18-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5580X-EI[HI] & S5580S-EI Switch Series Command References-R1330Pxx-6W10018-Network Management and Monitoring Command Reference
10-Mirroring commands
10-Mirroring commands 181.68 KB
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
group-id: Specifies a mirroring group by its ID. The value range for this argument is 1 to 7.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
remote-destination: Specifies remote destination groups.
remote-source: Specifies remote source groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port: GigabitEthernet1/0/1 Inbound
    Monitor port: GigabitEthernet1/0/2 truncation
Mirroring group 2:
    Type: Local
    Status: Active
                  Encapsulation: Destination IP address 1.1.1.1
                                 Source IP address 2.2.2.2
                                 DSCP 1
                                 VLAN 2
                                 VRF Instance 3
                                 Destination MAC address 0011-0200-0211
                                 Reflector port GigabitEthernet1/0/3
                                 Probe VLAN 2
Mirroring group
Number of the mirroring group.
Type of the mirroring group:
·     Local.
·     Remote source.
·     Remote destination.
Status
Status of the mirroring group:
·     Active—The mirroring group has taken effect.
·     Incomplete—The mirroring group configuration is not complete and does not take effect.
Mirroring port
Source port.
Mirroring CPU
Source CPU.
Monitor port
Destination port and the processing for mirrored packets. truncation means truncating mirrored packets is enabled on the port.
Encapsulation
Encapsulation parameters of the mirrored packets.
Destination IP address in the outer header of the GRE-encapsulated mirrored packets.
Source IP address
Source IP address in the outer header of the GRE-encapsulated mirrored packets.
DSCP
DSCP value in the outer header of the GRE-encapsulated mirrored packets.
VLAN
VLAN in the outer header of the GRE-encapsulated mirrored packets.
VRF Instance
VPN instance whose routing table is used to direct forwarding of the mirrored packets.
Destination MAC address in the outer header of the GRE-encapsulated mirrored packets.
Reflector port
Reflector port for the outgoing mirrored packets of mirroring source ports.
Probe VLAN
Probe VLAN for a reflector port.
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id { local | remote-destination | remote-source }
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
No mirroring groups exist.
group-id: Specifies a mirroring group ID. The value range for this argument is 1 to 7.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-cpu
Use mirroring-group mirroring-cpu to configure source CPUs for a mirroring group.
Use undo mirroring-group mirroring-cpu to remove source CPUs from a mirroring group.
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-cpu slot slot-number-list
No source CPU is configured for a mirroring group.
group-id: Specifies a mirroring group by its number. The specified mirroring group must already exist. The value range for this argument is 1 to 7.
slot slot-number-list: Specifies a space-separated list of up to eight slot number items. An item specifies an IRF member device by its member ID or specifies a range of IRF member devices in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number.
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
You can configure source CPUs only for local mirroring groups and remote source groups.
# Create local mirroring group 1 to monitor the inbound traffic of the CPU on the specified slot.
[Sysname] mirroring-group 1 mirroring-cpu slot 1 inbound
mirroring-group
mirroring-group mirroring-port (interface view)
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
You can configure source ports only for local mirroring groups and remote source groups.
A Layer 2 or Layer 3 aggregate interface cannot be configured as a source port for a mirroring group.
Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
A port can act as a source port for only one mirroring group.
A source port cannot be used as a reflector port, monitor port, or egress port.
# Create local mirroring group 1 to monitor the bidirectional traffic of the port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port both
# Create remote source group 2 to monitor the bidirectional traffic of the port GigabitEthernet 1/0/2.
[Sysname] mirroring-group 2 remote-source
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 mirroring-port both
mirroring-group
mirroring-group mirroring-port (system view)
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
# Create local mirroring group 1 to monitor the bidirectional traffic of GigabitEthernet 1/0/1.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
# Create remote source group 2 to monitor the bidirectional traffic of GigabitEthernet 1/0/2.
[Sysname] mirroring-group 2 mirroring-port gigabitethernet 1/0/2 both
mirroring-group
mirroring-group monitor-egress
Use mirroring-group monitor-egress to configure the egress port for a remote source group.
Use undo mirroring-group monitor-egress to restore the default.
In system view:
mirroring-group group-id monitor-egress interface-type interface-number
undo mirroring-group group-id monitor-egress interface-type interface-number
In interface view:
No egress port is configured for a remote source group.
Interface view
interface-type interface-number: Specifies a port by its type and number.
You can configure egress ports only for remote source groups.
