- 16-Security Command Reference
- 01-Keychain commands
- 02-Public key management
- 03-PKI commands
- 04-Crypto engine commands
- 05-SSH commands
- 06-SSL commands
- 07-Packet filter commands
- 08-DHCP snooping commands
- 09-DHCPv6 snooping commands
- 10-ARP attack protection commands
- 11-ND attack defense commands
- 12-Attack detection and prevention commands
- 13-IP-based attack prevention commands
- 14-IP source guard commands
- 15-uRPF commands
- 16-FIPS commands
- 17-APR commands
| 11-ND attack defense commands | 212.79 KB |
Source MAC consistency check commands
display ipv6 nd detection statistics
ipv6 nd detection port-match-ignore
reset ipv6 nd detection statistics
display ipv6 nd raguard policy
display ipv6 nd raguard statistics
if-match autoconfig managed-address-flag
if-match autoconfig other-flag
reset ipv6 nd raguard statistics
ND keepalive entry scanning commands
display ipv6 nd scan keepalive entry
display ipv6 nd scan keepalive statistics
ipv6 nd scan keepalive aging-time
ipv6 nd scan keepalive send-rate
reset ipv6 nd scan keepalive statistics
ipv6 nd check log enable
Use ipv6 nd check log enable to enable the ND logging feature.
Use undo ipv6 nd check log enable to restore the default.
The ND logging feature is disabled.
The ND logging feature logs source MAC inconsistency events, and sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see System Management Configuration Guide.
As a best practice, disable the ND logging feature to avoid excessive ND logs.
# Enable the ND logging feature.
[Sysname] ipv6 nd check log enable
ipv6 nd mac-check enable
Use ipv6 nd mac-check enable to enable source MAC consistency check for ND messages.
Use undo ipv6 nd mac-check enable to disable source MAC consistency check for ND messages.
Source MAC consistency check for ND messages is disabled.
Use this command to enable source MAC consistency check on a gateway. The gateway checks the source MAC address and the source link-layer address for consistency for each ND message. If an inconsistency is found, the gateway drops the ND message.
# Enable source MAC consistency check for ND messages.
[Sysname] ipv6 nd mac-check enable
ND attack detection commands
Use display ipv6 nd detection statistics to display statistics for ND messages dropped by ND attack detection.
display ipv6 nd detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics for ND messages dropped by ND attack detection on all interfaces.
# Display statistics for all ND messages dropped by ND attack detection.
<Sysname> display ipv6 nd detection statistics
ND packets dropped by ND detection:
Interface/AC Packets dropped
25GE1/0/1 78
25GE1/0/2 0
25GE1/0/3 0
25GE1/0/4 0
Input interface of the ND messages. |
Packets dropped |
Number of ND messages dropped by ND attack detection. |
ipv6 nd detection enable
Use ipv6 nd detection enable to enable ND attack detection. This feature checks the ND message validity.
Use undo ipv6 nd detection enable to disable ND attack detection.
VLAN view:
ipv6 nd detection enable [ dhcpv6-relay ]
Layer 2 Ethernet interface/Layer 2 aggregate interface/VSI interface view:
ND attack detection is disabled.
VLAN view
dhcpv6-relay: Configures ND attack detection to use DHCPv6 relay entries for user validity check.
Application scenarios
ND attack detection checks incoming ND messages for user validity to prevent spoofing attacks. It is typically configured on access devices.
Operating mechanism
ND attack detection compares the source IPv6 address and the source MAC address in an incoming ND message against security entries from other modules.
· If a match is found, the device verifies the user as legal, and it forwards the ND message.
· If no match is found, the device verifies the user as illegal, and it discards the ND message.
The security entries used by ND attack detection for user validity check vary by the specified keyword when you enable this feature.
· If you do not specify the dhcpv6-relay keyword, ND attack detection uses static IPv6 source guard binding entries, ND snooping entries, and DHCPv6 snooping entries for user validity check.
· If you specify the dhcpv6-relay keyword, ND attack detection uses DHCPv6 relay agent entries for user validity check.
