
Average absolute value of negative jitters from source to destination.
Negative DS average
Average absolute value of negative jitters from destination to source.
Square sum of negative jitters from source to destination.
Square sum of negative jitters from destination to source.
SD average
Average value of jitters from source to destination.
DS average
Average value of jitters from destination to source.
One way results
Unidirectional delay, in milliseconds.
This field is available only for the ICMP jitter, UDP jitter, and voice operations.
Max SD delay
Maximum delay from source to destination.
Max DS delay
Maximum delay from destination to source.
Min SD delay
Minimum delay from source to destination.
Min DS delay
Minimum delay from destination to source.
Number of SD delay
Number of delays from source to destination.
Number of DS delay
Number of delays from destination to source.
Sum of SD delay
Sum of delays from source to destination.
Sum of DS delay
Sum of delays from destination to source.
Square sum of delays from source to destination.
Square sum of delays from destination to source.
SD lost packets
Number of lost packets from the source to the destination.
DS lost packets
Number of lost packets from the destination to the source.
Number of lost packets for unknown reasons.
Voice scores
Voice parameters.
MOS value
MOS value calculated for the voice operation.
ICPIF value
ICPIF value calculated for the voice operation.
Hop IP
IP address of the hop.
This field is available only for the path jitter operation.
Path-jitter results
Path jitter operation results.
Jitter number
Number of jitters.
Minimum/maximum/average jitter in milliseconds.
Number of positive jitter.
Minimum/maximum/average positive jitter in milliseconds.
Sum/square sum of the positive jitter.
Number of negative jitter.
Minimum/maximum/average negative jitter in milliseconds.
Sum/square sum of the negative jitter.
TTL
Hop IP
Time
Time when the NQA client received the reply packet.
Status
Status of the operation or a test in the operation. The value can be:
·     Succeeded.
·     Failed.
·     In progress.
·     Aborted—The test was manually aborted.
·     Timeout.
·     Unknown error.
This field displays two hyphens (--) for a test whose status is meaningless..
Last test
Last completed test. The value can be:
·     CIR test
·     PIR test
·     Traffic policing test
·     Service performance test
Estimated total time
Total time that the operation was estimated to take, in seconds.
Actual test time used
Actual time taken to complete the operation, in seconds.
The timer used to measure the test start time and end time is accurate to 1 second. Therefore, a difference of up to 1 second might exist between the value displayed in this field and the time duration between the start and end of the test.
CIR test (with the step of 1)
Information about the CIR test with a step count of 1.
The number of steps in a CIR test can be set to any value in the range of 1 to 1000.
Start time
Start time of the test.
End time
End time of the test.
Min/Max/Average IR(Kbps)
Minimum, maximum, and average information rates in kbps.
Min/Max/Average FTD(us)
Minimum, maximum, and average frame transfer delays, in μs.
Min/Max/Average FDV(us)
Minimum, maximum, and average frame delay variations, in μs.
FL count/FLR
Number of lost frames and the frame loss ratio.
Packets out of order
Number of out-of-order packets.
Severely Err Secs/AVAIL
Total number of severely errored seconds (SESs) and the network availability ratio (AVAIL).
A severely errored second occurs when the ratio of lost frames during a one-second interval exceeds 50%.
AVAIL is calculated as follows: AVAIL = Total seconds in available periods / total seconds taken by the test.
·     The network is in an unavailable period after 10 consecutive SESs are recorded. The unavailable period ends when 10 consecutive non-SESs are recorded.
·     The network is in an available period after 10 consecutive non-SESs. The available period ends when 10 consecutive SESs are recorded.
By default, the test is considered to start in an available period.
PIR test (color green)
Statistics about the green frames in the PIR test.
PIR test (color yellow)
Statistics about the yellow frames in the PIR test.
PIR test (total)
Summary statistics about the PIR test.
PIR test (color-blind)
Statistics about the PIR test in non-color-aware mode.
Traffic policing test (color green)
Statistics about the green frames in the traffic policing test.
Traffic policing test (color yellow)
Statistics about the yellow frames in the traffic policing test.
Traffic policing test (total)
Summary statistics about the traffic policing test.
Traffic policing test (color-blind)
Statistics about the traffic policing test in non-color-aware mode.
Statistics about the service performance test.
Basic results
Results of basic items.
Min-jitter(ns)
Minimum jitter in nanoseconds.
Max-jitter(ns)
Maximum jitter in nanoseconds.
Avg-jitter(ns)
Average jitter in nanoseconds.
Sent packets
Number of packets sent.
Received packets
Number of packets received.
Use display nqa statistics to display NQA operation statistics.
display nqa statistics [ admin-name operation-tag ]
The statistics are generated after the NQA operation completes. If you execute the display nqa statistics command before the operation completes, the statistics are displayed as all 0s.
If a reaction entry is configured, the command displays the monitoring results of the reaction entry in the period specified by the statistics internal command. The result fields display hyphens (-) if the threshold type is average value or if the monitored performance metric is ICPIF or MOS for the voice operation.
If you do not specify an NQA operation, this command displays statistics for all NQA operations.
# Display the statistics for the ARP operation with administrator name admin and operation tag test.
<Sysname> display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
  NO. : 1
    Start time: 2007-01-01 09:30:20.0
    Life time: 2 seconds
    Min/Max/Average round trip time: 13/13/13
    Square-Sum of round trip time: 169
  Extended results:
# Display the statistics for the TCP operation with administrator name admin and operation tag test.
  NO. : 1
  Extended results:
# Display the statistics for the ICMP jitter operation with administrator name admin and operation tag test.
  NO. : 1
    Start time: 2015-03-09 17:42:10.7
    Life time: 156 seconds
    Send operation times: 1560           Receive response times: 1560
    Square-Sum of round trip time: 1563
  Extended results:
   RTT number: 1560
    Min positive SD: 1                     Min positive DS: 1
    Max positive SD: 1                     Max positive DS: 2
    Positive SD number: 18                 Positive DS number: 46
    Positive SD sum: 18                    Positive DS sum: 49
    Positive SD average: 1                 Positive DS average: 1
    Positive SD square-sum: 18             Positive DS square-sum: 55
    Min negative SD: 1                     Min negative DS: 1
    Negative SD number: 24                 Negative DS number: 57
    Negative SD sum: 24                    Negative DS sum: 58
    Negative SD average: 1                 Negative DS average: 1
    Negative SD square-sum: 24             Negative DS square-sum: 60
   SD average: 1                          DS average: 1
  One way results:
    Min SD delay: 1                        Min DS delay: 1
    Number of SD delay: 4                  Number of DS delay: 4
    Sum of SD delay: 4                     Sum of DS delay: 5
    Square-Sum of SD delay: 4              Square-Sum of DS delay: 7
  Reaction statistics:
    1      jitter-DS        accumulate      1500         10
    2      jitter-SD        average         -            -
    3      OWD-DS           -               1560         2
    4      OWD-SD           -               1560         0
    5      packet-loss      accumulate      0            0
    6      RTT              accumulate      1560         0
# Display the statistics for the UDP jitter operation with administrator name admin and operation tag test.
  NO. : 1
    Start time: 2007-01-01 09:33:22.3
    Life time: 23 seconds
    Send operation times: 100            Receive response times: 100
    Min/Max/Average round trip time: 1/11/5
    Square-Sum of round trip time: 24360
  Extended results:
  UDP-jitter results:
   RTT number: 550
    Max positive SD: 7                     Max positive DS: 1
    Positive SD number: 220                Positive DS number: 97
    Positive SD sum: 283                   Positive DS sum: 287
    Positive SD average: 1                 Positive DS average: 2
    Positive SD square-sum: 709            Positive DS square-sum: 1937
    Min negative SD: 2                     Min negative DS: 1
    Max negative SD: 10                    Max negative DS: 1
    Negative SD number: 81                 Negative DS number: 94
    Negative SD sum: 556                   Negative DS sum: 191
    Negative SD average: 6                 Negative DS average: 2
    Negative SD square-sum: 4292           Negative DS square-sum: 967
    SD average: 2                          DS average: 2
  One way results:
    Max SD delay: 5                        Max DS delay: 5
    Number of SD delay: 550                Number of DS delay: 550
    Sum of SD delay: 1475                  Sum of DS delay: 1201
    Square-Sum of SD delay: 5407           Square-Sum of DS delay: 3959
    1      jitter-DS        accumulate      90           25
    3      OWD-DS           -               100          24
    4      OWD-SD           -               100          13
    6      RTT              accumulate      100          52
# Display the statistics for the voice operation with administrator name admin and operation tag test.
  NO. : 1
    Start time: 2007-01-01 09:33:45.3
    Life time: 120 seconds
    Min/Max/Average round trip time: 1/12/7
    Square-Sum of round trip time: 620
  Extended results:
  Voice results:
   RTT number: 10
    Min positive SD: 3                     Min positive DS: 1
    Max positive SD: 10                    Max positive DS: 1
    Positive SD number: 3                  Positive DS number: 2
    Positive SD sum: 18                    Positive DS sum: 2
    Positive SD average: 6                 Positive DS average: 1
    Positive SD square-sum: 134            Positive DS square-sum: 2
    Min negative SD: 3                     Min negative DS: 1
    Max negative SD: 9                     Max negative DS: 1
    Negative SD number: 4                  Negative DS number: 2
    Negative SD sum: 25                    Negative DS sum: 2
    Negative SD average: 6                 Negative DS average: 1
    Negative SD square-sum: 187            Negative DS square-sum: 2
    SD average: 6                          DS average: 1
  One way results:
  Voice scores:
    Max MOS value: 4.40                    Min MOS value: 4.40
    Max ICPIF value: 0                     Min ICPIF value: 0
    1      ICPIF            -               -            -
    2      MOS              -               -            -
# Display the statistics for the path jitter operation with administrator name admin and operation tag test.
  NO. : 1
  Path 1:
    Basic Results:
    Extended Results:
      Jitter number: 9
    Basic Results:
    Extended Results:
      Jitter number: 9
Table 8 Command output
No.
Statistics group ID.
Start time
Time when the operation started.
Life time
Duration of the operation in seconds.
Number of probe packets sent.
Packet loss ratio
ICMP-jitter results
UDP-jitter results
Voice results
RTT number
Min positive SD
Min positive DS
Max positive SD
Max positive DS
Positive SD number
Positive DS number
Positive SD sum
Positive DS sum
Positive SD average
Positive DS average
Min negative SD
Min negative DS
Max negative SD
Max negative DS
Negative SD number
Negative DS number
Negative SD sum
Negative DS sum
Negative SD average
Negative DS average
SD average
DS average
One way results
Unidirectional delay result, in milliseconds.
Max SD delay
Max DS delay
Min SD delay
Min DS delay
Number of SD delay
Number of DS delay
Sum of SD delay
Sum of DS delay
SD lost packets
DS lost packets
Voice scores
Voice parameters.
Max MOS value
Maximum MOS value.
Min MOS value
Minimum MOS value.
Max ICPIF value
Maximum ICPIF value.
Min ICPIF value
Minimum ICPIF value.
Reaction statistics
Statistics about the reaction entry in the counting interval.
Index
Checked Element
Monitored element.
Threshold Type
Threshold type.
Checked Num
Over-threshold Num
Path
Serial number for the path in the path jitter operation.
Hop IP
Path-jitter results
Jitter number
Number of jitters.
Number of positive jitters.
Sum/square sum of positive jitters.
Number of negative jitters.
Sum/square sum of negative jitters.
Table 9 Monitored performance metrics for ARP/DHCP/DLSw/DNS/FTP/HTTP/ICMP echo/TCP/UDP echo operations
Threshold type
Collect data in
Checked Num
Over-threshold Num
probe-duration
accumulate
Probes in the counting interval.
