19-EVPN Configuration Guide
HomeSupportRoutersCR16000-M SeriesConfigure & DeployConfiguration GuidesH3C CR16000-M Router Configuration Guides-R8630Pxx-6W10019-EVPN Configuration Guide
03-EVPN VPLS configuration
03-EVPN VPLS configuration 1.35 MB
Configuring EVPN VPLS·· 1
About EVPN VPLS· 1
EVPN VPLS network model 1
Neighbor auto-discovery and PW establishment 1
MAC address learning, aging, and withdrawal 2
Traffic forwarding and flooding· 2
Full mesh and split horizon· 3
EVPN VPLS multihoming· 3
ARP flood suppression· 6
Control word· 7
L2VPN flow label 7
MAC mobility· 8
EVPN E-tree· 8
LDP or static PW ACs for EVPN PWs· 9
Intercommunication between EVPN VXLAN and EVPN VPLS networks· 10
EVPN VPLS over mLDP P2MP· 11
EVPN VPLS tasks at a glance· 16
Restrictions and guidelines: EVPN VPLS configuration· 18
Configuring a VSI 18
Creating a VSI 18
Configure VSI parameters· 18
Configuring an EVPN instance· 19
About EVPN instance configuration· 19
Restrictions and guidelines for EVPN instance configuration· 19
Configuring an EVPN instance created in system view· 19
Configuring an EVPN instance created in VSI view· 21
Mapping ACs to a VSI 22
Mapping a Layer 3 interface to a VSI 22
Mapping an Ethernet service instance to a VSI 22
Configuring BGP to advertise BGP EVPN routes· 23
Restrictions and guidelines for BGP EVPN route advertisement 23
Enabling BGP to advertise BGP EVPN routes· 23
Enabling advertisement of MPLS-encapsulated BGP EVPN routes· 24
Configuring BGP EVPN route attributes· 24
Configuring route advertisement and optimal route selection for BGP EVPN routes· 25
Configuring BGP route reflection settings· 27
Configuring BGP EVPN route filtering· 28
Advertising BGP RPKI validation state to a peer or peer group· 29
Configuring BGP soft-reset by saving all route updates· 29
Maintaining BGP sessions· 29
Configuring a PW class· 30
Configuring EVPN VPLS multihoming· 30
Restrictions and guidelines for EVPN VPLS multihoming· 30
Configuring an ESI 31
Setting the redundancy mode· 32
Configuring the DF election algorithm·· 33
Enabling AC state-based DF election· 34
Setting the DF election delay· 34
Enabling non-revertive mode for preference-based DF election· 35
Configuring Ethernet segment route advertisement delay· 36
Setting the advertisement delay timer for Ethernet auto-discovery routes· 36
Configuring local FRR for EVPN VPLS· 37
Generating MAC address entries for received MAC/IP advertisement routes· 38
Enabling VSIs to ignore the state of ACs· 39
Disabling advertisement of EVPN multihoming routes· 39
Ignoring the Ethernet tag on advertisement of Ethernet auto-discovery and MAC/IP advertisement routes  40
Configuring the device to advertise only MAC/IP advertisement routes that contain non-all-zero MAC addresses  40
Enabling the device to monitor the BGP peer status of another local edge device· 41
Setting the revertive WTR timer 42
Managing MAC address entries and ARP learning· 43
Disabling MAC address advertisement 43
Configuring UMRs· 43
Enabling MAC mobility event suppression· 44
Disabling learning of MAC addresses from ARP or ND information· 46
Configuring the AC source MAC check feature· 46
Disabling ARP information advertisement 47
Enabling EVPN E-tree· 48
About EVPN E-tree· 48
Restrictions and guidelines for EVPN E-tree configuration· 48
Enabling EVPN E-tree for an EVPN instance created in system view· 48
Enabling EVPN E-tree for an EVPN instance created in VSI view· 48
Configuring LDP or static PWs as ACs for EVPN PWs· 49
About LDP or static PW AC configuration for EVPN PWs· 49
Restrictions and guidelines for LDP or static PW AC configuration for EVPN PWs· 49
Prerequisites for LDP or static PW AC configuration for EVPN PWs· 50
Configuring LDP PWs as ACs for EVPN PWs· 50
Configuring static PWs as ACs for EVPN PWs· 51
Configuring EVPN VPLS over mLDP P2MP· 52
Restrictions and guidelines· 52
Prerequisites· 52
Configuring a multicast inclusive tunnel 52
Configuring a multicast selective tunnel 53
Confining floods to the local site· 53
Enabling ARP flood suppression· 54
Enabling direct PW-to-AC forwarding for a VSI 54
Setting the maximum number of MAC addresses that an AC can learn· 55
About setting the maximum number of MAC addresses that an AC can learn· 55
Setting the maximum number of MAC addresses that a Layer 3 interface type AC can learn· 55
Setting the maximum number of MAC addresses that an Ethernet service instance AC can learn· 55
Enabling packet statistics for an AC· 56
Restrictions and guidelines for AC packet statistics· 56
Enabling packet statistics for a Layer 3 interface· 56
Enabling packet statistics for an Ethernet service instance· 56
Enabling bandwidth-based load sharing· 57
Enabling SNMP notifications for L2VPN PWs· 57
Testing the connectivity of an EVPN PW·· 57
Pinging a PW destination· 57
Tracing the path to a PW destination· 58
Display and maintenance commands for EVPN VPLS· 58
EVPN VPLS configuration examples‌· 61
Example: Configuring EVPN VPLS between singlehomed sites· 61
Example: Configuring EVPN VPLS multihoming (access through aggregate links) 65
Example: Configuring EVPN VPLS multihoming (access through an S-Trunk system) 71
Example: Configuring local FRR for EVPN VPLS· 78
Example: Configuring LDP PWs as ACs for EVPN PWs· 85
Example: Configuring EVPN VPLS over mLDP· 92
About EVPN VPLS
EVPN Virtual Private LAN Service (VPLS) is a Layer 2 VPN technology that uses MP-BGP to advertise EVPN routes in the control plane and MPLS for forwarding in the data plane. EVPN VPLS provides point-to-multipoint forwarding services for users with MAC address table lookup in VSIs.
As shown in Figure 1, an EVPN VPLS network contains the following devices:
·     Customer edge (CE)—Customer device directly connected to the service provider network.
·     Provider edge (PE)—Service provider device connected to CEs. PEs provide access to the EVPN VPLS network and forward traffic between customer network sites by using public tunnels.
A PE uses ACs, PWs, tunnels, and VSIs to provide EVPN VPLS services.
·     Attachment circuit (AC)—A physical or virtual link between a CE and a PE.
·     Pseudowire (PW)—A pair of unidirectional virtual connections in opposite directions between two PEs.
·     Public tunnel—A connection that carries one or more PWs across the MPLS or IP backbone. A public tunnel can be an LSP, GRE, or MPLS TE tunnel.
·     Virtual Switch Instance (VSI)—A virtual switch instance provides Layer 2 switching services for a VPLS instance (EVPN instance) on a PE. A VSI acts as a virtual switch that has all the functions of a conventional Ethernet switch, including source MAC address learning, MAC address aging, and flooding. VPLS uses VSIs to forward Layer 2 data packets in EVPN instances.
Figure 1 EVPN VPLS network
In an EVPN VPLS network, PEs discover neighbors and establish PWs by using the following procedure:
1.     The PEs assign two PW labels to each VSI for forwarding known unicast, broadcast, unknown unicast, and unknown multicast (BUM) packets.
2.     Each PE advertises the PW labels to remote PEs as follows:
¡     Advertises the PW labels used for forwarding known unicast packets through MAC/IP prefix advertisement routes or Ethernet auto-discovery routes.
¡     Advertises the PW labels used for forwarding BUM traffic through IMET routes.
Those routes carry route targets.
3.     Each PE matches the route targets in a received MAC/IP prefix advertisement route, Ethernet auto-discovery route, or IMET route with the import targets of the EVPN instance. If the route targets match the import targets, the PE establishes a unidirectional virtual connection based on the PE address and PW label information carried in the route.
PW establishment is finished when two virtual connections in opposite directions are established between two PEs.
Source MAC address learning
A PE uses the MAC address table of a VSI to forward Layer 2 unicast traffic for that VSI.
A PE learns source MAC addresses in the following ways:
·     Local MAC address learning—When the PE receives a frame from a local CE, it first identifies the VSI of the frame. Then, the PE adds the source MAC address of the frame (the MAC address of the local CE) to the MAC address table of the VSI. The output interface of the MAC address entry is the AC that receives the frame.
·     Remote MAC address learning—A PE advertises the MAC addresses of local CEs to remote PEs through BGP EVPN MAC/IP advertisement routes. When a remote PE receives the routes, it adds the received MAC addresses to the MAC address table of the corresponding VSI. The output interface is the PW.
MAC address aging
·     Local MAC address aging—The MAC address table uses an aging timer for each dynamic MAC address entry. If no packet is received from a MAC address before the aging timer expires, VPLS deletes the MAC address.
·     Remote MAC address aging—Remote MAC addresses advertised through MAC/IP advertisement routes are not removed from the MAC address table until routes to withdraw the MAC addresses are received.
MAC address withdrawal
When an AC goes down, the PE deletes MAC addresses on the AC. Then it sends an LDP address withdrawal message to notify all other PEs in the EVPN instance to delete those MAC addresses.
Unicast traffic forwarding
After a PE receives a unicast packet with a known destination MAC address from an AC, the PE searches the MAC address table of the VSI bound to the AC for packet forwarding.
·     If the output interface in the entry is a PW, the PE inserts the PW label of the PW to the packet, and adds the public tunnel header to the packet. It then forwards the packet to the remote PE over the PW. If the public tunnel is an LSP or MPLS TE tunnel, each packet on the PW contains two labels. The inner label is the PW label, which identifies the PW and ensures that the packet is forwarded to the correct VSI. The outer label is the public LSP or MPLS TE tunnel label, which ensures that the packet is correctly forwarded to the remote PE.
·     If the output interface in the entry is a local interface, the PE directly forwards the packet to the local interface.
After a PE receives a unicast packet with a known destination MAC address from a PW, the PE searches the MAC address table of the VSI bound to the PW for packet forwarding. The PE forwards the packet through the output interface in the matching MAC address entry.
Flooding
When a PE receives flood traffic from an AC in a VSI, it will flood the traffic to the following interfaces:
·     All ACs in the VSI except for the incoming AC.
·     All PWs associated with the VSI.
When a PE receives flood traffic from a PW, it will flood the traffic to all ACs in the VSI bound to the PW.
A Layer 2 network requires a loop prevention protocol such as STP to avoid loops. However, a loop prevention protocol on PEs brings management and maintenance difficulties. Therefore, EVPN VPLS uses the following methods to prevent loops:
·     Full mesh—Every two PEs in an EVPN instance must establish PWs. The PWs form a full mesh among PEs in the EVPN instance.
·     Split horizon—A PE does not forward packets received from a PW to any other PWs in the same VSI but only forwards those packets to ACs.
About EVPN VPLS multihoming
As shown in Figure 2, EVPN VPLS supports deploying multiple PEs at a site for redundancy and high availability. On the redundant PEs, Ethernet links connected to the site form an ES that is uniquely identified by an ESI. EVPN VPLS supports only dualhoming.
Figure 2 EVPN VPLS multihoming
DF election
To prevent redundant PEs from sending duplicate flood traffic to a multihomed site, a designated forwarder (DF) is elected from the PEs to forward flood traffic to the local site. PEs that fail the election are assigned the backup designated forwarder (BDF) role. BDFs do not forward flood traffic to the local site.
Figure 3 DF election
DF election can be performed by using a VLAN tag-based algorithm or preference-based algorithm.
·     VLAN tag-based DF election
PEs select a DF for each AC based on the VLAN tag and PE IP address as follows:
a.     Arrange source IP addresses in Ethernet segment routes with the same ESI in ascending order and assign a sequence number to each IP address, starting from 0.
b.     Divide the lowest VLAN ID permitted on an AC by the number of the redundant PEs, and match the reminder to the sequence numbers of IP addresses.
c.     Assign the DF role to the PE that uses the IP address with the matching sequence number.
The following uses PE 1 and PE 2 in Figure 4 as an example to explain the DF election procedure:
d.     PE 1 and PE 2 send Ethernet segment routes to each other.
e.     The PEs assign sequence numbers 0 and 1 to IP addresses 1.1.1.1 and 2.2.2.2 in the Ethernet segment routes, respectively.
f.     The PEs divide 4 (the lowest VLAN ID permitted by the ACs) by 2 (the number of redundant PEs), and match the reminder 0 to the sequence numbers of the IP addresses.
g.     The DF role is assigned to PE 1 at 1.1.1.1.
Figure 4 VLAN tag-based DF election
·     Preference-based DF election
PEs select a DF for each ES based on the DF election preference, the Don't Preempt Me (DP) bit in Ethernet segment routes, and PE IP address. The DP bit can be set to one of the following values:
¡     1—Non-revertive mode is enabled for preference-based DF election (DF preemption is disabled). A DF retains its role when a new DF is elected.
¡     0—Non-revertive mode is disabled for preference-based DF election (DF preemption is enabled).
Preference-based DF election uses the following rules to select a DF for an ES:
a.     The PE with higher preference becomes the DF.
b.     If two PEs have the same preference, the PE with the DP bit set to 1 becomes the DF.
c.     If both of the PEs have the DP bit set to 1, the PE with a lower IP address becomes the DF.
As shown in Figure 5, PE 2 is the DF for ES 1, and PE 1 is the DF for ES 2.
Figure 5 Preference-based DF election
Redundancy mode
The device supports single-active redundancy mode and all-active redundancy mode of EVPN VPLS multihoming.
·     Single-active mode—This mode allows one of the redundant PEs to forward traffic. When the primary PE becomes unavailable because of device failure or link failure, traffic is switched to the secondary PE for forwarding.
·     All-active mode—This mode allows all redundant PEs to a multihomed site to load share unicast traffic.
IP aliasing
In all-active redundancy mode, all redundant PEs of an ES advertise the ES to remote PEs through MP-BGP. IP aliasing allows a remote PE to add the IP addresses of all the redundant PEs as the next hops for the MAC or ARP information received from one of these PEs. This mechanism creates ECMP routes between the remote PE and the redundant PEs.
Local FRR for EVPN VPLS
As shown in Figure 6, CE 1 is dualhomed to PE 1 and PE 2, and PE 1 is the DF. When the AC on PE 1 fails, PE 1 deletes the corresponding MAC address entries and advertises the local unreachable event to PE 2 and remote PEs (PE 3 in this example). Then, the remote PEs will switch traffic destined for CE 1 to the tunnels to PE 2. This process takes some time. PE 1 might receive packets destined for CE 1 before the remote PEs are notified of the unreachable event and perform link switchover. In this situation, PE 1 drops the packets, because the AC's MAC address entries have been deleted. To resolve this issue, enable local FRR on PE 1. If an AC fails, PE 1 changes the output interface of the AC's MAC address entries to the index of the PW between PE 1 and PE 2. When receiving packets from remote PEs after its AC fails, PE 1 forwards the packets to PE 2 over the PW to prevent traffic loss.
Figure 6 Local FRR network diagram
ARP flood suppression reduces ARP request broadcasts by enabling a PE to reply to ARP requests on behalf of VMs.
As shown in Figure 7, this feature snoops ARP requests, ARP responses, and BGP EVPN routes to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the PE replies to the request on behalf of the VM. If no match is found, the PE floods the request to both local and remote sites.
Figure 7 ARP flood suppression
ARP flood suppression uses the following workflow:
1.     CE1 sends an ARP request to obtain the MAC address of CE 2.
2.     PE 1 creates a suppression entry for CE 1, floods the ARP request to local CEs and remote PEs (PE 2 and PE 3) in the VSI, and sends the suppression entry to PE 2 and PE 3 through BGP EVPN. Unicast-mode flooding is used to illustrate the workflow.
3.     PE 2 and PE 3 de-encapsulate the ARP request and broadcast the request to local CEs in the VSI.
4.     CE 2 sends an ARP reply after it receives the ARP request.
5.     PE 2 creates a suppression entry for CE 2, forwards the ARP reply to PE 1, and sends the suppression entry to PE 1 and PE 3 through BGP EVPN.
6.     PE 1 de-encapsulates the ARP reply and forwards the ARP reply to CE 1.
7.     CE 4 sends an ARP request to obtain the MAC address of CE 1.
8.     PE 1 creates a suppression entry for CE 4 and replies to the ARP request.
9.     CE 3 sends an ARP request to obtain the MAC address of CE 1.
10.     PE 3 creates a suppression entry for CE 3 and replies to the ARP request.
Control word
The control word field is between the MPLS label stack and the Layer 2 data. It carries control information for the Layer 2 frame, for example, the sequence number.
The control word feature has the following functions:
·     Avoids fragment disorder. In multipath forwarding, fragments received might be disordered. The control word feature reorders the fragments according to the sequence number carried in the control word field.
·     Identifies the original payload length for packets that include padding.
The control word field is optional for EVPN VPLS. You can configure whether to carry the control word field in packets sent on PWs. If you enable the control word feature on PEs at both ends of a PW, packets transmitted on the PW carry the control word field. Otherwise, the packets do not carry the control word field.