ND attack detection is enabled on an interface when you enable this feature on the interface or in the VLAN where the interface resides. To disable ND attack detection on an interface, disable this feature both on the interface and in the VLAN of the interface.
You cannot enable ND attack detection on the interface that has been configured as an ND trusted interface.
# Enable ND attack detection for Twenty-FiveGigE 1/0/1.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] ipv6 nd detection enable
# Enable ND attack detection for Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] ipv6 nd detection enable
# Enable ND attack detection for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] ipv6 nd detection enable
# Enable ND attack detection for VLAN 1 and configure the feature to use DHCPv6 relay entries for user validity check.
[Sysname] vlan 1
[Sysname-vlan-1] ipv6 nd detection enable dhcpv6-relay
ipv6 nd detection log enable
Use ipv6 nd detection log enable to enable ND attack detection logging.
Use undo ipv6 nd detection log enable to disable ND attack detection logging.
ND attack detection logging is disabled.
This command allows a device to generate logs when it detects ND attacks. The log information helps administrators locate and solve problems. The ND attack detection logging feature sends the log message to the information center. The information center can then output log messages from different source modules to different destinations. For more information about information center, see System Management Configuration Guide.
The device performance is degraded when the device outputs a large number of ND attack detection logs. You can disable ND attack detection logging to ensure the device performance.
# Enable ND attack detection logging.
[Sysname] ipv6 nd detection log enable
Use ipv6 nd detection port-match-ignore to ignore ingress ports of ND packets in ND attack detection.
Use undo ipv6 nd detection port-match-ignore to remove the configuration.
Ingress ports of ND packets are examined in ND attack detection.
With ND attack detection enabled, the device can perform security check on received packets based on the local and remote IPSG bindings. Remote IPSG bindings do not contain port information. The device drops ND packets that match remote IPSG bindings because it does not find matching ingress ports for these packets. To prevent the device from dropping these packets, you can configure the device to ignore ingress ports of ND packets. This feature does not examine the ingress ports of ND packets, so that ND packets that match remote IPSG bindings will not be dropped.
Operating mechanism
This command configures ND attack detection to ignore the ingress port information of ND packets when the packets are compared with the entries in ND attack detection.
# Ignore ingress ports of ND packets in ND attack detection.
[Sysname] ipv6 nd detection port-match-ignore
ipv6 nd detection trust
Use ipv6 nd detection trust to configure an interface as an ND trusted interface.
Use undo ipv6 nd detection trust to restore the default.
All interfaces are ND untrusted interfaces.
# Configure Twenty-FiveGigE 1/0/1 as an ND trusted interface.
[Sysname-Twenty-FiveGigE1/0/1] ipv6 nd detection trust
# Configure Bridge-Aggregation 1 as an ND trusted interface.
[Sysname-Bridge-Aggregation1] ipv6 nd detection trust
Use reset ipv6 nd detection statistics to clear ND attack detection statistics.
reset ipv6 nd detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears ND attack detection statistics for all interfaces.
# Clear all ND attack detection statistics.
<Sysname> reset ipv6 nd detection statistics
ND scanning commands
ipv6 nd scan auto enable
Use ipv6 nd scan auto enable to enable automatic ND scanning in a specified address range on an interface.
Use undo ipv6 nd scan auto enable to disable automatic ND scanning on an interface.
ipv6 nd scan auto enable start-ipv6-address to end-ipv6-address [ source-addr source-ipv6-address ]
Automatic ND scanning is disabled on an interface.
VSI interface view
VLAN interface view
start-ipv6-address: Specifies the start IPv6 address of the scanning range.
to end-ipv6-address: Specifies the end IPv6 address of the scanning range. The end IPv6 address must be higher than or equal to the start IPv6 address. The maximum number of IPv6 addresses in the range is 65535.
source-addr source-ipv6-address: Specifies the source address for the NS requests. The source-ipv6-address argument can be any valid IPv6 addresses. If you do not specify this option, the interface uses its IPv6 address as the source address.
The device automatically creates ND entries by NS and NA messages when triggered by traffic. If no traffic is received or sent in a period of time, the ND entries cannot be created or updated in time.
