- 03-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-Port isolation configuration
- 04-VLAN configuration
- 05-MVRP configuration
- 06-QinQ configuration
- 07-VLAN termination configuration
- 08-Loop detection configuration
- 09-Spanning tree configuration
- 10-LLDP configuration
- 11-L2PT configuration
| 11-L2PT configuration | 120.20 KB |
Restrictions and guidelines: L2PT configuration
Enabling transparent transmission for packets of the specified protocol
Configuring L2PT
About L2PT
Layer 2 Protocol Tunneling (L2PT) can transparently send Layer 2 protocol packets from geographically dispersed customer networks across a service provider network or drop them.
L2PT application scenario
Dedicated lines are used in a service provider network to build user-specific Layer 2 networks. As a result, a customer network contains sites located at different sides of the service provider network.
As shown in Figure 1, Customer A's network is divided into network 1 and network 2, which are connected by the service provider network. For Customer A's network to implement Layer 2 protocol calculations, the Layer 2 protocol packets must be transmitted across the service provider network.
Upon receiving a Layer 2 protocol packet, the PEs cannot determine whether the packet is from the customer network or the service provider network. They must deliver the packet to the CPU for processing. In this case, the Layer 2 protocol calculation in Customer A's network is mixed with the Layer 2 protocol calculation in the service provider network. Neither the customer network nor the service provider network can implement independent Layer 2 protocol calculations.
Figure 1 L2PT application scenario
L2PT is introduced to resolve the problem. L2PT provides the following functions:
· Multicasts Layer 2 protocol packets from a customer network in a VLAN. Dispersed customer networks can complete an independent Layer 2 protocol calculation, which is transparent to the service provider network.
· Isolates Layer 2 protocol packets from different customer networks through different VLANs.
Supported protocols
H3C devices support L2PT for the following protocols:
· CDP.
· DLDP.
· EOAM.
· GVRP.
· LACP.
· LLDP.
· MVRP.
· PAgP.
· PVST.
· STP (including STP, RSTP, and MSTP).
· UDLD.
· VTP.
L2PT operating mechanism
As shown in Figure 2, L2PT operates as follows:
· When a port of PE 1 receives a Layer 2 protocol packet from the customer network in a VLAN, it performs the following operations:
¡ Multicasts the packet out of all customer-facing ports in the VLAN except the receiving port.
¡ Encapsulates the packet with a specified destination multicast address, and multicasts it out of all ISP-facing ports in the VLAN. The encapsulated packet is called the BPDU tunneled packet.
· When a port of PE 2 in the VLAN receives the tunneled packet from the service provider network, it performs the following operations:
¡ Multicasts the packet out of all ISP-facing ports in the VLAN except the receiving port.
¡ Decapsulates the packet and multicasts the decapsulated packet out of all customer-facing ports in the VLAN.
Figure 2 L2PT operating mechanism
For example, as shown in Figure 3, PE 1 receives an STP packet (BPDU) from network 1 to network 2. CEs are the edge devices on the customer network, and PEs are the edge devices on the service provider network. L2PT processes the packet as follows:
2. PE 1 performs the following operations:
a. Encapsulates the packet with a specified destination multicast MAC address (010f-e200-0003 by default).
b. Sends the tunneled packet out of all ISP-facing ports in the packet's VLAN.
3. Upon receiving the tunneled packet, PE 2 decapsulates the packet and sends the BPDU to CE 2.
Through L2PT, both the ISP network and Customer A's network can perform independent spanning tree calculations.
L2PT and L2PT drop configuration for a protocol on a port overwrite each other. The most recent configuration takes effect.
L2PT tasks at a glance
To configure L2PT, perform the following tasks:
1. (Optional.) Enabling transparent transmission for packets of the specified protocol
This feature is applicable to L2VPN networks such as VPLS and VPWS networks. With this feature disabled on a Layer 3 Ethernet subinterface or Ethernet service instance acting as an AC, it drops received packets of the CDP, LACP, LLDP, and UDLD protocols. As a result, user networks across sites cannot communicate by using these Layer 2 protocols. With this feature enabled on a Layer 3 Ethernet subinterface or Ethernet service instance on a PE, the PE can receive and transparently transmit packets of the specified protocol. These packets are not encapsulated with the multicast destination MAC address for tunneled packets. When the packets reach the peer PE through a PW, the peer PE forwards the packets to the corresponding user sites.
This feature is applicable to L2VPN networks such as VPLS and VPWS networks. With this feature disabled on a Layer 3 interface acting as an AC, it drops received LACP or LLDP packets. As a result, user networks across sites cannot communicate by using these Layer 2 protocols. With this feature enabled on a Layer 3 Ethernet subinterface or Ethernet service instance on a PE, the PE can receive and transparently transmit packets of the specified protocol. These packets are not encapsulated with the multicast destination MAC address for tunneled packets. When the packets reach the peer PE through a PW, the peer PE forwards the packets to the corresponding user sites.
For transparent transmission configurations of different packets in the network, see the following table.
Packet type |
Network type |
Configuration of transparent packet transmission |
eoam3ah |
SRv6 VPLS: Transparent transmission SRv6 VPWS: Transparent transmission |
l2protocol transparent lacp enable |
lldp |
l2protocol transparent lldp enable |
gmrp |
None. |
gvrp |
None. |
dldp |
None. |
hgmp |
None. |
vtp |
None. |
dtp |
None. |
cdp |
None. |
udld |
None. |
pagp |
None. |
pvst+ |
None. |
stp |
None. |
lacp |
mvrp |
None. |
e-lmi |
None. |
e-lmi |
None. |
802.1X |
None. |
sstp |
None. |
On a Layer 3 interface that has LLDP packet transparent transmission enabled, do not configure the interface to operate in dynamic aggregation mode to prevent aggregate interface flapping.
On a Layer 3 interface that has LLDP packet transparent transmission enabled, disable LLDP to prevent LLDP exceptions on devices attached to the interface.
If different subinterfaces of the same main interface on a following card are bound to the same VSI, transparent transmission for packets of the specified protocol takes effect on all subinterfaces of the main interface once you enable the feature on one of them.
1. Enter system view.
2. Enter interface view.
¡ Enter Layer 3 Ethernet interface view.
¡ Enter Layer 3 Ethernet subinterface view.
interface interface-type interface-number.subnumber
¡ Enter Layer 3 aggregate interface view.
¡ Enter Layer 3 aggregate subinterface view.
interface route-aggregation interface-number.subnumber
¡ Enter Layer 3 FlexE logical interface view.
interface flexe interface-number
¡ Enter Layer 3 FlexE logical subinterface view.
interface flexe interface-number.subnumber
3. Enable transparent transmission for packets of the specified protocol.
l2protocol transparent { lacp | lldp } enable
By default, transparent transmission is disabled for packets of the LACP and LLDP protocols, and enabled for other packets.
