11-Segment Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5580X-EI[HI] & S5580S-EI Switch Series Command References-R1330Pxx-6W10011-Segment Routing Command Reference
02-SRv6 commands
02-SRv6 commands 290.36 KB
SRv6 commands
display isis segment-routing ipv6 capability
Use display isis segment-routing ipv6 capability to display IS-IS SRv6 capability information.
display isis segment-routing ipv6 capability [ level-1 | level-2 ] [ process-id ]
level-1: Specifies IS-IS Level-1.
level-2: Specifies IS-IS Level-2.
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 capability information for all IS-IS processes.
If you do not specify a level, this command displays IS-IS SRv6 capability information for both Level-1 and Level-2.
# Display SRv6 capability information for IS-IS process 1.
<Sysname> display isis segment-routing ipv6 capability level-1 1
      IPv6 segment routing capability information for IS-IS(1)
                Level-1 IPv6 segment routing capability
System ID               SRv6 capability
0000.1000.0001          Enabled
0000.2000.0001          Enabled
0000.2000.0002          Enabled
0000.2000.0003          Enabled
System ID
Neighbor system ID.
SRv6 capability
Whether SRv6 is enabled.
display isis segment-routing ipv6 locator
Use display isis segment-routing ipv6 locator to display IS-IS SRv6 locator route information.
display isis segment-routing ipv6 locator [ ipv6-address prefix-length ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv6-address prefix-length: Specifies a destination IPv6 address prefix and the prefix length. The value range for the prefix-length argument is 1 to 128.
level-1: Specifies the level-1 area.
level-2: Specifies the level-2 area.
verbose: Displays detailed IS-IS SRv6 locator route information. If you do not specify this keyword, the command displays only brief IS-IS SRv6 locator route information.
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays IS-IS SRv6 locator route information for all IS-IS processes.
# Display IS-IS SRv6 locator route information.
<Sysname> display isis segment-routing ipv6 locator
                          Level-1 Locator Route Table
 Destination : 201::                                   PrefixLen: 64
 Flags       : R/-/-                                   Cost     : 2
 Next hop    : FE80::38A5:3DFF:FEE9:218                Interface: GE1/0/1
 Destination : 202::                                   PrefixLen: 64
 Flags       : R/-/-                                   Cost     : 1
 Next hop    : FE80::38A5:3DFF:FEE9:218                Interface: GE1/0/3
Destination
Destination IPv6 prefix.
PrefixLen
Prefix length.
Flag/Flags
Route flags:
·     D—The route is a direct route.
·     R—The route has been flushed to the RIB.
·     L—The route has been advertised in LSPs.
·     U—Penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
Cost
Route cost value.
Next hop
Route next hop.
Output interface.
# Display detailed IS-IS SRv6 locator route information.
<Sysname> display isis segment-routing ipv6 locator verbose
 IPv6 dest   : 5000::/64
 Flag        : D/L/-                       Cost        : 0
 Admin tag   : -                           Src count   : 1
 Algorithm   : 0
 Priority    : Low
 Nexthop     : Direct
 NxthopFlag  : -
 Interface   : NULL0                       Delay Flag : N/A
 Nib ID      : 0x0
                          Level-2 Locator Route Table
 Admin tag   : -                           Src count   : 4
 Algorithm   : 0
 Priority    : Low
 Nexthop     : Direct
 NxthopFlag  : -
 Nib ID      : 0x0
Locator route information about the IS-IS proces.
IS-IS Level-1 locator route information.
IS-IS Level-2 locator route information.
IPv6 dest
Flag
Route state flag:
·     D—Direct route.
·     R—The route has been added into the routing table.
·     L—The route has been advertised in an LSP.
·     URoute leaking flag, indicating that the Level-1 route is from Level-2. U means that the route will not be returned to Level-2.
Cost
Route cost.
Admin tag
Administrative tag.
Src count
Number of advertisement sources.
Algorithm
Flexible algorithm ID.
Priority
Route convergence priority:
·     Critical.
·     High.
·     Medium.
·     Low.
Next hop
Next hop. If the route is a direct route, this field displays Direct.
NxthopFlag
Next hop flag. Value D indicates that the next hop is the direct next hop of the advertisement source.
Output interface.
Delay Flag
Microloop avoidance delay flag:
·     D—Microloop avoidance is configured. Route convergence is delayed.
·     N/A—Microloop avoidance is not configured or the microloop avoidance delay timer has expired. Route convergence is in progress.
Nib ID
Next hop index assigned by the routing management module.
display isis segment-routing ipv6 sid-info conflict
Use display isis segment-routing ipv6 sid-info conflict to display information about conflicting SRv6 SIDs.
display isis segment-routing ipv6 sid-info conflict [ sid-value ] [ level-1 | level-2 ] [ process-id ]
sid-value: Specifies an SRv6 SID.
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays information about conflicting SRv6 SIDs for all IS-IS processes.
If you do not specify any parameters, this command displays information about all conflicting SRv6 SIDs.
# Display information about all conflicting SRv6 SIDs.
<Sysname> display isis segment ipv6 sid-info conflict
          Segment Routing IPv6 SID Conflict Information For IS-IS(1)
                       Level-1 SID Conflict Information
SID: 6:5::100
  System ID=3333.3333.3333.00, Flag(A)=0, Function type=End with PSP
  System ID=4444.4444.4444.00, Flag(A)=0, Function type=End with PSP
SID: 6:5::101
  System ID=3333.3333.3333.00, Flag(A)=0, Function type=End (no PSP, no USP)
  System ID=4444.4444.4444.00, Flag(A)=0, Function type=End (no PSP, no USP)
SID: 6:5::103
  System ID=3333.3333.3333.00, Flag(A)=0, Function type=End.X (no PSP, no USP)
  System ID=4444.4444.4444.00, Flag(A)=0, Function type=End.X (no PSP, no USP)
SID
Conflicting SRv6 SID.
