16-Telemetry Configuration Guide
HomeSupportRoutersCR16000-M SeriesConfigure & DeployConfiguration GuidesH3C CR16000-M Router Configuration Guides-R8630Pxx-6W10016-Telemetry Configuration Guide
01-gRPC configuration
01-gRPC configuration 417.72 KB
Configuring gRPC·· 1
About gRPC· 1
gRPC protocol stack· 1
Network architecture· 2
Telemetry technology based on gRPC· 2
Telemetry modes· 2
Telemetry data model architectures· 3
Protocols· 3
Restrictions and guidelines: gRPC configuration· 3
Configuring the gRPC dial-in mode· 3
gRPC dial-in mode configuration tasks at a glance· 3
Configuring the gRPC service· 3
Specifying a PKI domain for secure connections to collectors· 4
Configuring a gRPC user 4
Enabling gRPC logging in dial-in mode· 5
Configuring the gRPC dial-out mode· 6
gRPC dial-out mode configuration tasks at a glance· 6
Enabling the gRPC service· 6
Specifying a PKI domain for secure connections to collectors· 6
Configuring sensors· 7
Configuring collectors· 9
Configuring a subscription· 9
Configuring interface presampling· 11
Enabling gRPC logging in dial-out mode· 12
Display and maintenance commands for gRPC· 12
gRPC configuration examples· 12
Example: Configuring the gRPC dial-in mode· 12
Example: Configuring event-triggered telemetry in gRPC dial-out mode· 13
Example: Configuring periodic telemetry in gRPC dial-out mode· 14
Protocol buffer code· 16
Protocol buffer code format 16
Proto definition files· 17
Proto definition files in dial-in mode· 17
Proto definition file in dial-out mode· 19
Obtaining proto definition files· 21
Example: Developing a gRPC collector-side application· 21
Prerequisites· 21
Generating the C++ code for the proto definition files· 22
Developing the collector-side application (dial-in mode) 22
Developing the collector-side application (dial-out mode) 35
Appendix: Methods and attributes for gNMI operations· 36
Configuring gRPC
About gRPC
gRPC is an open source remote procedure call (RPC) system initially developed at Google. It uses HTTP 2.0 and provides network device configuration and management methods that support multiple programming languages.
gRPC protocol stack
Figure 1 shows the gRPC protocol stack.
Figure 1 gRPC protocol stack
Table 1 describes the gRPC protocol stack layers from the bottom up.
Table 1 gRPC protocol stack layers
Layer
TCP transport layer
Provides connection-oriented reliable data links.
TLS transport layer
(Optional.) Provides channel encryption and mutual certificate authentication.
HTTP 2.0 layer
The transport protocol for gRPC. HTTP 2.0 provides enhanced features such as header field compression, multiplexing requests on a single connection, and flow control.
gRPC layer
Defines the interaction format for RPC calls. Public proto definition files such as the grpc_dialout.proto file define the public RPC methods.
Content layer
Carries encoded service data. This layer supports the following encoding formats:
·     Google Protocol Buffer (GPB)—A highly efficient binary encoding format. This format uses proto definition files to describe the structure of data to be serialized. GPB is more efficient in data transmission than protocols such as JavaScript Object Notation.
·     JavaScript Object Notation (JSON)—A lightweight data exchange format. It uses a text format that is language neutral to store and represent data, which is easy to read and compile.
If service data is in JSON format, you can use the public proto files to decode the data without having to use the proto file specific to the service module.
As shown in Figure 2, the gRPC network uses the client/server model. It uses HTTP 2.0 for packet transport.
Figure 2 gRPC network architecture
The gRPC network uses the following mechanism:
1.     The gRPC server listens to connection requests from clients at the gRPC service port.
2.     A user runs the gRPC client application to log in to the gRPC server, and uses methods provided in the .proto file to send requests.
3.     The gRPC server responds to requests from the gRPC client.
The device can act as the gRPC server or client.
Telemetry is a remote data collection technology for monitoring device performance and operating status. H3C telemetry technology uses gRPC to push data from the device to the collectors on the NMSs. As shown in Figure 3, after a gRPC connection is established between the device and NMSs, the NMSs can subscribe to data of modules on the device.
Figure 3 Telemetry technology based on gRPC
Telemetry modes
The device supports the following telemetry modes:
·     Dial-in mode—The device acts as a gRPC server and the collectors act as gRPC clients. A collector initiates a gRPC connection to the device to subscribe to device data.
Dial-in mode supports the following types of operations:
¡     Get—Obtains device status and settings.
¡     CLI—Executes commands on the device.
¡     gNMI—gRPC Network Management Interface operations, which include the following subtypes of operations:
-     gNMI Capabilities—Obtains the capabilities of the device.
-     gNMI Get—Obtains the status and settings of the device.
-     gNMI Set—Deploys settings to the device.
-     gNMI Subscribe—Subscribes to data push services provided by the device. The data might be generated by periodical data collection or event-triggered data collection. The functionality of this type of operation is similar to the functionality of the dial-out mode.
·     Dial-out mode—The device acts as a gRPC client and the collectors act as gRPC servers. The device initiates gRPC connections to the collectors and pushes device data to the collectors as configured.
The device supports the following telemetry data model architectures:
·     Three-layer data model architecture—Contains the following three layers:
¡     RPC layer—Defined in public proto definition files grpc_dialout.proto and grpc_dialout_v3.proto. This layer provides public RPC methods such as the message format.
¡     Telemetry layer—Defined in the public proto definition file telemetry.proto. This layer provides data collection-related services.
¡     Content layer—Carries GPB or JSON encoded service data.
The RPC and telemetry layers are identical to the gRPC layer in the gRPC protocol stack.
For more information about the proto definition files, see "Proto definition files."
·     Two-layer data model architecture—Contains the RPC and content layers. Two-layer data models support only JSON for service data encoding.
Protocols
·     RFC 7540, Hypertext Transfer Protocol version 2 (HTTP/2)
·     RFC 2818, HTTP Over TLS
Disabling the gRPC service deletes all gRPC settings.
To configure the gRPC dial-in mode, perform the following tasks:
1.     Configuring the gRPC service
2.     (Optional.) Specifying a PKI domain for secure connections to collectors
3.     Configuring a gRPC user
4.     (Optional.) Enabling gRPC logging in dial-in mode
2.     Enable the gRPC service.
grpc enable
By default, the gRPC service is disabled.
3.     (Optional.) Specify an ACL to identify the gRPC clients allowed to establish gRPC sessions.
grpc acl [ ipv6 ] { acl-number | name acl-name }
By default, no ACL is used for identifying the gRPC clients allowed to establish gRPC sessions.
Associating an ACL with gRPC causes the gRPC service to restart, disconnecting the ongoing sessions. The clients must re-establish gRPC sessions.
You can use this command to specify only one IPv4 ACL and one IPv6 ACL. If you execute this command multiple times, the most recent specified IPv4 ACL and IPv6 ACL take effect.
4.     (Optional.) Set the gRPC service port number.
grpc port port-number
By default, the gRPC service port number is 50051.
Changing the gRPC service port number reboots the gRPC service and terminates all gRPC sessions to the gRPC server.
5.     (Optional.) Set the gRPC session idle timeout timer.
grpc idle-timeout minutes
By default, the gRPC session idle timeout timer is 5 minutes.
6.     (Optional.) Disable the gRPC dial-in mode.
undo grpc server enable
By default, the gRPC dial-in mode is enabled.
By default, the gRPC connection between the device and a collector does not provide data encryption service or require authentication. After you specify a PKI domain, the device and the collector will use TLS for data encryption and bidirectional certificate-based authentication to improve communication security.
After you specify the PKI domain, the gRPC service will reboot, closing the connections to collectors. The collectors must re-initiate the connections.
