05-Layer 3—IP Services Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Router Command Reference-R8630Pxx-6W10005-Layer 3—IP Services Command Reference
03-DNS commands
03-DNS commands 220.62 KB
DNS commands
description
Use description to configure a description for a DNS server group.
No description is configured for a DNS server group.
DNS server group view
text: Specifies a description, a case-insensitive string of 1 to 255 characters.
# Configure the description as office for DNS server group 1.
[Sysname] dns server-group 1
[Sysname-dns-server-group-1] description office
dns server-group
display dns domain
Use display dns domain to display the domain name suffixes.
display dns domain [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays the domain name suffixes dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays the statically configured and dynamically obtained domain name suffixes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays domain name suffixes for the public network.
# Display the statically configured and dynamically obtained domain name suffixes for the public network.
<Sysname> display dns domain
Type:
  D: Dynamic    S: Static
No.    Type   Domain suffix
1      S      com
2      D      net
No.
Sequence number.
Domain name suffix type:
·     S—A statically configured domain name suffix.
·     D—A domain name suffix dynamically obtained through DHCP or other protocols.
Domain suffix
Domain name suffixes.
dns domain
display dns host
Use display dns host to display information about domain name-to-IP address mappings.
display dns host [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ vpn-instance vpn-instance-name ] [ name host-name ] [ ttl { greater-than greater-than-value | less-than less-than-value } ]
ip [ ipv4-address ]: Specifies type A queries. A type A query resolves a domain name to the mapped IPv4 address. The ipv4-address argument specifies the mapped IPv4 address. If you specify this option, the command displays the domain name-to-IP address mapping that contains the IPv4 address. If you do not specify this option, the command displays all domain name-to-IP address mappings that contain IPv4 addresses.
ipv6 [ ipv6-address ]: Specifies type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address. The ipv6-address argument specifies the mapped IPv6 address. If you specify this option, the command displays the domain name-to-IP address mapping that contains the IPv6 address. If you do not specify this option, the command displays all domain name-to-IP address mappings that contain IPv6 addresses.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays domain name-to-IP address mappings for the public network.
name host-name: Specifies a host name. This option supports fuzzy match by adding a wildcard (*) to the host name. For example, to match a host name including abc, specify the domain-name argument as *abc*, *abc, or abc*. To exactly match a host name, do not add the wildcard (*).
ttl greater-than greater-than-value: Displays only dynamic domain name-to-IP address mappings with TTL values greater than or equal to the value for the greater-than-value argument. The greater-than-value argument specifies the lower TTL limit in the range of 1 to 4294967295.
ttl less-than less-than-value: Displays only dynamic domain name-to-IP address mappings with TTL values less than or equal to the value for the less-than-value argument. The less-than-value argument specifies the upper TTL limit in the range of 1 to 4294967295.
If you do not specify the ip or ipv6 keyword, this command displays domain name-to-IP address mappings of all query types.
# Display domain name-to-IP address mappings of all query types.
<Sysname> display dns host
Type:
Total number: 3
No.  Host name         Type  TTL        Query type   IP addresses
1    sample.com        D     3132       A            192.168.10.1
                                                     192.168.10.2
                                                     192.168.10.3
2    zig.sample.com    S     -          A            192.168.1.1
3    sample.net        S     -          AAAA         FE80::4904:4448
No.
Sequence number.
Host name
Domain name.
Domain name-to-IP address mapping type:
·     S—A static mapping configured by the ip host or ipv6 host command.
·     D—A mapping dynamically obtained through dynamic domain name resolution.
TTL
Time in seconds that a mapping can be stored in the cache.
For a static mapping, a hyphen (-) is displayed.
Query type
Query type: A or AAAA.
IP addresses
Replied IP address:
·     For a type A query, the replied IP address is an IPv4 address.
·     For a type AAAA query, the replied IP address is an IPv6 address.
ip host
ipv6 host
reset dns host
display dns server
Use display dns server to display IPv4 DNS server information.
display dns server [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays IPv4 DNS server information dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays statically configured and dynamically obtained IPv4 DNS server information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv4 DNS server information for the public network.
# Display IPv4 DNS server information for the public network.
<Sysname> display dns server
Type:
No. Type  IP address
1   S     202.114.0.124
2   S     169.254.65.125
No.