System ID
ID of the system that advertised the SID.
Flag (A)
Anycast flag (A flag). The value is 1 if this flag is set, which indicates that the SID is an anycast SID.
Function type
SID function type:
·     End.DT4—End.DT4 SID.
·     End.DT6—End.DT6 SID.
display isis segment-routing ipv6 sid-info locator
Use display isis segment-routing ipv6 sid-info locator to display information about SRv6 SIDs advertised by IS-IS in a locator or all locators.
display isis segment-routing ipv6 sid-info locator [ ipv6-prefix prefix-length ] [ end-dt4 | end-dt6 ] [ level-1 | level-2 ] [ process-id ]
ipv6-prefix prefix-length: Specifies a locator by its IPv6 prefix. The ipv6-prefix argument represents the IPv6 prefix address. The prefix-length argument represents the prefix length, in the range of 32 to 120.
end-dt4: Specifies End.DT4 SIDs.
end-dt6: Specifies End.DT6 SIDs.
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays information about SRv6 SIDs in the specified locator for all IS-IS processes.
If you do not specify any parameters, this command displays information about SRv6 SIDs advertised by IS-IS in all locators.
# Display information about SRv6 SIDs advertised by level-1 IS-IS in all locators.
<Sysname> display isis segment ipv6 sid-info locator level-1
          Segment Routing IPv6 SID Locator Information For IS-IS(1)
                           Level-1 SID Information
Locator: 1:2::/96
    System ID: 1111.1111.1111.00
       Locator Info: Cost=0, Flag(D)=0, Flag(A)=0, Algorithm=0
       SID: 1:2::1
          Function Type: End.DT4
            Neighbor ID: --
       SID: 1:2::2
          Function Type: End.DT6
            Neighbor ID: --
       SID: 1:2::3
          Function Type: End.DT46
            Neighbor ID: --
       SID: 1:2::104
          Function Type: End with PSP
            Neighbor ID: --
       SID: 1:2::105
          Function Type: End (no PSP, no USP)
            Neighbor ID: --
       SID: 1:2::106
          Function Type: End.X (no PSP, no USP)
            Neighbor ID: 2222.2222.2222.00
       SID: 1:2::107
          Function Type: End.X with PSP
Table 5 Command output
System ID
ID of the system that advertised an SRv6 SID.
SID
SRv6 SID.
Locator Info
Locator information.
Cost
Locator TLV cost.
Flag (D)
Leaking flag (D flag). The value is 1 if this flag is set, which indicates that locator TLVs cannot be leaked from Level-1 to Level-2.
Flag (A)
Anycast locator flag (A flag). The value is 1 if this flag is set, which indicates that the locator is an anycast locator.
Algorithm
ID of the algorithm associated with the SRv6 locator:
·     0—SPF algorithm.
·     128 to 255—Flex-Algo algorithm. This field is not supported in the current software version.
Function type
SID function type:
Neighbor ID
Neighbor ID.
This field displays a value only for an End.X SID. For other SRv6 SIDs, this field displays two hyphens (--).
display isis segment-routing ipv6 sid-info sid
Use display isis segment-routing ipv6 sid-info sid to display information about SRv6 SIDs advertised by IS-IS.
display isis segment-routing ipv6 sid-info sid [ sid-value | [ end-dt4 | end-dt6 ] ] [ level-1 | level-2 ] [ process-id ]
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays information about SRv6 SIDs for all IS-IS processes.
If you do not specify any parameters, this command displays information about all SRv6 SIDs advertised by IS-IS.
# Display information about all SRv6 SIDs advertised by level-1 IS-IS.
<Sysname> display isis segment-routing ipv6 sid-info sid level-1
              Segment Routing IPv6 SID Information For IS-IS(1)
SID: 1:2::1
           Flag(A): 0
       Neighbor ID: --
SID: 1:2::2
           Flag(A): 0, Function Type: End.DT6
       Neighbor ID: --
SID: 1:2::3
           Flag(A): 0, Function Type: End.DT46
       Neighbor ID: --
SID: 1:2::105
           Flag(A): 0, Function Type: End (no PSP, no USP)
       Neighbor ID: --
SID: 1:2::106
           Flag(A): 0, Function Type: End.X (no PSP, no USP)
Table 6 Command output
SID
SRv6 SID advertised by IS-IS
Flag (A)
Function type
SID function type:
System ID
ID of the system that advertised the SRv6 SID.
Neighbor ID
Neighbor ID.
display isis segment-routing ipv6 sid-info statistics
Use display isis segment-routing ipv6 sid-info statistics to display SRv6 SID statistics.
display isis segment-routing ipv6 sid-info statistics [ system-id system-id ] [ level-1 | level-2 ] [ process-id ]
system-id system-id: Specifies an advertisement source by its system ID.
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays SRv6 SID statistics for all IS-IS processes.
If you do not specify any parameters, this command displays all SRv6 SID statistics.
# Display all SRv6 SID statistics.
<Sysname> display isis segment-routing ipv6 sid-info statistics
          Segment Routing IPv6 SID Statistic Information For IS-IS(1)
                       Level-1 SID Statistic Information
System ID: 3333.3333.3333.00
  Locator: 6:5::/96
    End=2, End.X=0, End.M=0, End.DT4=0, End.DT6=0, End.DT46=0
  Total advertised SIDs:
  Locator: 1:2::/96
    End=2, End.X=2, End.M=0, End.DT4=3, End.DT6=3, End.DT46=1
Table 7 Command output
System ID
ID of the system that advertised SRv6 SIDs.
