- 10-Segment Routing Configuration Guide
- 01-SR-MPLS configuration
- 02-SR-MPLS TE policy configuration
- 03-SRv6 configuration
- 04-SRv6 TE policy configuration
- 05-SRv6 VPN overview
- 06-IP L3VPN over SRv6 configuration
- 07-EVPN L3VPN over SRv6 configuration
- 08-EVPN VPWS over SRv6 configuration
- 09-EVPN VPLS over SRv6 configuration
- 10-Public network IP over SRv6 configuration
- 11-SRv6 OAM configuration
- 12-SRv6 network slicing configuration
- 13-SRv6 service chain configuration
02-SR-MPLS TE policy configuration | 644.38 KB |
Configuring SR-MPLS TE policies
SR-MPLS TE policy routing procedure
SR-MPLS TE policy forwarding procedure
Traffic steering to an SR-MPLS TE policy
SR-MPLS TE policy association with SBFD
MP-BGP extension for SR-MPLS TE policy-based routing
SR-MPLS TE policy configuration tasks at a glance
Configuring SR-MPLS TE policy attributes
Shutting down an SR-MPLS TE policy
Configuring a candidate path and a SID list for the path
Enabling the device to distribute SR-MPLS TE policy path information to BGP-LS
Configuring BGP to advertise BGP IPv4 SR policy routes
Restrictions and guidelines for BGP IPv4 SR policy routes advertisement
Enabling BGP to advertise BGP IPv4 SR policy routes
Configuring BGP to redistribute routes from the SR-MPLS TE policy
Advertising BGP IPv4 SR policy routes to EBGP peers
Filtering BGP IPv4 SR policy routes by router ID
Enabling validity check for BGP IPv4 SR policy routes
Configuring BGP to control BGP IPv4 SR policy route selection and advertisement
Steering traffic to an SR-MPLS TE policy
Configuring the traffic steering mode
Configuring color-based traffic steering
Configuring tunnel policy-based traffic steering
Configuring DSCP-based traffic steering
Configuring static route-based traffic steering
Configuring QoS policy-based traffic steering
Configuring Flowspec rule-based traffic steering
Enabling SBFD for SR-MPLS TE policies
Enabling hot standby for SR-MPLS TE policies
Configuring path switchover and deletion delays for SR-MPLS TE policies
Setting the delay time for bringing up SR-MPLS TE policies
Configuring SR-MPLS TE policy CBTS
Enabling SR-MPLS TE policy logging
Enabling SNMP notifications for SR-MPLS TE policies
Configuring traffic forwarding statistics for SR-MPLS TE policies
Display and maintenance commands for SR-MPLS TE policies
SR-MPLS TE policy configuration examples
Example: Configuring SR-MPLS TE policy-based forwarding
Example: Configuring color-based traffic steering for IPv4 L3VPN over SR-MPLS TE Policy
About SR-MPLS TE policies
Segment Routing (SR) policies enable the device to flexibly steer traffic through an SR network.
SR-MPLS TE policies apply to scenarios where multiple paths exist between a source node and a destination node on an SR network.
Basic concepts
SR-MPLS TE policy identification
An SR-MPLS TE policy is identified by the following items:
· BSID—SID of the ingress node.
· Color—Color attribute for the forwarding path. You can use the color attribute to distinguish an SR-MPLS TE policy from other SR-MPLS TE policies that are configured for the same source and destination nodes.
· Endpoint—IP address of the destination node.
Candidate path
A candidate path is a forwarding path that an SR-MPLS TE policy can use to forward packets.
An SR-MPLS TE policy can have multiple candidate paths. Two SR-MPLS TE policies cannot share the same candidate path.
Preference
Candidate paths are uniquely identified by their preference values. An SR-MPLS TE policy chooses a candidate path from all its candidate paths based on the preference values.
Segment list
A segment list is a list of SIDs that indicates a packet forwarding subpath. Each SID identifies the segment for forwarding packets to the next hop along the subpath.
A segment list is also call a SID list.
A candidate path can have a single SID list or multiple SID lists that use different weight values.
Weight
A SID list can have a weight value. After an SR-MPLS TE policy chooses a candidate path with multiple SID lists, the traffic will be load shared among the subpaths based on weight values.
SR-MPLS TE policy tunnel
An SR-MPLS TE policy tunnel is a virtual point-to-point connection between the node deployed with the SR-MPLS TE policy and the destination node of the SR-MPLS TE policy. The tunnel is automatically created upon SR-MPLS TE policy creation. SR-MPLS TE policy tunnels use SRLSPs.
SR-MPLS TE policy group
An SR-MPLS TE policy group is a collection of SR-MPLS TE policies. You can add SR-MPLS TE policies to an SR-MPLS TE policy group to implement SR-MPLS TE policy based forwarding according to DSCP values of packets.
SR-MPLS TE policy validity
The following describes the rules for identifying the validity of a SR-MPLS TE policy:
1. An SR-MPLS TE policy is valid only if it has valid candidate paths.
2. A candidate path is valid only if it has a valid SID list.
3. A SID list is valid if none of the following situations exists:
¡ The SID list is empty.
¡ The weight of the SID list is 0.
¡ An SR node cannot find the outgoing interface or next hop address based on the SID at the top of the SID list stack.
The following describes how the device chooses and uses an SR-MPLS TE policy to route a packet:
1. Upon receiving a packet whose stack top label is a BSID, the device identifies the valid SR-MPLS TE policies based on the BSID.
2. If multiple valid SR-MPLS TE policies are available, the device chooses the SR-MPLS TE policy that was first bound to the BSID.
3. If the chosen SR-MPLS TE policy has multiple candidate paths, the device chooses the candidate path with the greatest preference value.
4. If the chosen candidate path has multiple SID lists, the traffic will be load shared based on the weight values among the subpaths identified by the SID lists. The load of SID list x is equal to Weight x/(Weight 1 + Weight 2 + … + Weight n).
For example, Device A in Figure 1 first chooses a valid SR-MPLS TE policy by BSID. Then, the device chooses a candidate path by preference. The candidate path has two valid SID lists: SID list 1 and SID list 2. The weight value of SID list 1 is 20 and the weight value of SID list 2 is 80. One fifth of the traffic will be forwarded through the subpath identified by SID list 1. Four fifth of the traffic will be forwarded through the subpath identified by SID list 2.
Figure 1 SR-MPLS TE policy routing diagram
As shown in Figure 2, the SR-MPLS TE policy forwarding procedure is as follows:
1. After Device A receives a packet with the stack top label 16001, it searches its LFIB and determines that the label is a BSID. Then, Device A obtains the outgoing label stack and next hop (Device B), pops the BSID, pushes SID list {20002, 21003, 22004}, and forwards the packet to Device B. 20002 is the SID of the segment for a packet to travel from Device A to Device B. 21003 is the SID of the segment for a packet to travel from Device B to Device C. 22004 is the SID of the segment for a packet to travel from Device C to Device D.
2. After Device B receives the packet, it searches its LFIB by the incoming label and determines that the next hop is Device C. Then, Device B forwards the packet to Device C.
3. After Device C receives the packet, it searches its LFIB by the incoming label and determines that the next hop is Device D. Then, Device C forwards the packet to Device D.
4. After Device D receives the packet, it identifies whether the packet is carrying a label. If yes, Device D searches its LFIB to forward the packet. If not, Device D searches its IP FIB to forward the packet.
Figure 2 SR-MPLS TE policy forwarding diagram
You can steer traffic to an SR-MPLS TE policy for further forwarding based on the following criteria:
· BSID—Upon receiving a packet whose stack top label is a BSID, the device chooses an SR-MPLS TE policy based on the BSID to forward the packet.
· Color—The device searches for an SR-MPLS TE policy with the color value and endpoint that match the color extended community attribute and next hop of a BGP route. If a matching SR-MPLS TE policy is found, the device recurses the BGP route to that SR-MPLS TE policy. Then, packets matching the BGP route will be steered to the SR-MPLS TE policy for further forwarding.
· Tunnel policy—The device looks up the configured tunnel policies for a matching SR-MPLS TE policy, and then uses that policy as the public-network tunnel to forward packets that match the BGP route. Tunnel policies can be further divided into tunnel binding policies, preferred tunnel policies, and tunnel load sharing policies. If multiple of them are configured, their priorities are different during tunnel policy selection. For more information about the tunnel policy configuration, see tunnel policy configuration in MPLS Configuration Guide.
· DSCP value—Create color-to-DSCP mappings for an SR-MPLS TE policy group, and create a tunnel policy that binds a destination IP address to the SR-MPLS TE policy group. Upon receiving a packet with the specified destination IP address, the device searches for the SR-MPLS TE policy containing the color value mapped to the DSCP value of the packet. The device will use the SR-MPLS TE policy to forward the packet.
· Static route—Associate a static route with an SR-MPLS TE policy so that packets matching the static route will be steered to the SR-MPLS TE policy for forwarding.
· QoS policy—Redirect traffic to an SR-MPLS TE policy through a QoS policy. The device uses the SR-MPLS TE policy to forward the packets that match the traffic classes of the QoS policy. For more information about QoS policies, see the QoS configuration in ACL and QoS Configuration Guide.
· Flowspec—Redirect traffic to an SR-MPLS TE policy through a Flowspec rule. The device uses the SR-MPLS TE policy to forward the packets that match the Flowspec rule. For more information about Flowspec, see ACL and QoS Configuration Guide.
About SR-MPLS TE policy CBTS
SR-MPLS TE policy Class Based Tunnel Selection (CBTS) enables dynamic routing and forwarding of traffic with service class values over different SR-MPLS TE policy tunnels between the same tunnel headend and tailend. CBTS uses a dedicated tunnel for a certain class of service to implement differentiated forwarding for services.
How SR-MPLS TE policy CBTS works
SR-MPLS TE policy CBTS processes traffic mapped to a priority as follows:
1. Uses a traffic behavior to set a service class value for the traffic. For more information about setting a service class value in traffic behavior view, see the remark service-class command in ACL and QoS Command Reference.
2. Compares the service class value of the traffic with the service class values of the SR-MPLS TE policy tunnels and forwards the traffic to a matching tunnel.
SR-MPLS TE policy tunnel selection rules
SR-MPLS TE policy CBTS uses the following rules to select an SR-MPLS TE policy tunnel for the traffic to be forwarded:
· If an SR-MPLS TE policy tunnel has the same service class value as the traffic, CBTS uses this tunnel.