Number of probes of which the duration exceeds the threshold.
average
N/A
N/A
N/A
consecutive
probe-fail
accumulate
consecutive
Table 10 Monitored performance metrics for ICMP jitter/UDP jitter/voice operations
Threshold type
Collect data in
Checked Num
Over-threshold Num
RTT
accumulate
Packets sent in the counting interval.
Number of packets of which the round-trip time exceeds the threshold.
average
N/A
N/A
N/A
jitter-DS/jitter-SD
accumulate
Number of packets of which the one-way jitter exceeds the threshold.
average
N/A
N/A
N/A
OWD-DS/OWD-SD
N/A
Number of packets of which the one-way delay exceeds the threshold.
packet-loss
accumulate
Number of packet loss.
N/A
N/A
N/A
N/A
statistics interval
Use display nqa template statistics to display the statistics for all instances in an NQA template.
display nqa template statistics template-name
template-name: Specifies an NQA template by its name, a case-sensitive string of 1 to 255 characters.
After a service module references an NQA template, NQA creates the corresponding test instance to measure the relevant data for the service module to use. NQA creates one test instance each time the NQA template is used. Use this command to display the statistical results of test instances created by NQA for the service module. These results help determine whether the NQA module collaborates with the service module correctly.
# Display the statistics for the ARP operation in the NQA template named testarp, which includes two instances.
<Sysname> display nqa template statistics testarp
NQA template (admin testarp, tag instance9d3d688?) test statistics:
  NO. : 1
    Start time: 2023-03-09 17:42:10.7
  Extended results:
  NO. : 1
  Extended results:
Table 11 Command output
NQA template (admin admin-name, tag operation-tag) test statistics
NQA test statistics information. The template name (admin-name) is configured in the nqa template command and operation tag (operation-tag) is assigned by the service module that uses the NQA template.
No.
Start time
Life time
Square sum of the round-trip time.
Packet loss ratio
Average packet loss ratio. ICMP jitter, UDP jitter, and voice operation type have a precision of 0.1%.
Number of failures due to other errors.
Use exchange-port enable to enable port exchange between the source port and the destination port.
Use undo exchange-port enable to restore the default.
Exchange between the source port and the destination port is disabled.
Frame loss/latency/throughput operation view
Application scenario
By default, the NQA server reflects the probe packets back to the client without changing the source or destination port in the frame loss, latency, and throughput operations. The client can parse the probe packets directly because the ports are not changed. Configure this command to enable the client to correctly parse the probe packets in which the source and destination ports are exchanged.
Operating mechanism
After you configure this command, the NQA server encapsulates probe response packets as follows in frame loss, latency, and throughput operations:
·     Sets the same value for the source port number in probe response packets and the destination port number in NQA probe packets.
·     Sets the same value for the destination port number in probe response packets and the source port number in NQA probe packets.
Configure this command on the NQA client.
# Enable port exchange between the source and destination ports.
[Sysname-nqa-admin-test] type throughput
[Sysname-nqa-admin-test-throughput] exchange-port enable
Use expect { data | hex-data } to configure the expected response string to determine a successful NQA operation.
Use undo expect { data | hex-data } to restore the default.
expect { data | hex-data } string [ { offset | strict-offset } number ]
No expected response string is configured to determine a successful NQA operation.
HTTP/HTTP2/HTTPS/TCP/UDP/WAP template view
data: Specifies a data string.
hex-data: Specifies a hexadecimal string. This keyword is available only in TCP, UDP and WAP template views.
string: Specifies the string.
·     If the data keyword is specified, the string is case-sensitive and can contain 1 to 200 characters.
·     If the hex-data keyword is specified, the string is case-insensitive and can contain any even number of characters in the range of 2 to 200.
offset number: Specifies the offset in bytes after which the first match operation starts. The value range for the number argument is 0 to 1000, and the default value is 0.
strict-offset number: Specifies the strict offset in bytes. The value range for the number argument is 0 to 1000, and the default value is 0.
Upon receiving a response packet, the NQA client searches the packet payload for the expected string. In whichever cases, the NQA client marks the NQA operation as successful if a match is found. If no match is found, it marks the NQA operation as failed.
·     If both the offset and the strict offset are not configured, the NQA client starts the first match operation from the beginning byte of the payload. If no match is found, it starts another match operation from the second byte of the payload. The process continues until a match is found or the last payload byte is tried.
·     If an offset is configured, the NQA client starts the first match operation after the specified offset bytes. If no match is found, it continues the match operation as if no offset was configured.
·     If a strict offset is configured, the NQA client starts the first match operation after the specified strict offset bytes. If no match is found, it starts another match operation from the second byte after the strict offset bytes. The process continues until a match is found or the last payload byte is tried.
Expected string check takes place in the following conditions:
·     For features that use the HTTP, HTTP/2, or HTTPS template, the NQA client checks for the expected string only if the response body type is content or chunk.
·     For features that use the TCP or UDP template, the NQA client checks for the expected string if the data-fill command is configured.
For features that use the UDP template, the start byte of the offset depends on whether the raw keyword is specified in the data-fill command:
·     If the raw keyword is specified, the start byte of the offset is the first byte of the packet payload.
·     If the raw keyword is not specified, the start byte of the offset is the sixth byte of the packet payload. The first five bytes of the UDP packet payload identify the probe packet type.
For the WAP template that has a destination URL specified, you must configure the expected response data. The system checks for the expected string in the WSP replies (starting from the Headers field) to determine whether the WAP operation is successful.
An NQA operation result varies by the configuration of the expected status code and string that determine a successful NQA operation:
·     If both these settings are configured, the NQA operation is successful when the NQA response packet matches both the criteria. Otherwise, the operation fails.
·     If either the expected status code or string is configured, the NQA operation is successful when the NQA response packet matches the configured criterion. Otherwise, the operation fails.
For the HTTP, HTTP/2, or HTTPS template, do not configure both this command and the expect { failed-data | hex-failed-data } command.
For the TCP or UDP template, you can also use the expect { failed-data | hex-failed-data } command to configure the expected string in the response of a failed NQA operation. If both the expect { data | hex-data } and expect { failed-data | hex-failed-data } commands are configured, only the expect { failed-data | hex-failed-data } command takes effect.
# In HTTP template view, specify welcome! as expected response string to determine a successful NQA operation.
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] expect data welcome!
Use expect { failed-data | hex-failed-data } to configure the expected response string to determine a failed NQA operation.
Use undo expect { failed-data | hex-failed-data } to restore the default.
expect { failed-data | hex-failed-data } string [ { offset | strict-offset } number ]
No expected response string is configured to determine a failed NQA operation.
HTTP template view
HTTP/2 template view
HTTPS template view
TCP template view
UDP template view
failed-data: Specifies a data string.
hex-failed-data: Specifies a hexadecimal string. This option is available only in TCP or UDP template view.
·     If the failed-data keyword is specified, the string is case-sensitive and can contain 1 to 200 characters.
·     If the hex-failed-data keyword is specified, the string is case-insensitive and can contain any even number of characters in the range of 2 to 200.
offset number: Specifies the offset in bytes after which the first match operation starts. The value range for the number argument is 0 to 1000, and the default value is 0. If you do not specify an offset, the match operation starts from the beginning byte of the payload.
Upon receiving a response packet, the NQA client performs the match process as follows:
1.     It first compares expected failed string with the search scope in the packet payload.
¡     If the string is longer than the search scope, the operation is marked as failed.
¡     If the string is shorter than the search scope, the NQA client goes to the following step.
2.     The client searches for the expected string in the search scope.
¡     If a match is found, the operation is marked as failed.
¡     If no match is found, the operation is marked as successful.
The NQA client performs the match process only once if no offset is specified or the strict offset is specified. If the offset is specified, the client will start another match process for the whole payload if no match is found for the first round.
This command takes effect only if the data-fill command is also configured.
An NQA operation result varies by the configuration of the expected status code and string that determine a failed NQA operation:
·     If both these settings are configured, the NQA operation fails when the NQA response packet matches both the criteria. Otherwise, the operation is successful.
·     If either the expected status code or string is configured, the NQA operation fails when the NQA response packet matches the configured criterion. Otherwise, the operation is successful.
For the TCP or UDP template, you can also use the expect { data | hex-data } command to configure the expected string in the response of a successful NQA operation. If both the expect { data | hex-data } and expect { failed-data | hex-failed-data } commands are configured, only the expect { failed-data | hex-failed-data } command takes effect.
# In TCP template view, specify error as expected response string to determine a failed NQA operation.
[Sysname-nqatplt-tcp-tcptplt] expect failed-data error
Use expect { hex-persistent-data | persistent-data } to configure the expected response string to determine a persistent NQA operation.
Use undo expect { hex-persistent-data | persistent-data } to restore the default.
expect { hex-persistent-data | persistent-data } string
No expected response string is configured to determine a persistent NQA operation.
HTTP template view
HTTPS template view
TCP template view
UDP template view
hex-persistent-data: Specifies a hexadecimal string. This keyword is supported only in TCP template view or UDP template view.
persistent-data: Specifies a data string.
string: Specifies the expected response string to determine a persistent NQA operation.
·     If the hex-persistent-data keyword is specified, the string is case-insensitive and can contain any even number of characters in the range of 2 to 200.
·     If the persistent-data keyword is specified, the string is case-sensitive and can contain 1 to 200 characters.
Application scenarios
Use this command together with the data-fill and hex-data-fill commands to have the NQA instance stay in persistent state for use by service modules (for example, LB).
Operating mechanism
Follow these guidelines when you configure the expected response string for determining a failed, successful, or persistent NQA operation.
·     For the HTTP, HTTP/2, or HTTPS template, do not configure both the expect { failed-data | hex-failed-data } and expect { data | hex-data } commands. For the TCP or UDP template, you can configure both the expect { failed-data | hex-failed-data } and expect { data | hex-data } commands. The expect { failed-data | hex-failed-data }, expect { data | hex-data }, and expect { hex-persistent-data | persistent-data } commands are matched in descending order of priority if they are all configured.
·     Whether an NQA operation is successful depends on the expected response string for determining a failed or successful NQA operation. The expected response string for determining a persistent NQA operation affects only the persistent state configuration, and does not affect the result of the NQA operation and the subsequent executions.
·     The operation continues to match the expected string for determining a persistent NQA operation only after it fails to match the expected string for determining a successful NQA operation.
¡     If the operation matches the expected string for determining a persistent NQA operation, NQA sets the operation to persistent state, and sends the persistent state to the service module (for example, LB) for use.
¡     If the operation fails to match the expected string for determining a persistent NQA operation, NQA does not set the persistent state.
If you configure the expected response string for determining a failed, successful, or persistent NQA operation, the NQA client starts the first match operation from the beginning byte of the payload. If no match is found, it starts another match operation from the second byte of the payload. The process continues until a match is found or the last payload byte is tried.
# In TCP template view, specify forLB as the expected response string to determine a persistent NQA operation.
[Sysname-nqatplt-tcp-tcptplt] expect persistent-data forLB
data-fill
hex-data-fill
Use expect failed-status to configure the expected status code to determine a failed NQA operation.
Use undo expect failed-status to restore the default.
expect failed-status status-list
undo expect failed-status [ status-list ]
No expected status code is configured to determine a failed NQA operation.
HTTP/HTTP2/HTTPS template view
status-list: Specifies a space-separated list of up to 10 status code items for the HTTP, HTTP/2, or HTTPS template. Each item specifies a status code or a range of status codes in the form of status-number1 to status-number2. The value ranges for both the status-number1 and status-number2 arguments are 0 to 999. The value for the status-number2 argument must be equal to or greater than the value for the status-number1 argument.
For the the HTTP, HTTP/2, or HTTPS template, the status code in the probe packet is a three-digit field in decimal notation which includes the server status information. The first digit defines the class of response.
