06-MPLS L2VPN commands | 366.49 KB |
MPLS L2VPN commands
ac interface
Use ac interface in cross-connect view to bind an Ethernet service instance to a cross-connect and enter cross-connect AC view, or enter an existing cross-connect AC view.
Use undo ac interface to remove the binding.
ac interface interface-type interface-number service-instance instance-id [ access-mode vlan ] [ track track-entry-number&<1-15> ]
undo ac interface interface-type interface-number service-instance instance-id
No Ethernet service instance is bound to a cross-connect.
Cross-connect view
Auto-discovery cross-connect view
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096.
access-mode: Specifies the access mode.
· When the AC is an Ethernet service instance, the default access mode depends on the match criterion of the Ethernet service instance:
¡ The default access mode is VLAN if the match criterion is specified by using the encapsulation s-vid vlan-id command.
- The default access mode is Ethernet if the match criterion is specified by using the encapsulation tagged command.
vlan: Specifies the VLAN access mode.
track track-entry-number&<1-15>: Specifies a space-separated list of up to 15 track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
After you execute this command, packets received from those matching the Ethernet service instance are forwarded to the bound PW or another AC.
The Ethernet service instance specified in this command must have a packet match criterion configured by the encapsulation command.
The access mode determines how the PE treats the VLAN tag in Ethernet frames received from the AC. It also determines how the PE forwards Ethernet frames to the AC. The device supports the VLAN access mode. Ethernet frames received from the AC must carry a VLAN tag in the Ethernet header. The VLAN tag is called a P-tag assigned by the service provider. Ethernet frames sent to the AC must also carry the P-tag.
# Configure Ethernet service instance 200 on GigabitEthernet 1/0/1 to match packets with an outer VLAN tag of 200. Bind the Ethernet service instance to cross-connect actopw in cross-connect group vpn1.
[Sysname-GigabitEthernet1/0/1] service-instance 200
[Sysname-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[Sysname-GigabitEthernet1/0/1-srv200] quit
[Sysname] xconnect-group vpn1
[Sysname-xcg-vpn1] connection actopw
[Sysname-xcg-vpn1-actopw] ac interface gigabitethernet 1/0/1 service-instance 200
[Sysname-xcg-vpn1-actopw-GigabitEthernet1/0/1-srv200]
# Configure Ethernet service instance 200 on GigabitEthernet 1/0/1 to match packets with an outer VLAN tag of 200. Bind the Ethernet service instance to the auto-discovery cross-connect in cross-connect group vpwsbgp.
[Sysname] xconnect-group vpwsbgp
[Sysname-xcg-vpwsbgp] auto-discovery bgp
[Sysname-xcg-vpwsbgp-auto] site 1 range 10 default-offset 0
[Sysname-xcg-vpwsbgp-auto-1] connection remote-site-id 2
[Sysname-xcg-vpwsbgp-auto-1-2] ac interface gigabitethernet 1/0/1 service-instance 200
[Sysname-xcg-vpwsbgp-auto-1-2-GigabitEthernet1/0/1-srv200]
connection
display l2vpn service-instance
encapsulation
address-family l2vpn
Use address-family l2vpn to create the BGP L2VPN address family and enter its view, or enter the view of the existing BGP L2VPN address family view.
Use undo address-family l2vpn to delete the BGP L2VPN address family and all settings from BGP L2VPN address family view.
No BGP L2VPN address family exists.
BGP instance view
To establish a BGP PW to a remote PE, you must execute the peer enable command in BGP L2VPN address family view to enable the remote PE.
# Create the BGP L2VPN address family and enter BGP L2VPN address family view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn
[Sysname-bgp-default-l2vpn]
peer enable (Layer 3—IP Routing Command Reference)
auto-discovery
Use auto-discovery to enable a cross-connect group to automatically discover neighbors and create PWs through BGP, and enter auto-discovery cross-connect group view.
Use undo auto-discovery to restore the default.
auto-discovery bgp
undo auto-discovery
A cross-connect group does not use BGP to automatically discover neighbors and create PWs.
Cross-connect group view
bgp: Enables the cross-connect group to automatically discover neighbors and create PWs through BGP.
In auto-discovery cross-connect group view, you can configure parameters such as the local site, remote site, and route target for BGP. The local PE can use BGP to discover remote PEs and create PWs.
# Enable cross-connect group bbb to automatically discover neighbors and create PWs through BGP, and enter auto-discovery cross-connect group view.
[Sysname] xconnect-group bbb
[Sysname-xcg-bbb] auto-discovery bgp
[Sysname-xcg-bbb-auto]
display l2vpn pw
display l2vpn xconnect-group
connection
Use connection to create a cross-connect and enter its view, or enter the view of an existing cross-connect.
Use undo connection to remove a cross-connect.
connection connection-name
undo connection connection-name
No cross-connects exist.
connection-name: Specifies the name of the cross-connect, a case-sensitive string of 1 to 20 characters, excluding hyphens.
A cross-connect is a point-to-point connection.
You can perform the following operations in cross-connect view:
· Execute ac interface and peer to connect an AC to a PW, so the PE can forward packets between the AC and the PW.
· Execute ac interface twice to connect two ACs, so the PE can forward packets between the two ACs.
# Create cross-connect ac2pw for cross-connect group vpn1 and enter cross-connect view.
[Sysname-xcg-vpn1] connection ac2pw
[Sysname-xcg-vpn1-ac2pw]
Use connection remote-site-id to create an auto-discovery cross-connect and enter its view, or enter the view of an existing auto-discovery cross-connect.
Use undo connection remote-site-id to remove the auto-discovery cross-connect.
connection remote-site-id remote-site-id
undo connection remote-site-id remote-site-id
No auto-discovery cross-connects exist.
Site view
remote-site-id: Specifies a remote site by its ID in the range of 0 to 256.
This command creates an auto-discovery cross-connect that uses BGP to establish a PW from the local site to the specified remote site.
In auto-discovery cross-connect view, you can execute ac interface to bind an AC to the auto-discovery cross-connect. The PE can forward packets between the AC and the PW.
# Create an auto-discovery cross-connect from site 1 to site 3 in site view, and enter auto-discovery cross-connect view.
[Sysname-xcg-bbb-auto] site 1 range 10
[Sysname-xcg-bbb-auto-1] connection remote-site-id 3
[Sysname-xcg-bbb-auto-1-3]
description
Use description to configure a description for a cross-connect group.
No description is configured for a cross-connect group.
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description of vpws for vpn2 for cross-connect group vpn2.
[Sysname] xconnect-group vpn2
[Sysname-xcg-vpn2] description vpws for vpn2
display bgp l2vpn signaling
Use display bgp l2vpn signaling to display MPLS L2VPN label block information discovered by BGP.
display bgp [ instance instance-name ] l2vpn signaling [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] | statistics ]
instance instance-name: Displays MPLS L2VPN label block information in a BGP instance. The instance-name argument specifies the BGP instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays MPLS L2VPN label block information in the default BGP instance.
peer ip-address: Displays MPLS L2VPN label block information advertised to or received from a BGP peer. The ip-address argument specifies the peer IP address.
advertised: Displays MPLS L2VPN label block information advertised to the BGP peer.
received: Displays MPLS L2VPN label block information received from the BGP peer.
statistics: Displays BGP MPLS L2VPN label block statistics.
route-distinguisher route-distinguisher: Displays BGP MPLS L2VPN label block information for the route distinguisher (RD), which is a string of 3 to 21 characters. You can specify an RD in one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
site-id site-id: Displays BGP MPLS L2VPN label block information for a site. The site-id argument specifies the site ID, in the range of 0 to 256.
label-offset label-offset: Displays information about the BGP MPLS L2VPN label block with an offset. The label-offset argument specifies the offset in the range of 0 to 65535.
advertise-info: Displays BGP MPLS L2VPN label block advertisement information.