Locator
Locator of the SRv6 SIDs.
End
Number of advertised End SIDs. This field is not supported in the current software version.
End.X
Number of advertised End.X SIDs. This field is not supported in the current software version.
End.M
Number of advertised End.M SIDs. This field is not supported in the current software version.
End.DT4
Number of advertised End.DT4 SIDs.
End.DT6
Number of advertised End.DT6 SIDs.
End.DT46
Number of advertised End.DT46 SIDs. This field is not supported in the current software version.
Total number of advertised SRv6 SIDs.
display isis segment-routing ipv6 sid-info system-id
Use display isis segment-routing ipv6 sid-info system-id to display information about SRv6 SIDs advertised from an advertisement source or all advertisement sources.
display isis segment-routing ipv6 sid-info system-id [ system-id ] [ end-dt4 | end-dt6 ] [ level-1 | level-2 ] [ process-id ] [ is-name isname ]
process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays information about SRv6 SIDs advertised from the specified advertisement source for all IS-IS processes.
is-name isname: Specifies a host by its name, a case-insensitive string of 1 to 64 characters.
If you do not specify any parameters, this command displays information about SRv6 SIDs advertised from all advertisement sources.
# Display information about SRv6 SIDs advertised from 0000.0000.0001.
<Sysname> display isis segment ipv6 sid-info system-id 0000.0000.0001
          Segment Routing IPv6 SID System ID Information For IS-IS(1)
System id: 0000.0000.0001
  Locator: 1:2::/96
  Cost=0, Flag(D)=0,Flag(A)=0,  Algorithm=0
    SID: 1:2::1
        Neighbors ID: --
    SID: 1:2::2
        Neighbors ID: --
    SID: 1:2::3
        Neighbors ID: --
    SID: 1:2::104
        Neighbors ID: --
    SID: 1:2::105
        Neighbors ID: --
    SID: 1:2::106
        Neighbors ID: 2222.2222.2222.00
    SID: 1:2::107
Table 8 Command output
Cost
Locator TLV cost.
Flag (D)
Flag (A)
Algorithm
·     0—SPF algorithm.
SID
SRv6 SID.
Function type
SID function type:
Neighbor ID
Neighbor ID.
display segment-routing ipv6 available-static-sid
Use display segment-routing ipv6 available-static-sid to display available static SRv6 SIDs in a locator.
display segment-routing ipv6 available-static-sid locator locator-name [ from begin-value ]
locator locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
from begin-value: Specifies available static SRv6 SIDs that start from the specified value. The begin-value argument represents the start value in IPv6 address format. If you do not specify a start value, this command displays available static SRv6 SIDs starting from the smallest available one.
If you specify a static length when configuring an SRv6 locator, the device can allocate static SRv6 SIDs from the locator. Use this command to display a maximum of 10 available static SRv6 SIDs in the locator.
To specify the from begin-value option, you must first identify the static SID range of the locator. For this purpose, use the display segment-routing ipv6 locator command.
# Display available static SRv6 SIDs in COC-both locator test3.
<Sysname> display segment-routing ipv6 available-static-sid locator test3
                      Available static SRv6 SID table
300:F8:4A::100
300:F8:4A::200
300:F8:4A::300
300:F8:4A::400
300:F8:4A::500
300:F8:4A::600
300:F8:4A::700
300:F8:4A::800
300:F8:4A::900
300:F8:4A::A00
                      Available static SRv6 CSID table
300:F8:4A:0:1::
300:F8:4A:0:2::
300:F8:4A:0:3::
300:F8:4A:0:4::
300:F8:4A:0:5::
300:F8:4A:0:6::
300:F8:4A:0:7::
300:F8:4A:0:8::
300:F8:4A:0:9::
300:F8:4A:0:A::
Table 9 Command output
Available static SRv6 SIDs.
Available static compressible SRv6 SIDs.
N/A
No static SRv6 SIDs are available.
display segment-routing ipv6 brief
Use display segment-routing ipv6 brief to display brief SRv6 information.
# Display brief SRv6 information.
<Sysname> display segment-routing ipv6 brief
Current SRv6 info:
  Flavor mode: NO-PSP
SRv6 info at next reboot:
  Flavor mode: NO-PSP
SRv6 TE FRR: Disabled
SRH flag check: Disabled
Encapsulation source-address: -
TTL mode: pipe
Path MTU: 1500
Path MTU reserved: 0
SRv6 compression: Disabled
Diffserv mode info:
  Ingress mode: -
  Engress mode: -
  Service class: 0
  SRv6 locator SBFD: Enabled
  SRv6 locator SBFD Template: LocatorBFD
  SRv6 locator SBFD prefix-list: prefixlist
End.X update-delay time: 100 ms
Table 10 Command output
Current SRv6 info
Current effective SRv6 information.
SRv6 info at the next reboot
SRv6 information that will take effect at the next startup.
Flavor mode
SRv6 SID flavor:
·     PSP—The penultimate SRv6 node removes the SRH.
·     NO-PSP—The penultimate SRv6 node does not remove the SRH.
SRv6 TE FRR
This field is not supported in the current software version. SRv6 TEE FRR status:
·     Disabled.
·     Enabled.
·     Downgrade—Switched to SRv6 BE FRR.
SRH flag check
SRH flag check status:
·     Disabled.
·     Enabled.
