- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-mDNS gateway commands
- 06-mDNS relay commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Adjacency table commands
- 10-IRDP commands
- 11-IP performance optimization commands
- 12-UDP helper commands
- 13-IPv6 basics commands
- 14-IPv6 neighbor discovery commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
01-ARP commands | 346.47 KB |
arp ip-unnumbered learning enable
arp mac-interface-consistency check enable
arp timer aging probe-interval
arp unknown-source-mac-probing enable
arp user-ip-conflict record enable
display arp user-ip-conflict record
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
ARP direct route advertisement commands
arp route-direct advertise delay
display arp route-direct advertise
Commands for disabling sending ARP requests when data packets trigger ARP resolution
ARP commands
arp check enable
Use arp check enable to enable dynamic ARP entry check.
Use undo arp check enable to disable dynamic ARP entry check.
arp check enable
Dynamic ARP entry check is enabled.
Dynamic ARP entry check disables a device from supporting dynamic ARP entries with multicast MAC addresses. The device cannot learn dynamic ARP entries containing multicast MAC addresses. You cannot manually add static ARP entries that contain multicast MAC addresses.
When dynamic ARP entry check is disabled, ARP entries containing multicast MAC addresses are supported. The device can learn dynamic ARP entries containing multicast MAC addresses obtained from the ARP packets sourced from a unicast MAC address. You can also manually add static ARP entries containing multicast MAC addresses.
# Enable dynamic ARP entry check.
[Sysname] arp check enable
arp check log enable
Use arp check log enable to enable the ARP logging feature.
Use undo arp check log enable to disable the ARP logging feature.
ARP logging is disabled.
This feature enables a device to log ARP events when ARP cannot resolve IP addresses correctly. The log information helps administrators locate and solve problems. The device can log the following ARP events:
· On a proxy ARP-disabled interface, the target IP address of a received ARP packet is not one of the following IP addresses:
¡ The IP address of the receiving interface.
¡ The virtual IP address of the VRRP group.
· The sender IP address of a received ARP reply conflicts with one of the following IP addresses:
The device sends ARP log messages to the information center. You can use the info-center source command to specify the log output rules for the information center. For more information about information center, see System Management Configuration Guide.
The device can generate a large number of ARP logs. To conserve system resources, enable ARP logging only when you are auditing or troubleshooting ARP events.
# Enable ARP logging.
[Sysname] arp check log enable
arp hardware log enable
Use arp hardware log enable to enable error logging for ARP entry deployment to hardware.
Use undo arp hardware log enable to disable error logging for ARP entry deployment to hardware.
arp hardware log enable [ count-limit count-limit-value ]
Error logging for ARP entry deployment to hardware is disabled.
count-limit count-limit-value: Specifies the maximum number of logs that can be output per second about ARP entry deployment to hardware. The value range for the count-limit-value argument is 1 to 2000. If you do not specify this option, the device outputs a maximum of 2000 logs per second about ARP entry deployment to hardware.
Application scenarios
After the device learns ARP entries, it deploys the ARP entries to hardware for packet forwarding. You can execute this command to enable error logging for ARP entry deployment to hardware, which helps error location.
Operating mechanism
After you execute this command, the device logs the errors that occur during the deployment. The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see System Management Configuration Guide.
Log generation occupies memory. As a best practice, enable this feature only when traffic forwarding is abnormal for troubleshooting.
If the maximum number of logs that can be output per second is reached, no new error logs will be output.
# Enable error logging for ARP entry deployment to hardware and set the maximum number of logs that can be output per second to 100.
[Sysname] arp hardware log enable count-limit 100
arp ip-unique learning enable
Use arp ip-unique learning enable to enable unique ARP entry learning for the device to learn only one ARP entry for one IP address.
Use undo arp ip-unique learning enable to disable unique ARP entry learning for IP addresses.
Unique ARP entry learning for IP addresses is disabled.
Unique ARP entry learning enables the device to learn only one ARP entry for one IP address. This feature prevents traffic loss that might occur in the IP numbered scenario because two ARP entries exist for an endpoint after it moves between interfaces of the same IP address.
After you configure one interface to borrow an IP address from another interface by using the ip address unnumbered command, the two interfaces have the same IP address. If an endpoint moves from one of the interfaces to another with its IP address unchanged, the device will learn a new ARP entry for the same IP address with a different interface than the ARP entry learned before endpoint movement. This will cause loss of packets destined for the endpoint, because the FIB entry for the endpoint is generated based on the ARP entry generated earlier for it.
Operating mechanism
With unique ARP entry learning enabled, the device deletes the existing ARP entry for an IP address when it learns a new ARP entry with a different interface than the existing entry for that IP address. This ensures that the outgoing interface in the FIB entry for the client is the one to which the endpoint is attached.
# Enable unique ARP entry learning.
[Sysname] arp ip-unique learning enable
Use arp ip-unnumbered learning enable to enable an IP unnumbered interface to learn ARP entries for different subnets.
Use undo arp ip-unnumbered learning enable to disable an IP unnumbered interface from learning ARP entries for different subnets.
arp ip-unnumbered learning enable [ source-address ip-address ]
An IP unnumbered interface cannot learn ARP entries for different subnets.
Interface view
source-address ip-address: Specifies the sender IP address in an ARP request sent by the IP unnumbered interface. If you do not specify this option, the sender IP address in the ARP request is the borrowed IP address.
An IP unnumbered interface might be unable to learn the ARP entry for the peer device if the unnumbered interface and the remote device are on different subnets. This is because some devices treat an ARP request as illegal and do not return a reply if the sender and target IP addresses in that ARP request are on different subnets.
To ensure communication between them, use this feature on the IP unnumbered interface to specify a sender IP address on the same subnet as the IP address of the peer interface on the remote device.
This feature takes effect only on IP unnumbered interfaces, which are configured with the ip address unnumbered command.
To avoid ARP learning anomalies, do not execute the arp ip-unnumbered learning enable command on a non-IP-unnumbered interface.
If you disable an IP unnumbered interface from learning ARP entries for different subnets, the device deletes the existing ARP entries learned for different subnets after they age out.
# Configure Twenty-FiveGigE 1/0/1 to borrow the IP address of Twenty-FiveGigE 1/0/2, and enable Twenty-FiveGigE 1/0/1 to learn ARP entries for different subnets.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] ip address unnumbered interface twenty-fivegige 1/0/2
[Sysname-Twenty-FiveGigE1/0/1] arp ip-unnumbered learning enable
Use arp mac-interface-consistency check enable to enable interface consistency check between ARP and MAC address entries.
Use undo arp mac-interface-consistency check enable to disable interface consistency check between ARP and MAC address entries.
Interface consistency check between ARP and MAC address entries is disabled.
In an unstable network, the receiving interface for packets from a user might change. The interface in the MAC address entry can be updated immediately while the interface in the ARP entry cannot. In this case, the packets matching the ARP entry will be sent out of an incorrect interface. To solve this problem, you can use this feature to periodically check the interface consistency between the ARP and MAC address entry for a user. If the interfaces are not the same, ARP sends ARP requests in the VLAN of the ARP entry and updates the entry with the ARP reply receiving interface.