Do not configure both this command and the expect status command.
# In HTTP template view, set the expected status codes to 300, and 400 to 500.
[Sysname] nqa template http tplt
[Sysname-nqatplt-http-tplt] expect failed-status 300 400 to 500
expect ip
Use expect ip to specify the expected IPv4 address.
Use undo expect ip to restore the default.
expect ip ip-address
undo expect ip
No expected IPv4 address is specified.
DNS template view
ip-address: Specifies the expected IPv4 address for a DNS echo request.
During a DNS operation, the NQA client compares the expected IPv4 address with the IPv4 address resolved by the DNS server. If they are the same, it considers the DNS server legal.
# In DNS template view, specify 1.1.1.1 as the expected IPv4 address.
[Sysname] nqa template dns dnstplt
[Sysname-nqatplt-dns-dnstplt] expect ip 1.1.1.1
expect ipv6
Use expect ipv6 to specify the expected IPv6 address.
Use undo expect ipv6 to restore the default.
expect ipv6 ipv6-address
undo expect ipv6
No expected IPv6 address is specified.
DNS template view
ip-address: Specifies the expected IPv6 address for a DNS echo request.
During a DNS operation, the NQA client compares the expected IPv6 address with the IPv6 address resolved by the DNS server. If they are the same, it considers the DNS server legal.
# In DNS template view, specify 1::1 as the expected IPv6 address.
[Sysname-nqatplt-dns-dnstplt] expect ipv6 1::1
expect status
Use expect status to configure the expected status code to determine a successful NQA operation.
Use undo expect status to restore the default.
expect status status-list
undo expect status [ status-list ]
No expected status code is configured to determine a successful NQA operation.
Diameter/HTTP/HTTP2/HTTPS/RTSP/SIP template view
status-list: Specifies a space-separated list of up to 10 status code items. Each item specifies a status code or a range of status codes in the form of status-num 1 to status-num 2. For the HTTP, HTTP/2, HTTPS, RTSP, or SIP template, the value ranges for both the status-num 1 and status-num 2 arguments are 0 to 999. For the Diameter template, the value ranges for both the status-num 1 and status-num 2 arguments are 0 to 5999. The value for the status-num 2 argument must be equal to or greater than the value for the status-num 1 argument.
For the HTTP, HTTP/2, HTTPS, RTSP, or SIP template, the status code in the probe packet is a three-digit field in decimal notation which includes the server status information. The first digit defines the class of response.
For the Diameter template, the status code in the probe packet is a four-digit field in decimal notation which indicates whether the request has been successfully completed or has failed. The first digit defines the class of response.
For the HTTP, HTTP/2, or HTTPS template, do not configure both this command and the expect status command.
# In HTTP template view, set the expected status codes to 200, 300, and 400 to 500.
[Sysname-nqatplt-http-httptplt] expect status 200 300 400 to 500
filename
Use filename to specify a file to be transferred between the FTP server and the FTP client.
Use undo filename to restore the default.
filename filename
undo filename
No file is specified.
FTP operation view
FTP template view
filename: Specifies the name of a file, a case-insensitive string of 1 to 200 characters that cannot contain slashes (/).
# Specify config.txt as the file to be transferred between the FTP server and the FTP client for the FTP operation.
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
# In FTP template view, specify config.txt as the file to be transferred between the FTP server and the FTP client.
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] filename config.txt
frequency
Use frequency to specify the interval at which the NQA operation repeats.
Use undo frequency to restore the default.
frequency interval
undo frequency
In NQA operation view, the interval between two consecutive voice or path jitter operations is 60000 milliseconds. The interval between two consecutive operations of other types is 0 milliseconds.
In NQA template view, the interval for two consecutive operations is 5000 milliseconds.
UDP tracert operation view
interval: Specifies the interval between two consecutive operations, in the range of 0 to 604800000 milliseconds. An interval of 0 milliseconds configures NQA to perform the operation only once, and not to generate any statistics.
After an NQA operation starts, it repeats at the specified interval. However, when the interval is reached, but the current operation is not completed or not timed out, the next operation does not start.
# Configure the ICMP echo operation to repeat every 1000 milliseconds.
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
# In DNS template view, configure the DNS operation to repeat every 1000 milliseconds.
[Sysname-nqatplt-dns-dnstplt] frequency 1000
probe timeout
frequency-adjustment
Use frequency-adjustment to specify the adjusted interval for NQA to start two consecutive NQA operations after a failed operation.
Use undo frequency-adjustment to restore the default.
frequency-adjustment adj-interval
No adjusted interval is specified.
adj-interval: Specifies the adjusted interval in the range of 0 to 604800000 milliseconds.
By default, the operation interval is determined by the frequency command and does not change regardless of the operation result. This command enables the device to adjust the interval for the next two operations after an NQA operation fails. This mechanism allows for detecting the server status in a timely manner.
The next operation starts only when the last operation is completed and the interval is reached.
# In HTTP template view, set the adjusted interval to 1000 milliseconds.
[Sysname-nqatplt-http-tplt] frequency-adjustment 1000
hex-data-fill
Use hex-data-fill to configure a hexadecimal string to fill the probe packet payload.
Use undo hex-data-fill to restore the default.
hex-data-fill hex [ raw ]
undo hex-data-fill
The default hexadecimal packet payload fill string is 00010203040506070809.
TCP template view
UDP template view
hex: Specifies a hexadecimal string, which is case-insensitive and can contain any even number of characters in the range of 2 to 200.
raw: Fills the payload with the specified hexadecimal string without truncation or repetition to fit the payload size. This keyword is available only in UDP template view.
With the raw keyword specified, the hexadecimal string will be used exactly as specified to fill the packet payload.
Without the raw keyword, the hexadecimal string will be truncated at the end or cyclically repeated to fit the payload size of the probe packet.
For example, if you configure the hexadecimal payload fill string as abcd:
# In TCP template view, specify abcd as the hexadecimal payload fill string.
[Sysname-nqatplt-tcp-tcptplt] hex-data-fill abcd
Use history-record enable to enable the saving of history records for the NQA operation.
Use undo history-record enable to disable the saving of history records.
The saving of history records is enabled only for the UDP tracert operation.
To display the history records of the NQA operation, use the display nqa history command.
The undo form of the command also removes existing history records of an NQA operation.
# Enable the saving of history records for the NQA operation.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test-icmp-echo] history-record enable
display nqa history
history-record keep-time
Use history-record keep-time to set the lifetime of history records for an NQA operation.
Use undo history-record keep-time to restore the default.
history-record keep-time keep-time
The history records of an NQA operation are kept for 120 minutes.
keep-time: Specifies how long the history records can be saved. The value range is 1 to 1440 minutes.
When an NQA operation completes, the timer starts. All records are removed when the lifetime is reached.
# Set the lifetime of the history records to 100 minutes for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] history-record keep-time 100
history-record number
Use history-record number to set the maximum number of history records that can be saved for an NQA operation.
Use undo history-record number to restore the default.
history-record number number
A maximum of 50 history records can be saved for an NQA operation.
number: Specifies the maximum number of history records that can be saved for an NQA operation. The value range is 0 to 50.
If the number of history records for an NQA operation exceeds the maximum number, earliest history records are removed.
# Set the maximum number of history records to 10 for the ICMP echo operation.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] history-record number 10
init-ttl
Use init-ttl to set the TTL value for UDP packets in the start round of the UDP tracert operation.
Use undo init-ttl to restore the default.
init-ttl value
undo init-ttl
The NQA client sends a UDP packet with the TTL value 1 to start the UDP tracert operation.
Tracert template view
value: Specifies the TTL value in the range of 1 to 255.
# Set the TTL value to 5 for the UDP packets in the start round.
[Sysname-nqa-admin-test] type udp-tracert
[Sysname-nqa-admin-test-udp-tracert] init-ttl 5
key
Use key to set the shared key for secure RADIUS authentication and accounting.
Use undo key to restore the default.
key { cipher | simple } string
undo key
No shared key is configured for secure RADIUS authentication or accounting.
RADIUS authentication template view
RADIUS accounting template view
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the shared key string. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
Make sure the NQA client and the RADIUS authentication and accounting server have the same shared key.
# In RADIUS template view, set the shared key to abc in plain text for secure RADIUS authentication.
[Sysname] nqa template radius radiustplt
[Sysname-nqatplt-radius-radiustplt] key simple abc
local-host-name
Use local-host-name to configure the local host name for Diameter probe packets.
Use undo local-host-name to restore the default.
local-host-name host-name
The local host name in Diameter probe packets is the IP address of the output interface for the packets.
Diameter template view
host-name: Specifies a local host name for Diameter probe packets, a case-sensitive string of 1 to 127 characters that can contain letters, digits, hyphens (-), and dots(.).
Use this command to configure the value of the Origin-Host AVP for Diameter probe packets. Diameter servers use the Origin-Host AVP and Origin-Realm AVP to identify the source of each packet.
# Configure local host name host.example.com for Diameter probe packets.
[Sysname] nqa template diameter diametertplt
[Sysname-nqatplt-diameter-diametertplt] local-host-name host.example.com
local-realm-name
Use local-realm-name to configure the local realm name for Diameter probe packets.
Use undo local-realm-name to restore the default.
The local realm name in Diameter probe packets is h3c.com.
realm-name: Specifies a local realm name for Diameter probe packets, a case-sensitive string of 1 to 127 characters that can contain letters, digits, hyphens (-), and dots(.).
Use this command to configure the value of the Origin-Realm AVP for Diameter probe packets. Diameter servers use the Origin-Host AVP and Origin-Realm AVP to identify the source of each packet.
# Configure local realm name realm.example.com for Diameter probe packets.
[Sysname-nqatplt-diameter-diametertplt] local-realm-name realm.example.com
lsr-path
Use lsr-path to specify a loose source routing (LSR) path.
Use undo lsr-path to restore the default.
lsr-path ip-address&<1-8>
undo lsr-path
No LSR path is configured.
Path jitter operation view
ip-address&<1-8>: Specifies a space-separated list of up to eight IP addresses. Each IP address represents a hop on the path.
The path jitter operation first uses tracert to detect each hop to the destination. It then sends ICMP echo requests to measure the delay and jitters from the source to each node. If multiple routes exist between the source and destination, the operation uses the path specified by using lsr-path command.
# Specify 10.1.1.20 and 10.1.2.10 as the hops on the LSR path for the path jitter operation.
[Sysname-nqa-admin-test] type path-jitter
[Sysname-nqa-admin-test- path-jitter] lsr-path 10.1.1.20 10.1.2.10
mailbox
Use mailbox to specify the mailbox name to be used in the IMAP operation.
Use undo mailbox to restore the default.
mailbox mailbox-name
undo mailbox
The IMAP operation uses the mailbox name INBOX.
IMAP template view
mailbox-name: Specifies the mailbox name, a case-sensitive string of 1 to 64 characters.
# Set the mailbox name to fortest1 for IMAP template imaptplt.
[Sysname] nqa template imap imaptplt
[Sysname-nqatplt-imap-imaptplt] mailbox fortest1
max-failure
Use max-failure to set the maximum number of consecutive probe failures in a UDP tracert operation.
Use undo max-failure to restore the default.
max-failure times
undo max-failure
A UDP tracert operation stops and fails when it detects five consecutive probe failures.
times: Specifies the maximum number in the range of 0 to 255. When this argument is set to 0 or 255, the UDP tracert operation does not stop when consecutive probe failures occur.
When a UDP tracert operation detects the maximum number of consecutive probe failures, the operation fails and stops probing the path.
# Set the maximum number of consecutive probe failures to 20 in a UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] max-failure 20
mode
Use mode to set the data transmission mode for the FTP operation.
Use undo mode to restore the default.
mode { active | passive }
undo mode
The FTP operation uses the data transmission mode active.
