01-EVPN commands | 516.97 KB |
address-family evpn (public instance view)
address-family evpn (VPN instance view)
address-family ipv4 (public instance view)
display arp filter source service-instance
display evpn m-lag synchronized-mac
display evpn ipv6 auto-discovery
display evpn route arp suppression
display evpn route arp-mobility
display evpn route mac-mobility
display evpn route nd suppression
display evpn route nd-mobility
evpn mac-ip advertise distributed-gateway
evpn route arp-mobility suppression
evpn route mac-mobility suppression
evpn route nd-mobility suppression
ip forwarding-conversational-learning
ipv6 nd ra tunnel-broadcast global enable
l2vpn m-lag peer-link ac-match-rule vxlan-mapping
nexthop recursive-lookup default-route ignore
peer default-gateway no-advertise
reset evpn route arp-mobility suppression
reset evpn route nd-mobility suppression
Basic EVPN commands
Use address-family evpn to enter public instance EVPN view.
Use undo address-family evpn to delete all settings in public instance EVPN view.
address-family evpn
Public instance view
You can configure EVPN settings such as route targets in public instance EVPN view.
# Enter public instance EVPN view.
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
Use address-family evpn to enter VPN instance EVPN view.
Use undo address-family evpn to delete all settings in VPN instance EVPN view.
address-family evpn
VPN instance view
You can configure EVPN settings such as route targets and routing policies in VPN instance EVPN view.
# Enter EVPN view of VPN instance tenant.
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
Use address-family ipv4 to enter public instance IPv4 address family view.
Use undo address-family ipv4 to delete all settings in public instance IPv4 address family view.
address-family ipv4
# Enter public instance IPv4 address family view.
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family l2vpn evpn
Use address-family l2vpn evpn to create the BGP EVPN address family and enter its view, or enter the view of the existing BGP EVPN address family.
Use undo address-family l2vpn evpn to delete the BGP EVPN address family and all settings in BGP EVPN address family view.
The BGP EVPN address family does not exist.
BGP instance view
Configuration made in BGP EVPN address family view takes effect only on routes and peers of the BGP EVPN address family that are on the public network.
# Create the BGP EVPN address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise l2vpn evpn
Use advertise l2vpn evpn to enable BGP EVPN route advertisement to the local site.
Use undo advertise l2vpn evpn to disable BGP EVPN route advertisement to the local site.
BGP EVPN route advertisement to the local site is enabled.
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
This command enables the device to advertise private BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance.
# Enable BGP EVPN route advertisement to the local site for VPN instance vpn1.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
arp mac-learning disable
Use arp mac-learning disable to disable an EVPN instance from learning MAC addresses from ARP information.
Use undo arp mac-learning disable to restore the default.
An EVPN instance learns MAC addresses from ARP information.
VSI EVPN instance view
The MAC information and ARP information advertised by a remote VTEP overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ARP information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable an EVPN instance from learning MAC addresses from ARP information.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
arp proxy-send enable
Use arp proxy-send enable to enable ARP request proxy.
Use undo arp proxy-send enable to disable ARP request proxy.
ARP request proxy is disabled on VSI interfaces.
VSI interface view
ARP request proxy allows a VSI interface to send an ARP request sourced from itself when the VTEP forwards an ARP request. This feature helps resolve certain communication issues.
In an EVPN VXLAN network, VM 1 and VM 2 are attached to VTEP 1 and VTEP 2, respectively, and the VMs are in the same subnet. The gateway interfaces of VM 1 and VM 2 are VSI-interface 1 on VTEP 1 and VSI-interface 2 on VTEP 2, respectively. The following conditions exist on the VTEPs:
· The VTEPs have established BGP EVPN neighbor relationships.
· EVPN is disabled from learning MAC addresses from ARP information.
· MAC address advertisement is disabled, and advertised MAC addresses are withdrawn.
· Remote-MAC address learning is disabled.
· Local proxy ARP is enabled on the VSI interfaces.
· The VSI interfaces use different IP addresses and MAC addresses.
In this network, when VM 1 attempts to communicate with VM 2, the following procedure occurs:
1. VM 1 sends an ARP request.
2. VTEP 1 learns the MAC address of VM 1 from the ARP request, replies to VM 1 on behalf of VM 2, and sends an ARP request to obtain the MAC address of VM 2.
3. VTEP 2 forwards the ARP request, and VM 2 replies to VTEP 1.
4. VTEP 2 forwards the ARP reply sent by VM 2 without learning the MAC address of VM 2 because EVPN is disabled from learning MAC addresses from ARP information.
5. VTEP 1 does not learn the MAC address of VM 2 because remote-MAC address learning is disabled.
As a result, VM 1 fails to communicate with VM 2.
For VM 1 to communicate with VM 2, enable ARP request proxy on VSI-interface 2 of VTEP 2. When receiving the ARP request sent by VTEP 1, VTEP 2 forwards it and sends an ARP request sourced from VSI-interface 2 simultaneously, and VM 2 replies to both ARP requests. Then, VTEP 2 learns the MAC address of VM 2 from the ARP reply destined from VSI-interface 2 and advertises the MAC address to VTEP 1 through BGP EVPN routes. In this way, VTEP 1 obtains the MAC address of VM 2, and VM 1 and VM 2 can communicate.
# Enable ARP request proxy on VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-vsi-interface100] arp proxy-send enable
local-proxy-arp enable (Layer 3—IP Services Command Reference)
arp-advertising disable
Use arp-advertising disable to disable ARP information advertisement for an EVPN instance.
Use undo arp-advertising disable to restore the default.
ARP information advertisement is enabled for an EVPN instance.
In an EVPN VXLAN network with distributed gateways, you can disable ARP information advertisement for a VXLAN network to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN network will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information. When ARP information advertisement is disabled, user terminals in other VXLANs networks still can communicate with that VXLAN through IP prefix advertisement routes.
# Disable ARP information advertisement for an EVPN instance of EVPN VXLAN.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] arp-advertising disable
bestroute ipv6-nexthop
Use bestroute ipv6-nexthop to enable BGP to prefer routes with an IPv6 next hop during optimal route selection.
Use undo bestroute ipv6-nexthop to restore the default.
BGP prefers routes with an IPv4 next hop during optimal route selection.
Execute this command for the VXLAN packets in an EVPN network to be forwarded through IPv6 routes when both IPv4 and IPv6 routes exist.
# In BGP EVPN address family view, enable BGP to prefer routes with an IPv6 next hop during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] bestroute ipv6-nexthop
Use display arp filter source service-instance to display ARP gateway protection configuration for Ethernet service instances.
display arp filter source service-instance [ interface interface-type interface-number [ service-instance instance-id ] ] [ slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ARP gateway protection configuration for Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays ARP gateway protection configuration for all Ethernet service instances on the specified interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ARP gateway protection configuration on the master device.
After you enable ARP gateway protection in Ethernet service instance view, use this command to view the ARP gateway protection configuration for Ethernet service instances.
# Display ARP gateway protection configuration for all Ethernet service instances on Twenty-FiveGigE 1/0/1 of slot 1.
<Sysname> display arp filter source service-instance interface twenty-fivegige 1/0/1 slot 1
Interface: twenty-fivegige 1/0/1
Service instance: 1
IPv4 address: 192.168.56.1
Drop count: 10
Service instance: 2
IPv4 address: 192.168.56.2
Drop count: 10
# Display ARP gateway protection configuration for Ethernet service instance 1 on Twenty-FiveGigE 1/0/1 of slot 1.
<Sysname> display arp filter source service-instance interface twenty-fivegige 1/0/1 instance 1 slot 1
Service instance: 1
Drop count: 10
# Display ARP gateway protection configuration for Ethernet service instances on all interfaces of slot 1.
<Sysname> display arp filter source service-instance slot 1
Service instance: 1
Drop count: 10
Service instance: 2
Drop count: 10
Interface: twenty-fivegige 1/0/2
Service instance: 2
Drop count: 10
Service instance |
Ethernet service instance ID. |
IPv4 address |
Protected gateway IP address. |
Drop count |
Number of packets dropped due to gateway protection. |
arp filter source
display bgp l2vpn evpn
Use display bgp l2vpn evpn to display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { imet | ip-prefix | mac-ip } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info | as-path | cluster-list | community | ext-community ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | rt route-target | soo site-of-origin | color color ]&<1-32> [ whole-match ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP EVPN routes for the default BGP instance.
peer { ipv4-address | ipv6-address }: Specifies a peer by its IPv4 address or IPv6 address.
advertised-routes: Specifies the routes advertised to the specified peer.
received-routes: Specifies the routes received from the specified peer.
statistics: Displays BGP EVPN route statistics.
route-distinguisher route-distinguisher: Specifies a route distinguisher (RD), a string of 3 to 21 characters. The RD can use one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
route-type: Specifies a route type.
imet: Specifies inclusive multicast Ethernet tag (IMET) routes.
ip-prefix: Specifies IP prefix advertisement routes.
mac-ip: Specifies MAC/IP advertisement routes.
evpn-route: Specifies a BGP EVPN route, a case-insensitive string of 1 to 512 characters.
route-length: Specifies the route length in bits, in the range of 0 to 65535.
evpn-prefix: Specifies a BGP EVPN route in the format of evpn-route/route-length, a case-insensitive string of 1 to 512 characters.
advertise-info: Displays advertisement information for BGP EVPN routes.
as-path: Specifies the AS path attribute.
cluster-list: Specifies the cluster list attribute.
community: Specifies the community attribute.
ext-community: Specifies the extended community attribute.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
mac-address: Specifies a MAC address in MAC/IP advertisement routes. If you specify the route-type keyword, to use this argument, you must also specify the mac-ip keyword.
community-number&<1-32>: Specifies a community sequence number. The value range for the community-number argument is 1 to 4294967295. &<1-32> indicates that a maximum of 32 numbers can be specified.
aa:nn&<1-32>: Specifies a community number. Both aa and nn are in the range of 0 to 65535. &<1-32> indicates that a maximum of 32 numbers can be specified.
internet: Specifies the INTERNET community attribute. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Specifies the NO_ADVERTISE community attribute. Routes with this attribute cannot be advertised to any BGP peers.
no-export: Specifies the NO_EXPORT community attribute. Routes with this attribute cannot be advertised outside the local AS or confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Specifies the NO_EXPORT_SUBCONFED community attribute. Routes with this attribute cannot be advertised outside the local AS or to other sub-ASs in the confederation.
whole-match: Displays BGP EVPN routes that exactly match the specified community list, community numbers, or extended community attribute. If you do not specify this keyword, the command displays BGP EVPN routes that include the specified community list, community numbers, or extended community attribute.
community-list: Specifies a community list to match BGP EVPN unicast routes.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
bandwidth link-bandwidth-value: Specifies the link bandwidth extended community attribute, a string of 3 to 16 characters. This attribute is in the format of 16-bit AS number:32-bit self-defined number, 100:3 for example. The value range is 0 to 65535 for an AS number and 0 to 4294967295 for a self-defined number.
color color: Specifies the color extended community attribute, a string of 4 to 13 characters. This attribute is in the format of binary Color-Only flag:decimal color value, 10:3 for example. The value range is 00 to 11 for the Color-Only flag and 0 to 4294967295 for the color value.
rt route-target: Specifies a route target, a string of 3 to 24 characters.
soo site-of-origin: Specifies the Site of Origin (SoO) extended community attribute, a string of 3 to 24 characters.