To resolve this issue, you can enable the automatic ND scanning feature on the device. This feature enables the device to periodically send ND packets (NS requests) at a specified rate to the IPv6 addresses not in the specified ND entries.
You can specify the source address for the sending NS requests when you enable automatic ND scanning on an interface:
· If you do not specify the source address, the interface uses its IPv6 address as the source address. The interface scans the IPv6 addresses that belong to both the automatic ND scanning range and the subnet of the interface IPv6 address.
If the interface is configured with multiple subnet IPv6 addresses and the addresses are also in the scanning range, the source address is the IPv6 address with the longest prefix. If the prefixes are in the same length, the source address is the primary IPv6 address for the interface.
· If you specify the source address, the interface uses the specified source address, and it scans all the IPv6 addresses in the automatic ND scanning range.
If the interface is enabled with ND proxy, the specified source address does not affect the Layer 3 forwarding route. For more information about ND proxy, see IPv6 basics in Layer 3—IP Services Configuration Guide.
You can set the ND packet sending rate by using the ipv6 nd scan auto send-rate command.
To avoid any impact on device performance, use automatic ND scanning only on networks where users come online and go offline frequently.
# Configure the device to scan neighbors in an address range.
[Sysname-Twenty-FiveGigE1/0/1] ipv6 nd scan auto enable 2001::1 to 2001::10
[Sysname-Vlan-interface100] ipv6 nd scan auto enable 2001::1 to 2001::10
Use ipv6 nd scan auto send-rate to set the ND packet sending rate for automatic ND scanning.
Use undo ipv6 nd scan auto send-rate to restore the default.
ipv6 nd scan auto send-rate { ppm ppm | pps pps }
The device sends ND packets at the rate of 48 pps during automatic ND scanning.
ppm ppm: Specifies the ND packet sending rate, in packets per minute (ppm). The value range for the ppm argument is 10 to 600, and the value must be a multiple of 10. Alternatively, a configuration error will occur.
pps pps: Specifies the ND packet sending rate, in packets per second (pps). The value range for the pps argument is 10 to 1000, and the value must be a multiple of 10. Alternatively, a configuration error will occur.
This command enables the device to periodically send ND packets (NS requests) at a specified rate. You can adjust the ND packet sending rate to avoid impact on device performance.
To avoid any impact on device performance, the actual ND packet sending rate might be smaller than the configured rate.
# Set the ND packet sending rate to 10 pps during automatic ND scanning.
[Sysname] ipv6 nd scan auto send-rate pps 10
ND SNMP notification commands
snmp-agent trap enable nd
Use snmp-agent trap enable nd to enable SNMP notifications for ND.
Use undo snmp-agent trap enable nd to disable SNMP notifications for ND.
snmp-agent trap enable nd [ entry-limit | local-conflict | nd-miss | rate-limit | user-ip-conflict ] *
undo snmp-agent trap enable nd [ entry-limit | local-conflict | nd-miss | rate-limit | user-ip-conflict ] *
SNMP notifications for ND are disabled.
entry-limit: Specifies ND entry limit notifications.
local-conflict: Specifies endpoints and local device conflict notifications.
nd-miss: Specifies rate limit notifications for sending ND Miss messages and ND packets.
rate-limit: Specifies rate limit notifications for receiving ND packets.
user-ip-conflict: Specifies user IPv6 address conflict notifications.
Enable SNMP notifications for ND as required.
· If you enable ND entry limit notifications, the device sends the current ND entry information as a notification to the SNMP module when the number of ND entries exceeds the alarm threshold.
· If you enable endpoint and local device conflict notifications, the device sends a notification to the SNMP module when an endpoint and local device conflict occurs. The notification includes the source IPv6 address, source MAC address, destination IPv6 address, and destination MAC address in the conflicting ND packet.
· If you enable rate limit notifications for sending ND Miss messages and ND packets, the device sends the highest threshold-crossed rate as a notification to the SNMP module. When the device receives an IP packet in which the destination IP address is unresolvable, it sends a ND Miss message to the CPU.