Encapsulated source address
Source IP address in the IPv6 header encapsulated by SRv6.
IP TTL
TTL value in the IPv6 header encapsulated by SRv6.
TTL mode
This field is not supported in the current software version. TTL handling mode of the SRv6 TE policy:
·     pipe—Pipe mode.
·     uniform—Uniform mode.
Path MTU
Path MTU value for SRv6.
Path MTU reserved
Global reserved path MTU for SRv6.
SRv6 compression
This field is not supported in the current software version. SRv6 compression status:
·     Disabled.
·     Enabled.
Diffserv mode info
SRv6 DiffServ mode.
Ingress mode
SRv6 DiffServ mode in the inbound direction:
·     pipe—Pipe mode.
·     short-pipe—Short-pipe mode.
If SRv6 DiffServ mode in the inbound direction is not configured, this field displays a hyphen (-).
Engress mode
SRv6 DiffServ mode in the outbound direction:
·     pipe—Pipe mode.
If SRv6 DiffServ mode in the outbound direction is not configured, this field displays a hyphen (-).
Service class
Traffic class for packets entering the SRv6 network from a common IP network.
SRv6 locator SBFD
SBFD status for SRv6 locators:
·     Disabled.
·     Enabled.
Template used for detecting the SBFD session status for SRv6 locators. This field is not displayed if no such template is configured.
SRv6 locator SBFD Prefix-list
IPv6 prefix list referenced by SBFD for SRv6 locators. This field is not displayed if no such IPv6 prefix list is configured.
Delay time to flush static End.X SIDs to the FIB, in milliseconds.
display segment-routing ipv6 forwarding
Use display segment-routing ipv6 forwarding to display SRv6 forwarding entry information.
display segment-routing ipv6 forwarding [ entry-id [ relation ] | forwarding-type { srv6be | srv6sids } ] [ slot slot-number ]
entry-id: Specifies an SRv6 forwarding entry by its ID, in the range of 0 to 4294967294. If you do not specify an SRv6 forwarding entry ID, this command displays information about all SRv6 forwarding entries.
relation: Displays information about entries associated with the specified entry.
forwarding-type: Specifies a forwarding type. If you do not specify a forwarding type, this command displays SRv6 forwarding information for all forwarding types.
srv6be: Specifies tunnels in SRv6 BE paths.
srv6sids: Specifies tunnels matching SRv6 SIDs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays SRv6 forwarding entries on the master device.
# Display all SRv6 forwarding entries.
<Sysname> display segment-routing ipv6 forwarding
Total SRv6 forwarding entries: 4
Flags: T – Forwarded through a tunnel
       N – Forwarded through the outgoing interface to the nexthop IP address
       A - Active forwarding information
       B – Backup forwarding information
ID            FWD-Type      Flags   Forwarding info
              Attri-Val             Attri-Val
2148532225    SRv6PSIDList  NA      GE1/0/1
                                    FE80::54CB:70FF:FE86:316
                                    {6000::1, 7000::1, 8000::1}
2149580801    SRv6PCPath    TA      2148532225
2150629377    SRv6Policy    TA      2149580801
              Policy10
2153775105    SRv6SFC       NA      GE1/0/1
Table 11 Command output
FWD-Type
Tunnel forwarding type:
·     SRv6PSIDs—Tunnel established based on SRv6 SIDs.
Flags
Forwarding flags:
·     T—Tunnel forwarding.
·     N—Output interface or next hop forwarding.
·     A—Active forwarding information.
·     B—Backup forwarding information.
·     S—Secondary backup forwarding information.
Forwarding info
SRv6 forwarding information.
·     For the N forwarding flag, the forwarding information includes the output interface, next hop, and SID list.
·     For the T forwarding flag, the forwarding information is the SRv6 forwarding entry ID.
Attri-Val
This field is not supported in the current software version. Forwarding attribute.
In the current software version, the value is an SRv6 TE policy name.
This field is available only when the value for the FWD-Type field is SRv6Policy or SRv6PGroup.
display segment-routing ipv6 local-sid
Use display segment-routing ipv6 local-sid to display information about the SRv6 local SID forwarding table.
display segment-routing ipv6 local-sid [ locator locator-name ] [ end-dt2m | end-dt2u ] [ owner owner ] [ sid ]
display segment-routing ipv6 local-sid [ locator locator-name ] [ end-dt4 | end-dt6 ] [ owner owner ] [ sid | vpn-instance vpn-instance-name ]
locator locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays information about the SRv6 local SID forwarding table for all locators.
end-dt2m: Specifies End.DT2M SIDs.
end-dt2u: Specifies End.DT2U SIDs.
sid: Specifies an SRv6 SID. If you do not specify an SRv6 SID, this command displays SRv6 local forwarding table information for all SRv6 SIDs of the specified type.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SRv6 SIDs belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays SRv6 local SID forwarding table information in the public network.
interface interface-type interface-number: Specifies an output interface by its type and number. If you do not specify an output interface, the command displays SRv6 local SID forwarding table information for all End.X SIDs.
nexthop nexthop-ipv6-address: Specifies the IPv6 address of a next hop. If you do not specify a next hop, the command displays SRv6 local SID forwarding table information for all IPv6 next hops.
owner owner: Specifies a protocol. The value for the owner argument is case insensitive. The supported values include SIDMGR, BGP, SRPolicy, IS-IS, OSPFv3, and L2VPN. If you do not specify a protocol, this command displays information about the SRv6 local SID forwarding table for all protocols.