Sequence number.
DNS server type:
·     S—A manually configured DNS server.
·     D—DNS server information dynamically obtained through DHCP or other protocols.
IP address
IPv4 address of the DNS server.
dns server
display dns snooping host
Use display dns snooping host to display domain name-to-IP address mappings recorded by DNS snooping.
display dns snooping host [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ vpn-instance vpn-instance-name ] [ name host-name ] [ server { ipv4-address | ipv6-address } ] [ ttl { greater-than greater-than-value | less-than less-than-value } ]
ip [ ipv4-address ]: Specifies type A queries. A type A query resolves a domain name to the mapped IPv4 address. The ipv4-address argument specifies the mapped IPv4 address. If you specify this option, the command displays the domain name-to-IP address mapping recorded by DNS snooping that contains the IPv4 address. If you do not specify this option, the command displays all domain name-to-IP address mappings recorded by DNS snooping that contain IPv4 addresses.
ipv6 [ ipv6-address ]: Specifies type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address. The ipv6-address argument specifies the mapped IPv6 address. If you specify this option, the command displays the domain name-to-IP address mapping recorded by DNS snooping that contains the IPv6 address. If you do not specify this option, the command displays all domain name-to-IP address mappings recorded by DNS snooping that contain IPv6 addresses.
server { ipv4-address | ipv6-address }: Specifies a DNS server. The ipv4-address argument specifies the IPv4 address of the DNS server. The ipv6-address argument specifies the IPv6 address of the DNS server.
If you do not specify the ip or ipv6 keyword, this command displays domain name-to-IP address mappings of both query types recorded by DNS snooping.
# Display domain name-to-IP address mappings of both query types recorded by DNS snooping.
<Sysname> display dns snooping host
Total number: 5
No.  Host name       Server               TTL        QType IP addresses
1    a.example.com   8.8.8.8              3593       A     100.100.0.7
2    b.example.com   8.8.8.8              3595       A     100.100.0.8
                                                           100.100.0.9
3    c.example.com   8.8.8.8              3593       A     100.100.0.6
4    d.example.com   8.8.8.8              3597       AAAA  101:101::104
5    e.example.com   8.8.8.8              3597       AAAA  101:101::103
No.
Sequence number.
Host name
Domain name.
Server
IP address of the DNS server.
TTL
QType
Query type: A and AAAA.
IP addresses
Replied IP address:
reset dns host
display ipv6 dns server
Use display ipv6 dns server to display IPv6 DNS server information.
display ipv6 dns server [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays IPv6 DNS server information dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays the statically configured and dynamically obtained IPv6 DNS server information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 DNS server information for the public network.
# Display IPv6 DNS server information for the public network.
<Sysname> display ipv6 dns server
Type:
No. Type  IPv6 address                             Outgoing Interface
1   S     2::2
Table 5 Command output
No.
Sequence number.
DNS server type:
IPv6 address
Outgoing Interface
Output interface.
ipv6 dns server
dns cache ttl
Use dns cache ttl to set the TTL value for DNS entries.
Use undo dns cache ttl to cancel the TTL configuration for DNS entries.
dns cache ttl { maximum max-value | minimum min-value } *
undo dns cache ttl [ maximum | minimum ]
The TTL value for DNS entries is the TTL value in the DNS reply.
maximum max-value: Specifies the maximum TTL value for DNS entries, in the range of 60 to 3600 seconds.
minimum min-value: Specifies the minimum TTL value for DNS entries, in the range of 60 to 3600 seconds. The value for the min-value argument must be smaller than that for the max-value argument.
Application scenarios
The device periodically sends a DNS request to the DNS server according to the TTL for DNS entries, which consumes CPU resources. If the TTL value is too small, the device sends DNS requests frequently to the DNS server, which consumes more CPU resources. If the TTL value is too large, DNS mappings cannot be updated in time. To avoid such issues, you can use this command to set the TTL value for DNS entries.
Operating mechanism
By default, the DNS client obtains the TTL from the DNS reply for dynamic domain name resolution cache.