· If multiple SR-MPLS TE policy tunnels have the same service class value as the traffic, CBTS selects a tunnel based on the flow forwarding mode:
¡ If only one flow exists and flow-based forwarding is set, CBTS randomly selects a matching tunnel for packets of the same flow.
¡ If multiple flows exist or if only one flow exists but packet-based forwarding is set, CBTS uses all matching tunnels to load share the packets.
For more information about the flow identification and load sharing mode, see the ip load-sharing mode command in Layer 3—IP Services Command Reference.
· If the traffic does not match any SR-MPLS TE policy tunnels by service class value, CBTS randomly selects a tunnel from all SR-MPLS TE policy tunnels with the lowest forwarding priority. An SR-MPLS TE policy that has a smaller service class value has a lower forwarding priority. An SR-MPLS TE policy that is not configured with a service class value has the lowest priority.
SR-MPLS TE policy CBTS application scenario
As shown in Figure 3, CBTS selects SR-MPLS TE policy tunnels for traffic from Device A to Device B as follows:
· Uses SR-MPLS TE policy B to forward traffic with service class value 3.
· Uses SR-MPLS TE policy C to forward traffic with service class value 6.
· Uses SR-MPLS TE policy A to forward traffic with service class value 4.
· Uses SR-MPLS TE policy A to forward traffic with no service class value.
Figure 3 SR-MPLS TE policy CBTS application scenario
Typically, SR-MPLS TE policies use SBFD to maintain policy state and detect path failures. By default, SBFD detects the SID lists for only the candidate path of the highest preference in an SR-MPLS TE policy.
Figure 4 SR-MPLS TE policy association with SBFD
As shown in Figure 4, the SR-MPLS TE policy is associated with SBFD on source node Device A. The endpoint IP address is specified as the remote discriminator of the SBFD session. If the candidate path of the highest preference in the SR-MPLS TE policy has multiple SID lists, multiple SBFD sessions are established to detect the forwarding path for each SID list. All SBFD sessions use the same remote discriminator.
The SR-MPLS TE policy uses SBFD to detect the forwarding paths as follows:
1. The source node (Device A) sends an SBFD packet that encapsulates the target SID lists of the SR-MPLS TE policy.
2. Upon receiving the SBFD packet, the destination node (Device E) sends a response along the shortest path obtained through routing table lookup.
3. Upon receiving the SBFD response, Device A determines that the forwarding path for the SID list is available. If no response is received, Device A determines that the forwarding path is faulty. If all SID lists for the current candidate path are faulty, another candidate path takes over.
NOTE: Because SBFD responses are forwarded according to the IP routing table lookup, all SBFD sessions for the SR-MPLS TE policies that have the same source and destination nodes use the same path to send responses. A failure of the SBFD response path will cause all the SBFD sessions to be down and consequentially packets cannot be forwarded through the SR-MPLS TE policies. |
SR-MPLS TE policy hot standby
If an SR-MPLS TE policy has multiple valid candidate paths, the device chooses the candidate path with the greatest preference value. If the chosen path fails, the SR-MPLS TE policy must select another candidate path. During path reselection, packet loss might occur to affect service continuity.
The SR-TE hot standby feature can address this issue. This feature takes the candidate path with the greatest preference value as the primary path and that with the second greatest preference value as the standby path. As shown in Figure 5, when the forwarding paths corresponding to all SID lists of the primary path fails, the standby path immediately takes over to minimize service interruption.
Figure 5 SR-MPLS TE policy hot standby
You can configure both the hot standby and SBFD features for an SR-MPLS TE policy. Use SBFD to detect the availability of the primary and standby paths specified for hot standby. If all SID lists of the primary path become unavailable, the standby path takes over and a path recalculation is performed. The standby path becomes the new primary path, and a new standby path is selected. If both the primary and standby paths fail, the SR-MPLS TE policy will calculate new primary and standby paths.
To support SR-MPLS TE policies, MP-BGP increases the following definitions:
· BGP IPv4 SR policy address family.
· BGP IPv4 SR policy routes, which are also called SR-MPLS TE policy NLRI.
BGP IPv4 SR policy route information carries SR-MPLS TE policy settings, including the BSIDs, color values, endpoints, preference values, and weight values. After the device advertises BGP IPv4 SR policy routes to a peer, the peer can also use SR-MPLS TE policies to steer traffic.
The device supports the color extended community attribute. Upon receiving a packet that matches a route with the color extended community attribute, the device searches for an SR-MPLS TE policy that has the same color value as the route. If an SR-MPLS TE policy is found, the device forwards the packet based on the SR-MPLS TE policy. If not, the device uses the optimal route to forward the packet.
The color extended community attribute is in the format of 2-bit Color-Only flag:32-bit user-defined color value, for example, 10:3.
To configure an SR-MPLS TE policy, perform the following tasks:
1. Create an SR-MPLS TE policy and configure the settings:
a. Creating an SR-MPLS TE policy
b. Configuring SR-MPLS TE policy attributes
c. (Optional.) Shutting down an SR-MPLS TE policy
d. Configuring a candidate path and a SID list for the path
e. (Optional.) Enabling the device to distribute SR-MPLS TE policy path information to BGP-LS
2. (Optional.) Configuring BGP to advertise BGP IPv4 SR policy routes
a. Enabling BGP to advertise BGP IPv4 SR policy routes
b. Configuring BGP to redistribute routes from the
c. (Optional.) Advertising BGP IPv4 SR policy routes to EBGP peers
d. (Optional.) Filtering BGP IPv4 SR policy routes by router ID
e. (Optional.) Enabling validity check for BGP IPv4 SR policy routes
f. (Optional.) Configuring BGP to control BGP IPv4 SR policy route selection and advertisement
g. (Optional.) Maintaining BGP sessions
3. Steering traffic to an SR-MPLS TE policy
4. (Optional.) Configuring SR-MPLS TE policy high availability
¡ Enabling SBFD for SR-MPLS TE policies
¡ Enabling hot standby for SR-MPLS TE policies
¡ Configuring path switchover and deletion delays for SR-MPLS TE policies
¡ Setting the delay time for bringing up SR-MPLS TE policies
5. (Optional.) Configuring SR-MPLS TE policy CBTS
6. (Optional.) Maintaining SR-MPLS TE policies
¡ Enabling SR-MPLS TE policy logging
¡ Enabling SNMP notifications for SR-MPLS TE policies
¡ Configuring traffic forwarding statistics for SR-MPLS TE policies
1. Enter system view.
2. Enter segment routing view.
segment-routing
3. Enter SR TE view.
traffic-engineering
4. Create an SR-MPLS TE policy and enter its view.
policy policy-name
An SR-MPLS TE policy is identified by the following items: BSID, color, and endpoint. Upon receiving a packet whose stack top label is a BSID, the device chooses an SR-MPLS TE policy based on the BSID to forward the packet.
You can bind a BSID to the policy manually, or set only the color and endpoint attributes of the policy so the system automatically assigns a BSID to the policy. If you use both methods, the manually bound BSID takes effect.
If you configure an MPLS label as the BSID but the label is not in the range of the SRLB or is already used by a protocol, the configuration does not take effect. For more information about SRLB, see "Configuring SR-MPLS."
Different SR-MPLS TE policies cannot have the same color and endpoint address combination.
segment-routing
3. Enter the SR TE view.
traffic-engineering
4. Enter SR-MPLS TE policy view.
policy policy-name
5. Bind a BSID to the policy.
binding-sid mpls mpls-label
6. Set the color and endpoint attributes.
color color-value end-point ipv4 ipv4-address
If multiple SR-MPLS TE policies exist on the device, you can shut down unnecessary SR-MPLS TE policies to prevent them from affecting traffic forwarding.
segment-routing
traffic-engineering
policy policy-name
5. Shut down the SR-MPLS TE policy.
shutdown
By default, an SR-MPLS TE policy is not administratively shut down.
After you add nodes to a SID list, the system will sort the nodes in ascending order of node index.
segment-routing
traffic-engineering
4. Create a SID list and enter its view.
segment-list segment-list-name
5. Add a node to the SID list.
index index-number mpls label label-value
6. Return to system view.
7. Enter SR-MPLS TE policy view.
policy policy-name
8. Create and enter SR-MPLS TE policy candidate path view.
candidate-paths
9. Set the preference for a candidate path and enter candidate path preference view.
preference preference-value
By default, no candidate path preferences are set.
Each preference represents a candidate path.
10. Specify an explicit path for the candidate path.
explicit segment-list segment-list-name [ weight weight-value ]
A candidate path can have multiple SID lists.
This feature enables the device to distribute SR-MPLS TE policy candidate path information to BGP-LS. BGP-LS advertises the SR-MPLS TE policy candidate path information to meet application requirements.
Before you configure this feature, enable the device to exchange LS information with the related peer or peer group. For more information about the LS exchange capability, see the BGP LS configuration in Layer 3—IP Routing Configuration Guide.
After BGP-LS receives SR-MPLS TE policy routing information, it generates and advertises link state information to other BGP-LS peers. As a best practice, configure the mpls lsr-id command to specify the IPv4 TE router ID in link state information. You can identify different source nodes of SR-MPLS TE Policy by their IPv4 TE router IDs. If you do not configure the mpls lsr-id command, the IPv4 TE router ID in link state information will be 0.0.0.0. This route might be discarded when it is exchanged between devices from different vendors, which affects the normal advertisement of link state information.
2. Configure an LSR ID for the local LSR.
mpls lsr-id lsr-id
3. Enter segment routing view.
segment-routing
4. Enter SR TE view.
traffic-engineering
5. Enable the device to distribute SR-MPLS TE policy candidate path information to BGP-LS.
distribute bgp-ls
By default, the device cannot distribute SR-MPLS TE policy candidate path information to BGP-LS.
For more information about BGP commands, see Layer 3—IP Routing Commands.
2. Configure a global router ID.
router id router-id
By default, no global router ID is configured.
3. Enable a BGP instance and enter its view.
By default, BGP is disabled and no BGP instances exist.
4. Configure a peer.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-number as-number
5. Create the BGP IPv4 SR policy address family and enter its view.
address-family ipv4 sr-policy
6. Enable BGP to exchange SR-MPLS TE policy routing information with the peer or peer group.
By default, the device cannot use BGP to exchange SR-MPLS TE policy routing information with a peer or peer group.
After you configure BGP to redistribute BGP IPv4 SR policy routes, the system will redistribute the local BGP IPv4 SR policy routes to the BGP routing table and advertise the routes to IBGP peers. Then, the peers can forward traffic based on the SR-MPLS TE policy.