Use the display mac-address command to display MAC address entries.
# Enable interface consistency check between ARP and MAC address entries.
[Sysname] arp mac-interface-consistency check enable
display mac-address (Layer 2—LAN Switching Command Reference)
arp max-learning-num
Use arp max-learning-num to set the dynamic ARP learning limit for an interface.
Use undo arp max-learning-num to restore the default.
arp max-learning-num max-number [ alarm alarm-threshold ]
The limit is the maximum value in the value range for the max-number argument. The value range for the max-number argument depends on the configuration of the hardware-mode command. For information about the hardware-mode command, see hardware resource management configuration in System Management Configuration Guide.
VXLAN VSI interface view
VLAN interface view
max-number: Specifies the maximum number of dynamic ARP entries for an interface. The maximum number depends on the configuration of the hardware-mode command. For information about the hardware-mode command, see hardware resource management configuration in System Management Configuration Guide.
alarm alarm-threshold: Specifies an alarm threshold for dynamic ARP learning, in percentage. The value range for the alarm-threshold argument is 1 to 100. The device generates a log message when the number of dynamic ARP entries learned on an interface reaches the value calculated by using the (max-number × alarm-threshold)/100 formula. If you do not specify an alarm threshold, the device does not generate log messages.
An interface can dynamically learn ARP entries. To prevent an interface from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the interface can learn. When the maximum number is reached, the interface stops learning ARP entries.
When the number argument is set to 0, the interface is disabled from learning dynamic ARP entries.
# Specify VLAN-interface 40 to learn a maximum of 10 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40] arp max-learning-num 10
# Specify Twenty-FiveGigE 1/0/1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-Twenty-FiveGigE1/0/1] arp max-learning-num 10
# Specify Layer 2 aggregate interface Bridge-Aggregation 1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-Bridge-Aggregation1] arp max-learning-num 10
# Specify Layer 3 aggregate interface Route-Aggregation 1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-Route-Aggregation1] arp max-learning-num 10
arp max-learning-number
Use arp max-learning-number to set the dynamic ARP learning limit for a device.
Use undo arp max-learning-number to restore the default.
arp max-learning-number max-number slot slot-number
undo arp max-learning-number slot slot-number
max-number: Specifies the maximum number of dynamic ARP entries for a device. The maximum number depends on the configuration of the hardware-mode command. For information about the hardware-mode command, see hardware resource management configuration in System Management Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID.
A device can dynamically learn ARP entries. To prevent a device from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the device can learn. When the maximum number is reached, the device stops learning ARP entries.
When the number argument is set to 0, the device is disabled from learning dynamic ARP entries.
# Configure the device to learn a maximum of 64 dynamic ARP entries.
[Sysname] arp max-learning-number 64
arp mode uni
Use arp mode uni to configure a port as a customer-side port.
Use undo arp mode to restore the default.
arp mode uni
undo arp mode
A port operates as a network-side port.
VLAN interface view
By default, the device associates an ARP entry with routing information when the device learns an ARP entry. The ARP entry provides the next hop information for routing. To save hardware resources, you can use this command to specify a port that connects to a user terminal as a customer-side port. The device will not associate the routing information with the learned ARP entries.
# Configure VLAN-interface 2 as a customer-side port.
[Sysname-Vlan-interface2] arp mode uni
arp static
Use arp static to configure a static ARP entry.
Use undo arp to delete an ARP entry.
arp static ip-address mac-address [ vlan-id interface-type interface-number | interface-type interface-number interface-type interface-number | vsi-interface vsi-interface-id tunnel number vsi vsi-name | vsi-interface vsi-interface-id interface-type interface-number service-instance instance-id vsi vsi-name ] [ vpn-instance vpn-instance-name ] [ description text ]
undo arp ip-address [ vpn-instance-name ]
No static ARP entries exist.
ip-address: Specifies an IP address for the static ARP entry.
mac-address: Specifies a MAC address for the static ARP entry, in the format of H-H-H.
vlan-id: Specifies the ID of a VLAN to which the static ARP entry belongs. The value range is 1 to 4094.
vsi-interface vsi-interface-id: Specifies a VSI interface by its number. The value range for the vsi-interface-id argument is the numbers of the VSI interfaces that have been created.
tunnel number: Specifies a tunnel interface by its number. The value range for the number argument is the numbers of the tunnel interfaces that have been created.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. You must specify this option if you specify a Layer 2 Ethernet interface for the preceding interface-type interface-number arguments. Do not specify this option if you specify an interface of other types for the preceding interface-type interface-number argument.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the static ARP entry belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The VPN instance must already exist. To specify a static ARP entry on the public network, do not specify this option.
description text: Specifies the description for the static ARP entry, a case-sensitive string of 1 to 255 characters.
A static ARP entry is manually configured and maintained. It does not age out and cannot be overwritten by any dynamic ARP entry.
Static ARP entries can be short or long.
A resolved short static ARP entry might become unresolved upon certain events, for example, when the resolved output interface goes down, or the corresponding VLAN or VLAN interface is deleted.
Long static ARP entries can be effective or ineffective. Ineffective long static ARP entries cannot be used for packet forwarding. A long static ARP entry is ineffective when any of the following conditions exists:
· The IP address in the entry conflicts with a local IP address.
· No local interface has an IP address in the same subnet as the IP address in the ARP entry.
If you specify the vlan-id interface-type interface-number argument, follow these restrictions and guidelines:
· The interface can be an Ethernet interface or an aggregate interface.
· The VLAN and VLAN interface must already exist. The specified Ethernet interface must belong to the specified VLAN.
· The IP address of the VLAN interface and the IP address specified by the ip-address argument must be on the same network.
· A long static ARP entry in a VLAN is deleted if the VLAN or VLAN interface is deleted.
On a VXLAN IP gateway that forwards traffic among VXLANs through VXLAN tunnels, a VSI interface can act as the gateway for multiple VXLANs. The VSI interface (input interface) might be connected to multiple VXLAN tunnel interfaces (output interfaces). In this case, you must specify the vsi-interface vsi-interface-id tunnel number vsi vsi-name parameters to identify a VSI interface-VSI-VXLAN tunnel interface binding. For more information about VSI interfaces, VSI, and VXLAN tunnel interfaces, see VXLAN Configuration Guide.
On a VXLAN IP gateway that forwards traffic from multiple local sites to remote sites, a VSI interface can act as the gateway for multiple local sites. The VSI interface (input interface) might be associated with multiple Ethernet services (output interfaces) on Layer 2 Ethernet interfaces through which the VSI interface connects to the local sites. In this case, you must specify the vsi-interface vsi-interface-id interface-type interface-number service-instance instance-id vsi vsi-name parameters to identify a VSI interface-Layer 2 Ethernet interface-Ethernet service instance-VSI binding. For more information about Ethernet service instances, see VXLAN Configuration Guide.
# Configure a long static ARP entry that contains IP address 202.38.10.2, MAC address 00e0-fc01-0000, and output interface Twenty-FiveGigE 1/0/1 in VLAN 10.