L2VPN flow label
Packets carrying different types of traffic might be transmitted through the same PW and encapsulated with the same PW label. The P devices forward the traffic flows of a PW over the same path even if Equal Cost Multiple Paths (ECMPs) exist.
The L2VPN flow label feature can enable a P device to perform load sharing on packets based on the flow types.
After you configure this feature, the P and PE devices process packets as follows:
·     When the ingress PE encapsulates a packet, it adds a flow label before it adds a PW label, as shown in Figure 8.
The ingress PE adds different flow labels for packets of different traffic types.
·     The P devices perform load sharing on packets based on the flow labels.
·     The egress PE removes both the PW and flow labels from a packet before forwarding the packet.
Figure 8 L2VPN flow label feature
You can enable the flow label sending, receiving, or both sending and receiving capabilities on a PE.
·     The sending capability enables a PE to send packets with flow labels. The PE adds a flow label before it adds a PW label to a packet during encapsulation.
·     The receiving capability enables a PE to identify the flow label in a received packet and removes the flow label before forwarding the packet.
For two PEs to successfully negotiate the flow label capabilities, make sure one end has the sending capability and the other end has the receiving capability.
For EVPN VPLS, you must manually configure flow label capabilities for the local and remote PEs.
MAC mobility
MAC mobility refers to the movement of a VM or host from one ES to another. The source PE is unaware of the MAC move event. To notify other PEs of the change, the destination PE advertises a MAC/IP advertisement route for the MAC address. The source PE withdraws the old route for the MAC address after receiving the new route. The MAC/IP advertisement route has a sequence number that increases when the MAC address moves. The sequence number identifies the most recent move if the MAC address moves multiple times.
EVPN E-tree
About EVPN E-tree
In an EVPN VPLS network, EVPN E-tree isolates unicast and flood traffic (broadcast, multicast, and unknown unicast) of ACs in the same EVPN instance based on the AC roles. With EVPN E-tree, the device isolates unicast and flood traffic of ACs in the same EVPN instance as follows:
·     Leaf ACs can access root ACs.
·     Leaf ACs cannot access each other.
·     Root ACs can access each other and access leaf ACs.
Figure 9 EVPN E-tree network diagram
Local traffic isolation
EVPN E-tree isolates traffic between local ACs on a PE as follows:
·     When the PE receives packets from a leaf AC on a VSI, it forwards the packets only to root ACs on the VSI.
·     When the PE receives packets from a root AC on a VSI, it forwards the packets to all local ACs on the VSI except the incoming AC.
Remote known unicast traffic isolation
With EVPN E-tree, PEs perform MAC address learning for hosts attached to leaf ACs as follows:
1.     When a PE receives a packet from a leaf AC, it learns the source MAC address of the packet and adds the Leaf flag to the MAC address.
2.     The PE advertises the MAC address to the remote PE in a MAC/IP advertisement route. The route carries the E-tree extended community attribute that contains the Leaf flag.
3.     The remote PE adds the MAC address that carries the Leaf flag to the MAC address table.
When one PE receives a packet destined for a host on another PE from a local AC, it searches the MAC address table for the destination MAC address. If the entry of the destination MAC address has the Leaf flag and the packet is also from a leaf AC, the PE discards the packet. In other situations, the PE forwards the packet.
Remote flood traffic isolation
With EVPN E-tree, a PE assigns a Leaf label to the leaf ACs of each VSI. The PE adds the Leaf label to the E-tree extended community attribute in Ethernet auto-discovery routes and advertises the routes to remote PEs.
EVPN E-tree isolates flood traffic from one PE to another PE as follows:
1.     When a PE receives a flood packet from a leaf AC on a VSI, it adds the Leaf label of that VSI to the packet, and then adds the private network label and public network label to the packet. After that, the PE forwards the packet to the remote PE.
2.     The remote PE removes the private network label and public network label and finds the Leaf label. Then, the PE forwards the packet only to local root ACs on the same VSI.
This feature ensures that a traditional VPLS network and an EVPN VPLS network can communicate with each other. The LDP or static PWs in the VPLS network are configured as ACs to the EVPN VPLS network. These ACs are referred to as UPWs in the EVPN VPLS network. Packets can be forwarded between EVPN PWs and UPWs, so the VPLS and EVPN VPLS networks can communicate with each other.
With this feature, an LDP or static PW can be single-homed to an EVPN PW or two LDP or static PWs can be dual-homed to two EVPN PWs.
As shown in Figure 10, in the VPLS network, PE 1 is connected to PE 2 and PE 3 through LDP or static PWs. One of the PWs is the primary PW and the other PW is the backup PW. The PWs are UPWs. In the EVPN VPLS network, PE 4 is connected to PE 2 and PE 3 through EVPN PWs. The UPWs in the VPLS network act as ACs for the EVPN VPLS network. When PE 2 or PE 3 receives packets from the UPWs, it decapsulates MPLS encapsulation from the packets and looks up the MAC address table for a matching EVPN PW. Then, the PE adds MPLS encapsulation to the packets based on the EVPN PW and forwards the packets to PE 4. When PE 2 or PE 3 receives packets from an EVPN PW, it uses the same procedure to process the packets.
Figure 10 LDP or static PW ACs for EVPN PWs
Figure 11 shows a typical application scenario for intercommunication between EVPN VXLAN and EVPN VPLS networks. Two EVPN VXLAN networks are connected through an EVPN VPLS network. GW 1, GW 2, GW 3, and GW 4 are boundary devices of the EVPN VXLAN and EVPN VPLS networks. They reoriginate the MAC/IP advertisement routes generated in one network and advertise the routes to another network. Route advertisement across the EVPN VXLAN and EVPN VPLS networks enables intercommunication between the EVPN VXLAN and EVPN VPLS networks.
Figure 11 Application scenario for intercommunication between EVPN VXLAN and EVPN VPLS networks
As shown in Figure 11, GWs handle received MAC/IP advertisement routes as follows:
·     When a GW receives a MAC/IP advertisement route from an EVPN VXLAN network, it reoriginates the route and advertises the route to the EVPN VPLS network. When the GW reoriginates the route, it performs the following operations:
a.     Assigns and adds an MPLS label to the route.
b.     Changes the encapsulation type of the route to MPLS encapsulation.
c.     Changes the RD and route targets of the route.
·     When a GW receives a MAC/IP advertisement route from the EVPN VPLS network, it reoriginates the route and advertises the route to the connected EVPN VXLAN network. When the GW reoriginates the route, it performs the following operations:
d.     Looks up the VXLAN ID matching the route and adds the VXLAN ID to the route.
e.     Changes the encapsulation type of the route to VXLAN encapsulation.
f.     Changes the RD and route targets of the route.
After the GWs finish MAC address learning through MAC/IP advertisement routes, they add VXLAN or MPLS encapsulation to received packets according to the learned MAC address entries. Then, they forward the packets to an EVPN VXLAN network or the EVPN VPLS network.
For more information about configuring intercommunication between EVPN VXLAN and EVPN VPLS networks, see "Configuring EVPN VXLAN."
Without a multicast tunnel, a PE in an EVPN VPLS network replicates Layer 2 flood traffic (multicast, broadcast, and unknown unicast traffic) and sends the replicas through all PWs and local interfaces except the incoming interface. As shown in Figure 12, PE 1 replicates a multicast flow and forwards the replicas over the public tunnels to PE 2 and PE 3. The number of flood traffic replicas grows with the number of PEs deployed in the network, which increases the bandwidth usage of the link between PE 1 and the P device.
Figure 12 Head-end replication of flood traffic in an EVPN VPLS network
To conserve bandwidth resources, use multipoint extensions for LDP (mLDP) to set up a point-to-multipoint (P2MP) tunnel in an EVPN VPLS network to forward flood traffic over the public network. As shown in Figure 13, PE 1, root node of the mLDP P2MP tunnel, forwards original flood packets over the mLDP P2MP tunnel, and the mLDP branch node replicates the flood packets and forwards them to the mLDP leaf nodes.
For more information about mLDP P2MP, root node, branch node, and leaf node, see mLDP configuration in MPLS Configuration Guide.
Figure 13 Multicast forwarding model of EVPN VPLS over mLDP P2MP
EVPN VPLS uses the following mLDP P2MP tunnels:
·     Multicast inclusive tunnel—Transmits all flood traffic of a VSI. A VSI has only one multicast inclusive tunnel. The ingress PE encapsulates flood packets into mLDP public multicast data packets and sends them over the multicast inclusive tunnel on the public network.
·     Multicast selective tunnel—Transmits flood traffic of one or multiple multicast groups. A VSI can have multiple multicast selective tunnels. The ingress PE encapsulates multicast data packets of a multicast group into mLDP public multicast data packets and sends them over the related multicast selective tunnel on the public network.
Multicast inclusive tunnel establishment
As shown in Figure 14, a multicast inclusive tunnel is established as follows:
1.     PE 1 sets up IBGP sessions in the BGP EVPN address family with PE 2 and PE 3. Then, PE 1 advertises an inclusive multicast Ethernet tag (IMET) route for mLDP P2MP tunnel establishment to PE 2 and PE 3. The route carries the following attributes:
¡     Route targets—Control route advertisement and reception.
¡     PMSI tunnel attributes—Advertise information about multicast inclusive tunnels, including the mLDP P2MP root node address and opaque value. For more information about the root node address and opaque value, see LDP configuration in MPLS Configuration Guide.
2.     PE 2 and PE 3 compare the route targets in the IMET route with the import targets configured in EVPN instance view of local VSIs. If a route target matches an import target on PE 2 or PE 3, the PE accepts the IMET route. In this example, both PE 2 and PE 3 accept the IMET route advertised by PE 1.
3.     PE 2 and PE 3 select an optimal unicast route to the root node address advertised by the IMET route, and use the next hop of the route as the upstream node. In this example, PE 2 and PE 3 consider the P device as their upstream node.
4.     PE 2 and PE 3 allocate labels to the upstream node, send it a label mapping message in which the FEC is formed by the root node address and opaque value, and generate label forwarding entries.
5.     The P device selects an optimal unicast route to the root node address in the label mapping message and uses the next hop of the root as the upstream node. In this example, the P device uses PE 1 as its upstream node.
6.     The P device checks whether it has sent PE 1 a label mapping message for upstream label allocation. If no, the PE device sends PE 1 a label mapping message in which the FEC is formed by the root node address and opaque value and generates label forwarding entries. If yes, the PE device will not send a label mapping message again.
7.     Root node PE 1 receives the label mapping message from the downstream P device, sets up an mLDP P2MP tunnel as a multicast inclusive tunnel, and generates label forwarding entries. The root node of the tunnel is PE 1, and the leaf node is PE 2 or PE 3, as shown in Figure 15.
Figure 14 Multicast forwarding model of EVPN VPLS over mLDP P2MP
Figure 15 Establishment of an mLDP P2MP multicast inclusive tunnel
Multicast selective tunnel establishment
The multicast inclusive tunnel of a VSI transmits flood traffic to all receiver-side PEs no matter whether a PE has a downstream receiver. To save bandwidth resources and reduce the traffic load on receiver-side PEs, set up multicast selective tunnels to load share flood traffic with the multicast inclusive tunnel. A multicast selective tunnel forwards multicast traffic only for specific (S, G) entries, and the traffic load on the multicast inclusive tunnel is reduced. Multicast selective tunnels are switched as follows, as shown in Figure 16:
Figure 16 Multicast forwarding model of EVPN VPLS over mLDP P2MP
1.     CEs forward the IGMP membership reports sent by multicast receivers to the receiver-side PEs, and the PEs generate a selective multicast Ethernet tag (SMET) route. The route carries the multicast source IP address and multicast group address in the IGMP membership reports, and route targets. The SMET routes are advertised over BGP EVPN sessions.
2.     Other PEs in the network compare the route targets in the SMET route with the import targets configured in EVPN instance view of local VSIs. If a route target matches an import target on a PE, the PE accepts the SMET route. In this example, PE 1 accepts the SMET route advertised by PE 3.
3.     Based on the (S, G) information carried by the SMET route, PE 1 determines whether to create multicast selective tunnels. If the (S, G) information is not within the address range for multicast selective tunnel creation, PE 1 does not set up tunnels. If the (S, G) information is within the address range for multicast selective tunnel creation, PE 1 sends an S-PMSI A-D route to PE 2 and PE 3 via IBGP sessions of the BGP EVPN address family. The route carries the following attributes:
¡     PMSI tunnel attributes—Advertise information about multicast selective tunnels, including the mLDP P2MP root node address and opaque value. For more information about the root node address and opaque value, see LDP configuration in MPLS Configuration Guide.
¡     Multicast source address and multicast group address—Identify the multicast traffic to switch to multicast selective tunnels. These addresses are obtained from the SMET route received by PE 1.
4.     PE 2 and PE 3 compare the route targets in the S-PMSI A-D route with the import targets configured in EVPN instance view of local VSIs. If a route target matches an import target on a PE, the PE accepts the S-PMSI A-D route. In this example, both PE 2 and PE 3 accept the S-PMSI A-D route advertised by PE 1.
5.     PE 2 and PE 3 check whether they have downstream receivers for the multicast source address and multicast group address carried in the S-PMSI A-D route. A PE with downstream receivers sends a label mapping message to the upstream device and generates label forwarding entries. The PE sets up an mLDP P2MP tunnel as a multicast selective tunnel with the multicast source-side PE as the root node and itself as the leaf node. PEs without downstream receivers do not set up mLDP P2MP tunnels. The mLDP P2MP LSP establishment procedure is similar to the multicast inclusive tunnel establishment procedure. For more information, see "Multicast inclusive tunnel establishment." In this example, PE 2 has downstream receivers, and PE 3 does not. The establishment of a multicast selective tunnel is as shown in Figure 17.
Figure 17 Establishment of a multicast selective tunnel
Multicast traffic forwarding
A leaf node generates Layer 2 multicast forwarding entries by exchanging IGMP messages with multicast receivers, and the root node generates Layer 2 multicast forwarding entries by exchanging SMET routes with leaf nodes. Nodes along an mLDP P2MP tunnel generate label forwarding tables through label mapping messages. When receiving a multicast packet, the nodes looks up forwarding entries as follows:
·     The root node searches for the outgoing interface in the Layer 2 multicast forwarding table, and then searches for the outgoing label in the label forwarding table.
·     Intermediate and branch nodes search for the outgoing label in the label forwarding table according to the incoming label of the packet..
·     Leaf nodes search for the outgoing interface in the Layer 2 multicast forwarding table, and then forward the packet to the local multicast receivers through the outgoing interface.
As shown in Figure 18, CE 1, CE 2, and CE 3 are in an EVPN VPLS network, and CE 1 is at the multicast source side. The traffic forwarding procedure of EVPN VPLS over mLDP P2MP is as follows:
1.     Root node PE 1 receives a packet from CE 1 and forwards the packet based on the packet type.
¡     For a non-multicast packet, PE 1 looks up the VSI MAC address table. If a matching entry is found, PE 1 forwards the packet according to the entry. If no matching entry exists, PE 1 looks up the Layer 2 multicast forwarding table and forwards the packet over the related multicast inclusive tunnel.
¡     For a multicast packet, PE 1 looks up the Layer 2 multicast forwarding table.
-     If the outgoing interface is an AC interface connected to the local site, PE 1 forwards the packet out of the AC interface.
-     If the outgoing interface is a multicast inclusive or selective tunnel interface, the PE adds the outgoing label A of the tunnel to the packet and then forwards it over the tunnel.
-     If no matching Layer 2 multicast forwarding entry is found, PE 1 adds the outgoing label of the incoming VSI's multicast inclusive tunnel to the packet and forwards the packet over the tunnel.
2.     Intermediate node P 1 receives the packet, looks up the label forwarding table, replaces incoming label A with outgoing label B, and forwards the packet out of the matching outgoing interface.
3.     Branch node P 2 receives the packet, looks up the label forwarding table, and founds two matching entries. P 2 replicates the packet and forwards the replicas as follows:
¡     Replaces the incoming label B of one replica with outgoing label C and forwards the replica out of interface D.
¡     Removes the incoming label of another replica and forwards it out of interface C.
4.     Leaf node PE 2 receives the packet, removes label C, and forwards the packet based on the packet type.
¡     For a non-multicast packet, PE 2 looks up the VSI MAC address table. If a matching entry is found, PE 2 forwards the packet according to the entry. If no matching entry exists, PE 2 floods the packet over all ACs of the VSI that owns the multicast inclusive tunnel.
¡     For a multicast packet, PE 2 looks up the Layer 2 multicast forwarding table. If a matching entry is found, PE 2 forwards the packet to the local site according to the entry. If no matching entry exists, PE 2 floods the packet over all ACs of the VSI that owns the multicast inclusive tunnel.
For more information about the root node, intermediate node, branch node, and leaf node, see mLDP configuration in MPLS Configuration Guide.