2. Enter BGP instance view.
3. Enter BGP IPv4 SR policy address family view.
4. Enable BGP to redistribute routes from the SR-MPLS TE policy.
import-route sr-policy
By default, BGP does not redistribute BGP IPv4 SR policy routes.
By default, only IBGP peers exchange BGP IPv4 SR policy routes. Perform this task to advertise BGP IPv4 SR policy routes to EBGP peers.
4. Advertise BGP IPv4 SR policy routes to EBGP peers.
advertise ebgp enable
By default, BGP IPv4 SR policy routes are not advertised to EBGP peers.
When a large number of BGP IPv4 SR policy routes exist in the network, perform this task to enable the device to process only specific BGP IPv4 SR policy routes.
The Router ID filtering feature enables the device to check the Route Target attribute of a received BGP IPv4 SR policy route.
· If the Route Target attribute contains the Router ID of the local device, the device accepts the route and generates an SR-MPLS TE policy accordingly.
· If the Route Target attribute does not contain the Router ID of the local device, the device processes the route as follows:
¡ If the bgp-rib-only keyword is not specified in the command for enabling Router ID filtering, the device drops the route.
¡ If the bgp-rib-only keyword is specified, the device accepts the route but does not generate the corresponding SR-MPLS TE policy.
When the controller advertises a BGP IPv4 SR policy route to the source node, the transit nodes between the controller and the source node only need to forward the BGP IPv4 SR policy route. They do not need to generate the SR-MPLS TE policy. In this case, you can execute the router-id filter bgp-rib-only command on the transit nodes. Then, when a transit node receives a BGP IPv4 SR policy route, it forwards the route even if the route's Route Target attribute does not contain the Router ID of the local device. Meanwhile, it does not generate an SR-MPLS TE policy in order to not affect packet forwarding.
To avoid incorrect route learning or filtering, configure a routing policy to add an appropriate RT attribute to BGP IPv4 SR policy routes before using this feature.
4. Enable BGP IPv4 SR policy route filtering by router ID.
router-id filter [ bgp-rib-only ]
By default, BGP IPv4 SR policy route filtering by router ID is disabled.
After validity check is enabled for BGP IPv4 SR policy routes, the device determines that a BGP IPv4 SR policy route is invalid and will not select the route if the route does not contain the RT extended community attribute (IPv4 address format) or the NO_ADVERTISE community attribute.
You can configure this feature on the RR in networks where the controller and the RR establish BGP peer relationship and the RR establishes BGP peer relationship with the source nodes of multiple SR-MPLS TE policies.
The RR checks whether the SR policy routes issued by the controller carry the IPv4 address format RT extended community attribute or the NO_ADVERTISE community attribute. If yes, the RR accepts the routes and reflects the routes that do not carry the NO_ADVERTISE attribute to the source nodes of the SR-MPLS TE policies.
On the source nodes, you can use the router-id filter command to enable BGP IPv4 SR policy route filtering by router ID. After a source node receives a BGP IPv4 SR policy route, it compares the local router ID with the IPv4 address in the RT attribute of the route. If they are the same, the source node accepts the route. If they are different, the source node drops the route.
4. Enable validity check for BGP IPv4 SR policy routes.
validation-check enable
By default, validity check for BGP IPv4 SR policy routes is disabled. The device does not check the validity of the BGP IPv4 SR policy routes received from the peer or peer group.
4. Specify the local router as the next hop for routes sent to a peer or peer group.
By default, BGP sets the local router as the next hop for all routes sent to an EBGP peer or peer group. BGP does not set the local router as the next hop for routes sent to an IBGP peer or peer group.
5. Set the default local preference.
By default, the default local preference is 100.
6. Allow a local AS number to exist in the AS_PATH attribute of routes from a peer or peer group, and to set the number of times the local AS number can appear.
By default, the local AS number is not allowed to exist in the AS_PATH attribute of routes from a peer or peer group.
7. Specify a preferred value for routes received from a peer or peer group.
By default, the preferred value is 0 for routes received from a peer or peer group.
8. Set the maximum number of routes that can be received from a peer or peer group.
By default, the number of routes that can be received from a peer or peer group is not limited.
9. Configure the device as a route reflector and specify a peer or peer group as a client.
By default, neither the route reflector nor the client is configured.
10. Enable the route reflector to change the attributes of routes to be reflected.
reflect change-path-attribute
By default, a route reflector cannot change the attributes of routes to be reflected.
11. Specify a prefix list to filter routes received from or advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name { export | import }
By default, no prefix list based filtering is configured.
12. Apply a routing policy to routes incoming from or outgoing to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
By default, no routing policy is applied to routes incoming from or outgoing to a peer or peer group.
13. Specify an AS path ACL to filter routes received from or advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
By default, no AS path ACL based route filtering is configured.
14. Advertise the COMMUNITY attribute to a peer or peer group.
By default, BGP does not advertise the COMMUNITY attribute to any peers or peer groups.
15. Advertise the extended community attribute to a peer or peer group.
By default, BGP does not advertise the extended community attribute to any peers or peer groups.
16. Advertise the Large Community attribute to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-large-community
By default, BGP does not advertise the Large Community attribute any peers or peer groups.
17. Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority [ preferred ]
By default, a peer or peer group does not have a high priority in BGP route selection.
For the priority of this command's configuration in BGP route selection, see BGP overview in Layer 3—IP Routing Configuration Guide.
18. Prefer routes with next hop addresses of the specified type during optimal route selection.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, BGP prefers routes with IPv4 next hop addresses.
19. Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
To maintain BGP sessions, execute the following commands in user view:
· Reset BGP sessions for the BGP IPv4 SR policy address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ mask-length ] | all | external | group group-name | internal } ipv4 sr-policy
· Manually soft-reset BGP sessions for the BGP IPv4 SR policy address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 sr-policy
This feature does not take effect in L2VPN networks.
3. Configure the SR-MPLS TE policy traffic steering mode.
sr-policy steering { disable | policy-based }
By default, traffic is steered to an SR-MPLS TE policy based on the color value.
To steer traffic to an SR-MPLS TE policy based on colors, you can configure a color extended community for routes that do not carry a color extended community in the following methods:
· Configure a routing policy to add a color value to routes.
· Configure a default color value.
The color value specified in the routing policy is preferred.
The default color value applies only to the VPN routes or public network routes learned from a remote PE.
The default color value is used only for SR-MPLS TE policy traffic steering. It does not used in route advertisement.
Configuring a routing policy to add a color value to routes
2. Enter routing policy node view.
3. Set the color extended community attribute for BGP routes.
apply extcommunity color color [ additive ]
By default, no BGP route attributes are configured.
4. Return to system view.
5. Enter BGP instance view.
6. Enter BGP IPv4 unicast address family view, BGP IPv6 unicast address family view, BGP VPNv4 address family view, or BGP VPNv6 address family view.
¡ Enter BGP IPv4 unicast address family view.
¡ Enter BGP IPv6 unicast address family view.
¡ Enter BGP VPNv4 address family view.
address-family vpnv4
¡ Enter BGP VPNv6 address family view.
address-family vpnv6
7. Specify a routing policy to filter routes advertised to or received from a peer or peer group.
By default, no routing policy is specified.
Configuring a default color value for VPN routes
2. Enter VPN instance view.
ip vpn-instance vpn-instance-name [ index vpn-index ]
3. Enter VPN instance IPv4 address family view or VPN instance IPv6 address family view.
¡ Enter VPN instance IPv4 address family view.
address-family ipv4
¡ Enter VPN instance IPv6 address family view.
address-family ipv6
4. Configure a default color value for L3VPN route recursion to an SR-MPLS TE policy.
default-color color-value [ evpn ]
By default, no default color is configured for L3VPN route recursion to an SR-MPLS TE policy.
Configuring a default color value for public network routes
2. Enter pubic instance view.
ip public-instance
3. Enter public instance IPv4 or IPv6 address family view.
¡ Enter public instance IPv4 address family view
address-family ipv4
¡ Enter public instance IPv6 address family view.
address-family ipv6
4. Configure a default color value for public network route recursion to an SR-MPLS TE policy.
By default, no default color value is configured for public network route recursion to an SR-MPLS TE policy.
2. Create a tunnel policy and enter tunnel policy view.
tunnel-policy tunnel-policy-name [ default ]
3. Configure the tunnel policy. Choose one option as needed:
¡ Configure an SR-MPLS TE policy tunnel as a preferred tunnel.
preferred-path sr-policy name sr-policy-name
By default, no preferred tunnels are configured.
¡ Configure a tunnel load sharing policy.
select-seq sr-policy load-balance-number number
By default, no tunnel load sharing policies are configured.
For more information about the commands, see MPLS Command Reference.
5. Enter VPN instance view, VPN instance IPv4 address family view, or VPN instance IPv6 address family view.
¡ Enter VPN instance view.
¡ Execute the following commands in sequence to enter VPN instance IPv4 address family view.
address-family ipv4
¡ Execute the following commands in sequence to enter VPN instance IPv6 address family view.
address-family ipv6
6. Apply a tunnel policy to the VPN instance.
tnl-policy tunnel-policy-name
By default, no tunnel policy is applied to the VPN instance.
For more information about this command, see MPLS Command Reference.
Each SR-MPLS TE policy in an SR-MPLS TE policy group has a different color attribute value. By configuring color-to-DSCP mappings for an SR-MPLS TE policy group, you associate DSCP values to SR-MPLS TE policies. This allows IP packets containing a specific DSCP value to be steered to the corresponding SR-MPLS TE policy for further forwarding.
You can map the color values of only valid SR-MPLS TE policies to DSCP values.
You can configure color-to-DSCP mappings separately for the IPv4 address family and IPv6 address family. For a specific address family, a DSCP value can be mapped to only one color value.
Use the color match dscp default command to specify the default SR-MPLS TE policy for an address family. If no SR-MPLS TE policy in an SR-MPLS TE policy group matches a specific DSCP value, the default SR-MPLS TE policy is used to forward packets containing the DSCP value. Only one default SR-MPLS TE policy can be specified for an address family.