If you do not specify any parameters, this command displays brief information about all BGP MPLS L2VPN label blocks.
# Display brief information about all BGP MPLS L2VPN label blocks.
<Sysname> display bgp l2vpn signaling
BGP local router ID is 192.168.1.135
Total number of label blocks: 2
Route distinguisher: 2:2
Site ID LB offset LB range LB base Nexthop
* > 1 0 10 1034 0.0.0.0
* >i 2 0 10 1162 192.3.3.3
Status codes |
Status codes: · * – valid—Valid route. · > – best—Best route. · d – damped—Dampened route. · h – history—History route. · s – suppressed—Suppressed route. · S – Stale—Stale route. · i – internal—Internal route. · e – external—External route. |
Origin |
Origin of the label block: · i – IGP—Originated in the AS. · e – EGP—Learned through EGP. · ? – incomplete—Unknown origin. |
LB offset |
Offset of the label block. |
LB range |
Size of the label block. |
LB base |
Initial value of the label block. |
<Sysname> display bgp l2vpn signaling route-distinguisher 2:2 site-id 2 label-offset 0
Local AS number: 100
Total number of label blocks: 1
Paths: 1 available, 1 best
Original nexthop: 192.3.3.3
Ext-Community : <RT: 2:2>, <L2VPN info: MTU 1500, Encap type VLAN>
AS-path : (null)
Origin : igp
Attribute value : localpref 100, pref-val 0
Site ID : 2
LB offset : 0
LB base : 1162
LB range : 10
State : valid, internal, best
CSV : 0x01000ABFFF
Paths |
Number of label block messages: · available—Number of available label block messages. · best—Number of best label block messages. |
From |
IP address of the peer from which the label block was received. |
Original nexthop |
Original next hop. If the label block was obtained from a BGP route update, this field displays the next hop address in that BGP route update. |
Ext-Community |
Extended community attribute: · RT—Route target. · L2VPN info—L2VPN information, including the MTU and encapsulation type. |
AS-path |
AS path attribute, which records all ASs that the label block passed to prevent routing loops. |
Origin |
Origin of the label block: · igp—Originated in the AS. · egp—Learned through EGP. · incomplete—Unknown origin. |
Attribute value |
Attribute of the label block: · MED—Multi-Exit Discriminator attribute. · localpref—Local preference value. · pref-val—Preferred value. · pre—Preference value. |
LB offset |
LB base |
LB range |
State |
State of the label block: · valid. · internal. · external. · local. · best. |
CSV |
Circuit status vector. |
# Display BGP advertisement information for the specified MPLS L2VPN label block.
<Sysname> display bgp l2vpn signaling route-distinguisher 2:2 site-id 1 label-offset 0 advertise-info
Paths: 1 best
Site ID : 1
LB offset : 0
LB base : 1034
LB range : 10
CSV : 0x01000ADFFF
192.3.3.3
Paths |
LB offset |
LB base |
LB range |
CSV |
Advertised to peers (1 in total) |
Peers to which the label block has been advertised. |
display l2vpn bgp
Use display l2vpn bgp to display MPLS L2VPN label block information.
display l2vpn bgp [ local | peer ip-address ] [ xconnect-group group-name ] [ verbose ]
local: Displays local MPLS L2VPN label block information.
peer ip-address: Displays MPLS L2VPN label block information received from the remote peer.
xconnect-group group-name: Displays MPLS L2VPN label block information for a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays MPLS L2VPN label block information for all cross-connect groups.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you specify a peer, this command displays both the label block received from the peer and the local label block that matches the received label block.
If you do not specify a peer or local, this command displays label blocks received from all peers and local label blocks that match the received ones. If no local label block matches the received ones, the command only displays the label blocks received from all peers.
A local label block matches a received label block if the following condition is met: local label block LO ≤ remote site ID ≤ local label block LO + local label block LR – 1.
# Display brief information about label blocks received from all peers.
<Sysname> display l2vpn bgp
Total number of BGP PWs: 1, 1 up, 0 down
Xconnect-group Name: vpnb, Site ID:1
Rmt Site Offset RD Nexthop In/Out Label State
2 0 2:2 192.3.3.3 1036/1163 Up
Rmt Site |
ID of the remote site. |
Offset |
# Display detailed information about label blocks received from all peers.
<Sysname> display l2vpn bgp verbose
Remote Site ID : 2
Offset : 0
RD : 2:2
PW State : Up
Encapsulation : VLAN
MTU : 1500
Nexthop : 192.3.3.3
Local VC Label : 1036
Remote VC Label : 1163
Link ID : 0x10000000
Local Label Block : 1034/10/0
Remote Label Block : 1162/10/0
Local Flow Label : Send
Reomote Flow Label : Recv
Export Route Target: 2:2
Table 5 Command output
Local VC Label |
Incoming label of the PW. |
Remote VC Label |
Outgoing label of the PW. |
Link ID |
Link ID of the PW. |
Local Label Block |
Local label block: label base/label range/Label-block offset. |
Remote Label Block |
Remote label block: label base/label range/Label-block offset. |
Local Flow Label |
Flow label capability of the local PE: · Both—Flow label sending and receiving capabilities. · Send—Flow label sending capability. · Recv—Flow label receiving capability. This field displays a hyphen (-) if the flow label feature is disabled. |
Remote Flow Label |
Flow label capability of the remote PE: · Both—Flow label sending and receiving capabilities. · Send—Flow label sending capability. · Recv—Flow label receiving capability. This field displays a hyphen (-) if the flow label feature is disabled. |
Export Route Target |
Route target of the remote label block. |
# Display brief information about all local label blocks.
<Sysname> display l2vpn bgp local
Site Offset Range Label Base RD
1 0 10 1034 2:2
# Display detailed information about all local label blocks.
<Sysname> display l2vpn bgp local verbose
Site ID : 1
Offset : 0
RD : 2:2
Range : 10
Label Base : 1034
Link ID : 1
Table 6 Command output
Offset |
RD |
RD of the label block. If no RD is configured, this field displays a hyphen (-). |
Range |
Range of the label block. |
Label Base |
Link ID |
Link ID of the PW established using the label block. The link ID is fixed to 1 because an MPLS L2VPN cross-connect can establish only one BGP PW. |
display l2vpn pw
display l2vpn forwarding
Use display l2vpn forwarding to display cross-connect forwarding information.
display l2vpn forwarding { ac | pw } [ xconnect-group group-name ] [ slot slot-number ] [ verbose ]
ac: Displays AC forwarding information.
pw: Displays PW forwarding information.
xconnect-group group-name: Displays forwarding information for a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive string of 1 to 31 characters. If you do not specify a group, this command displays forwarding information for all cross-connect groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays cross-connect forwarding information for the master device.
