13-Voice Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10213-Voice Command Reference
04-SIP commands
04-SIP commands 392.29 KB
SIP commands
The following compatibility matrixes show the support of hardware platforms for SIP:
Hardware
SIP compatibility
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G, MSR1004S-5G-CN
No
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL
No
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
No
MSR3600-28-G-DP, MSR3600-51-G-DP
No
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR-iMC
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
No
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
SIP compatibility
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3620-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
SIP compatibility
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
SIP compatibility
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
To support SIP, some device models require the Voice Software License. For more information, see license management in Fundamentals Configuration Guide.
address sip
Use address sip to configure a call destination IP address for a VoIP entity.
Use undo address sip to restore the default.
address sip { dns domain-name port port-number | ip ip-address [ port port-number ] | proxy }
undo address sip { dns | ip | proxy }
No call destination IP address exists.
VoIP entity view
dns domain-name: Specifies a destination domain name, which consists of case-insensitive strings separated by a dot (for example, aabbcc.example.com). Each separated string contains no more than 63 characters. A domain name can include letters, digits, hyphens (-), and underscores (_), and has a maximum length of 253 characters.
port port-number: Specifies a destination port by its port number in the range of 1 to 65535. If the ip keyword is specified, the default port number is 5060 for TCP and UDP and 5061 for TLS. If the dns keyword is specified, the destination port number must be configured.
ip ip-address: Specifies a destination IP address.
proxy: Contacts the SIP proxy server to obtain the destination IP address.
# Configure the call destination IP address as 3.3.3.3 for VoIP entity 10.
[Sysname] voice-setup
[Sysname-voice] dial-program
[Sysname-voice-dial] entity 10 voip
[Sysname-voice-dial-entity10] address sip ip 3.3.3.3
asserted-id
Use asserted-id to add the P-Asserted-Identity or P-Preferred-Identity header field to outgoing SIP messages.
Use undo asserted-id to restore the default.
asserted-id { pai | ppi }
undo asserted-id
Outgoing SIP messages do not carry the P-Asserted-Identity or P-Preferred-Identity header field in outgoing SIP messages.
SIP view
pai: Adds the P-Asserted-Identity header field to outgoing SIP messages.
ppi: Adds the P-Preferred-Identity header field to outgoing SIP messages.
# Add the P-Asserted-Identity header field to outgoing SIP messages.
[Sysname-voice] sip
[Sysname-voice-sip] asserted-id pai
bind
Use bind to configure global source interface binding for outbound SIP messages or media packets.
Use undo bind to restore the default.
bind { control | media } source-interface interface-type interface-number
undo bind { control | media }
The egress interface is used as the source interface of outbound SIP messages or media packets.
SIP view
control: Specifies outbound SIP messages.
media: Specifies outbound media packets.
source-interface interface-type interface-number: Uses the specified interface as the source interface of outbound SIP messages or media packets. The specified interface must be a Layer 3 Ethernet interface, VLAN interface, loopback interface, or dialer interface.
The following table describes how source interface binding works in different conditions:
Condition
Result
Configure a new source interface when ongoing calls exist.
·     The new source interface takes effect for new SIP media sessions but does not take effect for existing SIP media sessions.
·     The new source interface immediately takes effect for all SIP signaling sessions.
The bound source interface is shut down.
The source interface binding does not take effect, and the default setting is restored.
The IP address of the bound source interface or the bound source interface is removed.
The physical or link layer state of the bound interface is down.
The bound source interface obtains a new IP address from the DHCP or PPPoE server.
The new IP address is used as the source IP address.
Configure a new source interface during SIP registration.
The new source interface takes effect for new registrations.
You can configure source interface binding both globally (by using the bind command in SIP view) and for a specific VoIP entity (by using the voice-class sip bind command in VoIP entity view). The configuration in VoIP entity view takes precedence over the global configuration. A VoIP entity uses the global configuration only when source interface binding is not configured in VoIP entity view.
If the specified source interface does not have an IP address or its IP address is invalid, the device uses the default configuration.
# Specify Dialer 0 as the source interface for outbound SIP messages.
[Sysname-voice] sip
[Sysname-voice-sip] bind control source-interface dialer 0
crypto
Use crypto to configure an SSL client or server policy to be used by TLS.
Use undo crypto to delete the SSL client or server policy used by TLS.
crypto { ssl-client-policy client-policy-name | ssl-server-policy server-policy-name }
undo crypto { server-policy | client-policy }
No SSL client or server policy is configured for TLS.
SIP view
ssl-client-policy client-policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
ssl-server-policy server-policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters.