# Display SRv6 local forwarding table information for all End.DT4 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt4
                    Local SID forwarding table (End.DT4)
Total SIDs: 1
SID           : 6:5::1:1/120
Function type : End.DT4                         Flavor         : PSP
VPN instance  : vpn1                            Allocation type: Static
Network type  : MPLS L3VPN
Locator name  : abc
Owner         : SIDMGR                          State          : Active
Flags         : F
Create Time   : May 19 17:22:27.356 2020
# Display SRv6 local forwarding table information for all End.DT6 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt6
                    Local SID forwarding table (End.DT6)
Total SIDs: 1
SID           : 1:2::2:2/120
Function type : End.DT6                         Flavor         : PSP
Locator name  : abc
Flags         : F
# Display SRv6 local forwarding table information for all End.DT2U SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt2u
                    Local SID forwarding table (End.DT2U)
Total SIDs: 1
SID           : 100:1:2:3::C800/96
Function type : End.DT2U                        Flavor         : PSP
VSI name      : abc                             Allocation type: Static
Locator name  : abc
Flags         : F
Create Time   : May 20 09:18:14.504 2020
# Display SRv6 local forwarding table information for End.AS SIDs in Layer 3 encapsulation forwarding scenario.
<Sysname> display segment-routing ipv6 local-sid end-as
                    Local SID forwarding table (End.AS)
Total SIDs: 1
Function type : End.AS                          Allocation type: Static
Locator name  : abc                             Forward type   : L3
Inner type    : IPv4                            Source address : 2::60
Backup SID    : 1::AA                           Peer SID       : 300::3
Bypass        : Enabled                         Bypass SID     : 5::9
TTL mode      : Uniform                         TTL value      : -
Diffserv mode : Uniform                         Service class  : -
Color         : -                               Cache-SL       : 2
Cache list    :
  4::3
  7::8
  8::9
  1::16::9
Encapsulation count: 2
 Next hop     : 10.1.1.2                        Out-interface  : GE1/0/2
 In-interface : GE1/0/2                         Symmetric-index: 1
 Next hop     : 10.1.1.3                        Out-interface  : GE1/0/1
 In-interface : GE1/0/1                         Symmetric-index: 2
Flags         : F
Create Time   : May 19 17:21:15.687 2020
# Display SRv6 local forwarding table information for End.AM SIDs in Layer 3 encapsulation forwarding scenario.
<Sysname> display segment-routing ipv6 local-sid end-am
                    Local SID forwarding table (End.AM)
Total SIDs: 1
Function type : End.AM                          Allocation type: Static
 Next hop     : 1::1                            Out-interface  : GE1/0/2
 Next hop     : 1::2                            Out-interface  : GE1/0/1
Flags         : F
Table 12 Command output
SID
SRv6 SID.
Function type
SRv6 SID type:
·     End.DT2M.
·     End.DT2U.
·     End.DT4.
·     End.DT6.
Flavor
SRv6 SID flavor type:
·     NO-FLAVOR—The SRv6 SID does not carry any flavors.
·     PSP,USP,USD—The SRv6 SID carries the PSP, USP, and USD flavors.
·     NOPSP—The penultimate SRv6 node does not remove the SRH.
Output interface.
Interface index
Output interface index.
Next hop
Next hop address.
VPN instance
VPN instance name.
For the public network, this field displays Public instance.
Xconnect group
Cross-connect group name.
Connection
Cross-connect name.
VSI name
VSI name.
Service ID
Ethernet service instance ID.
If no Ethernet service instance ID exists, this field displays 0.
Allocation type
SID allocation type:
·     Static—Manually configured.
·     Dynamic—Dynamically allocated.
Network type
Type of the network to which the SRv6 SID is applied: MPLS L3VPN. The SRv6 SID is applied to an MPLS L3VPN network.
Mirror locator number
Number of protected locators.
Mirror locator
IPv6 address prefix and prefix length of each protected locator.
Owner
Protocol that applies for the SID:
·     SIDMGR.
·     BGP.
·     SRPolicy.
·     IS-IS.
·     OSPFv3.
·     L2VPN.
·     LSM.
Paths
Number of paths.
Path index
Index of the path for the SID.
Weight
Load sharing weight of the path.
SID state:
·     Active.
·     Inactive.
Flags
Flags:
·     If traffic forwarding statistics collection is enabled for local SRv6 SIDs, this field displays F.
·     If traffic forwarding statistics collection is disabled for local SRv6 SIDs, this field displays a hyphen (-).
Create Time
SID creation time.
Forward type
SFF-to-SF packet forwarding type:
·     L2—Layer 2 forwarding.
·     L3—Layer 3 forwarding.
Inner type
Protocol type of the original SFF-to-SF packet.
Source address
Source IPv6 address re-encapsulated for the packet received by the SFF from the SF.
Backup SID
Backup End.AS SID.
Peer SID
Backup SFF SID, which is the an End SID.
Bypass
Bypass protection status: Enabled or disabled (-).
Bypass SID
Backup SID of the bypass path, which is the valid End.AS SID of other protection devices in the SF group.
TTL mode
TTL processing mode:
·     Uniform—After a packet is forwarded back to the SFF from the SF, the SFF uses the TTL value in the original packet minus 1 as the TTL in the newly encapsulated IPv6 header.
·     Pipe—After a packet is forwarded back to the SFF from the SF, the SFF uses the specified TTL value (ttl-value) minus 1 as the TTL in the newly encapsulated IPv6 header.
TTL value
TTL value:
·     In the Uniform TTL processing mode, a hyphen (-) is displayed.
·     In the Pipe TTL processing mode, the configured TTL value is displayed.