After you set the TTL value for DNS entries, the device specifies the TTL for DNS entries as follows:
·     If the TTL value in the DNS reply is smaller than the minimum TTL value, the device uses the minimum TTL value as the TTL for DNS entries. If the TTL value is greater than or equal to the minimum TTL value, the device uses the TTL value in the DNS reply as the TTL for DNS entries.
·     If the TTL value in the DNS reply is greater than the maximum TTL value, the device uses the maximum TTL value as the TTL for DNS entries. If the TTL value is smaller than or equal to the maximum TTL value, the device uses the TTL value in the DNS reply as the TTL for DNS entries.
After you execute this command, the configuration only takes effect on the subsequent generated DNS entries.
After you execute the undo dns cache ttl command, the current TTL for the existing DNS entries still works.
If you do not specify any keywords when you execute the undo dns cache ttl command, this command cancels all TTL configuration for DNS entries.
If you execute the dns cache ttl minimum, dns cache ttl maximum, or dns cache ttl minimum maximum command multiple times, the most recent configuration takes effect.
# Set the maximum TTL value for DNS entries to 3600 seconds and the minimum TTL value for DNS entries to 180 seconds.
[Sysname] dns cache ttl maximum 3600 minimum 180
dns server
dns domain
Use dns domain to configure a domain name suffix.
Use undo dns domain to delete the specified domain name suffix.
dns domain domain-name [ vpn-instance vpn-instance-name ]
undo dns domain domain-name [ vpn-instance vpn-instance-name ]
No domain name suffix is configured. Only the provided domain name is resolved.
domain-name: Specifies a domain name suffix. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, aabbcc.com. The domain name suffix can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To configure a domain name suffix for the public network, do not specify this option.
You can configure a domain name suffix list so that the resolver can use the list to supply the missing part of an incomplete name. For example, you can configure com as the suffix for example.com. The user only needs to enter example to obtain the IP address of example.com. The resolver adds the suffix and delimiter before passing the name to the DNS server.
Operating mechanism
The name resolver handles the queries based on the domain names that the user enters:
·     If the user enters a domain name without a dot (.) (for example, example), the resolver considers the domain name to be a host name. It adds a DNS suffix to the host name before performing the query operation. If no match is found for any host name and suffix combination, the resolver uses the user-entered domain name (for example, example) for the IP address query.
·     If the user enters a domain name with a dot (.) among the letters (for example, www.example), the resolver directly uses this domain name for the query operation. If the query fails, the resolver adds a DNS suffix for another query operation.
·     If the user enters a domain name with a dot (.) at the end (for example, example.com.), the resolver considers the domain name an FQDN and returns the successful or failed query result. The dot at the end of the domain name is considered a terminating symbol.
The device performs the above operations only when it searches the dynamic domain name resolution cache.
The device supports the domain name suffix list only when it acts as a DNS client.
A domain name suffix applies to both IPv4 DNS and IPv6 DNS.
The system allows a maximum of 16 domain name suffixes for the public network or each VPN instance. You can specify domain name suffixes for both public network and VPN instances.
# Configure domain name suffix com for the public network.
[Sysname] dns domain com
display dns domain
dns domain-name-group
Use dns domain-name-group to create a domain name group and enter its view, or enter the view of an existing domain name group.
Use undo dns domain-name-group to delete a domain name group.
dns domain-name-group group-name
undo dns domain-name-group group-name
The system has a default domain name group named any.
group-name: Specifies the name of a domain name group, a case-insensitive string of 1 to 31 characters.
When the device uses domain name rules to match DNS queries, you can associate a domain name rule with a domain name group to simplify configuration. If multiple domain names are to be matched, you do not need to configure domain name rules multiple times.
Operating mechanism
After you add domain names or subdomain names to a domain name group, you can associate a domain name rule with it, so that the device can distribute DNS queries based on the matching results. To add domain names or subdomain names to a domain name group, use the domain-name or subdomain-name command, respectively.
The relationships between a domain name rule and its associated domain name groups include the following types:
·     Include the domain name group—The device matches the domain name in a query against the domain names in the domain name groups. The match succeeds if the domain name in the query matches any domain name in a domain name group.
If the domain name rule includes default domain name group any, any domain name can match the rule.
·     Exclude the domain name group—The device matches the domain name in a query against the domain names in the domain name groups. The match succeeds only when the domain name in the query does not match any domain name in the domain name groups.