FTP operation view
FTP template view
active: Sets the data transmission mode to active. The FTP server initiates a connection request.
passive: Sets the data transmission mode to passive. The FTP client initiates a connection request.
# Set the data transmission mode to passive for the FTP operation.
[Sysname-nqa-admin-test-ftp] mode passive
# In FTP template view, set the data transmission mode to passive for the FTP operation.
[Sysname-nqatplt-ftp-ftptplt] mode passive
next-hop ip
Use next-hop ip to specify the next hop IPv4 address for probe packets.
Use undo next-hop ip to restore the default.
next-hop ip ip-address
undo next-hop ip
No next hop IPv4 address is specified for probe packets.
ICMP echo operation view
DNS/ICMP/TCP half open template view
ip-address: Specifies the IPv4 address of the next hop. Make sure this address is the IP address of a directly connected next hop. If you cannot do that, the operation will fail.
If the next hop IPv4 address is not configured, the device searches the routing table to determine the next hop IPv4 address for the probe packets.
If you execute both the next-hop ip and out interface commands for the same NQA operation, the next-hop ip command takes effect and the out interface command does not.
# Specify 10.1.1.1 as the next hop IPv4 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.1
out interface
next-hop ipv6
Use next-hop ipv6 to specify the next hop IPv6 address for probe packets.
Use undo next-hop ipv6 to restore the default.
next-hop ipv6 ipv6-address
undo next-hop ipv6
No next hop IPv6 address is specified for probe packets.
ipv6-address: Specifies the IPv6 address of the next hop. IPv6 link-local addresses are not supported. Make sure this address is the IPv6 address of a directly connected next hop. If you cannot do that, the operation will fail.
If the next hop IPv6 address is not configured, the device searches the routing table to determine the next hop IPv6 address for the probe packets.
If you execute both the next-hop ipv6 and out interface commands for the same NQA operation, the next-hop ipv6 command takes effect and the out interface command does not.
# Specify 10::1 as the next hop IPv6 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] next-hop ipv6 10::1
out interface
no-fragment enable
Use no-fragment enable to enable the no-fragmentation feature.
Use undo no-fragment enable to disable the no-fragmentation feature.
no-fragment enable
The no-fragmentation feature is disabled.
The no-fragmentation feature sets the DF field to 1. Packets with the DF field set cannot be fragmented during the forwarding process.
You can use this command to test the path MTU of a link.
# Enable the no-fragmentation feature for the UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] no-fragment enable
nqa
Use nqa to create an NQA operation and enter its view, or enter the view of an existing NQA operation.
Use undo nqa to remove the operation.
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
No NQA operations exist.
all: Removes all NQA operations, NQA templates, and operation groups.
# Create an NQA operation with administrator name admin and operation tag test, and enter NQA operation view.
nqa agent enable
Use nqa agent enable to enable the NQA client.
Use undo nqa agent enable to disable the NQA client and stop all operations being performed.
nqa agent enable
The NQA client is enabled.
# Enable the NQA client.
[Sysname] nqa agent enable
nqa server enable
nqa agent running-test limit
Use nqa agent running-test limit to configure the maximum number of running NQA operations supported by the NQA client, as well as the maximum number of NQA operations that can run per second.
Use undo nqa agent running-test limit to restore the default.
nqa agent running-test limit max-running-test [ per-second-limit per-second-limit ]
The device supports a maximum of 2048 running NQA operations.
max-running-test: Specifies the maximum number of running NQA operations. The value range for this argument is 10 to 4096.
per-second-limit: Specifies the maximum number of NQA operations that can run per second. The value range for this argument is 10 to 4096. The default value is 0, which means not limited.
Use this command to set the maximum number of NQA operation that can run at the same time. To limit the number of operations per second, specify the per-second-limit keyword in the command. This can further control impact of the operations on device resources, and avoid excessive resource pressure caused by too many concurrent operations, which can affect device performance and operation accuracy.
The command takes effect immediately upon configuration. If the configured value is smaller than the number of ongoing operations, the device immediately terminates the operations exceeding the configured value to achieve the desired configuration goal.
# Configure the maximum number of running NQA operations supported by the NQA client as 1000 and the maximum number of NQA operations that can run per second as 100.
[Sysname] nqa agent running-test limit 1000 per-second-limit 100
nqa schedule
Use nqa schedule to configure scheduling parameters for an NQA operation.
Use undo nqa schedule to stop the operation.
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd | mm/dd/yyyy ] | now } lifetime { lifetime | forever } [ recurring ]
undo nqa schedule admin-name operation-tag
No schedule is configured for an NQA operation.
start-time: Specifies the start time and date of the NQA operation.
hh:mm:ss: Specifies the start time of an NQA operation.
yyyy/mm/dd: Specifies the start date of an NQA operation. The default value is the current system time, and the value for the yyyy argument is in the range of 2000 to 2035.
mm/dd/yyyy: Specifies the start date of an NQA operation. The default value is the current system time, and the value for the yyyy argument is in the range of 2000 to 2035.
now: Starts the operation immediately.
lifetime: Specifies the duration of an operation.
lifetime: Specifies the duration of an operation in seconds. The value range is 1 to 2147483647.
forever: Performs the operation until you stop it by using the undo nqa schedule command.
recurring: Runs the operation automatically at the start time and for the specified duration. If you do not specify this keyword, the NQA operation is performed only once at the specified date and time.
You cannot enter the view of a scheduled NQA operation. If you want to enter such a view, use the undo nqa schedule command to stop the NQA operation first. This restriction does not apply to path quality analysis operations.
The NQA operation works between the specified start time and the end time (the start time plus operation duration). If the specified start time is ahead of the system time, the operation starts immediately. If both the specified start time and end time are ahead of the system time, the operation does not start. To display the current system time, use the display clock command.
Specify a lifetime long enough for an operation to complete.
# Schedule the operation with administrator name admin and operation tag test to start on 08:08:08 2008/08/08 and last 1000 seconds.
[Sysname] nqa schedule admin test start-time 08:08:08 2008/08/08 lifetime 1000 recurring
destination ip
display clock (Fundamentals Command Reference)
nqa entry
type
nqa template
Use nqa template to create an NQA template and enter its view, or enter the view of an existing NQA template.
Use undo nqa template to remove an NQA template.
nqa template { arp | dns | ftp | http | https | icmp | imap | pop3 | radius | radius-account | rtsp | sip | smtp | ssl | tcp | tcphalfopen | tracert | udp | wap } name
undo nqa template { arp | dns | ftp | http | https | icmp | imap | pop3 | radius | radius-account | rtsp | sip | smtp  | ssl | tcp | tcphalfopen | tracert | udp | wap } name
No NQA templates exist.
arp: Specifies the ARP template.
diameter: Specifies the Diameter template.
dns: Specifies the DNS template.
ftp: Specifies the FTP template.
http: Specifies the HTTP template.
http2: Specifies the HTTP/2 template.
https: Specifies the HTTPS template.
icmp: Specifies the ICMP template.
imap: Specifies the IMAP template.
pop3: Specifies the POP3 template.
radius: Specifies the RADIUS authentication template.
radius-account: Specifies the RADIUS accounting template.
rtsp: Specifies the RTSP template.
sip: Specifies the SIP template.
smtp: Specifies the SMTP template.
ssl: Specifies the SSL template.
tcp: Specifies the TCP template.
tcphalfopen: Specifies the TCP half open template.
tracert: Specifies the tracert template.
udp: Specifies the UDP template.
wap: Specifies the WAP template.
name: Specifies the name of the NQA template, a case-insensitive string of 1 to 255 characters.
To delete an NQA template that a feature is referencing, you must first remove the reference relationship.
# Create an ICMP template named icmptplt, and enter its view.
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt]
operation (FTP operation view)
Use operation to specify the operation type for the FTP operation.
Use undo operation to restore the default.
operation { get | put }
undo operation
The FTP operation type is get.
FTP operation view
FTP template view
get: Gets a file from the FTP server.
put: Transfers a file to the FTP server.
When you perform the put operation with the filename command configured, make sure the file exists on the NQA client.
If you get a file from the FTP server, make sure the file specified in the URL exists on the FTP server. The NQA client does not save the file obtained from the FTP server.
Use a small file for the FTP operation. A big file might result in transfer failure because of timeout, or might affect other services for occupying much network bandwidth.
# Set the operation type to put for the FTP operation.
[Sysname-nqa-admin-test-ftp] operation put
# In FTP template view, set the operation type to put for the FTP operation.
[Sysname-nqatplt-ftp-ftptplt] operation put
password
username
operation (HTTP/HTTP2 operation view)
Use operation to specify the operation type for the HTTP or HTTP/2 operation.
operation { get | post | raw }
undo operation
The HTTP or HTTP/2 operation type is get.
HTTP/HTTP2 template view
get: Gets data from the HTTP or HTTP/2server.
post: Transfers data to the HTTP or HTTP/2 server.
raw: Sends the RAW request to the HTTP or HTTP/2 server.
The HTTP operation uses HTTP requests as probe packets. The HTTP/2 operation uses HTTP/2 requests as probe packets.
For the get or post operation, the content in the request is obtained from the URL specified by the url command.
For the HTTP raw operation, the content in the request is configured in raw request view. You can use the raw-request command to enter the raw request view.
For the HTTP/2 raw operation, the content in the request is configured in raw request hex view. You can use the raw-request-hex command to enter raw request hex view.
# Set the operation type to raw for the HTTP operation.
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] operation raw
# In HTTP template view, set the operation type to raw for the HTTP operation.
[Sysname-nqatplt-http-httptplt] operation raw
password
raw-request
username
operation (HTTPS template view)
Use operation to specify the operation type for the HTTPS operation.
undo operation
The HTTPS operation type is get.
HTTPS template view
get: Gets data from the HTTPS server.
post: Transfers data to the HTTPS server.
raw: Sends the RAW request to the HTTPS server.
The HTTPS operation uses HTTPS requests as probe packets.
For the raw operation, the content in the request is configured in raw request view. You can use the raw-request command to enter the raw request view.
# In HTTPS template view, set the operation type to raw for the HTTPS operation.
[Sysname] nqa template https httptplt
[Sysname-nqatplt-https-httptplt] operation raw
password
raw-request
username
out interface
Use out interface to specify the output interface for probe packets.
Use undo out interface to restore the default.
out interface interface-type interface-number
undo out interface
The output interface for probe packets is not specified. The NQA client determines the output interface based on the routing table lookup.
DHCP operation view
UDP jitter operation view
Frame loss/Latency/Throughput operation view
Diameter/DNS/ICMP/TCP half open/tracert/HTTP/HTTP2 template view
For successful operation, the specified output interface must be up.
The out interface command does not take effect if the next-hop command is configured in the ICMP echo operation, DNS template, ICMP template, or TCP half open template.
# Specify VLAN-interface 1 as the output interface for probe packets in the UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] out interface vlan-interface 1
next-hop ip
next-hop ipv6
password
Use password to specify a password.
Use undo password to restore the default.
undo password
No password is specified.
FTP/HTTP/HTTP2 operation view
FTP/HTTP/HTTP2/HTTPS/IMAP/POP3/RADIUS authentication template view
string: Specifies the password. The value of the argument varies as follows:
·     For FTP, HTTP, HTTP/2, and HTTPS operations, the plaintext form of the password is a case-sensitive string of 1 to 32 characters. The encrypted form of the password is a case-sensitive string of 1 to 73 characters.
·     For RADIUS templates, the plaintext form of the password is a case-sensitive string of 1 to 64 characters. The encrypted form of the password is a case-sensitive string of 1 to 117 characters.
·     For IMAP and POP3 templates, the plaintext form of the password is a string of 1 to 40 characters. The encrypted form of the password is a string of 1 to 85 characters.