[Sysname] arp static 202.38.10.2 00e0-fc01-0000 10 twenty-fivegige 1/0/1
# Configure a long static ARP entry that contains IP address 1.1.1.1, MAC address 00e0-fc01-0000, input interface VSI-interface 1, output interface Tunnel 1, and VSI a.
[Sysname] arp static 1.1.1.1 00e0-fc01-0000 vsi-interface 1 tunnel 1 vsi a
# Configure a long static ARP entry that contains IP address 1.1.1.1, MAC address 00e0-fc01-0000, input interface VSI-interface 1, output interface Ethernet instance 1 on Twenty-FiveGigE 1/0/1, and VSI a.
[Sysname] arp static 1.1.1.1 00e0-fc01-0000 vsi-interface 1 twenty-fivegige 1/0/1 service-in
stance 1 vsi a
display arp
reset arp
arp timer aging
Use arp timer aging to set the aging timer for dynamic ARP entries.
Use undo arp timer aging to restore the default.
arp timer aging { aging-minutes | second aging-seconds }
In system view, the aging timer for dynamic ARP entries is 20 minutes.
In interface view, the aging timer for dynamic ARP entries is the aging timer set in system view.
VSI interface view
VLAN interface view
aging-minutes: Specifies the aging timer in minutes. The value range for this argument is 1 to 1440.
second aging-seconds: Specifies the aging timer in seconds. The value range for the aging-seconds argument is 5 to 86400.
Each dynamic ARP entry in the ARP table has a limited lifetime, called an aging timer. The aging timer of a dynamic ARP entry is reset each time the dynamic ARP entry is updated. Dynamic ARP entries that are not updated upon expiration of their aging timers are deleted from the ARP table.
You can set the aging timer for dynamic ARP entries to ensure that dynamic ARP entries are updated in a timely manner.
You can set the aging timer for dynamic ARP entries in system view or in interface view. The aging timer set in interface view takes precedence over the aging timer set in system view.
Set the aging timer for dynamic ARP entries as needed. For example, when you configure proxy ARP, set a short aging time so that invalid dynamic ARP entries can be deleted in a timely manner.
# Set the aging timer for dynamic ARP entries to 10 minutes.
# Set the aging timer for dynamic ARP entries to 200 seconds.
[Sysname] arp timer aging second 200
# Set the aging timer for dynamic ARP entries to10 minutes on VLAN-interface 2.
[Sysname-Vlan-interface2] arp timer aging 10
display arp timer aging
arp timer aging probe-count
Use arp timer aging probe-count to set the maximum number of probes for dynamic ARP entries.
Use undo arp timer aging probe-count to restore the default.
arp timer aging probe-count count
In system view, the maximum number of probes for dynamic ARP entries is 3.
In interface view, the maximum number of probes for dynamic ARP entries is that set in system view.
VSI interface view
count: Specifies the maximum number of probes. The value range for this argument is 0 to 10. To disable the device from probing dynamic ARP entries, set the value to 0.
Dynamic ARP entry probing prevents legal dynamic ARP entries from aging out, avoiding unnecessary ARP resolution in forwarding.
This probe feature sends ARP requests for the IP address in a dynamic ARP entry before it ages out.
· If the device receives an ARP reply before the entry aging timer expires, the device resets the aging timer.
· If the device makes the maximum number of probes without receiving a reply, the device deletes the entry when the entry aging timer expires.
You can set the maximum number of probes in system view and in interface view. The setting in interface view takes precedence over that in system view.
# Configure the device to perform a maximum of five probes for dynamic ARP entries.
[Sysname] arp timer aging probe-count 5
# Configure the device to perform a maximum of five probes for dynamic ARP entries on Vlan-interface 2. (on switches)
[Sysname-Vlan-interface 2] arp timer aging probe-count 5
arp timer aging
Use arp timer aging probe-interval to set the interval for probing dynamic ARP entries.
Use undo arp timer aging probe-interval to restore the default.
arp timer aging probe-interval interval
In system view, the probe interval is 5 seconds.
In interface view, the probe interval is that set in system view.
VSI interface view
VLAN interface view
interval: Specifies the probe interval, in seconds. The value range is 1 to 60.
Before a dynamic ARP entry ages out, the device sends ARP requests for the IP address in the ARP entry.
· If the device receives an ARP reply before a probe interval expires, the device resets the aging timer.
· If the device has not received an ARP reply when a probe interval expires, the device starts a new probe.
· If the device makes the maximum number probes without receiving an ARP reply, the device deletes the entry.
You can set the probe interval in system view and in interface view. The probe interval in interface view takes precedence over the probe interval in system view.
# Set the probe interval to 10 seconds for dynamic ARP entries.
[Sysname] arp timer aging probe-interval 10
# Set the probe interval to 10 seconds for dynamic ARP entries on Vlan-interface 2.
[Sysname-Vlan-interface 2] arp timer aging probe-interval 10
arp timer aging
Use arp unknown-source-mac-probing enable to enable unknown source MAC-triggered ARP probing.
Use undo arp unknown-source-mac-probing enable to disable unknown source MAC-triggered ARP probing.
Unknown source MAC-triggered ARP probing is disabled.
By default, upon receiving a data packet with an unknown source MAC address from a user, the device learns a MAC address entry. It does not learn an ARP entry so the device cannot send packets destined for the user. To resolve this issue, you can enable unknown source MAC-triggered ARP probing.
Operating mechanism
This feature enables the device to perform ARP probing upon receiving a data packet with an unknown source MAC address. During ARP probing, the device sends an ARP request out of the receiving interface with the source IP address of the data packet as the target MAC address. If the device receives an ARP reply, the device creates an ARP entry.
In inter-AC roaming, a client roams among APs that are managed by different ACs with its IP address unchanged. For the client to receive packets after it roams to a new AC, enable this feature on the ACs.
# Enable unknown source MAC-triggered ARP probing on interface Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] arp unknown-source-mac-probing enable
Use arp user-ip-conflict record enable to enable recording user IP address conflicts.
Use undo arp user-ip-conflict record enable to disable recording user IP address conflicts.
Recording user IP address conflicts is disabled.
This feature enables the device to detect and record user IP address conflicts. The device determines that a conflict occurs if an incoming ARP packet has the same sender IP address as an existing ARP entry but a different sender MAC address. The device generates a user IP address conflict record, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration, see the information center in System Management Configuration Guide.
A device can generate a maximum of 10 user IP address conflict logs per second.
To display user IP address conflict records, use the display arp user-ip-conflict record command.
# Enable recording user IP address conflicts.
[Sysname] arp user-ip-conflict record enable
arp user-move record enable
Use user-move record enable to enable recording user port migrations.
Use undo arp user-move record enable to disable recording user port migrations.
Recording user port migrations is disabled.
Each device can generate a maximum of 10 user port migration logs per second.
To display user port migration records, use the display arp user-move record command.