· If you enable receiving rate limit notifications for ND packets, the device sends the highest threshold-crossed rate as a notification to the SNMP module.
· If you enable user IPv6 address conflict notifications, the device sends a notification to the SNMP module when a user IPv6 address conflict occurs. The notification includes the source IPv6 and MAC addresses in the conflicting ND packet, and MAC address in the corresponding local ND entry.
If you do not specify any keywords, this command enables all SNMP notifications for ND.
For ND event notifications to be sent correctly, you must also configure SNMP on the device. For more information, see SNMP configuration in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for endpoint and local device conflicts.
[Sysname] snmp-agent trap enable nd local-conflict
RA guard commands
Use display ipv6 nd raguard policy to display the RA guard policy configuration.
display ipv6 nd raguard policy [ policy-name ]
policy-name: Specifies an RA guard policy by its name. The policy name is a case-sensitive string of 1 to 31 characters. If you do not specify a policy, this command displays the configuration of all RA guard policies.
# Display the configuration of all RA guard policies.
<Sysname> display ipv6 nd raguard policy
Total number of policies: 2
RA Guard policy: policy1
if-match ACL 2001
if-match autoconfig managed-address-flag on
if-match autoconfig other-flag off
if-match hop-limit maximum 128
if-match hop-limit minimum 100
if-match prefix ACL name aa
if-match router-preference medium
if-match mac-address ACL 4000
applied to VLAN 1-3 7
RA Guard policy: policy2
if-match ACL name zdd
if-match prefix ACL 2200
if-match mac-address ACL name bb
RA Guard policy |
Name of the RA guard policy. |
if-match ACL |
Number of the ACL in the ACL match criterion. |
if-match ACL name |
Name of the ACL in ACL match criterion. |
if-match autoconfig managed-address-flag |
Match criterion of the advertised M flag: · on—The value of the advertised M flag is 1. · off—The value of the advertised M flag is 0. |
if-match autoconfig other-flag |
Match criterion of the advertised O flag: · on—The value of the advertised O flag is 1. · off—The value of the advertised O flag is 0. |
if-match hop-limit maximum |
The maximum advertised hop limit match criterion. |
if-match hop-limit minimum |
The minimum advertised hop limit match criterion. |
if-match prefix ACL |
Number of the ACL used to identify the prefix match criterion. |
if-match prefix ACL name |
Name of the ACL used to identify the prefix match criterion. |
if-match mac-address ACL |
Number of the ACL used to match source MAC addresses in RA messages. |
if-match mac-address ACL name |
Name of the ACL used to match source MAC addresses in RA messages. |
applied to VLAN |
ID of the VLAN to which the RA guard policy is applied. |
Use display ipv6 nd raguard statistics to display RA guard statistics.
display ipv6 nd raguard statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays RA guard statistics for all interfaces.
# Display RA guard statistics.
<Sysname> display ipv6 nd raguard statistics
RA messages dropped by RA guard:
Interface Dropped
25GE1/0/1 78
25GE1/0/2 0
25GE1/0/3 32
25GE1/0/4 0
Interface that received the dropped RA messages. |
Dropped |
Number of RA messages dropped on the interface. |
ipv6 nd raguard log enable
if-match acl
Use if-match acl to specify an ACL match criterion.
Use undo if-match acl to delete the ACL match criterion.
undo if-match acl
No ACL match criterion exists.
RA guard policy view
ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999.
name ipv6-acl-name: Specifies an IPv6 basic ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with an English letter. To avoid confusion, the name cannot be all.
RA guard uses the ACL match criterion to match the IP address of the RA message sender. If the sender IP address matches a permit rule, the message passes the check.
If the specified ACL does not exist or does not contain a rule, the ACL match criterion does not take effect.
# Use IPv6 basic ACL 2001 as the ACL match criterion for the RA guard policy policy1.
[Sysname] ipv6 nd raguard policy policy1
[Sysname-raguard-policy-policy1] if-match acl 2001
Use if-match autoconfig managed-address-flag to specify an M flag match criterion.