Diffserv mode
Differentiated services (Diffserv) mode:
·     Uniform—In the inbound direction (SF to SFF), the SFF maps the carried IP or DSCP value to the priority in the newly encapsulated IPv6 header. The packet color will not be changed. In the outbound direction (SFF to SF), the SFF removes the outer IPv6 and SRH header. Then it maps the priority in the outer IPv6 header to the IP or DSCP value in the original packet. The packet color will not be changed.
·     Pipe—In the inbound direction (SF to SFF), the SFF ignores the carried IP or DSCP value. It uses the configured service-class value as the priority in the newly encapsulated IPv6 header, and the configured color value as the color for the new packet. In SRv6 networks, QoS scheduling is performed for packets based on the priority and color values. In the outbound direction (SFF to SF), the SFF removes the outer IPv6 and SRH header without modifying the IP or DSCP value and color in the original packet.
Service class
Diffserv class of the service chain. Values include the following in ascending priority order:
·     be
·     af1
·     af2
·     af3
·     af4
·     ef
·     cs6
·     cs7
If no Diffserv class is configured, a hyphen (-) is displayed.
Color
Packet color. Values include the following in ascending order of packet loss probability:
·     green—Indicates packet loss probability 0.
·     yellow—Indicates packet loss probability 1.
·     red—Indicates packet loss probability 2.
Cache-SL
Segment left value, which indicates the number of nodes to access in the SID list before arrival at the final destination.
Cache list
SID list that needs to be encapsulated after the SFF receives the packet from the SF.
Encapsulation count
Number of equal-cost paths between the SFF and SF.
Out-Interface
Outbound interface for the SFF to forward packets to the SF.
In-Interface
Inbound interface for the SFF to receive packets from the SF.
Out-S-VLAN
Outer VLAN ID for SFF-to-SF (outbound) packets.
Out-C-VLAN
Inner VLAN ID for SFF-to-SF (outbound) packets.
In-S-VLAN
Outer VLAN ID for SF-to-SFF (inbound) packets.
In-C-VLAN
Inner VLAN ID for SF-to-SFF (inbound) packets.
Dest MAC
Destination MAC address encapsulated for packets from the SF to the remote backup SFF in Layer 2 forwarding.
Symmetric-index
Index that identifies a VM used for forwarding bidirectional traffic when multiple VMs exist on the SF. Both inbound and outbound traffic with the same source and destination addresses will traverse the same VM.
display segment-routing ipv6 local-sid statistics
Use display segment-routing ipv6 local-sid statistics to display statistics about SRv6 SIDs allocated for each protocol.
display segment-routing ipv6 local-sid statistics [ locator [ locator-name ] ]
locator: Displays statistics about SRv6 SIDs allocated for each protocol by locator. If you do not specify this keyword, the command does not display statistics about SRv6 SIDs allocated for each protocol by locator.
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, the command displays statistics about SRv6 SIDs for all locators.
# Display statistics about SRv6 SIDs allocated for each protocol (not by locator).
<Sysname> display segment-routing ipv6 local-sid statistics
Total SIDs: 0
Funtion         SIDMGR   SRP      IS-IS    OSPFv3   BGP      L2VPN    Total
End             0        0        0        0        0        0        0
End.X           0        0        0        0        0        0        0
End.COC32       0        0        0        0        0        0        0
End.XCOC32      0        0        0        0        0        0        0
End.COCNONE     0        0        0        0        0        0        0
End.XCOCNONE    0        0        0        0        0        0        0
End.B6Encaps    0        0        0        0        0        0        0
End.B6EncapsRed 0        0        0        0        0        0        0
End.B6Insert    0        0        0        0        0        0        0
End.B6InsertRed 0        0        0        0        0        0        0
End.DT4         0        0        0        0        0        0        0
End.DT46        0        0        0        0        0        0        0
End.DT6         0        0        0        0        0        0        0
End.DX4         0        0        0        0        0        0        0
End.DX6         0        0        0        0        0        0        0
End.DX2         0        0        0        0        0        0        0
End.DX2L        0        0        0        0        0        0        0
End.DT2M        0        0        0        0        0        0        0
End.DT2U        0        0        0        0        0        0        0
End.DT2UL       0        0        0        0        0        0        0
End.AS          0        0        0        0        0        0        0
END.AM          0        0        0        0        0        0        0
End.M           0        0        0        0        0        0        0
End.OP          0        0        0        0        0        0        0
End.T           0        0        0        0        0        0        0
# Display statistics about SRv6 SIDs allocated for each protocol from locator abc.
<Sysname> display segment-routing ipv6 local-sid statistics locator abc
Locator: abc
Total SIDs: 1
End             0        0        0        0        0        0        0
End.X           0        0        0        0        0        0        0
End.M           0        0        0        0        0        0        0
End.T           0        0        0        0        0        0        0
Table 13 Command output
Total SIDs
Total number of SRv6 SIDs. If you specify a locator, this field displays the total number of SRv6 SIDs that belong to the specified locator.
Locator
Locator name.
Function
SRv6 SID type:
·     End.DT4.
·     End.DT6.
·     End.DT2M.
·     End.DT2U.
SIDMGR
Static SIDs.
SRP
This field is not supported in the current software version. BSIDs dynamically allocated for SRv6 TE policies.
IS-IS
SRv6 SIDs allocated for IS-IS.
OSPFv3
SRv6 SIDs allocated for OSPFv3.
L2VPN
SRv6 SIDs allocated for L2VPN.
BGP
SRv6 SIDs allocated for BGP.
Total
Total number for a type of SRv6 SIDs.
Use display segment-routing ipv6 locator to display SRv6 locator information.
display segment-routing ipv6 locator [ locator-name ]
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays information about all locators.