Figure 18 Multicast traffic forwarding
To configure EVPN VPLS, perform the following tasks:
1.     Configuring a VSI
a.     Creating a VSI
b.     (Optional.) Configure VSI parameters
2.     Configuring an EVPN instance
3.     Mapping ACs to a VSI
¡     Mapping a Layer 3 interface to a VSI
¡     Mapping an Ethernet service instance to a VSI
4.     Configuring BGP to advertise BGP EVPN routes
a.     Enabling BGP to advertise BGP EVPN routes
b.     Enabling advertisement of MPLS-encapsulated BGP EVPN routes
c.     (Optional.) Configuring BGP EVPN route attributes
d.     (Optional.) Configuring route advertisement and optimal route selection for BGP EVPN routes
e.     (Optional.) Configuring BGP route reflection settings
f.     (Optional.) Configuring BGP EVPN route filtering
g.     (Optional.) Advertising BGP RPKI validation state to a peer or peer group
h.     (Optional.) Configuring BGP soft-reset by saving all route updates
i.     (Optional.) Maintaining BGP sessions
5.     (Optional.) Configuring a PW class
6.     (Optional.) Configuring EVPN VPLS multihoming
a.     Configuring an ESI
b.     (Optional.) Configuring the DF election algorithm
c.     (Optional.) Enabling AC state-based DF election
d.     (Optional.) Setting the DF election delay
e.     (Optional.) Enabling non-revertive mode for preference-based DF election
f.     (Optional.) Configuring Ethernet segment route advertisement delay
g.     (Optional.) Setting the advertisement delay timer for Ethernet auto-discovery routes
h.     (Optional.) Configuring local FRR for EVPN VPLS
i.     (Optional.) Generating MAC address entries for received MAC/IP advertisement routes
j.     (Optional.) Enabling VSIs to ignore the state of ACs
k.     (Optional.) Disabling advertisement of EVPN multihoming routes
l.     (Optional.) Ignoring the Ethernet tag on advertisement of Ethernet auto-discovery and MAC/IP advertisement routes
m.     (Optional.) Configuring the device to advertise only MAC/IP advertisement routes that contain non-all-zero MAC addresses
n.     (Optional.) Enabling the device to monitor the BGP peer status of another local edge device
o.     (Optional.) Setting the revertive WTR timer
7.     (Optional.) Managing MAC address entries and ARP learning
¡     Disabling MAC address advertisement
¡     Configuring UMRs
¡     Enabling MAC mobility event suppression
¡     Disabling learning of MAC addresses from ARP or ND information
¡     Configuring the AC source MAC check feature
¡     Disabling ARP information advertisement
8.     (Optional.) Enabling EVPN E-tree
9.     (Optional.) Configuring LDP or static PWs as ACs for EVPN PWs
10.     (Optional.) Configuring EVPN VPLS over mLDP P2MP
11.     (Optional.) Optimizing and maintaining an EVPN VPLS network:
¡     Confining floods to the local site
¡     Enabling ARP flood suppression
¡     Enabling direct PW-to-AC forwarding for a VSI
¡     Setting the maximum number of MAC addresses that an AC can learn
¡     Enabling packet statistics for an AC
¡     Enabling bandwidth-based load sharing
¡     Enabling SNMP notifications for L2VPN PW
¡     Testing the connectivity of an EVPN PW
EVPN VPLS is mutually exclusive with EVPN-DCI dualhoming. Do not use the evpn edge group command in an EVPN VPLS network. For more information about EVPN-DCI dualhoming, see "Configuring EVPN-DCI."
E-Tree is not supported if CFD or NQA is configured. For more information about CFD, see High Availability Configuration Guide. For more information about NQA, see Network Management and Monitoring Configuration Guide.
Configuring a VSI
Creating a VSI
2.     Enable L2VPN.
l2vpn enable
By default, L2VPN is disabled.
3.     Create a VSI and enter VSI view.
vsi vsi-name
4.     Bring up the VSI.
By default, a VSI is not administratively down.
To configure VSI parameters:
2.     Enter VSI view.
vsi vsi-name
3.     Configure a VSI description.
By default, a VSI does not have a description.
4.     Set the MTU of the VSI.
mtu mtu
The default MTU for a VSI is 1500 bytes.
5.     Set the maximum bandwidth for known unicast traffic of the VSI.
bandwidth bandwidth
By default, the maximum bandwidth is not limited for known unicast traffic of a VSI.
6.     Set the broadcast, multicast, or unknown unicast bandwidth restraints of the VSI.
restrain { broadcast | multicast | unknown-unicast } bandwidth
By default, the broadcast, multicast, and unknown unicast bandwidth restraints of a VSI are 5120 kbps.
7.     Configure MAC address learning features for the VSI:
a.     Enable MAC address learning for the VSI.
mac-learning enable
By default, MAC address learning is enabled for a VSI.
b.     (Optional.) Enable the VSI to drop source-unknown unicast frames if the MAC address table is full.
mac-table limit drop-unknown
By default, the VSI forwards source-unknown unicast frames without learning the source MAC address if the MAC address table is full.
The command mac-table limit drop-unknown does not impact traffic received from the peer of an EVPN VXLAN tunnel. That is, when the number of MAC addresses learned by the VSI reaches the limit, the device still forwards packets from the EVPN VXLAN tunnel peer, even if the source MAC addresses of these packets are not in the MAC address table.
The BGP EVPN routes advertised by a PE carry the RD and route targets configured for the EVPN instance of the routes.
Use one of the following methods to create an EVPN instance:
·     Create an EVPN instance in system view—You can bind an EVPN instance created in system view to multiple VSIs to simplify configuration.
·     Create an EVPN instance on a VSI—An EVPN instance created in VSI view is automatically bound with the VSI.
In EVPN instance view and VSI EVPN instance view, you can configure routing policies to filer the routes redistributed from BGP EVPN to an EVPN instance and vice versa.
If you have created an EVPN instance in VSI view for a VSI, you cannot bind the VSI to an EVPN instance created in system view. If you have bound a VSI to an EVPN instance created in system view, you cannot create an EVPN instance in VSI view for the VSI.
2.     Create an EVPN instance and enter its view.
evpn instance instance-name
3.     Configure an RD for the EVPN instance.
By default, no RD is configured for an EVPN instance.
4.     Configure route targets for the EVPN instance.
By default, an EVPN instance does not have route targets.
Parameter
export-extcommunity
Do not specify the same export targets for different EVPN instances.
Do not specify the same export targets for the EVPN instances created in different views (system view, VSI view, VPN instance view, public instance view, and cross-connect group view).
As a best practice, the export targets configured for the following objects do not match the import targets configured for the EVPN instances created in cross-connect group view:
·     VPN instances.
·     The public instance.
·     EVPN instances created in system view, VSI view, VPN instance view, and public instance view.
import-extcommunity
As a best practice, the import targets configured for the following objects do not match the export targets configured for the EVPN instances created in cross-connect group view:
·     VPN instances.
5.     (Optional.) Apply a PW class to the EVPN instance.
pw-class class-name
By default, no PW class is applied to an EVPN instance.
The PW class applies to all PWs in the EVPN instance.
6.     (Optional.) Apply a tunnel policy to the EVPN instance.
tunnel-policy tunnel-policy-name
By default, no tunnel policy is applied to an EVPN instance.
7.     (Optional.) Apply an export routing policy to the EVPN instance.
By default, no export routing policy is applied to an EVPN instance. The EVPN instance does not filter advertised routes.
8.     (Optional.) Apply an import routing policy to the EVPN instance.
By default, no import routing policy is applied to an EVPN instance. The EVPN instance accepts a route when the export route targets of the route match local import route targets.
9.     Return to system view.
10.     Enter VSI view.
vsi vsi-name
11.     Bind the VSI to the EVPN instance.
evpn encapsulation mpls binding instance instance-name vsi-tag tag-id
By default, a VSI is not bound to an EVPN instance created in system view.
You can bind a VSI to one or two EVPN instances. If you bind a VSI to two EVPN instances, the encapsulation type must be MPLS for one EVPN instance and VXLAN for the other EVPN instance.
2.     Enter VSI view.
vsi vsi-name
3.     Create an EVPN instance and enter VSI EVPN instance view.
4.     Configure an RD for the EVPN instance.
5.     Configure route targets for the EVPN instance.
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
Parameter
export-extcommunity
Do not specify the same export targets for the EVPN instances of different VSIs.
·     VPN instances.
import-extcommunity
·     VPN instances.
6.     (Optional.) Apply a PW class to the EVPN instance.
pw-class class-name
The specified PW class applies to all PWs in the EVPN instance.
7.     (Optional.) Apply a tunnel policy to the EVPN instance.
8.     (Optional.) Apply an export routing policy to the EVPN instance.
9.     (Optional.) Apply an import routing policy to the EVPN instance.
10.     (Optional.) Set broadcast, multicast, or unknown unicast restraint bandwidth.
By default, broadcast, multicast, or unknown unicast restraint bandwidth is not set.
To assign the customer traffic on a Layer 3 interface to a VSI, map that interface to the VSI. The VSI uses its MAC address table to forward the customer traffic.
For more information about the commands in this task, see VPLS in MPLS Command Reference.
2.     Enter Layer 3 interface view.
3.     Map the Layer 3 interface to a VSI.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
By default, a Layer 3 interface is not mapped to a VSI.
An Ethernet service instance matches a list of VLANs on a site-facing interface by using a frame match criterion. The frame match criterion specifies the characteristics of traffic from the VLANs, such as tagging status and VLAN IDs. The PE assigns traffic from the VLANs to a VSI by mapping the Ethernet service instance to the VSI. The VSI performs Layer 2 forwarding for the VLANs based on its MAC address table.
An Ethernet service instance can contain only one match criterion. To change the match criterion, you must remove the original criterion first. When you remove the match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
2.     Enter interface view.
¡     Enter Layer 2 Ethernet interface view.
¡     Enter Layer 2 aggregate interface view.
3.     Create an Ethernet service instance and enter Ethernet service instance view.
service-instance instance-id
4.     Match frames with the specified outer VLAN tag.
encapsulation s-vid vlan-id
By default, an Ethernet service instance does not contain a frame match criterion.
5.     Map the Ethernet service instance to a VSI.
By default, an Ethernet service instance is not mapped to a VSI.
For more information about BGP commands in this task, see Layer 3—IP Routing Command Reference.
2.     Configure a global router ID.
router id router-id
By default, no global router ID is configured.
3.     Enable a BGP instance and enter BGP instance view.
By default, BGP is disabled and no BGP instances exist.
4.     Specify remote PEs as BGP peers.
5.     Create the BGP EVPN address family and enter BGP EVPN address family view.
address-family l2vpn evpn
6.     Enable BGP to exchange BGP EVPN routes with a peer or peer group.
By default, BGP does not exchange BGP EVPN routes with peers.
Perform this task on PEs for them to establish PWs.
3.     Enter BGP EVPN address family view.
4.     Enable MPLS encapsulation for the BGP EVPN routes advertised to a peer or peer group.
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
By default, BGP EVPN routes use VXLAN encapsulation.
4.     Set a preferred value for routes received from a peer or peer group.
By default, the preferred value is 0 for routes received from a peer or peer group.
5.     Permit the local AS number to appear in routes from a peer or peer group and set the number of appearances.
By default, the local AS number is not allowed in routes from peers.
6.     Configure BGP to remove or replace private AS numbers with the local AS number in BGP updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only [ force [ include-peer-as ] ] keep-local-as
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
7.     Disable the device from changing the next hop of routes advertised to an EBGP peer or peer group.
By default, BGP sets the local device as the next hop for all routes advertised to an EBGP peer or peer group.
8.     Advertise the COMMUNITY attribute or the Large community attribute to a peer or peer group.
¡     Advertise the COMMUNITY attribute to a peer or peer group.
By default, the COMMUNITY attribute is not advertised to a peer or peer group.
¡     Advertise the Large community attribute to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise-large-community
By default, the Large community attribute is not advertised to a peer or peer group.
9.     Configure the SoO attribute for a peer or peer group.
By default, no SoO attribute is configured for a peer or peer group.
10.     Enable BGP to add the link bandwidth attribute to routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bandwidth
By default, BGP does not add the link bandwidth attribute to routes received from a peer or peer group.
4.     Configure optimal route selection.
¡     Set a high priority for BGP routes learned from a peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority [ preferred ]
By default, BGP does not prefer routes learned from any peer or peer groups during optimal route selection.
For the priority order of optimal route selection, see BGP overview in Layer 3—IP Routing Configuration Guide.
¡     Set the BGP next hop priority for optimal route selection.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, routes with IPv4 next hops are preferred in optimal route selection.
¡     Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
5.     Configure BGP route dampening:
¡     Configure EBGP route dampening.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
¡     Configure IBGP route dampening.
dampening ibgp [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
For more information about this command, see MPLS L3VPN commands in MPLS Command Reference.
By default, BGP route dampening is not configured.
For more information about route dampening, see BGP configuration in Layer 3—IP Routing Configuration Guide.
6.     Set the delay time for responding to recursive next hop changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
By default, BGP responds to recursive next hop changes immediately.
7.     Configure the BGP additional path feature.
¡     Configure the BGP additional path capabilities.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP additional path capabilities are configured.
¡     Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, a maximum number of one Add-Path optimal route can be advertised to a peer or peer group.
¡     Set the maximum number of Add-Path optimal routes that can be advertised to all peers.
By default, a maximum number of one Add-Path optimal route can be advertised to all peers.
8.     Specify the maximum number of BGP EVPN routes that the local router can receive from a peer or peer group.
¡     Specify the maximum number of all types of BGP EVPN routes that the local router can receive from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only| discard | reconnect reconnect-time } | percentage-value ] *
¡     Specify the maximum number of MAC/IP advertisement routes that the local router can receive from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } macip-route-limit route-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ]
By default, the number of routes that the local router can receive from a peer or peer group is not limited.
In BGP EVPN address family view, the peer macip-route-limit command is mutually exclusive with the peer route-limit command for the same peer or peer group.
4.     Configure the device as an RR and specify a peer or peer group as its client.
By default, no RR or client is configured.
5.     (Optional.) Enable BGP EVPN route reflection between clients.
reflect between-clients
By default, BGP EVPN route reflection between clients is enabled.
6.     (Optional.) Configure the cluster ID of the RR.
By default, an RR uses its own router ID as the cluster ID.
7.     (Optional.) Create a reflection policy for the RR to filter reflected BGP EVPN routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, an RR does not filter reflected BGP EVPN routes.
8.     (Optional.) Enable the RR to change the attributes of routes to be reflected.
reflect change-path-attribute
By default, the RR cannot change the attributes of routes to be reflected.
9.     (Optional.) Add a peer or peer group to the nearby cluster.
peer { group-name | ipv4-address [ mask-length ] } reflect-nearby-group
By default, the nearby cluster does not have any peers or peer groups.
The RR does not change the next hop of routes reflected to peers or peer groups in the nearby cluster.
4.     Enable route target filtering for BGP EVPN routes.
policy vpn-target
By default, route target filtering is enabled for BGP EVPN routes.
5.     Apply a routing policy to routes received from or advertised to a peer or peer group.
By default, no routing policies are applied to routes received from or advertised to peers or peer groups.
6.     Specify a routing policy as the existent policy to control BGP EVPN route advertisement.
By default, no existent policy is specified to control BGP EVPN route advertisement.
7.     Specify a routing policy as the nonexistent policy to control BGP EVPN route advertisement.
By default, no nonexistent policy is specified to control BGP EVPN route advertisement.
8.     Apply a Layer 2 ACL to filter routes advertised to or received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { mac-acl-number | name mac-acl-name } { export | import }
By default, no Layer 2 ACL is applied to filter routes advertised to or received from a peer or peer group.
To deny or permit a MAC/IP advertisement route with a specific MAC address, use the rule [ rule-id ] { deny | permit } dest-mac dest-address dest-mask command. Other rules configured in Layer 2 ACL view do not take effect on EVPN route filtering.
9.     Apply an IPv4 prefix list to filter BGP EVPN routes advertised to or received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name { export | import }
By default, no IPv4 prefix list is applied to filter BGP EVPN routes advertised to or received from a peer or peer group.
This command can filter only MAC/IP advertisement routes that contain host route information, and cannot filter other BGP EVPN routes.
BGP advertises the BGP RPKI validation state to a peer or peer group through the extended community attribute. For more information about BGP RPKI, see BGP in Layer 3—IP Routing Configuration Guide.
4.     Advertise the BGP RPKI validation state to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise origin-as-validation
By default, BGP does not advertise the BGP RPKI validation state to a peer or peer group.
Use this feature if the device does not support route refresh. This feature enables the device to save all route updates from the specified peer or peer group. When the route selection policy has changes, the device uses the new policy settings to filter routing information for BGP soft-reset.
For more information about route refresh and BGP soft-reset, see BGP in Layer 3—IP Routing Configuration Guide.
4.     Save all route updates from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
By default, route updates from peers and peer groups are not saved.
Perform the following tasks in user view:
·     Reset BGP sessions of the BGP EVPN address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } l2vpn evpn
·     Soft-reset BGP sessions of the BGP EVPN address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } l2vpn evpn
In a PW class, you can configure PW attributes such as the PW data encapsulation type, and whether to enable control word. To simplify PW attribute configuration for PWs, you can configure a PW class and apply the PW class to the PWs.
Make sure the same data encapsulation type is configured for the two PEs that are connected by the same PW.
For correct PW setup, make sure the status of the control word feature is the same on the two PEs that are connected by the same PW.
For more information about PW class commands, see MPLS L2VPN in MPLS Command Reference.
2.     Create a PW class and enter PW class view.
pw-class class-name
3.     Enable control word.
control-word enable
By default, control word is disabled.
4.     Specify the PW data encapsulation type.
pw-type { ethernet | vlan }
By default, the PW data encapsulation type is VLAN.