# Display brief AC forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding ac
Total number of cross-connections: 1
Total number of ACs: 1 up, 0 down
AC Xconnect-group Name Link ID State
BAGG1 srv1 1 0x1 Up
Table 7 Command output
Total number of cross-connections |
Total number of cross-connects, including cross-connects not bound to any ACs. |
Total number of ACs |
Total number of ACs in up state and down state, respectively. |
AC |
AC type. The value is Ethernet service instance on a Layer 2 interface. |
State |
State of the AC, which can be Up or Down. |
# Display detailed AC forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding ac verbose
Xconnect-group Name: vpws1
Connection Name: actopw
Interface: GE1/0/3 Service Instance: 1
Link ID : 0x1
Access Mode : VLAN
Encapsulation : s-vid 16
Connection Name: actopw2
Interface: GE1/0/3 Service Instance: 4
Link ID : 0x1
Access Mode : VLAN
Encapsulation : untagged
Redundancy Mode : All-active
DF State : DF
Reflector :
IP Address : 100.1.1.4
MAC Address : 8850-fc51-5cee
Src Port : 200
Dst Port : 201
State : Ready
Table 8 Command output
Xconnect-group Name |
Cross-connect group name. |
Connection Name |
Cross-connect name. |
Service Instance |
The field is available only when the AC is an Ethernet service instance on a Layer 2 interface. |
Access Mode |
AC access mode: · VLAN. · Ethernet. |
Encapsulation |
Match criterion of the Ethernet service instance. This field is displayed only when the AC type is Ethernet service instance on a Layer 2 interface. |
Redundancy Mode |
Redundancy mode of the Ethernet segment (ES): · All-active—All-active mode. · Single-active—Single-active mode. This field is not displayed if the interface is not configured with an Ethernet Segment Identifier (ESI). |
DF State |
Designated forwarder (DF) role of the EVPN ES: · DF—The ES is a DF. · BDF—The ES is a backup designated forwarder (BDF). · DF (BFD)—BDF has detected faults on the DF-side AC by monitoring the static BFD session state and switched the AC to DF. This field is not displayed if the interface is not configured with an ESI. |
Reflector |
Packet reflection information. |
IP Address |
Destination IP address to be reflected. |
MAC Address |
Destination MAC address to be reflected. |
Src Port |
Source UDP port to be reflected. |
Dst Port |
Destination UDP port to be reflected. |
State |
Packet reflection deployment state: · Ready—The packet reflection information has been deployed to the drive. · Not ready—The packet reflection information has not been deployed to the drive. |
# Display brief PW forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding pw
Total number of PWs: 2, 2 up, 0 blocked, 0 down
Xconnect-group Name In/Out Label NID Link ID State
vpn1 1279/1151 1025 0x10000000 Up
vpn1 1278/1151 1027 0x10000001 Up
Table 9 Command output
Total number of cross-connects, including those not bound to any PW. |
In/Out Label |
Incoming and outgoing labels of the PW. A hyphen (-) indicates that no label exists. |
NID |
NHLFE ID for the public tunnel that carries the PW. If equal-cost tunnels are available, this field displays multiple NIDs. If no tunnel is available, this field displays None. |
State |
PW state: Up, Down, or Blocked. Blocked indicates that the PW is a backup PW or bypass PW. |
# Display detailed PW forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding pw verbose
Xconnect-group Name: vpn1
Connection Name: ldp
Link ID: 0x10000000
PW Type : VLAN PW State : Up
In Label : 1279 Out Label: 1151
MTU : 1500
PW Attributes : Main
VCCV CC : Router-Alert
VCCV BFD : Fault Detection with BFD
Flow Label : Send
Tunnel Group ID : 0x60000000
Tunnel NHLFE IDs: 1025
Link ID: 0x10000001
In Label : 1278 Out Label: 1151
MTU : 1500
Flow Label : Send
Tunnel Group ID : 0x160000001
Tunnel NHLFE IDs: 1027
Table 10 Command output
PW State |
In Label |
Incoming label of the PW. A hyphen (-) indicates that no label exists. |
Out Label |
Outgoing label of the PW. A hyphen (-) indicates that no label exists. |
PW Attributes |
PW attribute: · Main—Primary PW. · Backup—Backup PW. · Bypass—Bypass PW. · AC-bypass—The PW is an AC bypass. This attribute is not supported in the current software version. · PW-bypass—The PW is a PW bypass. This attribute is not supported in the current software version. · ECMP—The PW is an ECMP PW. |
VCCV CC |
VCCV CC type: · Control-Word—Control word. · Router-Alert—MPLS Router Alert Label. · TTL—TTL expiry (MPLS PW Label with TTL=1.) This field displays a hyphen (-) if no VCCV CC type is specified. |
VCCV BFD |
VCCV BFD type: · Fault Detection with BFD. BFD packets use IP/UDP encapsulation (with IP/UDP headers). · Fault Detection with Raw-BFD. BFD packets use PW-ACH encapsulation (without IP/UDP headers). This field displays a hyphen (-) if BFD is not used to verify PW connectivity. |
Flow Label |
Flow label capability: · Both—Flow label sending and receiving capabilities. · Send—Flow label sending capability. · Recv—Flow label receiving capability. This field displays a hyphen (-) if the flow label feature is disabled. |
Tunnel Group ID |
ID of the tunnel group for the PW. |
Tunnel NHLFE IDs |
NHLFE IDs of the public tunnels that carry the PW. If equal-cost tunnels are available, this field displays multiple tunnel NHLFE IDs. If no tunnel is available, this field displays None. |
display l2vpn ldp
Use display l2vpn ldp to display LDP PW label information.
display l2vpn ldp [ peer ip-address [ pw-id pw-id ] | xconnect-group group-name ] [ verbose ]
peer ip-address: Displays LDP PW label information advertised by a peer PE. The ip-address argument specifies the LSR ID of the peer PE. If you do not specify a peer PE, this command displays LDP PW label information advertised by all peer PEs.
pw-id pw-id: Displays LDP PW label information for a PW. The pw-id argument specifies the PW ID in the range of 1 to 4294967295. If you specify peer ip-address without this option, the command displays all LDP PW label information advertised by the peer PE.
xconnect-group group-name: Displays LDP PW label information for a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays LDP PW label information for all cross-connect groups.