When the device receives an IPv4 or IPv6 packet that does not match any color-to-DSCP mapping, the device selects a valid SR-MPLS TE policy for the packet in the following order:
1. The default SR-MPLS TE policy specified for the same address family as the packet.
2. The default SR-MPLS TE policy specified for the other address family.
3. The SR-MPLS TE policy mapped to the smallest DSCP value in the same address family as the packet.
4. The SR-MPLS TE policy mapped to the smallest DSCP value in the other address family.
segment-routing
3. Create and enter the SR TE view.
traffic-engineering
4. Create an SR-MPLS TE policy group and enter its view.
policy-group group-id
5. Configure the endpoint IP address for the SR-MPLS TE policy group.
By default, no endpoint IP address is configured for the SR-MPLS TE policy group.
The SR-MPLS TE policies added to the SR-MPLS TE policy group must use the same endpoint IP address as the SR-MPLS TE policy group.
6. Create color-to-DSCP mappings for the SR-MPLS TE policy group.
color color-value match dscp { ipv4 | ipv6 } dscp-value-list
color color-value match dscp { ipv4 | ipv6 } default
By default, no color-to-DSCP mappings are created for the SR-MPLS TE policy group.
DSCP-based traffic steering cannot function if no color-to-DSCP mappings are created.
7. Return to system view.
8. Create a tunnel policy and enter tunnel policy view.
9. Bind the SR-MPLS TE policy group to a destination IP address.
binding-destination dest-ip-address sr-policy group sr-policy-group-id [ ignore-destination-check ] [ down-switch ]
By default, a tunnel policy does not bind any SR-MPLS TE policy group to a destination IP address.
For more information about the command, see MPLS Command Reference.
After you configure this feature, execute the route-replicate command in public instance IPv4 address family view to replicate the routes of the specified VPN instance to the public network. The public network can then use the VPN routes to forward user traffic.
2. Configure a static route and associate it with an SR-MPLS TE policy.
Public network:
ip route-static dest-address { mask-length | mask } sr-policy policy-name [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } sr-policy policy-name [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured.
For more information about the commands, see Layer 3—IP Routing Command Reference.
To resolve congestion for certain IPv4 public network traffic, you can create a traffic class to identify traffic, and redirect matching traffic to an SR-MPLS TE policy based on endpoint and color. If traffic fails to match the redirection rule or the SR-MPLS TE policy fails, the traffic class becomes invalid, and the traffic is forwarded according to IPv4 routing table lookup.
For more information about QoS policy commands, see QoS commands in ACL and QoS Command Reference.
a. Enter system view.
b. Create a traffic class and enter traffic class view.
c. Configure a match criterion.
if-match [ not ] match-criteria
By default, no match criterion is configured.
For more information, see the if-match command in ACL and QoS Command Reference.
a. Create a traffic behavior and enter traffic behavior view.
b. Redirect matching traffic to an SR-MPLS TE policy.
redirect sr-policy endpoint color
By default, no action is configured for a traffic behavior.
a. Create a QoS policy and enter QoS policy view.
qos policy policy-name
b. Associate a traffic class with a traffic behavior to create a class-behavior association in the QoS policy.
classifier classifier-name behavior behavior-name
By default, a traffic class is not associated with a traffic behavior.
c. Return to system view.
d. Apply the QoS policy.
For more information, see QoS policy configuration in ACL and QoS Configuration Guide.
By default, the QoS policy is not applied.
Creating and activating an IPv4 Flowspec rule
2. Create an IPv4 Flowspec rule.
flow-route flowroute-name
3. Configure a match criterion.
if-match match-criteria
4. Apply an action that redirects packets to an SR-MPLS TE policy.
apply redirect next-hop ipv4-address color color
By default, no action is configured.
5. Commit the match criterion and action.
commit
By default, match criteria and actions are not committed.
Applying an IPv4 Flowspec rule to the public network
2. Enter Flowspec view.
flowspec
3. Create a Flowspec IPv4 address family for the public network and enter its view.
address-family ipv4
4. Apply an IPv4 Flowspec rule to the public network. Choose one option as needed:
¡ Apply an IPv4 Flowspec rule.
By default, no IPv4 Flowspec rule is applied to the public network.
¡ Apply an IPv4 Flowspec rule and associate it with a Flowspec interface group.
flow-route flowroute-name flow-interface-group group-id
By default, no Flowspec interface group is associated with an IPv4 Flowspec rule.
Applying an IPv4 Flowspec rule to a VPN instance
2. Configure a VPN instance.
a. Create a VPN instance and enter VPN instance view.
b. Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
c. Configure route targets for the VPN instance.
vpn-target { vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] }
By default, no route targets are configured.
For more information about the ip vpn-instance, route-distinguisher, and vpn-target commands, see MPLS L3VPN commands in MPLS Command Reference.
3. Enter the IPv4 Flowspec address family view of the VPN instance.
address-family ipv4 flowspec
4. Configure an RD for the IPv4 Flowspec address family.
By default, no RD is configured for the IPv4 Flowspec address family.
5. Configure route targets for the IPv4 Flowspec address family.
By default, no route targets are configured for the IPv4 Flowspec address family.
The route targets configured must be the same as the route targets configured previously for the VPN instance.
6. Execute the quit command twice to return to system view.
7. Enter Flowspec view.
flowspec
8. Create a Flowspec IPv4 address family and associate the address family with the VPN instance.
address-family ipv4 vpn-instance vpn-instance-name
9. Apply an IPv4 Flowspec rule to the Flowspec IPv4 VPN instance address family. Choose one option as needed:
By default, no IPv4 Flowspec rule is applied to a Flowspec IPv4 VPN instance address family.
Enabling BGP to distribute IPv4 Flowspec rules
2. Enter BGP instance view:
3. Enter BGP IPv4 Flowspec address family view, BGP-VPN IPv4 Flowspec address family view, or BGP VPNv4 Flowspec address family view:
¡ Enter BGP IPv4 Flowspec address family view to distribute public network IPv4 Flowspec rules:
¡ Enter BGP-VPN IPv4 Flowspec address family view to distribute private network IPv4 Flowspec rules:
¡ Enter BGP VPNv4 Flowspec address family view to distribute VPNv4 Flowspec rules:
address-family vpnv4 flowspec
4. Enable BGP Flowspec peers to exchange routing information.
By default, BGP Flowspec peers cannot exchange routing information.
You can enable SBFD for all SR-MPLS TE policies globally in SR TE view or for a specific SR-MPLS TE policy in SR-MPLS TE policy view. The policy-specific configuration takes precedence over the global configuration. An SR-MPLS TE policy uses the global configuration only when it has no policy-specific configuration.
Before you configure this feature, execute the mpls bfd enable command to enable MPLS BFD. For more information about the mpls bfd enable command, see MPLS OAM commands in MPLS Command Reference.
After you enable SBFD for SR-MPLS TE policies, SBFD sessions use the MPLS LSR ID of the local device as their source address. As a best practice to ensure correct establishment of SBFD sessions, perform the following operations:
1. Configure a loopback interface address of the local device as the local MPLS LSR ID.
2. Advertise the loopback interface address to remote devices through an IGP.
This operation ensures that those remote devices can route traffic to the local MPLS LSR ID.
segment-routing
traffic-engineering
4. Enable SBFD for all SR-MPLS TE policies.
sr-policy sbfd enable [ remote remote-id ] [ template template-name ] [ backup-template backup-template-name ]
By default, SBFD is disabled for all SR-MPLS TE policies.
5. (Optional.) Configure SBFD detection timer parameters.
sr-policy sbfd timer { detect-multiplier multiplier-value | min-tx-interval transmit-interval }
By default, no SBFD detection timer parameters are configured.
6. (Optional.) Globally enable BFD session down events to trigger SR-MPLS TE policy path reselection.
sr-policy bfd trigger path-down enable
7. (Optional.) Configure the delay time for the device to notify an SR-MPLS TE policy of the BFD/SBFD session down event.
sr-policy bfd first-fail-timer seconds
By default, the delay time for the device to notify an SR-MPLS TE policy of the BFD/SBFD session down event is 60 seconds.
8. Enter SR-MPLS TE policy view.
policy policy-name
9. Configure SBFD for the SR-MPLS TE policy.
sbfd { disable | enable [ remote remote-id ] [ template template-name ] [ backup-template backup-template-name ] }
By default, SBFD is not configured for an SR-MPLS TE policy.
10. (Optional.) Enable BFD session down events to trigger candidate path reselection for the SR-MPLS TE policy.
bfd trigger path-down { disable | enable }
By default, this feature is not configured for an SR-MPLS TE policy, and the configuration in SR TE view applies.
You can enable hot standby for all SR-MPLS TE policies globally in SR TE view or for a specific SR-MPLS TE policy in SR-MPLS TE policy view. The policy-specific configuration takes precedence over the global configuration. An SR-MPLS TE policy uses the global configuration only when it has no policy-specific configuration.
segment-routing
traffic-engineering
4. Enable hot standby for all SR-MPLS TE policies.
sr-policy backup hot-standby enable
By default, hot standby is disabled for all SR-MPLS TE policies.
5. Enter SR-MPLS TE policy view.
policy policy-name
6. Configure hot standby for the SR-MPLS TE policy.
backup hot-standby { disable | enable }
By default, hot standby is not configured for an SR-MPLS TE policy.
The switchover delay and deletion delay mechanism is used to avoid traffic forwarding failure during a forwarding path (SID list) switchover.
When updating an SR-MPLS TE policy forwarding path, the device first establishes the new forwarding path before it deletes the old one. During the new path setup process, the device uses the old path to forward traffic until the switchover delay timer expires. When the switchover delay timer expires, the device switches traffic to the new path. The old path is deleted when the deletion delay timer expires.
To apply the switchover delay and deletion delay, the old and new forwarding paths of the SR-MPLS TE policy must both be up. When the old forwarding path goes down, traffic is switched to the new path immediately without waiting for the switchover delay time.
segment-routing
traffic-engineering
4. Configure the switchover delay time and deletion delay time for the SR-MPLS TE policy forwarding path.
sr-policy switch-delay switch-delay-time delete-delay delete-delay-time
By default, the switchover delay time and deletion delay time for the SR-MPLS TE policy forwarding path is 5000 milliseconds and 20000 milliseconds, respectively.
After an SR-MPLS TE policy recovers from a fault, the device waits for the delay time before bringing up the SR-MPLS TE policy. This is to ensure that the fault is completely removed so as to avoid packet loss caused by SR-MPLS TE policy flapping.
After this command is executed, the device starts different delay timers for an SR-MPLS TE policy according to the SBFD configuration for the SR-MPLS TE policy.
· If SBFD is not enabled, the device starts an LSP delay timer when the SID list state changes from Down to Up.
· If SBFD is enabled, the device starts an SBFD delay timer when the SBFD session state changes from Down to Up.