Use undo if-match autoconfig managed-address-flag to delete the M flag match criterion.
if-match autoconfig managed-address-flag { off | on }
No M flag match criterion exists.
off: Specifies the advertised M flag as 0
on: Specifies the advertised M flag as 1.
The M flag in an RA message determines whether a receiving host uses stateful autoconfiguration to obtain an IPv6 address.
· If the M flag is set to 1, the host uses stateful autoconfiguration, for example, uses a DHCPv6 server.
· If the M flag is set to 0, the host uses stateless autoconfiguration. In stateless autoconfiguration, the host generates an IPv6 address according to its link-layer address and the prefix information in the RA message.
# Specify on as the M flag match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match autoconfig managed-address-flag on
Use if-match autoconfig other-flag to specify an O flag match criterion.
Use undo if-match autoconfig other-flag to delete the O flag match criterion.
if-match autoconfig other-flag { off | on }
No O flag match criterion exists.
off: Specifies the advertised O flag as 0.
on: Specifies the advertised O flag as 1.
The O flag in an RA message determines whether a receiving host uses stateful autoconfiguration to obtain configuration information other than IPv6 address.
· If the O flag is set to 1, the host uses stateful autoconfiguration, for example, uses a DHCPv6 server.
· If the O flag is set to 0, the host uses stateless autoconfiguration.
[Sysname-raguard-policy-policy1] if-match autoconfig other-flag on
if-match hop-limit
Use if-match hop-limit to specify a maximum or minimum hop limit match criterion.
Use undo if-match hop-limit to delete the maximum or minimum hop limit match criterion.
if-match hop-limit { maximum | minimum } limit
undo if-match hop-limit { maximum | minimum }
No maximum or minimum hop limit match criterion exists.
maximum: Specifies the maximum advertised hop limit. An RA message passes the check if its current hop limit is not higher than the maximum advertised hop limit.
minimum: Specifies the minimum advertised hop limit. An RA message passes the check if its current hop limit is not less than the minimum advertised hop limit.
limit: Specifies the advertised hop limit in the range of 1 to 255.
If a hop limit match criterion is set, and the RA message's current hop limit is 0, the message will be dropped.
# Set the maximum hop limit match criterion to 128 for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match hop-limit maximum 128
if-match mac-address acl
Use if-match mac-address acl to configure a source MAC address match criterion.
Use undo if-match mac-address acl to delete a source MAC address match criterion.
if-match mac-address acl { acl-number | name acl-name }
No source MAC address match criterion is configured.
acl-number: Specifies a Layer 2 ACL by its number in the range of 4000 to 4999.
name acl-name: Specifies a Layer 2 ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with an English letter. To avoid confusion, the name cannot be all.
RA guard uses the specified Layer 2 ACL to match source MAC addresses in RA messages. An RA message passes the check if its source MAC address matches a permit rule.
When you specify an ACL, follow these restrictions and guidelines:
· If the ACL does not exist or does not contain a rule, the ACL match criterion does not take effect.
· If you specify the vpn-instance keyword for an ACL rule, the rule does not take effect.
# Use Layer 2 ACL 4000 as the source MAC address match criterion for RA guard policy policy1.
[Sysname] acl mac 4000
[Sysname-acl-mac-4000] rule permit source-mac 0001-0001-0001 ffff-ffff-ffff
[Sysname-acl-mac-4000] quit
[Sysname-raguard-policy-policy1] if-match mac-address acl 4000
if-match prefix
Use if-match prefix to specify a prefix match criterion.
Use undo if-match prefix to delete the prefix match criterion.
if-match prefix acl { ipv6-acl-number | name ipv6-acl-name }
undo if-match prefix acl
No prefix match criterion exists.
An RA message passes the check if the advertised prefixes in the message match the prefixes set by the ACL.
If the specified ACL does not exist or does not contain a rule, the prefix match criterion does not take effect.
# Use IPv6 basic ACL 2000 as the prefix match criterion for the RA guard policy policy1.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 1001:: 64
[Sysname-acl-ipv6-basic-2000] rule permit source 3124:1123:: 64
[Sysname-acl-ipv6-basic-2000] rule deny source any
[Sysname-raguard-policy-policy1] if-match prefix acl 2000
Use if-match router-preference maximum to specify a router preference match criterion.