The specified PKI domain must already exist and has correct certificate and key settings. For more information about PKI domains, see PKI configuration in Security Configuration Guide.
Perform this task before enabling the gRPC service. If you enable the gRPC service before performing this task, the configuration does not take effect.
2.     Specify a PKI domain for secure connections to collectors.
grpc pki domain domain-name
By default, no PKI domain is specified for secure connections to collectors.
For gRPC clients to establish gRPC sessions with the device, you must configure local users for the gRPC clients on the device.
2.     Add a local user with the device management right.
3.     Configure a password for the user.
By default, no password is configured for a local user. A non-password-protected user can pass authentication after providing the correct username and passing attribute checks.
4.     Assign user role network-admin to the user.
By default, a local user is assigned the network-operator role.
5.     Authorize the user to use the HTTPS service.
service-type https
By default, no service types are authorized to a local user.
For more information about the local-user, password, authorization-attribute, and service-type commands, see AAA configuration in BRAS Services Command Reference.
To identify issues with gRPC in dial-in mode, enable gRPC operations logging in dial-in mode.
This feature generates gRPC operation logs in dial-in mode and sends them to the information center.
With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
gRPC operation logging might degrade device performance if gRPC operations are frequent. As a best practice, use gRPC operation logging only when necessary and log only gRPC operations of interest if gRPC operation logging is enabled.
2.     Enable gRPC logging in dial-in mode. Choose the options to configure as needed:
¡     Enable gRPC logging for RPC operations in dial-in mode.
grpc log dial-in rpc { all | { cli | get }* }
By default, gRPC logging is disabled for RPC operations in dial-in mode.
¡     Enable gRPC logging for gNMI operations in dial-in mode.
grpc log dial-in gnmi { all | { capabilities | get | set | subscribe }* }
By default, gRPC logging is enabled for gNMI Set operations and disabled for other gNMI operations in dial-in mode.
To configure the gRPC dial-out mode, perform the following tasks:
1.     Enabling the gRPC service
3.     Configuring sensors
4.     Configuring collectors
5.     Configuring a subscription
6.     (Optional.) Configuring interface presampling
7.     (Optional.) Enabling gRPC logging in dial-out mode
grpc enable
3.     (Optional.) Specify the architecture of telemetry data models.
grpc data-model { 2-layer | 3-layer }
By default, the device uses two-layer telemetry data models to push data.
With the two-layer telemetry data model architecture, the device can only encode pushed data in JSON format.
Configuring sensors
The device uses sensors to collect data. A sensor path indicates a data source.
The device supports the following data collection types:
·     Event-triggered collection—Collects data from sensors in a sensor group when certain events occur. For sensor paths of this type, see NETCONF XML API Event Reference for the module.
·     Periodic collection—Collects data from sensors in a sensor group at intervals. For sensor paths of this type, see the NETCONF XML API references for the module except for NETCONF XML API Event Reference.
The device supports flexible sensor mode and simple sensor mode for flexible filtering and simple filtering, respectively.
Depending on the sensor mode, you can configure the sensor paths in a sensor group with simple filtering conditions or flexible filtering conditions.
·     In flexible sensor mode, you can set the operator between filtering conditions on a sensor path to AND or OR.
·     In simple sensor mode, the operator between filtering conditions on a sensor path is fixed at AND. The device pushes only data that matches all filtering conditions from the sensor path.
The sensor path configuration procedure differs depending on the sensor mode.
·     In flexible sensor mode, use the following procedure to configure a sensor path and its filtering conditions:
a.     Execute the sensor-path-flex command to add the sensor path to the sensor group and enter flex-mode sensor path view. In some situations, the sensor paths specified by using this method are called flex-mode sensor paths for clarity.
b.     Execute the filter command to create a filter for the sensor path.
c.     Execute the condition command to add filtering conditions to the filter.
d.     Execute the operator command to set the operator between the filtering conditions.
-     To push data that matches all conditions, set the operator to and.
-     To push data that matches any filtering conditions, set the operator to or.
·     In simple sensor mode, use the following procedure to configure a sensor path and its filtering conditions:
e.     Execute the sensor path command to add the sensor path to the sensor group. When you execute the command, you can specify a filtering condition. In some situations, the sensor paths specified by using this method are called simple-mode sensor paths for clarity.
f.     To specify multiple filtering conditions on the sensor path, repeat the command with different filtering conditions.
The operator between filtering conditions on the sensor path is fixed at AND. The device pushes only data that matches all filtering conditions from the sensor path.
Flexible filtering and simple filtering are mutually exclusive. Before you change the sensor mode from simple to flexible, you must delete all sensor groups or delete all simple-mode sensor paths from all sensor groups. Likewise, before you change the sensor mode from flexible to simple, you must delete all sensor groups or delete all flex-mode sensor paths.
In simple sensor mode, you can repeat the sensor path command to configure multiple sensor paths or configure a sensor path with different data filtering conditions. A sensor path can have a maximum of five data filtering conditions. The device pushes data of the sensor path to collectors only when all these conditions are met.
In flexible sensor mode, you can configure only one filter for a sensor path.
Configuring sensors in simple mode
2.     Enter telemetry view.
telemetry
3.     Create a sensor group and enter sensor group view.
sensor-group group-name
4.     Specify a sensor path.
sensor path path [ condition node node operator operator value value | depth depth ]
Configuring sensors in flexible mode
telemetry
3.     Enable flexible sensor mode.
grpc sensor-mode flex
By default, simple sensor mode applies.
4.     Create a sensor group and enter sensor group view.
5.     Specify a flex-mode sensor path and enter flex-mode sensor path view.
sensor-path-flex path
6.     (Optional.) Set the retrieval level for the sensor path.
depth depth
By default, the data retrieval depth is 1.
This command is supported only for sensor paths that represent multilevel tables.
7.     (Optional.) Configure a filter for the sensor path.
a.     Create a filter and enter filter view.
filter filter-name
By default, a sensor path does not have a filter.
b.     (Optional.) Set the logical operator between the filtering conditions in the filter.
operator { and | or }
By default, the AND operator applies to the filtering conditions in a filter.
c.     Configure a filtering condition. To configure multiple filtering conditions, repeat this step.
By default, a filter does not contain filtering conditions.
Collectors are used to receive data from network devices. For the device to communicate with collectors, you must create a destination group and add collectors to the destination group.
As a best practice, configure a maximum of five destination groups. If you configure too many destination groups, system performance might degrade.
telemetry
3.     Create a destination group and enter destination group view.
destination-group group-name
4.     Specify a collector.
IPv4:
ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
IPv6:
ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
The IPv6 address of a collector cannot be an IPv6 link-local address. For more information about IPv6 link-local addresses, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
To specify multiple collectors, execute this command multiple times. One collector must have a different address, port, or VPN instance than the other collectors.
A subscription binds sensor groups to destination groups. Then, the device pushes data from the specified sensors to the collectors.
When you specify a sensor group for a subscription, follow these restrictions and guidelines:
·     Specify the data sampling interval (sample-interval) for periodic sensor paths and only for periodic sensor paths.
¡     If you specify the option for event-triggered sensor paths, the sensor paths do not take effect.
¡     If you do not specify the option for periodic sensor paths, the device does not sample or push data.
When you set the data sampling interval to 10 or 100 milliseconds and specify the UDP transport protocol, follow these restrictions and guidelines:
·     The 10 milliseconds data sampling interval applies only to the ifmgr/statistics sensor paths specified with the [ifindex="index"] filter, for example, sensor path ifmgr/statistics[ifindex="Ten-GigabitEthernet3/0/1"]. The device will collect data from all other sensor paths in the sensor group at the minimum data sampling interval for each of them.
·     To collect data from the ifmgr/statistics sensor path at 10 milliseconds, the transport protocol for the subscription must be UDP. To set the transport protocol for a subscription, use the protocol command.
