08-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5580X-EI[HI] & S5580S-EI Switch Series Command References-R1330Pxx-6W10008-Layer 3—IP Routing Command Reference
08-Policy-based routing commands
08-Policy-based routing commands 170.35 KB
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] }&<1-2>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No default next hops are set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ip-address: Specifies the IP address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
service-chain path-id service-path-id: Specifies a service chain by its path ID. A path ID uniquely identifies a service chain, and its value range is 1 to 16777215.
path-index service-path-index: Specifies a node in the service chain as a default next hop by its index in the range of 1 to 255.
&<1-2>: Indicates that you can repeat the previous group of parameters to configure up to two default next hops.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
To set multiple default next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
·     If the next hops are used in different service chains, use the apply default-next-hop command to specify the service chain parameters.
·     If the next hops are used in the same service chain, use the apply service-chain command to specify the service chain parameters as a best practice.
·     On a policy node, you cannot configure both the apply default-next-hop command with the service chain parameters and the apply service-chain command.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 direct
apply loadshare
apply service-chain
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops or default next hops.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | next-hop }
undo apply loadshare { default-next-hop | next-hop }
Multiple next hops or default next hops operate in primary/backup mode.
Policy node view
default-next-hop: Enables load sharing among multiple default next hops.
next-hop: Enables load sharing among multiple next hops.
Multiple next hop or default next hop options operate in either primary/backup or load sharing mode.
·     Primary/backup mode—A next hop is selected from all next hops in configuration order for packet forwarding, with all remaining next hops as backups. When the selected next hop fails, the next available next hop takes over.
·     Load sharing mode—Matching traffic is distributed across the available next hops. If the traffic does not match any fast forwarding entries, per-packet load sharing is performed. If the traffic matches a fast forwarding entry, per-flow load sharing is performed.
# Enable load sharing among multiple next hops.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare next-hop
# Enable load sharing among multiple default next hops.
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare default-next-hop
apply next-hop
apply mirror-to-destination
Use apply mirror-to-destination to set a mirroring action that mirrors packets to the specified destination IP address.
Use undo apply mirror-to-destination to restore the default.
apply mirror-to-destination [ vpn-instance vpn-instance-name ] destination-ip-address [ source-ip source-ip-address ] [ dscp dscp-value ]
undo apply mirror-to-destination [ vpn-instance vpn-instance-name ] destination-ip-address
The mirroring action is not set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist. If the destination IP address belongs to the public network, do not specify this option.
destination-ip-address: Specifies the destination IP address encapsulated in the outer header of mirrored packets.
source-ip source-ip-address: Specifies the source IP address encapsulated in the outer header of mirrored packets. If you do not specify this option, the primary IP address for the output interface of the mirrored packets is encapsulated.
dscp dscp-value: Specifies the DSCP value encapsulated in the outer header of mirrored packets. The value range for the dscp-value argument is 0 to 63, and the default value is 63.
This command enables the device to mirror packets to a specific destination device through a tunnel (for example, a GRE tunnel) for packet analysis and monitoring. The device will encapsulate the parameters set for this command in the outer header of the mirrored packets.
This apply clause is always executed for packets matching the policy node in either permit or deny mode.
# Set a mirroring action by specifying source IP address 2.2.2.2 and destination IP address 1.1.1.1 in the outer header of mirrored packets.
[Sysname-pbr-aa-11] apply mirror-to-destination 1.1.1.1 source-ip 2.2.2.2
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] }&<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No next hops are set.
Policy node view
ip-address: Specifies the IP address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
path-index service-path-index: Specifies a node in the service chain as a next hop by its index in the range of 1 to 255.
&<1-2>: Indicates that you can repeat the previous group of parameters to configure up to two next hops.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
To set multiple next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
·     If the next hops are used in different service chains, use the apply next-hop command to specify the service chain parameters.
·     On a policy node, you cannot configure both the apply next-hop command with the service chain parameters and the apply service-chain command.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply loadshare
apply service-chain
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { NULL 0 }
undo apply output-interface [ NULL 0 ]
No output interfaces are set.
Policy node view
NULL 0: Specifies interface Null 0 as the output interface.