A route target or SoO attribute has the following forms:
· 16-bit AS number:32-bit self-defined number. For example, 101:3. The value range is 0 to 65535 for an AS number and 0 to 4294967295 for a self-defined number.
· 32-bit IP address:16-bit self-defined number. For example, 192.168.122.15:1. The value range is 0 to 65535 for a self-defined number.
· 32-bit AS number:16-bit self-defined number. For example, 70000:3. The value range is 65536 to 4294967295 for an AS number and 0 to 65535 for a self-defined number.
· 32-bit IP address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
· 32-bit AS number in dotted format:16-bit user-defined number. For example, 65535.65535:1.
&<1-32>: Specifies a maximum of 32 items.
If you do not specify any parameter, this command displays brief information about all BGP EVPN routes.
This command displays BGP EVPN routes that carry any community attribute and the whole-match keyword does not take effect if you do not specify the following parameters:
· community-number
· aa:nn
· internet
· no-advertise
· no-export
· no-export-subconfed
This command displays BGP EVPN routes that carry any extended community attribute and the whole-match keyword does not take effect if you do not specify the following parameters:
· bandwidth
· color
· rt
· soo
# Display brief information about all BGP EVPN routes.
<Sysname> display bgp l2vpn evpn
BGP local router ID is 1.1.1.9
a – additional-path
Total number of routes from all PEs: 6
Route distinguisher: 100:1
Total number of routes: 3
* > [2][0][48][00aa.00bb.00cc][4][0.0.0.0]/136
10.1.1.2 0 32768 ?
* e 10.1.1.1 0 0 65410?
* > [3][300][16][::ffff:1.1.1.1]/176
127.0.0.1 0 32768 ?
Route distinguisher: 200:1
Total number of routes: 2
* >i [2][0][48][00aa.00cc.00dd][4][1.1.1.1]/136
3.3.3.9 0 100 0 ?
* >i [3][300][16][::ffff:2.2.2.2]/176
3.3.3.9 0 100 0 65420?
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >e [2][0][48][0011.0022.0033][32][11.22.33.55]/136
30.30.1.2 0 0 100i
# Display all BGP EVPN routes that carry community attributes.
<Sysname> display bgp l2vpn evpn community
a – additional-path
Network NextHop MED LocPrf PrefVal Path/Ogn Community
10.1.1.2 0 32768 ? <1:2>
* e 10.1.1.1 0 0 65410? <2:3>
127.0.0.1 0 32768 ? <3:4>
# Display all BGP EVPN routes that carry extended community attributes.
<Sysname> display bgp l2vpn evpn ext-community
a – additional-path
Network NextHop MED LocPrf PrefVal Path/Ogn Ext-Community
10.1.1.2 0 32768 ? <RT 1:2>
* e 10.1.1.1 0 0 65410? <RT 2:3>
127.0.0.1 0 32768 ? <RT 3:4>
Status codes |
Route status codes: · * - valid—Valid route. · > - best—Optimal route. · d - dampened—Dampened route. · h - history—History route. · i - internal—Internal route. · e - external—External route. · s - suppressed—Suppressed route. · S - stale—Stale route. · a - additional-path—Add-Path optimal route. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. The origin of routes advertised by using the network command is IGP. · e – EGP—Learned through EGP. · ? – incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete. |
Network |
BGP EVPN route/route length. For example, in the entry [2][0][48][1485-247c-0506][32][10.1.2.20]/136, [2][0][48][1485-247c-0506][32][10.1.2.20] is the route, and 136 is the route length in bytes. BGP EVPN routes are as follows: · [1][ESI][EthernetTagID] ¡ 1—Ethernet auto-discovery route. ¡ ESI—Ethernet segment identifier (ESI). ¡ EthernetTagID—Ethernet tag ID. · [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress] ¡ 2—MAC/IP advertisement route. ¡ EthernetTagID—Ethernet tag ID. ¡ MACLength—MAC address length. ¡ MAC—MAC address. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address. · [3][EthernetTagID][IPAddressLength][IPAddress] ¡ 3—IMET route. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [4][ESI][IPAddressLength][IPAddress] ¡ 4—ES route. ¡ ESI—ESI. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [5][EthernetTagID][IPAddressLength][IPAddress] ¡ 5—IP prefix advertisement route. ¡ EthernetTagID—Ethernet tag ID. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [6][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 6—Selective multicast Ethernet tag route. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. · [7][ESI][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 7—IGMP join synch route. ¡ ESI—ESI. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. · [8][ESI][EthernetTagID] [Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP][ [LeaveGroup Synchronization] ¡ 8—IGMP leave synch route. ¡ ESI—ESI. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. ¡ LeaveGroup Synchronization—Leave group synchronization sequence number. |
NextHop |
Next hop IP address. |
MED |
Multi-Exit Discriminator (MED) attribute. |
LocPrf |
Local precedence. |
PrefVal |
Preferred value. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route. |
Community |
Community attribute. |
Ext-Community |
Extended community attribute. |
# Display detailed information about BGP EVPN route [1][00:01:02:03:04:05:06:07:08:09][5]/120 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][00:01:02:03:04:05:06:07:08:09][5] 120
BGP local router ID: 172.16.250.133
Local AS number: 100
Route distinguisher: 1.1.1.1:100
Paths: 1 available, 1 best
BGP routing table information of [1][00:01:02:03:04:05:06:07:08:09][5]/120:
Rely nexthop : 10.1.1.2
Original nexthop: 10.1.1.2
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN >, <ESI Label: Flag 0,
Label 1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Ethernet auto-discovery route
ESI : 00:01:02:03:04:05:06:07:08:09
Ethernet tag ID : 5
MPLS label : 10
Paths |
Number of routes: · available—Number of valid routes. · best—Number of optimal routes. |
From |
IP address of the BGP peer that advertised the route. |
Rely nexthop |
Next hop after route recursion. If no next hop is found, this field displays not resolved. |
Original nexthop |
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message. |
OutLabel |
Outgoing label of the route. |
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ESI Label. |
RxPathID |
Add-Path ID value of the received route. This field is not supported by the BGP EVPN address family. |
TxPathID |
Add-Path ID value of the sent route. This field is not supported by the BGP EVPN address family. |
AS-path |
AS_PATH attribute of the route. This attribute records the ASs the route has passed and avoids routing loops. |
Origin |
Origin of the route: · igp—Originated in the AS. The origin of routes advertised by using the network command is IGP. · egp—Learned through EGP. · incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete. |
Attribute value |
Attributes of the route: · MED—MED value for the destination network. · localpref—Local preference value. · pref-val—Preferred value. · pre—Route preference value. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · localredist—The route is redistributed from a local VPN instance or public instance. · reoriginated. |
IP precedence |
IP precedence in the range of 0 to 7. N/A indicates that the IP precedence is invalid. |
QoS local ID |
QoS local ID in the range of 1 to 4095. N/A indicates that the QoS local ID is invalid. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the traffic index is invalid. |
MPLS label |
MPLS label. The current software version does not support this field. |
# Display detailed information about BGP EVPN route [2][5][48][0001-0203-0405][32][4.5.5.5]/136 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
OutLabel : 0
Ext-Community : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
>, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
>, <Default GateWay>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : MAC/IP advertisement route
Ethernet tag ID : 5
MAC address : 0001-0203-0405
IP address : 5.5.5.5/32
MPLS label1 : 10
MPLS label2 : 0
Re-origination : Enable
Route distinguisher: 2.2.2.2:100
OutLabel : 0
>, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
State : valid, external, best, reoriginated, remoteredist
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
ESI : 0001.0203.0405.0607.0809
Ethernet tag ID : 5
MPLS label1 : 200
MPLS label2 : 300
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · Router's Mac. · Default GateWay—Route for the default gateway. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · reoriginated—Reoriginated route. · remoteredist—MAC/IP advertisement route generated based on a remote route. |
MPLS label1 |
VXLAN ID used for Layer 2 forwarding. |
MPLS label2 |
L3 VXLAN ID used for Layer 3 forwarding. |
Re-origination |
State of route reorigination: · Enable. · Disable. |
# Display detailed information about BGP EVPN route [3][0][32][5.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
BGP routing table information of [3][0][32][4.5.5.5]/80:
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
Attribute value : MED 0,pref-val 0
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Inclusive multicast Ethernet tag route
Ethernet tag ID : 0
Origin address : 5.5.5.5/32
Table 5 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. |
Origin address |
IP address of the originating router. |
# Display detailed information about BGP EVPN route [5][10][32][4.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
BGP routing table information of [5][10][32][4.5.5.5]/80:
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
0006-0708-0910>, <Priority-Color: (1:10:10)>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IP prefix advertisement route
ESI : 00:00:00:00:00:00:00:00:00:0a
Ethernet tag ID : 10
IP address : 4.5.5.5/32
Gateway address : 0.0.0.0
MPLS Label : 1
Table 6 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · Router's Mac. · Priority-Color. |
IP address |
IP address and prefix length. |
MPLS Label |
# Display detailed information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a] [32][4.5.5.5] 128 advertise-info
Paths: 1 best
BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128:
10.2.1.2
Inlabel : 1279
Table 7 Command output
Paths |
Advertised to peers (1 in total) |
Peers to whom the route has been advertised and the number of the peers. |
InLabel |
Incoming label, which is the private network label assigned by the local PE. |
# Display community attribute information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 community
BGP local router ID: 1.1.1.9
Community: no-export
# Display extended community attribute information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 ext-community
Ext-Community: <RT 1:1>
# Display the AS path attribute of BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 as-path
As-path: 80
# Display the cluster ID list attribute of BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 cluster-list
Cluster list: 80
Table 8 Command output
Paths |
Numbers of available routes and optimal routes. |
Community |
Ext-Community |
As-path |
AS path attribute. |
Cluster-list |
Cluster ID list attribute. |
# Display statistics about the BGP EVPN routes with community attributes.
<Sysname> display bgp l2vpn evpn statistics community
Total number of routes from all PEs: 1
Route distinguisher: 100:1(vpn1)
Total number of routes: 4
display bgp route-target evpn
Use display bgp route-target evpn to display the route targets sourced from the EVPN process and ES-import route targets for BGP.