·     You can add ifmgr/statistics paths with interface-based filtering conditions in the sensor group to sample data from up to four interfaces per slot in total. If the ifstats sample-interval udp command is executed, the maximum number of interfaces configured in the ifstats sample-interval udp command applies.
·     After sensor path ifmgr/statistics is configured for the sensor group, if the presampling interval is greater than the data sampling interval, the data push interval is the same as the presampling interval. To configure the presampling interval, use the ifstats sample-interval command.
telemetry
3.     Create a subscription and enter subscription view.
subscription subscription-name
4.     (Optional.) Specify a transport protocol for the device to send packets to collectors.
protocol { grpc | udp }
By default, the device uses gRPC (TCP) as the transport protocol to send packets to collectors.
5.     (Optional.) Set the DSCP value of packets sent to collectors.
dscp dscp-value
By default, the DSCP value of packets sent to collectors is 0.
A greater DSCP value represents a higher priority.
6.     (Optional.) Specify the source IP address for packets sent to collectors.
source-address { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
By default, the device uses the primary IP address of the output interface for the route to the collectors as the source address.
Changing the source address causes the device to reconnect to the gRPC server.
7.     (Optional.) Specify the encoding format for pushed data.
encoding { gpb | json }
By default, the device uses the JSON format to encode pushed data.
The device can use the GPB format to encode pushed data only when it uses three-layer telemetry data models to push data.
8.     (Optional.) Enable per-row time-stamping for JSON-encoded subscription data.
json row-timestamp enable
By default, the device time-stamps JSON-encoded subscription data on a per-message basis.
9.     Specify a sensor group.
sensor-group group-name [ sample-interval [ msec ] interval ]
10.     Specify a destination group.
Before a sensor group specified for a subscription periodically samples subscribed interfaces, the device periodically presamples the subscribed interfaces and directly reports the presampling data to the sensor group.
You can use this feature to configure the presampling interval and the maximum number of interfaces in each presampling.
·     If the gRPC transport protocol is specified:
The device performs multiple presamplings within an actual gRPC sampling interval. It calculates the number of interfaces in each presampling by using the following formula:
Number of interfaces in each presampling = (subscribed interface count + (actual gRPC sampling interval / presampling interval) – 1) / (actual gRPC sampling interval / presampling interval).
The actual gRPC sampling interval depends on the data sampling interval (sample-interval) configured by using the sensor-group command.
¡     If the data sampling interval is less than 1800s, the actual gRPC sampling interval can be 100ms, 1s, 5s, 10s, 30s, 60s, 180s, 300s, 900s, or 1800s. The actual gRPC sampling interval is rounded up to the nearest value that exceeds the data sampling interval. For example, if the data sampling interval is 10ms, the actual gRPC sampling interval is 100ms. If the data sampling interval is 2s, the actual sampling interval is 5s. If subscribed interface count to the maximum number of interfaces in each presampling is greater than actual gRPC sampling interval to presampling interval, the actual gRPC sampling interval is rounded up to the next nearest value that exceeds the data sampling interval.
¡     If the data sampling interval is equal to or greater than 1800s, the actual gRPC sampling interval equals the data sampling interval.
The number of interfaces in each presampling cannot be fewer than 10. If it is fewer than 10, the device presamples 10 interfaces in each presampling. If the result of the formula (actual gRPC sampling interval / presampling interval) × the number of interfaces in each presampling might is greater than the subscribed interface count, presampling is complete in advance within an actual gRPC sampling interval. The device performs another presampling once the actual gRPC sampling interval expires.
·     If the UDP transport protocol is specified:
The device presamples the subscribed interfaces only once. The number of interfaces in the presampling does not exceed the maximum number of interfaces in each presampling.
If the data sampling interval is less than the presampling interval, data is collected at the presampling interval.
You must specify the udp keyword if UDP is specified as the transport protocol for the device to send packets to collectors by using the protocol command. If gRPC is specified as the transport protocol for the device to send packets to collectors, do not specify the udp keyword.
The value for the port-max-number number option must be greater than the number of subscribed interfaces on each slot.
2.     Configure interface presampling.
ifstats sample-interval [ udp ] interval port-max-number number
The default setting varies by device model.
To identify issues with gRPC in dial-out mode, enable gRPC data collection logging in dial-out mode.
This feature generates gRPC data collection logs in dial-out mode and sends them to the information center.
2.     Enable gRPC logging in dial-out mode.
grpc log dial-out { all | { event | sample }* }
By default, gRPC logging is disabled in dial-out mode.
Display gRPC information.
display grpc [ verbose ]
These configuration examples describe only CLI configuration tasks on the device. The collectors need to run an extra application. For information about collector-side application development, see "Protocol buffer code."
As shown in Figure 4, configure the gRPC dial-in mode on the device so the device acts as the gRPC server and the gRPC client can subscribe to LLDP events on the device.
Figure 4 Network diagram
1.     Assign IP addresses to interfaces on the gRPC server and client and configure routes. Make sure the server and client can reach each other.
2.     Configure the device as the gRPC server:
# Enable the gRPC service.
[Device] grpc enable
# Create a local user named test. Set a password and assign the network-admin user role and HTTPS service to the user.
[Device] local-user test
[Device-luser-manage-test] password simple 123456TESTplat&!
[Device-luser-manage-test] authorization-attribute user-role network-admin
[Device-luser-manage-test] service-type https
[Device-luser-manage-test] quit
3.     Configure the gRPC client.
a.     Prepare a PC and install the gRPC environment on the PC. For more information, see the user guide for the gRPC environment.
b.     Obtain the H3C proto definition file and uses the protocol buffer compiler to generate code of a specific language, for example, Java, Python, C/C++, or Go.
c.     Create a client application to call the generated code.
d.     Start the application to log in to the gRPC server.
When an LLDP event occurs on the gRPC server, verify that the gRPC client receives the event.
As shown in Figure 5, the device acts as a gRPC client and connects to the telemetry data collector (a gRPC server). The collector receives data on port 50050.
Configure the device to operate in dial-out mode to push NetStream4 module event data to the collector.
Figure 5 Network diagram
When you execute the sensor-group command in subscription view to specify a sensor group that contains event-triggered sensor paths for a subscription, do not use the sample-interval parameter to set a data sampling interval.
An event-triggered sensor path typically contains a string of event in its path name.
# Configure IP addresses as required so the device and the collector can reach each other. (Details not shown.)
# Enable gRPC.
# Create a sensor group named Test, and add sensor path netstream4/netstream4event to it.
[Device] telemetry
[Device-telemetry] sensor-group Test
[Device-telemetry-sensor-group-Test] sensor path netstream4/netstream4event
[Device-telemetry-sensor-group-Test] quit
# Create a destination group named collector1 and add a collector to the group. In this example, the collector receives data on port 50050 at IPv4 address 192.168.2.1.
[Device-telemetry] destination-group collector1
[Device-telemetry-destination-group-collector1] ipv4-address 192.168.2.1 port 50050
[Device-telemetry-destination-group-collector1] quit
# Configure a subscription named B to bind sensor group Test with destination group collector1.
[Device-telemetry] subscription B
[Device-telemetry-subscription-B] sensor-group Test
[Device-telemetry-subscription-B] destination-group collector1
[Device-telemetry-subscription-B] quit
Access the collector and verify that the collector can receive the NetStream4 module event data pushed by the device. (Details not shown.)
As shown in Figure 6, the device is connected to a collector. The collector uses port 50050.
Configure gRPC dial-out mode on the device so the device pushes the device capability information of its interface module to the collector at 10-second intervals.
Figure 6 Network diagram
# Create a sensor group named test, and add sensor path ifmgr/devicecapabilities/.
[Device] telemetry
[Device-telemetry] sensor-group test
[Device-telemetry-sensor-group-test] sensor path ifmgr/devicecapabilities/
[Device-telemetry-sensor-group-test] quit
# Create a destination group named collector1. Specify a collector that uses IPv4 address 192.168.2.1 and port number 50050.