# Specify interface Null 0 as the output interface for IP packets.
[Sysname-pbr-aa-11] apply output-interface NULL 0
apply service-chain
Use apply service-chain to set the service chain information.
Use undo apply service-chain to restore the default.
apply service-chain path-id service-path-id [ path-index service-path-index ]
No service chain information is set.
Policy node view
path-id service-path-id: Specifies a service chain by its path ID in the range of 1 to 16777215. The path ID uniquely identifies a service chain.
path-index service-path-index: Specifies the path index of the node to which you are sending the matching packets. The value range for path indexes is 1 to 255. Specify this option if the destination node might receive packets from different nodes in the service chain. If the destination node receives packets only from the device, you do not need to specify this option.
# Set service chain path ID 1 and node index 10.
[Sysname] policy-based-route aa permit node 5
[Sysname-pbr-aa-5] apply service-chain path-id 1 path-index 10
apply statistics
Use apply statistics to enable successful matches counting on a policy node.
Use undo apply statistics to restore the default.
apply statistics
Match counting is disabled on a policy node.
Policy node view
To include the number of successful matches and matching bytes on a policy node in the statistics displayed by a display command, execute this command. As a best practice to conserve hardware resources, disable this counting function.
This apply clause is always executed for the policy node.
# Enable match counting on policy node 11.
[Sysname-pbr-aa-11] apply statistics
description
Use description to configure a description for a policy node.
No description is configured for a policy node.
Policy node view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for policy node 1.
[Sysname] policy-based-route 1 permit node 1
[Sysname-pbr-1-1] description Officeuse
display ip policy-based-route
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
policy-based-route
display ip policy-based-route global
Use display ip policy-based-route global to display information about global PBR, including its configuration and statistics.
display ip policy-based-route global [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about global PBR on the master device.
# Display information about global PBR.
<Sysname> display ip policy-based-route global
Global policy-based routing information:
Policy name: aaa
  node 0 deny:
  Matches: 0, bytes: 0
  node 1 permit:
    if-match acl 3999
  node 2 permit:
    if-match acl 2000
    apply next-hop 2.2.2.2
  node 5 permit:
    if-match acl 3101
Total matches: 0, total bytes: 0
Global PBR configuration and statistics.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy and then apply it again.
node 0 deny
node 2 permit
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·     not support—The device does not support the match criteria configured on the node.
·     no resource—No sufficient resources (for example, ACLs) are available for the node.
if-match acl
apply next-hop
Matches
Number of successful matches on the node.
If the device does not support counting successful matches on a node, this field displays N/A.
If match counting is disabled on the node, this field is not displayed.
If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
bytes
Number of matching bytes on the node.
This field displays N/A if the device does not support counting matching bytes on a node.
This field is not displayed if match counting is disabled on the node.
Total matches
Total number of successful matches on all nodes.
This field displays N/A if the device does not support counting successful matches on a node.
This field is not displayed if match counting is disabled on all nodes.
total bytes
Total number of matching bytes on all nodes.
ip global policy-based-route
display ip policy-based-route interface
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information on the master device.
# Display PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ip policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-interface2:
Policy name: aaa
  node 0 deny:
  node 1 permit:
    if-match acl 3999
  node 2 permit:
    if-match acl 2000
  node 5 permit:
    if-match acl 3101
Policy based routing information for interface XXXX
PBR configuration and statistics on the interface.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·     For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·     For a physical interface, specify its slot number.
node 0 deny
node 2 permit
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
apply next-hop
Matches
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
bytes
Total matches
total bytes
display ip policy-based-route local
Use display ip policy-based-route local to display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays local PBR configuration and statistics for the master device.
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  node 1 permit:
    if-match acl 3999
  node 2 permit:
    if-match acl 2000
  node 5 permit:
    if-match acl 3101
Local PBR configuration and statistics.
node 0 deny/node 2 permit
Match mode of the node: permit or deny.
if-match acl
apply next-hop
Matches
bytes
Total matches
total bytes
ip local policy-based-route
display ip policy-based-route setup
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy name              Type     Interface
pr01                     Forward  Vlan-interface2
aaa                      Egress   Tunnel1
aaa                      Local    N/A
abc                      Global   N/A
Table 5 Command output
Type of the PBR:
·     Forward—Interface PBR.