Use undo if-match router-preference maximum to delete the router preference match criterion.
if-match router-preference maximum { high | low | medium }
No router preference match criterion exists.
high: Sets the maximum router preference to high. An RA message passes the check if its router preference is not higher than high.
low: Sets the maximum router preference to low. An RA message passes the check if its router preference is not higher than low.
medium: Sets the maximum router preference to medium. An RA message passes the check if its router preference is not higher than medium.
A host selects a router as the default gateway according to the router preference in received RA messages. If router preferences are the same, the host selects the default router from which the first RA message is received.
An RA message will not pass the router preference check if the message does not have a preference value. This RA message will be dropped.
# Specify medium as the router preference match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match router-preference maximum medium
ipv6 nd raguard apply policy
Use ipv6 nd raguard apply policy to apply an RA guard policy to a VLAN.
Use undo ipv6 nd raguard apply policy to remove the RA guard policy from a VLAN.
ipv6 nd raguard apply policy [ policy-name ]
No RA guard policy is applied to a VLAN.
VLAN view
policy-name: Specifies an RA guard policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a policy, RA guard blocks RA messages on all interfaces in the VLAN except interfaces that are defined to be connected to routers.
If an RA message has multiple VLAN tags, RA guard uses the outermost VLAN tag to select the applied RA guard policy.
If the specified RA guard policy does not exist, the command does not take effect.
# Apply the RA guard policy policy1 to VLAN 100.
[Sysname] vlan 100
[Sysname-vlan100] ipv6 nd raguard apply policy policy1
Use ipv6 nd raguard log enable to enable the RA guard logging feature.
Use undo ipv6 nd raguard log enable to disable the RA guard logging feature.
The RA guard logging feature is disabled.
This command allows a device to generate logs when it detects forged RA messages. The log information helps administrators locate and solve problems. Each log records the following information:
· Name of the interface that received the forged RA message.
· Source IP address of the forged RA message.
· Number of RA messages dropped on the interface.
The RA guard logging feature sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see System Management Configuration Guide.
# Enable the RA guard logging feature.
[Sysname] ipv6 nd raguard log enable
Use ipv6 nd raguard policy to create an RA guard policy and enter its view, or enter the view of an existing RA guard policy.
Use undo ipv6 nd raguard policy to delete an RA guard policy.
ipv6 nd raguard policy policy-name
undo ipv6 nd raguard policy policy-name
No RA guard policies exist.
policy-name: Assigns a name to the RA guard policy. The name is a case-sensitive string of 1 to 31 characters.
# Create RA guard policy policy1 and enter its view.
ipv6 nd raguard role
Use ipv6 nd raguard role to specify the role of the device attached to the interface.
Use undo ipv6 nd raguard role to remove the role of the device attached to the interface.
ipv6 nd raguard role { host | router }
No role is specified for the device attached to the interface.
host: Specifies the host role. The interface attached to a host drops all received RA messages.
router: Specifies the router role. The interface attached to a router forwards all received RA messages.
Make sure your setting is consistent with the device type. If you are not aware of the attached device type, do not specify a role for the device.
# Specify host as the role for the device attached to Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] ipv6 nd raguard role host
Use reset ipv6 nd raguard statistics to clear RA guard statistics.
reset ipv6 nd raguard statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears RA guard statistics for all interfaces.
# Clear RA guard statistics.
<Sysname> reset ipv6 nd raguard statistics
Use display ipv6 nd scan keepalive entry to display ND keepalive entries.
display ipv6 nd scan keepalive entry [ interface interface-type interface-number ] [ count ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ND keepalive entries for all interfaces.
count: Displays the total number of ND keepalive entries.