# Configure a subscription named A to bind sensor group test with destination group collector1. Set the sampling interval to 10 seconds.
[Device-telemetry] subscription A
[Device-telemetry-subscription-A] sensor-group test sample-interval 10
[Device-telemetry-subscription-A] destination-group collector1
[Device-telemetry-subscription-A] quit
# Verify that the collector receives the device capability information of the interface module from the device at 10-second intervals. (Details not shown.)
Google Protocol Buffers provide a flexible mechanism for serializing structured data. Different from XML code and JSON code, the protocol buffer code is binary and provides higher performance.
Table 2 compares a protocol buffer code format example and the corresponding JSON code format example.
Table 2 Protocol buffer and JSON code format examples
Protocol buffer code format example
Corresponding JSON code format example
1:“H3C”
2:“H3C”
3:“H3C device_test”
4:“Syslog/LogBuffer”
5:"notification": {
"Syslog": {
"LogBuffer": {
"BufferSize": 512,
"BufferSizeLimit": 1024,
"DroppedLogsCount": 0,
"LogsCount": 100,
"LogsCountPerSeverity": {
"Alert": 0,
"Critical": 1,
"Debug": 0,
"Emergency": 0,
"Error": 3,
"Informational": 80,
"Notice": 15,
"Warning": 1
"OverwrittenLogsCount": 0,
"State": "enable"
"Timestamp": "1527206160022"
"producerName": "H3C",
"deviceName": "H3C",
"deviceModel": "H3C device_test",
"sensorPath": "Syslog/LogBuffer",
"jsonData": {
"notification": {
"Syslog": {
"LogBuffer": {
"BufferSize": 512,
"LogsCount": 100,
"Alert": 0,
"Critical": 1,
"Debug": 0,
"Emergency": 0,
"Error": 3,
"Notice": 15,
"Warning": 1
"State": "enable"
You can define data structures in a proto definition file. Then, you can compile the file with utility protoc to generate code in a programing language such as Java and C++. Using the generated code, you can develop an application for a collector to communicate with the device.
H3C provides proto definition files for both dial-in mode and dial-out mode.
Dial-in mode supports the following public proto definition files:
·     grpc_service.proto—Defines the public RPC methods in dial-in mode.
·     gnmi.proto—Defines the public RPC methods for gNMI operations.
·     gnmi_ext.proto—Defines the expanded message structures required by file gnmi.proto.
Files gnmi.proto and gnmi_ext.proto are from Google. For information about the download paths, see "Obtaining proto definition files."
The grpc_service.proto file is provided by H3C. The following are the content of the file:
syntax = "proto2";
package grpc_service;
message GetJsonReply { // Reply to the Get method
    required string result = 1;
message SubscribeReply { // Subscription result
message ConfigReply {   // Configuration result
message ReportEvent {   // Subscribed event
    required string token_id = 1;   // Login token_id
    required string stream_name = 2; // Event stream name
    required string event_name = 3;     // Event name
    required string json_text = 4;  // Subscription result, a JSON string
message GetReportRequest{ // Obtains the event subscription result
    required string token_id = 1; // Returns the token_id upon a successful login
message LoginRequest {  // Login request parameters
    required string user_name = 1; // Username
    required string password = 2; // Password
message LoginReply {  // Reply to a login request
message LogoutRequest { // Logout parameter
    required string token_id = 1; // token_id
message LogoutReply { // Reply to a logout request
    required string result = 1; // Logout result
message SubscribeRequest { // Event stream name
    required string stream_name = 1;
message CliConfigArgs { // Sends a configuration command and the parameters to the device
    required int64 ReqId = 1; // Request ID of the command
    required string cli = 2;  // Command line of the configuration command
message CliConfigReply { // Reply to a configuration command execution request
    required int64 ResReqId = 1;  // Request ID, which corresponds to that in CliConfigArgs
    required string output = 2; // Output from the command
    required string errors = 3; // Command execution result
message DisplayCmdArgs { // Sends a display command and the parameters to the device
    required string cli = 2;  // Command line of the display command
message DisplayCmdReply { // Reply to a display command execution request
    required int64 ResReqId = 1;  // Request ID, which corresponds to that in DisplayCmdArgs
service GrpcService {   // gRPC methods
    rpc Login (LoginRequest) returns (LoginReply) {}    // Login method
    rpc Logout (LogoutRequest) returns (LogoutReply) {}     // Logout method
    rpc SubscribeByStreamName (SubscribeRequest) returns (SubscribeReply) {} // Event subscription method
    rpc GetEventReport (GetReportRequest) returns (stream ReportEvent) {} // Method for obtaining the subscribed event
    rpc CliConfig (CliConfigArgs)  returns (stream CliConfigReply) {} // Method for executing a configuration command and returning the execution result
    rpc DisplayCmdTextOutput(DisplayCmdArgs)  returns(stream DisplayCmdReply) {} // Method for executing a display command and returning the execution result
Proto definition files for service modules
The dial-in mode supports proto definition files for the following service modules: Device, Ifmgr, IPFW, LLDP, and Syslog.
The following are the content of the Device.proto file, which defines the RPC methods for the Device module:
syntax = "proto2";
import "grpc_service.proto";
package  device;
message DeviceBase { // Structure for obtaining basic device information
    optional string HostName = 1;   // Device name
    optional string HostOid = 2;    // sysoid
    optional uint32 MaxChassisNum = 3; // Maximum number of chassis
    optional uint32 MaxSlotNum = 4;     // Maximum number of slots
    optional string HostDescription = 5; // Device description
message DevicePhysicalEntities {    // Structure for obtaining physical entity information of the device
    message Entity {
        optional uint32 PhysicalIndex = 1; // Entity index
        optional string VendorType = 2;         // Vendor type
        optional uint32 EntityClass = 3;        // Entity class
        optional string SoftwareRev = 4;        // Software version
        optional string SerialNumber = 5;   // Serial number
        optional string Model = 6;          // Model
    repeated Entity entity = 1;
service DeviceService { // RPC methods
    rpc GetJsonDeviceBase(DeviceBase) returns (grpc_service.GetJsonReply) {} // Method for obtaining basic device information
    rpc GetJsonDevicePhysicalEntities(DevicePhysicalEntities) returns (grpc_service.GetJsonReply) {}    // Method for obtaining physical entity information of the device
Dial-out mode supports the following public proto definition files:
·     grpc_dialout.proto—Defines the public RPC methods in dial-out mode.
·     grpc_dialout_v3.proto—Defines the public RPC methods for three-layer telemetry data models in dial-out mode.
·     telemetry.proto—Defines data sampling parameters for three-layer telemetry data models in dial-out mode.