5.     Enable the flow label feature and configure flow label capabilities.
flow-label { both | receive | send } static
By default, the flow label feature is disabled.
EVPN VPLS does not support flow label capability negotiation for dynamic PWs in the current software version. For this command to take effect, you must specify the static keyword.
In a multihomed site, AC configuration must be consistent on redundant PEs of the same ES.
You can assign ESIs to a main interface and its subinterfaces.
·     If you assign an ESI to a subinterface, the subinterface-specific ESI and ES configuration take precedence over those configured on the main interface. The ES configuration includes the following:
¡     evpn redundancy-mode.
¡     evpn df-election algorithm.
¡     evpn df-election preference.
¡     evpn df-election preference non-revertive.
¡     evpn timer es-delay.
·     If you do not assign an ESI to a subinterface, it inherits the ESI and ES configuration (if configured) of the main interface. In this scenario, the ES configuration on the subinterface does not take effect.
Configuring an ESI
An ESI uniquely identifies an ES. The links on interfaces (or VSIs) with the same ESI belong to the same ES. Traffic of the ES can be distributed among the interfaces (or VSIs) for load sharing.
Assigning an ESI to an interface
¡     Enter Layer 3 Ethernet interface view.
¡     Enter Layer 3 aggregate interface view.
¡     Enter FlexE physical interface view.
¡     Enter FlexE logical interface view.
interface flexe interface-number
3.     Assign an ESI to the interface.
esi esi-id
By default, no ESI is assigned to an interface.
Assigning an ESI to a VSI
2.     Enter VSI view.
vsi vsi-name
3.     Assign an ESI to the VSI.
esi esi-id
By default, no ESI is assigned to a VSI.
Setting the redundancy mode
EVPN VPLS multihoming provides the single-active redundancy mode and all-active redundancy mode.
The redundant PEs at a dualhomed site each establish an EVPN PW to a remote PE. To use one PW as a backup of the other PW, use the single-active mode. To distribute traffic across the PWs for load sharing, use the all-active mode.
Restrictions and guidelines for redundancy mode configuration
When you configure S-Trunk on the redundant PEs at a dualhomed site, follow these restrictions:
·     In single-active redundancy mode, execute the s-trunk port-role auto command on the PEs.
·     In all-active redundancy mode, execute the s-trunk port-role primary command on the PEs.
For more information about S-Trunk, see High Availability Configuration Guide.
Setting the redundancy mode on an interface
3.     Setting the redundancy mode on the interface
evpn redundancy-mode { all-active | single-active }
By default, the all-active redundancy mode is used.
Setting the redundancy mode on a VSI
2.     Enter VSI view.
vsi vsi-name
3.     Setting the redundancy mode on the VSI.
At a multihomed EVPN network site, you can modify the DF election algorithm to control the DF election result.
If ambiguous VLAN termination is enabled on a subinterface acting as an AC, do not configure the VLAN tag-based algorithm for DF election on the subinterface. Otherwise, traffic forwarding errors will occur.
You can configure the DF election algorithm in system view and in interface view. The global DF election algorithm takes effect on all ESs, and the interface-specific DF election algorithm takes effect only on the ESs on an interface. The interface-specific DF election algorithm takes precedence over the global DF election algorithm.
Configuring the DF election algorithm globally
2.     Configure the DF election algorithm.
evpn df-election algorithm algorithm
By default, the VLAN tag-based algorithm is used for DF election.
Configuring the DF election algorithm on an interface
3.     Configure the DF election algorithm.
By default, the DF election algorithm specified in system view takes effect.
Configuring parameters for preference-based DF election
3.     Set the DF election preference.
evpn df-election preference preference
By default, the DF election preference is 32767.
The larger the value, the higher the preference.
At a multihomed EVPN network site, all PEs in an ES participate in DF election by default, regardless of their AC states. If the AC on the PE elected as the DF is down, traffic forwarding will fail. You can configure this feature to resolve this issue.
After you configure this feature, a PE participates in DF election only when the AC on the PE is up. A PE determines that the AC on the remote PE is up only when it receives AD per ES and AD per EVI routes from the remote PE.
This feature takes effect only when you enable this feature on all PEs in an ES.
2.     Enable AC state-based DF election.
evpn df-election ac-influence enable
By default, AC state-based DF election is disabled.
The DF election can be triggered by site-facing interface status changes, redundant PE membership changes, and interface ESI changes. To prevent frequent DF elections from degrading network performance, set the DF election delay. The DF election delay defines the minimum interval allowed between two DF elections.
2.     Set the DF election delay.
evpn multihoming timer df-delay delay-value
By default, the DF election delay is 3 seconds.
At a multihomed EVPN network site, configuration changes, device restarts, or process restarts will trigger DF re-election, and DF switchover might cause packet loss. You can configure this feature to resolve this issue.
For example, PE 1 and PE 2 are in the same ES, and PE 1 is the DF. When PE 1 restarts and PE 2 becomes the new DF, non-revertive mode for preference-based DF election works as follows:
·     If PE 1 receives Ethernet segment routes from PE 2 after the restart, PE 1 compares the DF election preference in the Ethernet segment routes with the local DF election preference.
¡     If the local DF election preference is smaller than that in the received Ethernet segment routes, PE 1 uses the local DF election preference in the advertised Ethernet segment routes.
¡     If the local DF election preference is equivalent to that in the received Ethernet segment routes, PE 1 compares the IP addresses as follows:
-     If PE 1's IP address is lower than PE 2's IP address, PE 1 uses the local DF election preference and the DP value of 0 in the advertised Ethernet segment routes.
-     If PE 1's IP address is higher than PE 2's IP address, PE 1 uses the local DF election preference and the DP value of 1 in the advertised Ethernet segment routes.
¡     If the local DF election preference is larger than that in the received Ethernet segment routes, PE 1 uses the DF election preference in the received Ethernet segment routes and the DP value of 0 when advertising Ethernet segment routes.
·     If PE 1 does not receive Ethernet segment routes from PE 2 after the restart, PE 1 uses the local DF election preference in the advertised Ethernet segment routes.
As a best practice, configure this feature when the all-active redundancy mode is used, and do not configure this feature when the single-active redundancy mode is used.
When the DF restarts or the process restarts and a new DF is elected, the original DF will immediately advertise Ethernet segment routes after the restart to become the DF again. However, access-side connections restore slowly and packet loss might occur after DF switchover. To resolve this issue, configure this feature together with the Ethernet segment route advertisement delay feature on all PEs in an ES.
3.     Enable non-revertive mode for preference-based DF election.
By default, non-revertive mode is disabled for preference-based DF election.
When the DF restarts or the process restarts and a new DF is elected, the original DF will immediately advertise Ethernet segment routes after the restart to become the DF again. However, access-side connections restore slowly and packet loss might occur after DF switchover. To resolve this issue, perform this task to configure a PE to delay the advertisement of Ethernet segment routes.
3.     Configure Ethernet segment route advertisement delay when preference-based DF election is used.
evpn timer es-recovery recovery-time
By default, Ethernet segment route advertisement delay is disabled when preference-based DF election is used.
The advertisement delay timer for Ethernet auto-discovery routes helps reduce the traffic loss caused by a PE reboot at a multihomed EVPN VPLS network site.
At a multihomed EVPN VPLS network site, CE 1 is dualhomed to PE 1 and PE 2 through an aggregate link or smart trunk, and PE 3 is at a remote site. PE 1 forwards all traffic sent from CE 1 to the remote site, and PE 3 forwards the traffic that the remote site sends to CE 1 to both PE 1 and PE 2. When PE 1 reboots, it advertises Ethernet auto-discovery routes that carry next hop information to PE 3. If PE 3 has not received the MAC/IP advertisement routes advertised by PE 2 when receiving the Ethernet auto-discovery routes, it will forward traffic to both PE 1 and PE 2. In this situation, PE 1 does not have MAC address entries for CE 1 and drops the traffic.
To resolve this issue, set the advertisement delay timer for Ethernet auto-discovery routes on the CE-facing interface of PE 1. This timer allows PE 3 to receive the MAC/IP advertisement routes advertised by PE 2 before the Ethernet auto-discovery routes advertised by PE 1 and update its MAC address table timely.
2.     Enable interface view.
3.     Set the advertisement delay timer for Ethernet auto-discovery routes.
evpn timer ad-delay delay-time
By default, advertisement of Ethernet auto-discovery routes is not delayed.
Local fast reroute (FRR) enables two PEs at a multihomed EVPN VPLS network site to set up a PW between them. This feature helps reduce the traffic loss caused by AC failure.
On an EVPN instance, EVPN instance-specific local FRR configuration takes precedence over global local FRR configuration.
If you have executed the evpn frr local enable command on an EVPN instance, the undo evpn multihoming vpls-frr local command does not disable local FRR for the EVPN instance.
Perform this task on redundant PEs at a multihomed EVPN VPLS network site.
Enabling local FRR globally
2.     Enable local FRR globally for EVPN VPLS.
By default, local FRR is disabled globally for EVPN VPLS.
Configuring local FRR on an EVPN instance created in system view
2.     Enter EVPN instance view.
3.     Configure local FRR on the EVPN instance.
evpn frr local { disable | enable }
By default, an EVPN instance uses the global local FRR configuration of EVPN VPLS.
Configuring local FRR on an EVPN instance created in VSI view
2.     Enter VSI view.
vsi vsi-name
3.     Enter VSI EVPN instance view.
4.     Configure local FRR on the EVPN instance.
This task helps reduce the traffic loss caused by AC failure at a dualhomed EVPN VPLS network site.
At a multihomed EVPN VPLS network site, CE 1 is dualhomed to PE 1 and PE 2 through an aggregate link or smart trunk, and PE 3 is at a remote site. PE 1 forwards all traffic sent from CE 1 to the remote site, and PE 3 forwards the traffic that the remote site sends to CE 1 to both PE 1 and PE 2. When the AC on PE 1 fails, PE 1 withdraws the MAC/IP advertisement routes advertised to PE 2 and PE 3. In this situation, PE 3 does not have MAC address entries for CE 1 until PE 2 learns MAC address entries for CE 1 and advertises them to PE 3. As a result, traffic interruption occurs.
To resolve this issue, perform this task on PE 1 and PE 2. When receiving the MAC/IP advertisement routes advertised by PE 1, PE 2 generates MAC address entries for the routes and advertises the entries to PE 3. PE 3 can use those MAC address entries to forward traffic to CE 1 when the AC on PE 1 fails.
You can configure PE 1 and PE 2 to generate MAC address entries for received MAC/IP advertisement routes. In this case, when receiving the MAC/IP advertisement routes advertised by PE 1, PE 2 generates MAC address entries for the routes and advertises the entries to PE 3. If the received the MAC/IP advertisement routes are deleted on PE1 or PE2, the generated MAC address entries will age out after the age timer specified by the evpn multihoming re-originated mac age-time command expires.
You must enable FRR for EVPN VPLS before you perform this task.
You must perform this task on each redundant PE at a multihomed site.
2.     Enable the device to generate MAC address entries for received MAC/IP advertisement routes.
By default, the device does not generate MAC address entries for received MAC/IP advertisement routes.
3.     Specify the age timer for MAC address entries that are generated for received MAC/IP advertisement routes.
evpn multihoming re-originated mac age-time seconds
By default, the age timer is 120 seconds for MAC address entries that are generated for received MAC/IP advertisement routes.
This task helps reduce the traffic loss caused by AC failure at a multihomed EVPN VPLS network site that uses single-active redundancy mode.
At a multihomed EVPN VPLS network site that uses single-active redundancy mode, CE 1 is dualhomed to PE 1 and PE 2 through a smart trunk. PE 1 is the primary PE, and PE 2 is the secondary PE. When the AC on PE 1 fails, PE 1 and PE 2 act as follows:
·     PE 1 withdraws advertised Ethernet auto-discovery routes.
·     PE 2 brings up its AC and advertises Ethernet auto-discovery routes to remote PEs.
The remote PEs switch traffic to the paths to PE 2 only after receiving the Ethernet auto-discovery routes advertised by PE 2, and traffic loss occurs during path switchover. To resolve this issue, enable VSIs to ignore the state of ACs on PE 2. This feature allows PE 2 to advertise Ethernet auto-discovery routes to remote PEs regardless of the state of ACs and speeds up path switchover when the AC on PE 1 fails.
Restrictions and guidelines for AC state ignore configuration
On a VSI, VSI-specific AC state ignore configuration takes precedence over global AC state ignore configuration.
Perform this task together with the feature of generating MAC address entries for received MAC/IP advertisement routes.
Enabling VSIs to ignore the state of ACs globally
2.     Enable VSIs to ignore the state of ACs globally.
l2vpn ignore-ac-state [ evpn-vpls ]
By default, VSIs does not ignore the state of ACs.
Configuring a VSI to ignore the state of ACs
2.     Enter VSI view.
vsi vsi-name
3.     Enable a VSI to ignore the state of ACs or disable a VSI from ignoring the state of ACs.
ignore-ac-state { enable | disable }
By default, a VSI uses the global AC state ignore configuration.
EVPN multihoming routes include Ethernet auto-discovery routes and Ethernet segment routes.
In a multihomed EVPN network, perform this task on a redundant PE before you reboot it. This operation allows other PEs to refresh their EVPN routing table to prevent traffic interruption caused by the reboot.
2.     Disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
evpn multihoming advertise disable
By default, the device advertises EVPN multihoming routes.
Perform this task on the redundant PEs at a dualhomed site.
This task enables the device to perform the following operations:
·     Withdraw the Ethernet auto-discovery routes and MAC/IP advertisement routes that have been advertised.
·     Set the Ethernet tag to 0 for the Ethernet auto-discovery routes and MAC/IP advertisement routes and re-advertise them.
After you configure ESIs for ACs on the redundant PEs at a dualhomed site, the PEs carry Ethernet tags in Ethernet auto-discovery and MAC/IP advertisement routes advertised to remote sites. If the remote peers are unable to identify Ethernet tags, you must perform this task on the redundant PEs to enable communication with the peers.
After you assign an ESI to a Layer 2 Ethernet or aggregate interface, you must map the Ethernet service instances created on the interface to different VSIs. If two interfaces use the same ESI, you must map the Ethernet service instances created on them to different VSIs.
After you assign an ESI to a Layer 3 main interface, its subinterfaces inherit the ESI if they do not have one. In addition, you must map two subinterfaces to different VSIs if the subinterfaces have the same ESI.
2.     Enable the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes.
evpn multihoming advertise ignore-ethernet-tag
By default, the device advertises Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags.
The device supports advertising UMRs that are MAC/IP advertisement routes for MAC address 0-0-0. At a multihomed EVPN VPLS site that accommodates a large number of hosts, you can configure the PEs to advertise UMRs instead of specific MAC addresses by using the unknown-mac-route send detail-suppressed command in VSI EVPN instance view. UMRs help reduce the MAC address table size on remote PEs and the number of advertised MAC/IP advertisement routes.
To synchronize MAC address entries between the PEs with the same ES attached and UMR advertisement enabled, execute the peer advertise evpn mac-route detail-only command on the PEs.
4.     Configure the device to advertise only MAC/IP advertisement routes that contain non-all-zero MAC addresses to BGP EVPN peers.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise evpn mac-route detail-only
By default, the MAC/IP advertisement routes advertised to BGP EVPN peers contain both all-zero and non-all-zero MAC addresses.
Perform this task on the CE-facing interfaces of the edge devices multihomed to a site to prevent device reboots from causing inter-site forwarding failure.
This task excludes unavailable edge devices from DF election at a multihomed site. After an edge device recovers from failure and brings up its CE-facing interface, it starts a delay timer and checks the status of the BGP peer specified in the evpn track peer command. If the BGP peer comes up before the timer expires, the edge device advertises Ethernet segment routes to the peer. If the BGP peer is still down when the timer expires, the edge device does not advertise Ethernet segment routes to the peer. The edge devices then perform DF election based on the Ethernet segment routes they have received.
3.     Enable the device to monitor the BGP peer status of another local edge device.
evpn track peer peer-address
By default, the device does not monitor the BGP peer status of the other edge devices at a multihomed site.
4.     Enable Ethernet segment route advertisement delay and set the advertisement delay timer.
evpn timer es-delay delay-time
By default, advertisement of Ethernet segment routes is not delayed.
In EVPN VPLS multihoming, when the access link on the primary PE or the primary PE recovers from failure, the primary PE will generate AD per EVI routes and advertise them to remote PEs via BGP EVPN peer relationships. After a remote PE receives and generates forwarding entries for the AD per EVI routes, it switches traffic from the backup PE path to the primary PE path. As a result, the primary PE might experience a small amount of packet loss due to incomplete forwarding entries. To avoid this situation, you can configure the revertive WTR timer on the remote PEs to delay the generation of forwarding entries for AD per EVI routes. The remote PEs will wait for the forwarding entries on the primary PE to converge. When the revertive WTR timer expires, a remote PE generates new forwarding entries, and the traffic is switched to the primary PE to prevent packet loss.
Setting the revertive WTR timer for an EVPN instance
3.     Set the revertive WTR timer.
revertive wtr wtr-time
By default, the revertive WTR timer is 0, which means delayed switchover is disabled.