<Sysname> display ipv6 nd scan keepalive entry
Interface: 25GE1/0/1
IPv6 address: 1::23 MAC address: 08-00-27-00-50-38
VLANID: 1 SECVLANID: 1
Port interface: -- VPN instance: --
Scan status: 1 Probe count: 10
Scan time: 08:01:01
Name of the Layer 3 interface. |
IPv6 address |
IPv6 address in the ND keepalive entry. |
MAC address |
MAC address in the ND keepalive entry. |
VLANID |
ID of the primary VLAN. |
SECVLANID |
ID of the secondary VLAN. |
Port interface |
Layer 2 input interface for ND packets. |
VPN instance |
Name of the VPN instance. |
Scan status |
Status of the ND keepalive entry: · 0—Offline. · 1—Online. |
Probe count |
Number of scans on the ND keepalive entry. |
Scan time |
Time when the ND keepalive entry became offline, in hh:mm:ss format. · hh—Represents the hours. · mm—Represents the minutes. · ss—Represents the seconds. |
Use display ipv6 nd scan keepalive statistics to display statistics about ND keepalive entry scanning.
display ipv6 nd scan keepalive statistics [ slot slot-number ] [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics about ND keepalive entry scanning for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics about ND keepalive entry scanning on all member devices.
Interfaces enabled with ND keepalive entry scanning send NS packets to the IPv6 addresses in offline ND keepalive entries until the entries restore online state. This command displays the number of the NS packets sent the IPv6 addresses in the offline keepalive entries in the last five seconds, one minute, and five minutes.
A great many NS packets indicate that the number of offline keepalive entries is great or some offline entries remain in offline state for a long time. The reasons and solutions are as follows:
1. Use the display ipv6 nd scan keepalive entry command to identify the number of offline keepalive entries.
2. If the number of offline keepalive entries is large, check the aging time set for offline keepalive entries. Shorten the aging time if it is too long.
3. If the aging time is proper, the problem might be caused by too many abnormal user offline events. In this case, check the network configuration and condition.
4. If the number of offline keepalive entries is not large, the problem might be because some offline keepalive entries cannot restore online state through NS packets. In this case, troubleshoot according to the offline entries.
# Display statistics about NS packets sent the IPv6 addresses in offline keepalive entries on slot 1.
<Sysname> display ipv6 nd scan keepalive statistics slot 1
Scanning statistics for slot 1:
Total NS packets: 1000 packets
Start time for statistics: 12:20:30
Interface 5 secs 1 min 5 mins
Twenty-FiveGigE1/0/1 123 200 230
Twenty-FiveGigE1/0/2 0 0 0
Twenty-FiveGigE1/0/3 0 0 0
Twenty-FiveGigE1/0/4 0 0 0
Twenty-FiveGigE1/0/5 0 0 0
Twenty-FiveGigE1/0/6 0 0 0
Table 5 Command output
Total NS packets |
Total number of NS packets sent the IPv6 addresses in offline keepalive entries. |
Start time for statistics |
Time when the device started counting the number of NS packets sent the IPv6 addresses in offline keepalive entries. |
Name of an interface that sends NS packets the IPv6 addresses in offline keepalive entries. |
5 secs |
Number of the NS packets sent in the last five seconds. |
1 min |
Number of the NS packets sent in the last one minute. |
5 mins |
Number of the NS packets sent in the last five minutes. |
Use ipv6 nd scan keepalive aging-time to set the aging time for ND keepalive entries.
Use undo ipv6 nd scan keepalive aging-time to restore the default.
ipv6 nd scan keepalive aging-time time
In system view, the aging time for ND keepalive entries is 60 minutes.
In interface view, the aging time for ND keepalive entries is the aging time set in system view.
VSI interface view
time: Specifies the aging time for ND keepalive entries in minutes. The value range for this argument is 1 to 1440.
With ND keepalive entry scanning enabled, the device generates a keepalive entry in online state for a user that comes online. If the user goes offline abnormally, the device will perform the following tasks:
· Set the state of the keepalive entry for that user to offline state.
· Delete the keepalive entry if its state does not restore to online after the aging time elapses.
To enable ND keepalive entry scanning, use the ipv6 nd scan keepalive enable command. For more information about ND keepalive entry scanning, see the configuration guide.