display bgp [ instance instance-name ] route-target evpn
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays route targets for the default BGP instance.
Use this command to display the following information:
· ES-import route targets carried in the ES-Import Route Target extended community attribute.
· Route targets configured for all EVPN instances created in system view and VSI view.
The ES-Import Route Target extended community attribute is advertised with ES routes. An ES-import route target carried in this attribute is a 48-bit string that is automatically generated in the H-H-H format based on an ESI. The device accepts an ES route only if the ES-import route target carried in that route matches an ES-import route target created based on a local ESI.
In the command output, the route targets enumerated for each route target type cannot exceed 8191 bytes. Each character is one byte long. For example, 1:1 are three bytes. If this limit is reached, excess characters are replaced with three dots (…).
# Display the route targets sourced from the EVPN process and ES-import route targets for BGP.
<Sysname> display bgp route-target evpn
Total EVPN route target count: 6
EVPN import route-target count: 5
1:1 2:2 3:3 4:4 5:5
EVPN es-import route target count: 1
1111-2222-3333
Table 9 Command output
Total EVPN route target count |
Total number of EVPN route targets. |
EVPN import route-target count |
Number of import route targets configured for all EVPN instances created in system view and VSI view. |
EVPN es-import route target count |
Number of ES-import route targets. |
display evpn auto-discovery
Use display evpn auto-discovery to display information about peers that are automatically discovered through BGP.
display evpn auto-discovery { { imet | mac-ip } [ peer peer-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet: Specifies peers discovered through IMET routes.
peer peer-address: Specifies a peer by its IP address. If you do not specify this option, the command displays information about all automatically discovered peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays peer information for all VSIs.
macip-prefix: Specifies peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays peer information for all next hops.
count: Displays the number of peers. If you do not specify this keyword, the command displays detailed peer information.
# Display information about peers discovered through IMET routes for EVPN VXLAN.
<Sysname> display evpn auto-discovery imet
Total number of automatically discovered peers: 2
VSI name: vpna
EVPN instance: -
RD PE_address Tunnel_address Tunnel mode VXLAN ID
1:10 2.2.2.2 2.2.2.2 VXLAN 10
2:100 3.3.3.3 3.3.3.3 VXLAN 10
Table 10 Command output
EVPN instance |
EVPN instance name. If the EVPN instance is created on a VSI, this field displays a hyphen (-). |
PE_address |
Identifier of the remote VTEP on the VSI. |
Tunnel_address |
Tunnel destination IP address. |
Tunnel mode |
Tunnel mode: VXLAN. |
# Display information about IPv4 peers discovered through MAC/IP advertisement routes for EVPN VXLAN.
<Sysname> display evpn auto-discovery mac-ip
Total number of automatically discovered peers: 1
VSI name: vpna
EVPN instance: -
Destination IP Source IP VXLAN ID Tunnel mode Tunnel name
6.6.6.6 1.1.1.9 100 VXLAN Tunnel1
Table 11 Command output
EVPN instance |
Tunnel mode |
# Display information about peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
<Sysname> display evpn auto-discovery macip-prefix
Destination IP Source IP L3VNI Tunnel mode Outgoing interface
1.1.1.1 3.3.3.3 200 VXLAN Vsi-interface3
2.2.2.2 3.3.3.3 200 VXLAN Vsi-interface3
# Display the total number of peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
Table 12 Command output
Destination IP |
Source IP |
Tunnel source IP address. |
L3VNI |
Tunnel mode |
Outgoing interface |
VSI interface associated with the L3 VXLAN ID. |
Use display evpn m-lag synchronized-mac to display M-LAG-synchronized MAC address entries.
display evpn m-lag synchronized-mac [ vsi vsi-name ] [ count ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
count: Displays the number of MAC address entries that match the command. If you do not specify this keyword, the command displays detailed information about MAC address entries.
To ensure VM reachability information consistency in an M-LAG system, M-LAG member devices synchronize MAC address entries and ARP packets with each other through a peer link. This command displays the synchronized MAC address entries from an M-LAG peer.
# Display all M-LAG-synchronized MAC address entries.
<Sysname> display evpn m-lag synchronized-mac
VSI name: bbb
MAC address Link ID Interface
0000-0000-000a 1 BAGG10
0000-0000-0009 0 Tunnel1
# Display the total number of M-LAG-synchronized MAC address entries.
<Sysname> display evpn m-lag synchronized-mac count
Table 13 Command output
Link ID |
AC's or VXLAN tunnel's link ID on a VSI. |
Outgoing interface name. |
Use display evpn ipv6 auto-discovery to display information about IPv6 peers that are automatically discovered through BGP.
display evpn ipv6 auto-discovery { { imet | mac-ip } [ peer ipv6-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet: Specifies IPv6 peers discovered through IMET routes.
mac-ip: Specifies IPv6 peers discovered through MAC/IP advertisement routes.
peer ipv6-address: Specifies a peer by its IPv6 address. If you do not specify this option, the command displays information about all automatically discovered IPv6 peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv6 peer information for all VSIs.
macip-prefix: Specifies IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays IPv6 peer information for all next hops.
count: Displays the number of IPv6 peers. If you do not specify this keyword, the command displays detailed IPv6 peer information.
# Display information about IPv6 peers discovered through IMET routes for EVPN VXLAN.
<Sysname> display evpn ipv6 auto-discovery imet
VSI name: vpna
EVPN instance : -
RD : 1:10
PE address : 11::8
Tunnel address : 11::8
Tunnel mode : VXLAN
VXLAN ID : 10
RD : 2:100
PE address : 12::8
Tunnel address : 12::8
Tunnel mode : VXLAN
VXLAN ID : 10
Table 14 Command output
EVPN instance |
EVPN instance name. This field displays a hyphen (-) if no EVPN instance exists. |
PE address |
Tunnel address |
Tunnel mode |
# Display information about IPv6 peers discovered through MAC/IP advertisement routes that do not carry L3 VXLAN IDs for EVPN VXLAN.
<Sysname> display evpn ipv6 auto-discovery mac-ip
VSI name: vpna
Destination IP : 6:6::6:8
Source IP : 1:1::1:7
VXLAN ID : 100
Tunnel mode : VXLAN
Tunnel name : Tunnel1
Table 15 Command output
Destination IP |
Source IP |
Tunnel mode |
# Display information about IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
<Sysname> display evpn ipv6 auto-discovery macip-prefix
L3VNI : 100
Tunnel mode : VXLAN
OutInterface : Vsi-interface3
# Display the total number of IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
<Sysname> display evpn ipv6 auto-discovery macip-prefix count
Total number of entries: 1
Table 16 Command output
Destination IP |
Source IP |
L3VNI |
Tunnel mode |
OutInterface |
Use display evpn route arp to display EVPN ARP entries.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ip ipv4-address ] [ count ]
local: Specifies local ARP entries.
remote: Specifies remote ARP entries.
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
ip ipv4-address: Specifies an IPv4 address in dotted decimal notation. If you do not specify this option, the command displays all ARP entries that match the criteria you specify.
count: Displays the number of ARP entries. If you do not specify this keyword, the command displays detailed information about ARP entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays EVPN ARP entries for the public instance and all VPN instances.
# Display all EVPN ARP entries.
<Sysname> display evpn route arp
Flags: D - Dynamic B - BGP L - Local active
G - Gateway S - Static M - Mapping I - Invalid
E - Multihoming ES sync F - Leaf
VPN instance: vpn1 Interface: Vsi-interface1
IP address MAC address Router MAC VSI index Flags
10.1.1.1 0003-0003-0003 a0ce-7e40-0400 0 GL
10.1.1.11 0001-0001-0001 a0ce-7e40-0400 0 DL
10.1.1.12 0001-0001-0011 a0ce-7e41-0401 0 B
10.1.1.13 0001-0001-0021 a0ce-7e42-0402 0 B
Public instance Interface: Vsi-interface2
11.1.1.1 0033-0033-0033 a0ce-7e40-0400 0 GL
11.1.1.11 0011-0011-0011 a0ce-7e40-0400 0 DL
# Display the total number of EVPN ARP entries.
<Sysname> display evpn route arp count
Total number of entries: 6
Table 17 Command output
VSI interface. |
Router MAC |
Router MAC address of the device. A hyphen (-) is displayed for an SRv6 network with distributed gateways. |
Flags |
ARP entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. · E—The entry is synchronized between devices at a multihomed site. · F—The entry is from a leaf AC of EVPN E-tree. |
Use display evpn route arp suppression to display EVPN ARP flood suppression entries.
display evpn route arp suppression [ local | remote ] [ vsi vsi-name ] [ ip ipv4-address ] [ count ]
local: Specifies local ARP flood suppression entries.
remote: Specifies remote ARP flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ARP flood suppression entries for all VSIs.
ip ipv4-address: Specifies an IPv4 address in dotted decimal notation. If you do not specify this option, the command displays all ARP flood suppression entries that match the criteria you specify.
count: Displays the number of ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about ARP flood suppression entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP flood suppression entries.
