- 18-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-NTP commands
- 05-PTP commands
- 06-SNMP commands
- 07-RMON commands
- 08-Event MIB commands
- 09-Sampler commands
- 10-Mirroring commands
- 11-sFlow commands
- 12-VCF fabric commands
- 13-Cloud connection commands
- 14-Performance management commands
- 15-IPv6 NetStream commands
- 16-NetStream commands
- 17-NetAnalysis commands
- 18-SQA commands
- 19-CWMP commands
17-NetAnalysis commands | 109.58 KB |
display netanalysis rocev2 cache
display netanalysis rocev2 statistics
netanalysis rocev2 drop global
netanalysis rocev2 report-interval
netanalysis rocev2 timeout inactive
reset netanalysis rocev2 statistics
Use display netanalysis rocev2 cache to display the configuration and status of the RoCEv2 cache.
display netanalysis rocev2 cache [ destination destination-ip | source source-ip ]*
destination destination-ip: Specifies a server IP address.
source source-ip: Specifies a client IP address.
The device uses the RoCEv2 cache to save RoCEv2 traffic statistics after receiving RoCEv2 flows. When an RoCEv2 flow ages out, the device deletes the related traffic statistics from the RoCEv2 cache.
# Display the configuration and status of the RoCEv2 cache when bidirectional mode is used for RoCEv2 traffic analysis.
<Sysname> display netanalysis rocev2 cache source 1.1.1.2 destination 2.2.2.1
S2D: source to destination D2S: destination to source
RTT: round trip time RPT: packet throughput in read mode
WPT: packet throughput in write mode SPT: packet throughput in send mode
I: input O: output L: local R: remote
NetAnalysis cache information:
Flow created at Service type
Src IP Src QP S2D RTT S2D RPT S2D SPT/WPT
S2D NAK Pkts S2D Interface(I) S2D Interface(O)
S2D Src VXLAN ID S2D Dst VXLAN ID
Dst IP Dst QP D2S RTT D2S RPT D2S SPT/WPT
D2S NAK Pkts D2S Interface(I) D2S Interface(O)
D2S Src VXLAN ID D2S Dst VXLAN ID
01/22/2019 09:08:15 RC
1.1.1.2 93309 50 11 11
2 25GE1/0/1(L) 25GE1/0/2(L)
10 10
2.2.2.1 85353 50 11 11
8373 25GE1/0/2(L) 25GE1/0/1(L)
10 10
NOTE: S2D: source to destination D2S: destination to source RTT: round trip time RPT: packet throughput in read mode WPT: packet throughput in write mode SPT: packet throughput in send mode I: input O: output L: local R: remote |
Meanings of the acronyms: · S2D—Statistics about an RoCEv2 flow sent from a client to a server. · D2S—Statistics about an RoCEv2 flow sent from a server to a client. · RTT—RTT for an RoCEv2 flow. · RPT—Read packet throughput. · WPT—Write packet throughput. · SPT—Send packet throughput. · I—Incoming interface for an RoCEv2 flow. · O—Outgoing interface for an RoCEv2 flow. · L—Local interface. · R—Interface on an M-LAG peer. |
NetAnalysis cache information |
Configuration and status of the RoCEv2 cache. |
Flow created at |
Time when the RoCEv2 flow was created. |
Service type |
Service type of the RoCEv2 flow: · RC—Reliable connection. · UC—Unreliable connection. This value is not supported in the current software version. · RD—Reliable datagram. This value is not supported in the current software version. · UD—Unreliable datagram. · XRC—Extended reliable connection. This value is not supported in the current software version. |
Src IP |
Client IP address for the RoCEv2 flow. |
Dst IP |
Server IP address for the RoCEv2 flow. |
Src QP |
Client QP for the RoCEv2 flow. |
Dst QP |
Server QP for the RoCEv2 flow. |
S2D RPT |
Throughput in KBps for the Read packets sent from the client. |
D2S RPT |
Throughput in KBps for the Read packets sent from the server. |
S2D SPT/WPT |
Throughput in KBps for the Send and Write packets sent from the client. |
D2S SPT/WPT |
Throughput in KBps for the Send and Write packets sent from the server. |
S2D RTT |
RTT in microseconds for the RoCEv2 flow sent from the client. |
D2S RTT |
RTT in microseconds for the RoCEv2 flow sent from the server. |
S2D NAK Pkts |
Number of NAK packets sent from the client. Packet loss has occurred if this field is not 0. |
D2S NAK Pkts |
Number of NAK packets sent from the server. Packet loss has occurred if this field is not 0. |
S2D Interface(I) |
Incoming interface for the RoCEv2 flow sent from the client. |
S2D Interface(O) |
Outgoing interface for the RoCEv2 flow sent from the client. |
D2S Interface(I) |
Incoming interface for the RoCEv2 flow sent from the server. |
D2S Interface(O) |
Outgoing interface for the RoCEv2 flow sent from the server. |
S2D Src VXLAN ID |
This field is not supported in the current software version. Source VXLAN ID of the RoCEv2 flow sent from the client. A value of N/A indicates non-VXLAN flow table. |
S2D Dst VXLAN ID |
This field is not supported in the current software version. Destination VXLAN ID for the RoCEv2 flow originating from the client. A value of N/A indicates non-VXLAN flow table. |
D2S Src VXLAN ID |
This field is not supported in the current software version. Source VXLAN ID for the RoCEv2 flow returned from the server. A value of N/A indicates non-VXLAN flow table. |
D2S Dst VXLAN ID |
This field is not supported in the current software version. Destination VXLAN ID for the RoCEv2 flow returned from the server. A value of N/A indicates non-VXLAN flow table. |