To view the SBFD configuration, SID list state, and SBFD session state, execute the display segment-routing te policy command.
Set a proper SR-MPLS TE policy up delay time according to your network conditions. A very long delay time will cause an SR-MPLS TE policy to be unable to process user traffic for a long time.
You can set the delay time for all SR-MPLS TE policies globally in SR TE view or for a specific SR-MPLS TE policy in SR-MPLS TE policy view. The policy-specific configuration takes precedence over the global configuration. An SR-MPLS TE policy uses the global configuration only when it has no policy-specific configuration.
If you execute this command for multiple times, the most recent configuration takes effect. A new delay time setting does not apply to the SR-MPLS TE policies that are already in a policy-up delay process.
segment-routing
traffic-engineering
4. Set the policy-up delay time for all SR-MPLS TE policies.
sr-policy up-delay delay-time
By default, the device does not delay bringing up SR-MPLS TE policies.
policy policy-name
6. Set the policy-up delay time for the SR-MPLS TE policy.
up-delay delay-time
By default, no policy-up delay time is set for an SR-MPLS TE policy and the policy-up delay time set in SR TE view applies.
Before configuring CBTS, you must configure a QoS traffic behavior to mark the MPLS TE service class values for packets by using the remark service-class command. For more information, see QoS policy commands in ACL and QoS Command Reference.
segment-routing
traffic-engineering
policy policy-name
5. Set a service class value for the SR-MPLS TE policy.
service-class service-class-value
By default, no service class value is set for an SR-MPLS TE policy. An SR-MPLS TE policy uses service class 255, which has the lowest forwarding priority.
Abou this task
This feature enables the device to log SR-MPLS TE policy state changes to facilitate audit of SR-MPLS TE policy operations. The SR-MPLS TE policy log messages are sent to the information center and output as configured in the information center. For more information about information center, see Network Management and Monitoring Configuration Guide.
segment-routing
traffic-engineering
4. Enable SR-MPLS TE policy logging.
sr-policy log enable
By default, SR-MPLS TE policy logging is disabled.
Abou this task
This feature enables the device to send SNMP notifications about state changes of SR-MPLS TE policies. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for SR-MPLS TE policies.
snmp-agent trap enable sr-policy
By default, SNMP notifications for SR-MPLS TE policies
This feature collects statistics on traffic forwarded by SR-MPLS TE policies.
You can configure the SR-MPLS TE policy forwarding statistics feature for all SR-MPLS TE policies globally in SR TE view or for a specific SR-MPLS TE policy in SR-MPLS TE policy view. The policy-specific configuration takes precedence over the global configuration. An SR-MPLS TE policy uses the global configuration only when it has no policy-specific configuration.
segment-routing
traffic-engineering
4. Enable traffic forwarding statistics for all SR-MPLS TE policies globally.
forwarding statistics [ service-class ] enable
By default, traffic forwarding statistics is disabled for all SR-MPLS TE policies globally.
If you specify the service-class keyword, the device collects statistics on the total traffic as well as the traffic of each service class that are forwarded by SR-MPLS TE policies.
5. (Optional.) Set the SR-MPLS TE policy forwarding statistics interval.
forwarding statistics interval interval
By default, the SR-MPLS TE policy forwarding statistics interval is 30 seconds.
6. Enter SR-MPLS TE policy view.
policy policy-name
7. Configure traffic forwarding statistics for the SR-MPLS TE policy.
forwarding statistics { disable | [ service-class ] enable }
By default, an SR-MPLS TE policy uses the traffic forwarding statistics configuration in SR TE view.
If you specify the service-class keyword, the device collects statistics on the total traffic as well as the traffic of each service class that are forwarded by the SR-MPLS TE policy.
Execute display commands in any view. Execute reset commands in user view.
Task |
Command |
Display BGP peer or peer group information. |
display bgp [ instance instance-name ] peer ipv4 sr-policy [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 sr-policy [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ] |
Display BGP IPv4 SR policy routing information. |
display bgp [ instance instance-name ] routing-table ipv4 sr-policy [ sr-policy-prefix [ advertise-info ] ] display bgp [ instance instance-name ] routing-table ipv4 sr-policy [ as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression ] display bgp [ instance instance-name ] routing-table ipv4 sr-policy [ color color-value [ end-point ipv4 ipv4-address ] | end-point ipv4 ipv4-address ] display bgp [ instance instance-name ] routing-table ipv4 sr-policy [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ sr-policy-prefix [ verbose ] | color color-value [ end-point ipv4 ipv4-address ] | end-point ipv4 ipv4-address | statistics [ color color-value [ end-point ipv4 ipv4-address ] | end-point ipv4 ipv4-address ] ] ] display bgp [ instance instance-name ] routing-table ipv4 sr-policy [ statistics [ color color-value [ end-point ipv4 ipv4-address ] | end-point ipv4 ipv4-address ] ] display bgp [ instance instance-name ] routing-table ipv4 sr-policy peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } display bgp [ instance instance-name ] routing-table ipv4 sr-policy time-range min-time max-time |
Display BGP peer group information. |
display bgp [ instance instance-name ] group ipv4 sr-policy [ group-name group-name ] |
Display BGP update group information. |
display bgp [ instance instance-name ] update-group ipv4 sr-policy [ ipv4-address | ipv6-address ] |
Display SR-MPLS TE policy database information. |
display segment-routing te database [ link | node | prefix ] |
Display SR TE forwarding information. |
display segment-routing te forwarding [ policy { name policy-name | { color color-value | end-point ipv4 ip-address } * } ] [ verbose ] |
Display SR-MPLS TE policy information. |
display segment-routing te policy [ name policy-name | down | up | { color color-value | end-point ipv4 ip-address } * ] |
Display information about the most recent down event for SR-MPLS TE policies. |
display segment-routing te policy last-down-reason [ binding-sid bsid | color color-value end-point ipv4 ipv4-address | policy-name policy-name ] |
Display SR-MPLS TE policy statistics. |
display segment-routing te policy statistics |
Display SR-MPLS TE policy group information. |
display segment-routing te policy-group [ group-id ] [ verbose ] |
Display SBFD information for SR-MPLS TE policies. |
display segment-routing te sbfd [ down | policy { { color color-value | end-point ipv4 ipv4-address } * | name policy-name } | up ] |
Display SR-TE SID list information. |
display segment-routing te segment-list [ name segment-list-name | id id-value ] |
Clear SR TE forwarding statistics. |
reset segment-routing te forwarding statistics [ binding-sid binding-sid | color color-value endpoint endpoint-ipv4 | name name-value ] |
As shown in Figure 6, perform the following tasks on the devices to implement SR-MPLS TE policy-based forwarding:
· Configure Device A through Device D to run IS-IS to implement Layer 3 connectivity.
· Configure SR-MPLS on Device A through Device D to establish an SRLSP.
· Configure an SR-MPLS TE policy on Device A to forward user packets along path Device A > Device B > Device C > Device D.
Device |
IP address |
Device |
IP address |
Device A |
Loop1 |
1.1.1.1/32 |
Device B |
Loop1 |
2.2.2.2/32 |
XGE3/0/1 |
12.0.0.1/24 |
XGE3/0/1 |
12.0.0.2/24 |
XGE3/0/2 |
14.0.0.1/24 |
XGE3/0/2 |
23.0.0.2/24 |
Device C |
Loop1 |
3.3.3.3/32 |
Device D |
Loop1 |
4.4.4.4/32 |
XGE3/0/1 |
34.0.0.3/24 |
XGE3/0/1 |
34.0.0.4/24 |
XGE3/0/2 |
23.0.0.3/24 |
XGE3/0/2 |
14.0.0.4/24 |
1. Configure IP addresses and masks for interfaces.
# Assign IP addresses to Device A's interfaces.
[Sysname] sysname DeviceA
[DeviceA] interface loopback 1
[DeviceA-LoopBack1] ip address 1.1.1.1 32
[DeviceA-LoopBack1] quit
[DeviceA] interface ten-gigabitethernet 3/0/1
[DeviceA-Ten-GigabitEthernet3/0/1] ip address 12.0.0.1 24
[DeviceA-Ten-GigabitEthernet3/0/1] quit
[DeviceA] interface ten-gigabitethernet 3/0/2
[DeviceA-Ten-GigabitEthernet3/0/2] ip address 14.0.0.1 24
[DeviceA-Ten-GigabitEthernet3/0/2] quit
# Assign IP addresses to Device B's interfaces.
[Sysname] sysname DeviceB
[DeviceB] interface loopback 1
[DeviceB-LoopBack1] ip address 2.2.2.2 32
[DeviceB-LoopBack1] quit
[DeviceB] interface ten-gigabitethernet 3/0/1
[DeviceB-Ten-GigabitEthernet3/0/1] ip address 12.0.0.2 24
[DeviceB-Ten-GigabitEthernet3/0/1] quit
[DeviceB] interface ten-gigabitethernet 3/0/2
[DeviceB-Ten-GigabitEthernet3/0/2] ip address 23.0.0.2 24
[DeviceB-Ten-GigabitEthernet3/0/2] quit
# Assign IP addresses to Device C's interfaces.
[Sysname] sysname DeviceC
[DeviceC] interface loopback 1
[DeviceC-LoopBack1] ip address 3.3.3.3 32
[DeviceC-LoopBack1] quit
[DeviceC] interface ten-gigabitethernet 3/0/1
[DeviceC-Ten-GigabitEthernet3/0/1] ip address 34.0.0.3 24
[DeviceC-Ten-GigabitEthernet3/0/1] quit
[DeviceC] interface ten-gigabitethernet 3/0/2
[DeviceC-Ten-GigabitEthernet3/0/2] ip address 23.0.0.3 24
[DeviceC-Ten-GigabitEthernet3/0/2] quit
# Assign IP addresses to Device D's interfaces.
[Sysname] sysname DeviceD
[DeviceD] interface loopback 1
[DeviceD-LoopBack1] ip address 4.4.4.4 32
[DeviceD-LoopBack1] quit
[DeviceD] interface ten-gigabitethernet 3/0/1
[DeviceD-Ten-GigabitEthernet3/0/1] ip address 34.0.0.4 24
[DeviceD-Ten-GigabitEthernet3/0/1] quit
[DeviceD] interface ten-gigabitethernet 3/0/2
[DeviceD-Ten-GigabitEthernet3/0/2] ip address 14.0.0.4 24
[DeviceD-Ten-GigabitEthernet3/0/2] quit
2. Configure Device A:
# Configure IS-IS and set the IS-IS cost style to wide.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] address-family ipv4