If the domain name rule includes default domain name group any, no domain names can match the rule.
The default domain name group cannot be manually created or deleted.
You can execute this command multiple times to create multiple domain name groups.
Do not delete domain name groups that are already associated with domain name rules.
# Create a domain name group named 1 and enter its view.
[Sysname] dns domain-name-group 1
[Sysname-domain-name-group-1]
dns domain-rule
domain-name
subdomain-name
dns domain-rule
Use dns domain-rule to configure a domain name rule.
Use undo dns domain-rule to delete a domain name rule.
dns domain-rule rule-id { domain-name domain-name | [ exclude ] domain-name-group group-name | subdomain-name subdomain-name } [ vpn-instance vpn-instance-name ] server-group group-id
undo dns domain-rule rule-id [ domain-name domain-name | [ exclude ] domain-name-group group-name | subdomain-name subdomain-name ]
No domain name rule is configured.
rule-id: Specifies the ID of a domain name rule. The value range is 1 to 16.
domain-name domain-name: Specifies a domain name, a dot-separated, case-insensitive string of up to 253 characters that can contain letters, digits, hyphens (-), underscores (_), and dots (.), for example, www.example.com. The domain name cannot start or end with a dot (.) or contain two consecutive dots (..).
exclude: Matches a DNS query when the domain name in the query is not in the domain name group. If you do not specify this keyword, the domain name rule matches a DNS query when the domain name in the query is in the domain name group.
domain-name-group group-name: Specifies a domain name group by its name, a case-insensitive string of 1 to 31 characters. The specified domain name group must already exist.
subdomain-name subdomain-name: Specifies a subdomain name, a dot-separated, case-insensitive string that can contain letters, digits, hyphens (-), underscores (_), and dots (.), for example, .example.com. The subdomain name can contain up to 253 characters, and each separated string can contain up to 63 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the DNS client that sends DNS queries belongs by its name, a case-sensitive string of 1 to 31 characters. If the DNS client belongs to the public network, do not specify this option.
server-group group-id: Specifies a DNS server group by its ID, in the range of 1 to 16. You can bind a domain name rule to a non-existent DNS server group. For the configuration to take effect, execute the dns server-group command to create that DNS server group.
This feature allows the device (DNS client or proxy) to search for a matching domain name rule and send queries to servers in the DNS server group bound to the rule.
Operating mechanism
A domain name rule can be matched in one of the following methods:
·     Exact match—The match succeeds only when the domain name in the query is exactly the same as a domain name in the rule.
·     Fuzzy match—The match succeeds if the domain name in the query contains a subdomain name.
When the device receives a user query and fails to find a local matching DNS entry, it looks for a matching domain name rule in the same VPN instance or on the public network as the user in ascending order of rule IDs:
·     If the domain name in the query matches a domain name or subdomain name in a rule, the device sends the query to DNS servers in the DNS server group bound to the rule.
¡     After the device receives the reply, it sends the reply to the user and stores the DNS mapping in the local DNS cache.
¡     If no reply is received, the device turns to the next domain name rule.
·     If the domain name in the query does not match any domain names or subdomain names in all rules, the device does not forward the query to DNS servers in DNS server groups and the domain name resolution fails.
A domain name rule is uniquely identified by its ID and VPN instance. When you configure a domain name rule, follow these guidelines:
·     A domain name rule can be bound to only one DNS server group.
·     A domain name rule can be associated with a maximum of eight domain name groups. Do not configure both the including the domain name group and excluding the domain name group matching methods for the same rule.
·     For one domain name rule, you can repeat this command to bind a maximum of eight domain names and subdomain names to the same DNS server group.
·     After you associate a domain name rule with a domain name group, do not configure the domain name or subdomain name matching method for the rule. After you configure the domain name or subdomain name matching method for a domain name rule, do not associate the rule with a domain name group.
·     To delete a domain name or subdomain name specified for a rule, execute the undo dns domain-rule command and specify the domain-name domain-name or subdomain-name subdomain-name option. To disassociate a domain name group from a domain name rule, specify the exclude domain-name-group domain-group-name or domain-name-group domain-group-name option. To delete a complete domain name rule, do not specify any parameters.
A user query can match only domain name rules that are in the same VPN instance or on the public network as the user.
