08-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9820-8M[S6880] Command References-R1330Pxx-6W10008-Layer 3—IP Routing Command Reference
15-Dual-stack PBR commands
15-Dual-stack PBR commands 132.22 KB
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { { ipv4-address | ipv6-address } [ direct ] [ track track-entry-number ] }&<1-4>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] { ipv4-address | ipv6-address }&<1-4> ]
No default next hops are set.
Dual-stack policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ipv4-address: Specifies the IPv4 address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
ipv6-address: Specifies the IPv6 address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-4>: Indicates that the argument before it can be entered up to four times. You can specify a maximum of 16 default next hops for a dual-stack policy node.
You can specify multiple default next hops for backup or in one command line or by executing this command multiple times. The device selects the first configured default next hop as the primary default next hop. When the primary default next hop becomes invalid, the device selects the next available default next hop for forwarding packets based on configuration order.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname] dual-stack policy-based-route aa permit node 11
[Sysname-pbrdual-aa-11] apply default-next-hop 1.1.1.1 direct
apply mirror-to-destination
Use apply mirror-to-destination to set a mirroring action that mirrors packets to the specified destination IP address.
Use undo apply mirror-to-destination to restore the default.
apply mirror-to-destination [ vpn-instance vpn-instance-name ] destination-ipv4-address [ source-ip source-ipv4-address ] [ dscp dscp-value ]
undo apply mirror-to-destination [ vpn-instance vpn-instance-name ] destination-ipv4-address
The mirroring action is not set.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist. If the destination IP address belongs to the public network, do not specify this option.
destination-ipv4-address: Specifies the destination IP address encapsulated in the outer header of mirrored packets.
source-ip source-ipv4-address: Specifies the source IP address encapsulated in the outer header of mirrored packets. If you do not specify this option, the primary IP address for the output interface of the mirrored packets is encapsulated.
dscp dscp-value: Specifies the DSCP value encapsulated in the outer header of mirrored packets. The value range for the dscp-value argument is 0 to 63, and the default value is 63.
This command enables the device to mirror packets to a specific destination device through a tunnel (for example, a GRE tunnel) for packet analysis and monitoring. The device will encapsulate the parameters set for this command in the outer header of the mirrored packets.
This apply clause is always executed for packets matching the policy node.
# Set a mirroring action by specifying source IP address 2.2.2.2 and destination IP address 1.1.1.1.
[Sysname-pbrdual-aa-11] apply mirror-to-destination 1.1.1.1 source-ip 2.2.2.2
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { { ipv4-address | ipv6-address } [ direct ] [ track track-entry-number ] }&<1-4>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] { ipv4-address | ipv6-address }&<1-4> ]
No next hops are set.
ipv4-address: Specifies the IPv4 address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
ipv6-address: Specifies the IPv6 address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
&<1-4>: Indicates that the argument before it can be entered up to four times. You can specify a maximum of 16 next hops for a dual-stack policy node.
You can specify multiple next hops for backup in one command line or by executing this command multiple times. The device selects the first configured next hop as the primary next hop. When the primary next hop becomes invalid, the device selects the next available next hop for forwarding packets based on configuration order.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbrdual-aa-11] apply next-hop 1.1.1.1 direct
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface NULL 0
undo apply output-interface [ NULL 0 ]
No output interfaces are set.
NULL 0: Specifies Null 0 as the output interface.
# Specify Null 0 as the output interface for IPv4 or IPv6 packets.
[Sysname-pbrdual-aa-11] apply output-interface vlan-interface 2
apply statistics
Use apply statistics to enable match counting on a policy node.
Use undo apply statistics to restore the default.
apply statistics
Match counting is disabled on a policy node.
To include the number of successful matches and matching bytes on a policy node in the statistics displayed by a display command, execute this command. As a best practice to conserve hardware resources, disable this counting function.
This apply clause is always executed for the policy node.
# Enable match counting on policy node 11.
[Sysname-pbrdual-aa-11] apply statistics
description
Use description to configure a description for a dual-stack policy node.
No description is configured for a dual-stack policy node.
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for policy node 1.
[Sysname] dual-stack policy-based-route 1 permit node 1
[Sysname-pbrdual-1-1] description Officeuse
display dual-stack policy-based-route
Use display dual-stack policy-based-route to display dual-stack PBR policy information.
display dual-stack policy-based-route [ policy policy-name ]
policy policy-name: Specifies a dual-stack PBR policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a dual-stack PBR policy, this command displays information for all dual-stack PBR policies.
# Display all dual-stack PBR policy information.
<Sysname> display dual-stack policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl ipv4 2000
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
dual-stack policy-based-route (system view)
display dual-stack policy-based-route global
Use display dual-stack policy-based-route global to display information about global dual-stack PBR, including its configuration and statistics.
display dual-stack policy-based-route global [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the master device is specified by default.
# Display information about global dual-stack PBR.
<Sysname> display dual-stack policy-based-route global
Global policy-based routing information:
Policy name: aaa
  node 0 deny:
  Matches: 0, bytes: 0
  node 1 permit:
    if-match acl ipv6 3999
  node 2 permit:
    apply next-hop 2.2.2.2
  node 5 permit:
    if-match acl ipv4 3101
Total matches: 0, total bytes: 0
Global dual-stack PBR configuration and statistics.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the global dual-stack PBR policy and then apply it again.
node 0 deny
node 2 permit
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·     not support—The device does not support the match criteria configured on the node.