The following are the content of the grpc_dialout.proto file:
syntax = "proto2";
package grpc_dialout;
message DeviceInfo{     // Pushed device information
    required string producerName = 1; //Vendor name
    required string deviceName = 2;      //Device name
    required string deviceModel = 3;  //Device model
    optional string deviceIpAddr = 4; //Device IP
    optional string eventType = 5; //Type of the sensor path
    optional string deviceSerialNumber = 6; //Serial number of the device
message DialoutMsg{   // Format of the pushed data
    required DeviceInfo deviceMsg = 1; // Device information described by DeviceInfo
    required string sensorPath = 2; // Sensor path, which corresponds to xpath in NETCONF
    required string jsonData = 3;  // Collected data, a JSON string
message DialoutResponse{  // Response from the collector. Reserved. The value is not processed.
    required string response = 1;
service GRPCDialout {  // Data push method
    rpc Dialout(stream DialoutMsg) returns (DialoutResponse);
The following is the content of the grpc_dialout_v3.proto file:
syntax = "proto3";
package grpc_dialout_v3;
message DialoutV3Args{
    int64 ReqId = 1;// Request ID
    bytes data = 2;// Carried data
    string errors = 3;// Error description.
    int32 totalSize = 4;// Total size of the message when fragmented. Value 0 indicates that the message is not fragmented.
service gRPCDialoutV3{
    rpc DialoutV3(stream DialoutV3Args) returns (stream DialoutV3Args) {};
The following is the content of the telemetry.proto file:
syntax = "proto3";
package telemetry;
message Telemetry {
    string producer_name = 1;// Vendor name
    string node_id_str = 2;// Device name
    string product_name = 3;// Product name
    string subscription_id_str = 15;// Subscription name
    string sensor_path = 16;// Sensor path
    uint64 collection_id = 17;// Sampling ID
    uint64 collection_start_time = 18;// Start time of the sampling period
    uint64 msg_timestamp = 19;// Timestramp when this message was generated
    uint64 collection_end_time = 20;// End time of the sampling period
    uint32 current_period = 21;// Sampling accuracy
    string except_desc = 22;// Error description
    enum Encoding {
        Encoding_JSON = 0;// GPB encoding format
        Encoding_GPB = 1;// JSON encoding format
    Encoding encoding = 23;// Data encoding format
    string data_str = 24;// This field is valid only when a non-GPB encoding is used. If GPB encoding is used, this field is null.
    TelemetryGPBTable data_gpb = 25;// This filed indicates that the data carried is defined in TelemetryGPBTable.
message TelemetryGPBTable {
    repeated TelemetryRowGPB row = 1;// Array definition, which indicates that the data contains multiple TelemetryRowGPB structures.
message TelemetryRowGPB {
    uint64 timestamp = 1;// Timestramp of the current sampling instance
    bytes keys = 10;// Reserved field
    bytes content = 11;// Data carried by the sampling instance
If service data is in GPB format, the device must use the proto definition file for the service module to decode the data.
The dial-out mode supports proto definition files for the following service modules: Device, Ifmgr, Vlan, and Syslog.
For example, the oc_vlan_v3.proto file defines the RPC methods for the VLAN module, as follows:
syntax = "proto3";
package  vlans_v3;
message vlans {
    message Vlan {
        uint32 vlan_id = 1;
        message Config {
            uint32 vlan_id = 1;
            string name = 2;
            uint32 tpid = 3;
        Config config = 2;
    repeated Vlan vlan = 1;
To obtain files gnmi.proto and gnmi_ext.proto, use the following download paths:
·     https://github.com/openconfig/gnmi/tree/master/proto/gnmi/gnmi.proto
·     https://github.com/openconfig/gnmi/tree/master/proto/gnmi_ext/gnmi_ext.proto
To obtain other proto definition files, contact H3C Support.
Use a language (for example, C++) to develop a gRPC collector-side application on Linux to achieve the following goals:
·     Collect device data by using Get, gNMI Capabilities, gNMI Get, or gNMI Subscribe operations in dial-in mode or by using dial-out mode.
·     Send settings to the device by using gNMI Set or CLI operations in dial-in mode.
1.     Obtain proto definition files.
¡     For Get operations in dial-in mode, obtain the grpc_service.proto file and proto definition files for service modules.
¡     For gNMI operations in dial-in mode, obtain files grpc_service.proto, gnmi.proto, and gnmi_ext.proto.
¡     For CLI operations in dial-in mode, obtain the grpc_service.proto file.
¡     For dial-out mode, obtain the grpc_dialout.proto file.
2.     Obtain utility protoc from https://github.com/google/protobuf/releases.
3.     Obtain the protobuf plug-in for C++ (protobuf-cpp) from https://github.com/google/protobuf/releases.
Dial-in mode
# Copy the required proto definition files to the current directory, for example, grpc_service.proto and BufferMonitor.proto.
$protoc --plugin=./grpc_cpp_plugin  --grpc_out=. --cpp_out=. *.proto
Dial-out mode
# Copy proto definition file grpc_dialout.proto to the current directory.
$ protoc --plugin=./grpc_cpp_plugin  --grpc_out=.  --cpp_out=. *.proto
In dial-in mode, the application needs to provide the code to be run on the gRPC client.
The C++ code generated from the proto definition files already encapsulates the service classes. For the gRPC client to initiate RPC requests, you only need to call the RPC method in the application.
The application performs the following operations:
·     Log in to obtain the token_id.
·     Prepare parameters for the RPC method, use the service classes generated from the proto definition files to call the RPC method, and resolve the returned result.
·     Log out.
Using Get operations
Service classes GrpcService and BufferMonitorService are used in this example.
To develop the collector-side application:
1.     Create a GrpcServiceTest class.
# In the class, use the GrpcService::Stub class generated from grpc_service.proto. Implement login and logout with the Login and Logout methods generated from grpc_service.proto.
class GrpcServiceTest
public:
    /* Constructor functions */
   GrpcServiceTest(std::shared_ptr<Channel> channel): GrpcServiceStub(GrpcService::NewStub(channel))  {}
    /* Member functions */
    int Login(const std::string& username, const std::string& password);
   void Logout();
   void listen();
Status listen(const std::string& command);
    /* Member variable */
   std::string token;
private:
   std::unique_ptr<GrpcService::Stub> GrpcServiceStub;  // Use the GrpcService::Stub class generated from grpc_service.proto.
2.     Customize the Login method.
# Call the Login method of the GrpcService::Stub class to allow a user who provides the correct the username and password to log in.
int GrpcServiceTest::Login(const std::string& username, const std::string& password)
    LoginRequest request;   // Username and password.
    request.set_user_name(username);
    request.set_password(password);
LoginReply reply;
ClientContext context;
   // Call the Login method.
   Status status = GrpcServiceStub->Login(&context, request, &reply);
   if (status.ok())
       std::cout << "login ok!" << std::endl;
        std::cout <<"token id is :" << reply.token_id() << std::endl;
       token = reply.token_id();  // The login succeeds. The token is obtained.
        return 0;
    else{
       std::cout << status.error_code() << ": " << status.error_message()
                   << ". Login failed!" << std::endl;
        return -1;
3.     Initiate an RPC request to the device.
In this example, the application subscribes to interface packet drop events.
rpc SubscribePortQueDropEvent(PortQueDropEvent) returns (grpc_service.SubscribeReply) {}
4.     Create the BufMon_GrpcClient class to encapsulate the RPC method.
# Use the BufferMonitorService::Stub class generated from BufferMonitor.proto to call the RPC method.
class BufMon_GrpcClient
public:
    BufMon_GrpcClient(std::shared_ptr<Channel> channel): mStub(BufferMonitorService::NewStub(channel))
    std::string BufMon_Sub_AllEvent(std::string token);
    std::string BufMon_Sub_BoardEvent(std::string token);
    std::string BufMon_Sub_PortOverrunEvent(std::string token);
    std::string BufMon_Sub_PortDropEvent(std::string token);
    /* Get entries */
    std::string BufMon_Sub_GetStatistics(std::string token);
    std::string BufMon_Sub_GetGlobalCfg(std::string token);
    std::string BufMon_Sub_GetBoardCfg(std::string token);
    std::string BufMon_Sub_GetNodeQueCfg(std::string token);
    std::string BufMon_Sub_GetPortQueCfg(std::string token);
private:
   std::unique_ptr<BufferMonitorService::Stub> mStub; // Use the class generated from BufferMonitor.proto.