A domain name rule and its bound DNS server group can be in different VPN instances, or one can be in a VPN instance and the other on the public network.
# Create domain name rule 1 and bind subdomain name .example.com and domain name www.ddeeff.com to DNS server group 1.
[Sysname] dns domain-rule 1 subdomain-name .example.com server-group 1
[Sysname] dns domain-rule 1 domain-name www.ddeeff.com server-group 1
# Create domain name rule 1, associate the rule with domain name group group1, and bind the rule to DNS server group 1.
[Sysname] dns domain-name-group group1
[Sysname-dns-domain-name-group-group1] domain-name www.example.com
[Sysname-dns-domain-name-group-group1] subdomain-name example.com
[Sysname-dns-domain-name-group-group1] quit
[Sysname] dns domain-rule 1 domain-name-group group1 server-group 1
dns server-group
dns dscp
Use dns dscp to set the DSCP value for DNS packets sent by a DNS client or DNS proxy.
Use undo dns dscp to restore the default.
dns dscp dscp-value
undo dns dscp
The DSCP value is 0 in DNS packets sent by a DNS client or DNS proxy.
dscp-value: Specifies the DSCP value in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for outgoing DNS packets.
[Sysname] dns dscp 30
dns proxy enable
Use dns proxy enable to enable DNS proxy.
Use undo dns proxy enable to disable DNS proxy.
dns proxy enable
DNS proxy is disabled.
This configuration applies to both IPv4 DNS and IPv6 DNS.
# Enable DNS proxy.
[Sysname] dns proxy enable
dns redirect enable
Use dns redirect enable to enable DNS redirection.
Use undo dns redirect enable to disable DNS redirection.
dns redirect enable
DNS redirection is disabled.
With DNS redirection enabled, the device monitors the received DNS requests (only UDP packets are supported in the current software version) and resolves the source IP addresses, source port numbers, and domain names. Then, the device searches for a matching domain name rule and redirects the request to the DNS server in the rule.
The device enabled with DNS redirection works as follows:
1.     The device searches for a matching domain name rule.
¡     If a match is found, it replaces the destination IP address in the request with the IP address of the first reachable DNS server in the server group bound to the rule. Then, the device forwards the request to the DNS server.
¡     If no match is found, the device does not redirect the DNS request.
2.     The device records the replacement, including the source IP address, source port number, and requested server address in the DNS request, and the replaced server address.
3.     Upon receiving the DNS reply, the device replaces the source IP address in the reply with the original server address in the request.
This configuration applies to both IPv4 DNS redirection and IPv6 DNS redirection.
# Enable DNS redirection.
[Sysname] dns redirect enable
dns server (system view/interface view)
Use dns server to specify the IPv4 address of a DNS server.
Use undo dns server to remove the IPv4 address of a DNS server.
dns server ip-address [ vpn-instance vpn-instance-name ]
undo dns server [ ip-address ] [ vpn-instance vpn-instance-name ]
No DNS server IPv4 address is specified.
Interface view
ip-address: Specifies the IPv4 address of a DNS server. When you execute the undo form of the command in interface view, you must specify this argument.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a DNS server IPv4 address for the public network, do not use this option.
In system view, you can specify a maximum of six DNS server IPv4 addresses for the public network or each VPN instance. You can specify DNS server IPv4 addresses for both public network and VPN instances.
In interface view, you can specify a maximum of six DNS server IPv4 addresses for the public network or each VPN instance. You can specify DNS server IPv4 addresses for both public network and VPN instances.
A DNS server IPv4 address specified in system view takes priority over a DNS server IPv4 address specified in interface view. A DNS server IPv4 address specified earlier has a higher priority. A DNS server IPv4 address manually specified takes priority over a DNS server IPv4 address dynamically obtained, for example, through DHCP. The device first sends a DNS query to the DNS server IPv4 address of the highest priority. If the first query fails, it sends the DNS query to the DNS server IPv4 address of the second highest priority, and so on.
If you do not specify an address, the undo dns server command in system view removes all DNS server IPv4 addresses for the public network or the specified VPN instance.
# Specify DNS server IPv4 address 172.16.1.1.
[Sysname] dns server 172.16.1.1
# Specify DNS server IPv4 address 172.16.1.1 on Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] dns server 172.16.1.1
display dns server
dns server (DNS server group view)
Use dns server to add an IPv4 DNS server to the DNS server group.