·     no resource—No sufficient resources (for example, ACLs) are available for the node.
if-match acl
apply next-hop
Specifies an output interface for permitted packets.
This field displays the interface status in brackets.
·     down—The interface is down at the network layer.
·     inactive—The card that hosts the interface is not in position.
Matches
Number of successful matches on the node.
If the device does not support counting successful matches on a node, this field displays N/A.
If match counting is disabled on the node, this field is not displayed.
If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
bytes
Number of matching bytes on the node.
This field displays N/A if the device does not support counting matching bytes on a node.
This field is not displayed if match counting is disabled on the node.
Total matches
Total number of successful matches on all nodes.
This field displays N/A if the device does not support counting successful matches on a node.
This field is not displayed if match counting is disabled on all nodes.
total bytes
Total number of matching bytes on all nodes.
dual-stack global policy-based-route
display dual-stack policy-based-route interface
Use display dual-stack policy-based-route interface to display interface dual-stack PBR configuration and statistics.
display dual-stack policy-based-route interface interface-type interface-number [ slot slot-number ]
# Display dual-stack PBR configuration and statistics on VLAN-interface 2.
<Sysname> display dual-stack policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-interface2:
Policy name: aaa
  node 0 deny:
  node 1 permit:
  node 2 permit:
  node 5 permit:
Policy based routing information for interface XXXX
Dual-stack PBR configuration and statistics on the interface.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the dual-stack policy from the interface and then apply it on the interface again.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·     For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·     For a physical interface, specify its slot number.
node 0 deny
node 2 permit
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
apply next-hop
Matches
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
bytes
Total matches
total bytes
dual-stack policy-based-route (interface view)
display dual-stack policy-based-route setup
Use display dual-stack policy-based-route setup to display dual-stack PBR configuration.
# Display dual-stack PBR configuration.
<Sysname> display dual-stack policy-based-route setup
Policy name              Type     Interface
pr01                     Forward  Vlan-interface2
pr01                     Global   N/A
Type of the PBR:
·     Forward—Interface PBR.
·     Global—Global PBR.
Interface where the policy is applied.
This field displays N/A for local dual-stack PBR and global dual-stack PBR.
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
if-match acl { ipv4 | ipv6 | user-defined } { acl-number | name acl-name }
undo if-match acl
No ACL match criterion is set.
ipv4: Specifies IPv4 ACL.
ipv6: Specifies IPv6 ACL.
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, 3000 to 3999 for an advanced ACL, and 5000 to 5999 for a user-defined ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
If the specified ACL does not exist or has no rules configured, no packets will match the ACL.
ACL rules specified in a dual-stack PBR policy do not support specifying the vpn-instance keyword.
# Configure Node 11 of policy aa to permit the packets matching IPv4 ACL 2011.
[Sysname-pbrdual-aa-11] if-match acl ipv4 2011
# Configure Node 11 of policy aa to permit the packets matching IPv6 ACL aaa.
[Sysname-pbrdual-aa-11] if-match acl ipv6 name aaa
Use dual-stack global policy-based-route to specify a PBR policy as the global dual-stack PBR policy.
Use undo dual-stack global policy-based-route to restore the default.
dual-stack global policy-based-route policy-name
No policy is specified for global dual-stack PBR.
policy-name: Specifies a PBR policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Global dual-stack PBR guides the forwarding of packets on all interfaces of the device.
You can specify only one policy for global dual-stack PBR on the device. Before you apply a new global dual-stack PBR policy, you must first remove the current global dual-stack PBR policy.
Interface dual-stack PBR takes precedence over global dual-stack PBR on an interface. When they are both configured and packets fail to match the interface dual-stack PBR policy, global dual-stack PBR applies.
# Specify policy aaa for global dual-stack PBR.
[Sysname] dual-stack global policy-based-route aaa
display ip policy-based-route global
Use dual-stack policy-based-route to apply a dual-stack PBR policy to an interface.
Use undo dual-stack policy-based-route to restore the default.
dual-stack policy-based-route policy-name
No dual-stack PBR policy is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
# Apply dual-stack PBR policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] dual-stack policy-based-route aaa
Use dual-stack policy-based-route to create a dual-stack policy node and enter its view, or enter the view of an existing dual-stack policy node.
Use undo dual-stack policy-based-route to delete a dual-stack policy or dual-stack policy node.
dual-stack policy-based-route policy-name [ deny | permit ] node node-number
undo dual-stack policy-based-route policy-name [ deny | node node-number | permit ]
No dual-stack policy nodes exist.
policy-name: Specifies a dual-stack policy by its name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
A dual-stack policy that has been applied to an interface or globally cannot be deleted. To delete it, you must first cancel the application.
·     If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
·     If a match mode is specified, the command deletes all nodes configured with the match mode.
·     If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for dual-stack policy policy1 and enter its view.
[Sysname] dual-stack policy-based-route policy1 permit node 10
[Sysname-pbrdual-policy1-10]
reset dual-stack policy-based-route statistics
Use reset dual-stack policy-based-route statistics to clear dual-stack PBR statistics.
reset dual-stack policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a dual-stack PBR policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a dual-stack PBR policy, this command clears statistics for all dual-stack PBR policies.
# Clear all dual-stack PBR statistics.
<Sysname> reset dual-stack policy-based-route statistics