# Enable recording user port migration.
[Sysname] arp user-move record enable
display arp
Use display arp to display ARP entries.
display arp [ [ all | dynamic | static ] [ slot slot-number ] | interface interface-type interface-number ] [ count | verbose ]
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
static: Displays static ARP entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ARP entries for the master device.
vlan vlan-id: Specifies a VLAN by its VLAN ID. The VLAN ID is in the range of 1 to 4094.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ARP entries for all interfaces.
count: Displays the number of ARP entries.
verbose: Displays detailed information about ARP entries.
This command displays information about static and dynamic ARP entries, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display all ARP entries.
Type: S-Static D-Dynamic O-Openflow R-Rule I-Invalid
IP address MAC address VLAN/VSI name Interface Aging Type
1.1.1.1 02e0-f102-0023 1 25GE1/0/1 -- S
1.1.1.2 00e0-fc00-0001 12 25GE1/0/2 960 D
# Display detailed information about all ARP entries.
<Sysname> display arp all verbose
IP address : 1.1.1.1 MAC address : 02e0-f102-0023
Type : Static Aging : --
Interface : 25GE1/0/1 SVLAN/CVLAN : 1/--
VPN instance : --
Link ID : --
Service instance : --
VXLAN ID : --
VSI name : --
VSI interface : --
IP address : 1.1.1.2 MAC address : 00e0-fc00-0001
Type : Dynamic Aging : 960 seconds
Interface : 25GE1/0/2 SVLAN/CVLAN : 12/--
VPN instance : --
Link ID : --
VXLAN ID : --
VSI name : --
VSI interface : --
# Display the number of all ARP entries.
<Sysname> display arp all count
Total number of entries : 3
IP address |
IP address in an ARP entry. |
MAC address |
MAC address in an ARP entry. |
VLAN/VSI name |
ID of the VLAN to which an ARP entry belongs. This field displays hyphens (--) in either of the following situations: · The ARP entry is an unresolved short static ARP entry. · The output interface of the ARP entry does not belong to any VLAN. |
Output interface in an ARP entry. This field displays hyphens (--) if the ARP entry is an unresolved short static ARP entry. |
Aging |
Aging time for an ARP entry, in seconds. · For a static ARP entry, this field always displays hyphens (--). The static ARP entry never ages out unless you delete it manually. · For a dynamic ARP entry, this field displays hyphens (--) if the aging time is unknown. |
Type |
ARP entry type: · D—Dynamic. · S—Static. · O—OpenFlow. This type is not supported in the current software version. · R—Rule. This type is not supported in the current software version. · I—Invalid. |
SVLAN/CVLAN |
ID of the SVLAN or CVLAN to which the ARP entry belongs. This field displays hyphens (--) in either of the following situations: · The ARP entry is an unresolved short static ARP entry. · The output interface of the ARP entry does not belong to any SVLAN or CVLAN. |
VPN instance |
Name of VPN instance. This field displays hyphens (--) if no VPN instance is configured for the ARP entry. |
Link ID |
This field is not supported in the current software version. Link ID in an ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any VSI. |
Service instance |
This field is not supported in the current software version. Ethernet service instance in an ARP entry. This field displays hyphens (--) if no Ethernet service instance is specified for the Layer 2 Ethernet interface or Layer 2 aggregate interface in the ARP entry. |
VXLAN ID |
This field is not supported in the current software version. VXLAN ID (also called VNI). This field displays hyphens (--) if the ARP entry does not belong to any VXLAN. |
VSI name |
This field is not supported in the current software version. Name of the VSI to which the ARP entry belongs. This field displays hyphens (--) if the ARP entry does not belong to a specific VSI. |
VSI interface |
This field is not supported in the current software version. VSI interface specified for the VSI. This field displays hyphens (--) if no VSI interface is specified for the VSI. |
Total number of entries |
Number of ARP entries. |
arp static
reset arp
display arp diff
Use display arp diff to display the differences in ARP entries between the specified slots.
display arp diff [ all | [ vpn-instance vpn-instance-name ] [ ip-address ] ] slot slot-number1 slot slot-number2
all: Displays ARP entry differences on the public network and all private networks.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN instance name cannot contain spaces. If you do not specify a VPN instance, this command displays ARP entry differences on the public network.
ip-address: Displays differences for ARP entries that exactly match the specified IP address. If you do not specify an IP address, this command displays differences for all ARP entries.
slot slot-number1 slot slot-number2: Specifies two IRF member devices by member ID.
Entry inconsistency between IRF member devices might cause packet loss, slow packet processing, or too many packets in queues. To avoid such an issue, you can use this command to display ARP entry differences between the specified slots.
Operating mechanism
If you specify none of the all, vpn-instance vpn-instance-name, and ip-address parameters, this command displays the differences in ARP entries on the public network.
When you execute this command, you must specify two different slots.
# Display the differences in ARP entries between the specified slots on the public network and all private networks.
<Sysname> dis arp diff all slot 0 slot 1
--- Slot 0 CPU 0
+++ Slot 1 CPU 0
@@ -1,3 +0,0 @@
-IP:10.0.0.2 Interface:25GE1/0/1
-IP:10.0.0.2 Interface:25GE1/0/2
\ No newline at end of file
+IP:10.0.0.4 Interface:25GE1/0/1
+IP:10.0.0.4 Interface:25GE1/0/2
Slot |
· --- Slot—The first slot specified for comparison. · +++ Slot—The second slot specified for comparison. |
CPU |
ID of the CPU on the card. |
IP |
IP address of the ARP entry. The minus sign (-) before this field indicates that the entry belongs to the first specified slot. The plus sign (+) before this field indicates that the entry belongs to the second specified slot. |
Output interface for the ARP entry. |
\ No newline at end of file |
All ARP entry differences on the specified slot have been printed. |
display arp entry-limit
Use display arp entry-limit to display the maximum number of ARP entries that a device supports.
# Display the maximum number of ARP entries that the device supports.
<Sysname> display arp entry-limit
ARP entries: 90112
display arp ip-address
Use display arp ip-address to display the ARP entry for an IP address.
display arp ip-address [ slot slot-number ] [ verbose ]
ip-address: Displays the ARP entry for the specified IP address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for the master device.
verbose: Displays the detailed information about the specified ARP entry.
The ARP entry information includes the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display the ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
20.1.1.1 00e0-fc00-0001 N/A -- -- S
arp static
reset arp
display arp log
Use display arp log to display brief ARP log information.
display arp log [ interface interface-type interface-number | ip ip-address ] [ slot slot-number ]
interface: Displays the ARP log information for the specified interface.
ip: Displays the ARP log information for the specified IP address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ARP logs for the master device.