# Display all EVPN ARP flood suppression entries.
<Sysname> display evpn route arp suppression
VSI name: vpna
EVPN instance: -
IP address MAC address Flags Encap
10.1.1.12 0002-0002-0002 B VXLAN
10.1.1.13 0002-0002-0002 BI VXLAN
10.1.1.101 0001-0011-0101 BS VXLAN
10.1.1.102 0001-0011-0102 DL VXLAN
# Display the total number of ARP flood suppression entries.
<Sysname> display evpn route arp suppression count
Table 18 Command output
EVPN instance |
Flags |
ARP flood suppression entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. · E—The entry is synchronized between devices at a multihomed site. · F—The entry is from a leaf AC of EVPN E-tree. |
Encap |
Packet encapsulation type: · VXLAN. |
Use display evpn route arp-mobility to display EVPN ARP mobility information.
display evpn route arp-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ] [ verbose ]
ip ip-address: Specifies an IPv4 address in dotted decimal notation. If you do not specify an IP address, this command displays ARP mobility information about all IP addresses of the public instance or MPLS L3VPN instance.
verbose: Displays detailed ARP mobility information. If you do not specify this keyword, the command displays brief ARP mobility information.
If you do not specify any parameters, this command displays ARP mobility information about the public instance and all VPN instances.
# Display EVPN ARP mobility information about the public instance and all VPN instances.
<Sysname> display evpn route arp-mobility
Flags: S - Suppressed, N - Not suppressed
VPN instance : vpn1
Interface : Vsi-interface1
IP address Move count Moved from Flags Suppressed at
192.168.156.120 5 25GE1/0/1 S 17:24:33 2018/04/01
192.168.56.20 - - N -
Public instance
Interface : Vsi-interface2
192.168.156.120 5 25GE1/0/2 S 17:24:33 2018/04/01
192.168.56.20 5 2.2.2.2 S 17:24:33 2018/04/01
Table 19 Command output
Move count |
Number of ARP moves from the interface to other interfaces. |
Moved from |
Source interface or source VTEP/PE IP address for the ARP move. |
Flags |
Whether the ARP move was suppressed: · S—Suppressed. · N—Not suppressed. |
Suppressed at |
Time when the ARP move was suppressed. |
# Display detailed EVPN ARP mobility information about the public instance and all VPN instances.
<Sysname> display evpn route arp-mobility verbose
VPN instance : vpn1
IP address : 192.168.156.120
Move count : 5
Moved from : 25GE1/0/1
Flags : Suppressed
Suppressed at : 17:24:33 2018/04/01
Suppression threshold: 5
Detection cycle : 180s
Suppression-time : Permanent
Table 20 Command output
Moved from |
Flags |
Whether the ARP move was suppressed: · Suppressed. · Not suppressed. |
Suppressed at |
Suppression threshold |
ARP mobility suppression threshold, which is the number of ARP moves from the local site to a remote site. If ARP mobility suppression is disabled or ARP moves are not suppressed, this field displays a hyphen (-). |
Detection cycle |
ARP mobility detection cycle in seconds. If ARP mobility suppression is disabled or ARP moves are not suppressed, this field displays a hyphen (-). |
Suppression time |
ARP mobility suppression time in seconds. Permanent indicates that ARP moves are suppressed permanently. If ARP mobility suppression is disabled or ARP moves are not suppressed, this field displays a hyphen (-). |
Use display evpn route mac to display EVPN MAC address entries.
display evpn route mac [ local | remote ] [ vsi vsi-name ] [ mac-address mac-address ] [ count ]
local: Specifies local MAC address entries.
remote: Specifies remote MAC address entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays MAC address entries for all VSIs.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a MAC address, this command displays all MAC address entries that match the criteria you specify.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
# Display all EVPN MAC address entries for EVPN VXLAN.
<Sysname> display evpn route mac
VSI name: bbb
EVPN instance: -
MAC address Link ID/Name Flags Encap Next hop
0000-0000-000a 1 DL VXLAN -
0000-0000-0009 Tunnel1 B VXLAN 2.2.2.2
0001-2000-4000 - BI VXLAN 3.3.3.3
# Display the total number of EVPN MAC address entries.
<Sysname> display evpn route mac count
Table 21 Command output
EVPN instance |
Link ID/Name |
For a local MAC address, this field displays the AC's link ID on the VSI. For a remote MAC address, this field displays the tunnel interface name. |
Flags |
MAC address entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. · E—The entry is synchronized between devices at a multihomed site. · F—The entry is from a leaf AC of EVPN E-tree. |
Encap |
Packet encapsulation type: VXLAN. |
Next hop |
IP address of the remote VTEP. If the MAC address entry is a local entry, a hyphen (-) is displayed. |
Use display evpn route mac-mobility to display EVPN MAC mobility information.
display evpn route mac-mobility [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac-address mac-address ] [ verbose ]
evpn-instance instance-name: Specifies an EVPN instance by its name, a case-sensitive string of 1 to 31 characters.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC mobility information about all VSIs.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a MAC address, this command displays MAC mobility information about all MAC addresses in the specified VSI or all VSIs.
verbose: Displays detailed MAC mobility information. If you do not specify this keyword, the command displays brief MAC mobility information.
If you do not specify any parameters, this command displays IPv4 EVPN MAC mobility information about all VSIs.
# Display IPv4 EVPN MAC mobility information about all VSIs.
<Sysname> display evpn route mac-mobility
VSI name : vsia
EVPN instance : -
MAC address Move count Moved from Flags Suppressed at
1000-0000-0000 10 25GE1/0/1 S 15:30:30 2018/03/30
1000-0000-0001 - - N -
VSI name : vsib
EVPN instance : -
1000-0000-0003 2 25GE1/0/2 N -
1000-0000-0005 10 5.5.5.5 S 17:24:33 2018/04/01
Table 22 Command output
EVPN instance |
EVPN instance name. If the EVPN instance is created on a VSI, this field displays a hyphen (-). This field is supported only by EVPN VXLAN. |
Move count |
Number of MAC moves from the interface to other interfaces. |
Moved from |
Source interface or source VTEP/PE IP address for the MAC move. |
Flags |
Whether the MAC move was suppressed: · S—Suppressed. · N—Not suppressed. |
Suppressed at |
Time when the MAC move was suppressed. |
# Display detailed IPv4 EVPN MAC mobility information about all VSIs.
<Sysname> display evpn route mac-mobility verbose
VSI name : vsia
MAC Address : 1000-0000-0000
Move count : 10
Flags : Suppressed
Suppressed at : 15:30:30 2018/03/30
Suppression threshold: 10
Table 23 Command output
Moved from |
Flags |
Whether the MAC move was suppressed: · Suppressed. · Not suppressed. |
Suppressed at |
MAC mobility suppression threshold, which is the number of MAC moves from the local site to a remote site. If MAC mobility suppression is disabled or MAC moves are not suppressed, this field displays a hyphen (-). |
Detection cycle |
MAC mobility detection cycle in seconds. If MAC mobility suppression is disabled or MAC moves are not suppressed, this field displays a hyphen (-). |
Suppression time |
MAC mobility suppression time in seconds. Permanent indicates that MAC moves are suppressed permanently. If MAC mobility suppression is disabled or MAC moves are not suppressed, this field displays a hyphen (-). |
Use display evpn route nd to display EVPN ND entries.
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ count ]
local: Specifies local ND entries.
remote: Specifies remote ND entries.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify this option, the command displays all ND entries that match the criteria you specify.
count: Displays the number of ND entries. If you do not specify this keyword, the command displays detailed information about ND entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ND entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays EVPN ND entries for the public instance and all VPN instances.
# Display all EVPN ND entries.
<Sysname> display evpn route nd
IPv6 address : AD80:0300:1000:0050:0200:0300:0100:0012
MAC address : 0001-0001-0001 Router MAC : a0ce-7e40-0400
VSI index : 0 Flags : GL
IPv6 address : AD10:0300:1000:0020:0200:0300:0100:0022
MAC address : 0001-0001-0002 Router MAC : a0ce-7e40-0411
Public instance Interface: Vsi-interface1
IPv6 address : BC80:0300:1000:0050:0200:0300:0100:0033
MAC address : 0002-0002-0001 Router MAC : a0ce-7e40-0422
IPv6 address : BC10:0300:1000:0020:0200:0300:0100:0034
MAC address : 0002-0002-0002 Router MAC : a0ce-7e40-0433
# Display the total number of EVPN ND entries.
<Sysname>display evpn route nd count
Table 24 Command output
VSI interface. |
Flags |
ND entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Use display evpn route nd suppression to display EVPN ND flood suppression entries.
display evpn route nd suppression [ local | remote ] [ vsi vsi-name ] [ ipv6 ipv6-address ] [ count ] [ verbose ]
local: Specifies local ND flood suppression entries.
remote: Specifies remote ND flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ND flood suppression entries for all VSIs.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify this option, the command displays all ND flood suppression entries that match the criteria you specify.
count: Displays the number of ND flood suppression entries. If you do not specify this keyword, the command displays detailed information about ND flood suppression entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ND flood suppression entries.
# Display all EVPN ND flood suppression entries.
<Sysname> display evpn route nd suppression
VSI name: vpna
IPv6 address MAC address Flags Encap
11::8 72cb-ce9b-0a06 DL VXLAN
11::9 0001-0001-0001 B VXLAN
# Display the total number of ND flood suppression entries.
<Sysname> display evpn route nd suppression count
Table 25 Command output
Flags |
ARP flood suppression entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Encap |
Use display evpn route nd-mobility to display EVPN ND mobility information.
display evpn route nd-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ verbose ]
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays ND mobility information about all IPv6 addresses of the public instance or MPLS L3VPN instance.
verbose: Displays detailed ND mobility information. If you do not specify this keyword, the command displays brief ND mobility information.