# Display information about all locators. (The coc-both keyword is not specified when you configure locators.)
<Sysname> display segment-routing ipv6 locator
                      Locator configuration table
Locator name        : abc                                   Flag(A)       : 0
IPv6 prefix         : 100:1:2:3::                           Prefix length : 96
Static length       : 24                                    Args length   : 8
Common prefix length: 0
Algorithm           : 0
Auto SID start      : N/A
Auto SID end        : N/A
Static SID start    : 100:1:2:3::100
Static SID end      : 100:1:2:3::FFFF:FF00
Compressed Auto SID count      : 0
Compressed Static SID count    : 0
Non-compressed Auto SID count  : 0
Non-compressed Static SID count: 1
# Display information about all locators. (The coc-both keyword is specified when you configure locators.)
Locator name        : test1                                 Flag(A)       : 0
IPv6 prefix         : 100:200:DB8:ABCD::                    Prefix length : 64
Static length       : 8                                     Args length   : 16
Common prefix length: 48                     Non-compressed static length : 16
Algorithm           : 0
Compressed auto SID start      : 100:200:DB8:ABCD:100::
Compressed auto SID end        : 100:200:DB8:ABCD:FFFF::
Table 14 Command output
Flag(A)
Anycast locator flag (A-bit). If A-bit is set, the locator is an anycast locator.
IPv6 prefix
IPv6 address prefix of the locator.
Prefix length
Prefix length of the locator.
Static length
Static length of the locator.
Args length
Argument length.
Common prefix length of the locator.
Static length of the locator for non-compressible SRv6 SIDs.
Algorithm
Algorithm ID:
·     0—SPF algorithm.
Auto SID start
Start dynamic SRv6 SID.
If no dynamic SRv6 SIDs exist, this field displays N/A.
Auto SID end
End dynamic SRv6 SID.
Static SID start
Start static SRv6 SID.
If no static SRv6 SIDs exist, this field displays N/A.
Static SID end
End static SRv6 SID.
Start value for compressible dynamic SRv6 SIDs.
If no compressible dynamic SRv6 SIDs exist, this field displays N/A.
End value for compressible dynamic SRv6 SIDs.
Compressed static SID start
Start value for compressible static SRv6 SIDs.
If no compressible static SRv6 SIDs exist, this field displays N/A.
Compressed static SID end
End value for compressible static SRv6 SIDs.
Non-compressed auto SID start
Start value for non-compressible dynamic SRv6 SIDs.
If no non-compressible dynamic SRv6 SIDs exist, this field displays N/A.
Non-compressed auto SID end
End value for non-compressible dynamic SRv6 SIDs.
Non-compressed static SID start
Start value for non-compressible static SRv6 SIDs.
If no non-compressible static SRv6 SIDs exist, this field displays N/A.
Non-compressed static SID end
End value for non-compressible static SRv6 SIDs.
Reserved SID start
Start value for reserved SRv6 SIDs.
If no start value is specified for SRv6 SID reservation, this field displays N/A.
Reserved SID count
Number of reserved SRv6 SIDs.
Reserved SID end
End value for reserved SRv6 SIDs.
If no end value is specified for SRv6 SID reservation, this field displays N/A.
Number of dynamic compressible SRv6 SIDs.
Number of static compressible SRv6 SIDs.
Number of dynamic non-compressible SRv6 SIDs.
Number of static non-compressible SRv6 SIDs.
display segment-routing ipv6 locator-statistics
Use display segment-routing ipv6 locator-statistics to display SRv6 locator configuration and statistics about allocated SRv6 SIDs in locators.
display segment-routing ipv6 locator-statistics [ locator-name ]
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays SRv6 locator configuration and statistics about allocated SRv6 SIDs in all locators.
# Display SRv6 locator configuration and statistics about allocated SRv6 SIDs in all locators.
<Sysname> display segment-routing ipv6 locator-statistics
Total Locators: 1    Total SIDs: 1
Name       IPv6 prefix/Prefix length       CDyn/CStatic/Dyn/Static   Flag   Algo
abc        100:1::/64                      0   /0      /0  /1        0      0
Table 15 Command output
Total Locators
Total number of locators.
Total SIDs
Total number of SIDs that have been allocated in the locators.
Name
Locator name.
Locator prefix and prefix length.
Number of dynamic compressible SRv6 SIDs, number of static compressible SRv6 SIDs, number of dynamic non-compressible SRv6 SIDs, and number of static non-compressible SRv6 SIDs.
Flag
Algo
Algorithm ID:
·     0—SPF algorithm.
encapsulation source-address
Use encapsulation source-address to specify a source address for the outer IPv6 header of SRv6 packets.
Use undo encapsulation source-address to restore the default.
encapsulation source-address ipv6-address [ ip-ttl ttl-value ]
No source address is specified for the outer IPv6 header of SRv6 packets.
SRv6 view
ipv6-address: Specifies a source IPv6 address. The IPv6 address cannot be a loopback address, 0:0:0:0:0:0:0:0 or ::, link-local address, multicast address, or unspecified address.
ip-ttl ttl-value: Specifies the TTL of the outer IPv6 header, in the range of 1 to 255. The default value is 255.
As a best practice to ensure correct traffic forwarding in an SRv6 network, specify a source address for the outer IPv6 header of SRv6 packets.
You must specify an IPv6 address of the local device as the source IPv6 address, and make sure the IPv6 address has been advertised by a routing protocol. As a best practice, specify a loopback interface address of the local device as the source IPv6 address.