Use undo dns server to delete an IPv4 DNS server from the DNS server group.
A DNS server group does not have any DNS servers.
Operating mechanism
The device sends a DNS query to DNS servers in a DNS server group in the configuration order of their IPv4 addresses.
A DNS server group supports a maximum of six IPv4 DNS server addresses.
If you do not specify the ip-address argument when you execute the undo dns server command, the command deletes all IPv4 DNS server addresses from the DNS server group.
# Add DNS server 172.16.1.1 to DNS server group 1.
[Sysname-dns-server-group-1] dns server 172.16.1.1
dns server-group
Use dns server-group to create a DNS server group and enter its view, or enter the view of an existing DNS server group.
Use undo dns server-group to delete a DNS server group.
dns server-group group-id [ vpn-instance vpn-instance-name ]
undo dns server-group group-id
No DNS server group exists.
group-id: Specifies the ID of a DNS server group, in the range of 1 to 16.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the DNS server group is on the public network, do not specify this option.
Operating mechanism
# Create DNS server group 1 and enter its view.
description
dns domain-rule
dns snooping enable
Use dns snooping enable to enable DNS snooping.
Use undo dns snooping enable to disable DNS snooping.
dns snooping enable
DNS snooping is disabled.
DNS snooping is applicable to the scenario where traffic filtering is based on domain names.
Operating mechanism
Other modules (for example, the address object group module) can obtain the IP addresses corresponding to domain names through DNS snooping only after they send domain name subscription requests to the DNS module.
Enabled with DNS snooping, the device monitors received DNS requests and replies, and works as follows:
·     If the domain name in a DNS request matches a subscribed domain name, the device records the DNS mapping after receiving the DNS reply, and reports the mapping to the corresponding module for traffic filtering.
·     If the domain name does not match a subscribed domain name, the device does not record the DNS mapping.
When the domain names subscribed to by other modules age out, the DNS module notifies the modules of deleting the corresponding mappings to ensure mapping accuracy.
DNS snooping works only between the DNS client and DNS server, or the DNS client and DNS proxy.
The DNS snooping feature cannot be used across VPNs. Make sure the input and output interfaces of DNS packets on the device belong to the same VPN.
# Enable DNS snooping.
[Sysname] dns snooping enable
dns source-interface
Use dns source-interface to specify the source interface for DNS packets.
Use undo dns source-interface to restore the default.
dns source-interface interface-type interface-number [ vpn-instance vpn-instance-name ]
undo dns source-interface interface-type interface-number [ vpn-instance vpn-instance-name ]
No source interface is specified for DNS packets. The device uses the primary IP address of the output interface of the matching route as the source IP address for a DNS request.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a source interface on the public network, do not use this option.
This configuration applies to both IPv4 and IPv6.
In IPv4 DNS, the device uses the primary IPv4 address of the specified source interface as the source IP address of a DNS query. In IPv6 DNS, the device selects an IPv6 address of the specified source interface as the source IP address of a DNS query. The method of selecting the IPv6 address is defined in RFC 3484.
The system allows only one source interface for the public network or each VPN instance. If you execute this command multiple times, the most recent configuration takes effect. You can specify source interfaces for both public network and VPN instances.
This command takes effect whether the source interface belongs to the VPN instance or not. As a best practice, specify an interface that belongs to the VPN instance as the source interface.
# Specify Ten-GigabitEthernet 3/0/1 as the source interface for DNS packets on the public network.
[Sysname] dns source-interface ten-gigabitethernet 3/0/1
dns trust-interface
Use dns trust-interface to specify a DNS trusted interface.
Use undo dns trust-interface to remove a DNS trusted interface.
dns trust-interface interface-type interface-number
undo dns trust-interface [ interface-type interface-number ]
No DNS trusted interface is specified.
By default, an interface obtains DNS suffix and DNS server information from DHCP. A network attacker might act as the DHCP server to assign a wrong DNS suffix and DNS server address to the device. As a result, the device fails to obtain the resolved IP address or might get the wrong IP address. With the DNS trusted interface specified, the device only uses the DNS suffix and DNS server information obtained through the trusted interface to avoid attacks.