If you do not specify any parameters, this command displays ND mobility information about the public instance and all VPN instances.
# Display brief EVPN ND mobility information about the public instance and all VPN instances.
<Sysname> display evpn route nd-mobility
VPN instance : vpn1
IPv6 address : 1::1
Move count : 5
Flags : S
Suppressed at : 15:30:30 2020/03/30
Public instance
IPv6 address : 2::2
Move count : 5
Moved from : 20::20
Flags : S
Suppressed at : 17:24:33 2020/04/01
Table 26 Command output
Move count |
Number of ND moves from the interface to other interfaces. |
Moved from |
Source interface or source VTEP/PE IP address for the ND move. |
Flags |
Whether the ND move was suppressed: · Suppressed. · Not suppressed. |
Suppressed at |
Time when the ND move was suppressed. |
# Display detailed EVPN ND mobility information about the public instance and all VPN instances.
<Sysname> display evpn route nd-mobility verbose
VPN instance : vpn1
IPv6 address : 1::1
Move count : 5
Flags : Suppressed
IPv6 address : 1::1
Move count : 5
Flags : Suppressed
Table 27 Command output
Moved from |
Flags |
Suppressed at |
ND mobility suppression threshold, which is the number of ND moves from the local site to a remote site. If ND mobility suppression is disabled or ND moves are not suppressed, this field displays a hyphen (-). |
Detection cycle |
ND mobility detection cycle in seconds. If ND mobility suppression is disabled or ND moves are not suppressed, this field displays a hyphen (-). |
Suppression time |
Suppression time in seconds. If this field displays Permanent, ND moves are suppressed permanently. If ND mobility suppression is disabled or ND moves are not suppressed, this field displays a hyphen (-). |
evpn route nd-mobility suppression
display evpn routing-table
Use display evpn routing-table to display EVPN routing table information.
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
ipv6: Specifies IPv6 information. If you do not specify this keyword, the command displays IPv4 information.
count: Displays the number of entries in the routing table. If you do not specify this keyword, the command displays detailed information about the routing table.
# Display the EVPN IPv4 routing table for VPN instance vpn1 of an EVPN network with distributed gateways.
<Sysname> display evpn routing-table vpn-instance vpn1
Flags: E - with valid ESI A – A-D ready L - Local ES exists
VPN instance name: vpn1 Local L3VNI: 7
IP address Nexthop Outgoing interface NibID Flags
10.1.1.11 1.1.1.1 Vsi-interface3 0x18000000 -
10.1.1.12 2.2.2.2 Vsi-interface3 0x18000001 -
# Display the EVPN IPv4 routing table for the public instance of an EVPN network with distributed gateways.
<Sysname> display evpn routing-table public-instance
Public instance Local L3VNI: 3900
# Display the number of EVPN route entries in the IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1 count
# Display the EVPN IPv6 routing table for VPN instance vpna of an EVPN network with distributed gateways.
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
VPN instance: vpna Local L3VNI: 7
Outgoing interface : Vsi-interface3
Next hop : 1.1.1.1
NibID : 0x18000000
Flags : E
IPv6 address : BC10:0300:1000:0020:0200:0300:0100:0035
Next hop : 2.2.2.2
NibID : 0x18000001
Flags : E
Table 28 Command output
Local L3VNI |
L3 VXLAN ID associated with the VPN instance or the public instance. |
NibID |
Next hop ID. |
Flags |
Flags of the route: · E—The route carries a valid ESI. · A—An Ethernet auto-discovery route has been received. The ECMP routes to the next hop are ready to be issued. · L—A local active ESI exists. The remote route is not issued. |
evpn m-lag group
Use evpn m-lag group to enable EVPN M-LAG and specify the virtual VTEP address.
Use undo evpn m-lag group to restore the default.
evpn m-lag group { virtual-vtep-ipv4 | virtual-vtep-ipv6 }
EVPN M-LAG is disabled.
virtual-vtep-ipv4: Specifies the virtual IPv4 VTEP address.
virtual-vtep-ipv6: Specifies the virtual IPv6 VTEP address.
virtual-vtep-ip: Specifies the virtual VTEP address.
EVPN M-LAG virtualizes two VTEPs, EDs or EVPN gateways into one M-LAG system to avoid single points of failure. The VTEPs, EDs or EVPN gateways use a virtual VTEP address to establish VXLAN tunnels to remote devices.
For the device to re-establish tunnels, you must execute the address-family l2vpn evpn command in BGP instance view after you enable or disable EVPN M-LAG.
To change the virtual VTEP address, first execute the undo evpn m-lag group command to remove the original virtual VTEP address.
The evpn m-lag group and evpn m-lag local commands must specify three IPv4 or IPv6 addresses. Mixed use of IPv4 and IPv6 addresses is not allowed.
# Enable EVPN M-LAG and specify the virtual VTEP address as 1.1.1.1.
[Sysname] evpn m-lag group 1.1.1.1
evpn m-lag local
Use evpn m-lag local to specify the IP addresses of the VTEPs in an M-LAG system.
Use undo evpn m-lag local to restore the default.
evpn m-lag local { local-ipv4-address remote remote-ipv4-address | local-ipv6-address remote remote-ipv6-address }
The IP addresses of the VTEPs in an M-LAG system are not specified.
local-ipv4-address: Specifies the IPv4 address of the local VTEP.
local-ipv6-address: Specifies the IPv6 address of the local VTEP.
remote remote-ip: Specifies the IP address of the peer VTEP.
remote-ipv4-address: Specifies the IPv4 address of the peer VTEP.
remote-ipv6-address: Specifies the IPv6 address of the peer VTEP.
An AC that is attached to only one of the VTEPs in an M-LAG system is called a single-armed AC. After you configure this command, each VTEP in an M-LAG system changes the next hop of the routes for single-armed ACs to its local VTEP IP address when advertising the routes. This ensures that the traffic of a single-armed AC is forwarded to its attached VTEP. When a VTEP receives BGP EVPN routes from the peer VTEP IP address specified by using this command, it does not set up a VXLAN tunnel to the peer VTEP.
You must execute this command if single-armed ACs are attached to an M-LAG system with a direct peer link. You do not need to execute this command on an M-LAG system with a tunnel peer link. In such an M-LAG system, a VTEP uses the source IP address of the peer link as the next hop of routes for single-armed ACs to ensure correct traffic forwarding.
When you execute this command, make sure the IP address of the local VTEP belongs to a local interface. Make sure the local VTEP IP address and peer VTEP IP address are reversed on the VTEPs in an M-LAG system.
Do not use this command on EDs.
# Specify the IP addresses of the local and peer VTEPs in the M-LAG system as 2.2.2.2 and 3.3.3.3, respectively.
[Sysname] evpn m-lag local 2.2.2.2 remote 3.3.3.3
evpn encapsulation
Use evpn encapsulation to create an EVPN instance and enter its view, or enter the view of an existing EVPN instance.
Use undo evpn encapsulation to restore the default.
evpn encapsulation vxlan
No EVPN instance exists.
VSI view
vxlan: Specifies VXLAN encapsulation.
Before you can configure EVPN settings, you must create an EVPN instance.
# Create a VSI EVPN instance and enter its view.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
evpn global-mac
Use evpn global-mac to configure the EVPN global MAC address.
Use undo evpn global-mac to restore the default.
evpn global-mac mac-address
No EVPN global MAC address is configured.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address, broadcast MAC address, or all-zeros MAC address.
The EVPN global MAC address is used only by VSI interfaces associated with an L3 VXLAN ID.
For a VSI interface associated with an L3 VXLAN ID, the MAC address assigned to it by using the mac-address command takes precedence over the EVPN global MAC address.
Do not use a reserved MAC address as the EVPN global MAC address.
# Configure the EVPN global MAC address as 0001-0001-0001.
[Sysname] evpn global-mac 1-1-1
evpn irb asymmetric
Use evpn irb asymmetric to enable asymmetric IRB for EVPN VXLAN.
Use undo evpn irb asymmetric to restore the default.
evpn irb asymmetric [ route-policy route-policy-name ]
Symmetric IRB is enabled for EVPN VXLAN.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The device will perform asymmetric IRB forwarding for the traffic that matches the routing policy. If you do not specify a routing policy or the specified routing policy does not exist, the device performs asymmetric IRB forwarding for all traffic.
Use this command to set the IRB mode for EVPN VXLAN.
# Enable asymmetric IRB for EVPN VXLAN.
[Sysname] evpn irb asymmetric
evpn mac-ip advertise distributed-gateway
Use evpn mac-ip advertise distributed-gateway to enable the device to advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
Use undo evpn mac-ip advertise distributed-gateway to disable the device from advertising ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
By default, the device does not advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
If a distributed EVPN gateway has downstream VTEPs attached, the gateway advertises ARP information for gateway interfaces through IP prefix advertisement routes. Because the VTEPs do not have gateway configuration, they cannot learn the ARP information for the gateway interfaces or forward traffic to the gateway. For the VTEPs to learn ARP information for the gateway interfaces, enable the distributed EVPN gateway to advertise ARP information for the gateway interfaces through MAC/IP advertisement routes.
# Enable the device to advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
[Sysname] evpn mac-ip advertise distributed-gateway
evpn route arp-mobility suppression
Use evpn route arp-mobility suppression to enable ARP mobility event suppression.
Use undo evpn route arp-mobility suppression to disable ARP mobility event suppression.
evpn route arp-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
ARP mobility event suppression is disabled.
EVPN instance view
VSI EVPN instance view
Layer 3 interface view
detect-cycle detect-time: Sets the ARP mobility detection cycle in seconds, in the range of 60 to 900. The default value is 180 seconds.
detect-threshold move-times: Sets the ARP mobility suppression threshold, in the range of 3 to 10. The default is 5. This threshold is the number of ARP moves from the local site to remote sites.
suppression-time: Sets the ARP mobility suppression time. A suppressed ARP entry cannot move until the ARP mobility suppression time expires. If you do not set this parameter, the default setting permanent applies.
suppression-time: Specifies the ARP mobility suppression time in seconds, in the range of 120 to 3600 seconds.
permanent: Suppresses ARP moves permanently.