·     Local—Local PBR.
·     Global—Global PBR.
Interface where the policy is applied.
This field displays N/A for local and global PBR.
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
If the specified ACL does not exist or has no rules configured, no packets will match the ACL.
You cannot specify the vpn-instance keyword for any rules in the ACL specified in this command.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
if-match service-chain
Use if-match service-chain to set a service chain match criterion.
Use undo if-match service-chain to restore the default.
if-match service-chain { path-id service-path-id [ path-index service-path-index ] }
undo if-match service-chain [ path-id service-path-id ] ]
No service chain match criteria are set.
Policy node view
path-index service-path-index: Specifies a node in the service chain by its index to match packets sent from that node. The value range for path indexes is 1 to 255. Specify this option if the device might receive packets from different nodes in the service chain. If only one node in the service chain sends packets to the device, you do not need to specify this option.
# Set a service chain match criterion to match packets with service chain path ID 1 and node index 10.
[Sysname-pbr-aa-5] if-match service-chain path-id 1 path-index 10
Use ip global policy-based-route to specify a PBR policy as the global PBR policy.
Use undo ip global policy-based-route to restore the default.
ip global policy-based-route policy-name
No policy is specified for global PBR.
policy-name: Specifies a PBR policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Global PBR guides the forwarding of packets on all interfaces of the device.
You can specify only one policy for global PBR on the device. Before you apply a new policy, you must first remove the current policy.
Interface PBR takes precedence over global PBR on an interface. When they are both configured and packets fail to match the interface PBR policy, global PBR applies.
# Specify PBR policy aaa for global PBR.
[Sysname] ip global policy-based-route aaa
ip ignore policy-based-route dest-local enable
Use ip ignore policy-based-route dest-local enable to enable PBR to ignore IPv4 packets destined to the local interface.
Use undo ip ignore policy-based-route dest-local enable to restore the default.
PBR does not ignore IPv4 packets destined to the local interface.
Interface view
If the device performs forwarding in hardware and a packet destined for it matches a PBR policy, PBR will execute the apply clauses in the policy, including the clause for forwarding. To prevent PBR from mistakenly forwarding the packet to another device, you can configure this command in interface view. Upon receiving a packet destined to any IPv4 addresses (main or secondary) of the interface, the device will ignore PBR settings and deliver the packet to the CPU.
# Enable PBR to ignore IPv4 packets destined to local interface VLAN-interface 2.
[Sysname-Vlan-interface2] ip ignore policy-based-route dest-local enable
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is referenced for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ip policy-based-route aaa
ip policy-based-route-log enable
Use ip policy-based-route-log enable to enable the PBR logging feature.
Use undo ip policy-based-route-log enable to disable the PBR logging feature.
The PBR logging feature is disabled.
The PBR logging feature helps the administrator locate and fix faults. The feature logs PBR events and sends the logs to the information center. The information center processes the logs according to output rules. For more information about the information center, see System Management Configuration Guide.
Excessive PBR log messages degrade the performance of the device. To avoid this problem, disable the PBR logging feature.
# Enable the PBR logging feature.
[Sysname] ip policy-based-route-log enable
ip policy-based-route vxlan-mode enable
Use ip policy-based-route vxlan-mode enable to enable VXLAN-mode PBR.
Use undo ip policy-based-route vxlan-mode enable to disable VXLAN-mode PBR.
VXLAN-mode PBR is disabled.
VXLAN-mode PBR enables you to guide packets from a site-facing interface on a VXLAN VTEP to a VXLAN tunnel by using a PBR policy. If VXLAN-mode PBR is not enabled, the PBR policy on a site-facing interface cannot guide packets to a VXLAN tunnel.
Execute this command before you apply a PBR policy to a site-facing interface. This command requires updating forwarding entries, which is time-consuming and might cause inadequate table entry resources.
# Enable VXLAN-mode PBR.
[Sysname] ip policy-based-route vxlan-mode enable
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535. You can configure a maximum of 256 nodes for a policy.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
·     If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
·     If a match mode is specified, the command deletes all nodes configured with the match mode.
·     If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10]
reset ip policy-based-route statistics
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