Setting the revertive WTR timer for a VSI EVPN instance
2.     Enter VSI view.
vsi vsi-name
4.     Set the revertive WTR timer.
The MAC information and ARP or ND information advertised by the PE overlap. To avoid duplication, disable MAC address advertisement and withdraw the MAC addresses advertised to remote PEs.
Procedure (EVPN instance created in system view)
3.     Disable MAC address advertisement and withdraw advertised MAC addresses.
mac-advertising disable
By default, MAC address advertisement is enabled.
Procedure (EVPN instance created in VSI view)
2.     Enter VSI view.
vsi vsi-name
4.     Disable MAC address advertisement and withdraw advertised MAC addresses.
Configuring UMRs
Unknown MAC routes (UMRs) refer to MAC/IP advertisement routes for MAC address 0-0-0.
With UMR advertisement enabled, PEs advertise UMRs to BGP peers.
With UMR reception enabled, a PE adds a MAC address entry for MAC address 0-0-0 to the MAC address table of the related VSI after receiving a UMR route. That MAC address entry is a default MAC address entry. When the PE receives a packet from an AC of the VSI, it looks up the MAC address table for a matching entry. If no match is found for the destination MAC address, the PE forwards the packet based on the default MAC address entry.
You can use UMRs for the following purposes:
·     To reduce the MAC address table size on PEs and the number of MAC/IP advertisement routes when network sites accommodate a large number of hosts.
·     To avoid traffic loss when unknown unicast floods are suppressed. When unknown unicast floods are suppressed on the local PE, enable remote PEs to advertise UMRs for the local PE to forward unknown unicast packets to the remote sites.
At a multihomed site, the UMRs advertised by a PE carry an ESI configured in VSI view. The ESI identifies the ES of the routes. In VSI view, you can also configure the redundancy mode for the ES. For more information about the ESI and redundancy mode configuration, see "Assigning an ESI to a VSI" and "Setting the redundancy mode on a VSI."
After a PE receives a UMR, it forwards all unknown unicast packets to the remote PE that advertises the UMR. If the UMR does not point to the remote site that accommodates the destination of the unknown unicast packets, forwarding failure will occur. To ensure correct traffic forwarding, enable UMR advertisement or reception with caution.
2.     Enter VSI view.
vsi vsi-name
4.     Enable UMR advertisement or reception.
unknown-mac-route send [ detail-suppressed ] [ receive ]
By default, UMR advertisement and reception are disabled.
On an EVPN VPLS network, misconfiguration of MAC addresses might cause two sites to contain the same MAC address. In this condition, the PEs at the two sites constantly synchronize and update EVPN MAC address entries and determine that MAC mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by MAC entry synchronization traffic. To eliminate loops and suppress those MAC mobility events, enable MAC mobility event suppression on the PEs.
The MAC mobility event suppression feature allows a MAC address to move at most the specified number of times (MAC mobility suppression threshold) out of a site within a MAC mobility detection cycle. If the suppression threshold has been reached for a MAC address within a detection cycle, the PE at the site suppresses the subsequent move after the MAC address moves back to the site. In addition, the PE learns the MAC address but does not advertise the MAC address.
After you execute the undo evpn route mac-mobility suppression command or when the MAC mobility suppression time expires, a PE acts as follows:
·     Advertises MAC address entries immediately for the suppressed MAC address entries that have not aged out.
·     Relearns the MAC addresses for the suppressed MAC address entries that have aged out and advertises the MAC address entries.
If both MAC address entry conflicts and ARP entry conflicts exist for a MAC address, you must enable both MAC mobility event suppression and ARP mobility event suppression. If you enable only MAC mobility event suppression, the system cannot suppress MAC mobility events for the MAC address.
The MAC mobility event suppression setting configured in system view takes effect on all EVPN instances. The MAC mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The MAC mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The MAC mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The MAC mobility event suppression settings configured in the following views are in descending order of priority:
1.     Layer 3 interface view.
2.     EVPN instance view or VSI EVPN instance view.
3.     System view.
Enabling MAC mobility event suppression in system view
2.     Enable MAC mobility event suppression.
evpn route mac-mobility suppression [ detect-cycle detect-time | detect-threshold  move-times | suppression-time [ suppression-time | permanent ] ] *
By default, MAC mobility event suppression is disabled.
Enabling MAC mobility event suppression in EVPN instance view
3.     Enable MAC mobility event suppression.
Enabling MAC mobility event suppression in VSI EVPN instance view
2.     Enter VSI view.
vsi vsi-name
evpn encapsulation vxlan
4.     Enable MAC mobility event suppression.
Enabling MAC mobility event suppression in Layer 3 interface view
The MAC information and ARP or ND information advertised by a remote PE overlap. To avoid duplication, disable the learning of MAC addresses from ARP or ND information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
3.     Disable the EVPN instance from learning MAC addresses from ARP information.
arp mac-learning disable
By default, an EVPN instance learns MAC addresses from ARP information.
4.     Disable the EVPN instance from learning MAC addresses from ND information.
nd mac-learning disable
By default, an EVPN instance learns MAC addresses from ND information.
2.     Enter VSI view.
vsi vsi-name
4.     Disable the EVPN instance from learning MAC addresses from ARP information.
5.     Disable the EVPN instance from learning MAC addresses from ND information.
In an EVPN VPLS network, devices advertise local MAC addresses to remote sites through BGP EVPN routes. If the device erroneously learns a local MAC address identical to an advertised remote MAC address, it will refresh the related MAC address entry and fail to forward the traffic destined for the remote MAC address.
To prevent the device from learning incorrect local MAC address entries, enable AC source MAC check. This feature disables the device from learning the source MAC address of a packet received from an AC if the source MAC address is in the MAC address list for AC source MAC check.
If you repeat the mac-address source-mac-check ac mac-address mask command to specify different MAC addresses, all the specified MAC addresses are added for AC source MAC check.
If you repeat the mac-address source-mac-check ac mac-address mask command to specify the same MAC address and different MAC address masks, the most recent configuration takes effect.
To view the MAC addresses for AC source MAC check, execute the display this command in VSI view.
2.     Enter VSI view.
vsi vsi-name
3.     Enable AC source MAC check and add MAC address entries for this feature.
By default, AC source MAC check is disabled.
In an EVPN VPLS network, you can disable ARP information advertisement for an EVPN instance to save resources if all user terminals in the EVPN instance are attached to one PE. The EVPN instance will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information.
3.     Disable ARP information advertisement for the EVPN instance.
arp-advertising disable
By default, ARP information advertisement is enabled for an EVPN instance.
2.     Enter VSI view.
vsi vsi-name
4.     Disable ARP information advertisement for the EVPN instance.
About EVPN E-tree
Use EVPN E-tree to isolate traffic between ACs based on the AC roles. This feature can better control AC access and improve security.
Restrictions and guidelines for EVPN E-tree configuration
Inter-site EVPN E-tree controls communication between local ACs and remote ACs. You do not need to enable this feature if you want to control communication between local ACs.
Enabling EVPN E-tree for an EVPN instance created in system view
3.     Enable inter-site EVPN E-tree.
e-tree enable
By default, inter-site EVPN E-tree is disabled.
4.     Return to system view.
5.     Execute the following commands to configure a Layer 3 interface as a leaf AC:
a.     Enter Layer 3 interface view.
b.     Configure the AC as a leaf AC.
xconnect vsi vsi-name leaf
If you do not specify the leaf keyword for an AC, the AC acts as a root AC.
6.     Execute the following commands to configure an Ethernet service instance as a leaf AC:
a.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
b.     Enter Ethernet service instance view.
c.     Configure the AC as a leaf AC.
Enabling EVPN E-tree for an EVPN instance created in VSI view
2.     Enter VSI view.
vsi vsi-name
4.     Enable inter-site EVPN E-tree.
e-tree enable
5.     Return to system view.
6.     Execute the following commands to configure a Layer 3 interface as a leaf AC:
7.     Execute the following commands to configure an Ethernet service instance as a leaf AC:
About LDP or static PW AC configuration for EVPN PWs
Use this feature to ensure that a VPLS network and an EVPN VPLS network can communicate with each other.
Restrictions and guidelines for LDP or static PW AC configuration for EVPN PWs
As a best practice, set the same redundancy mode for the UPWs that use the same ESI at a multihomed site.
If the all-active redundancy mode is used at a multihomed site, you must enable the dual receive feature for PW redundancy on the multihomed PEs. To enable this feature, use the protection dual-receive command.
Prerequisites for LDP or static PW AC configuration for EVPN PWs
Complete the following tasks:
·     In the VPLS network, complete VPLS settings on the PEs and set up LDP or static PWs.
·     In the EVPN VPLS network, complete EVPN VPLS settings on the PEs and set up EVPN PWs.
Configuring LDP PWs as ACs for EVPN PWs
Make sure the access mode of ACs is the same as the data encapsulation type of LDP PWs. To configure the data encapsulation type for an LDP PW, execute the pw-type command for the PW class used by the LDP PW. To configure the access mode for an AC, use the xconnect vsi command.
2.     Enter VSI view.
vsi vsi-name
4.     Return to VSI view.
5.     Configure the VSI to use LDP to establish LDP PWs, and enter VSI LDP signaling view.
pwsignaling ldp
By default, no PW signaling protocol is specified for a VSI.
6.     Configure a VSI LDP PW, disables split horizon forwarding for the PW, and enter VSI LDP PW view.
peer ip-address [ pw-id pw-id ] no-split-horizon [ hub | ignore-standby-state | pw-class class-name | tunnel-policy tunnel-policy-name ] *
The LDP PW configured by using this command is called an UPW, which acts as an AC for the EVPN VPLS network.
For more information about this command, see VPLS commands in MPLS Command Reference.
7.     (Optional.) Assign an ESI to the UPW.
esi esi-id
By default, no ESI is assigned to an UPW.
At a multihomed site, use this command on the PEs in the VPLS and EVPN VPLS networks.
For more information about this command, see EVPN commands in EVPN Command Reference.
8.     (Optional.) Set the redundancy mode of the UPW.
By default, the redundancy mode is all-active.
9.     Configure a VSI LDP backup PW and enter its view.
backup-peer ip-address [ pw-id pw-id ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
At a multihomed site, use this command on the multihomed PEs.
Configuring static PWs as ACs for EVPN PWs
2.     Enter VSI view.
vsi vsi-name
5.     Configure the VSI to establish static PWs and enter VSI static configuration view.
pwsignaling static
6.     Configure a static PW, disable split horizon forwarding for the PW, and enter VSI static PW view.
peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value no-split-horizon [ hub | pw-class class-name | tunnel-policy tunnel-policy-name ] *
The static PW configured by using this command is called an UPW, which acts as an AC for the EVPN VPLS network.
esi esi-id
9.     Configure a VSI static backup PW and enter its view.
backup-peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
Configure EVPN VPLS over mLDP P2MP on the root nodes of mLDP P2MP LSPs. You only need to execute the provider-tunnel command on the leaf nodes of mLDP P2MP LSPs.
Do not configure MPLS L2VPN and EVPN VPLS over mLDP P2MP in combination, or VPLS and EVPN VPLS over mLDP P2MP in combination.
Enable mLDP P2MP on all nodes along mLDP P2MP LSPs, and enable IGMP snooping on the ingress and egress nodes of mLDP P2MP LSPs. For more information about mLDP P2MP configuration, see mLDP configuration in MPLS Configuration Guide. For more information about IGMP snooping configuration, see IGMP snooping configuration in IP Multicast Configuration Guide.
Configuring a multicast inclusive tunnel
3.     Create multicast tunnel view and enter it.
provider-tunnel
4.     Create a multicast inclusive tunnel and enter its view.
inclusive-provider-tunnel
5.     Specify the local node as the root node of mLDP P2MP tunnels.
role root
By default, the local node is not a root node of any mLDP P2MP tunnel.
6.     Configure the type as mLDP P2MP for the multicast inclusive tunnel and enter mLDP view.
mldp p2mp
By default, a multicast inclusive or selective tunnel is not an mLDP P2MP tunnel.
7.     Specify the root node address of mLDP P2MP tunnels.
root-ip ip-address
By default, the root node address is not configured for mLDP P2MP tunnels.
8.     Execute the following commands in turn to return to system view.
9.     Enter VSI view.
vsi vsi-name
10.     Associate the EVPN instance with a VSI.
evpn encapsulation vxlan binding instance instance-name vsi-tag { tag-id | auto-vxlan }
By default, an EVPN instance is not associated with any VSI.
Configuring a multicast selective tunnel
To avoid frequent switchovers from a multicast inclusive tunnel to multicast selective tunnels, set the switchover parameters.
In multicast tunnel view, multicast selective tunnels inherit the configurations made in multicast inclusive tunnel view.
3.     Create a multicast tunnel and enter its view.
provider-tunnel
4.     Create a multicast selective tunnel and enter its view.
selective-provider-tunnel
5.     Configure the multicast group addresses and multicast source addresses to switch to multicast selective tunnels.
IPv4:
group group-address { group-mask | group-mask-length } [ source source-address { source-mask | source-mask-length } ] mldp [ limit number ]
IPv6:
group group-ipv6-address group-prefix-length [ source source-ipv6-address source-prefix-length ] mldp [ limit number ]
By default, traffic is not switched to multicast selective tunnels.
6.     Set the delay before switchover from a multicast inclusive tunnel to a multicast selective tunnel.
switch-delay delay-time
By default, the delay is 5 seconds for switchover from a multicast inclusive tunnel to a multicast selective tunnel.
By default, the PE floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VSI:
·     All site-facing interfaces except for the incoming interface.
·     All PWs.
To confine a kind of flood traffic to the site-facing interfaces, disable flooding for that kind of flood traffic on the VSI. The VSI will not flood the corresponding frames to PWs.
To exclude a remote MAC address from the flood suppression done by using this feature, enable selective flood for the MAC address. The PE will flood the frames destined for the MAC address to remote sites.
2.     Enter VSI view.
vsi vsi-name
3.     Disable flooding for the VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * }
By default, flooding is enabled for a VSI.
4.     (Optional.) Enable selective flood for a MAC address.
selective-flooding mac-address mac-address
Use ARP flood suppression to reduce ARP request broadcasts.
The aging timer is fixed at 25 minutes for ARP flood suppression entries. If the flooding disable command is configured, set the MAC aging timer to a higher value than the aging timer for ARP flood suppression entries on all PEs. This setting prevents the traffic blackhole that occurs when a MAC address entry ages out before its ARP flood suppression entry ages out. To set the MAC aging timer, use the mac-address timer command.
2.     Enter VSI view.
vsi vsi-name
3.     Enable ARP flood suppression.
arp suppression enable
By default, ARP flood suppression is disabled.
To improve forwarding performance in an EVPN VPLS network, enable direct PW-to-AC forwarding for a VSI if only one AC is mapped to the VSI. With this feature enabled, the VSI forwards the traffic received from a PW through the only AC without looking up the MAC address table.
You cannot enable this feature on a VSI if multiple ACs have been mapped to the VSI. After you enable this feature on a VSI, you can map only one AC to the VSI.
2.     Enter VSI view.
vsi vsi-name
3.     Enable direct PW-to-AC forwarding for the VSI.
straight-forwarding pw-to-ac
By default, direct PW-to-AC forwarding is disabled for a VSI.
About setting the maximum number of MAC addresses that an AC can learn
Perform this task to prevent a single AC (Layer 3 interface or Ethernet service instance) from occupying too many MAC address entry resources.
Setting the maximum number of MAC addresses that a Layer 3 interface type AC can learn
2.     Enter Layer 3 Ethernet interface view or Layer 3 aggregate interface view.
3.     Set the maximum number of MAC addresses that a Layer 3 interface type AC can learn and the actions performed when the maximum is reached.
ac mac-limit { action { discard | forward } | alarm { disable | enable } | maximum mac-limit } *
By default, no limit is set to the number of MAC addresses that a Layer 3 interface type AC can learn.
For more information about this command, see VPLS in MPLS Command Reference.
Setting the maximum number of MAC addresses that an Ethernet service instance AC can learn
3.     Enter Ethernet service instance view.
4.     Set the maximum number of MAC addresses that an Ethernet service instance type AC can learn and the actions performed when the maximum is reached.
By default, no limit is set to the number of MAC addresses that an Ethernet service instance type AC can learn.
Restrictions and guidelines for AC packet statistics
For the ac statistics enable command to take effect on a Layer 3 interface, you must map the Layer 3 interface to a VSI. When you modify the VSI mapping, the packet statistics of the interface are cleared. To display the statistics, use the display l2vpn interface verbose command.
For the statistics enable command to take effect on an Ethernet service instance, you must configure a frame match criterion for the Ethernet service instance and map it to a VSI. When you modify the frame match criterion or VSI mapping, the packet statistics of the instance are cleared. To display the statistics, use the display l2vpn service-instance verbose command.
To clear packet statistics for ACs, use the reset l2vpn statistics ac command.
Enabling packet statistics for a Layer 3 interface
3.     Enable packet statistics for the Layer 3 interface.
By default, the packet statistics feature is disabled for Layer 3 interfaces that act as ACs.
Enabling packet statistics for an Ethernet service instance
4.     Enable packet statistics for the Ethernet service instance.
statistics enable
By default, the packet statistics feature is disabled for all Ethernet service instances.