# Specify 1::1 as the source address of SRv6 packets in the outer IPv6 header and set the TTL of the outer IPv6 header to 200.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] encapsulation source-address 1::1 ip-ttl 200
locator
Use locator to create an SRv6 locator and enter its view, or enter the view of an existing SRv6 locator.
Use undo locator to delete an SRv6 locator.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
undo locator locator-name
No SRv6 locators exist.
SRv6 view
locator-name: Specifies a locator name, a case-sensitive string of 1 to 31 characters.
ipv6-prefix ipv6-address prefix-length: Specifies an IPv6 address prefix and the prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120.
args args-length: Specifies an argument length. The value range for the args-length argument depends on the value of the prefix-length argument and varies by device model. If you do not specify an argument length, the argument length is 0.
static static-length: Specifies the static length. The value range for the static-length argument varies by the value of the prefix-length argument and varies by device model. If you do not specify a static length, the static length is 0.
An SRv6 locator can be different types. For more information about the SRv6 SID fields, see SRv6 configuration in Segment Routing Configuration Guide.
If a static opcode has been configured, a routing protocol preferentially uses the static opcode to construct SRv6 SIDs. If no static opcode exists, the routing protocol dynamically allocates SRv6 SIDs.
By applying a locator to IGP and BGP, you can use IGP and BGP to advertise the SRv6 SIDs on the locator.
When you create a locator, you must specify an IPv6 address prefix, prefix length, and static length for the locator. When you enter the view of an existing SRv6 locator, you do not need to specify the IPv6 address prefix, prefix length, or static length of the locator.
Each locator must have a unique name.
Do not specify the same IPv6 address prefix and prefix length for different locators. In addition, the IPv6 address prefixes of different locators cannot overlap.
You cannot delete a locator if that locator has dynamic SRv6 SIDs that are being used.
# Configure locator test1, setting the IPv6 address prefix to 100::, prefix length to 64, and static length to 32, and enter the SRv6 locator view of this locator.
[Sysname-segment-routing-ipv6] locator test1 ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test1]
opcode
opcode
Use opcode to configure the opcode of SRv6 SIDs for a locator.
Use undo opcode to delete the opcode of SRv6 SIDs for a locator.
opcode opcode end-dt4 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode opcode  end-dt6 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode opcode end-dt2m vsi vsi-name
opcode opcode end-dt2u vsi vsi-name
undo opcode opcode { end-dt2m | end-dt2u | end-dt4 | end-dt6 }
No opcode exists.
SRv6 locator view
opcode: Specifies an opcode in the range of 1 to 2static-length-1, in which the static-length argument is configured by using the locator command.
end-dt4: Specifies the End.DT4 type.
end-dt6: Specifies the End.DT6 type.
end-dt2m: Specifies the End.DT2M type.
end-dt2u: Specifies the End.DT2U type.
weight weight-value: Specifies the load sharing weight value for the path, in the range of 1 to 254. The default value is 1.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SRv6 SIDs belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must exist. If the SRv6 SIDs belong to the public network, do not specify this option.
evpn: Specifies EVPN routes. If you do not specify this keyword, the command specifies the SRv6 SIDs of VPNv4 or VPNv6 routes.
l3vpn-evpn: Specifies EVPN routes, VPNv4 routes, and VPNv6 routes.
vsi vsi-name: Specifies the VSI to which the SRv6 SIDs belong. The vsi-name argument represents the VSI name, a case-sensitive string of 1 to 31 characters. The specified VSI must exist.
An SRv6 locator and its opcode and argument generate unique SRv6 SIDs. SRv6 SIDs form local SID forwarding table entries.
Use this command to configure the opcode of static SRv6 SIDs on a locator. The number of static SRv6 SIDs is determined by the static static-length option in the locator command.
To modify the opcode of static SRv6 SIDs on a locator, you must first delete the original opcode by using the undo opcode command.
# Configure End-DT4 SRv6 SIDs, and set the opcode to 64.
[Sysname-segment-routing-ipv6] locator test ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test] opcode 64 end-dt4
locator
segment-routing ipv6 (system view)
Use segment-routing ipv6 to enable SRv6 and enter SRv6 view.
Use undo segment-routing ipv6 to disable SRv6.
SRv6 is disabled.
After you execute this command, you can configure locators in SRv6 view. Then, you can configure the opcode portion in SRv6 locator view to generate local SID forwarding table entries.
You cannot disable SRv6 when a locator in SRv6 view has dynamic SRv6 SIDs that are being used.
# Enable SRv6 and enter SRv6 view.
segment-routing ipv6 locator (IS-IS IPv6 address family view)
Use segment-routing ipv6 locator to apply an SRv6 locator to an IPv6 IS-IS process.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from an IPv6 IS-IS process.
segment-routing ipv6 locator locator-name [ level-1 | level-2 ]
undo segment-routing ipv6 locator locator-name
No SRv6 locators are applied to an IPv6 IS-IS process.
Use this command to enable IPv6 IS-IS to advertise SRv6 SIDs.
If you do not specify a level, this command applies the specified locator to both level-1 and level-2 areas.
Use this command only when the cost style of IS-IS is wide, compatible, or wide-compatible.
Execute this command multiple times to apply multiple locators to an IPv6 IS-IS process so that the process can advertise multiple SRv6 SIDs.
The auto-sid-coc32 keyword takes effect only when the specified locator is a COC32 locator.
The auto-sid-coc-both { all | coc32 | coc32-all | coc32-none } keyword takes effect only when the specified locator is a COC-both locator.
# Apply locator abc to an IPv6 IS-IS process.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] segment-routing ipv6 locator abc
locator
