- 03-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-MVRP commands
- 06-QinQ commands
- 07-VLAN termination commands
- 08-Loop detection commands
- 09-Spanning tree commands
- 10-LLDP commands
- 11-L2PT commands
11-L2PT commands | 50.58 KB |
L2PT commands
l2protocol transparent enable
Use l2protocol transparent enable to enable transparent transmission for packets of the specified protocol.
Use undo l2protocol transparent enable to disable transparent transmission for packets of the specified protocol.
l2protocol transparent { lacp | lldp } enable
undo l2protocol transparent { lacp | lldp } enable
Transparent transmission is disabled for packets of the LACP and LLDP protocols, and enabled for other packets.
Enter Layer 3 FlexE logical interface view.
Enter Layer 3 FlexE logical subinterface view.
lacp: Specifies LACP.
lldp: Specifies LLDP.
This feature is applicable to L2VPN networks such as VPLS and VPWS networks. With this feature disabled on a Layer 3 interface acting as an AC, it drops received LACP or LLDP packets. As a result, user networks across sites cannot communicate by using these Layer 2 protocols. With this feature enabled on a PE, the Layer 3 interface acting as an AC can receive and transparently transmit packets of the specified protocol. These packets are not encapsulated with the multicast destination MAC address for tunneled packets. When the packets reach the peer PE through a PW, the peer PE forwards the packets to the corresponding user sites.
For transparent transmission configurations of different packets in the network, see the following table.
Packet type |
Network type |
Configuration of transparent packet transmission |
eoam3ah |
SRv6 VPLS: Transparent transmission SRv6 VPWS: Transparent transmission |
l2protocol transparent lacp enable |
lldp |
l2protocol transparent lldp enable |
gmrp |
None. |
gvrp |
None. |
dldp |
None. |
hgmp |
None. |
vtp |
None. |
dtp |
None. |
cdp |
None. |
udld |
None. |
pagp |
None. |
pvst+ |
None. |
stp |
None. |
lacp |
mvrp |
None. |
e-lmi |
None. |
e-lmi |
None. |
802.1X |
None. |
sstp |
None. |
On a Layer 3 interface that has LLDP packet transparent transmission enabled, do not configure the interface to operate in dynamic aggregation mode to prevent aggregate interface flapping.
On a Layer 3 interface that has LLDP packet transparent transmission enabled, disable LLDP to prevent LLDP exceptions on devices attached to the interface.
If different subinterfaces of the same main interface on a following card are bound to the same VSI, transparent transmission for packets of the specified protocol takes effect on all subinterfaces of the main interface once you enable the feature on one of them.
# Enable transparent transmission for packets of the LACP protocol on GigabitEthernet1/0/1.1.
[Sysname] interface ten-gigabitethernet 3/0/1.1
[Sysname-GigabitEthernet1/0/1.1] l2protocol transparent lacp enable