On an EVPN VXLAN network, misconfiguration of IP addresses might cause two sites to contain the same IP address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN ARP entries and determine that ARP mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ARP entry synchronization traffic. To eliminate loops and suppress those ARP mobility events, enable ARP mobility event suppression on the VTEPs.
The ARP mobility event suppression feature allows an IP address to move at most the specified number of times (ARP mobility suppression threshold) out of a site within an ARP mobility detection cycle. If the suppression threshold has been reached for an IP address within a detection cycle, the VTEP at the site suppresses the subsequent move after the IP address moves back to the site. In addition, the VTEP learns ARP information for the IP address but does not advertise the ARP information.
After you execute the undo evpn route arp-mobility suppression command or when the ARP mobility suppression time expires, a VTEP acts as follows:
· Advertises ARP information immediately for the suppressed ARP entries that have not aged out.
· Relearns ARP information for the suppressed ARP entries that have aged out and advertises the ARP information.
ARP mobility event suppression takes effect only on an EVPN VXLAN network configured with distributed VXLAN IP gateways.
The ARP mobility event suppression setting configured in system view takes effect on all EVPN instances. The ARP mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The ARP mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The ARP mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The ARP mobility event suppression settings configured in the following views are in descending order of priority:
1. Layer 3 interface view.
2. EVPN instance view or VSI EVPN instance view.
3. System view.
# Enable ARP mobility event suppression.
[Sysname] evpn route arp-mobility suppression
evpn route mac-mobility suppression
Use evpn route mac-mobility suppression to enable MAC mobility event suppression.
Use undo evpn route mac-mobility suppression to disable MAC mobility event suppression.
evpn route mac-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
MAC mobility event suppression is disabled.
EVPN instance view
detect-cycle detect-time: Sets the MAC mobility detection cycle in seconds, in the range of 60 to 900. The default value is 180 seconds.
detect-threshold move-times: Sets the MAC mobility suppression threshold, in the range of 3 to 10. The default is 5. This threshold is the number of MAC moves from the local site to remote sites.
suppression-time: Sets the MAC mobility suppression time. A suppressed MAC entry cannot move until the MAC mobility suppression time expires. If you do not set this parameter, the default setting permanent applies.
suppression-time: Specifies the MAC mobility suppression time in seconds, in the range of 120 to 3600 seconds.
permanent: Suppresses MAC moves permanently.
On an EVPN VXLAN network, misconfiguration of MAC addresses might cause two sites to contain the same MAC address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN MAC entries and determine that MAC mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by MAC entry synchronization traffic. To eliminate loops and suppress those MAC mobility events, enable MAC mobility event suppression on the VTEPs.
The MAC mobility event suppression feature allows a MAC address to move at most the specified number of times (MAC mobility suppression threshold) out of a site within an MAC mobility detection cycle. If the suppression threshold has been reached for a MAC address within a detection cycle, the VTEP at the site suppresses the subsequent move after the MAC address moves back to the site. In addition, the VTEP learns the MAC address but does not advertise it.
After you execute the undo evpn route mac-mobility suppression command or when the MAC mobility suppression time expires, a VTEP acts as follows:
· Advertises MAC address entries immediately for the suppressed MAC address entries that have not aged out.
· Relearns the MAC addresses for the suppressed MAC address entries that have aged out and advertises the MAC address entries.
The MAC mobility event suppression setting configured in system view takes effect on all EVPN instances. The MAC mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The MAC mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The MAC mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The MAC mobility event suppression settings configured in the following views are in descending order of priority:
3. System view.
# Enable MAC mobility event suppression.
[Sysname] evpn route mac-mobility suppression
Use evpn route nd-mobility suppression to enable ND mobility event suppression.
Use undo evpn route nd-mobility suppression to disable ND mobility event suppression.
evpn route nd-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
ND mobility event suppression is disabled.
EVPN instance view
detect-cycle detect-time: Specifies the ND mobility detection cycle in seconds. The value range for the detect-time argument is 60 to 900, and the default is 180.
detect-threshold move-times: Specifies the ND mobility suppression threshold, which is the number of ND moves from the local site to a remote site. The value range for the move-times argument is 3 to 10, and the default is 5.
suppression-time: Specifies the length of time that an ND entry is suppressed. After the suppression time expires, the ND entry can move again. The default suppression time is permanent.
suppression-time: Specifies the suppression time in seconds. The value range for this argument is 120 to 3600.
permanent: Suppresses ND moves permanently.
On an EVPN VXLAN network, misconfiguration of IP addresses might cause two sites to contain the same IP address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN ND entries and determine that ND mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ND entry synchronization traffic. To eliminate loops and suppress those ND mobility events, enable ND mobility event suppression on the VTEPs. This feature allows an IP address to move a specified number of times (the ND mobility suppression threshold) from a site within an ND mobility detection cycle. If an IP address moves more than the ND mobility suppression threshold, the VTEP at the site will suppress the last ND move to the local site and will not advertise ND information for the IP address.
After you execute the undo evpn route nd-mobility suppression command or the suppression time expires, a VTEP acts as follows:
· Advertises ND information immediately for the suppressed ND entries that have not aged out.
· Relearns ND information for the suppressed ND entries that have aged out and advertises the ND information.
ND mobility event suppression takes effect only on the following networks:
· EVPN VXLAN network enabled with ND flood suppression.
· EVPN VXLAN network configured with distributed VXLAN IP gateways.
The ND mobility event suppression setting configured in system view takes effect on all EVPN instances. The ND mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The ND mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The ND mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The ND mobility event suppression settings configured in the following views are in descending order of priority:
3. System view.
# Enable ND mobility event suppression.
[Sysname] evpn route nd-mobility suppression
evpn span-segment disable
Use evpn span-segment disable to disable a VSI interface from learning ARP or ND information that does not belong to its subnet from MAC/IP advertisement routes.
Use undo evpn span-segment disable to restore the default.
evpn span-segment { arp-learning | nd-learning } disable
undo evpn span-segment { arp-learning | nd-learning } disable
On a centralized EVPN gateway, a VSI interface can learn the ARP or ND information that does not belong to its subnet from MAC/IP advertisement routes.
VSI interface view
arp-learning: Disables ARP learning.
nd-learning: Disables ND learning.
On an EVPN VXLAN network deployed with a centralized EVPN gateway, VM 1 and VM 2 belong to the same VXLAN in subnet 10.1.1.0/24. The gateway interface is VSI-interface 1 and the gateway is connected to external Layer 3 network 10.1.2.0/24. The VTEP to which VM 2 is attached is configured with ARP or ND flood suppression. The IP address of VM 2 is mistakenly configured as an IP address in subnet 10.1.2.0/24 (for example, 10.1.2.2). In this situation, the VTEP connected to VM 2 advertises MAC/IP advertisement routes that contain ARP or ND information to the gateway. The IP address and MAC address in the routes are the IP address and MAC address of VM 2, respectively. The gateway learns the ARP or ND information and issues the information to the forwarding table. When VM 1 visits 10.1.2.2 in the external network, the gateway will forward the traffic to VM 2. As a result, VM 1 cannot visit 10.1.2.2.
To resolve the above issue, perform this task on the VSI interface to disable the VSI interface from learning ARP or ND information across subnets from MAC/IP advertisement routes.
# Disable a VSI-interface 1 from learning ARP or ND information that does not belong to its subnet from MAC/IP advertisement routes.
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] evpn span-segment arp-learning disable
igp-metric inherit
Use igp-metric inherit to set the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
Use undo igp-metric inherit to restore the default.
igp-metric inherit
The device sets the metric to 0 when adding BGP EVPN routes a VPN instance's routing table.
BGP EVPN address family view
After you execute this command, the device sets the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
# Set the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] igp-metric inherit
import evpn mac-ip
Use import evpn mac-ip to enable the device to redistribute received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table and advertise the routes.
Use undo import evpn mac-ip to restore the default.
import evpn mac-ip
For EVPN VXLAN, received MAC/IP advertisement routes (carrying VXLAN IDs) that contain ARP or ND information are not redistributed into any BGP unicast routing table.
For SRv6, received MAC/IP advertisement routes (carrying SIDs) that contain ARP or ND information are redistributed into BGP unicast routing tables, but the routes are not advertised.
BGP IPv4 unicast address family view
BGP IPv6 unicast address family view
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
This command enables the device to redistribute received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table.
· If you use this command in BGP IPv4 or IPv6 unicast address family view, the device will redistribute the routes into the BGP IPv4 or IPv6 unicast routing table. In addition, the device will advertise the routes to the local site.
· If you use this command in BGP-VPN IPv4 or IPv6 unicast address family view, the device will redistribute the routes into the BGP-VPN IPv4 or IPv6 unicast routing table of the corresponding VPN instance. To advertise the routes to the local site, you must configure the advertise l2vpn evpn command.
# Redistribute received MAC/IP advertisement routes into the BGP-VPN IPv4 unicast routing table of VPN instance vpna and advertise the routes.
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
ip forwarding-conversational-learning
Use ip forwarding-conversational-learning to enable conversational learning for host route FIB entries.
Use undo ip forwarding-conversational-learning to disable conversational learning for host route FIB entries.
ip forwarding-conversational-learning [ aging aging-time ]
Conversational learning is disabled for host route FIB entries.
aging aging-time: Specifies an aging timer in minutes for host route FIB entries, in the range of 60 to 1440. The default value is 60.
Use this command only on an EVPN network.
By default, the device issues a host route FIB entry to the hardware after the entry is generated. This feature enables the device to issue a host route FIB entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
Set an appropriate aging timer for host route FIB entries according to your network. A much longer or shorter aging timer will degrade the device performance.
· If the aging timer is too long, the device will save many outdated host route FIB entries and fail to accommodate the most recent network changes. These entries cannot be used for correct packet forwarding and exhaust FIB resources.