# Display brief information about all ARP log entries.
<Sysname> display arp log
Operate : ADD Reason : ADDBYMSG
Mac : 0000-0000-0000 Interface: GE2/0/1
SVLAN : 65535 IP : 1.1.1.2
CVLAN : 65535 Time : Oct 28 22:22:02 2022
SVLAN : 65535 IP : 1.1.1.1
Operate |
ARP entry operation type: · ADD—Add an entry to the table. · MOD—Modify an existing entry in the table. · DEL—Delete an entry from the table. |
Reason |
Source of the ARP log entry: · DRNIMSG—Added in response to an ARP entry update message from the M-LAG module. · STATICFIX—Added in response to conversion of a dynamic ARP entry to a static one. · PKTLEARN—Added by learning from an ARP packet. · STATICMSG—Added through static configuration. · ADDBYRULE—Added by the IPoE or portal feature. · ADDBYOP—Added by the OpenFlow feature. · ADDBYMSG—Added through ARP entry synchronization. · ADDWADJ—Added in response to an IPv4 adjacency entry refresh message sent by the WAN link adjacency table module. · ADDWADJSYN—Added in response to an inter-card IPv4 adjacency entry synchronization message sent by the WAN link adjacency table module. · DRVRELOAD—Added in response to the ARP update operation done in the driver. · STATICEVENT—Added through ARP entry update in response to a long static entry event. · SYNCWITHDRV—Added in synchronization with the driver. · RELOADBYPW—Added in response to the PW reload operation. · RELOADBYMMAC— Added through ARP entry refresh triggered by the MultiMac module. · RELOADBYRB—Added through ARP entry refresh triggered by the RB module. · DELBYCFG—Manually deleted. · DELBYIPVRF—Deleted in bulk. · DELBYVSRP—Deleted by VSRP. · DELBYNODUMMY—Deleted due to lack of a DUMMY entry. · DELBYSMOOTH—Deleted upon ARP entry smoothing. · DELBYSMOOTHFILTER—Deleted through filtering in an ARP entry smooth operation. · DELCONFIGIPIF—Deleted upon an IPv4 address or interface conflict. · DELARPSYN—Deleted upon an inter-card ARP entry synchronization. · DELWADJMSG—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table. · DELWADJIFMSG—Deleted by interface upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table. · DELWADJBI—Deleted upon reception of the entry deletion message sent from the WAN link adjacency table module to the link layer in the kernel. · DELWADJDUMMY—Deleted upon deletion of the corresponding DUMMY entry by the WAN link adjacency table module. · DELWADJIFEVENT—Deleted upon deletion of the corresponding IPv4 adjacency entry done by the WAN link adjacency table module in response to an interface event. · DELWADJALL—Deleted upon deletion of all IPv4 adjacency entries from the WAN link adjacency table. · DELWADJ—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table. · DELWADJSAGE—Deleted upon deletion of the corresponding IPv4 adjacency entry that had aged out from the WAN link adjacency table. · DELWADJIFSYN—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table in response to interface entry synchronization. · DELWADJSYNMSG—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table in response to inter-card entry synchronization. · DELWADJSMOOTH—Deleted upon deletion of the corresponding IPv4 adjacency entry because of entry smoothing done by the WAN link adjacency table module. · DELWADJPULLFINISH—Deleted upon deletion of the corresponding IPv4 adjacency entry after the WAN link adjacency table module successfully obtained entries in bulk. · DELPORTLVLAN—Deleted upon removal of the port from the VLAN. · DELVLANMODCHG—Deleted upon VLAN mode change. · DELLIMIT—Deleted because the number of ARP entries has reached the limit. · DELARPBYOPIF—Deleted upon deletion of the interface. · DELARPVLANEVENT—Deleted upon a VLAN event. · DELARPSTATUS—Deleted upon ARP entry status change. · DELARPBYIPIF—Deleted by specify the IPv4 address or interface. · DELARPBYIFMAP—Deleted upon an interface mapping operation. · DELARPBYIFDOWN— Deleted because the interface went down. · DELARPBYIFAGG—Deleted because the interface was added to a link aggregation group. · DELARPBYNODE—Deleted upon deletion of ARP entries by slot. · DELARPBYALL—Deleted upon deletion of all ARP entries. · DELARPBYALLEM—Deleted upon deletion of all ARP entries from non-management interfaces. · DELARPBYPW—Deleted upon deletion of ARP entries from a PW. · DELARPBYPWVSI—Deleted upon deletion of ARP. entries done by PWVSI. · DELARPBYMACNOTIFY—Deleted upon reception of ARP entries from MAC. · DELARPBYRB—Deleted upon a RB action. · DELARPBYTCPKEEP—Deleted because of the topology change notification (TCN) flag. · DELARPBYSTATICFIX—Deleted upon conversion of a dynamic entry to a static entry. · DELBYPULLFINISH—Deleted upon a successful batch data pull. · DELSTATICCONFLICT—Deleted upon a static configuration conflict. |
IP |
IP address in the ARP entry. |
Mac |
MAC address in the ARP entry. |
Name of the outgoing interface in the ARP entry. |
SVLAN |
Service provider VLAN. |
CVLAN |
Customer VLAN. |
Time |
Timestamp of log creation. |
display arp openflow count
Use display arp openflow count to display the number of OpenFlow ARP entries.
display arp openflow count [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the number of OpenFlow ARP entries for the master device.
# Display the number of OpenFlow ARP entries.
<Sysname> display arp openflow count
Total number of OpenFlow ARP entries: 6
Use display arp timer aging to display the aging timer of dynamic ARP entries.
This command always displays the aging time in seconds no matter which unit you set in the arp timer aging command.
# Display the aging timer of dynamic ARP entries.
<Sysname> display arp timer aging
Current ARP aging time is 1200 seconds
arp timer aging
display arp usage
Use display arp usage to display the ARP table usage.
display arp usage
This command displays the maximum number of ARP entries supported on the device in addition to the history ARP table usage. You can use this command to monitor the number of ARP entries on the device and to determine whether ARP flood attacks exist on the network.
The device can display the ARP table usage only in the most recent hour.
# Display the ARP table usage.
<Sysname> display arp usage
ARP table upper limit: 65000
Time ARP entry count Usage
Current 52000 80%
1 min ago 51351 79%
2 min ago 50711 78%
3 min ago 47748 77%
59 min ago 13656 21%
60 min ago 13007 20%
ARP table upper limit |
Maximum number of ARP entries supported on the device. |
Time |
Time when the number of ARP entries was counted. This field displays Current if the number of ARP entries was counted just now. |
ARP entry count |
Usage |
ARP table usage, which is the ratio of the real-time ARP entry count to the ARP table upper limit. |
Use display arp user-ip-conflict record to display user IP address conflict records.
display arp user-ip-conflict record [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user IP address conflict records for the master device.
Each device can save a maximum of 200 user IP address conflict records.
If the maximum number is reached, a new record will override the earliest record.
# Display all user IP address conflict records.
<Sysname> display arp user-ip-conflict record
IP address: 10.1.1.1
System time: 2018-02-02 11:22:29
Conflict count: 1
Log suppress count: 0
Old interface: Twenty-FiveGigE1/0/1
New interface: Twenty-FiveGigE1/0/2
Old SVLAN/CVLAN: 100/2
New SVLAN/CVLAN: 100/2
Old MAC: 00e0-ca63-8141
New MAC: 00e0-ca63-8142
IP address: 10.1.1.2
System time: 2018-02-02 10:20:30
Conflict count: 1
Old SVLAN/CVLAN: 100/--
New SVLAN/CVLAN: 100/--
Table 5 Command output
IP address |
IP address of a user. |
System time |
Time when the user IP address conflict occurred. |
Conflict count |
Number of times that conflicts for the IP address. |
Log suppress count |
Number of times that user IP address conflict logs are suppressed. |
Old interface |
Output interface in the old ARP entry. |
New interface |
Output interface in the new ARP entry. |
Old SVLAN/CVLAN |
ID of the outer VLAN or inner VLAN in the old ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN. |
New SVLAN/CVLAN |
ID of the outer VLAN or inner VLAN in the new ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN. |
Old MAC |
MAC address in the old ARP entry. |
New MAC |
MAC address in the new ARP entry. |
Use display arp user-move record to display user port migration records.
display arp user-move record [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user port migration records for the master device.