# Display brief information about all LDP PW labels.
<Sysname> display l2vpn ldp
Total number of LDP PWs: 5, 4 up, 1 down
Peer PW ID/VPLS ID In/Out Label State Owner
192.3.3.3 1001 775125/775126 Up vpws1
192.3.3.3 1003 775117/775122 Up vpws3
192.3.3.3 1004 775120/775120 Up vpws4
192.4.4.4 1000 775116/unknown Down vpws5
Table 11 Command output
PW ID/VPLS ID |
This field displays the PW ID for FEC 128, and displays the VPLS ID for FEC 129. Only VPLS supports FEC 129. |
Owner |
Cross-connect group of the PW. |
# Display detailed information about all LDP PW labels.
<Sysname> display l2vpn ldp verbose
Peer: 192.2.2.2 PW ID: 1000
Xconnect-group: vpn1
Connection : ldp
PW State : Up
PW Status Communication: Notification method
PW Preferential Forwarding Status Bit: Process
PW ID FEC (Local/Remote):
PW Type : VLAN/VLAN
Group ID : 0/0
Label : 1151/1279
Control Word: Disabled/Disabled
VCCV CC Type: -/-
VCCV CV Type: -/-
Flow Label : Send/Recv
MTU : 1500/1500
PW Status : PW forwarding/PW forwarding
Table 12 Command output
Xconnect-group |
Connection |
Cross-connect of the PW. |
PW Status Communication |
PW state communicate: · Notification method—Uses notifications to communicate PW states. · Label withdraw method—Assigns a PW label to the PW when the AC is up and withdraws the PW label when the AC goes down. |
PW Preferential Forwarding Status Bit |
PW state processing mode: · Process—Process the received PW states. · Ignore—Ignore the received PW states. |
VCCV CC Type |
VCCV CC type: · Control-Word—Control word. · Router-Alert—MPLS Router Alert Label. · TTL—TTL expiry (MPLS PW Label with TTL=1.) This field displays a hyphen (-) if no VCCV CC type is specified. For information about VCCV, see MPLS Configuration Guide. |
VCCV CV Type |
VCCV CV type: · LSP Ping—Uses MPLS LSP ping to verify PW connectivity. · BFD—Uses BFD to verify PW connectivity. BFD packets use IP/UDP encapsulation (with IP/UDP headers). · Raw-BFD—Uses BFD to verify PW connectivity. BFD packets use PW-ACH encapsulation (without IP/UDP headers). This field displays a hyphen (-) if VCCV is not performed on the PW. |
Flow Label |
Bit Rate |
This field is not supported in the current software version. CEM interface bit rate, in kbps. It varies by circuit type of CEM interfaces. · E1 in SAToP mode = 32. · T1 in SAToP mode = 24. · E1/T1 in CESoPSN mode = Number of time slots. |
Payload |
This field is not supported in the current software version. CEM interface payload size, in bytes. The value of this parameter is calculated by the formula: payload size in bytes = number of time slots × payload size in frames. |
RTP Header |
This field is not supported in the current software version. Whether the RTP header is enabled. |
Timestamping |
This field is not supported in the current software version. Timestamp transmission mode: · Differential. · Absolute. |
Frequency |
This field is not supported in the current software version. Time stamping frequency. |
display l2vpn pw
Use display l2vpn pw to display L2VPN PW information.
display l2vpn pw [ xconnect-group group-name ] [ protocol { bgp | evpn | ldp | static } ] [ verbose ]
xconnect-group group-name: Displays L2VPN PW information for a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive string of 1 to 31 characters. If you do not specify a group, this command displays L2VPN PW information for all cross-connect groups.
protocol: Displays L2VPN PW information established by a protocol. If you do not specify a protocol, this command displays L2VPN PW information established by all protocols.
bgp: Displays BGP PW information.
evpn: Displays EVPN PW information.
ldp: Displays LDP PW information.
static: Displays static PW information.
After you enable PW statistics, you can use the display l2vpn pw verbose command to display PW statistics.
# Display brief information about all L2VPN PWs.
<Sysname> display l2vpn pw
N - no split horizon, A - administration, ABY – ac-bypass
PBY – pw-bypass
Total number of PWs: 3
3 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: ldp
Peer PWID/RmtSite/SrvID In/Out Label Proto Flag Link ID State
192.3.3.3 500 1299/1299 LDP M 10000000 Up
192.3.3.2 600 1292/1291 LDP ABY 10000000 Up
192.3.3.3 2 1036/1163 BGP M 10000001 Up
Table 13 Command output
Flags |
PW flag. |
PWID/RmtSite/SrvID |
This field displays the PW ID for a static or LDP PW, the remote site ID for a BGP PW, and the remote service ID for an EVPN PW or SRv6 tunnel. |
Proto |
Protocol that established the PW: LDP, Static, or BGP. |
Flag |
PW attribute: · M - Main—The PW is a primary PW. · B - Backup—The PW is a backup PW. · E - ECMP—The PW is an ECMP PW. · BY - Bypass—The PW is a bypass PW. · H - Hub link—The PW is the hub link in a hub-spoke VPLS network. · S - Spoke link—The PW is a spoke link in a hub-spoke VPLS network. · N - No-split-horizon—Split horizon forwarding is disabled. · A - Administration—The PW is an administration PW. This attribute is not supported in the current software version. · ABY - AC-bypass—The PW is an bypass PW for AC bypass. This attribute is not supported in the current software version. · PBY - PW-bypass—The PW is a bypass PW for PW bypass. This attribute is not supported in the current software version. |
Link ID |
State |
PW state: · Up—The PW is available. · Down—The PW is not available. · Blocked—The PW is a backup PW. · Defect—BFD has detected a defect on the PW. · Idle—The incoming label of the PW is not available. · Dup—The incoming label of the static PW is used by a static LSP, static CRLSP, or static SRLSP. |
# Display detailed information about all PWs.
<Sysname> display l2vpn pw verbose
Peer: 192.3.3.3 PW ID: 500
Signaling Protocol : LDP
Link ID : 0x10000000 PW State : Up
In Label : 1299 Out Label: 1299
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : Send
Tunnel Group ID : 0x800000160000000
Tunnel NHLFE IDs : 1026
Admin PW : Associated AC interface Loop0
Input statistics :
Octets : 10600
Packets : 100
Errors : 0
Discards : 0
Output statistics :
Octets : 12600
Packets : 100
Errors : 0
Discards : 0
Connection of auto-discovery: Site 1
Peer: 192.3.3.3 Remote Site: 2
Signaling Protocol : BGP
Link ID : 0x10000001 PW State : Up
In Label : 1036 Out Label: 1163
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : Recv
Admin PW : -
Xconnect-group Name: ccc
Connection Name: 1
Peer: 13.13.13.9 Remote Service ID: 4011
Signaling Protocol : EVPN
Link ID : 1 PW State : Down
In Label : 710126 Out Label: 1424
MTU : 1500
PW Attributes : AC-bypass, No-split-horizon
VCCV CC : -
VCCV BFD : -
Flow Label : -
Control Word : Disabled
Tunnel Group ID : 0x2000000130000001
Tunnel NHLFE IDs : 4
Admin PW : -
Color : -
Table 14 Command output
Connection Name |
Cross-connect name, which is displayed for LDP and static PWs. |
Peer |
IP address of the peer PE of the PW. |
Remote Service ID |
This field is not supported in the current software version. Remote service ID used for EVPN PW establishment. |
Signaling Protocol |
Protocol that established the PW: LDP, Static, BGP, or EVPN. |
PW State |
PW state: · Up—The PW is available. · Down—The PW is not available. · Blocked—The PW is a backup PW. · Defect—BFD has detected a defect on the PW. · Idle—The incoming label of the PW is not available. · Duplicate—The incoming label of the static PW is used by a static LSP, static CRLSP, or static SRLSP. |
Wait to Restore Time |
Wait time to switch traffic from the backup PW to the primary PW when the primary PW recovers, in seconds. If the switchover is disabled, this field displays Infinite. This field is available when both primary and backup PW exist, and is displayed only for the primary PW. |
Remaining Time |
Remaining wait time for traffic switchover, in seconds. |
PW Attributes |
PW attribute: · Main—Primary PW. · Backup—Backup PW. · ECMP—ECMP PW. · Bypass—Bypass PW. · Administration—Administration PW. This attribute is not supported in the current software version. · AC-bypass—Bypass PW for AC bypass. This attribute is not supported in the current software version. · PW-bypass—Bypass PW for PW bypass. This attribute is not supported in the current software version. |
VCCV CC |
VCCV BFD |
Flow Label |
Tunnel Group ID |
Tunnel NHLFE IDs |
Admin PW |