Enabling bandwidth-based load sharing
If an L2VPN PW is carried by multiple equal-cost LDP LSPs, the PW evenly transmits packets through the LDP LSPs. After you enable this feature, packets are transmitted through the LDP LSPs in the proportion calculated based on the bandwidth of the egress interfaces.
This feature is available only when the public tunnels that carry a PW are LDP LSPs.
2.     Enable bandwidth-based load sharing.
l2vpn bandwidth-based-sharing
By default, bandwidth-based load sharing is disabled.
Enabling SNMP notifications for L2VPN PWs
This feature enables L2VPN to generate SNMP notifications when PW deletions, PW switchovers, or PW status changes occur. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
2.     Enable SNMP notifications for L2VPN PWs.
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
By default, SNMP notifications for L2VPN PWs are disabled.
Testing the connectivity of an EVPN PW
Pinging a PW destination
Perform this task to test the connectivity of a PW when the PW has traffic loss or interruption issues in an EVPN VPLS network. The process of a ping operation is as follows:
1.     The PW source PE sends MPLS echo requests that contain the PW labels of the PW to the PW destination PE based on the destination MAC address and VSI you specify.
2.     The PW destination PE looks up the routing table and responds to the PW source PE with MPLS echo replies.
3.     The PW source PE outputs packet statistics and the test result based on whether and when it receives MPLS echo replies.
To test the connectivity of a PW, execute the following command in any view:
ping evpn vsi vsi-name mac mac-address [ -a source-ipv4 | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] *
Tracing the path to a PW destination
Perform this task to locate failed nodes on the path for a PW that has traffic loss or interruption issues in an EVPN VPLS network. The process of a tracert operation is as follows:
1.     The PW source PE sends MPLS echo requests that contain the PW labels of the PW to the PW destination PE based on the destination MAC address and VSI you specify. The TTL in the MPLS header of the requests is set to 1.
2.     The first hop on the path responds to the PW source PE with a TTL-expired ICMP error message.
3.     The PW source PE sends MPLS echo requests with the TTL set to 2 if the PE receives the TTL-expired ICMP error message or has not received any packets within the timeout period.
4.     The second hop responds with a TTL-expired ICMP error message.
5.     This process continues until an MPLS echo request reaches the PW destination PE or the maximum TTL value is reached. If an MPLS echo request reaches the PW destination PE, the PW destination PE sends an MPLS echo reply to the PW source PE.
6.     The PW source PE outputs packet statistics and the test result based on the received ICMP error messages and on whether an MPLS echo reply is received.
To trace the path to a PW destination and locate failed nodes on the path, execute the following command in any view:
tracert evpn vsi vsi-name mac mac-address [ -a source-ipv4 | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out ] *
Display and maintenance commands for EVPN VPLS
For more information about the following BGP commands, see Layer 3—IP Routing Command Reference:
·     display bgp group.
·     display bgp peer.
·     display bgp update-group.
Display BGP peer group information.
display bgp [ instance instance-name ] group l2vpn evpn [ group-name group-name ]
Display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ { evpn-route route-length | evpn-prefix } [ verbose ] | statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | imet | mac-ip } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ route-type { inter-as | intra-as | leaf | s-pmsi | shared-tree | source-active | source-tree } ] time-range min-time max-time
Display BGP peer or peer group information.
display bgp [ instance instance-name ] peer l2vpn evpn [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
Display information about BGP update groups.
display bgp [ instance instance-name ] update-group l2vpn evpn [ ipv4-address ]
Display dampened BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn dampened
Display BGP EVPN route dampening parameters.
display bgp [ instance instance-name ] dampening parameter l2vpn evpn
Display flapping statistics about BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn flap-info
Display information about route targets and ES-import route targets in BGP routes originated from the EVPN process.
display bgp [ instance instance-name ] route-target evpn
Display information about peers that are automatically discovered through BGP.
display evpn auto-discovery { ethernet-ad mpls [ peer ip-address ] [ vsi vsi-name ] | { imet | mac-ip } [ mpls | vxlan ] [ peer ip-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
Display routes for selective multicast service interfaces of EVPN instances.
display evpn auto-discovery s-pmsi
Display DF election information.
display evpn df-election [ vsi vsi-name ] [ esi esi-id ]
Display EVPN ES information.
display evpn es { local [ count | [ vsi vsi-name ] [ esi esi-id ] [ verbose ] ] | remote [ vsi vsi-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose ] }
Display mLDP P2MP tunnels of EVPN instances.
display evpn mldp p2mp [ vsi vsi-name ]
Display EVPN ARP entries.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ] [ count ]
Display ARP flood suppression entries.
display evpn route arp suppression [ mpls ] [ local | remote ] [ vsi vsi-name ] [ ip ip-address ] [ count ]
Display EVPN MAC address entries.
display evpn route mac [ mac-address mac-address | umr [ verbose ] ] [ mpls | vxlan ] [ local | remote ] [ vsi vsi-name ] [ count ]
Display EVPN MAC mobility information.
display evpn route mac-mobility [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac-address mac-address ] [ verbose ]
Display EVPN ND entries.
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
Display SMET routes of EVPN instances.
display evpn route smet [ local | remote ] [ vsi vsi-name ] [ count ]
Display the routing table for a VPN instance.
display evpn routing-table { public-instance | vpn-instance vpn-instance-name } [ ipv6 ipv6-address ] [ count ]
Display EVPN instance information.
display evpn instance [ vsi vsi-name ] [ verbose ]
Display site-facing interfaces excluded from traffic forwarding by split horizon.
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number } [ slot slot-number ]
Display information about EVPN VPLS forwarding.
display l2vpn forwarding evpn vsi [ name vsi-name ] [ slot slot-number ] [ verbose ]
Display forwarding information about mLDP P2MP tunnels.
display l2vpn forwarding mldp p2mp [ slot slot-number ]
Display mLDP P2MP tunnels of VSIs.
display l2vpn mldp p2mp [ vsi vsi-name ]
Reset BGP EVPN route dampening information and disable BGP EVPN route dampening.
reset bgp [ instance instance-name ] dampening l2vpn evpn
Reset flapping statistics about BGP EVPN routes.
reset bgp [ instance instance-name ] flap-info l2vpn evpn [ as-path-acl { as-path-acl-number | as-path-acl-name } | peer [ ipv4-address [ mask-length ] | peer ipv6-address [ prefix-length ] ] ]
Advertise suppressed MAC addresses for one time.
reset evpn route mac-mobility suppression [ evpn-instance instance-name | interface interface-type interface-number  | vsi vsi-name ] [ mac mac-address ]
EVPN VPLS configuration examples
Example: Configuring EVPN VPLS between singlehomed sites
As shown in Figure 19, set up a path between PE 1 and PE 2 for the CEs in site 1 and site 2 to communicate through EVPN VPLS over the MPLS or IP backbone network.
Figure 19 Network diagram
Device
IP address
Device
IP address
CE 1
XGE3/0/1
10.1.1.10/24
P
Loop0
3.3.3.3/32
PE 1
Loop0
1.1.1.1/32
XGE3/0/1
11.1.1.2/24
XGE3/0/1
N/A
XGE3/0/2
11.1.2.2/24
XGE3/0/2
11.1.1.1/24
PE 2
Loop0
2.2.2.2/32
CE 2
XGE3/0/1
10.1.1.20/24
XGE3/0/1
N/A
XGE3/0/2
11.1.2.1/24
1.     Configure CE 1.
<CE1> system-view
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.10 24
[CE1-Ten-GigabitEthernet3/0/1] quit
2.     Configure PE 1:
# Configure the LSR ID.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.1
# Enable L2VPN.
[PE1] l2vpn enable
# Enable global LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to the P device), and enable LDP on the interface.
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip address 11.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/2] mpls enable
[PE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[PE1-Ten-GigabitEthernet3/0/2] quit
# Configure OSPF for LDP to create LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Create an IBGP connection to PE 2, and enable BGP to advertise L2VPN information to PE 2.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE1-bgp-default] address-family l2vpn evpn
[PE1-bgp-default-evpn] peer 2.2.2.2 enable
[PE1-bgp-default-evpn] peer 2.2.2.2 advertise encap-type mpls
[PE1-bgp-default-evpn] quit
[PE1-bgp-default] quit
# Create VSI vpna, create an EVPN instance on the VSI, enable MPLS encapsulation, and configure an RD and route targets for the EVPN instance.
[PE1] vsi vpna
[PE1-vsi-vpna] evpn encapsulation mpls
[PE1-vsi-vpna-evpn-mpls] route-distinguisher 1:1
[PE1-vsi-vpna-evpn-mpls] vpn-target 1:1 export-extcommunity
[PE1-vsi-vpna-evpn-mpls] vpn-target 1:1 import-extcommunity
[PE1-vsi-vpna-evpn-mpls] quit
[PE1-vsi-vpna] quit
# Map Ten-GigabitEthernet 3/0/1 (the interface connected to CE 1) to VSI vpna.
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] xconnect vsi vpna
[PE1-Ten-GigabitEthernet3/0/1] quit
3.     Configure the P device:
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 3.3.3.3 32
[P-LoopBack0] quit
[P] mpls lsr-id 3.3.3.3
[P] mpls ldp
[P-ldp] quit
# Configure Ten-GigabitEthernet 3/0/1 (the interface connected to PE 1), and enable LDP on the interface.
[P] interface ten-gigabitethernet 3/0/1
[P-Ten-GigabitEthernet3/0/1] ip address 11.1.1.2 24
[P-Ten-GigabitEthernet3/0/1] mpls enable
[P-Ten-GigabitEthernet3/0/1] mpls ldp enable
[P-Ten-GigabitEthernet3/0/1] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to PE 2), and enable LDP on the interface.
[P] interface ten-gigabitethernet 3/0/2
[P-Ten-GigabitEthernet3/0/2] ip address 11.1.2.2 24
[P-Ten-GigabitEthernet3/0/2] mpls enable
[P-Ten-GigabitEthernet3/0/2] mpls ldp enable
[P-Ten-GigabitEthernet3/0/2] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 11.1.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
4.     Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.2 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.2
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip address 11.1.2.1 24
[PE2-Ten-GigabitEthernet3/0/2] mpls enable
[PE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/2] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 11.1.2.0 0.0.0.255
[PE2-ospf-1] quit
# Create an IBGP connection to PE 1, and enable BGP to advertise L2VPN information to PE 1.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn evpn
[PE2-bgp-default-evpn] peer 1.1.1.1 enable
[PE2-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
[PE2-bgp-default-evpn] quit
[PE2-bgp-default] quit
[PE2] vsi vpna
[PE2-vsi-vpna] evpn encapsulation mpls
[PE2-vsi-vpna-evpn-mpls] route-distinguisher 1:1
[PE2-vsi-vpna-evpn-mpls] vpn-target 1:1 export-extcommunity
[PE2-vsi-vpna-evpn-mpls] vpn-target 1:1 import-extcommunity
[PE2-vsi-vpna-evpn-mpls] quit
[PE2-vsi-vpna] quit
# Map Ten-GigabitEthernet 3/0/1 (the interface connected to CE 2) to VSI vpna.
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] xconnect vsi vpna
[PE2-Ten-GigabitEthernet3/0/1] quit
5.     Configure CE 2.
<CE2> system-view
[CE2] interface ten-gigabitethernet 3/0/1
[CE2-Ten-GigabitEthernet3/0/1] ip address 10.1.1.20 24
[CE2-Ten-GigabitEthernet3/0/1] quit
# Verify that an EVPN PW has been established between PE 1 and PE 2.
[PE1] display l2vpn pw
       N - no split horizon, A - administration, ABY - ac-bypass
       PBY - pw-bypass
Total number of PWs: 1
1 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: vpna
Peer            PWID/RmtSite/SrvID In/Out Label   Proto  Flag  Link ID  State
2.2.2.2         -                  775127/775127  EVPN   M     8        Up
# Display PW information on PE 2.
[PE2] display l2vpn pw
       PBY - pw-bypass
VSI Name: vpna
1.1.1.1         -                  775127/775127  EVPN   M     8        Up
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring EVPN VPLS multihoming (access through aggregate links)
As shown in Figure 20, configure EVPN VPLS for dualhomed site 1 and singlehomed site 2 to communicate over the MPLS or IP backbone network.
Figure 20 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
192.1.1.1/32
CE 1
RAGG1
100.1.1.1/24
XGE3/0/1
N/A
CE 2
XGE3/0/1
100.1.1.2/24
XGE3/0/2
10.1.1.1/24
PE 3
Loop0
192.3.3.3/32
XGE3/0/3
10.1.3.1/24
XGE3/0/1
N/A
PE 2
Loop0
192.2.2.2/32
XGE3/0/2
10.1.1.2/24
XGE3/0/1
N/A
XGE3/0/3
10.1.2.2/24
XGE3/0/2
10.1.2.1/24
XGE3/0/3
10.1.3.2/24
1.     Configure CE 1:
# Create static Layer 3 aggregate interface 1 and assign it an IP address.
<CE1> system-view
[CE1] interface route-aggregation 1
[CE1-Route-Aggregation1] ip address 100.1.1.1 24
[CE1-Route-Aggregation1] quit
# Assign Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 to aggregation group 1.
[CE1-Ten-GigabitEthernet3/0/1] port link-aggregation group 1
[CE1] interface ten-gigabitethernet 3/0/2
[CE1-Ten-GigabitEthernet3/0/2] port link-aggregation group 1
[CE1-Ten-GigabitEthernet3/0/2] quit
2.     Configure PE 1:
<PE1> system-view
[PE1-LoopBack0] ip address 192.1.1.1 32
[PE1] mpls lsr-id 192.1.1.1
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to PE 3), and enable LDP on the interface.
[PE1-Ten-GigabitEthernet3/0/2] ip address 10.1.1.1 24
# Configure Ten-GigabitEthernet 3/0/3 (the interface connected to PE 2), and enable LDP on the interface.
[PE1] interface ten-gigabitethernet 3/0/3
[PE1-Ten-GigabitEthernet3/0/3] ip address 10.1.3.1 24
[PE1-Ten-GigabitEthernet3/0/3] mpls enable
[PE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
[PE1-Ten-GigabitEthernet3/0/3] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.1.1.1 0.0.0.0
[PE1-ospf-1] quit
# Create IBGP connections to PE 2 and PE 3, and enable BGP to advertise routes to PE 2 and PE 3.
[PE1] bgp 100
[PE1-bgp-default] peer 192.2.2.2 as-number 100
[PE1-bgp-default] peer 192.2.2.2 connect-interface loopback 0
[PE1-bgp-default] peer 192.3.3.3 as-number 100
[PE1-bgp-default] peer 192.3.3.3 connect-interface loopback 0
[PE1-bgp-default-evpn] peer 192.2.2.2 enable
[PE1-bgp-default-evpn] peer 192.3.3.3 enable
[PE1-bgp-default-evpn] peer 192.2.2.2 advertise encap-type mpls
[PE1-bgp-default-evpn] peer 192.3.3.3 advertise encap-type mpls
# Assign an ESI to Ten-GigabitEthernet 3/0/1.
[PE1-Ten-GigabitEthernet3/0/1] esi 1.1.1.1.1
[PE1] vsi vpna
[PE1-vsi-vpna] quit
3.     Configure PE 2:
<PE2> system-view
[PE2-LoopBack0] ip address 192.2.2.2 32
[PE2] mpls lsr-id 192.2.2.2
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/2] ip address 10.1.2.1 24
# Configure Ten-GigabitEthernet 3/0/3 (the interface connected to PE 1), and enable LDP on the interface.
[PE2] interface ten-gigabitethernet 3/0/3
[PE2-Ten-GigabitEthernet3/0/3] ip address 10.1.3.2 24
[PE2-Ten-GigabitEthernet3/0/3] mpls enable
[PE2-Ten-GigabitEthernet3/0/3] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 192.2.2.2 0.0.0.0
[PE2-ospf-1] quit
# Create IBGP connections to PE 1 and PE 3, and enable BGP to advertise routes to PE 1 and PE 3.
[PE2] bgp 100
[PE2-bgp-default] peer 192.1.1.1 as-number 100
[PE2-bgp-default] peer 192.1.1.1 connect-interface loopback 0
[PE2-bgp-default] peer 192.3.3.3 as-number 100
[PE2-bgp-default] peer 192.3.3.3 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 192.1.1.1 enable
[PE2-bgp-default-evpn] peer 192.3.3.3 enable
[PE2-bgp-default-evpn] peer 192.1.1.1 advertise encap-type mpls
[PE2-bgp-default-evpn] peer 192.3.3.3 advertise encap-type mpls
[PE2-Ten-GigabitEthernet3/0/1] esi 1.1.1.1.1
[PE2] vsi vpna
[PE2-vsi-vpna] quit
4.     Configure PE 3:
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 192.3.3.3 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 192.3.3.3
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to PE 1) and Ten-GigabitEthernet 3/0/3 (the interface connected to PE 2), and enable LDP on the interfaces.