# Set the FTP login password to ftpuser.
[Sysname-nqa-admin-test-ftp] password simple ftpuser
# Set the FTP login password to ftpuser in FTP template view.
[Sysname-nqatplt-ftp-ftptplt] password simple ftpuser
operation
username
port-detect enable
Use port-detect enable to enable port detection.
Use undo port-detect enable to disable port detection.
port-detect enable
Port detection is disabled.
TCP half open/UDP template view
In the TCP half open operation, port detection probes whether the listening port of the TCP service on the destination device is available. If the NQA client receives the SYN-ACK packet from the destination device within the probe timeout time after sending a SYN packet, the TCP half open operation succeeds. If the NQA client does not receive the SYN-ACK packet from the destination device within the probe timeout time, the TCP half open operation fails.
In the UDP operation, port detection probes whether the listening port of the UDP service on the destination device is available. If the NQA client does not receive any ICMP port unreachable messages within the probe timeout time, the UDP operation succeeds. If the client receives an ICMP port unreachable message, the UDP operation fails.
If the destination device is an H3C device, you must also perform the following tasks for the UDP operation:
·     Execute the ip unreachables enable command on the destination device to enable sending ICMP destination unreachable messages.
·     Execute the data-fill or hex-data-fill command on the NQA client with the raw keyword specified.
To set the probe timeout time, execute the probe timeout command.
For port detection to take effect, you must use the destination port command to configure the destination port.
# Enable port detection in TCP half open template tplt.
[Sysname] nqa template tcphalfopen tplt
[Sysname-nqatplt-tcphalfopen-tplt] port-detect enable
data-fill
destination port
hex-data-fill
ip unreachables enable (Network Connectivity Command Reference)
probe count
Use probe count to specify the probe times.
Use undo probe count to restore the default.
probe count times
undo probe count
In an UDP tracert operation, the NQA client sends three probe packets to each hop along the path. In other types of operations, the NQA client performs one probe to the destination per operation.
ICMP echo/TCP/UDP echo operation view
ARP/DHCP/DLSw/DNS/FTP/HTTP operation view
ICMP jitter/UDP jitter operation view
times: Specifies the probe times.
·     For the UDP tracert operation, this argument specifies the times of probes to each hop along the path. The value range for this argument is 1 to 10.
·     For other types of operations, this argument specifies the times of probes to the destination per operation. The value range for this argument is 1 to 15.
The following describes how NQA performs different types of operations:
·     A TCP or DLSw operation sets up a connection.
·     An ICMP jitter or UDP jitter operation sends a number of probe packets. The number of probe packets is set by using the probe packet-number command.
·     An FTP, DHCP, DNS, HTTP, or HTTP/2 operation completes an independent task in each probe. For example, an FTP operation uploads or downloads a file in each probe, and an HTTP operation gets a Web page in each probe.
·     An ICMP echo operation sends an ICMP echo request.
·     An ARP operation sends an ARP request.
·     A UDP echo operation sends a UDP packet.
·     A path jitter operation is accomplished in the following steps:
a.     The operation uses tracert to obtain the path from the NQA client to the destination. A maximum of 64 hops can be detected.
b.     The NQA client sends ICMP echo requests to each hop along the path. The number of ICMP echo requests is set by using the probe packet-number command.
·     A UDP tracert operation determines the routing path from the source to the destination. The number of probe packets sent to each hop is set by using the probe count command.
If an operation is to perform multiple probes, the NQA client starts a new probe in one of the following conditions:
·     The NQA client receives responses to packets sent in the last probe.
·     The probe timeout time expires.
This command is not available for the voice or path jitter operations. Each of these operations performs only one probe.
# Configure the ICMP echo operation to perform 10 probes.
[Sysname-nqa-admin-test-icmp-echo] probe count 10
probe method incremental
Use probe method incremental to configure the algorithm used for probing network throughput as the incremental method.
Use undo probe method incremental to restore the default.
The algorithm used for probing network throughput is the binary search method.
In the throughput operation, to minimize impact on the network services, you can configure the calculation method as incremental to perform small batch adjustments to the test bandwidth.
Operating mechanism
In a throughput operation, the device adjusts the sending rate of probe packets periodically to obtain the link throughput. By default, the device uses the binary search mechanism to adjust the sending rate of probe packets according to the value configured in the speed granularity command.
# Configure the algorithm used for probing network throughput as the incremental method for a throughput operation.
[Sysname-nqa-admin-test-throughput] probe method incremental
speed granularity
probe packet-interval
Use probe packet-interval to configure the packet sending interval in the probe.
Use undo probe packet-interval to restore the default.
probe packet-interval interval
The packet sending interval is 20 milliseconds.
ICMP jitter/path jitter/UDP jitter/voice operation view
interval: Specifies the sending interval in the range of 10 to 60000 milliseconds.
# Configure the UDP jitter operation to send packets every 100 milliseconds.
[Sysname-nqa-admin-test] type udp-jitter
[Sysname-nqa-admin-test-udp-jitter] probe packet-interval 100
probe packet-number
Use probe packet-number to set the number of packets to be sent in a UDP jitter, path jitter, or voice probe.
Use undo probe packet-number to restore the default.
probe packet-number number
An ICMP jitter, UDP jitter, or path jitter operation sends 10 packets probe and a voice operation sends 1000 packets per probe.
number: Specifies the number of packets to be sent per probe. Available value ranges include:
·     10 to 1000 for the ICMP jitter, UDP jitter, and path jitter operations.
·     10 to 60000 for the voice operation.
# Configure the UDP jitter probe to send 100 packets.
[Sysname-nqa-admin-test-udp-jitter] probe packet-number 100
probe packet-timeout
Use probe packet-timeout to set the timeout time for waiting for a response in the UDP jitter, path jitter, or voice operation.
Use undo probe packet-timeout to restore the default.
probe packet-timeout timeout
The response timeout time for the UDP jitter or path jitter operation is 3000 milliseconds.
The response timeout time for the voice operation is 5000 milliseconds.
timeout: Specifies the timeout time in milliseconds. The value range is 10 to 3600000.
# Set the response timeout time to 100 milliseconds in the UDP jitter operation.
[Sysname-nqa-admin-test-udp-jitter] probe packet-timeout 100
probe timeout
Use probe timeout to set the probe timeout time.
Use undo probe timeout to restore the default.
probe timeout timeout
undo probe timeout
The timeout time of a probe is 3000 milliseconds.
Any NQA template view
timeout: Specifies the probe timeout time in milliseconds. The value range for this argument varies as follows:
·     For FTP and HTTP operations, the value range is 10 to 86400000.
·     For DHCP, DNS, DLSw, ICMP echo, TCP, UDP echo, and UDP tracert operations, the value range is 10 to 3600000.
·     For FTP, HTTP, and HTTPS templates, the value range is 10 to 86400000.
·     For other types of NQA templates, the value range is 10 to 3600000.
If a probe does not complete within the period, the probe is timed out.
To make this command to take effect, the interval specified in the frequency command must be greater than that specified in this command.
# Set the probe timeout time to 10000 milliseconds for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] probe timeout 10000
# In HTTP template view, set the probe timeout time to 10000 milliseconds for the HTTP operation.
[Sysname-nqatplt-http-httptplt] probe timeout 10000
frequency
product name
Use product-name to configure the product name for Diameter probe packets.
Use undo product-name to restore the default.
product-name product-name
undo product-name
The product name in Diameter probe packets is H3C Diameter Health Monitoring.
product-name: Specifies a product name for Diameter probe packets, a case-sensitive string of 1 to 127 characters.
Use this command to configure the value of the Product-Name AVP for Diameter probe packets. The combination of the Vendor-Id, Product-Name, and Firmware-Revision (if any) AVPs provides useful debugging information for Diameter servers.
# Configure product name Diameter Health Monitoring for Diameter probe packets.
[Sysname-nqatplt-diameter-diametertplt] product-name Diameter Health Monitoring
proxy-url
Use proxy-url to specify the URL of the HTTP, HTTP/2, or HTTPS proxy server.
Use undo proxy-url to restore the default.
proxy-url url
undo proxy-url
The URL of the HTTP, HTTP/2 or HTTPS proxy server is not specified.
HTTP template view
HTTPS template view
url: Specifies the proxy server URL, a case-sensitive string of 1 to 255 characters.
·     The URL of the HTTP proxy server is in the format of http://host or http://host:port.
·     The URL of the HTTP/2 proxy server is in the format of http://host, http://host:port, https://host, or https://host:port.
·     The URL of the HTTPS proxy server is in the format of https://host or https://host:port.
The host parameter in the URL represents the host name of the server, which must meet the following requirements:
·     Case sensitive.
·     Valid characters are letters, digits, hyphens (-), underscores (_), and dots (.), but consecutive dots (.) are not allowed.
·     Must be a dot-separated series of labels. Each label can contain 1 to 63 characters.
After you configure this command, the NQA client will send probe packets to the proxy server that acts on behalf of the HTTP. HTTP/2, or HTTPS server.
If proxy servers are required for Internet access, you must configure this command for successful HTTP. HTTP/2, or HTTPS operations.
# In HTTP template view, specify https://www.example.com as the URL of the HTTPS proxy server.
[Sysname-nqatplt-http-httptplt] proxy-url https://www.example.com
raw-request
Use raw-request to enter raw request view and specify the content of an HTTP or HTTPS request.
Use undo raw-request to restore the default.
raw-request
undo raw-request
The contents of an HTTP or HTTPS raw request are not specified.
HTTP operation view
HTTP/HTTPS template view
This command places you in raw request view and deletes the previously configured request content.
If the HTTP or HTTPS operation type is set to raw, you must enter raw request view and configure the request content to be sent to the HTTP or HTTPS server. For successful HTTP or HTTPS operations, make sure the raw request content is valid and does not contain aliases set by using the alias command. For more information about the command, see CLI in Fundamentals Command Reference.
# Enter raw request view and specify the content of a GET request for the HTTP operation.
[Sysname-nqa-admin-test-http] raw-request
[Sysname-nqa-admin-test-http-raw-request] GET /sdn/ui/app/index HTTP/1.0\r\nHost: 172.0.0.2\r\n\r\n
# In HTTP template view, enter raw request view and specify the content of a POST request for the HTTP operation.
[Sysname-nqatplt-http-httptplt] raw-request
[Sysname-nqatplt-http-httptplt-raw-request] POST /sdn/ui/app/index HTTP/1.0\r\nHost:
 172.0.0.2\r\nAuthorization: Basic cm9vdDoxMjM0NTY=\r\n\r\n
raw-request-hex
Use raw-request-hex to enter raw request hex view and specify the content of an HTTP/2 request.
Use undo raw-request-hex to restore the default.
raw-request-hex
The contents of an HTTP/2 raw request are not specified.
HTTP/2 operation view
This command places you in raw request hex view and deletes the previously configured request content.
If the HTTP/2 operation type is set to raw, you must enter raw request hex view and configure the request content to be sent to the HTTP/2 server. For successful HTTP/2 operations, make sure the raw request content is valid and meets the following requirements:
·     The raw request content can be a hexadecimal string of 2 to 512 characters. The string is case insensitive, and the length of the string must be even.
·     The raw request content does not contain aliases set by using the alias command. For more information about the command, see CLI in Fundamentals Command Reference.