This field is not supported in the current software version. Administration PW to which the PW is bound. This field displays a hyphen (-) if the PW is not bound to an administration PW. |
Connection of auto-discovery |
The PW is a BGP PW. |
Site |
Local site ID. |
Remote site |
Remote site ID. |
Down Reasons |
Reason why the PW went down: · BFD session for PW down. · BGP RD was deleted. · BGP RD was empty. · Control word not match. · Encapsulation not match. · EVPN VPWS AD per EVI route not received from peer—The local end of the EVPN-VPWS PW did not receive A-D per EVI routes from the remote end. · EVPN VPWS AD per ES route not received from peer—The local end of the EVPN-VPWS PW did not receive A-D per ES routes from the remote end. · Label not allocated. · LDP interface parameter not match. · Local and remote LDP PWs have different AII. · Non-existent remote LDP PW—The remote end has deleted the LDP PW. · Local AC Down. · Local AC was non-existent—Local AC was not configured. · Local LDP PW VN defect—Local LDP PW had VN defects. · Local LDP PW was not sent mapping message—The local end did not send LDP mapping messages. · Local VSI Down. · MTU not match. · Remote AC Down. · Remote LDP PW VN defect—Remote LDP PW had VN defects. · PW down after created—The PW is in down state after being created. · Tunnel Down. |
Input statistics |
Incoming packet statistics for the PW: · Octets—Number of incoming octets. · Packets—Number of incoming packets. · Errors—Number of error packets. · Discards—Number of discarded packets. |
Output statistics |
Outgoing packet statistics for the PW: · Octets—Number of outgoing octets. · Packets—Number of outgoing packets. · Errors—Number of error packets. · Discards—Number of discarded packets. |
Color |
Color attribute value of the SR-MPLS TE policy expected to be recursed to. If no color attribute exists, this field displays a hyphen (-). This field is displayed only for EVPN PWs. |
statistics enable (cross-connect PW view)
display l2vpn pw state-machine
Use display l2vpn pw state-machine to display MPLS L2VPN PW state machine information.
display l2vpn pw state-machine [ vsi vsi-name | xconnect-group group-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN PW state machine information for all VSIs.
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a group, this command displays L2VPN PW state machine information for all cross-connect groups.
# Display MPLS L2VPN PW state machine information.
<Sysname> display l2vpn pw state-machine
PW Group State:
Idle - Idle, N - Normal, UA - Unavailable, PA - Protecting administrative
PF - Protecting failure, WTR - Wait-to-Restore, DNR - Do-not-Revert
SWT - Switchover wait, SWTR - Switchover wait Restore
M - Manual switch, P - Protection PW failure, W - Working PW failure
L - Local, R - Remote
PW Group Link ID : 0
Main PW : Peer: 192.3.3.3 PW ID: 500
Backup PW : -
Main PW Defect State : No defect
Backup PW Defect State : -
Switch Flag : 0x01
Switch Result : None
Switch Reason : PW down
SWT Expiry Count : 0
SWTR Expiry Count : 0
Remote Event : None
Local Event : None
PW Group Old State : Idle
PW Group State : Normal
PW Group Link ID : 1
Main PW : Peer: 192.3.3.3 Remote Site: 2
Backup PW : -
Switch Flag : 0x01
Remote Event : None
Local Event : None
PW Group State : Idle
Table 15 Command output
Connection Name |
Cross-connect name. This field is displayed for LDP PWs and static PWs. |
BGP PW. |
Site |
Local site ID. |
Peer |
Backup PW |
If no backup PWs exist, this field displays a hyphen (-). |
Main PW Defect State |
Primary PW defect state: · No defect—The primary PW does not have defects. · Signal defect—The signaling protocol detects a defect on the primary PW. · VN defect—The virtual next hop (VN) detects a defect on the primary PW. · OAM defect—OAM detects a defect on the primary PW. · Admin PW defect—The administration PW detects a defect on the primary PW. This state is not supported in the current software version. · Remote defect—The remote end of the PW has defects. |
Backup PW Defect State |
Backup PW defect state. The options of this field are the same as those of the Main PW Defect State field. If no backup PWs exist, this field displays a hyphen (-). |
Switch Flag |
Primary/backup PW switchover flag: · Local manual switching—A manual primary/backup PW switchover is performed at the local end. · Signaling switching—A primary/backup PW switchover is triggered by the signaling protocol. · Remote manual switching—A manual primary/backup PW switchover is performed at the remote end. |
Switch Result |
Primary/backup PW switchover result: · None—Neither the primary nor the backup PW is used to forward traffic. · Main—The primary PW is used to forward traffic. · Backup—The backup PW is used to forward traffic. |
Switch Reason |
Reason for the primary/backup PW switchover: · Manual force switch—The l2vpn switchover command was executed. · Config changed—A PW was added or removed in the set of redundant PWs. · Fault dectected—BFD or VCCV detected a PW failure. · PW down—The PW went down. · PW up—The PW came up. · Receive notification message—A notification was received. · Restore manual force switch—Restored the PW state before the l2vpn switchover command was most recently executed. · None—No primary/backup PW switchover occurred. |
SWT Expiry Count |
Number of times that the switchover wait timer expires. This value is used to determine whether to re-initiate a request switchover. This counter is reset when a primary/backup PW switchover occurs. |
SWTR Expiry Count |
Number of times that the switchover wait restore timer. This value is used to determine whether to re-initiate a request switchover. This counter is reset when a primary/backup PW switchover occurs. |
Remaining Wait Time |
Remaining wait time for the request switchover acknowledgment, in seconds. This field is displayed after the switchover wait timer is started. |
Remote Event |
Event received from the remote state machine: · SFW—The primary PW has defects. · SFP—The backup PW has defects. · SFCW—The primary PW comes up. · SFCP—The backup PW comes up. · MS—Traffic is manually switched from the primary PW to the backup PW. · MR—Traffic is manaully switched from the backup PW to the primary PW. · None—No event is received. |
Local Event |
Event received from the local state machine: · SFW—The primary PW has defects. · SFP—The backup PW has defects. · SFCW—The primary PW comes up. · SFCP—The backup PW comes up. · MS—Traffic is manually switched from the primary PW to the backup PW. · MR—Traffic is manually switched from the backup PW to the primary PW. · WTREXP—The wait to restore timer expires. · WTR—The wait to restore timer is set to a non-zero value. · DNR—The switchover mode is set to non-revertive, which indicates that traffic is not switched from the backup PW to the primary PW after the primary PW recovers. · SWTEXP—The switchover wait timer expires. · None—No event is received. |
PW Group Old State |
PW state before the primary/backup PW switchover: · Idle—Neither the primary nor the backup PW is available. · Normal—Both the primary and backup PWs are available. The primary PW is up. · UA:P:L—The local end of the backup PW has defects. The primary PW is up. · UA:P:R—The remote end of the backup PW has defects. The primary PW is up. · PF:W:L—The local end of the primary PW has defects. The backup PW is up. · PF:W:R—The remote end of the primary PW has defects. The backup PW is up. · PA:M:L—Both the primary and backup PWs are available. A switchover command is executed at the local end to switch traffic from the primary PW to the backup PW. · PA:M:R—Both the primary and backup PWs are available. A switchover command is executed at the remote end to switch traffic from the primary PW to the backup PW. · WTR—Waiting for the expiration of the wait to restore timer. · DNR—Traffic is not switched from the backup PW to the primary PW after the primary PW recovers. · SWT—Waiting for acknowledgment for the primary-to-backup switchover request. · SWTR—Waiting for acknowledgment for the backup-to-primary switchover request. |
PW Group State |
PW state after the primary/backup PW switchover. Options of this field are the same as those of the PW Group Old State field. |
Use display l2vpn service-instance to display Ethernet service instance information.