[PE3] interface ten-gigabitethernet 3/0/2
[PE3-Ten-GigabitEthernet3/0/2] ip address 10.1.1.2 24
[PE3-Ten-GigabitEthernet3/0/2] mpls enable
[PE3-Ten-GigabitEthernet3/0/2] mpls ldp enable
[PE3-Ten-GigabitEthernet3/0/2] quit
[PE3] interface ten-gigabitethernet 3/0/3
[PE3-Ten-GigabitEthernet3/0/3] ip address 10.1.2.2 24
[PE3-Ten-GigabitEthernet3/0/3] mpls enable
[PE3-Ten-GigabitEthernet3/0/3] mpls ldp enable
[PE3-Ten-GigabitEthernet3/0/3] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 192.3.3.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE3-ospf-1] quit
# Create IBGP connections to PE 1 and PE 2, and enable BGP to advertise routes to PE 1 and PE 2.
[PE3] bgp 100
[PE3-bgp-default] peer 192.1.1.1 as-number 100
[PE3-bgp-default] peer 192.1.1.1 connect-interface loopback 0
[PE3-bgp-default] peer 192.2.2.2 as-number 100
[PE3-bgp-default] peer 192.2.2.2 connect-interface loopback 0
[PE3-bgp-default] address-family l2vpn evpn
[PE3-bgp-default-evpn] peer 192.1.1.1 enable
[PE3-bgp-default-evpn] peer 192.2.2.2 enable
[PE3-bgp-default-evpn] peer 192.1.1.1 advertise encap-type mpls
[PE3-bgp-default-evpn] peer 192.2.2.2 advertise encap-type mpls
[PE3-bgp-default-evpn] quit
[PE3-bgp-default] quit
[PE3] vsi vpna
[PE3-vsi-vpna] evpn encapsulation mpls
[PE3-vsi-vpna-evpn-mpls] route-distinguisher 1:1
[PE3-vsi-vpna-evpn-mpls] vpn-target 1:1 export-extcommunity
[PE3-vsi-vpna-evpn-mpls] vpn-target 1:1 import-extcommunity
[PE3-vsi-vpna-evpn-mpls] quit
[PE3-vsi-vpna] quit
[PE3] interface ten-gigabitethernet 3/0/1
[PE3-Ten-GigabitEthernet3/0/1] xconnect vsi vpna
[PE3-Ten-GigabitEthernet3/0/1] quit
5.     Configure CE 2.
<CE2> system-view
[CE2-Ten-GigabitEthernet3/0/1] ip address 100.1.1.2 24
# Verify that PE 1 has established EVPN PWs to PE 2 and PE 3.
<PE1> display l2vpn pw
       PBY - pw-bypass
Total number of PWs: 2
2 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI name: vpna
192.3.3.3       -                  710263/710265  EVPN   M    8        Up
192.2.2.2       -                  710263/710124  EVPN   M    9        Up
# Verify that PE 1 has local ES information.
<PE1> display evpn es local
Redundancy mode: A - All-active, S - Single-active
VSI name : vpna
ESI                             Tag ID      DF address      Mode  State  ESI label
0001.0001.0001.0001.0001        0           192.1.1.1       A     Up     775128
# Verify that PE 1 has remote ES information.
<PE1> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
Status codes: * - valid
VSI name : vpna
  ESI                     : 0001.0001.0001.0001.0001
  Ethernet segment routes :
    192.2.2.2
  A-D per ES routes       :
    Peer IP             Remote Redundancy mode
    192.2.2.2           All-active
  A-D per EVI routes      :
    Tag ID      Peer IP
    0           192.2.2.2
# Verify that PE 2 has established EVPN PWs to PE 1 and PE 3.
<PE2> display l2vpn pw
       PBY - pw-bypass
VSI name: vpna
192.1.1.1       -                  710124/710263  EVPN   M    8        Up
192.3.3.3       -                  710124/710265  EVPN   M    9        Up
# Verify that PE 3 has established EVPN PWs to PE 1 and PE 2.
<PE3> display l2vpn pw
       PBY - pw-bypass
VSI name: vpna
192.1.1.1       -                  710265/710263  EVPN   M    8        Up
192.2.2.2       -                  710265/710124  EVPN   M    9        Up
# Verify that CE 1 and CE 2 can ping each other when the PW on PE 1 or PE 2 fails. (Details not shown.)
Example: Configuring EVPN VPLS multihoming (access through an S-Trunk system)
As shown in Figure 21, configure EVPN VPLS for dualhomed site 1 and singlehomed site 2 to communicate over the MPLS or IP backbone network. Configure PE 1 and PE 2 to form an S-Trunk system.
Figure 21 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
192.1.1.1/32
CE 1
RAGG1
100.1.1.1/24
XGE3/0/1
CE 2
XGE3/0/1
100.1.1.2/24
XGE3/0/2
10.1.1.1/24
PE 3
Loop0
192.3.3.3/32
XGE3/0/3
10.1.3.1/24
XGE3/0/1
PE 2
Loop0
192.2.2.2/32
XGE3/0/2
10.1.1.2/24
XGE3/0/1
XGE3/0/3
10.1.2.2/24
XGE3/0/2
10.1.2.1/24
XGE3/0/3
10.1.3.2/24
1.     Configure CE 1:
<CE1> system-view
2.     Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
[PE1] bgp 100
# Configure S-Trunk to set up a multichassis aggregate link to CE 1.
[PE1] lacp system-priority 10
[PE1] lacp system-mac 1-1-1
[PE1] lacp system-number 1
[PE1] s-trunk id 1
[PE1-s-trunk1] s-trunk ip destination 10.1.3.2 source 10.1.3.1
[PE1-s-trunk1] quit
[PE1] interface route-aggregation 1
[PE1-Route-Aggregation1] s-trunk 1
[PE1-Route-Aggregation1] s-trunk port-role primary
[PE1-Route-Aggregation1] quit
[PE1-Ten-GigabitEthernet3/0/1] port link-aggregation group 1
# On Route-Aggregation 1, configure an ESI and enable all-active redundancy mode.
[PE1-Route-Aggregation1] esi 1.1.1.1.1
[PE1-Route-Aggregation1] evpn redundancy-mode all-active
[PE1] vsi vpna
[PE1-vsi-vpna] quit
# Map Route-Aggregation 1 (the interface connected to CE 1) to VSI vpna.
[PE1-Route-Aggregation1] xconnect vsi vpna
3.     Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
[PE2] bgp 100
[PE2] lacp system-priority 10
[PE2] lacp system-mac 1-1-1
[PE2] lacp system-number 2
[PE2] s-trunk id 1
[PE2-s-trunk1] s-trunk ip destination 10.1.3.1 source 10.1.3.2
[PE2-s-trunk1] quit
[PE2] interface route-aggregation 1
[PE2-Route-Aggregation1] s-trunk 1
[PE2-Route-Aggregation1] s-trunk port-role primary
[PE2-Route-Aggregation1] quit
[PE2-Ten-GigabitEthernet3/0/1] port link-aggregation group 1
[PE2-Route-Aggregation1] esi 1.1.1.1.1
[PE2-Route-Aggregation1] evpn redundancy-mode all-active
[PE2] vsi vpna
[PE2-vsi-vpna] quit
[PE2-Route-Aggregation1] xconnect vsi vpna
4.     Configure PE 3:
<PE3> system-view
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
[PE3] bgp 100
[PE3] vsi vpna
[PE3-vsi-vpna] quit
5.     Configure CE 2.
<CE2> system-view
       PBY - pw-bypass
VSI name: vpna
VSI name : vpna
VSI name : vpna
    192.2.2.2
  A-D per ES routes       :
    Tag ID      Peer IP
    0           192.2.2.2
       PBY - pw-bypass
VSI name: vpna
       PBY - pw-bypass
VSI name: vpna
Example: Configuring local FRR for EVPN VPLS
As shown in Figure 22:
·     CE 1 is dualhomed to PE 1 and PE 2 through an aggregate link.
·     Configure EVPN VPLS on PE 1, PE 2, and PE 3 for CE 1 and CE 2 to communicate at Layer 2 over the backbone network.
·     Enable local FRR on PE 1 and PE 2 to prevent traffic loss caused by AC failure.
Figure 22 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
192.1.1.1/32
CE 1
XGE3/0/1
100.1.1.1/24
XGE3/0/1
CE 2
XGE3/0/1
100.1.1.2/24
XGE3/0/2
10.1.1.1/24
PE 3
Loop0
192.3.3.3/32
XGE3/0/3
10.1.3.1/24
XGE3/0/1
PE 2
Loop0
192.2.2.2/32
XGE3/0/2
10.1.1.2/24
XGE3/0/1
XGE3/0/3
10.1.2.2/24
XGE3/0/2
10.1.2.1/24
XGE3/0/3
10.1.3.2/24
1.     Configure CE 1:
# Create static Layer 3 aggregate interface Route-Aggregation 1 and assign it an IP address.
<CE1> system-view
2.     Configure PE 1:
# Configure an LSR ID.
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to PE3), and enable MPLS and LDP on the interface.
# Configure Ten-GigabitEthernet 3/0/3 (the interface connected to PE 2), and enable MPLS and LDP on the interface.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure PE 1 to establish IBGP peer relationships with PE 2 and PE 3, and configure BGP to advertise BGP EVPN routes.
[PE1] bgp 100
# Configure a smart trunk to establish an aggregate link across PE 1 and PE 2.
[PE1] s-trunk id 1
[PE1-s-trunk1] quit
# Create VSI vpna, create an EVPN instance on it, and enable MPLS encapsulation. Configure an RD and route targets for the EVPN instance.
[PE1] vsi vpna
[PE1-vsi-vpna] quit
# Assign an ESI to Route-Aggregation 1.
# Map Route-Aggregation 1 to VSI vpna.
# Enable local FRR for EVPN VPLS globally.
[PE1] evpn multihoming vpls-frr local
3.     Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to PE 3), and enable MPLS and LDP on the interface.
# Configure Ten-GigabitEthernet 3/0/3 (the interface connected to PE 1), and enable MPLS and LDP on the interface.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Configure PE 2 to establish IBGP peer relationships with PE 1 and PE 3, and configure BGP to advertise BGP EVPN routes.
[PE2] bgp 100
[PE2] s-trunk id 1
[PE2-s-trunk1] quit
[PE2] vsi vpna
[PE2-vsi-vpna] quit
[PE2] evpn multihoming vpls-frr local
4.     Configure PE 3:
<PE3> system-view
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to PE 1), and enable MPLS and LDP on the interface.
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
# Configure PE 3 to establish IBGP peer relationships with PE 1 and PE 2, and configure BGP to advertise EVPN routes.
[PE3] bgp 100
[PE3] vsi vpna
[PE3-vsi-vpna] quit
# Map Ten-GigabitEthernet 3/0/1 to VSI vpna.
5.     Configure CE 2.
<CE2> system-view
1.     Verify PW information:
# Verify that PE 1 has established PWs with PE 3 and PE 2.
       PBY - pw-bypass
VSI name: vpna
# Verify that PE 2 has established PWs with PE 1 and PE 3.
       PBY - pw-bypass
VSI name: vpna
# Verify that PE 3 has established PWs with PE 1 and PE 2.
       PBY - pw-bypass
VSI name: vpna
2.     Verify ES information:
# Display local ES information on PE 1.
VSI name : vpna
# Display remote ES information on PE 1.
VSI name : vpna
    192.2.2.2
  A-D per ES routes       :
    Tag ID      Peer IP             Control Flags
    0           192.2.2.2           B
3.     Verify that CE 1 and CE 2 can ping each other when all PWs are up and when a PW is down. (Details not shown.)
Example: Configuring LDP PWs as ACs for EVPN PWs
As shown in Figure 23:
·     PE 1 and PE 2 are edge devices on both the VPLS network and EVPN VPLS network.
·     PE 1, PE 2, and PE 4 use LDP to establish LDP PWs.
·     On PE 1 and PE 2, configure LDP PWs as UPWs (ACs) for EVPN PWs to ensure that the VPLS and EVPN VPLS networks can communicate with each other.
·     PE 4 is dual-homed to PE 1 and PE 2 through two LDP PWs (UPWs).
Figure 23 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
1.1.1.9/32
PE 3
Loop0
3.3.3.9/32
XGE3/0/1
10.1.1.1/24
XGE3/0/1
XGE3/0/2
30.1.1.1/24
XGE3/0/2
30.1.1.3/24
XGE3/0/3
10.1.3.1/24
XGE3/0/3
10.1.2.3/24
PE 2
Loop0
2.2.2.9/32
PE 4
Loop0
4.4.4.9/32
XGE3/0/1
20.1.1.2/24
XGE3/0/3
XGE3/0/2
10.1.2.2/24
XGE3/0/1
10.1.1.4/24
XGE3/0/3
10.1.3.2/24
XGE3/0/2
20.1.1.4/24
CE 1
XGE3/0/1
100.1.1.1/32
CE 2
XGE3/0/1
100.1.1.2/32
1.     Configure CE 1:
# Configure an IP address and mask for Ten-GigabitEthernet 3/0/1.
<CE1> system-view
[CE1-Ten-GigabitEthernet3/0/1] ip address 100.1.1.1 24
2.     Configure PE 4:
# Configure MPLS basic capabilities.
<PE4> system-view
[PE4] interface loopback 0
[PE4-LoopBack0] ip address 1.1.1.9 32
[PE4-LoopBack0] quit
[PE4] mpls lsr-id 1.1.1.9
# Enable LDP globally.
[PE4] mpls ldp
[PE4-ldp] quit
# Enable L2VPN.
[PE4] l2vpn enable
# Configure Ten-GigabitEthernet 3/0/1, the interface connected to PE 1.
[PE4] interface ten-gigabitethernet 3/0/1
[PE4-Ten-GigabitEthernet3/0/1] ip address 10.1.1.4 24
[PE4-Ten-GigabitEthernet3/0/1] ospf 1 area 0
[PE4-Ten-GigabitEthernet3/0/1] mpls enable
[PE4-Ten-GigabitEthernet3/0/1] mpls ldp enable
[PE4-Ten-GigabitEthernet3/0/1] undo shutdown
[PE4-Ten-GigabitEthernet3/0/1] quit
# Configure Ten-GigabitEthernet 3/0/2, the interface connected to PE 2.
[PE4] interface ten-gigabitethernet 3/0/2
[PE4-Ten-GigabitEthernet3/0/2] ip address 20.1.1.4 24
[PE4-Ten-GigabitEthernet3/0/2] ospf 1 area 0
[PE4-Ten-GigabitEthernet3/0/2] mpls enable
[PE4-Ten-GigabitEthernet3/0/2] mpls ldp enable
[PE4-Ten-GigabitEthernet3/0/2] undo shutdown
[PE4-Ten-GigabitEthernet3/0/2] quit
# Configure VSI vpna to use LDP to establish LDP PWs. The LDP PW between PE 1 and PE 4 is the primary PW and the LDP PW between PE 2 and PE 4 is the backup PW. Enable the dual receive feature for PW redundancy.
[PE4] vsi vpna
[PE4-vsi-vpna] protection dual-receive
[PE4-vsi-vpna] pwsignaling ldp
[PE4-vsi-vpna-ldp] peer 1.1.1.9 pw-id 500
[PE4-vsi-vpna-ldp-1.1.1.9-500] backup-peer 2.2.2.9 pw-id 500
[PE4-vsi-vpna-ldp-1.1.1.9-500-backup] quit
[PE4-vsi-vpna-ldp-1.1.1.9-500] quit
[PE4-vsi-vpna-ldp] quit
[PE4-vsi-vpna] quit
# Map Ten-GigabitEthernet 3/0/3 to VSI vpna.
[PE4] interface ten-gigabitethernet 3/0/3
[PE4-Ten-GigabitEthernet3/0/3] xconnect vsi vpna
[PE4-Ten-GigabitEthernet3/0/3] quit
3.     Configure PE 1:
# Configure interface Loopback 0.
<PE1> system-view
[PE1-LoopBack1] ip address 1.1.1.9 32
[PE1-LoopBack1] quit
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Run OSPF on PE 1 to set up LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure Ten-GigabitEthernet 3/0/1, the interface connected to PE 4.
[PE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/1] mpls enable
[PE1-Ten-GigabitEthernet3/0/1] mpls ldp enable
[PE1-Ten-GigabitEthernet3/0/1] undo shutdown
# Configure Ten-GigabitEthernet 3/0/2, the interface connected to PE 3.
[PE1-Ten-GigabitEthernet3/0/2] ip address 30.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/2] undo shutdown
# ConfigureTen-GigabitEthernet 3/0/3, the interface connected to PE 2.
[PE1-Ten-GigabitEthernet3/0/3] undo shutdown
# Establish IBGP connections to PE 2 and PE 3, and enable BGP EVPN to advertise route information to PE 2 and PE 3.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-evpn] peer 2.2.2.9 enable
[PE1-bgp-default-evpn] peer 3.3.3.9 enable
[PE1-bgp-default-evpn] peer 2.2.2.9 advertise encap-type mpls
[PE1-bgp-default-evpn] peer 3.3.3.9 advertise encap-type mpls
# Create a PW class and set its data encapsulation type to Ethernet.
[PE1] pw-class aaa
[PE1-pw-class-aaa] pw-type ethernet
[PE1-pw-class-aaa] quit
# Create VSI vpna, create an EVPN instance for it, enable MPLS encapsulation, and configure an RD and route targets for the EVPN instance.
[PE1] vsi vpna
# Configure VSI vpna to use LDP to establish LDP PWs. Configure PE 1 to establish an UPW with PE 4, assign an ESI to the UPW, and set the redundancy mode of the UPW to all-active.