Operating mechanism
You can set the aging time for ND keepalive entries in both system view and interface view. The aging time set in interface view takes precedence over the aging time set in system view. In interface view, the default aging time for ND keepalive entries is the aging time set in system view.
# Set the aging time for ND keepalive entries to 10 minutes.
[Sysname] ipv6 nd scan keepalive aging-time 10
# Set the aging time for ND keepalive entries to 100 minutes on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd scan keepalive aging-time 100
Use ipv6 nd scan keepalive enable to enable ND keepalive entry scanning.
Use undo ipv6 nd scan keepalive enable to disable ND keepalive entry scanning.
ND keepalive entry scanning is disabled on an interface.
VSI interface view
VLAN interface view
In a large-scale network, it takes a long time for ND scanning to identify the hosts that go offline abnormally if you specify a large scanning range. After you enable ND keepalive entry scanning, the system can quickly locate those hosts and monitor the host status within the aging time.
Operating mechanism
When users come online, the system generates ND entries and IPSG binding entries. Enabled with ND keepalive entry scanning, the system also creates online keepalive entries when users come online. If users go offline, the corresponding ND entries are deleted and the status of the keepalive entries is set to offline. The device sends NS packets at intervals to the IPv6 addresses in the offline keepalive entries until the keepalive entries become online again.
The interval varies with the number of NS packets that have been sent to the IPv6 address in an offline keepalive entry:
· If the number is not greater than 50, the device sends an NS packet every 30 seconds.
· If the number is greater than 50 but not greater than 100, the device sends an NS packet every 45 seconds.
· If the number is greater than 100, the device sends an NS packet every 60 seconds.
To view the keepalive entries, use the display ipv6 nd scan keepalive entry command.
For more information about IP source guard configuration, see Security Configuration Guide.
The offline keepalive entries are deleted when the aging time expires. To set the aging time for ND keepalive entries, use the ipv6 nd scan keepalive aging-time command.
# Enable ND keepalive entry scanning on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd scan keepalive enable
Use ipv6 nd scan keepalive send-rate to set the NS packet sending rate for keepalive entry scanning.
Use undo ipv6 nd scan keepalive send-rate to restore the default.
ipv6 nd scan keepalive send-rate pps
The device sends NS packets at a rate of 48 pps during keepalive entry scanning.
pps: Specifies the NS packet sending rate, in packets per second (pps). The value range for this argument is 10 to 1000, and the value must be a multiple of 10.
Enabled with keepalive entry scanning, the interface sends NS packets to the IPv6 addresses in the offline keepalive entries. To avoid any impact on the device performance, use this command to set the NS packet sending rate for keepalive entry scanning.
Operating mechanism
If the status of a keepalive entry is set to offline and does not become online within an interval, the keepalive entry is to be scanned. The interface sends an NS packet per second to the IPv6 address in each keepalive entry to be scanned.
The NS packet sending rate is the maximum number of scanned keepalive entries per second.
· If the number of keepalive entries to be scanned per second is lower than the sending rate, the device scans all these keepalive entries within a second.
· If the number of keepalive entries to be scanned per second is greater than the sending rate, the device scans the keepalive entries at the sending rate.
When you set the sending rate to a large value, the device might use a rate lower than the specified rate to ensure the device performance.
# Set the NS packet sending rate to 10 pps during keepalive entry scanning.
[Sysname] ipv6 nd scan keepalive send-rate 10
Use reset ipv6 nd scan keepalive statistics to clear statistics about ND keepalive entry scanning.
reset ipv6 nd scan keepalive statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears statistics about ND keepalive entry scanning on all member devices.
This command clears statistics about the NS packets sent to the IPv6 addresses in offline keepalive entries and resets the start time of NS packet statistics collection.
The NS packet count and the statistics start time displayed by the display ipv6 nd scan keepalive statistics command are the data collected since the most recent execution of the reset ipv6 nd scan keepalive statistics command.
# Clear statistics about NS packets sent the IPv6 addresses in offline keepalive entries.
<Sysname> reset ipv6 nd scan keepalive statistics