5.     Use std::string BufMon_Sub_PortDropEvent(std::string token) to implement interface packet drop event subscription.
std::string BufMon_GrpcClient::BufMon_Sub_PortDropEvent(std::string token)
    std::cout << "-------BufMon_Sub_PortDropEvent-------- " << std::endl;
   PortQueDropEvent stNodeEvent;
   PortQueDropEvent_PortQueDrop* pstParam = stNodeEvent.add_portquedrop();
    UINT uiIfIndex = 0;
    UINT uiQueIdx = 0;
    UINT uiAlarmType = 0;
    std::cout<<"Please input interface queue info : ifIndex queIdx alarmtype " << std::endl;
    cout<<"alarmtype : 1 for ingress; 2 for egress; 3 for port headroom"<<endl;
    std::cin>>uiIfIndex>>uiQueIdx>>uiAlarmType; // Set the subscription parameters and interface index.
    pstParam->set_ifindex(uiIfIndex);
    pstParam->set_queindex(uiQueIdx);
    pstParam->set_alarmtype(uiAlarmType);
   /* Token needs to be added to context */ // Set the token_id to be returned after a successful login
   std::string key = "token_id";
   std::string value = token;
   context.AddMetadata(key, value);
   SubscribeReply reply;
   Status status = mStub->SubscribePortQueDropEvent(&context,stNodeEvent,&reply); // Call the RPC method.
   return reply.result();
6.     Use a loop to listen to event reports.
# Implement this method in the GrpcServiceTest class.
void GrpcServiceTest::listen()
    GetReportRequest reportRequest;
    ReportEvent reportedEvent;
   /* Add the token to the request */
   reportRequest.set_token_id(token);
    std::unique_ptr< ClientReader< ReportEvent>> reader(GrpcServiceStub->GetEventReport(&context, reportRequest)); // Use GetEventReport (which is generated from grpc_service.proto) to obtain event information.
    std::string streamName;
    std::string eventName;
    std::string jsonText;
   std::string token;
    JsonFormatTool jsonTool;
   std::cout << "Listen to server for Event" << std::endl;
    while(reader->Read(&reportedEvent) ) // Read the received event report.
        streamName = reportedEvent.stream_name();
        eventName = reportedEvent.event_name();
        jsonText = reportedEvent.json_text();
        token = reportedEvent.token_id();
        std::cout << "/***********EVENT COME**************/" << std::endl;
        std::cout << "TOKEN: " << token << std::endl;
        std::cout << "StreamName: "<< streamName << std::endl;
        std::cout << "EventName: " << eventName << std::endl;
       std::cout << "JsonText without format: " << std::endl << jsonText << std::endl;
        std::cout << std::endl;
       std::cout << "JsonText Formated: " << jsonTool.formatJson(jsonText) << std::endl;
    Status status = reader->Finish();
    std::cout << "Status Message:" << status.error_message() << "ERROR code :" << status.error_code();
}  // Login and RPC request finished.
7.     To log out, call the Logout method.
void GrpcServiceTest:: Logout ()
    LogoutRequest request;
   request.set_token_id(token);
   LogoutReply reply;
   Status status = mStub->Logout(&context, request, &reply);
std::cout << "Logout! :" << reply.result() << std::endl;
Using gNMI Capabilities operations
See step 1 in "Using Get operations."
See step 2 in "Using Get operations."
rpc Capabilities(CapabilityRequest) returns (CapabilityResponse);
4.     Create the gnmi_client class to encapsulate the RPC method.
class gnmi_client
public:
   explicit gnmi_client(const std::string &address,const std::string &tokenId);
   bool TestCapabilities();
   bool TestGet();
   bool TestSet();
   bool TestSubscribePool();
   bool TestSubscribeOnce();
   bool TestSubscribeStream();
   bool TestSubscribeStreamWithAlias();
private:
   void PrintCapabilityResponse(const gnmi::CapabilityResponse &response);
   void PrintGetResponse(const gnmi::GetResponse &response);
   void PrintSubscribeResponse(const gnmi::SubscribeResponse &response);
   void PrintSubscribeRequest(const gnmi::SubscribeRequest &request);
   void PrintGetRequest(const gnmi::GetRequest &request);
   void PrintSetRequest(const gnmi::SetRequest &request);
   void FillGetRequest(gnmi::GetRequest &request);
   void FillSetRequest(gnmi::SetRequest &request);
   void FillSubscribeRequestByOnce(gnmi::SubscribeRequest &request);
   void FillSubscribeRequestByPool(gnmi::SubscribeRequest &request);
   void FillSubscribeRequestByStream(gnmi::SubscribeRequest &request);
   void FillSubscribePool(gnmi::SubscribeRequest &request);
   void FillSubscribeAlias(gnmi::SubscribeRequest &request);
private:
   std::unique_ptr<gnmi::gNMI::Stub> mStubGnmiService;
   std::string mTokenID;
5.     Use the TestCapabilities() method to obtain the capabilities.
bool gnmi_client::TestCapabilities()
   CapabilityRequest request;
   CapabilityResponse response;
  context.AddMetadata("token_id", mTokenID);
   std::cout << std::endl << "CapabilitiesRequest => " << std::endl;
   Status ret = mStubGnmiService->Capabilities(&context,request,&response);
   if( StatusCode::OK != ret.error_code() )
       cout << "TestCapabilities ErrorMessage:" << ret.error_message() << endl;
       return false;
   else
       PrintCapabilityResponse(response);
       return true;
6.     To log out, call the Logout method.
See step 7 in "Using Get operations."
Using gNMI Get operations
rpc Get(GetRequest) returns (GetResponse);
See step 4 in "Using gNMI Capabilities operations."
5.     Use the TestGet() method to obtain the Device/Base/HostName.
bool gnmi_client::TestGet()
  GetRequest request;
  FillGetRequest(request);
  PrintGetRequest(request);
  GetResponse response;
  Status ret = mStubGnmiService->Get(&context,request,&response);
    cout << "TestGet ErrorMessage:" << ret.error_message() << endl;
    return false;
  else
    PrintGetResponse(response);
    return true;
void gnmi_client::FillGetRequest(gnmi::GetRequest &request)
   auto prefix = request.mutable_prefix();
   auto pathelem01 = prefix->add_elem();
   pathelem01->set_name("Device");
   auto path1 = request.add_path();
   auto pathelem02 = path1->add_elem();
   pathelem02->set_name("Base");
   auto pathelem03 = path1->add_elem();
   pathelem03->set_name("HostName");
Using gNMI Set operations
This example uses the Device module.
rpc Set(SetRequest) returns (SetResponse)
4.     Create a gNMITest class to encapsulate the RPC method.
Use the gNMI::Stub class that is automatically created by gnmi.proto to call the RPC method.
class gNMITest
public:
gNMITest(std::shared_ptr<Channel> channel, const std::string tokenId ):
                                             mStubGrpcService(GrpcService::NewStub(channel)),
                                             mStubgNMIService(gNMI::NewStub(channel)),
                                             mTokenID(tokenId ){}
     SetResponse TestSetResponseInformation(SetRequest &request, const std::string tokenId);
/*---delete: Device/Base/HostName Restore the default for HostName -----------*/
SetResponse DeleteDeviceBaseHostName();    /* delete: Device Base/HostName*/
/* update: Device/Base/HostName, string_val("string_hostname") */
SetResponse UpdateDeviceBaseHostNameStringVal();
/* replace: Device/Base/HostName, string_val("string_hostname") */
REPL_001 SetResponse ReplaceDeviceBaseHostNameStringVal();
private:
std::unique_ptr<GrpcService::Stub> mStubGrpcService;
std::unique_ptr<gNMI::Stub> mStubgNMIService;
5.     Use customized methods to perform gNMI Set operations on service data, for example, on the Device module.
// Call the Set method to implement communication between client and server and get the response.