interface interface-type interface-number: Displays Ethernet service instance information for the specified Layer 2 Ethernet interface or Layer 2 aggregate interface. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Displays information about the Ethernet service instance specified by its ID. The instance ID is in the range of 1 to 4096. If you specify interface interface-type interface-number without this option, the command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 1, 0 up, 1 down
Total number of ACs: 1, 0 up, 1 down
Interface SrvID Owner LinkID State Type
GE1/0/1 1 1 1 Down VPWS
Table 16 Command output
SrvID |
Ethernet service instance ID. |
Owner |
Name of the cross-connect group bound to the Ethernet service instance. This field is empty if no cross-connect group is bound. |
Link ID |
Link ID of the AC. |
State |
State of the service instance: UP or Down. |
Type |
L2VPN type. The value can only be VPWS for an MPLS L2VPN network. |
# Display detailed information about all Ethernet service instances on Layer 2 Ethernet interface GigabitEthernet 1/0/1.
<Sysname> display l2vpn service-instance interface gigabitethernet 1/0/1 verbose
Interface: GE1/0/1
Service Instance: 1
Xconnect-group: vpws1
Connection : actopw
Link ID : 0x1
State : Up
Statistics : Enabled
Input Statistics:
Octets :0
Packets :0
Errors :0
Discards:0
Output Statistics:
Octets :0
Packets :0
Errors :0
Discards:0
Table 17 Command output
Layer 2 Ethernet interface or Layer 2 aggregate interface. |
Encapsulation |
Packet match criterion of the Ethernet service instance. This field is not displayed if no packet match criterion is configured. |
Xconnect-group |
Name of the cross-connect group bound to the Ethernet service instance. |
AD connection |
Name of the auto-discovery cross-connect bound to the Ethernet service instance, identified by the local and remote site IDs. |
Link ID |
State |
State of the Ethernet service instance: UP or Down. |
Statistics |
Packet statistics state: · Enabled—Packet statistics is enabled for the Ethernet service instance. · Disabled—Packet statistics is disabled for the Ethernet service instance. |
Input Statistics |
Incoming packet statistics for the Ethernet service instance: · Octets—Number of incoming octets. · Packets—Number of incoming packets. · Errors—Number of incoming error packets. · Discards—Number of discarded incoming packets. |
Output Statistics |
Outgoing packet statistics for the Ethernet service instance: · Octets—Number of outgoing octets. · Packets—Number of outgoing packets. · Errors—Number of outgoing error packets. · Discards—Number of discarded outgoing packets. |
service-instance
Use display l2vpn xconnect-group to display cross-connect group information.
display l2vpn xconnect-group [ name group-name [ connection connection-name ] | evpn-srv6 | evpn-vpws | vpws ] [ count | verbose ]
name group-name: Displays information about a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive sting of 1 to 31 characters. If you do not specify a group, this command displays information about all cross-connect groups.
connection connection-name: Displays information about a cross-connect. The connection-name argument specifies the cross-connect name, a case-sensitive string of 1 to 20 characters excluding hyphens (-). If you do not specify a cross-connect, this command displays information about all cross-connects.
evpn-srv6: Displays information about cross-connect groups in the EVPN VPWS over SRv6 network. For more information about EVPN VPWS over SRv6, see EVPN VPWS over SRv6 configuration in Segment Routing Configuration Guide.
evpn-vpws: Displays information about cross-connect groups in the EVPN VPWS network.
vpws: Displays information about cross-connect groups in the MPLS L2VPN network. If you do not specify this keyword, the command displays information about all cross-connect groups.
count: Displays the number of cross-connect groups.
If you do not specify the evpn-srv6, evpn-vpws, or vpws keyword, this command displays information about all cross-connect groups.
# Display brief information about all cross-connect groups.
<Sysname> display l2vpn xconnect-group
Status Codes: UP - Up, DN - Down, DF - Defect, BD - Blocked, AD - Admin Down,
DL - Idle, DP - Duplicate
Total number of Xconnect-group: 1
Total number of cross-connections: 1, 1 up, 0 down, 0 admin down
Xconnect-group Connection ST
Segment1 ST Segment2 ST
1111 yyy UP
Static 192.2.2.2 5 UP Static 192.3.3.3 4 UP --------------------------------------------------------------------------------
# Display cross-connect group statistics.
<Sysname> display l2vpn xconnect-group count
Table 18 Command output
Total number of Xconnect-group |
Total number of cross-connect groups. |
ST |
Cross-connect state: · UP—The cross-connect is up. · DN—The cross-connect is down. · AD—The cross-connect has been shut down by using the shutdown command. |
Segment1 / Segment2 |
· PW information—PW establishment mode, IP address of the remote PE, and PW ID. · SRv6 tunnel information—SRv6 tunnel establishment mode and IP address of the remote PE. |
When this field displays the AC state, options include the following: · UP—The AC is up. · DN—The AC is down. · When this field displays the PW state, options include the following: · UP—The PW is up. · DN—The PW is down. · DF—BFD has detected faults on the PW. · BD—The PW is a backup PW and does not forward traffic. · DL—The incoming label of the PW is unavailable. · DP—The incoming label of the PW is the same as the incoming label of a static LSP, static CRLSP, or static SRLSP. |