For port mirroring to work correctly, disable the following features on the egress port of a mirroring group:
·     Spanning tree.
·     802.1X.
·     IGMP snooping.
·     Static ARP.
·     MAC address learning.
The member port of an existing mirroring group cannot be configured as an egress port.
The member port of an aggregate interface cannot be configured as an egress port.
# Create remote source group 1. Configure GigabitEthernet 1/0/1 as its egress port in system view.
[Sysname] mirroring-group 1 remote-source
[Sysname] mirroring-group 1 monitor-egress gigabitethernet 1/0/1
# Create remote source group 2. Configure GigabitEthernet 1/0/2 as its egress port in interface view.
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 monitor-egress
mirroring-group
mirroring-group monitor-port (interface view)
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name | reflector-port interface-type interface-number probe-vlan probe-vlan-id ] * | truncation ] *
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
destination-ip destination-ip-address: Specifies the destination IP address for the mirrored packets.
source-ip source-ip-address: Specifies the source IP address for the mirrored packets.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 2. The default DSCP value is 0.
Table 2 DSCP keywords and values
Keyword
DSCP value in binary
DSCP value in decimal
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094 for the mirrored packets.
vrf-instance vrf-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The mirrored packets will be forwarded based on the routing table of the specified VPN instance.
truncation: Truncates the specified length of a mirrored packet from the specified start position and sends the truncated part to the monitor port.
reflector-port interface-type interface-number: Specifies a reflector port by its type and number for outgoing mirrored packets of mirroring source ports.
probe-vlan probe-vlan-id: Specifies a probe VLAN by its ID in the range of 1 to 4094.
You can configure monitor ports only for local mirroring groups and remote destination groups.
Only when you configure Layer 3 remote port mirroring through encapsulation parameters, you can configure the following encapsulation parameters for mirrored packets sent to the monitor port:
·     Destination IP address, which is the IP address of the remote data monitoring device.
·     Source IP address.
·     Optional encapsulation parameters, including the DSCP value, VLAN, VPN instance, and destination MAC address.
The mirrored packet is first encapsulated in a GRE packet with a protocol number of 0x88BE. The GRE packet is then encapsulated in a delivery protocol by using the configured encapsulation parameters and routed to the final destination.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
A Layer 2 or Layer 3 aggregate interface cannot be configured as the monitor port for a mirroring group.
An aggregation member port cannot be configured as the monitor port.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
Mirrored packet truncation reduces the packet processing workload on the data monitoring device and prevents the payload in packets from be sent to the data monitoring device.
Only local mirroring groups support mirrored packet truncation.
To modify the mirrored packet truncation configuration, you must first execute the undo mirroring-group monitor-port command.
When a port is configured as a reflector port, all the other settings on the port will be cleared. You cannot configure other features on a reflector port.
In a mirroring group, make sure the monitor port is different from the reflector port for outgoing mirrored packets of mirroring source ports.
You can configure a probe VLAN only for the reflector port of a local mirroring group. You cannot configure a probe VLAN for the reflector port of a remote source or destination group.
When a VLAN is configured as a probe VLAN for a reflector port, do not use the VLAN for any other purposes.
Only a static VLAN that already exists can be configured as a probe VLAN for a reflector port. A VLAN can be configured as the probe VLAN for the reflector port of only one mirroring group.
To delete a VLAN that is configured as a probe VLAN for a reflector port, first remove the probe VLAN configuration.
# Create local mirroring group 1 and configure GigabitEthernet 1/0/1 as its monitor port.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 monitor-port
# Create remote destination group 2 and configure GigabitEthernet 1/0/2 as its monitor port.
[Sysname] mirroring-group 2 remote-destination
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 monitor-port
# Create local mirroring group 3. Specify GigabitEthernet 1/0/1 as its monitor port and configure the encapsulation parameters including the source and destination IP addresses, DSCP value, VLAN, and VPN instance for the mirrored packets.
[Sysname] mirroring-group 3 local
[Sysname-GigabitEthernet1/0/1] mirroring-group 3 monitor-port destination-ip 1.1.1.1 source-ip 3.3.3.3 dscp 1 vlan 1 vrf-instance 122
mirroring-group
mirroring-group monitor-port (system view)
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name | reflector-port interface-type interface-number probe-vlan probe-vlan-id ] * | truncation ] *
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 3. The default DSCP value is 0.
Table 3 DSCP keywords and values
Keyword
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
A Layer 2 and Layer 3 aggregate interface cannot be configured as the monitor port for a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0/1
[Sysname] mirroring-group 2 monitor-port gigabitethernet 1/0/2
# Create local mirroring group 3 and configure ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 and GigabitEthernet 1/0/5 as its monitor ports.
