- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-mDNS gateway commands
- 06-mDNS relay commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Adjacency table commands
- 10-IRDP commands
- 11-IP performance optimization commands
- 12-UDP helper commands
- 13-IPv6 basics commands
- 14-IPv6 neighbor discovery commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
| 07-IP forwarding basics commands | 96.57 KB |
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ] [ slot slot-number]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays FIB entries for the master device.
You can use this command to view the number of FIB entries successfully issued to hardware.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Route destination count: 5
Directly-connected host count: 0
Entries issued to hardware: 5
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
1.1.1.0/24 192.168.126.1 USGF M-GE0/0/0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Route destination count: 8
Flag:
R:Relay F:FRR
20.20.20.0/24 20.20.20.25 U M-GE0/0/0 Null
20.20.20.0/32 20.20.20.25 UBH M-GE0/0/0 Null
20.20.20.25/32 127.0.0.1 UH InLoop0 Null
20.20.20.25/32 20.20.20.25 H M-GE0/0/0 Null
20.20.20.255/32 20.20.20.25 UBH M-GE0/0/0 Null
20.20.20.255/32 1000:2000:3000:4000:5000:6000:7000:8000 UBH MGE0
/0/0 Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
FIB entry count: 1
Entries issued to hardware: 1
Flag:
R:Relay F:FRR
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
Route destination count |
Number of route destination addresses. |
Directly-connected host count |
Number of directly connected hosts learned by features such as ARP. |
Entries issued to hardware |
Number of FIB entries successfully issued to hardware. |
FIB entry count |
Total number of FIB entries. |
Destination/Mask |
Destination address and the mask length. |
Nexthop |
Next hop address. |
Flag |
Flags of routes: · U—Usable route. · G—Gateway route. · H—Host route. · B—Blackhole route. · D—Dynamic route. · S—Static route. · R—Relay route. · F—Fast reroute. |
OutInterface/Token |
Output interface/LSP index number. |
Label |
Inner label. |
display fib prefix diff
Use display fib prefix diff to display the differences in FIB entries between two slots.
display fib prefix diff [ all | [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ] ] slot slot-number1 slot slot-number2
all: Specifies all FIB entries of the public network and VPN instances.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters without spaces.
ip-address: Compares the FIB entries that match the specified destination IPv4 address.
mask: Specifies the mask for the IPv4 address.
mask-length: Specifies the mask length for the IPv4 address. The value range is 0 to 32.
slot slot-number1 slot slot-number2: Specifies two IRF member devices by their member IDs. You must specify two different IRF member devices.
Application scenarios
Inconsistency of FIB entries between member devices might cause issues such as packet loss, packet processing delay, and packet queue overload. Use this command to display the differences in FIB entries between member devices and check for inconsistency. If inconsistency exists, execute the display current-configuration diff command in any view to display the differences that the running configuration has as compared with the next-startup configuration and identify unnecessary configuration.
Operating mechanism
You can specify a subnet to match FIB entries when specifying the ip-address argument. If you do not specify any mask or mask length, the system compares the FIB entry that has the longest match with the specified destination IPV4 address on each slot. If you specify a mask or mask length, the system compares the FIB entry that has the exact match with the specified destination IPV4 address and mask on each slot.