You can configure a maximum of 128 DNS trusted interfaces on the device.
If you do not specify an interface, the undo dns trust-interface command removes all DNS trusted interfaces and restores the default.
# Specify Ten-GigabitEthernet 3/0/1 as a DNS trusted interface.
[Sysname] dns trust-interface ten-gigabitethernet 3/0/1
domain-name
Use domain-name to add a domain name to a domain name group.
Use undo domain-name to delete a domain name from a domain name group.
undo domain-name domain-name
A domain name group does not have domain names.
Domain name group view
domain-name: Specifies a domain name, a dot-separated, case-insensitive string of up to 253 characters that can contain letters, digits, hyphens (-), underscores (_), and dots (.), for example, www.example.com. It cannot start or end with a dot (.) or contain two consecutive dots (..).
When the device matches the domain name in a query against the domain names in a domain name group, the match succeeds only when the domain name in the query is exactly the same as a domain name in the domain name group.
You can execute this command multiple times to add multiple domain names to a domain name group.
# Add domain name www.example.com to domain name group 1.
[Sysname-domain-name-group-1] domain-name www.example.com
subdomain-name
ip host
Use ip host to create a host name-to-IPv4 address mapping.
Use undo ip host to remove a host name-to-IPv4 address mapping.
ip host host-name ip-address [ vpn-instance vpn-instance-name ]
undo ip host host-name ip-address [ vpn-instance vpn-instance-name ]
No host name-to-IPv4 address mappings exist.
host-name: Specifies a host name, a case-insensitive string of 1 to 253 characters that can contain letters, digits, hyphens (-), underscores (_), and dots (.). A host name must meet the following requirements:
·     The host name string is separated by dots (.). Each separated part can contain up to 63 characters.
·     The host name cannot start or end with a dot (.).
·     The host name cannot contain two consecutive dots (..).
ip-address: Specifies the IPv4 address of the host.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To create a host name-to-IP address mapping for the public network, do not specify this option.
The system allows a maximum of 1024 host name-to-IPv4 address mappings for the public network or each VPN instance. You can configure host name-to-IPv4 address mappings for both public network and VPN instances.
Each host name maps to only one IPv4 address for the public network or a VPN instance. If you execute this command multiple times, the most recent configuration takes effect.
Do not use the ping command parameter ip, -a, -c, -f, -h, -i, -m, -n, -p, -q, -r, -s, -t, -tos, -v, or -vpn-instance as the host name. For more information about the ping command parameters, see Network Management and Monitoring Command Reference.
# Map IPv4 address 10.110.0.1 to host name aaa for the public network.
[Sysname] ip host aaa 10.110.0.1
display dns host
ipv6 dns dscp
Use ipv6 dns dscp to set the DSCP value for IPv6 DNS packets sent by an IPv6 DNS client or DNS proxy.
Use undo ipv6 dns dscp to restore the default.
ipv6 dns dscp dscp-value
undo ipv6 dns dscp
The DSCP value is 0 in IPv6 DNS packets sent by an IPv6 DNS client or DNS proxy.
# Set the DSCP value to 30 for outgoing IPv6 DNS packets.
[Sysname] ipv6 dns dscp 30
ipv6 dns server (system view)
Use ipv6 dns server to specify the IPv6 address of a DNS server.
Use undo ipv6 dns server to remove the IPv6 address of a DNS server.
ipv6 dns server ipv6-address [ interface-type interface-number ] [ vpn-instance vpn-instance-name ]
undo ipv6 dns server [ ipv6-address [ interface-type interface-number ] ] [ vpn-instance vpn-instance-name ]
No DNS server IPv6 address is specified.
ipv6-address: Specifies the IPv6 address of a DNS server.
interface-type interface-number: Specifies the output interface by its type and number. If you do not specify an interface, the device forwards DNS packets out of the output interface of the matching route. Specify this argument if the IPv6 address of the DNS server is a link-local address. Do not specify this argument if the IPv6 address of the DNS server is a global unicast address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a DNS server IPv6 address on the public network, do not use this option.
For dynamic DNS, the device sends a DNS query request to the DNS servers in the order their IPv6 addresses are specified.
The system allows a maximum of six DNS server IPv6 addresses for the public network or each VPN instance. You can specify DNS server IPv6 addresses for both public network and VPN instances.