# Display detailed information about all cross-connect groups.
<Sysname> display l2vpn xconnect-group verbose
Connection of auto-discovery: Site 1, Remote Site 2
Connection ID : 0
State : Up
MTU : 1500
Diffserv Mode : -
BGP PWs:
Peer Remote Site Link ID State Flag
192.3.3.3 2 0x10000001 Up Main
Create time: 2019-04-25 17:05:06
Last time status changed: 2019-04-25 17:05:06
Last time PW went down: 2019-04-25 17:05:06
ACs:
AC Link ID State
GE1/0/4 srv1 0x0 Up
Table 19 Command output
Description for the cross-connect group. If no description is configured, this field is not displayed. |
Connection Name |
Auto-discovery cross-connect. |
Site |
Local site ID. |
Remote site |
Remote site ID. |
Connection ID |
Cross-connect ID. |
State |
Cross-connect group state: Up, Down, or Admin down. Admin down indicates that the cross-connect group has been shut down by using the shutdown command. |
Create time |
Time when the PW was established. |
Last time status changed |
Time when the PW state most recently changed. |
Last time PW went down |
Time when the PW most recently went down. |
Statistics |
AC or PW statistics state: Enabled or Disabled. If AC or PW statistics is enabled, the following information is displayed: · Octets—Numbers of incoming and outgoing bytes. · Packets—Numbers of incoming and outgoing packets. · Errors—Numbers of incoming and outgoing error packets. · Discards—Numbers of discarded incoming and outgoing packets. |
PW Redundancy Mode |
PW redundancy operation mode: · Slave—Master/slave mode and the local PE operates as the slave node. · Master—Master/slave mode and the local PE operates as the master node. · Independent—Independent mode. |
Diffserv Mode |
DiffServ mode. Options include the following: · ingress—MPLS DiffServ mode for the inbound direction. · egress—MPLS DiffServ mode for the outbound direction. · pipe—Pipe mode. · short-pipe—Short-pipe mode. · uniform—Uniform mode · trust—Priority trust mode ¡ inner-dot1p—Trusts the inner 802.1p priority in packets. ¡ dscp—Trusts the DSCP in packets. af1, af2, af3, af4, be, cs6, cs7, or ef represents the MPLS EXP value. If no DiffServ mode is configured, this field displays a hyphen (-). |
Interworking IPv4 |
This field is not supported in the current software version. IPv4 interworking state: Enabled or Disabled. |
EVPN PWs |
This field is not supported in the current software version. |
Remote Service ID |
State |
PW state: Up, Down, Blocked, or Defect. |
Flag |
PW type: · Main—Primary PW. · BackUp—Backup PW. |
Statistics |
Whether AC or PW statistics collection is enabled: · Enabled. · Disabled. With statistics collection enabled, the device can collect statistics about octets, packets, errors, and discards. |
AC |
AC type: · Layer 3 interface. · Ethernet service instance on a Layer 2 interface. |
xconnect-group
encapsulation
Use encapsulation to configure a packet match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation untagged
undo encapsulation
No packet match criterion is configured for an Ethernet service instance.
Ethernet service instance view
s-vid vlan-id: Matches packets with the specified outer VLAN IDs and the specified inner VLAN IDs. The vlan-id argument specifies a VLAN ID in the range of 1 to 4094.
untagged: Matches any packets that do not have a VLAN tag.
An Ethernet service instance can contain only one match criterion. To modify the match criterion, execute the undo encapsulation command to remove the criterion and then execute the encapsulation command. When you remove the match criterion in an Ethernet service instance, the mapping between the Ethernet service instance and the cross-connect is removed automatically.
# Configure Ethernet service instance 1 on GigabitEthernet 1/0/1 to match packets that have an outer VLAN ID of 111.
[Sysname-GigabitEthernet1/0/1] service-instance 1
[Sysname-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before configuring other L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn log enable
Use l2vpn log enable to enable L2VPN logging.
Use undo l2vpn log enable to disable L2VPN logging.
l2vpn log enable
L2VPN logging is enabled.
This feature enables L2VPN to generate logs for running state changes. The generated logs are sent to the information center. The information center processes the logs according to user-defined output rules (whether to output logs and where to output).
For more information about the information center, see information center configuration in System Management Configuration Guide.
# Enable L2VPN logging.
[Sysname] l2vpn log enable
peer
Use peer to configure a PW for a cross-connect and enter cross-connect PW view, or enter the view of an existing cross-connect PW.
Use undo peer to delete a PW for a cross-connect.
peer ip-address pw-id pw-id [ ignore-standby-state | in-label label-value out-label label-value ]
undo peer ip-address pw-id pw-id
No PWs exist for a cross-connect.
Cross-connect view
ip-address: Specifies the LSR ID of the peer PE.
pw-id pw-id: Specifies a PW ID for the PW, in the range of 1 to 4294967295.
ignore-standby-state: Ignores the PW active/standby status bit received from the remote PE. If you do not specify this keyword, the local PE does not ignore the PW active/standby status bit received from the remote PE. This keyword is applicable only to LDP PWs.
in-label label-value: Specifies the incoming label of the PW in the range of 16 to 1023.
out-label label-value: Specifies the outgoing label of the PW, in the range of 16 to 1048575.
To create a static PW, you must specify the incoming and outgoing labels. To enter the view of an existing static PW, you do not need to specify the incoming and outgoing labels.
If you do not specify the incoming and outgoing labels when you create a new PW, LDP is used to create the PW.
The PW ID for a PW must be the same on the PEs at the ends of the PW.
On a PE, the LSR ID of the peer PE and the PW ID uniquely identify a PW. The peer LSR ID and PW ID combination of a PW must be unique among all VPLS PWs and cross-connect PWs.
# Configure an LDP PW destined for 4.4.4.4 for cross-connect pw2pw in cross-connect group vpn1 and enter cross-connect PW view. The PW ID is 200.
[Sysname-xcg-vpn1] connection pw2pw
[Sysname-xcg-vpn1-pw2pw] peer 4.4.4.4 pw-id 200
[Sysname-xcg-vpn1-pw2pw-4.4.4.4-200]
# Configure a static PW destined for 5.5.5.5 for cross-connect pw2pw in cross-connect group vpn1 and enter cross-connect PW view. The static PW has an ID of 200, an incoming label of 100, and an outgoing label of 200.
[Sysname-xcg-vpn1-pw2pw] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200
[Sysname-xcg-vpn1-pw2pw-5.5.5.5-200]
display l2vpn ldp
display l2vpn pw
peer signaling
Use peer signaling to enable BGP to exchange label block information with the specified peer or peer group.
Use undo peer signaling to disable BGP to exchange label block information with the specified peer or peer group.
peer { group-name | ip-address [ mask-length ] } signaling [ non-standard ]
undo peer { group-name | ip-address [ mask-length ] } signaling
BGP can exchange label block information with an L2VPN peer or peer group through RFC 4761 MP_REACH_NLRI.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must have been created.
ip-address: Specifies a peer by its IP address. The specified peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to exchange label block information with all dynamic peers in the subnet.
non-standard: Uses draft-kompella-ppvpn-l2vpn-03 MP_REACH_NLRI to exchange label block information. If you do not specify this keyword, RFC 4761 MP_REACH_NLRI is used to exchange label block information.
L2VPN uses MP-BGP to exchange label blocks when creating a BGP PW.
To enable BGP to exchange label blocks with the specified peers through RFC 4761 MP_REACH_NLRI, you can also use the peer enable command in BGP L2VPN address family view. To disable the capability, use the undo peer signaling command.
# Enable BGP to exchange label block information with the peer 3.3.3.9 through draft-kompella-ppvpn-l2vpn-03 MP_REACH_NLRI.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] peer 3.3.3.9 signaling non-standard
policy vpn-target
Use policy vpn-target to enable route target-based filtering of incoming BGP L2VPN information.
Use undo policy vpn-target to disable route target-based filtering of incoming BGP L2VPN information.
policy vpn-target
Route target-based filtering of incoming BGP L2VPN information is enabled.
If route target-based filtering is enabled, L2VPN accepts only the incoming BGP L2VPN information whose export route target attribute matches the local import route target attribute. If route target-based filtering is disabled, L2VPN accepts all incoming BGP L2VPN information.
To establish a BGP PW between two MP-IBGP peers that use a route reflector, you must disable route target-based filtering of incoming BGP L2VPN information on the route reflector.
# Disable route target-based filtering of incoming BGP L2VPN information.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] undo policy vpn-target
route-distinguisher
Use route-distinguisher to configure a route distinguisher (RD) for a BGP cross-connect group.