[DeviceA-isis-1-ipv4] quit
[DeviceA-isis-1] quit
[DeviceA-Ten-GigabitEthernet3/0/1] isis enable 1
[DeviceA-Ten-GigabitEthernet3/0/2] isis enable 1
[DeviceA-LoopBack1] isis enable 1
# Configure the MPLS LSR ID, and enable MPLS and MPLS TE.
[DeviceA] mpls lsr-id 1.1.1.1
[DeviceA] mpls te
[DeviceA-te] quit
[DeviceA-Ten-GigabitEthernet3/0/1] mpls enable
[DeviceA-Ten-GigabitEthernet3/0/2] mpls enable
# Configure the SRGB and enable SR-MPLS in IPv4 unicast address family view.
[DeviceA] isis 1
[DeviceA-isis-1] segment-routing global-block 16000 16999
[DeviceA-isis-1-ipv4] segment-routing mpls
# Configure the IS-IS prefix SID.
[DeviceA-LoopBack1] isis prefix-sid index 10
# Configure an SID list.
[DeviceA] segment-routing
[DeviceA-segment-routing] traffic-engineering
[DeviceA-sr-te] segment-list s1
[DeviceA-sr-te-sl-s1] index 10 mpls label 16020
[DeviceA-sr-te-sl-s1] index 20 mpls label 17030
[DeviceA-sr-te-sl-s1] index 30 mpls label 18040
[DeviceA-sr-te-sl-s1] quit
# Create an SR-MPLS TE policy and set the attributes.
[DeviceA-sr-te] policy p1
[DeviceA-sr-te-policy-p1] binding-sid mpls 15000
[DeviceA-sr-te-policy-p1] color 10 end-point ipv4 4.4.4.4
# Configure a candidate path for the SR-MPLS TE policy and specify an explicit path for the candidate path.
[DeviceA-sr-te-policy-p1] candidate-paths
[DeviceA-sr-te-policy-p1-path] preference 10
[DeviceA-sr-te-policy-p1-path-pref-10] explicit segment-list s1
[DeviceA-sr-te-policy-p1-path-pref-10] quit
[DeviceA-sr-te-policy-p1-path] quit
[DeviceA-sr-te-policy-p1] quit
[DeviceA-sr-te] quit
[DeviceA-segment-routing] quit
3. Configure Device B:
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] address-family ipv4
[DeviceB-isis-1-ipv4] quit
[DeviceB-isis-1] quit
[DeviceB-Ten-GigabitEthernet3/0/1] isis enable 1
[DeviceB-Ten-GigabitEthernet3/0/2] isis enable 1
[DeviceB-LoopBack1] isis enable 1
[DeviceB] mpls lsr-id 2.2.2.2
[DeviceB] mpls te
[DeviceB-te] quit
[DeviceB-Ten-GigabitEthernet3/0/1] mpls enable
[DeviceB-Ten-GigabitEthernet3/0/2] mpls enable
[DeviceB] isis 1
[DeviceB-isis-1] segment-routing global-block 17000 17999
[DeviceB-isis-1-ipv4] segment-routing mpls
[DeviceB-LoopBack1] isis prefix-sid index 20
4. Configure Device C:
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] address-family ipv4
[DeviceC-isis-1-ipv4] quit
[DeviceC-isis-1] quit
[DeviceC-Ten-GigabitEthernet3/0/1] isis enable 1
[DeviceC-Ten-GigabitEthernet3/0/2] isis enable 1
[DeviceC-LoopBack1] isis enable 1
[DeviceC] mpls lsr-id 3.3.3.3
[DeviceC] mpls te
[DeviceC-te] quit
[DeviceC-Ten-GigabitEthernet3/0/1] mpls enable
[DeviceC-Ten-GigabitEthernet3/0/2] mpls enable
[DeviceC] isis 1
[DeviceC-isis-1] segment-routing global-block 18000 18999
[DeviceC-isis-1-ipv4] segment-routing mpls
[DeviceC-LoopBack1] isis prefix-sid index 30
5. Configure Device D:
[DeviceD] isis 1
[DeviceD-isis-1] network-entity 00.0000.0000.0004.00
[DeviceD-isis-1] cost-style wide
[DeviceD-isis-1] address-family ipv4
[DeviceD-isis-1-ipv4] quit
[DeviceD-isis-1] quit
[DeviceD-Ten-GigabitEthernet3/0/1] isis enable 1
[DeviceD-Ten-GigabitEthernet3/0/2] isis enable 1
[DeviceD-LoopBack1] isis enable 1
[DeviceD] mpls lsr-id 4.4.4.4
[DeviceD] mpls te
[DeviceD-te] quit
[DeviceD-Ten-GigabitEthernet3/0/1] mpls enable
[DeviceD-Ten-GigabitEthernet3/0/2] mpls enable
[DeviceD] isis 1
[DeviceD-isis-1] segment-routing global-block 19000 19999
[DeviceD-isis-1-ipv4] segment-routing mpls
[DeviceD-LoopBack1] isis prefix-sid index 40
# Display SR TE policy information on Device A. (For illustration only)
[DeviceA] display segment-routing te policy
Name/ID: p1/0
Color: 10
Endpoint: 4.4.4.4
Name from Bgp:
BSID:
Mode: Explicit Type: Type_1 Request state: Succeeded
Current BSID: 15000 Explicit BSID: 15000 Dynamic BSID: -
Reference counts: 4
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Up time: 2019-10-25 11:16:15
Down time: 2019-10-25 11:16:00
Hot-standby: Not configured
Statistics: Not configured
Statistics by service class: Not configured
SBFD: Not configured
BFD trigger path-down: Disabled
PolicyNid: 6201
Service-class: -
Candidate paths state: Configured
Candidate paths statistics:
CLI paths: 1 BGP paths: 0 PCEP paths: 0
Candidate paths:
Preference : 10
CPathName:
ProtoOrigin: CLI Discriminator: 10
Instance ID: 0 Node Address: 0.0.0.0
Originator: 0, 0.0.0.0
Optimal: Y Flags: V/A
Explicit SID list:
ID: 1 Name: s1
Weight: 1 Nid: 24117249
State: Up SBFD state: -
The output shows that the SR-MPLS TE policy is in up state (see the Status field). The device can use the SR-MPLS TE policy to forward packets.
# Display SR TE forwarding information on Device A.
[DeviceA] display segment-routing te forwarding verbose
Total Forwarding entries: 1
Policy name/ID: p1/0
Binding SID: 15000
Policy NID: 0x01400001
Main path:
SegList ID: 1
SegList NID: 0x01700001
Weight: 1
Outgoing NID: 0x01600001
OutLabels: 3
Interface: XGE3/0/1
NextHop: 12.0.0.2
Path ID: 0
Label stack: {17030, 18040}
The output shows that the label stack for packets forwarded by using the SR-MPLS TE policy is {17030, 18040}.
# Display MPLS LSP information on Device A.
[DeviceA] display mpls lsp
FEC Proto In/Out Label Out Inter/NHLFE/LSINDEX
12.0.0.2 Local -/- XGE3/0/1
14.0.0.4 Local -/- XGE3/0/2
1.1.1.1/32 ISIS 16010/- -
2.2.2.2/32 ISIS 16020/3 XGE3/0/1
2.2.2.2/32 ISIS -/3 XGE3/0/1
3.3.3.3/32 ISIS 16030/17030 XGE3/0/1
3.3.3.3/32 ISIS -/17030 XGE3/0/1
3.3.3.3/32 ISIS 16030/19030 XGE3/0/2
3.3.3.3/32 ISIS -/19030 XGE3/0/2
4.4.4.4/32 ISIS 16040/3 XGE3/0/2
4.4.4.4/32 ISIS -/3 XGE3/0/2
4.4.4.4/32/23068673 SRPolicy -/17030 XGE3/0/1
18040
24117249 SRPolicy -/- LSINDEX23068673
4.4.4.4/10 SRPolicy 15000/- NHLFE24117249
The output shows that the forwarding paths used by the SR-MPLS TE policy.
Configuration files
Device A
sysname DeviceA
isis 1
cost-style wide
address-family ipv4 unicast
mpls lsr-id 1.1.1.1
mpls te
segment-routing
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
interface LoopBack1
ip address 1.1.1.1 255.255.255.255
isis enable 1
interface Ten-GigabitEthernet3/0/1
ip address 12.0.0.1 255.255.255.0
isis enable 1
mpls enable
interface Ten-GigabitEthernet3/0/2
ip address 14.0.0.1 255.255.255.0
isis enable 1
mpls enable
Device B
sysname DeviceB
isis 1
cost-style wide
mpls lsr-id 2.2.2.2
mpls te
interface LoopBack1
ip address 2.2.2.2 255.255.255.255
isis enable 1
ip address 12.0.0.2 255.255.255.0
isis enable 1
mpls enable
ip address 23.0.0.2 255.255.255.0
isis enable 1
mpls enable
Device C
sysname DeviceC
isis 1
cost-style wide
mpls lsr-id 3.3.3.3
mpls te
interface LoopBack1
ip address 3.3.3.3 255.255.255.255
isis enable 1
ip address 34.0.0.3 255.255.255.0
isis enable 1
mpls enable
ip address 23.0.0.3 255.255.255.0
isis enable 1
mpls enable
Device D
sysname DeviceD
isis 1
cost-style wide
mpls lsr-id 4.4.4.4
mpls te
interface LoopBack1
ip address 4.4.4.4 255.255.255.255
isis enable 1
ip address 34.0.0.4 255.255.255.0
isis enable 1
mpls enable
ip address 14.0.0.4 255.255.255.0
isis enable 1
mpls enable
Example: Configuring color-based traffic steering for IPv4 L3VPN over SR-MPLS TE Policy
As shown in Figure 7, the backbone network runs SR-MPLS, and the VPN is IPv4. PE 1, PE 2, P 1, and P 2 are in the same autonomous system, running IS-IS for network interconnectivity. Static SR-MPLS TE policies p1 and p2 are configured between PE 1 and PE 2 to support IPv4 L3VPN services. Routing policies are configured on PE 1 and PE 2 to set the color attribute of BGP routes, enabling traffic steering to the desired SR-MPLS TE policy. SBFD is enabled for SR-MPLS TE policies to detect the reachability of forwarding paths.