· If the aging timer is too short, the device will delete the valid host route FIB entries that can still be effective for packet forwarding. As a result, FIB entry flapping will occur, and the device performance will be affected.
# Enable conversational learning for host route FIB entries.
[Sysname] ip forwarding-conversational-learning
ip public-instance
Use ip public-instance to create the public instance and enter its view, or enter the view of the existing public instance.
Use undo ip public-instance to delete the public instance.
ip public-instance
The public instance does not exist.
A distributed EVPN gateway uses the public instance to perform Layer 3 forwarding for the public network and to enable communication between private and public networks. The public instance is similar to a VPN instance. A distributed EVPN gateway processes traffic of the public instance in the same way it does for a VPN instance.
# Create the public instance and enter its view.
[Sysname] ip public-instance
[Sysname-public-instance]
ipv6 nd proxy-send enable
Use ipv6 nd proxy-send enable to enable ND request proxy.
Use undo ipv6 nd proxy-send enable to disable ND request proxy.
ND request proxy is disabled on VSI interfaces.
VSI interface view
ND request proxy allows a VSI interface to send an ND request sourced from itself when the VTEP forwards an ND request. This feature helps resolve certain communication issues.
In an EVPN VXLAN network, VM 1 and VM 2 are attached to VTEP 1 and VTEP 2, respectively, and the VMs are in the same subnet. The gateway interfaces of VM 1 and VM 2 are VSI-interface 1 on VTEP 1 and VSI-interface 2 on VTEP 2, respectively. The following conditions exist on the VTEPs:
· The VTEPs have established BGP EVPN neighbor relationships.
· EVPN is disabled from learning MAC addresses from ND information.
· MAC address advertisement is disabled, and advertised MAC addresses are withdrawn.
· Remote-MAC address learning is disabled.
· Local proxy ND is enabled on the VSI interfaces.
· The VSI interfaces use different IP addresses and MAC addresses.
In this network, when VM 1 attempts to communicate with VM 2, the following process occurs:
1. VM 1 sends an NS packet.
2. VTEP 1 learns the MAC address of VM 1 from the NS packet, replies to VM 1 on behalf of VM 2, and sends an NS packet to obtain the MAC address of VM 2.
3. VTEP 2 forwards the NS packet, and VM 2 replies to VTEP 1.
4. VTEP 2 forwards the NA packet sent by VM 2 without learning the MAC address of VM 2 because EVPN is disabled from learning MAC addresses from ND information.
5. VTEP 1 does not learn the MAC address of VM 2 because remote-MAC address learning is disabled.
As a result, VM 1 fails to communicate with VM 2.
For VM 1 to communicate with VM 2, enable NS packet proxy on VSI-interface 2 of VTEP 2. When receiving the NS packet sent by VTEP 1, VTEP 2 forwards it and sends an NS packet sourced from VSI-interface 2 simultaneously, and VM 2 replies to both NS packets. Then, VTEP 2 learns the MAC address of VM 2 from the NA packet sent to VSI-interface 2 and advertises the MAC address to VTEP 1 through BGP EVPN routes. In this way, VTEP 1 obtains the MAC address of VM 2, and VM 1 and VM 2 can communicate.
# Enable ND request proxy on VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-vsi-interface100] ipv6 nd proxy-send enable
local-proxy-nd enable (Layer 3—IP Services Command Reference)
ipv6 nd ra tunnel-broadcast global enable
Use ipv6 nd ra tunnel-broadcast global enable to globally enable VSI interfaces to send RA messages over VXLAN tunnels.
Use undo ipv6 nd ra tunnel-broadcast global enable to globally disable VSI interfaces from sending RA messages over VXLAN tunnels.
VSI interfaces do not send RA messages over VXLAN tunnels.
By default, a distributed EVPN gateway drops the RS messages received from VXLAN tunnels and periodically advertises RA messages only to the local site. As a result, a distributed EVPN gateway does not send RA messages over VXLAN tunnels, and remote gateways cannot update information about the gateway based on RA messages. To resolve the issue, use this command to enable distributed EVPN gateways to reply to remote RS messages with RA messages and periodically advertise RA messages over VXLAN tunnels.
# Globally enable VSI interfaces to send RA messages over VXLAN tunnels.
[Sysname] ipv6 nd ra tunnel-broadcast global enable
ipv6 nd ra interval (Layer 3—IP Services Command Reference)
l2vpn m-lag peer-link ac-match-rule vxlan-mapping
Use l2vpn m-lag peer-link ac-match-rule vxlan-mapping to enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the Ethernet aggregate link peer link.
Use undo l2vpn m-lag peer-link ac-match-rule vxlan-mapping to restore the default.
On an M-LAG system with a direct peer link, dynamic ACs on the peer link use frame match criteria that are identical to those of site-facing ACs.
By default, if an M-LAG system uses a direct peer link, each M-LAG member device creates a dynamic AC on the peer link when an AC is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other. To prevent this issue, enable the M-LAG member devices to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link.
With this command configured, an M-LAG member device creates dynamic ACs on the peer link and maps them to the VSIs of VXLANs after the VXLANs are created. The matching VLAN IDs in frame match criteria are calculated for the dynamic ACs according to the following rules:
· Outer VLAN ID = VXLAN ID / 4094 + 1.
· Inner VLAN ID = VXLAN ID % 4094 + 1.
· If the calculated outer VLAN ID of a dynamic AC is the PVID of the peer-link interface, the device uses the calculated inner VLAN ID as the outer VLAN ID. The device does not add a matching inner VLAN ID to the frame match criterion of the dynamic AC.
After you execute this command, do not create VXLANs with IDs larger than 16000000.
This command deletes existing dynamic ACs from peer-link interfaces and takes effect on all VXLANs.
# Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the Ethernet aggregate link peer link.
[Sysname] l2vpn m-lag peer-link ac-match-rule vxlan-mapping
l2vpn m-lag peer-link tunnel
Use l2vpn m-lag peer-link tunnel to enable an M-LAG member device to automatically set up a VXLAN tunnel with the peer M-LAG member device.
Use undo l2vpn m-lag peer-link tunnel to disable an M-LAG member device from automatically setting up a VXLAN tunnel with the peer M-LAG member device.
l2vpn m-lag peer-link tunnel { source source-ipv4 destination destination-ipv4 | source source-ipv6 destination destination-ipv6 }
The M-LAG member devices in an M-LAG system do not set up a VXLAN tunnel between them.
source source-ipv4 destination destination-ipv4: Specifies source and destination IPv4 addresses for the automatically established VXLAN tunnel.
source source-ipv6 destination destination-ipv6: Specifies source and destination IPv6 addresses for the automatically established VXLAN tunnel.
This command applies to an M-LAG system with a direct peer link.
By default, the dynamic ACs created on the peer link use frame match criteria and VSI mappings identical to those of the site-facing ACs. If you configure the same frame match criterion for the site-facing ACs of different VSIs, the dynamic ACs created for the site-facing ACs will conflict with each other. To resolve this issue, use this command to enable the M-LAG member devices to automatically set up a VXLAN tunnel between them.
After you execute this command, the M-LAG member devices no longer create dynamic ACs on the peer link. Instead, they set up a VXLAN tunnel and assign it to all VXLANs. The VXLAN tunnel and the peer link transmit different types of traffic.
· The VXLAN tunnel is used to forward data traffic. When a site-facing AC on one M-LAG member device fails, the device forwards the remote packets destined for the AC to the other M-LAG member device over the VXLAN tunnel. The remote packets are encapsulated with the VXLAN ID of the failed site-facing AC. When the other M-LAG member device receives the packets, it decapsulates them and forwards them in the VXLAN where they belong.
· The peer link is used to exchange M-LAG protocol packets and synchronize MAC and ARP entries.
The l2vpn m-lag peer-link tunnel and l2vpn m-lag peer-link ac-match-rule vxlan-mapping commands are mutually exclusive. Do not use them together.
If you use this command on an M-LAG system with a tunnel peer link, the M-LAG member devices do not assign the automatically established VXLAN tunnel to VXLANs and thus cannot use it to forward traffic.
To change the tunnel source and destination addresses, first execute the undo l2vpn m-lag peer-link tunnel command to delete the existing VXLAN tunnel.
# Enable the device to set up a VXLAN tunnel with its M-LAG peer. Specify the source and destination IPv4 addresses of the VXLAN tunnel as 1.1.1.1 and 2.2.2.2, respectively.
[Sysname] l2vpn m-lag peer-link tunnel source 1.1.1.1 destination 2.2.2.2
l2vpn statistics vsi l3-vni
Use l2vpn statistics vsi l3-vni to enable traffic statistics for the VSIs that are automatically created for L3 VXLAN IDs.
Use undo l2vpn l3-vni vsi statistics to disable traffic statistics for the VSIs that are automatically created for L3 VXLAN IDs.
undo l2vpn statistics vsi l3-vni
The traffic statistics feature is disabled for the VSIs that are automatically created for L3 VXLAN IDs.
If you configure an L3 VXLAN ID on a distributed EVPN gateway, the gateway automatically creates a VSI for the L3 VXLAN ID. You cannot enter the view of such a VSI to configure settings on it.
This command enables the device to collect incoming and outgoing traffic statistics for the automatically created VSIs. You can use the display l2vpn vsi verbose command to view the traffic statistics and use the reset l2vpn statistics vsi command to clear the traffic statistics.
# Enable traffic statistics for the VSIs that are automatically created for L3 VXLAN IDs.
[Sysname] l2vpn statistics vsi l3-vni
display l2vpn vsi verbose (VXLAN Command Reference)
reset l2vpn statistics vsi (VXLAN Command Reference)
l3-vni
Use l3-vni to configure an L3 VXLAN ID for a VSI interface or for the public instance.
Use undo l3-vni to remove the L3 VXLAN ID for a VSI interface or for the public instance.
l3-vni vxlan-id
undo l3-vni
No L3 VXLAN ID is configured for a VSI interface or for the public instance.
VSI interface view
Public instance view
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215.
On distributed EVPN gateways, you must configure L3 VXLAN IDs for the gateways to differentiate traffic of different VPN instances.