Each device can save a maximum of 200 user port migration records.
When the number of user port migration records reaches the upper limit, new records will overwrite the earliest ones.
# Display all user port migration records.
<Sysname> display arp user-move record
MAC address: 0001-0201-0e81
Move count: 1
Before:
SVLAN/CVLAN: 100/2
After:
SVLAN/CVLAN: 100/2
MAC address: 0001-0201-0e82
Move count: 1
Before:
SVLAN/CVLAN: 100/--
After:
SVLAN/CVLAN: 100/--
Table 6 Command output
IP address |
IP address of the user. |
MAC address |
MAC address of the user. |
System time |
Time when the user port migration occurred. |
Move count |
Number of times that user port migrated. |
Number of times that the generation of user port migration logs is suppressed. |
Output interface in the ARP entry. |
SVLAN/CVLAN |
ID of the outer VLAN or inner VLAN in the ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN. |
display arp vpn-instance
Use display arp vpn-instance to display the ARP entries for a VPN instance.
display arp vpn-instance vpn-instance-name [ count ]
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN instance name cannot contain any spaces.
This command displays information about ARP entries for a VPN instance, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display ARP entries for VPN instance test.
<Sysname> display arp vpn-instance test
20.1.1.1 00e0-fc00-0001 -- -- -- S
arp static
reset arp
reset arp
Use reset arp to clear ARP entries from the ARP table.
reset arp { all | dynamic | interface interface-type interface-number | slot slot-number | static }
all: Clears all ARP entries.
dynamic: Clears all dynamic ARP entries.
static: Clears all static ARP entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears ARP entries for the master device.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears ARP entries for all interfaces.
CAUTION: The reset arp command will clear existing ARP entries from the ARP table. It might cause that external users cannot quickly communicate with the LAN users. |
# Clear all static ARP entries.
<Sysname> reset arp static
arp static
display arp
Gratuitous ARP commands
arp ip-conflict log prompt
Use arp ip-conflict log prompt to enable IP conflict notification.
Use undo arp ip-conflict log prompt to restore the default.
IP conflict notification is disabled.
By default, the device performs the following operations if it is using the sender IP address of a received ARP packet:
· Sends a gratuitous ARP request.
· Displays an error message after the device receives an ARP reply about the conflict.
You can use this command to enable the device to display error messages before sending a gratuitous ARP reply or request for conflict confirmation.
# Enable IP conflict notification on the device.
[Sysname] arp ip-conflict log prompt
arp send-gratuitous-arp
Use arp send-gratuitous-arp to enable periodic sending of gratuitous ARP packets on an interface.
Use undo arp send-gratuitous-arp to disable the interface from periodically sending gratuitous ARP packets.
arp send-gratuitous-arp [ interval interval ]
Periodic sending of gratuitous ARP packets is disabled.
VLAN interface view
interval interval: Specifies the sending interval in the range of 200 to 200000 milliseconds. The default value is 2000 milliseconds.
This feature takes effect on an interface only when the interface has an IP address and the data link layer state of the interface is up.
This feature can send gratuitous ARP requests only for a VRRP virtual IP address, or the sending interface's primary IP address or manually configured secondary IP address. The primary IP address can be configured manually or automatically, whereas the secondary IP address must be configured manually.
If you change the sending interval for gratuitous ARP packets, the configuration takes effect at the next sending interval.
The sending interval for gratuitous ARP packets might be much longer than the set interval when any of the following conditions exist:
· This feature is enabled on multiple interfaces.
· Each interface is configured with multiple secondary IP addresses.
· A small sending interval is configured in the preceding cases.
# Enable VLAN-interface 2 to send gratuitous ARP packets every 300 milliseconds.
[Sysname-Vlan-interface2] arp send-gratuitous-arp interval 300
Use gratuitous-arp mac-change retransmit to set the times and the interval for retransmitting a gratuitous ARP packet for the device MAC address change.
Use undo gratuitous-arp mac-change retransmit to restore the default.
gratuitous-arp mac-change retransmit times interval seconds
The device sends a gratuitous packet for its MAC address change once only.
times: Specifies the times of retransmitting a gratuitous packet, in the range of 1 to 10.
interval seconds: Specifies the interval for retransmitting a gratuitous packet, in the range of 1 to 10 seconds.
The device sends a gratuitous ARP packet to inform other devices of its MAC address change. However, the other devices might fail to receive the packet because the device sends the gratuitous ARP packet once only by default. Use this command to configure gratuitous ARP retransmission parameters to ensure that the other devices can receive the packet.
After you execute this command, the device will retransmit a gratuitous ARP packet for its MAC address change at the specified interval for the specified times.
# Set the times to 3 and the interval to 5 for retransmitting a gratuitous ARP packet for the device MAC address change.
[Sysname] gratuitous-arp mac-change retransmit 3 interval 5
Use gratuitous-arp-learning enable to enable learning of gratuitous ARP packets.
Use undo gratuitous-arp-learning enable to disable learning of gratuitous ARP packets.
Learning of gratuitous ARP packets is enabled.
The learning of gratuitous ARP packets feature allows a device to maintain its ARP table by creating or updating ARP entries based on received gratuitous ARP packets.
When this feature is disabled, the device uses received gratuitous ARP packets to update existing ARP entries only. ARP entries are not created based on the received gratuitous ARP packets, which saves ARP table space.
# Enable learning of gratuitous ARP packets.
[Sysname] gratuitous-arp-learning enable
gratuitous-arp-sending enable
Use gratuitous-arp-sending enable to enable sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
Use undo gratuitous-arp-sending enable to disable sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
A device does not send gratuitous ARP packets when it receives ARP requests whose sender IP address is on a different subnet.
# Disable a device from sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
[Sysname] undo gratuitous-arp-sending enable
Proxy ARP commands
display local-proxy-arp
Use display local-proxy-arp to display the local proxy ARP status.
display local-proxy-arp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the local proxy ARP status for all interfaces.
You can use this command to check whether local proxy ARP is enabled or disabled.
# Display the local proxy ARP status for VLAN-interface 2.
<Sysname> display local-proxy-arp interface vlan-interface 2
Interface Vlan-interface2
Local Proxy ARP status: enabled
local-proxy-arp enable
display proxy-arp
Use display proxy-arp to display the proxy ARP status.
display proxy-arp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the proxy ARP status for all interfaces.
You can use this command to check whether proxy ARP is enabled or disabled.