# Enter raw request hex view and specify the content of a GET request for the HTTP/2 operation.
[Sysname-nqa-admin-test] type http2
[Sysname-nqa-admin-test-http2] raw-request-hex
[Sysname-nqa-admin-test-http2-raw-request-hex] 505249202a20485454502f322e300d0a0d0a534d0d0a0d0a00002404000000000000010000100000020000000100030000000100040001000000050000400000060000100000009401250000000300000000008286110b31302e32312e32312e323114082f31622e68746d6c1006616363657074032a2f2a100f6163636570742d6c616e677561676505656e2d757390100a757365722d6167656e74454d6f7a696c6c612f342e302028636f6d70617469626c653b204d53494520362e303b2057696e646f7773204e5420352e313b202e4e455420434c5220312e312e3433323229
# In HTTP/2 template view, enter raw request hex view and specify the content of a GET request for the HTTP/2 operation.
[Sysname] nqa template http2 http2tplt
[Sysname-nqatplt-http2-http2tplt] raw-request-hex
[Sysname-nqatplt-http2-http2tplt-raw-request-hex] 505249202a20485454502f322e300d0a0d0a534d0d0a0d0a00002404000000000000010000100000020000000100030000000100040001000000050000400000060000100000009401250000000300000000008286110b31302e32312e32312e323114082f31622e68746d6c1006616363657074032a2f2a100f6163636570742d6c616e677561676505656e2d757390100a757365722d6167656e74454d6f7a696c6c612f342e302028636f6d70617469626c653b204d53494520362e303b2057696e646f7773204e5420352e313b202e4e455420434c5220312e312e3433323229
reaction checked-element { jitter-ds | jitter-sd }
Use reaction checked-element { jitter-ds | jitter-sd } to configure a reaction entry for monitoring one-way jitter in the NQA operation.
Use undo reaction to delete a reaction entry.
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
undo reaction item-number
No reaction entries for monitoring one-way jitter exist.
ICMP jitter/UDP jitter/voice operation view
item-number: Assigns an ID to the reaction entry, in the range of 1 to 10.
jitter-ds: Specifies the destination-to-source jitter of each probe packet as the monitored element (or performance metric).
jitter-sd: Specifies source-to-destination jitter of each probe packet as the monitored element.
threshold-type: Specifies a threshold type.
accumulate accumulate-occurrences: Checks the total number of threshold violations in the operation. The value range is 1 to 14999 for the ICMP jitter and UDP jitter operations, and 1 to 59999 for the voice operation.
average: Checks the average one-way jitter.
threshold-value: Specifies threshold range in milliseconds.
upper-threshold: Specifies the upper limit in the range of 0 to 3600000.
lower-threshold: Specifies the lower limit in the range of 0 to 3600000. It must not be greater than the upper limit.
action-type: Specifies the action to be triggered. The default action is none.
none: Specifies the action of displaying results on the terminal display.
trap-only: Specifies the action of displaying results on the terminal display and meanwhile sending SNMP trap messages to the NMS.
You cannot edit a reaction entry after it is created. To change the attributes in a reaction entry, use the undo reaction command to delete the entry, and then configure a new one.
Only successful probe packets are monitored. Statistics about failed probe packets are not collected.
# Create reaction entry 1 for monitoring the average destination-to-source jitter of UDP jitter packets, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average destination-to-source jitter is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element jitter-ds threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the destination-to-source jitter of UDP jitter probe packets, and set the upper limit to 50 milliseconds, and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the destination-to-source jitter is checked against the threshold range. If the total number of threshold violations reaches or exceeds 100, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 2 checked-element jitter-ds threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction checked-element { owd-ds | owd-sd }
Use reaction checked-element { owd-ds | owd-sd } to configure a reaction entry for monitoring the one-way delay.
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
No reaction entries for monitoring the one-way delay exist.
owd-ds: Specifies the destination-to-source delay of each probe packet as the monitored element.
owd-sd: Specifies the source-to-destination delay of each probe packet as the monitored element.
No actions can be configured for a reaction entry of monitoring one-way delays. To display the monitoring results and statistics, use the display nqa reaction counters and display nqa statistics commands.
# Create reaction entry 1 for monitoring the destination-to-source delay of every UDP jitter packet, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. The destination-to-source delay is calculated after the response to the probe packet arrives. If the delay exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element owd-ds threshold-value 50 5
reaction checked-element icpif
Use reaction checked-element icpif to configure a reaction entry for monitoring the ICPIF value in the voice operation.
reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entries for monitoring ICPIF values exist.
Voice operation view
threshold-value: Specifies threshold range.
upper-threshold: Specifies the upper limit in the range of 1 to 100.
lower-threshold: Specifies the lower limit in the range of 1 to 100. It must not be greater than the upper limit.
action-type: Specifies what action to be triggered. The default action is none.
# Create reaction entry 1 for monitoring the ICPIF value in the voice operation, and set the upper limit to 50 and lower limit to 5. Before the voice operation starts, the initial state of the reaction entry is invalid. After the operation, the ICPIF value is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] reaction 1 checked-element icpif threshold-value 50 5 action-type trap-only
reaction checked-element mos
Use reaction checked-element mos to configure a reaction entry for monitoring the MOS value in the voice operation.
reaction item-number checked-element mos threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entries for monitoring the MOS value exist.
upper-threshold: Specifies the upper limit in the range of 1 to 500.
lower-threshold: Specifies the lower limit in the range of 1 to 500. It must not be greater than the upper limit.
For the MOS threshold, the number is expressed in three digits representing ones, tenths, and hundredths. For example, to express a MOS threshold of 1, enter 100.
# Create reaction entry 1 for monitoring the MOS value of the voice operation, and set the upper limit to 2 and lower limit to 1. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the MOS value is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-voice] reaction 1 checked-element mos threshold-value 200 100 action-type trap-only
reaction checked-element packet-loss
Use reaction checked-element packet-loss to configure a reaction entry for monitoring packet loss in UDP jitter or voice operation.
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
No reaction entries for monitoring packet loss exist.
accumulate accumulate-occurrences: Specifies the total number of lost packets in the operation. The value range is 1 to 15000 for the ICMP jitter and UDP jitter operations and 1 to 60000 for the voice operation.
# Create reaction entry 1 for monitoring packet loss in the UDP jitter operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the total number of the lost packets is checked against the threshold. If the number reaches or exceeds 100, the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element packet-loss threshold-type accumulate 100 action-type trap-only
reaction checked-element probe-duration
Use reaction checked-element probe-duration to configure a reaction entry for monitoring the probe duration.
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entries for monitoring the probe duration exist.
accumulate accumulate-occurrences: Checks the total number of threshold violations. The value range is 1 to 15.
average: Checks the average probe duration.
consecutive consecutive-occurrences: Specifies the number of consecutive threshold violations after the NQA operation starts. The value range is 1 to 16.
lower-threshold: Specifies the lower limit in the range of 0 to 3600000. It must not be greater than the upper threshold.
trap-only: Specifies the action of displaying results on the terminal display and meanwhile sending SNMP trap messages to the NMS. This keyword is not available for the DNS operation.
# Create reaction entry 1 for monitoring the average probe duration of ICMP echo operation, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average probe duration is checked. If it exceeds the upper limit, the state is set to over-threshold. If it is below the lower limit, the state of the reaction entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the probe duration of ICMP echo operation, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the accumulated probe duration is checked against the threshold range. If the total number of threshold violations reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-duration threshold-type accumulate 10 threshold-value 50 5 action-type trap-only
# Create reaction entry 3 for monitoring the probe duration time of ICMP echo operation, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the consecutive probe duration is checked against the threshold range. If the total number of consecutive threshold violations reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 3 checked-element probe-duration threshold-type consecutive 10 threshold-value 50 5 action-type trap-only
reaction checked-element probe-fail (for trap)
Use reaction checked-element probe-fail to configure a reaction entry for monitoring the probe failures of the operation.
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
No reaction entries for monitoring probe failures exist.
accumulate accumulate-occurrences: Checks the total number of probe failures. The value range is 1 to 15.
consecutive consecutive-occurrences: Checks the maximum number of consecutive probe failures. The value range is 1 to 16.
# Create reaction entry 1 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the total number of probe failures reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type accumulate 10 action-type trap-only
# Create reaction entry 2 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the number of consecutive probe failures reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-fail threshold-type consecutive 10 action-type trap-only
reaction checked-element probe-fail (for trigger)
Use reaction checked-element probe-fail to configure a reaction entry for monitoring probe failures.
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
consecutive consecutive-occurrences: Checks the maximum number of consecutive probe failures, in the range of 1 to 16.
trigger-only: Triggers other modules to react to certain conditions.
# Create reaction entry 1. If the number of consecutive probe failures reaches 3, collaboration is triggered.
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
track (High Availability Command Reference)
reaction checked-element rtt
Use reaction checked-element rtt to configure a reaction entry for monitoring packet round-trip time.
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entries for monitoring packet round-trip time exist.
The value range for the accumulate-occurrences argument varies by operation type:
·     1 to 15000 for the ICMP jitter and UDP jitter operations.
·     1 to 60000 for the voice operation.
average: Checks the packet average round-trip time.
# Create reaction entry 1 for monitoring the average round-trip time of UDP jitter probe packets, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average packet round-trip time is checked. If it exceeds the upper limit, the state is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the reaction entry state changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the round-trip time of UDP jitter probe packets, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the packet round-trip time is checked. If the total number of threshold violations reaches or exceeds 100, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction trap
Use reaction trap to configure the sending of traps to the NMS under specific conditions.
Use undo reaction trap to restore the default.
reaction trap { path-change | probe-failure consecutive-probe-failures | test-complete | test-failure [ accumulate-probe-failures ] }
undo reaction trap { path-change | probe-failure | test-complete | test-failure }
No traps are sent to the NMS.
path-change: Sends a trap when the UDP tracert operation detects a different path to the destination.
probe-failure consecutive-probe-failures: Sends a trap to the NMS if the number of consecutive probe failures in an operation is greater than or equal to consecutive-probe-failures. The value range for the consecutive-probe-failures argument is 1 to 15. The system counts the number of consecutive probe failures for each operation, so multiple traps might be sent.
test-complete: Sends a trap to indicate that the operation is completed. A UDP tracert operation is considered completed when the path to the destination is determined.
test-failure: Sends a trap when an operation fails. For operations other than UDP tracert operation, the system counts the total number of probe failures in an operation. If the number reaches or exceeds the value for the accumulate-probe-failures argument, a trap is sent for the operation failure.
accumulate-probe-failures: Specifies the total number of probe failures in an operation. The value range is 1 to 15. This argument is not supported by the UDP tracert operation.
The ARP operation supports the probe-failure, test-complete, and test-failure keywords.
The ICMP jitter, UDP jitter, and voice operations support only the test-complete keyword.
The following parameters are not available for the UDP tracert operation:
·     The probe-failure consecutive-probe-failures option.
·     The accumulate-probe-failures argument.
# Configure the system to send a trap if five or more consecutive probe failures occur in an ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
reaction trigger per-probe
Use reaction trigger per-probe to configure the probe result sending on a per-probe basis.
Use undo reaction trigger per-probe to restore the default.
The probe result is sent to the feature that uses the template after three consecutive failed or successful probes.
DNS/ICMP/TCP half open/tracert template view
The feature enables the NQA client to send the probe result to the feature that uses the NQA template every time a probe is completed.
If you execute this command and the reaction trigger probe-fail command multiple times, the most recent configuration takes effect.
If you execute this command and the reaction trigger probe-pass command multiple times, the most recent configuration takes effect.
# In ICMP template view, configure the probe result sending on a per-probe basis.
[Sysname-nqatplt-icmp-icmptplt] reaction trigger per-probe
Use reaction trigger probe-fail to set the number of consecutive probe failures to determine an operation failure.
Use undo reaction trigger probe-fail to restore the default.
reaction trigger probe-fail count
The NQA client notifies the feature of the operation failure when the number of consecutive probe failures reaches 3.
count: Specifies the number of consecutive probe failures, in the range of 1 to 15.
If the number of consecutive probe failures is reached, the NQA client notifies the feature that uses the NQA template of the operation failure.
If you execute this command and the reaction trigger per-probe command multiple times, the most recent configuration takes effect.