Device |
IP address |
Device |
IP address |
XGE3/0/1 |
10.1.1.1/24 |
CE 2 |
XGE3/0/1 |
20.1.1.1/24 |
PE 1 |
Loop1 |
1.1.1.1/32 |
PE 2 |
Loop1 |
3.3.3.3/32 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/1 |
20.1.1.2/24 |
XGE3/0/2 |
11.0.0.1/30 |
XGE3/0/2 |
21.0.0.1/30 |
XGE3/0/3 |
31.0.0.1/30 |
XGE3/0/3 |
41.0.0.1/30 |
P 1 |
Loop1 |
2.2.2.2/32 |
P 2 |
Loop1 |
4.4.4.4/32 |
XGE3/0/1 |
11.0.0.2/30 |
XGE3/0/1 |
31.0.0.2/30 |
XGE3/0/2 |
21.0.0.2/30 |
XGE3/0/2 |
41.0.0.2/30 |
· If various tunnels exist in the network, such as SRv6 TE policies and SR-MPLS TE policies, and those tunnels have the same color value, you must use a routing policy to set the color attribute of the related routes. In addition, you must configure a tunnel policy to ensure that the specified SR-MPLS TE policy is preferred during tunnel selection.
· In this example, the SRLB range is 15000 to 15999 for all of the following devices. The values of manual adjacency SIDs depend on the SRLB range. As a best practice to ensure valid forwarding paths, plan and configure SID lists based on the real adjacency SIDs of the related interfaces.
1. Configure CE 1.
[Sysname] sysname CE1
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[CE1-Ten-GigabitEthernet3/0/1] quit
[CE1] bgp 200
[CE1-bgp-default] peer 10.1.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
2. Configure PE 1.
# Configure IPv4 IS-IS to achieve PE interconnects in the backbone network.
[Sysname] sysname PE1
[PE1] isis 1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 00.0000.0000.0001.00
[PE1-isis-1] address-family ipv4 unicast
[PE1-isis-1-ipv4] quit
[PE1-isis-1] quit
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 1.1.1.1 32
[PE1-LoopBack1] isis enable 1
[PE1-LoopBack1] quit
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip address 11.0.0.1 30
[PE1-Ten-GigabitEthernet3/0/2] isis enable 1
[PE1-Ten-GigabitEthernet3/0/2] quit
[PE1] interface ten-gigabitethernet 3/0/3
[PE1-Ten-GigabitEthernet3/0/3] ip address 31.0.0.1 30
[PE1-Ten-GigabitEthernet3/0/3] isis enable 1
[PE1-Ten-GigabitEthernet3/0/3] quit
# Configure a VPN instance that connects CE 1 to PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.2 24
[PE1-Ten-GigabitEthernet3/0/1] quit
# Establish an EBGP peer relationship between PE 1 and CE 1, and enable the PE to redistribute VPN routes to BGP.
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 200
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] import-route direct
[PE1-bgp-default-vpn1] quit
# Establish a BGP VPNv4 peer relationship between the PEs.
[PE1-bgp-default] peer 3.3.3.3 as-number 100
[PE1-bgp-default] peer 3.3.3.3 connect-interface loopback 1
[PE1-bgp-default-vpnv4] peer 3.3.3.3 enable
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
# Enable MPLS TE on the PE, and enable MPLS on each interface that participates in MPLS-based forwarding in the backbone network.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls te
[PE1-te] quit
[PE1-Ten-GigabitEthernet3/0/2] mpls enable
[PE1-Ten-GigabitEthernet3/0/3] mpls enable
# In IS-IS IPv4 unicast address family view, enable SR-MPLS and enable SR-MPLS adjacency SID allocation.
[PE1] isis 1
[PE1-isis-1-ipv4] segment-routing mpls
[PE1-isis-1-ipv4] segment-routing adjacency enable
[PE1-isis-1] quit
# Assign IS-IS adjacency SIDs to the related interfaces.
[PE1-Ten-GigabitEthernet3/0/2] isis adjacency-sid index 10 nexthop 11.0.0.2
[PE1-Ten-GigabitEthernet3/0/3] isis adjacency-sid index 20 nexthop 31.0.0.2
# Configure SID lists.
[PE1] segment-routing
[PE1-segment-routing] traffic-engineering
[PE1-sr-te] segment-list s1
[PE1-sr-te-sl-s1] index 10 mpls label 15010
[PE1-sr-te-sl-s1] index 20 mpls label 15011
[PE1-sr-te-sl-s1] quit
[PE1-sr-te] segment-list s2
[PE1-sr-te-sl-s2] index 10 mpls label 15020
[PE1-sr-te-sl-s2] index 20 mpls label 15012
[PE1-sr-te-sl-s2] quit
# Create SR-MPLS TE policies and configure their attributes.
[PE1-sr-te] policy p1
[PE1-sr-te-policy-p1] color 10 end-point ipv4 3.3.3.3
[PE1-sr-te-policy-p1] candidate-paths
[PE1-sr-te-policy-p1-path] preference 10
[PE1-sr-te-policy-p1-path-pref-10] explicit segment-list s1
[PE1-sr-te-policy-p1-path-pref-10] quit
[PE1-sr-te-policy-p1-path] quit
[PE1-sr-te-policy-p1] quit
[PE1-sr-te] policy p2
[PE1-sr-te-policy-p2] color 20 end-point ipv4 3.3.3.3
[PE1-sr-te-policy-p2] candidate-paths
[PE1-sr-te-policy-p2-path] preference 10
[PE1-sr-te-policy-p2-path-pref-10] explicit segment-list s2
[PE1-sr-te-policy-p2-path-pref-10] quit
[PE1-sr-te-policy-p2-path] quit
[PE1-sr-te-policy-p2] quit
[PE1-sr-te] quit
[PE1-segment-routing] quit
# Configure a routing policy and a tunnel policy. The routing policy sets the color value to 00:20 for the BGP VPNv4 routes learned from PE 2, ensuring that those routes can match SR-MPLS TE policy p2 (whose color value is 20) and VPN service traffic can be directed to the SR-MPLS TE policy. The tunnel policy ensures that the preferred tunnel is an SR-MPLS TE policy.
[PE1] route-policy a permit node 10
[PE1-route-policy-a-10] apply extcommunity color 00:20 additive
[PE1-route-policy-a-10] quit
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 3.3.3.3 route-policy a export
[PE1] tunnel-policy a
[PE1-tunnel-policy-a] select-seq sr-policy load-balance-number 1
[PE1-tunnel-policy-a] quit
[PE1-vpn-instance-vpn1] tnl-policy a
# Enable BFD for MPLS, and enable SBFD for all SR-MPLS TE policies. As the SBFD session initiator, PE 1 must be configured with the remote SBFD session discriminator of PE 2. Make sure PE 1 and PE 2 are configured with the same remote discriminator.
[PE1] mpls bfd enable
[PE1-sr-te] sr-policy sbfd enable remote 1000001
[PE1-sr-te] quit
NOTE: In this example, no source address is specified for the SBFD session. After you enable SBFD for SR-MPLS TE policies, SBFD sessions use the MPLS LSR ID of the local device as their source address. As a best practice to ensure correct establishment of SBFD sessions, perform the following operations: · Configure a loopback interface address of the local device as the local MPLS LSR ID. · Advertise the loopback interface address to remote devices through an IGP. These operations ensure that the related remote devices can route traffic to the local MPLS LSR ID. |