To forward Layer 3 traffic of a VPN instance, you must assign an L3 VXLAN ID to the VSI interface of the VPN instance. To forward Layer 3 traffic of the public network, you must assign the same L3 VXLAN ID to the public instance and the VSI interface of the public instance.
To modify the L3 VXLAN ID for the public instance, you must first delete the original L3 VXLAN ID.
The L3 VXLAN ID specified by using this command cannot be the same as any VXLAN ID specified by using the mapping vni command.
# Configure the L3 VXLAN ID as 1000 for VSI-interface 100.
[Sysname-Vsi-interface100] l3-vni 1000
mac-advertising disable
Use mac-advertising disable to disable MAC address advertisement and withdraw advertised MAC addresses.
Use undo mac-advertising disable to restore the default.
MAC address advertisement is enabled.
The MAC information and ARP information advertised by the VTEP overlap. To avoid duplication, use this command to disable MAC address advertisement and withdraw the MAC addresses advertised to remote devices.
# Disable MAC address advertisement and withdraw advertised MAC addresses for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
nd-advertising enable
Use nd-advertising enable to enable ND information advertisement.
Use undo nd-advertising enable to disable ND information advertisement and withdraw advertised ND information.
ND information advertisement is enabled.
EVPN instance view
In an EVPN network with distributed gateways, you can disable ND information advertisement for a VXLAN to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN will stop advertising ND information through MAC/IP advertisement routes and withdraw advertised ND information. When ND information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
# Disable ND information advertisement for a VSI EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] undo nd-advertising enable
nd mac-learning disable
Use nd mac-learning disable to disable a VSI EVPN instance from learning MAC addresses from ND information.
Use undo nd mac-learning disable to restore the default.
A VSI EVPN instance learns MAC addresses from ND information.
The MAC information and ND information advertised by a remote VTEP overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ND information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable a VSI EVPN instance from learning MAC addresses from ND information.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] nd mac-learning disable
nexthop recursive-lookup default-route ignore
Use nexthop recursive-lookup default-route ignore to enable the device to ignore default routes in route recursion.
Use undo nexthop recursive-lookup default-route ignore to restore the default.
nexthop recursive-lookup default-route ignore [ route-policy route-policy-name ]
The device can select a default route for forwarding after performing route recursion.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The device will ignore default routes when performing route recursion for the routes that match the if-match interface criterion in the routing policy. If you do not specify a routing policy or the specified routing policy does not exist, the device ignores default routes when performing route recursion for all received BGP routes.
CAUTION: After you execute this command, VXLAN tunnels might be reestablished, and transient VXLAN traffic loss might occur. As a best practice, enable BGP EVPN route reception and advertisement again after you execute this command. |
By default, the device selects a default route to forward traffic if only the default route is obtained after BGP route recursion. If the default route does not point to the desired next hop, traffic forwarding will fail.
To resolve this issue, enable the device to ignore default routes in route recursion. If only the default route is obtained after route recursion is performed for a BGP route, that BGP route becomes invalid, and other BGP routes with the same prefix are selected for forwarding.
Enable this feature if multiple links exist between the device and a destination IP address. If one of the links fail, traffic will be switched to the other available links instead of being incorrectly forwarded based on a default route.
# Enable the device to ignore default routes when it performs route recursion for the BGP EVPN routes that match routing policy policy1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] nexthop recursive-lookup default-route ignore route-policy policy1
if-match interface (Layer 3—IP Routing Command Reference)
peer default-gateway no-advertise
Use peer default-gateway no-advertise to remove the default-gateway extended community attribute from the EVPN gateway routes advertised to a peer or peer group.
Use undo peer default-gateway no-advertise to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
EVPN gateway routes advertised to peers and peer groups contain the default-gateway extended community attribute.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv4-address: Specifies a peer by its IPv4 address. The peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
An EVPN gateway route is the route for the IP address of a VSI interface on an EVPN gateway. By default, the EVPN gateway routes advertised by an EVPN gateway contain the default-gateway extended community attribute. The EVPN gateway routes with that attribute cannot be used as ECMP routes. You can use this command to remove the default-gateway extended community attribute from EVPN gateway routes for the routes to be used for load sharing.
# Remove the default-gateway extended community attribute from the EVPN gateway routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 default-gateway no-advertise
policy vpn-target
Use policy vpn-target to enable route target filtering for BGP EVPN routes.
Use undo policy vpn-target to disable route target filtering for BGP EVPN routes.
policy vpn-target
Route target filtering is enabled for BGP EVPN routes.
When route target filtering is enabled for BGP EVPN routes, the EVPN routing table accepts only BGP EVPN routes of which the export route targets match the local import route targets. If the device must save all BGP EVPN routes, use the undo policy vpn-target command to disable route target filtering for BGP EVPN routes.
# Disable route target filtering for BGP EVPN routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
reset evpn route arp-mobility suppression
Use reset evpn route arp-mobility suppression to cancel ARP mobility event suppression.
reset evpn route arp-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ip ip-address ] ]
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
ip ip-address: Specifies an IPv4 address in dotted decimal notation. If you do not specify an IPv4 address, this command cancels the suppression done on all ARP entries of the public instance or specified MPLS L3VPN instance.
Use this command to cancel the ARP mobility event suppression done on IPv4 addresses. After you cancel suppression for an IPv4 address, the IPv4 address can move between sites, and the device advertises ARP information for the IPv4 address. The device still suppresses the IPv4 address if the suppression criteria are met.
If you do not specify the public instance or an MPLS L3VPN instance, this command cancels ARP mobility event suppression for the public instance and all MPLS L3VPN instances.
# Cancel the ARP mobility event suppression done on 1.1.1.1 of VPN instance vpna.
<Sysname> reset evpn route arp-mobility suppression vpn-instance vpna ip 1.1.1.1
reset evpn route nd-mobility suppression
Use reset evpn route nd-mobility suppression to cancel ND mobility event suppression.
reset evpn route nd-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ipv6 ipv6-address ] ]
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command cancels suppression on all ND entries of the public instance or specified MPLS L3VPN instance.
Use this command to cancel the ND mobility event suppression done on IPv6 addresses. After you cancel suppression for an IPv6 address, the IPv6 address can move between sites, and the device advertises ND information for the IPv6 address. The device still suppresses the IPv6 address if the suppression criteria are met.
If you do not specify the public instance or an MPLS L3VPN instance, this command cancels ND mobility event suppression for the public instance and all MPLS L3VPN instances.
# Cancel the ND mobility event suppression done on 1::1 of VPN instance vpna.
<Sysname> reset evpn route nd-mobility suppression vpn-instance vpna ipv6 1::1
route-distinguisher
Use route-distinguisher to configure an RD for an EVPN instance or public instance.
Use undo route-distinguisher to restore the default.
In public instance view:
In VSI EVPN instance (VXLAN encapsulation) view:
route-distinguisher { route-distinguisher | auto }
No RD is configured for an EVPN instance or public instance.
Public instance
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD cannot be all zeros and can use one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
auto: Automatically generates an RD in the N:VXLAN ID format. The initial value of N is 1. If N:VXLAN ID is already in use, the system increases the value of N by 1 until the RD is available.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses the RD to differentiate BGP EVPN routes of different EVPN instances.
To modify the RD, first execute the undo route-distinguisher command to remove the original RD.
# Configure 22:1 as the RD of an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
rr-filter { ext-comm-list-number | ext-comm-list-name }
undo rr-filter
An RR does not filter reflected BGP EVPN routes.
ext-comm-list-number: Specifies an extended community attribute list by its number in the range of 1 to 65535.
ext-comm-list-name: Specifies an extended community attribute list by its name, a case-sensitive string of 1 to 63 characters.
This command enables an RR to reflect only received BGP EVPN routes that match the attributes in the specified extended community attribute list.
If a cluster contains multiple RRs, you can configure different reflection policies on the RRs for load sharing among the RRs.
For more information about the extended community attribute list, see Layer 3—IP Routing Configuration Guide.
# Configure a reflection policy for the device to reflect BGP EVPN routes that match extended community attribute list 10.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
snmp-agent trap enable evpn
Use snmp-agent trap enable evpn to enable SNMP notifications for EVPN.
snmp-agent trap enable evpn [ mac-mobility-suppression ]
undo snmp-agent trap enable evpn [ mac-mobility-suppression ]
SNMP notifications are disabled for EVPN.
mac-mobility-suppression: Specifies the MAC mobility suppression notification.
If SNMP notifications are enabled for EVPN, a MAC mobility suppression notification is sent to SNMP module after the MAC mobility suppression threshold is reached. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
If you do not specify any parameter, all EVPN notifications are enabled or disabled.
# Enable SNMP notifications for EVPN.
[Sysname] snmp-agent trap enable evpn
vpn-route cross multipath
Use vpn-route cross multipath to enable ECMP VPN route redistribution.
Use undo vpn-route cross multipath to disable ECMP VPN route redistribution.
ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table.
ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table.
# Enable ECMP VPN route redistribution.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
vpn-target
Use vpn-target to configure route targets for EVPN.
Use undo vpn-target to delete route targets for EVPN.
In VSI EVPN instance view (VXLAN encapsulation):
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN instance EVPN view, public instance view, public instance IPv4 address family view, public instance IPv6 address family view, public instance EVPN view:
EVPN does not have route targets.
Public instance EVPN view
Public instance IPv4 address family view
Public instance IPv6 address family view
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets. Each route target is a string of 3 to 21 characters in one of the following formats:
auto: Automatically generates a route target in the format of BGP AS number:VXLAN ID.
both: Uses the specified route targets as both import and export targets. If you do not specify the both, export-extcommunity, or import-extcommunity keyword, the both keyword applies.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Specifies all route targets.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses route targets to control the advertisement and acceptance of BGP EVPN routes.
A VTEP sets the export targets for BGP EVPN routes before advertising the routes to remote VTEPs. The VTEP checks the export targets of BGP EVPN routes from remote VTEPs and imports only BGP EVPN routes of which the export targets match the local import targets.
If you execute this command multiple times, all configured route targets take effect.
# Configure import route targets 10:1, 100:1, and 1000:1 for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