# In HTTP template view, configure the NQA client to notify the feature of the operation failure when the number of consecutive probe failures reaches 5.
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] reaction trigger probe-fail 5
Use reaction trigger probe-pass to set the number of consecutive successful probes to determine a successful operation event.
Use undo reaction trigger probe-pass to restore the default.
reaction trigger probe-pass count
The NQA client notifies the feature of the successful operation event if the number of consecutive successful probes reaches 3.
count: Specifies the number of consecutive successful probes, in the range of 1 to 15.
If number of consecutive successful probes is reached, the NQA client notifies the feature that uses the template of the successful operation event.
# In HTTP template view, configure the NQA client to notify the feature of the successful operation event if the number of consecutive successful probes reaches 5.
[Sysname-nqatplt-http-httptplt] reaction trigger probe-pass 5
request-method
Use request-method to specify the request method for the RTSP operation.
Use undo request-method to restore the default.
request-method { describe | options }
undo request-method
The options request method is used.
RTSP template view
describe: Specifies the DESCRIBE request method. A DESCRIBE request returns information on a particular object identified by a URL.
options: Specifies the OPTIONS request method. An OPTIONS request returns the request types that the RTSP server will accept.
For an RTSP template that uses the DESCRIBE request method, you must use the url command to specify the path of a file located on the RTSP server.
# In RTSP template view, set the RTSP request method to DESCRIBE.
[Sysname] nqa template rtsp rtsptplt
[Sysname-nqatplt-rtsp-rtsptplt] request method describe
url
resolve-target
Use resolve-target to specify the domain name to be resolved in the DNS operation.
Use undo resolve-target to restore the default.
resolve-target domain-name
undo resolve-target
The domain name to be resolved in the DNS operation is not specified.
DNS operation view
DNS template view
domain-name: Specifies the domain name to be resolved. It is a dot-separated case-sensitive string of 1 to 255 characters including letters, digits, hyphens (-), and underscores (_) (for example, aabbcc.com). Each part consists of 1 to 63 characters, and consecutive dots (.) are not allowed.
# Specify domain1 as the domain name to be resolved.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type dns
[Sysname-nqa-admin-test-dns] resolve-target domain1
# In DNS template view, specify domain1 as the domain name to be resolved.
[Sysname] nqa template dns dnstplt
[Sysname-nqatplt-dns-dnstplt] resolve-target domain1
resolve-type
Use resolve-type to configure the domain name resolution type.
Use undo resolve-type to restore the default.
resolve-type { A | AAAA }
undo resolve-type
The domain name resolution type is type A.
DNS template view
A: Specifies the type A queries. A type A query resolves a domain name to a mapped IPv4 address.
AAAA: Specifies the type AAAA queries. A type AAAA query resolves a domain name to a mapped IPv6 address.
# In DNS template view, set the domain name resolution type to A.
[Sysname-nqatplt-dns-dnstplt] resolve-type A
resource-release { data-fill | hex-data-fill }
Use to resource-release { data-fill | hex-data-fill } to enable the NQA client to send a resource release notification packet to the NQA server when an NQA operation is complete.
Use undo resource-release to restore the default.
resource-release { data-fill | hex-data-fill } string
The NQA client does not send resource release notifications to the NQA server when an NQA operation is complete.
TCP/UDP template view
data-fill: Specifies a payload fill string.
hex-data-fill: Specifies a hexadecimal payload fill string.
string: Specifies the payload fill string.
·     If the data-fill keyword is specified, the payload fill string is case-sensitive and can contain 1 to 200 characters.
·     If the hex-data-fill keyword is specified, the payload fill string is case-insensitive and can contain any even number of characters in the range of 2 to 200.
With this command configured, the NQA client sends a resource release notification packet containing the specified payload to the NQA server when the NQA operation is complete. The NQA server will then terminate the connection for the NQA operation and release the resources assigned to the operation.
# In TCP template view, enable the NQA client to send a resource release notification packet containing payload abcd to the NQA server.
[Sysname] nqa template tcp tcptplt
[Sysname-nqatplt-tcp-tcptplt] resource-release data-fill abcd
route-option bypass-route
Use route-option bypass-route to enable the routing table bypass feature to test the connectivity to the direct destination.
Use undo route-option bypass-route to disable the routing table bypass feature.
The routing table bypass feature is disabled.
UDP tracert operation view
When the routing table bypass feature is enabled, the following events occur:
·     The routing table is not searched. Packets are sent to the destination on a directly connected network.
·     The TTL value in the probe packet is set to 1. The TTL set in the ttl command does not take effect.
This command does not take effect if the destination address of the NQA operation is an IPv6 address.
# Enable the routing table bypass feature.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
source interface (ICMP echo/UDP tracert operation view)
Use source interface to specify the IP address of an interface as the source IP address of probe packets.
Use undo source interface to restore the default.
source interface interface-type interface-number
The probe packets take the primary IP address of the outgoing interface as their source IP address.
ICMP/tracert template view
The specified interface must be up. If the interface is down, no probe requests can be sent out.
If you execute this command and the source ip or source ipv6 command for an ICMP echo operation or ICMP template multiple times, the most recent configuration takes effect.
If you execute this command and the source ip command for a UDP tracert operation multiple times, the most recent configuration takes effect.
source ip
source ipv6
source ip
Use source ip to configure the source IPv4 address for probe packets.
Use undo source ip to restore the default.
source ip ip-address
undo source ip
 the probe packets take the primary IP address of their output interface as the source IPv4 address.
ARP/DHCP/DLSw/FTP/HTTP operation view
ip-address: Specifies the source IPv4 address for probe packets.
The specified source IP address must be the IPv4 address of a local interface, and the local interface must be up. Otherwise, no probe packets can be sent out.
For an NQA template, if the source and destination addresses have different IP versions, the source address does not take effect.
If you execute the source interface and source ip commands multiple times for the following types of NQA operations or templates, the most recent configuration takes effect:
·     ICMP echo operation.
·     UDP tracert operation.
·     ICMP template.
# Specify 10.1.1.1 as the source IPv4 address for ICMP echo requests.
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
# In ICMP template view, specify 10.1.1.1 as the source IPv4 address for ICMP echo requests.
[Sysname-nqatplt-icmp-icmptplt] source ip 10.1.1.1
source interface
source ipv6
Use source ipv6 to configure the source IPv6 address for probe packets.
Use undo source ipv6 to restore the default.
source ipv6 ipv6-address
undo source ipv6
For NQA operations, the probe packets take the IPv6 address of their output interface as the source IPv6 address.
ICMP echo/TCP/UDP echo/UDP jitter operation view
DNS/FTP/HTTP/HTTPS/ICMP/IMAP/POP3/RADIUS authentication/RADIUS accounting/RTSP/SMTP/SSL/TCP/TCP half open/UDP/WAP template view
ipv6-address: Specifies the source IPv6 address for probe packets. IPv6 link-local addresses are not supported.
The specified source IPv6 address must be the IPv6 address of a local interface. The local interface must be up. Otherwise, no probe packets can be sent out.
If you execute the source interface and source ipv6 commands multiple times for an ICMP echo operation or ICMP template, the most recent configuration takes effect.
# Specify 1::1 as the source IPv6 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] source ipv6 1::1
# In ICMP template view, specify 1::1 as the source IPv6 address for ICMP echo requests.
[Sysname-nqatplt-icmp-icmptplt] source ipv6 1::1
source interface
source port
Use source port to configure the source port number for probe packets.
Use undo source port to restore the default.
source port port-number
undo source port
The NQA client randomly picks an unused port as the source port when the operation starts
DNS/tracert template view
port-number: Specifies the source port number in the range of 1 to 65535.
For the operation to succeed, make sure the specified port number is not used by any services on the device.
·     To obtain the IPv4 addresses and the port numbers in use on this device, see the Local Addr:port field in the output from the display tcp and display udp commands.
·     To obtain the IPv6 addresses and the port numbers in use on this device, see the LAddr->port field in the output from the display ipv6 tcp and display ipv6 udp commands.
# Set the source port number to 8000 for probe packets in the UDP echo operation.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] source port 8000
# In DNS template view, set the source port number to 8000 for probe packets in the DNS operation.
[Sysname-nqatplt-dns-dnstplt] source port 8000
·     display ipv6 tcp (Network Connectivity Command Reference)
·     display ipv6 udp (Network Connectivity Command Reference)
·     display tcp (Network Connectivity Command Reference)
·     display udp (Network Connectivity Command Reference)
ssl-client-policy
Use ssl-client-policy to specify an SSL client policy for an HTTP/2, HTTPS, SSL or Diameter template.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
No SSL client policy is specified for an HTTPS or SSL template.
HTTP2/HTTPS/SSL/Diameter template view
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
In the HTTPS or SSL operation, the NQA client uses the specified SSL client policy to establish an SSL connection to the server.
# Specify SSL client policy policy for SSL template ssltplt.
[Sysname] nqa template ssl ssltplt
[Sysname-nqatplt-ssl-ssltplt] ssl-client-policy policy
statistics hold-time
Use statistics hold-time to set the hold time of statistics groups for an NQA operation.
Use undo statistics hold-time to restore the default.
statistics hold-time hold-time
The hold time of statistics groups for an NQA operation is 120 minutes.
hold-time: Specifies the hold time in minutes, in the range of 1 to 1440.
A statistics group is deleted when its hold time expires.
# Set the hold time to 3 minutes for statistics groups of the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] statistics hold-time 3
statistics interval
Use statistics interval to set the statistics collection interval for an NQA operation.
Use undo statistics interval to restore the default.
statistics interval interval
The statistics collection interval is 60 minutes.
interval: Specifies the interval in minutes, in the range of 1 to 35791394.
NQA forms statistics within the same collection interval as a statistics group. To display information about the statistics groups, use the display nqa statistics command.
# Configure NQA to collect the ICMP echo operation statistics every 2 minutes.
[Sysname-nqa-admin-test-icmp-echo] statistics interval 2
statistics max-group
Use statistics max-group to set the maximum number of statistics groups that can be saved.
Use undo statistics max-group to restore the default.
statistics max-group number
A maximum of two statistics groups can be saved.
number: Specifies the maximum number of statistics groups, in the range of 0 to 100. To disable statistics collection, set the value to 0.
When the maximum number of statistics groups is reached and a new statistics group is to be saved, the earliest statistics group is deleted.
# Configure NQA to save a maximum of five statistics groups for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] statistics max-group 5
target-only
Use target-only to perform the path jitter operation only on the destination address.
Use undo target-only to restore the default.
target-only
undo target-only
NQA performs the path jitter operation to the destination hop by hop.
Path jitter operation view
# Perform the path jitter operation only on the destination address.
[Sysname-nqa-admin-test] type path-jitter
[Sysname-nqa-admin-test-path-jitter] target-only
tos
Use tos to set the ToS value in the IP header for probe packets.
Use undo tos to restore the default.
tos value
undo tos
The ToS value in the IP header of probe packets is 0.
Any operation view
DNS/FTP/HTTP/HTTPS/ICMP/IMAP/POP3/RADIUS authentication/RADIUS accounting/RTSP/SIP/SMTP/SSL/TCP/TCP half open/UDP/WAP/tracert template view
value: Specifies the ToS value in the range of 0 to 255.
# In ICMP echo operation view, set the ToS value to 1 in the IP header for probe packets.
[Sysname-nqa-admin-test-icmp-echo] tos 1
# In ICMP template view, set the ToS value to 1 in the IP header for probe packets.
[Sysname-nqatplt-icmp-icmptplt] tos 1
transport-protocol
Use transport-protocol to specify the transport protocol used by the SIP operation.
Use undo transport-protocol to restore the default.
transport-protocol { tcp | udp }
UDP is used.
SIP template view
tcp: Specifies TCP as the transport protocol.
udp: Specifies UDP as the transport protocol.