# Display the configuration and status of the RoCEv2 cache when unidirectional mode is used for RoCEv2 traffic analysis.
<sysname> display netanalysis rocev2 cache source 1.1.1.2 destination 2.2.2.1
Src IP Dst IP Src QP Dst QP
Interface(I) Interface(O) RPT SPT/WPT
Src VXLAN ID Dst VXLAN ID
1.1.1.2 2.2.2.1 N/A 8373
25GE1/0/1(L) 25GE1/0/2(L) 11 11
10 10
NOTE: RPT: packet throughput in read mode WPT: packet throughput in write mode SPT: packet throughput in send mode I: input O: output L: local R: remote |
Meanings of the acronyms: · RPT—Read packet throughput. · WPT—Write packet throughput. · SPT—Send packet throughput. · I—Incoming interface for an RoCEv2 flow. · O—Outgoing interface for an RoCEv2 flow. · L—Local interface. · R—Interface on an M-LAG peer. |
Flow created at |
Service type |
Src IP |
Source IP address for the RoCEv2 flow. |
Dst IP |
Destination IP address for the RoCEv2 flow. |
Src QP |
Source QP for the RoCEv2 flow. |
Dst QP |
Destination QP for the RoCEv2 flow. |
RPT |
Throughput in KBps for Read packets. |
SPT/WPT |
Throughput in KBps for the Send and Write packets |
NAK Pkts |
Number of NAK packets. Packet loss has occurred if this field is not 0. |
Interface(I) |
Incoming interface for the RoCEv2 flow. |
Interface(O) |
Outgoing interface for the RoCEv2 flow. |
Src VXLAN ID |
This field is not supported in the current software version. Source VXLAN ID for the RoCEv2 flow. A value of N/A indicates non-VXLAN flow table. |
Dst VXLAN ID |
This field is not supported in the current software version. Destination VXLAN ID for the RoCEv2 flow. A value of N/A indicates non-VXLAN flow table. |
Use display netanalysis rocev2 statistics to display RoCEv2 traffic statistics.
# Display RoCEv2 traffic statistics when bidirectional mode is used for RoCEv2 traffic analysis.
<Sysname> display netanalysis rocev2 statistics
Last statistics resetting time: Never
Received packets: 1833088
Active Aged Created Reported
(Sessions) (Sessions) (Sessions) (Sessions)
RoCEv2
2 0 2 10
# Display RoCEv2 traffic statistics when unidirectional mode is used for RoCEv2 traffic analysis.
Received packets: 2833088
(Flows) (Flows) (Flows) (Flows)
RoCEv2
4 0 2 20
Last statistics resetting time |
Time when the RoCEv2 traffic statistics were last cleared. |
Received packets |
Number of received RoCEv2 packets. |
Type |
Flow type. The current software version supports only the RoCEv2 flow type. |
Active (Flows) |
Number of active flows. |
Aged (Flows) |
Number of aged flows. |
Created (Flows) |
Number of created flows. |
Reported (Flows) |
Number of flows reported to the NDA. |
Active (Sessions) |
Number of active sessions. |
Aged (Sessions) |
Number of aged sessions. |
Created (Sessions) |
Number of created sessions. |
Reported (Sessions) |
Number of sessions reported to the NDA. |
Use netanalysis rocev2 drop global to enable RoCEv2 packet loss analysis globally.
Use undo netanalysis rocev2 drop global to disable RoCEv2 packet loss analysis globally.
RoCEv2 packet loss analysis is disabled globally.
For RoCEv2 packet loss analysis to take effect, first enable bidirectional mode for RoCEv2 traffic analysis.
This command enables the device to perform RoCEv2 packet loss analysis for all received RoCEv2 packets.
To view RoCEv2 packet loss statistics, examine the S2D NAK Pkts and D2S NAK Pkts fields in the output from the display netanalysis rocev2 cache command.
# Enable RoCEv2 packet loss analysis globally.
[Sysname] netanalysis rocev2 drop global
netanalysis rocev2 mode
Use netanalysis rocev2 mode to set the mode of RoCEv2 traffic analysis.