# Display the proxy ARP status on VLAN-interface 2.
<Sysname> display proxy-arp interface vlan-interface 2
Proxy ARP status: disabled
proxy-arp enable
display proxy-arp statistics
Use display proxy-arp statistics to display statistics about proxy ARP reply packets.
This command displays the proxy ARP reply statistics within the most recent minute on a per-second basis and displays the statistics one minute ago on a five-minute basis. The device can display the proxy ARP reply statistics in the most recent hour.
# Display proxy ARP reply statistics.
<Sysname> display proxy-arp statistics
Last 1 sec proxy count: 200
Last 2 sec proxy count: 400
Last 1 min proxy count: 12000
Last 5 min proxy count: 18000
Last 10 min proxy count: 24000
Last 60 min proxy count: 182445
Table 7 Command output
Last n sec proxy count: |
Number of proxy ARP reply packets within the most recent nth second. |
Last n min proxy count: |
Number of proxy ARP reply packets within the most recent nth minute. |
Use local-proxy-arp enable to enable local proxy ARP.
Use undo local-proxy-arp enable to disable local proxy ARP.
local-proxy-arp enable [ ip-range start-ip-address to end-ip-address ]
Local proxy ARP is disabled.
VLAN interface view
ip-range start-ip-address to end-ip-address: Specifies the IP address range for which local proxy ARP is enabled. The start IP address must be lower than or equal to the end IP address.
Proxy ARP enables a device on a network to answer ARP requests for an IP address not on that network. With proxy ARP, hosts in different broadcast domains can communicate with each other as they do on the same network.
Proxy ARP includes common proxy ARP and local proxy ARP.
Common proxy ARP allows communication between hosts that connect to different Layer 3 interfaces and reside in different broadcast domains.
Local proxy ARP allows communication between hosts that connect to the same Layer 3 interface and reside in different broadcast domains.
# Enable local proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] local-proxy-arp enable
# Enable local proxy ARP on VLAN-interface 2 for an IP address range.
[Sysname-Vlan-interface2] local-proxy-arp enable ip-range 1.1.1.1 to 1.1.1.20
proxy-arp enable
Use proxy-arp enable to enable proxy ARP.
Use undo proxy-arp enable to disable proxy ARP.
proxy-arp enable
Proxy ARP is disabled.
VLAN interface view
# Enable proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] proxy-arp enable
display proxy-arp
ARP snooping commands
arp snooping enable
Use arp snooping enable to enable ARP snooping.
Use undo arp snooping enable to disable ARP snooping.
arp snooping enable
ARP snooping is disabled.
VLAN view
VSI view
# Enable ARP snooping for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp snooping enable
# Enable ARP snooping for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp snooping enable
display arp snooping
Use display arp snooping to display ARP snooping entries.
display arp snooping { vlan [ vlan-id ] | vsi [vsi-name ] } [ slot slot-number ] [ count ]
display arp snooping vlan ip ip-address [ slot slot-number ]
vlan vlan-id: Displays ARP snooping entries for a VLAN. The vlan-id argument is in the range of 1 to 4094. If you do not specify a VLAN, this command deletes ARP snooping entries for all VLANs.
vsi vsi-name: Displays ARP snooping entries for a VSI. The vsi-name argument specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays ARP snooping entries for all VSIs.
count: Displays the number of the ARP snooping entries.
ip ip-address: Displays the ARP snooping entry for the specified IP address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ARP snooping entries for the master device.
# Display ARP snooping entries for VLAN 2.
<Sysname> display arp snooping vlan 2
IP Address MAC Address VLAN ID Interface Aging Status
3.3.3.3 0003-0003-0003 2 25GE1/0/1 20 Valid
3.3.3.4 0004-0004-0004 2 25GE1/0/2 5 Invalid
# Display ARP snooping entries for all VSIs.
<Sysname> display arp snooping vsi
IP address MAC address VSI name Link ID Aging(min)
1.1.1.2 000f-e201-0101 vsi1 0x70000 14
1.1.1.3 000f-e201-0202 vsi1 0x80000 18
1.1.1.4 000f-e201-0203 vsi2 0x90000 10
# Display the ARP snooping entry for IP address 1.1.1.1 in a VLAN.
<Sysname> display arp snooping vlan ip 1.1.1.1
IP address MAC address VLAN ID Interface Aging Status
1.1.1.1 001f-e201-0111 2 25GE1/0/1 15 Valid
# Display the number of ARP snooping entries in all VSIs.
<Sysname> display arp snooping vsi count
Total entries: 3
Table 8 Command output
IP Address |
IP address in an ARP snooping entry. |
MAC Address |
MAC address in the ARP snooping entry. |
VLAN ID |
ID of the VLAN to which the ARP snooping entry belongs. |
Input interface in the ARP snooping entry. |
Aging |
Aging time for the ARP snooping entry in minutes. If the card learns an ARP snooping entry from another card, the card cannot learn the aging time of the entry, and this field displays N/A. |
Status |
Status of the ARP snooping entry: Valid, Invalid, Collision. |
VSI name |
Name of the VSI to which the ARP snooping entry belongs. |
Link ID |
Link ID in the ARP snooping entry. It uniquely identifies an AC or a VXLAN tunnel in the VSI. |
Total entries |
Number of ARP snooping entries. |
reset arp snooping
reset arp snooping
Use reset arp snooping to delete ARP snooping entries.
reset arp snooping { vlan [ vlan-id ] | vsi [ vsi-name ] }
reset arp snooping vlan ip ip-address
vlan vlan-id: Deletes ARP snooping entries for the specified VLAN. The value range for the vlan-id argument is 1 to 4094. If you do not specify a VLAN, this command deletes ARP snooping entries for all VLANs.
vsi vsi-name: Deletes ARP snooping entries for the specified VSI. The vsi-name argument specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command deletes ARP snooping entries for all VSIs.
ip ip-address: Deletes the ARP snooping entry for the specified IP address.
If you do not specify any option, the command deletes all ARP snooping entries.
# Delete ARP snooping entries for VLAN 2.
<Sysname> reset arp snooping vlan 2
ARP fast-reply commands
arp fast-reply enable
Use arp fast-reply enable to enable ARP fast-reply for a VLAN.
Use undo arp fast-reply enable to disable ARP fast-reply for a VLAN.
ARP fast-reply is disabled on a VLAN.
VLAN view
# Enable ARP fast-reply for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp fast-reply enable
ARP direct route advertisement commands
arp route-direct advertise
Use arp route-direct advertise to enable ARP direct route advertisement.
Use undo arp route-direct advertise to disable ARP direct route advertisement.
arp route-direct advertise [ preference preference-value | tag tag-value ] *
ARP direct route advertisement is disabled.
VLAN interface view
VSI interface view
preference preference-value: Specifies the preference for the ARP-advertised direct routes. The value range for the preference-value argument is 1 to 255, and the default is 0. The smaller the value, the higher the preference.
tag tag-value: Specifies the route tag for the ARP-advertised direct routes. The value range for the tag-value argument is 1 to 4294967295, and the default is 0.