SetResponse gNMITest::TestSetResponseInformation(SetRequest &request, const std::string tokenId)
SetResponse reply;
context.AddMetadata("token_id", tokenId);
/* Call the Set method */
Status ret = mStubgNMIService->Set(&context,request,&reply);
if( StatusCode::OK != ret.error_code())
std::cout<<"error: "<<ret.error_message()<<std::endl;
return reply;
// Delete operation
SetResponse gNMITest:: DeleteDeviceBaseHostName ()     /* prefix == Device/Base */
SetRequest request;
/* SetRequest->prefix */
Path       *path01 = request.mutable_prefix();
PathElem   *pathelem01 = path01->add_elem();
PathElem   *pathelem02 = path01->add_elem();
/* SetRequest->delete */
Path       *path02 = request.add_delete_();
PathElem   *pathelem03 = path02->add_elem();
/* Gather response info. */
 return TestSetResponseInformation(request, mTokenID);
// Update operation
SetResponse gNMITest::UpdateDeviceBaseHostNameStringVal()
SetRequest request;
/* SetRequest->update */
Update     *update01 = request.add_update();
Path       *path02 = update01->mutable_path();
TypedValue *typevalue01 = update01->mutable_val();
typevalue01->set_string_val("string_hostname");
// Replace operation
SetResponse gNMITest::ReplaceDeviceBaseHostNameStringVal()
SetRequest request;
/* SetRequest->replace */
Update     *replace01 = request.add_replace();
Path       *path02 = replace01->mutable_path();
TypedValue *typevalue01 = replace01->mutable_val();
Using gNMI Subscribe operations
rpc Subscribe(stream SubscribeRequest) returns (stream SubscribeResponse);
5.     Create a subscribe method.
void gnmi_client::FillSubscribeRequestByOnce(gnmi::SubscribeRequest &request)
  auto subscribeList = request.mutable_subscribe();
  auto prefix = subscribeList->mutable_prefix();
  pathelem01->set_name("LLDP");
  auto subscribe = subscribeList->add_subscription();
  auto path = subscribe->mutable_path();
  auto pathelem02 = path->add_elem();
  pathelem02->set_name("NeighborEvent");
  auto pathelem03 = path->add_elem();
  pathelem03->set_name("Neighbor");
  (*pathelem03->mutable_key())["IfName"] = "xxx";
   subscribeList->set_mode(::gnmi::SubscriptionList_Mode_ONCE);
   subscribeList->set_encoding(::gnmi::JSON);
void gnmi_client::FillSubscribeRequestByPool(gnmi::SubscribeRequest &request)
   pathelem02->set_name("CPUs");
   pathelem03->set_name("CPU");
   auto pathelem04 = path->add_elem();
   pathelem04->set_name("CPUUsage");
   subscribeList->set_mode(::gnmi::SubscriptionList_Mode_POLL);
void gnmi_client::FillSubscribeRequestByStream(gnmi::SubscribeRequest &request)
    pathelem01->set_name("Diagnostic");
    pathelem02->set_name("CPUEvent");
    (*pathelem03->mutable_key())["Chassis#condition"] = "equal:1";
    subscribe->set_mode(::gnmi::ON_CHANGE);
    subscribe->set_sample_interval(1000);
    subscribe->set_suppress_redundant(false);
    subscribe->set_heartbeat_interval(1000);
    subscribeList->set_mode(::gnmi::SubscriptionList_Mode_STREAM);
void gnmi_client::FillSubscribeAlias(gnmi::SubscribeRequest &request)
   auto aliases = request.mutable_aliases();
   auto alias = aliases->add_alias();
   auto path = alias->mutable_path();
   auto pathelem01 = path->add_elem();
   alias->set_alias("#cpu_usage");
Using CLI operations
This example uses the CliConfig method in file grpc_service.proto.
4.     Use the GrpcServiceTest class to encapsulate the RPC method in the same way you do for Get operations.
5.     Use a customized method to support CliConfig operations.
// Make a thread to listen to the sever and get messages
Status GrpcServiceTest::listen(const std::string& command)
CliConfigArgs reportRequest;
CliConfigReply reportedEvent;
/* Add token to request */
reportRequest.set_reqid(12345678);
reportRequest.set_cli(command);
std::unique_ptr< ClientReader< CliConfigReply>> reader(mStub->CliConfig(&context, reportRequest));
std::string output;
int64 resreqid;
std::cout << "Command result" << std::endl;
while( reader->Read(&reportedEvent) )
streamName = reportedEvent.errors();
output = reportedEvent.output();
resreqid = reportedEvent.resreqid();
std::cout << "resreqid: "<< resreqid << std::endl;
std::cout << "errors: "<< streamName << std::endl;
std::cout << "output: \n"<< output << "\n"<< std::endl;
return status;
6.     Use a loop in the main function to wait for commands.
Use the GrpcServiceTest class.
int main(int argc, char *argv[])
const char *cmd;
unsigned int i = 0;
unsigned int cycle = 0;
if (4 == argc)
g_server_address = argv[1];
g_username = argv[2];
g_password = argv[3];
std::cout << "server_address: " << g_server_address <<std::endl;
std::cout << "username: " << g_username << " " << "password: " << g_password << std::endl;
auto channel = grpc::CreateChannel(g_server_address,grpc::InsecureChannelCredentials());
 // 1. Log in
GrpcServiceTest reporter(channel);
if(0 != reporter.Login(g_username, g_password))
           return 0;
       while(1)
       {// 2. Read a command and execute the command
               std::cout<<"\n\nPlease Input Command:\n";
               getline(std::cin,g_command);            // Read a command
               Status status = reporter.listen(g_command);
               if (!status.ok())
                   std::cout << status.error_code() << ": " << status.error_message() << std::endl;
                   break;
   std::cout<<"Complete exec Command."<<std::endl;
   return 0;
In dial-out mode, the application needs to provide the gRPC server code so the collector can receive and resolve data obtained from the device.
·     Inherit the automatically generated GRPCDialout::Service class, reload the automatically generated RPC Dialout service, and resolve the fields.
·     Register the RPC service with the specified listening port.
To develop the collector-side application in dial-out mode:
1.     Inherit and reload RPC service Dialout.
# Create class DialoutTest and inherit GRPCDialout::Service.
class DialoutTest final : public GRPCDialout::Service { // Reload the automatically generated abstract class.
    Status Dialout(ServerContext* context, ServerReader< DialoutMsg>* reader, DialoutResponse* response) override; // Implement RPC method Dialout.
2.     Register the DialoutTest service as a gRPC service and specify the listening port.
using grpc::Server;
using grpc::ServerBuilder;
std::string server_address("0.0.0.0:60057"); // Specify the address and port to listen to.
DialoutTest dialout_test; // Define the object declared in step 1.
ServerBuilder builder;
builder.AddListeningPort(server_address, grpc::InsecureServerCredentials());// Add the listening port.
builder.RegisterService(&dialout_test); // Register the service.
std::unique_ptr<Server> server(builder.BuildAndStart()); // Start the service.
server->Wait();
3.     Implement the Dialout method and data resolution.
Status DialoutTest::Dialout(ServerContext* context, ServerReader< DialoutMsg>* reader, DialoutResponse* response)
        DialoutMsg msg;
        while( reader->Read(&msg))
            const DeviceInfo &device_msg = msg.devicemsg();
            std::cout<< "Producer-Name: " << device_msg.producername() << std::endl;
            std::cout<< "Device-Name: " << device_msg.devicename() << std::endl;
            std::cout<< "Device-Model: " << device_msg.devicemodel() << std::endl;
            std::cout<<"Sensor-Path: " << msg.sensorpath()<<std::endl;
            std::cout<<"Json-Data: " << msg.jsondata()<<std::endl;
            std::cout<<std::endl;
        response->set_response("test");
        return Status::OK;
4.     After obtaining the DialoutMsg object (generated from the proto definition file) through the Read method, you can call the method to obtain the field values.
gNMI operations are intended for data tables and event tables.
·     Some data tables are periodically reported and some data tables are reported only when triggered.
·     All event tables are reported only when triggered.
Methods for adding columns in gNMI operations
Table 3 describes the methods for adding columns in gNMI operations.