# Display the differences in FIB entries between slot 0 and slot 3.
<Sysname> display fib prefix diff slot 0 slot 3
--- Slot 0 CPU 0
+++ Slot 3 CPU 0
@@ -1,19 +0,0 @@
-Destination/Mask:0.0.0.0/32 VNID:0x310000003 VPN:--
-Destination/Mask:10.0.0.0/24 VNID:0x710000007 VPN:--
-Destination/Mask:10.0.0.0/32 VNID:0x710000007 VPN:--
-Destination/Mask:10.0.0.1/32 VNID:0x310000003 VPN:--
-Destination/Mask:10.0.0.2/32 VNID:-- VPN:--
-Destination/Mask:10.0.0.255/32 VNID:0x710000007 VPN:--
-Destination/Mask:30.0.0.0/24 VNID:0x17000000 VPN:--
-Destination/Mask:127.0.0.0/8 VNID:0x310000003 VPN:--
-Destination/Mask:127.0.0.0/32 VNID:0x410000004 VPN:--
-Destination/Mask:127.0.0.1/32 VNID:0x310000003 VPN:--
-Destination/Mask:127.255.255.255/32 VNID:0x410000004 VPN:--
-Destination/Mask:172.16.94.0/24 VNID:0x610000006 VPN:--
-Destination/Mask:172.16.94.0/32 VNID:0x610000006 VPN:--
-Destination/Mask:172.16.94.100/32 VNID:0x310000003 VPN:--
-Destination/Mask:172.16.94.200/32 VNID:-- VPN:--
-Destination/Mask:172.16.94.201/32 VNID:-- VPN:--
-Destination/Mask:172.16.94.255/32 VNID:0x610000006 VPN:--
-Destination/Mask:255.255.255.255/32 VNID:0x310000003 VPN:--
\ No newline at end of file
+Destination/Mask:192.168.100.10/24 VNID:-- VPN:--
+Destination/Mask:192.168.100.20/24 VNID:-- VPN:--
--- A +++ B |
· A—Source slot number and CPU number for comparison. · B—Destination slot number and CPU number for comparison. |
@@ -linenumber1,number1 +linenumber2,number2 @@ |
· -linenumber1,number1—Display number1 entries starting from linenumber1 on the source slot. · +linenumber2,number2—Display number2 entries starting from linenumber2 on the destination slot. |
Destination/Mask |
Destination IP address and mask length. · A hyphen(-) in front of this field indicates that the entry exists on the source slot but not on the destination slot. · A plus sign(+) in front of this field indicates that the entry exists on the destination slot but not on the source slot. |
VNID |
VN ID. Two hyphens (--) indicates that no VN ID exists. |
VPN |
VPN instance name. Two hyphens (--) indicates the public network. |
No newline at end of file |
No more comparison results are available. |
display fib vn diff
Use display fib vn diff to display the differences in FIB VN entries between two slots.
display fib vn diff [ id id ] slot slot-number1 slot slot-number2
id id: Specifies the VN entry by its VN ID.
Inconsistency of VN entries between member devices might cause issues such as packet loss, packet processing delay, and packet queue overload. Use this command to display the differences in VN entries between the member devices and check for inconsistency. If inconsistency exists, execute the display current-configuration diff command in any view to display the differences that the running configuration has as compared with the next-startup configuration and identify unnecessary configuration.
If you do not specify the id keyword, the command displays the differences in all FIB VN entries between two slots.
