- 05-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DNS configuration
- 04-IP forwarding basics configuration
- 05-Fast forwarding configuration
- 06-Adjacency table configuration
- 07-IRDP configuration
- 08-IP performance optimization configuration
- 09-UDP helper configuration
- 10-IPv6 basics configuration
- 11-IPv6 fast forwarding configuration
- 12-Tunneling configuration
- 13-GRE configuration
- 14-ADVPN configuration
- 15-HTTP redirect configuration
05-Fast forwarding configuration | 54.56 KB |
Restrictions and guidelines: Fast forwarding configuration
Configuring the aging time for fast forwarding entries
Configuring fast forwarding load sharing
Display and maintenance commands for fast forwarding
About fast forwarding
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields: source IP address, source port number, destination IP address, destination port number, and protocol number. After a flow's first packet is forwarded through the routing table, fast forwarding creates an entry and uses the entry to forward subsequent packets of the flow.
Fast forwarding can process fragmented IP packets, but it does not fragment IP packets.
The device might receive packets from the same flow on different interfaces when the upstream devices load share traffic or the uplinks change. To ensure correct flow processing, configure the same fast forwarding settings on these input interfaces for the device.
The fast forwarding table uses an aging timer for each forwarding entry. If an entry is not updated before the timer expires, the device deletes the entry. If an entry has a hit within the aging time, the aging timer restarts.
1. Enter system view.
2. Configure the aging time for fast forwarding entries.
ip fast-forwarding aging-time aging-time
By default, the aging time is 30 seconds.
Fast forwarding load sharing enables the device to identify a data flow by using the five-tuple (source IP, source port, destination IP, destination port, and protocol).
If fast forwarding load sharing is disabled, the device identifies a data flow by the five-tuple and the input interface.
2. Configure fast forwarding load sharing. Choose one option as needed:
¡ Enable fast forwarding load sharing.
ip fast-forwarding load-sharing
¡ Disable fast forwarding load sharing.
undo ip fast-forwarding load-sharing
By default, fast forwarding load sharing is enabled.
Task |
Command |
Display fast forwarding entries. |
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ] |
Display fast forwarding entries about fragmented packets. |
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ] |
Display the aging time of fast forwarding entries. |
display ip fast-forwarding aging-time |
Clear the fast forwarding table. |
reset ip fast-forwarding cache [ slot slot-number ] |