Table 3 Methods for adding columns in gNMI operations
Request description
Sample request
Sample client-side code
Set a column of the key.
For example:
ifTypeExt=colvalue
path:
    elem:
     key:
        value:"colvalue"
  pathelem01->set_name("Interface");
  (*pathelem01->mutable_key())["ifTypeExt"] = "colvalue";
Set an attribute for a column of the key.
For example, set the attr attribute of ifTypeExt:
attr=attrvalue
path:
    elem:
     key:
        value:"attrvalue"
  (*pathelem01->mutable_key())["ifTypeExt#attr"] = "attrvalue";
Set a column in a group of the key.
For example, set the Upper column of the Broadcast group:
Upper=colvalue
path:
    elem:
     key:
        value:"colvalue"
  (*pathelem01->mutable_key())["Broadcast:Upper"] = "colvalue";
Set an attribute for a column in a group of the key.
For example, set the attr attribute of the Upper column of the Broadcast group:
attr=attrvalue
path:
    elem:
     key:
        value:"attrvalue"
  (*pathelem01->mutable_key())["Broadcast:Upper#attr"] = "attrvalue";
Set an attribute of a column through the key:
For example, set the attr attribute of Interface:
attr=attrvalue
path:
    elem:
     key:
        value:"attrvalue"
  (*pathelem01->mutable_key())["#attr"] = "attrvalue";
Set a column or column attribute in JSON:
For example:
Set Upper to colvalue and set the attr attribute of Upper to attrvalue.
 "Upper": {
  "#text": "colvalue",
  "@#attr": "attrvalue"
 "Upper": {
The YANG files for different YANG models might have a top-level node with the same name. To specify the top-level node in the YANG file for a particular YANG model, add the YANG model name before the top-level node name. If you do not add the YANG model name, the top-level node in the first YANG file is specified.
For example, add oc-if before node interfaces to specify the interfaces node in the YANG file for OpenConfig.
path:
    elem:
  pathelem01->set_name("oc-if:interfaces");
gNMI Get operation attributes
gNMI Get operations support the following attributes:
·     regExp—Regular expression.
To implement a complex filtering with characters, you can add a regExp attribute for a specific column.
The following example obtains the interface descriptions that contain only characters in upper case:
 pathelem01->set_name("Ifmgr");
 pathelem02->set_name("Interfaces");
 pathelem03->set_name("Interface");
 auto pathelem04 = path1->add_elem();
 pathelem04->set_name("Description");
 (*pathelem04->mutable_key())["#regExp"] = "^[A-Z]*$";
·     match—Conditional match.
Table 4 describes the conditional match operators.
Table 4 Conditional match operators
Operation
Operator
Greater than
match="more:value"
Greater than the specified value. The supported data types include date, digit, and character string.
Less than
match="less:value"
Less than the specified value. The supported data types include date, digit, and character string.
Not less than
match="notLess:value"
Not less than the specified value. The supported data types include date, digit, and character string.
Not greater than
match="notMore:value"
Not greater than the specified value. The supported data types include date, digit, and character string.
Equal to
match="equal:value"
Equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL.
Not equal to
match="notEqual:value"
Not equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL.
Include
match="include:string"
Includes the specified string. The supported data types include only character string.
Not include
match="exclude:string"
Excludes the specified string. The supported data types include only character string.
Start with
match="startWith:string"
Starts with the specified string. The supported data types include character string and OID.
End with
match="endWith:string"
Ends with the specified string. The supported data types include only character string.
The following example obtains extension information about the entity whose CPU usage is greater than 50%:
 pathelem02->set_name("ExtPhysicalEntities");
 pathelem03->set_name("Entity");
 pathelem04->set_name("CpuUsage");
 (*pathelem04->mutable_key())["#match"] = "more:50";
·     valuetype—Attribute value type.
When obtaining interface information, the device cannot identify whether an integer value for the IfIndex or vrfindex column represents an interface name or index. To resolve the issue, you can use the valuetype attribute to specify the value type.
The valuetype attribute has the following values:
Value
name
The column is carrying a name.
index
The column is carrying an index.
auto
Default value. The device uses the value of the column as a name for interface matching. If no match is found, the device uses the value as an index for interface matching.
The following example sets the valuetype attribute to index and set the index to 1 for IfIndex:
 pathelem01->set_name("VLAN");
 pathelem02->set_name("TrunkInterfaces");
(*pathelem03->mutable_key())["IfIndex"] = "1";
(*pathelem03->mutable_key())["IfIndex#valuetype"] = "index";
·     count—Specifies the data entry quantity.
The example sets the count attribute:
 pathelem01->set_name("Syslog");
 pathelem02->set_name("Logs");
(*pathelem03->mutable_key())["count"] = "5";
 pathelem03->set_name("Log");
(*pathelem03->mutable_key())["Index"] = "10";
·     Value filtering
You can specify a value for a column in a table to implement full match filtering. If you specify values for multiple columns, the system returns the data that matches all the specified values.
The following example obtains information about interface whose IfIndex is 1.
gNMI Set operation attributes
gNMI Set operations support the following attributes:
·     incremental—Adds configuration data to a column without affecting the original data. This attribute applies to a list column such as the vlan permitlist column.
This example adds VLANs 1 through 10 to an untagged VLAN list that has untagged VLANs 12 through 15.
pathelem02->set_name("HybridInterfaces");
Update *Update01 = request.add_update();
Path       *path02 = Update01->mutable_path();
(*pathelem03->mutable_key())["IfName"] = "262";
(*pathelem03->mutable_key())["UntaggedVlanList#incremental"] = "true";
(*pathelem03->mutable_key())["UntaggedVlanList"] = "1-10";
When configuring an interface, the device cannot identify whether an integer value for the IfIndex or vrfindex column represents an interface name or index. To resolve the issue, you can use the valuetype attribute to specify the value type.
Value
name
index
auto
   PathElem    *pathelem04 = path02->add_elem();
   pathelem04->set_name("Interface ");
(*pathelem04->mutable_key())["IfIndex"] = "1";
(*pathelem04->mutable_key())["IfIndex#valuetype"] = "index";
gNMI Subscribe operation attributes
gNMI Subscribe operations support the following attributes:
·     All gNMI Get operation attributes. See "gNMI Get operation attributes."
These attributes are used for subscription to periodically reported data tables.
·     condition—Data filtering condition.
These attributes are used for event table subscription. Values for this attribute are as follows:
¡     more—Greater than.
¡     less—Less than.
¡     notLess—Not less than.
¡     notMore—Not greater than.
¡     equal—Equal to.
¡     notEqual—Not equal to.
¡     include—Include.
¡     exclude—Not include.
¡     startWith—Start with.
¡     endWith—End with.
The following example monitors LLDP events:
  (*pathelem03->mutable_key())["IfName"] = "Ten-GigabitEthernet3/0/1";
  (*pathelem03->mutable_key())["IfName#condition"] = "equal";
This attribute is used for data table subscription.
The matching object can be a fixed value or another column. The latter supports only data tables that are reported only when triggered.
Table 4 describes the conditional match operators for matching a fixed value. Attribute values for matching another column are as follows:
¡     refMore—Greater than.
¡     refLess—Less than.
¡     refNotLess—Not less than.
¡     refNotMore—Not greater than.
¡     refEqual—Equal to.
¡     refNotEqual—Not equal to.
In the following example, a report is triggered only if the current-usage column has a greater value than the alarm-threshold column:
  pathelem02->set_name("queue");
  pathelem03->set_name("state");
  (*pathelem03->mutable_key())["current-usage#match"] = "refMore:alarm-threshold";
·     select—Reports certain columns in a data table that is reported only when triggered.
The following example reports only the current-usage column and the available-usage column:
  (*pathelem03->mutable_key())["current-usage#select"] = "";
  (*pathelem03->mutable_key())["available-usage#select"] = "";