3. Configure P 1.
[Sysname] sysname P1
[P1] isis 1
[P1-isis-1] cost-style wide
[P1-isis-1] network-entity 00.0000.0000.0002.00
[P1-isis-1] address-family ipv4 unicast
[P1-isis-1-ipv4] quit
[P1-isis-1] quit
[P1] interface loopback 1
[P1-LoopBack1] ip address 2.2.2.2 32
[P1-LoopBack1] isis enable 1
[P1-LoopBack1] quit
[P1] interface ten-gigabitethernet 3/0/1
[P1-Ten-GigabitEthernet3/0/1] ip address 11.0.0.2 30
[P1-Ten-GigabitEthernet3/0/1] isis enable 1
[P1-Ten-GigabitEthernet3/0/1] quit
[P1] interface ten-gigabitethernet 3/0/2
[P1-Ten-GigabitEthernet3/0/2] ip address 21.0.0.2 30
[P1-Ten-GigabitEthernet3/0/2] isis enable 1
[P1-Ten-GigabitEthernet3/0/2] quit
# Enable MPLS on the P device and each interface that participates in MPLS-based forwarding in the backbone network.
[P1] mpls lsr-id 2.2.2.2
[P1-Ten-GigabitEthernet3/0/1] mpls enable
[P1-Ten-GigabitEthernet3/0/2] mpls enable
[P1] isis 1
[P1-isis-1-ipv4] segment-routing mpls
[P1-isis-1-ipv4] segment-routing adjacency enable
[P1-isis-1] quit
[P1-Ten-GigabitEthernet3/0/1] isis adjacency-sid index 11 nexthop 11.0.0.1
[P1-Ten-GigabitEthernet3/0/2] isis adjacency-sid index 11 nexthop 21.0.0.1
4. Configure P 2.
[Sysname] sysname P2
[P2] isis 1
[P2-isis-1] cost-style wide
[P2-isis-1] network-entity 00.0000.0000.0004.00
[P2-isis-1] address-family ipv4 unicast
[P2-isis-1-ipv4] quit
[P2-isis-1] quit
[P2] interface loopback 1
[P2-LoopBack1] ip address 4.4.4.4 32
[P2-LoopBack1] isis enable 1
[P2-LoopBack1] quit
[P2] interface ten-gigabitethernet 3/0/1
[P2-Ten-GigabitEthernet3/0/1] ip address 31.0.0.2 30
[P2-Ten-GigabitEthernet3/0/1] isis enable 1
[P2-Ten-GigabitEthernet3/0/1] quit
[P2] interface ten-gigabitethernet 3/0/2
[P2-Ten-GigabitEthernet3/0/2] ip address 41.0.0.2 30
[P2-Ten-GigabitEthernet3/0/2] isis enable 1
[P2-Ten-GigabitEthernet3/0/2] quit
[P2] mpls lsr-id 4.4.4.4
[P2-Ten-GigabitEthernet3/0/1] mpls enable
[P2-Ten-GigabitEthernet3/0/2] mpls enable
[P2] isis 1
[P2-isis-1-ipv4] segment-routing mpls
[P2-isis-1-ipv4] segment-routing adjacency enable
[P2-isis-1] quit
[P2-Ten-GigabitEthernet3/0/1] isis adjacency-sid index 12 nexthop 31.0.0.1
[P2-Ten-GigabitEthernet3/0/2] isis adjacency-sid index 12 nexthop 41.0.0.1
5. Configure PE 2.
[Sysname] sysname PE2
[PE2] isis 1
[PE2-isis-1] cost-style wide
[PE2-isis-1] network-entity 00.0000.0000.0003.00
[PE2-isis-1] address-family ipv4 unicast
[PE2-isis-1-ipv4] quit
[PE2-isis-1] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip address 3.3.3.3 32
[PE2-LoopBack1] isis enable 1
[PE2-LoopBack1] quit
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip address 21.0.0.1 30
[PE2-Ten-GigabitEthernet3/0/2] isis enable 1
[PE2-Ten-GigabitEthernet3/0/2] quit
[PE2] interface ten-gigabitethernet 3/0/3
[PE2-Ten-GigabitEthernet3/0/3] ip address 41.0.0.1 30
[PE2-Ten-GigabitEthernet3/0/3] isis enable 1
[PE2-Ten-GigabitEthernet3/0/3] quit
# Configure a VPN instance that connects CE 2 to PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
[PE2-vpn-instance-vpn1] vpn-target 100:1
[PE2-vpn-instance-vpn1] quit
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/1] ip address 20.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/1] quit
# Establish an EBGP peer relationship between PE 2 and CE 2, and enable the PE to redistribute VPN routes to BGP.
[PE2] bgp 100
[PE2-bgp-default] router-id 3.3.3.3
[PE2-bgp-default-vpn1] peer 20.1.1.1 as-number 300
[PE2-bgp-default-ipv4-vpn1] peer 20.1.1.1 enable
[PE2-bgp-default-ipv4-vpn1] import-route direct
[PE2-bgp-default-vpn1] quit
# Establish a BGP EVPN peer relationship between the PEs.
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 1
[PE2-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls te
[PE2-te] quit
[PE2-Ten-GigabitEthernet3/0/2] mpls enable
[PE2-Ten-GigabitEthernet3/0/3] mpls enable
[PE2] isis 1
[PE2-isis-1-ipv4] segment-routing mpls
[PE2-isis-1-ipv4] segment-routing adjacency enable
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/0/2] isis adjacency-sid index 10 nexthop 21.0.0.2
[PE2-Ten-GigabitEthernet3/0/3] isis adjacency-sid index 20 nexthop 41.0.0.2
[PE2] segment-routing
[PE2-segment-routing] traffic-engineering
[PE2-sr-te] segment-list s1
[PE2-sr-te-sl-s1] index 10 mpls label 15010
[PE2-sr-te-sl-s1] index 20 mpls label 15011
[PE2-sr-te-sl-s1] quit
[PE2-sr-te] segment-list s2
[PE2-sr-te-sl-s2] index 10 mpls label 15020
[PE2-sr-te-sl-s2] index 20 mpls label 15012
[PE2-sr-te-sl-s2] quit
[PE2-sr-te] policy p1
[PE2-sr-te-policy-p1] color 10 end-point ipv4 1.1.1.1
[PE2-sr-te-policy-p1] candidate-paths
[PE2-sr-te-policy-p1-path] preference 10
[PE2-sr-te-policy-p1-path-pref-10] explicit segment-list s1
[PE2-sr-te-policy-p1-path-pref-10] quit
[PE2-sr-te-policy-p1-path] quit
[PE2-sr-te-policy-p1] quit
[PE2-sr-te] policy p2
[PE2-sr-te-policy-p2] color 20 end-point ipv4 1.1.1.1
[PE2-sr-te-policy-p2] candidate-paths
[PE2-sr-te-policy-p2-path] preference 10
[PE2-sr-te-policy-p2-path-pref-10] explicit segment-list s2
[PE2-sr-te-policy-p2-path-pref-10] quit
[PE2-sr-te-policy-p2-path] quit
[PE2-sr-te-policy-p2] quit
[PE2-sr-te] quit
[PE2-segment-routing] quit
# Configure a routing policy and a tunnel policy. The routing policy sets the color value to 00:20 for the BGP VPNv4 routes learned from PE 1, ensuring that those routes can match SR-MPLS TE policy p2 (whose color value is 20) and VPN service traffic can be directed to the SR-MPLS TE policy. The tunnel policy ensures that the preferred tunnel is an SR-MPLS TE policy.
[PE2] route-policy a permit node 10
[PE2-route-policy-a-10] apply extcommunity color 00:20 additive
[PE2-route-policy-a-10] quit
[PE2] bgp 100
[PE2-bgp-default-vpnv4] peer 1.1.1.1 route-policy a export
[PE2] tunnel-policy a
[PE2-tunnel-policy-a] select-seq sr-policy load-balance-number 1
[PE2-tunnel-policy-a] quit
[PE2-vpn-instance-vpn1] tnl-policy a
# Configure the local discriminator for the reflector in the SBFD session.
[PE2] sbfd local-discriminator 1000001
6. Configure CE 2.
[Sysname] sysname CE2
[CE2] interface ten-gigabitethernet 3/0/1
[CE2-Ten-GigabitEthernet3/0/1] ip address 20.1.1.1 24
[CE2-Ten-GigabitEthernet3/0/1] quit
[CE2] bgp 300
[CE2-bgp-default] peer 20.1.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 20.1.1.2 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# On PE 1, execute the display segment-routing te policy command to display detailed SR-MPLS TE policy information. The command output shows that the Status field for the SR-MPLS TE policy is Up.
[PE1] display segment-routing te policy name p2
Name/ID: p2/1
Color: 20
End-point: 3.3.3.3
Name from BGP:
BSID:
Mode: Dynamic Type: Type_1 Request state: Succeeded
Current BSID: 1406 Explicit BSID: - Dynamic BSID: 1406
Reference counts: 4
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Up time: 2024-02-24 16:35:39
Down time: 2024-02-24 16:33:01
PolicyNid: 20971522
Explicit SID list:
ID: 2 Name: s2
Weight: 1 Nid: 24117251
State: Up SBFD state: Up
# On PE 1, execute the display ip routing-table vpn-instance vpn1 20.1.1.0 24 command to view detailed information about VPN route 20.1.1.0/24. The command output shows that VPN route 20.1.1.0/24 uses SR-MPLS TE policy p2 as the output interface.
[PE1] display ip routing-table vpn-instance vpn1 20.1.1.0 24
Summary count : 1
20.1.1.0/24 BGP 255 0 3.3.3.3 p2
Alternatively, you can execute the display ip routing-table vpn-instance vpn1 20.1.1.0 command to view detailed information about VPN route 20.1.1.0. The command output shows that the color attribute of the VPN route is correct and the value of the Rely tunnel IDs field is the forwarding entry index of SR-MPLS TE policy p2.
[PE1] display bgp routing-table vpnv4 20.1.1.0
BGP local router ID: 1.1.1.1
Local AS number: 100
Route distinguisher: 100:1(vpn1)
Total number of routes: 1
Paths: 1 available, 1 best
BGP routing table information of 20.1.1.0/24:
Rely nexthop : 11.0.0.2
Original nexthop: 3.3.3.3
Out interface : Ten-GigabitEthernet3/0/2
Route age : 00h43m59s
OutLabel : 1151
Ext-Community : <RT: 100:1>, <CO-Flag:Color(00:20)>
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
State : valid, internal, best
Source type : local
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : a
Rely tunnel IDs : 20971522
# Verify that CE 1 and CE 2 can ping each other.
<CE1> ping -a 10.1.1.1 20.1.1.1
Ping 20.1.1.1 (20.1.1.1) from 10.1.1.1: 56 data bytes, press CTRL+C to break
56 bytes from 20.1.1.1: icmp_seq=0 ttl=253 time=3.000 ms
56 bytes from 20.1.1.1: icmp_seq=1 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=2 ttl=253 time=2.000 ms
56 bytes from 20.1.1.1: icmp_seq=3 ttl=253 time=2.000 ms
56 bytes from 20.1.1.1: icmp_seq=4 ttl=253 time=2.000 ms
--- Ping statistics for 20.1.1.1 ---
round-trip min/avg/max/std-dev = 1.000/2.000/3.000/0.632 ms
Configuration files
CE 1
sysname CE1
bgp 200
import-route direct
CE 2
sysname CE2
ip address 20.1.1.1 255.255.255.0
bgp 300
import-route direct
PE 1
sysname PE1
tnl-policy a
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
isis 1
cost-style wide
mpls lsr-id 1.1.1.1
mpls te
tunnel-policy a
mpls bfd enable
segment-routing
traffic-engineering
segment-list s1
segment-list s2
policy p1
candidate-paths
preference 10
policy p2
candidate-paths
preference 10
interface LoopBack1
isis enable 1
ip address 11.0.0.1 255.255.255.252
isis enable 1
mpls enable
interface Ten-GigabitEthernet3/0/3
ip address 31.0.0.1 255.255.255.252
isis enable 1
mpls enable
bgp 100
router-id 1.1.1.1
peer 3.3.3.3 connect-interface LoopBack1
peer 3.3.3.3 enable
import-route direct
PE 2
sysname PE2
tnl-policy a
isis 1
cost-style wide
mpls lsr-id 3.3.3.3
mpls te
explicit-path s2
tunnel-policy a
select-seq sr-lsp load-balance-number 1
mpls bfd enable
segment-routing
traffic-engineering
segment-list s1
segment-list s2
policy p1
candidate-paths
preference 10
policy p2
candidate-paths
preference 10
interface LoopBack1
isis enable 1
ip address 20.1.1.2 255.255.255.0
ip address 21.0.0.1 255.255.255.252
isis enable 1
mpls enable
ip address 41.0.0.1 255.255.255.252
isis enable 1
mpls enable
bgp 100
router-id 3.3.3.3
peer 1.1.1.1 connect-interface LoopBack1
peer 1.1.1.1 enable
import-route direct
P 1
sysname P1
isis 1
cost-style wide
mpls lsr-id 2.2.2.2
segment-routing
traffic-engineering
interface LoopBack1
isis enable 1
ip address 11.0.0.2 255.255.255.252
isis enable 1
mpls enable
ip address 21.0.0.2 255.255.255.252
isis enable 1
mpls enable
P 2
sysname P2
isis 1
cost-style wide
mpls lsr-id 4.4.4.4
interface LoopBack1
isis enable 1
ip address 31.0.0.2 255.255.255.252
isis enable 1
mpls enable
ip address 41.0.0.2 255.255.255.252
isis enable 1
mpls enable