Use undo route-distinguisher to restore the default.
No RD is configured for a BGP cross-connect group.
Auto-discovery cross-connect group view
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. An RD can be in one of the following formats:
MPLS L2VPN uses RDs to differentiate the sites with the same site ID but in different VPNs.
BGP adds the configured RD before the site ID. The RD and the site ID uniquely identify a VPN site.
You cannot configure the same RD for different BGP cross-connect groups.
To modify an RD, execute the undo route-distinguisher command to remove the RD, and then execute the route-distinguisher command.
# Configure the RD 22:2 for BGP cross-connect group bbb.
[Sysname-xcg-bbb-auto] route-distinguisher 22:2
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
rr-filter { ext-comm-list-name | ext-comm-list-number }
undo rr-filter
An RR does not filter reflected L2VPN information.
ext-comm-list-name: Specifies an extended community list name, a case-sensitive string of 1 to 63 characters. The name cannot contain only digits.
ext-comm-list-number: Specifies an extended community list number in the range of 1 to 65535.
After this command is executed, only the L2VPN information that is permitted by the specified extended community list is reflected.
By configuring different RR reflection policies on RRs in a cluster, you can implement load balancing among the RRs.
For more information about extended community lists, see Layer 3—IP Routing Configuration Guide.
# Configure the RR to reflect only the BGP L2VPN information that is permitted by extended community list 10.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
service-instance
Use service-instance to create an Ethernet service instance on an interface and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance on an interface.
undo service-instance instance-id
No Ethernet service instances exist.
instance-id: Specifies an ID for the Ethernet service instance, in the range of 1 to 4096.
# Create Ethernet service instance 1 on Layer 2 Ethernet interface GigabitEthernet 1/0/1, and enter Ethernet service instance 1 view.
shutdown
Use shutdown to disable a cross-connect group.
Use undo shutdown to enable a cross-connect group.
shutdown
A cross-connect group is enabled.
After you disable a cross-connect group, all cross-connects in the group cannot provide L2VPN services.
Use the shutdown command when you want to temporarily disable L2VPN. When a cross-connect group is disabled, you can still configure the cross-connect group. After the configuration, use the undo shutdown command to enable the cross-connect group. The cross-connect group will provide L2VPN services using the new settings.
# Disable cross-connect group vpn2.
[Sysname-xcg-vpn2] shutdown
site
Use site to create a local site and enter its view, or enter the view of an existing local site.
Use undo site to delete a local site.
site site-id [ range range-value ] [ default-offset default-offset ]
undo site site-id
No sites exist.
site-id: Specifies a local site ID in the range of 0 to 256.
range range-value: Specifies the maximum number of sites in a VPN, in the range of 2 to 257. The default value is 10.
default-offset default-offset: Specifies the start site ID, 0 or 1. The default value is 0.
The range range-value and default-offset default-offset options determine the label block of the site.
· If you execute the site command with the range-value of range1, a label block with LR of range1 and LO of default-offset is assigned to the site.
· If you execute another site command with range-value of range2 (range2 is larger than range1), a second label block with LR of range2 to range1 and LO being range1 + default-offset is assigned to the site.
For example, if you execute the following commands, three label blocks LB1/0/10, LB2/10/12, and LB3/22/14 are assigned to site 1. LB1, LB2, and LB3 are automatically selected.
site 1 range 22
site 1 range 36
You can create multiple local sites for a cross-connect group.
You can use the site command to increase the range value for an existing site. You cannot decrease the range value for an existing site with the site command. To decrease the range value, execute the undo site command to delete the site and then execute the site command.
Select a large range value to reduce future modifications for VPN expansion.
You cannot modify the default-offset for a site with the site command. To modify it, execute the undo site command to delete the site and then execute the site command.
# Create site 1, configure the VPN to contain a maximum of 30 sites, set the start site ID to 0 for cross-connect group bbb, and enter site view.
[Sysname-xcg-bbb-auto] site 1 range 30 default-offset 0
display l2vpn pw
snmp-agent trap enable l2vpn
Use snmp-agent trap enable l2vpn to enable SNMP notifications for L2VPN PW.
Use undo snmp-agent trap enable l2vpn to disable SNMP notifications for L2VPN PW.
snmp-agent trap enable l2vpn [ maclimit-ac | maclimit-pw | maclimit-vsi | pw-delete | pw-up-down ] *
undo snmp-agent trap enable l2vpn [ maclimit-ac | maclimit-pw | maclimit-vsi | pw-delete | pw-up-down ] *
SNMP notifications for L2VPN PW are disabled.
maclimit-ac: maclimit-ac: Enables the system to generate notifications when the number of MAC addresses learned by an AC reaches the limit.
maclimit-pw: Enables the system to generate notifications when the number of MAC addresses learned by a PW reaches the limit.
maclimit-vsi: Enables the system to generate notifications when the number of MAC addresses learned by a VSI reaches the limit.
pw-delete: Enables PW deletion notifications.
pw-up-down: Enables PW up-down notifications.
This feature enables L2VPN to generate SNMP notifications when the number of MAC addresses learned by an AC/PW/VSI reaches the limit, PW deletion, or PW status change occurs. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
If you do not specify a notification type, this command enables all types of notifications for L2VPN PW.
# Enable PW up-down notifications.
[Sysname] snmp-agent trap enable l2vpn pw-up-down
display snmp-agent trap-list (Network Management and Monitoring Command Reference)
vpn-target
Use vpn-target to configure route targets for a cross-connect group.
Use undo vpn-target to remove the specified or all route targets for a cross-connect group.
undo vpn-target { vpn-target&<1-8> | all } [ both | export-extcommunity | import-extcommunity ]
No route targets are configured for a cross-connect group.
vpn-target&<1-8>: Specifies a space-separated list of a maximum of eight route targets.
A route target is a string of 3 to 21 characters in one of the following formats:
both: Uses the specified route targets as both import targets and export targets. The both keyword is used when you do not specify any of both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
A local PE sets the route targets as export targets in BGP update messages when it advertises L2VPN information through the update messages to a remote peer. The peer uses its import targets to match the received export targets. If a match is found, the peer accepts the L2VPN information.
You can repeat the vpn-target command to configure multiple route targets for a cross-connect group.
# Configure import route targets as 10:1 100:1 1000:1 and export route targets as 20:1 200:1 2000:1 for BGP cross-connect group bbb.
[Sysname] xconnect-group bbb
[Sysname-xcg-bbb] auto-discovery bgp
[Sysname-xcg-bbb-auto] vpn-target 10:1 100:1 1000:1 import-extcommunity
[Sysname-xcg-bbb-auto] vpn-target 20:1 200:1 2000:1 export-extcommunity
xconnect-group
Use xconnect-group to create a cross-connect group and enter its view, or enter the view of an existing cross-connect group.
Use undo xconnect-group to delete a cross-connect group.
undo xconnect-group group-name
No cross-connect groups exist.
group-name: Specifies a name for the cross-connect group, a case-sensitive string of 1 to 31 characters excluding hyphens.
L2VPN can create multiple LDP, BGP, and static PWs for a cross-connect group.
# Create a cross-connect group named vpn1 and enter cross-connect group view.
[Sysname] xconnect-group vpn1
[Sysname-xcg-vpn1]
