06-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS6550X-HI SeriesReference GuidesCommand ReferencesH3C S6550X-HI Command References-R1330Pxx-6W10006-Layer 2—LAN Switching Command Reference
15-Layer 2 forwarding commands
15-Layer 2 forwarding commands 35.70 KB
Cut-through Layer 2 forwarding commands
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to disable cut-through forwarding.
cut-through enable
Cut-through forwarding is disabled.
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the device and enhances forwarding performance.
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of being dropped.
# Enable cut-through forwarding on the device.
[Sysname] cut-through enable