# Display the differences in FIB VN entries between slot 0 and slot 3.
<Sysname> display fib vn diff slot 0 slot 3
--- Slot 0 CPU 0
+++ Slot 3 CPU 0
@@ -1,19 +1,2 @@
-VNID:0x810000008 NextHopNum:1 Flag:U Nexthop:[0]10.0.0.1
-VNID:0x70000001 NextHopNum:1 Flag:-- Nexthop:[0]Invalid
-VNID:0x10000000 NextHopNum:1 Flag:U Nexthop:[0]127.0.0.1
-VNID:0x20000000 NextHopNum:1 Flag:U Nexthop:[0]::1
-VNID:0x510000005 NextHopNum:1 Flag:U Nexthop:[0]127.0.0.1
-VNID:0x520000005 NextHopNum:1 Flag:U Nexthop:[0]::
-VNID:0x210000002 NextHopNum:1 Flag:-- Nexthop:[0]0.0.0.0
-VNID:0x220000002 NextHopNum:1 Flag:U Nexthop:[0]::1
-VNID:0x710000007 NextHopNum:1 Flag:U Nexthop:[0]10.0.0.1
-VNID:0x410000004 NextHopNum:1 Flag:U Nexthop:[0]127.0.0.1
-VNID:0x420000004 NextHopNum:1 Flag:U Nexthop:[0]::
-VNID:0x110000001 NextHopNum:1 Flag:U Nexthop:[0]127.0.0.1
-VNID:0x120000001 NextHopNum:1 Flag:U Nexthop:[0]::
-VNID:0x610000006 NextHopNum:1 Flag:U Nexthop:[0]172.16.94.100
-VNID:0x17000000 NextHopNum:2 Flag:-- Nexthop:[0]172.16.94.200
-VNID:0x17000000 NextHopNum:2 Flag:-- Nexthop:[1]172.16.94.201
-VNID:0x310000003 NextHopNum:1 Flag:-- Nexthop:[0]0.0.0.0
-VNID:0x320000003 NextHopNum:1 Flag:U Nexthop:[0]::
+VNID:0x70000001 NextHopNum:1 Flag:-- Nexthop:[0]Invalid
--- A +++ B |
VNID |
Virtual next hop ID. |
NextHopNum |
Total number of next hops. |
Nexthop |
Next hop information in the [Number]IP format: · Number—Next hop index number, starting from 0. · IP—Next hop IPv4 or IPv6 address. |
Flag |
Flag bit value: · U—The next hop takes effect. · --—The next hop does not take effect. |
forwarding split-horizon
Use forwarding split-horizon to enable split horizon forwarding.
Use undo forwarding split-horizon to disable split horizon forwarding.
Split horizon forwarding is disabled.
This feature prevents IPv4, IPv6, and MPLS packets from being forwarded out of the physical interface on which they were received, avoiding network loops.
# Enable split horizon forwarding.
[Sysname] forwarding split-horizon
forwarding vxlan-packet inner-protocol
Use forwarding vxlan-packet inner-protocol to enable hardware forwarding for specific packets received from VXLAN tunnels.
Use undo forwarding vxlan-packet inner-protocol to restore the default.
forwarding vxlan-packet inner-protocol { ipv4 | ipv6 } *
undo forwarding vxlan-packet inner-protocol [ ipv4 | ipv6 ]
Packets received from VXLAN tunnels are delivered to the CPU for processing.
ipv4: Specifies IPv4 packets.
ipv6: Specifies IPv6 packets.
By default, the device forwards packets received from VXLAN tunnels to the CPU for processing when acting as a VTEP in a distributed EVPN gateway network. If a large number of packets are received, packet loss might occur because of software rate limit, which might cause service exceptions on downlink devices.
To resolve this issue, you can enable the device to forward specific packets received from VXLAN tunnels in hardware without delivering them to the CPU.
# Enable hardware forwarding for IPv4 packets received from VXLAN tunnels.
[Sysname] forwarding vxlan-packet inner-protocol ipv4
ip forwarding apply vpn-peer-id enable
Use ip forwarding apply vpn-peer-id enable to enable the VPN peer-based processing.
Use undo ip forwarding apply vpn-peer-id enable to disable the VPN peer-based processing.
The VPN peer-based processing is disabled.
This feature enables the device to use the VPN peer ID of the routing information in the FIB table to process packets.
This command must be used together with the apply vpn-peer-id command. For more information about the command, see routing policy commands in Layer 3—IP Routing Command Reference.
# Enable the VPN peer-based processing.
[Sysname] ip forwarding apply vpn-peer-id enable
snmp-agent trap enable fib
Use snmp-agent trap enable fib to enable SNMP notifications for FIB events.
Use undo snmp-agent trap enable fib to disable SNMP notifications for FIB events.
SNMP notifications for FIB events are enabled.
This feature enables the FIB module to generate SNMP notifications for critical FIB events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for FIB events.
[Sysname] undo snmp-agent trap enable fib