After you change the transport protocol for a SIP template, the system stops the ongoing SIP operation that uses the template and starts a new SIP operation by using the new transport protocol.
# Specify TCP as the transport protocol for SIP template siptplt.
[Sysname] nqa template sip siptplt
[Sysname-nqatplt-sip-siptplt] transport-protocol tcp
ttl
Use ttl to set the maximum number of hops that the probe packets can traverse.
Use undo ttl to restore the default.
ttl value
undo ttl
The maximum number of hops is 30 for probe packets of the UDP tracert operation, and is 20 for probe packets of other types of operations.
value: Specifies the TTL value in the range of 1 to 255. For the UDP tracert operation, this setting represents the maximum TTL value that can be carried in the probe packets. For other type of operations, this setting determines the maximum number of hops that the probe packets can traverse.
The route-option bypass-route command sets the TTL to 1 for probe packets. If you configure both the route-option bypass-route and ttl commands for an operation, the ttl command does not take effect.
For a successful UDP tracert operation, make sure the specified TTL value is not smaller than the value set in the init-ttl command.
# Set the maximum number of hops to 16 for probe packets in the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] ttl 16
# In ICMP template view, set the maximum number of hops to 16 for probe packets.
[Sysname-nqatplt-icmp-icmptplt] ttl 16
type
Use type to specify an NQA operation type and enter its view.
type { arp | dhcp | dlsw | dns | ftp | http | icmp-echo | icmp-jitter | path-jitter | tcp | udp-echo | udp-jitter | udp-tracert | voice }
No operation type is specified.
NQA operation view
arp: Specifies the ARP operation type.
dhcp: Specifies the DHCP operation type.
dlsw: Specifies the DLSw operation type.
dns: Specifies the DNS operation type.
ftp: Specifies the FTP operation type.
http: Specifies the HTTP operation type.
http2: Specifies the HTTP/2 operation type.
icmp-echo: Specifies the ICMP echo operation type.
icmp-jitter: Specifies the ICMP jitter operation type.
path-jitter: Specifies the path jitter operation type.
tcp: Specifies the TCP operation type.
udp-echo: Specifies the UDP echo operation type.
udp-jitter: Specifies the UDP jitter operation type.
udp-tracert: Specifies the UDP tracert operation type.
voice: Specifies the voice operation type.
You can specify only one type for an NQA operation. After that, you can configure the operation type-related settings for the NQA operation. To change the type of the NQA operation, remove the NQA operation in system view, and then re-create the NQA operation.
# Specify FTP as the NQA operation type and enter FTP operation view.
[Sysname-nqa-admin-test] type ftp
url
Use url to specify the URL of the destination.
Use undo url to restore the default.
url url
undo url
The destination URL is not specified.
FTP/HTTP/HTTP2/HTTPS/RTSP/WAP/ICMP/TCP template view
url: Specifies the destination URL, a case-sensitive string of 1 to 255 characters.
The following table shows the URL format requirement for different NQA operations:
Operation
URL format
Default port number
HTTP operation
http://host/resource
http://host:port/resource
80
HTTP/2 operation
80
https://host/resource
https://host:port/resource
443
HTTPS operation
443
FTP operation
ftp://host/filename
ftp://host:port/filename
21
ICMP echo operation
protocol://host:port
The host paramter is required.
The protocol and port parameters can be unspecified or any values.
N/A
The host and port parameters are required.
The protocol parameter can be unspecified or any value.
N/A
RTSP operation
rtsp://host/resource
rtsp://host:port/resource
554
WAP operation
http://host/filename
http://host:port /filename
N/A
The host parameter in the URL represents the host name of the destination server, which must meet the following requirements:
·     Case sensitive.
The port parameter in the URL, if specified, represents the port number on the destination server that provides the service. If the value for the host parameter is an IPv6 address and the protocol parameter is specified in the URL, you must use a pair of square brackets ([]) to include the IPv6 address, for example, http://[2001::1]/test.
For description about the filename parameter, see Fundamentals Configuration Guide.
For the url command to take effect in the WAP operation, you must configured the expect { data | hex-data } command in WAP template view.
For the ICMP echo operation or ICMP template, the url command and the destination ip command are mutually exclusive.
For the UDP jitter operation or TCP template, the url command is mutually exclusive with the destination ip command and the destination port command.
# Configure the URL that the HTTP operation visits as http://www.example.com/index.html.
[Sysname-nqa-admin-test-http] url http://www.example.com/index.html
# In HTTP template view, configure the URL that the HTTP operation visits as http://www.example.com/index.html.
[Sysname-nqatplt-http-httptplt] url http://www.example.com/index.html
username
Use username to specify a username.
Use undo username to restore the default.
username username
undo username
No username is configured.
FTP/HTTP/HTTP2/HTTPS/IMAP/POP3/RADIUS authentication/RADIUS accounting template view
username: Specifies the case-sensitive username.
·     The FTP, HTTP, HTTP/2, or HTTPS username is a string of 1 to 32 characters.
·     The POP3 or IMAP username is a string of 1 to 40 characters in the format of username@domain.com.
·     The RADIUS authentication or accounting username is a string of 1 to 253 characters.
# Set the FTP login username to administrator.
[Sysname-nqa-admin-test-ftp] username administrator
# Set the FTP login username to administrator in FTP template view.
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] username administrator
operation
password
vendor-id
Use vendor-id to configure the vendor ID for Diameter probe packets.
Use undo vendor-id to restore the default.
vendor-id vendor-id
undo vendor-id
The vendor ID in Diameter probe packets is 0.
vendor-id: Specifies a vendor ID for Diameter probe packets, in the range of 0 to 4294967295. The value of 0 is the reserved value. Upon receiving Diameter probe packets with the vendor ID as 0, Diameter servers ignore this field.
Use this command to configure the value of the Vendor-Id AVP for Diameter probe packets. Each Diameter probe packet must have an IANA-managed SMI Network Management Private Enterprise Code of the device vendor.
# Configure vendor ID 25506 for Diameter probe packets.
[Sysname] nqa template diameter diametertplt
[Sysname-nqatplt-diameter-diametertplt] vendor-id 25506
vendor-specific-app-id
Use vendor-specific-app-id to configure a vendor-specific application ID for Diameter probe packets.
Use undo vendor-specific-app-id to restore the default.
vendor-specific-app-id vendor-id vendor-id [ { auth-app-id | acct-app-id } application-id ]
No vendor-specific application ID is configured for Diameter probe packets.
vendor-id vendor-id Specifies a vendor-specific application ID for Diameter probe packets, in the range of 1 to 4294967295.
auth-app-id: Specifies an authentication and authorization application by its ID.
acct-app-id: Specifies an accounting application by its ID.
application-id: Specifies an application by its ID in the range of 1 to 4294967295. Each Diameter application except for the base protocol must have an IANA-assigned application ID.
Use this command to configure the value of the Vendor-Specific-Application-Id AVP for Diameter probe packets. The Vendor-Specific-Application-Id AVP is used to inform the Diameter server of the Diameter applications supported by the device vendor.
# Configure vendor-specific application ID 25506 and accounting application ID 2000 for Diameter probe packets.
[Sysname-nqatplt-diameter-diametertplt] vendor-specific-app-id vendor-id 25506 acct-app-id 2000
version (HTTP/HTTPS operation view/HTTPS template view)
Use version to specify the version used in the HTTP or HTTPS operation.
Use undo version to restore the default.
version { v1.0 | v1.1 }
undo version
Version 1.0 is used in the HTTP operation or HTTPS operation.
HTTP operation view
v1.0: Uses version 1.0.
v1.1: Uses version 1.1.
# Configure the HTTP operation to use the HTTP version 1.1.
[Sysname-nqa-admin-test-http] version v1.1
NQA server commands
IMPORTANT
IMPORTANT:
Configure the NQA server only for UDP jitter, TCP, UDP echo, and voice operations.
display nqa server
Use display nqa server to display NQA server status.
display nqa server
# Display NQA server status.
<Sysname> display nqa server
NQA server status: Enabled
TCP connect:
   IP address: 2.2.2.2
   Port: 2000
   ToS:200
   VPN instance: -
UDP echo:
   IP address: 3.3.3.3
   Port: 3000
   ToS: 255
   VPN instance: -
  High performance mode: Enabled
Table 12 Command output
NQA server status
Whether the NQA server is enabled.
TCP connect
Information about the TCP listening service on the NQA server.
UDP echo
Information about the UDP listening service on the NQA server.
IP address
IP address specified for the TCP/UDP listening service on the NQA server.
Port
Port number specified for the TCP/UDP listening service on the NQA server.
ToS
ToS value in reply packets sent by the NQA server.
VPN instance
Name of the VPN instance to which the IP address that the NQA server listens on belongs. This field displays a hyphen (-) if the NQA server listens on a public IP address.
nqa server enable
Use nqa server enable to enable the NQA server.
Use undo nqa server enable to disable the NQA server.
nqa server enable
The NQA server is disabled.
# Enable the NQA server.
[Sysname] nqa server enable
nqa server tcp-connect
Use nqa server tcp-connect to configure a TCP listening service to enable the NQA server to listen to a port on an IP address.
Use undo nqa server tcp-connect to remove a TCP listening service.
nqa server tcp-connect { ipv4-address | ipv6 ipv6-address } port-number [ tos tos ]
undo nqa server tcp-connect { ipv4-address | ipv6 ipv6-address } port-number
No TCP listening services exist.
ipv4-address: Specifies the IPv4 address for the TCP listening service.
ipv6 ipv6-address: Specifies the IPv6 address for the TCP listening service.
port-number: Specifies the port number for the TCP listening service, in the range of 1 to 65535.
tos tos: Specifies the ToS value in the IP header for reply packets. The value range is 0 to 255, and the default value is 0.
Use this command on the NQA server only for the TCP and DLSw operations. For the DLSw operation, the port number for the TCP listening service on the NQA server must be 2065. Otherwise, the DLSw operation fails.
When you configure the IP address and port number for a TCP listening service on the NQA server, follow these restrictions and guidelines:
·     The IP address and port number must be unique on the NQA server and match the configuration on the NQA client.
·     The IP address must be the address of an interface on the NQA server.
·     To ensure successful NQA operations and avoid affecting existing services, do not configure the TCP listening service on well-known ports from 1 to 1023.
# Configure a TCP listening service to enable the NQA server to listen to port 9000 on the IP address 169.254.10.2.
[Sysname] nqa server tcp-connect 169.254.10.2 9000
destination ip
destination port
nqa server udp-echo
Use nqa server udp-echo to configure a UDP listening service to enable the NQA server to listen to a port on an IP address.
Use undo nqa server udp-echo to remove the UDP listening service created.
nqa server udp-echo { ipv4-address | ipv6 ipv6-address } port-number [ tos tos ]
undo nqa server udp-echo { ipv4-address | ipv6 ipv6-address } port-number
No UDP listening services exist.
ipv4-address: Specifies the IPv4 address for the UDP listening service.
ipv6 ipv6-address: Specifies the IPv6 address for the UDP listening service.
port-number: Specifies the port number for the UDP listening service, in the range of 1 to 65535.
tos tos: Specifies the ToS value in the IP header for reply packets. The value range for this argument is 0 to 255, and the default value is 0.
Use this command on the NQA server only for the UDP jitter, UDP echo, and voice operations.
When you configure the IP address and port number for a UDP listening service on the NQA server, follow these restrictions and guidelines:
·     To ensure successful NQA operations and avoid affecting existing services, do not configure the UDP listening service on well-known ports from 1 to 1023.
# Configure a UDP listening service to enable the NQA server to listen to port 9000 on IP address 169.254.10.2.
[Sysname] nqa server udp-echo 169.254.10.2 9000
destination ip
destination ipv6
destination port