[Sysname] mirroring-group 3 monitor-port gigabitethernet 1/0/1 to gigabitethernet 1/0/3 gigabitethernet 1/0/5
# Create local mirroring group 4. Specify GigabitEthernet 1/0/1 as its monitor port and configure the encapsulation parameters including the source and destination IP addresses, DSCP value, VLAN, and VPN instance for the mirrored packets.
[Sysname] mirroring-group 4 local
[Sysname] mirroring-group 4 monitor-port gigabitethernet 1/0/1 destination-ip 1.1.1.1 source-ip 3.3.3.3 dscp 1 vlan 1 vrf-instance 122
mirroring-group
mirroring-group reflector-port
Use mirroring-group reflector-port to configure the reflector port for a remote source group.
Use undo mirroring-group reflector-port to restore the default.
In system view:
mirroring-group group-id reflector-port interface-type interface-number
undo mirroring-group group-id reflector-port interface-type interface-number
In interface view:
No reflector port is configured for a mirroring group.
Interface view
CAUTION
CAUTION:
·     The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port.
·     When a port is configured as a reflector port, all the other settings on the port are cleared. You cannot configure other features on a reflector port.
You can configure reflector ports only for remote source groups.
You cannot change the duplex mode, MDI settings, or speed for a reflector port.
The member port of an aggregate interface cannot be configured as a reflector port.
# Create remote source group 1. Configure GigabitEthernet 1/0/1 as its reflector port in system view.
[Sysname] mirroring-group 1 reflector-port gigabitethernet 1/0/1
# Create remote source group 2. Configure GigabitEthernet 1/0/2 as its reflector port in interface view.
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 reflector-port
mirroring-group
mirroring-group remote-probe vlan
Use mirroring-group remote-probe vlan to specify a VLAN as the remote probe VLAN for a mirroring group.
Use undo mirroring-group remote-probe vlan to restore the default.
mirroring-group group-id remote-probe vlan vlan-id
undo mirroring-group group-id remote-probe vlan vlan-id
No remote probe VLAN is configured for a mirroring group.
vlan-id: Specifies a VLAN by its ID.
You can configure remote probe VLANs only for remote source groups and remote destination groups.
When a VLAN is configured as a remote probe VLAN, use the VLAN for port mirroring exclusively.
The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
Only a static VLAN that already exists can be configured as a remote probe VLAN. A VLAN can be configured as the remote probe VLAN for only one mirroring group.
To delete a VLAN that is configured as a remote probe VLAN, remove the remote probe VLAN configuration first.
# Create remote source group 1 and configure VLAN 10 as its remote probe VLAN.
[Sysname] mirroring-group 1 remote-probe vlan 10
# Create remote destination group 2 and configure VLAN 20 as its remote probe VLAN.
[Sysname] mirroring-group 2 remote-probe vlan 20
mirroring-group
Flow mirroring commands
display monitoring-group
Use display monitoring-group to display monitoring group information.
display monitoring-group { group-id | all }
group-id: Specifies a monitoring group by its number. The value range for this argument is 1 to 128.
all: Specifies all monitoring groups.
# Display information about all monitoring groups.
<Sysname> display monitoring-group all
Monitoring group 1:
  Monitoring ports:
    GigabitEthernet1/0/4
    GigabitEthernet1/0/5
  Monitoring ports:
    GigabitEthernet1/0/6
                     DSCP 1
                     VLAN 2
                     VRF Instance 3
  Monitoring ports:
    Dynamic Interface
      Encapsulation: Destination IP address 3.3.3.3
                     Source IP address 4.4.4.4
                     DSCP 11
                     VLAN 21
                     VRF Instance 31
                     Destination MAC address 0022-0301-2211
Monitoring group
ID of the monitoring group.
Monitoring ports
Monitoring ports in the monitoring group.
Encapsulation
Source IP address
DSCP
VLAN
VRF Instance
mirror-to cpu
Use mirror-to cpu to configure a mirroring action that mirrors traffic to the CPU.
Use undo mirror-to cpu to delete the mirroring action that mirrors traffic to the CPU.
mirror-to cpu
undo mirror-to cpu
No mirroring action exists to mirror traffic to the CPU.
Traffic behavior view
# Create traffic behavior 1 and configure the action of mirroring traffic to the CPU for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
Syntax I:
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
Syntax II:
mirror-to interface interface-type interface-number reflector-port interface-type interface-number strip-vlan vlan-id
No mirroring actions exist to mirror traffic to interfaces.