If you do not specify an IPv6 address, the undo ipv6 dns server command removes all DNS server IPv6 addresses for the public network or the specified VPN instance.
# Specify DNS server IPv6 address 2002::1 for the public network.
[Sysname] ipv6 dns server 2002::1
ipv6 dns server (DNS server group view)
Use ipv6 dns server to add an IPv6 DNS server to the DNS server group.
Use undo ipv6 dns server to delete an IPv6 DNS server from the DNS server group.
ipv6-address : Specifies the IPv6 address of a DNS server.
Operating mechanism
The device sends a DNS query to DNS servers in a DNS server group in the configuration order of their IPv6 addresses.
A DNS server group supports a maximum of six IPv6 DNS server addresses.
If you do not specify the ipv6-address argument when you execute the undo ipv6 dns server command, the command deletes all IPv6 DNS server addresses from the DNS server group.
# Add DNS server 2000::1 to DNS server group 1.
[Sysname-server-group-1] ipv6 dns server 2000::1
ipv6 host
Use ipv6 host to create a host name-to-IPv6 address mapping.
Use undo ipv6 host to remove a host name-to-IPv6 address mapping.
ipv6 host host-name ipv6-address [ vpn-instance vpn-instance-name ]
undo ipv6 host host-name ipv6-address [ vpn-instance vpn-instance-name ]
No host name-to-IPv6 address mappings exist.
ipv6-address: Specifies the IPv6 address of the host.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To create a host name-to-IPv6 address mapping for the public network, do not specify this option.
The system allows a maximum of 1024 host name-to-IPv6 address mappings for the public network or each VPN instance. You can configure host name-to-IPv6 address mappings for both public network and VPN instances.
Each host name maps to only one IPv6 address for the public network or a VPN instance. If you execute this command multiple times, the most recent configuration takes effect.
Do not use the ping ipv6 command parameter -a, -c, -i, -m, -q, -s, -t, -tc, -v, or -vpn-instance as the host name. For more information about the ping ipv6 command parameters, see Network Management and Monitoring Command Reference.
# Map IPv6 address 2001::1 to host name aaa for the public network.
[Sysname] ipv6 host aaa 2001::1
ip host
reset dns host
Use reset dns host to clear dynamic DNS entries.
reset dns host [ client | snooping ] [ ip | ipv6 ] [ vpn-instance vpn-instance-name ]
client: Clear dynamic DNS entries on the DNS client.
snooping: Clear dynamic DNS entries on the device enabled with DNS snooping.
ip: Specifies type A queries. A type A query resolves a domain name to the mapped IPv4 address.
ipv6: Specifies type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears dynamic DNS entries for the public network.
If you do not specify the ip or ipv6 keyword, the reset dns host command clears dynamic DNS entries of all query types.
Use this command to clear the following dynamic DNS entries:
·     Dynamic DNS entries on the DNS client.
·     Dynamic DNS entries on the device enabled with DNS snooping.
To clear all the dynamic DNS entries, do not specify the client or snooping keyword.
# Clear dynamic DNS entries of all query types for the public network.
<Sysname> reset dns host
display dns host
subdomain-name
Use subdomain-name to add a subdomain name to a domain name group.
Use undo subdomain-name to delete a subdomain name from a domain name group.
undo subdomain-name subdomain-name
A domain name group does not have subdomain names.
subdomain-name: Specifies a subdomain name, a dot-separated, case-insensitive string that can contain letters, digits, hyphens (-), underscores (_), and dots (.), for example, .example.com. The subdomain name can include up to 253 characters, and each separated string includes up to 63 characters.
When the device matches the domain name in a query against the subdomain names in a domain name group, the match succeeds if the domain name in the query contains a subdomain name in the group. For example, example.net has two subdomain names a.example.net and b.example.net.
·     If you specify subdomain-name as .example.net, only a.example.net and b.example.net can match the specified subdomain name.
·     If you specify subdomain-name as example.net, example.net, a.example.net, and b.example.net can all match the specified subdomain name.
You can execute this command multiple times to add multiple subdomain names to a domain name group.
# Add subdomain name com to domain name group 1.
[Sysname-domain-name-group-1] subdomain-name com
domain-name