If ARP direct route advertisement is configured, ARP advertises ARP entries to the route management module to generate direct routes with an optional preference or route tag. The route preference value determines the match order of a route. Dynamic routing protocols use the tag value as the route identifier when they redistribute the route.
# Enable ARP direct route advertisement on Layer 3 Ethernet interface Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] arp route-direct advertise
# Enable ARP direct route advertisement on Layer 3 Ethernet interface Twenty-FiveGigE 1/0/1 and set the preference value to 1 for direct routes.
[Sysname-Twenty-FiveGigE1/0/1] arp route-direct advertise preference 1
arp route-direct advertise delay
Use arp route-direct advertise delay to set a delay for generating direct routes based on ARP entries.
Use undo arp route-direct advertise delay to restore the default.
arp route-direct advertise delay delay-time
The device generates a direct route immediately after an ARP entry is learned on an interface enabled with ARP direct route advertisement.
VLAN interface view
VSI interface view
delay-time: Specifies the delay for ARP-based generation of direct routes. The value range is 0 to 3600 seconds.
Application scenarios
After you enable ARP direct route advertisement on an interface by using the arp route-direct advertise command, the device generates direct routes and adjacency table entries based on ARP entries learned on that interface. If the direct routes are generated before the adjacency table entries for them, temporary packet loss will occur due to lack of Layer 2 information for packet encapsulation. To avoid such an issue, use this command to set a route generation delay for ARP direct route advertisement on the interface.
Operating mechanism
After you enable ARP direct route advertisement and set a route generation delay for it on an interface, a delay timer starts when an ARP entry is learned on that interface.
If the configuration for ARP direct route advertisement is modified before the delay time expires, the device advertises the direct route based on the new settings when the timer expires.
If you change the delay setting after a delay timer starts for an ARP entry, the new setting takes effect. However, the timer does not reset.
· If the timer count is equal to or higher than the new delay setting, the device generates a direct route based on the ARP entry.
· If the timer count is lower than the new delay setting, the device generates a direct route based on the ARP entry when the amount of new delay time is reached.
You can enable ARP direct route advertisement and set a delay for ARP-based generation of direct routes in any order. If you set the delay first and then enable ARP direct route advertisement, the device generates a direct route based on the ARP entry when the delay time is reached.
# Set a route generation delay for ARP direct route advertisement on Layer 3 Ethernet interface Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] arp route-direct advertise delay 200
display arp route-direct advertise
Use display arp route-direct advertise to display information about ARP direct route advertisement.
display arp route-direct advertise interface interface-type interface-number
interface interface-type interface-number: Specifies an interface by its type and number. Make sure ARP direct route advertisement is enabled on the interface.
When ARP direct route advertisement is enabled, the device generates direct routes based on ARP entries for packet forwarding and route advertisement. You can use this command to verify that the route management module has generated direct routes for ARP entries as configured.
# Display the direct routes generated based on ARP entries on Twenty-FiveGigE 1/0/1.
<Sysname> display arp route-direct advertise interface twenty-fivegige 1/0/1
IP address MAC address VLAN/VSI Interface Route
1.1.1.1 02e0-f102-0023 1 25GE1/0/1 Yes
1.1.1.2 00e0-fc00-0001 12 25GE1/0/1 No
Table 9 Command output
IP address |
MAC address |
VLAN/VSI |
ID of the VLAN or index of the VSI to which the ARP entry belongs. This field displays two hyphens (--) in either of the following situations: The ARP entry is an unresolved short static ARP entry. The output interface of the ARP entry does not belong to the VLAN or VSI. |
Route |
Whether or not a direct route has been generated based on the ARP entry: · Yes—A direct route has been generated based on the ARP entry. · No—No direct route has been generated based on the ARP entry. |
Commands for disabling sending ARP requests when data packets trigger ARP resolution
arp fib-miss drop
Use arp fib-miss drop to disable the device from sending ARP requests for ARP learning when data packets trigger ARP resolution.
Use undo arp fib-miss drop to restore the default.
arp fib-miss drop
The device sends ARP requests for ARP learning when data packets trigger ARP resolution.
VSI interface view
VLAN interface view
By default, when the device receives a data packet not destined for it and cannot find a match for the next hop in the ARP table, it performs the following tasks:
1. Sends an ARP request to obtain the MAC address of the next hop.
2. Generates an ARP entry based on the obtained MAC address.
A large number of ARP requests consume too many network resources, affecting normal service operation. To resolve the issue, use this feature to disable the device from sending ARP requests for ARP learning when data packets trigger ARP resolution. This suppresses ARP flooding by reducing ARP packets on the network.
Operating mechanism
After you configure this feature on an interface of the device, the device does not send an ARP request for ARP learning in the following conditions:
· The interface receives a data packet not destined for the device and the next hop for the data packet does not match any ARP entry.
· The interface sends a data packet that triggers ARP resolution.
As a best practice, configure this feature only when the network is attacked by ARP flooding.
# On VLAN-interface 100, disable the device from sending ARP requests for ARP learning when data packets trigger ARP resolution.
[Sysname-Vlan-interface100] arp fib-miss drop
ARP-Ping commands
ping arp ip
Use ping arp ip to test whether an IPv4 address is in use on a LAN by sending ARP requests.
ping arp ip host [ interface interface-type interface-number [ vlan vlan-id ] ] [ timeout timeout ] [ count count ]
host: Specifies the IP address or host name of the destination. The host name is a case-insensitive string of 1 to 253 characters. It can contain letters, digits, hyphens (-), underscores (_), and dots (.).
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the device uses the outgoing interface of the matching route to send ARP requests.
timeout timeout: Specifies the amount of time waiting for an ARP reply, in milliseconds. The value range is 0 to 65535. The default value is 3000.
count count: Specifies the maximum number of ARP requests to be sent. The value range is 1 to 4294967295. The default value is 5.
This command tests whether an IPv4 address in a LAN is in use by sending ARP requests. Compared with the ping command, the ping arp ip command avoids a wrong result when the destination host is enabled with a firewall that blocks ICMP packets. In addition, it consumes fewer network resources because an ARP request is shorter than an ICMP packet.
Operating mechanism
After the device sends an ARP request to an IPv4 address, if it receives an ARP reply before the ARP request timeout timer expires, it determines that the IP address is being used. If no ARP reply is received before the ARP request timeout timer expires, the device sends another ARP request. After the device sends the maximum number of ARP requests without receiving a reply, the device stops sending ARP requests and regards the IPv4 address as an unused address.
To execute the ping arp ip command by specifying the destination host name, configure the DNS feature first. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
If multiple devices exist on the LAN, executing this command will take some time. To stop an ongoing test, press Ctrl + C.
# Test whether IP address 1.1.1.3 is in use on the LAN by sending ARP requests. (In this example, the IP address has been used.)
<Sysname> ping arp ip 1.1.1.3
1.1.1.3 is used by 0003-0003-0003.
# Test whether IP address 1.1.1.3 is in use on the LAN by sending ARP requests. (In this example, the IP address is not in use.
The IP address is not used by anyone.