You can mirror traffic to only one interface. If you execute this command for a traffic behavior multiple times, the most recent configuration takes effect.
When you use syntax 3 to mirror traffic to an interface, the device copies packets received on the mirroring sources to the destination interface. Then, the destination interface sends the mirrored packets to the specified reflector port, and the reflector port broadcasts the mirrored packets within the specified VLAN. This syntax is applicable only when the mirrored packets are VLAN-tagged and these packets must be sent out of the device untagged.
When you use syntax 3, the specified mirroring destination interface and reflector port must be assigned to a mirroring-type service loopback group. For more information about service loopback groups, see service loopback group configuration in Layer 2—LAN Switching Configuration Guide.
# Create traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 1/0/1 for the traffic behavior.
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1
mirror-to monitoring-group
Use mirror-to monitoring-group to configure a mirroring action that mirrors traffic to a monitoring group.
Use undo mirror-to monitoring-group to delete a mirroring action that mirrors traffic to a monitoring group.
mirror-to monitoring-group group-id
undo mirror-to monitoring-group group-id
No mirroring actions exist to mirror traffic to a monitoring group.
# Create traffic behavior b1 and configure the action of mirroring traffic to monitoring group 1.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] mirror-to monitoring-group 1
monitoring-group
Use monitoring-group to create a monitoring group and enter its view, or enter the view of an existing monitoring group.
Use undo monitoring-group to delete monitoring groups.
undo monitoring-group { group-id | all }
No monitoring groups exist.
group-id: Specifies a number for the monitoring group. The value range for this argument is 1 to 128.
# Create monitoring group 1.
[Sysname] monitoring-group 1
monitoring-port
Use monitoring-port to assign ports to a monitoring group.
Use undo monitoring-port to remove ports from a monitoring group.
Syntax I
monitoring-port interface-list [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name | destination-mac mac-address ] * ]
undo monitoring-port interface-list
Syntax II
monitoring-port { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ erspanv3 ] [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ]
undo monitoring-port { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address }
A monitoring group does not contain any ports.
Monitoring group view
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the start interface number must be identical to or lower than the end interface number.
destination-ip destination-ip-address: Specifies the destination IPv4 address for the mirrored packets.
source-ip source-ip-address: Specifies the source IPv4 address for the mirrored packets.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
destination-mac mac-address: Specifies the destination MAC address for mirrored packets. The mac-address argument is in the format of H-H-H. If you do not specify this option, the device uses the destination IP address to obtain the destination MAC address. If the destination MAC address cannot be obtained, the default MAC address 000f-e241-5e5b is used.
Use the ports in a monitoring group only for flow mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
If you use syntax 1 to assign multiple ports to a monitoring group, the device encapsulates a mirrored packet with the specified encapsulation parameters in a GRE packet with a protocol number of 0x88BE. Then, a copy of the packet is sent of each port in the monitoring group.
If you use syntax II, the device encapsulates a mirrored packet with the specified encapsulation parameters in a GRE packet with a protocol number of 0x88BE. Then, the device looks up the source IP address and destination IP address of the packet in the routing table and forwards the packet based on the matching route. The outgoing interface of the route is the destination interface of the mirrored packet.
Through configuring load sharing in the routing protocols, you can specify multiple destination interfaces for the mirrored traffic. When the current mirroring destination interface fails, the mirrored traffic is forwarded to the outgoing interface re-calculated by the routing protocols.
# Create monitoring group 1 and assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to it.
[Sysname-monitoring-group-1] monitoring-port gigabitethernet 1/0/1 to gigabitethernet 1/0/2
# Create monitoring group 2 and encapsulate the mirrored packets with destination IP address 1.1.1.1, source IP address 2.2.2.2, DSCP value 20, and VLAN ID 100. Forward the mirrored packets based on the routing table of the VPN instance named vrf1.
[Sysname] monitoring-group 2
[Sysname-monitoring-group-2] monitoring-port destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf1
# Create monitoring group 3 and assign GigabitEthernet 1/0/1 to the monitoring group. Encapsulate the mirrored packets with destination IP address 1.1.1.1, source IP address 2.2.2.2, DSCP value 20, and VLAN ID 100. Forward the mirrored packets based on the routing table of the VPN instance named vrf2.
[Sysname] monitoring-group 3
[Sysname-monitoring-group-3] monitoring-port gigabitethernet 1/0/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf2
monitoring-group