Use undo netanalysis rocev2 mode to restore the default.
netanalysis rocev2 mode { bidir | single }
RoCEv2 traffic analysis is disabled, and the mode of RoCEv2 traffic analysis is not set.
bidir: Specifies bidirectional mode. In this mode, NetAnalysis collects RoCEv2 traffic statistics based on RoCEv2 sessions and provides the RTT and lost packet count for each RoCEv2 session.
single: Specifies unidirectional mode. In this mode, NetAnalysis collects RoCEv2 traffic statistics based on RoCEv2 flows and does not provides the flow-specific RTT or lost packet count.
For NetAnalysis features to take effect, first set the mode of RoCEv2 traffic analysis.
When you change the mode of RoCEv2 traffic analysis, all NetAnalysis configuration and the RoCEv2 cache are cleared. Make sure you are fully aware of the impact of this operation when you perform it on a live network.
For IPCC to take effect when you enable both NetAnalysis and IPCC on the device, make sure NetAnalysis operates in bidirectional mode. For more information about IPCC, see Intelligent Lossless Network Configuration Guide.
When multiple paths exist between an RDMA client and an RDMA server, set the mode of RoCEv2 traffic analysis as follows to ensure correct RoCEv2 traffic analysis:
· Enable bidirectional mode on the devices attached to the server and the client.
· Enable unidirectional mode on the intermediate devices.
# Enable unidirectional RoCEv2 traffic analysis.
[Sysname] netanalysis rocev2 mode single
This operation will erase all the net analysis configuration.
Continue?[Y/N]:y
# Enable bidirectional RoCEv2 traffic analysis.
[Sysname] netanalysis rocev2 mode bidir
Continue?[Y/N]:y
Use netanalysis rocev2 report-interval to set the interval for reporting RoCEv2 traffic statistics to the NDA.
Use undo netanalysis rocev2 report-interval to restore the default.
netanalysis rocev2 report-interval interval
The device reports RoCEv2 traffic statistics to the NDA at an interval of 10 seconds.
seconds: Specifies an interval value in seconds, in the range of 5 to 500.
Use this command to adjust the interval at which the device reports RoCEv2 traffic statistics to the NDA.
# Configure the device to report RoCEv2 traffic statistics to the NDA at an interval of 15 seconds.
[Sysname] netanalysis rocev2 report-interval 15
Use netanalysis rocev2 statistics to enable RoCEv2 traffic statistics collection.
Use undo netanalysis rocev2 statistics to disable RoCEv2 traffic statistics collection.
netanalysis rocev2 statistics { global | acl name acl-name }
RoCEv2 traffic statistics collection is disabled.
global: Specifies all received RoCEv2 traffic.
acl name acl-name: Specifies an advanced ACL for filtering RoCEv2 traffic by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with an uppercase or lowercase letter and cannot be all. If the specified ACL is nonexistent or contains only rules not supported by NetAnalysis, this command does not take effect.
Use this command to enable NetAnalysis to analyze RoCEv2 traffic and send the analysis results to the NAP. You can use an ACL to match the RoCEv2 traffic of interest. The deny or permit action in the ACL does not take effect. NetAnalysis supports the following rules of advanced ACLs:
· Rule 1—Matches the UDP protocol and destination IPv4 address.
· Rule 2—Matches the UDP protocol and source IPv4 address.
· Rule 3—Matches the UDP protocol and source and destination IPv4 addresses.
To ensure correct collection and reporting of RoCEv2 traffic statistics, use the rules supported by NetAnalysis. For more information about ACLs, see ACL and QoS Configuration Guide.
# Enable NetAnalysis to collect statistics about all received RoCEv2 traffic.
[Sysname] netanalysis rocev2 statistics global
# Enable NetAnalysis to collect statistics about the received RoCEv2 traffic that matches ACL abc.
[Sysname] netanalysis rocev2 statistics acl name abc
Use netanalysis rocev2 timeout inactive to set the aging timer for inactive RoCEv2 flows.
Use undo netanalysis rocev2 timeout inactive to restore the default.
netanalysis rocev2 timeout inactive seconds
The aging timer for inactive RoCEv2 flows is set to 30 seconds.
seconds: Sets the aging timer for inactive RoCEv2 flows, in seconds. The value range for this argument is 5 to 500 seconds.
When an inactive RoCEv2 flow ages out, the device outputs the related traffic statistics to the NDA and deletes these traffic statistics from the RoCEv2 cache.
# Set the aging timer for inactive RoCEv2 flows to 10 seconds.
[Sysname] netanalysis rocev2 timeout inactive 10
Use reset netanalysis rocev2 statistics to clear RoCEv2 traffic statistics.
Use this command to clear RoCEv2 traffic statistics if you want to collect RoCEv2 traffic statistics for a specific time period.
You cannot recover cleared RoCEv2 traffic statistics. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Clear RoCEv2 traffic statistics.
<Sysname> reset netanalysis rocev2 statistics