[PE1-vsi-vpna] pwsignaling ldp
[PE1-vsi-vpna-ldp] peer 4.4.4.9 pw-id 500 no-split-horizon pw-class aaa
[PE1-vsi-vpna-ldp-4.4.4.9-500] esi 1.1.1.1.1
[PE1-vsi-vpna-ldp-4.4.4.9-500] evpn redundancy-mode all-active
[PE1-vsi-vpna-ldp-4.4.4.9-500] quit
[PE1-vsi-vpna-ldp] quit
[PE1-vsi-vpna] quit
4.     Configure PE 2:
<PE2> system-view
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Run OSPF on PE 2 to set up LSPs.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
# Configure Ten-GigabitEthernet 3/0/3, the interface connected to PE 1.
[PE2-Ten-GigabitEthernet3/0/3] undo shutdown
[PE2-Ten-GigabitEthernet3/0/2] undo shutdown
[PE2-Ten-GigabitEthernet3/0/1] ip address 20.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/1] mpls enable
[PE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/1] undo shutdown
# Establish IBGP connections to PE 1 and PE 3 and enable BGP EVPN to advertise route information to PE 1 and PE 3.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] peer 3.3.3.9 as-number 100
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 1.1.1.9 enable
[PE2-bgp-default-evpn] peer 3.3.3.9 enable
[PE2-bgp-default-evpn] peer 1.1.1.9 advertise encap-type mpls
[PE2-bgp-default-evpn] peer 3.3.3.9 advertise encap-type mpls
[PE2] pw-class aaa
[PE2-pw-class-aaa] pw-type ethernet
[PE2-pw-class-aaa] quit
[PE2] vsi vpna
# Configure VSI vpna to use LDP to establish LDP PWs. Configure PE 2 to establish an UPW with PE 4, assign an ESI to the UPW, and set the redundancy mode of the UPW to all-active.
[PE2] vsi vpna
[PE2-vsi-vpna] pwsignaling ldp
[PE2-vsi-vpna-ldp] peer 1.1.1.9 pw-id 500 no-split-horizon pw-class aaa
[PE2-vsi-vpna-ldp-1.1.1.9-500] esi 1.1.1.1.1
[PE2-vsi-vpna-ldp-1.1.1.9-500] evpn redundancy-mode all-active
[PE2-vsi-vpna-ldp-1.1.1.9-500] quit
[PE2-vsi-vpna-ldp] quit
[PE2-vsi-vpna] quit
5.     Configure PE 3:
<PE3> system-view
[PE3-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
# Run OSPF on PE 3 to set up LSPs.
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE3-ospf-1] quit
# Configure Ten-GigabitEthernet 3/0/2, the interface connected to PE 1.
[PE3-Ten-GigabitEthernet3/0/2] ip address 30.1.1.3 24
[PE3-Ten-GigabitEthernet3/0/2] undo shutdown
# Configure Ten-GigabitEthernet 3/0/3, the interface connected to PE 2.
[PE3-Ten-GigabitEthernet3/0/3] ip address 10.1.2.3 24
[PE3-Ten-GigabitEthernet3/0/3] undo shutdown
# Establish IBGP connections to PE 1 and PE 2, and enable BGP EVPN to advertise route information to PE 1 and PE 2.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default] peer 2.2.2.9 as-number 100
[PE3-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-default-evpn] peer 1.1.1.9 enable
[PE3-bgp-default-evpn] peer 2.2.2.9 enable
[PE3-bgp-default-evpn] peer 1.1.1.9 advertise encap-type mpls
[PE3-bgp-default-evpn] peer 2.2.2.9 advertise encap-type mpls
[PE3] vsi vpna
6.     Configure CE 2.
<CE2> system-view
# On PE 1, display PW information. Verify that PE 1 has established an LDP PW with PE 4 and EVPN PWs with PE 2 and PE 3.
       PBY - pw-bypass
Total number of PWs: 3
3 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: vpna
4.4.4.9         500                1147/-         LDP    MN   8        Up
2.2.2.9         -                  1148/1148      EVPN   M    9        Up
3.3.3.9         -                  1148/1149      EVPN   M    10       Up
# On PE 1, display local ES information. Verify that the LDP PW (UPW) has multihoming settings.
<PE1> display evpn es local verbose
VSI name : vpna
  Interface                : -
  Redundancy mode          : All-active
  State                    : Up
  UPWs                     :
    Link ID     Service instance ID   Tag ID      DF address        ESI label
    8           -                     0           -                 1146
# Display information on PE 2 in the same way as information is displayed on PE 1. (Details not shown.)
Example: Configuring EVPN VPLS over mLDP
As shown in Figure 24, on the EVPN VPLS network, mLDP P2MP tunnels are set up to forward flood traffic over the public network, avoiding excessive bandwidth usage in the core network. On the EVPN VPLS network:
·     PE 1 connects to the multicast source. PE 2 and PE 3 connect to the multicast receivers.
·     The RR reflects BGP EVPN routes between PEs.
Figure 24 Network diagram
Analysis
To forward flood traffic from the EVPN VPLS network through mLDP P2MP tunnels over the public network, configure the following settings on PE devices except for basic EVPN VPLS functions:
·     Enable mLDP on the RR and each PE to set up mLDP P2MP tunnels on the public network.
·     On PE 1 connecting to the multicast source, configure a multicast inclusive tunnel and a multicast selective tunnel, and set the IP address for the root node of the mLDP P2MP tunnel to the loopback address of PE 1. On the PEs connecting to the multicast receivers, create only multicast tunnels with no need to configure multicast inclusive and selective tunnels.
·     Enable IGMP snooping on each PE to listen to IGMP messages.
1.     Configure IP addresses on the interfaces of each PE and RR, and run OSPF to reach the public network.
# Configure PE 1.
<PE1> system-view
[PE1] ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
[PE1-LoopBack0] ospf 1 area 0
[PE1-Ten-GigabitEthernet3/0/1] ip address 14.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/1] ospf 1 area 0
# Configure PE 2.
<PE2> system-view
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
[PE2-LoopBack0] ospf 1 area 0
[PE2-Ten-GigabitEthernet3/0/1] ip address 15.1.1.1 24
[PE2-Ten-GigabitEthernet3/0/1] ospf 1 area 0
# Configure PE 3.
<PE3> system-view
[PE3] ospf 1
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
[PE3-LoopBack0] ip address 3.3.3.3 32
[PE3-LoopBack0] ospf 1 area 0
[PE3-Ten-GigabitEthernet3/0/1] ip address 16.1.1.1 24
[PE3-Ten-GigabitEthernet3/0/1] ospf 1 area 0
# Configure the RR.
<RR> system-view
[RR] ospf 1
[RR-ospf-1] area 0
[RR-ospf-1-area-0.0.0.0] quit
[RR-ospf-1] quit
[RR] interface loopback 0
[RR-LoopBack0] ip address 4.4.4.4 32
[RR-LoopBack0] ospf 1 area 0
[RR-LoopBack0] quit
[RR] interface ten-gigabitethernet 3/0/1
[RR-Ten-GigabitEthernet3/0/1] ip address 14.1.1.2 24
[RR-Ten-GigabitEthernet3/0/1] ospf 1 area 0
[RR-Ten-GigabitEthernet3/0/1] quit
[RR] interface ten-gigabitethernet 3/0/2
[RR-Ten-GigabitEthernet3/0/2] ip address 15.1.1.2 24
[RR-Ten-GigabitEthernet3/0/2] ospf 1 area 0
[RR-Ten-GigabitEthernet3/0/2] quit
[RR] interface ten-gigabitethernet 3/0/3
[RR-Ten-GigabitEthernet3/0/3] ip address 16.1.1.2 24
[RR-Ten-GigabitEthernet3/0/3] ospf 1 area 0
[RR-Ten-GigabitEthernet3/0/3] quit
2.     Enable MPLS, LDP, and mLDP on each PE and the RR.
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] mldp p2mp
All associated LDP sessions will be reset. Continue? [Y/N]:y
[PE1-ldp] quit
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] mldp p2mp
[PE2-ldp] quit
# Configure PE 3.
[PE3] mpls lsr-id 3.3.3.3
[PE3] mpls ldp
[PE3-ldp] mldp p2mp
[PE3-ldp] quit
[PE3-Ten-GigabitEthernet3/0/1] mpls enable
[PE3-Ten-GigabitEthernet3/0/1] mpls ldp enable
# Configure the RR.
[RR] mpls lsr-id 4.4.4.4
[RR] mpls ldp
[RR-ldp] mldp p2mp
[RR-ldp]  quit
[RR-Ten-GigabitEthernet3/0/1] mpls enable
[RR-Ten-GigabitEthernet3/0/1] mpls ldp enable
[RR-Ten-GigabitEthernet3/0/2] mpls enable
[RR-Ten-GigabitEthernet3/0/2] mpls ldp enable
[RR-Ten-GigabitEthernet3/0/3] mpls enable
[RR-Ten-GigabitEthernet3/0/3] mpls ldp enable
3.     Configure BGP EVPN on each PE and the RR.
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.4 as-number 100
[PE1-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[PE1-bgp-default-evpn] peer 4.4.4.4 enable
[PE1-bgp-default-evpn] peer 4.4.4.4 advertise encap-type mpls
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 4.4.4.4 as-number 100
[PE2-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 4.4.4.4 enable
[PE2-bgp-default-evpn] peer 4.4.4.4 advertise encap-type mpls
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 4.4.4.4 as-number 100
[PE3-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[PE3-bgp-default-evpn] peer 4.4.4.4 enable
[PE3-bgp-default-evpn] peer 4.4.4.4 advertise encap-type mpls
# Configure the RR.
[RR] bgp 100
[RR-bgp-default] peer 1.1.1.1 as-number 100
[RR-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[RR-bgp-default] peer 2.2.2.2 as-number 100
[RR-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[RR-bgp-default] peer 3.3.3.3 as-number 100
[RR-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[RR-bgp-default] address-family l2vpn evpn
[RR-bgp-default-evpn] undo policy vpn-target
[RR-bgp-default-evpn] peer 1.1.1.1 enable
[RR-bgp-default-evpn] peer 1.1.1.1 reflect-client
[RR-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
[RR-bgp-default-evpn] peer 2.2.2.2 enable
[RR-bgp-default-evpn] peer 2.2.2.2 reflect-client
[RR-bgp-default-evpn] peer 2.2.2.2 advertise encap-type mpls
[RR-bgp-default-evpn] peer 3.3.3.3 enable
[RR-bgp-default-evpn] peer 3.3.3.3 reflect-client
[RR-bgp-default-evpn] peer 3.3.3.3 advertise encap-type mpls
[RR-bgp-default-evpn] quit
[RR-bgp-default] quit
4.     Enable L2VPN on each PE.
# Configure PE 1.
[PE1] l2vpn enable
# Configure PE 2.
[[PE2] l2vpn enable
# Configure PE 3.
[[PE3] l2vpn enable
5.     Configure an EVPN instance on each PE. Create a multicast tunnel in each EVPN instance. On PE 1 connecting to the multicast source, create a multicast inclusive tunnel and a selective tunnel and specify the mLDP P2MP tunnel as the inclusive tunnel.
# Configure PE 1.
[PE1] evpn instance vpna
[PE1-evpn-instance-vpna] route-distinguisher 1:1
[PE1-evpn-instance-vpna] vpn-target 1:1
[PE1-evpn-instance-vpna] provider-tunnel
[PE1-evpn-instance-vpna-provider] inclusive-provider-tunnel
[PE1-evpn-instance-vpna-provider-inclusive] role root
[PE1-evpn-instance-vpna-provider-inclusive] mldp p2mp
[PE1-evpn-instance-vpna-provider-inclusive-mldp] root-ip 1.1.1.1
[PE1-evpn-instance-vpna-provider-inclusive-mldp] quit
[PE1-evpn-instance-vpna-provider-inclusive] quit
[PE1-evpn-instance-vpna-provider] selective-provider-tunnel
[PE1-evpn-instance-vpna-provider-selective] switch-delay 10
[PE1-evpn-instance-vpna-provider-selective] group 239.1.1.0 255.255.255.0 mldp
[PE1-evpn-instance-vpna-provider-selective] quit
[PE1-evpn-instance-vpna-provider] quit
[PE1-evpn-instance-vpna] quit
# Configure PE 2.
[PE2] evpn instance vpna
[PE2-evpn-instance-vpna] route-distinguisher 1:1
[PE2-evpn-instance-vpna] vpn-target 1:1
[PE2-evpn-instance-vpna] provider-tunnel
[PE2-evpn-instance-vpna-provider] quit
[PE2-evpn-instance-vpna] quit
# Configure PE 3.
[PE3] evpn instance vpna
[PE3-evpn-instance-vpna] route-distinguisher 1:1
[PE3-evpn-instance-vpna] vpn-target 1:1
[PE3-evpn-instance-vpna] provider-tunnel
[PE3-evpn-instance-vpna-provider] quit
[PE3-evpn-instance-vpna] quit
6.     Create a VSI instance on each PE, bind the VSI to the EVPN instance, and configure IGMP snooping in the VSI.
# Configure PE 1.
[PE1] igmp-snooping
[PE1-igmp-snooping] quit
[PE1] vsi vsi1
[PE1-vsi-vsi1] igmp-snooping enable
[PE1-vsi-vsi1] igmp-snooping version 3
[PE1-vsi-vsi1] igmp-snooping proxy enable
[PE1-vsi-vsi1] evpn encapsulation mpls binding instance vpna
[PE1-vsi-vsi1-evpn-mpls-bind] quit
[PE1-vsi-vsi1] quit
# Configure PE 2.
[PE2] igmp-snooping
[PE2-igmp-snooping] quit
[PE2] vsi vsi1
[PE2-vsi-vsi1] igmp-snooping enable
[PE2-vsi-vsi1] igmp-snooping version 3
[PE2-vsi-vsi1] igmp-snooping proxy enable
[PE2-vsi-vsi1] evpn encapsulation mpls binding instance vpna
[PE2-vsi-vsi1-evpn-mpls-bind] quit
[PE2-vsi-vsi1] quit
# Configure PE 3.
[PE3] igmp-snooping
[PE3-igmp-snooping] quit
[PE3] vsi vsi1
[PE3-vsi-vsi1] igmp-snooping enable
[PE3-vsi-vsi1] igmp-snooping version 3
[PE3-vsi-vsi1] igmp-snooping proxy enable
[PE3-vsi-vsi1] evpn encapsulation mpls binding instance vpna
[PE3-vsi-vsi1-evpn-mpls-bind] quit
[PE3-vsi-vsi1] quit
7.     Map the interface on each  PE to the VSI.
# Configure PE 1.
[PE1-Ten-GigabitEthernet3/0/2] xconnect vsi vsi1
# Configure PE 2.
[PE2-Ten-GigabitEthernet3/0/2] xconnect vsi vsi1
# Configure PE 3.
[PE3-Ten-GigabitEthernet3/0/2] xconnect vsi vsi1
# Execute the display mpls mldp lsp p2mp and display evpn mldp p2mp commands on PE 1. PE 1 as the root node has set the mLDP P2MP tunnel successfully. This tunnel is used to forward flood traffic of VSI instance vsi1.
<PE1> display mpls mldp lsp p2mp
Ingress: 1           Transit: 0           Egress: 0           Bud: 0
FECs: 1              Liberal: 0
Root IP        : 1.1.1.1              Instance         : --
Opaque decoded : LSP-ID 1025
Opaque value   : 01000400000401
Tunnel ID      : 1
LSR type       : Ingress
Trigger type   : EVPN
Downstream info:
  Peer: 4.4.4.4:0
    Out label: 1279             State: Established
    Next hops: 14.1.1.2                XGE3/0/1
<PE1> display evpn mldp p2mp
Total Num of Tunnels : 1
1 up, 0 down
VSI name: vsi1
EVPN instance: vpna
  Source address : 0.0.0.0
  Group address  : 0.0.0.0
  Mac address    : 0000-0000-0000
  Tunnel ID      : 1
  VN ID          : 0x80000001
  Tunnel state   : Up
  Root IP        : 1.1.1.1
  Opaque value   : 0x01000400000401
# Execute the display mpls mldp lsp p2mp command on PE 2, PE 3, and the RR. The mLDP P2MP tunnel has been set up on PE 2, PE 3, and the RR with PE 1 as the root node.
<PE2> display mpls mldp lsp p2mp
Ingress: 0           Transit: 0           Egress: 1           Bud: 0
FECs: 1              Liberal: 0
Tunnel ID      : 1
LSR type       : Egress
Trigger type   : EVPN
In label       : 1407
Upstream info:
  Peer: 4.4.4.4: 0               State: Established
<PE3> display mpls mldp lsp p2mp
FECs: 1              Liberal: 0
Tunnel ID      : 1
LSR type       : Egress
Trigger type   : EVPN
In label       : 1407
Upstream info:
<RR> display mpls mldp lsp p2mp
Ingress: 0           Transit: 1           Egress: 0           Bud: 0
FECs: 1              Liberal: 0
Tunnel ID      : 1
LSR type       : Transit
Trigger type   : --
In label       : 1279
Upstream info:
  Peer: 1.1.1.1:0               State: Established
Downstream info:
  Peer: 2.2.2.2:0
    Out label: 1407             State: Established
    Next hops: 15.1.1.1                XGE3/0/2
  Peer: 3.3.3.3:0
    Next hops: 16.1.1.1                XGE3/0/3XGE3/0/3