To enable the device to receive TLS requests, specify the SSL client and server policies to be used by TLS and then enable the TLS listening port by using the transport command.
You must disable the TLS listening port before you can use a new SSL server policy or modify the configuration of the existing SSL server policy.
If you use a new SSL client policy or modify the configuration of the existing SSL client policy, the new policy applies only to new TLS connections. Existing TLS connections still use the original SSL client policy.
# Configure TLS to use the SSL server policy named Server1 and the SSL client policy named Server2.
[Sysname-voice] sip
[Sysname-voice-sip] crypto ssl-server-policy Server1
[Sysname-voice-sip] crypto ssl-client-policy Server2
transport
display voice ip address trusted list
Use display voice ip address trusted list to display the trusted node list.
This command displays trusted nodes configured by using the ip command and call destination IP addresses configured by using the address sip command.
# Display the trusted node list.
<Sysname> display voice ip address trusted list
IP address trusted authentication: Enabled
VoIP entity IP addresses:
Entity tag      State    SIP IP address
20              Up       192.168.4.110
53232           Down     192.168.4.210
55555           Up       192.168.4.210
9613            Up       192.168.4.125
IP address trusted list:
 192.168.4.0 255.255.255.0
 192.168.5.120 255.255.255.255
Whether IP address trusted authentication is enabled:
·     Enabled.
·     Disabled.
Trusted IP addresses for VoIP entities.
Entity tag
Tag of a VoIP entity.
Status of a VoIP entity:
·     Up.
·     Down.
SIP IP address
Call destination IP address of a VoIP entity.
List of trusted nodes.
address sip
ip
ip address trusted authenticate
display voice sip call
Use display voice sip call to display information about SIP calls.
# Display information about SIP calls.
<Sysname> display voice sip call
SIP UAC Call Information
Call 1
   Call ID: [email protected]
   Call status: Connected
   Calling number: 77201
   Called number: 30
   Control block ID: 8
   Local IP address: 200.1.1.36: 5060
   Remote IP address: 200.1.1.30: 5060
Media stream
   Media status: Send and receive
   Negotiated codec: g729r8
   Codec payload type: 18
   Codec payload size: 30
   Codec transparent: Disabled
   Media mode: Flow-through
   Negotiated DTMF-relay: Inband-voice
   Local IP address: 200.1.1.36: 16316
   Remote IP address: 200.1.1.30: 16642
Number of SIP UAC calls: 1
Call status
Call status:
·     Originating.
·     Answering.
·     Connected.
·     Releasing.
Local IP address
Source IP address and port number for SIP messages.
Remote IP address
Destination IP address and port number for SIP messages.
Negotiated codec
Negotiated codec:
·     g711alaw.
·     g711ulaw.
·     g723r53.
·     g723r63.
·     g726r16.
·     g726r24.
·     g726r32.
·     g726r40.
·     g729a.
·     g729br8.
·     g729r8.
This field displays N/A if codec negotiation fails or no codec is used.
Media status
Media status:
·     Send and receive.
·     Send only.
·     Receive only.
·     Inactive.
·     None.
Media mode
Whether media flow around is enabled:
·     Flow-around—Enabled.
·     Flow-through—Disabled.
Negotiated type of DTMF signaling:
·     Inband-voice—Inband DTMF signaling.
·     Outband-SIP—SIP mode for out-of-band DTMF signaling.
·     Outband-NTE—NTE mode for out-of-band DTMF signaling.
Number of SIP calls initiated by the device that acts as a UAC.
Number of SIP UAS calls
Number of SIP calls initiated by the device that acts as a UAS.
display voice sip connection
Use display voice sip connection to display information about SIP connections.
display voice sip connection { tcp | tls }
tcp: Specifies TCP connections.
tls: Specifies TLS connections.
This command displays information about established SIP connections and SIP connections that are being established.
# Display information about TCP connections.
<Sysname> display voice sip connection tcp
Conn-Id  Local-IP         Local-Port  Remote-IP        Remote-Port      Conn-State
 569      100.1.1.84       1593       100.1.1.100       5060            Established
 570      100.1.1.84       1594       100.1.1.101       5060            Established
 571      100.1.1.84       1595       100.1.1.81        5060            Established
 572      192.168.0.82     1596       192.168.0.81      5060            Established
# Display information about TLS connections.
<Sysname> display voice sip connection tls
 73       192.168.0.202    1086       192.168.0.132     5061            Established
Conn-Id
Connection ID.
Conn-State
Connection state:
·     Connecting.
·     Established.
reset voice sip connection
display voice sip map
Use display voice sip map to display mappings between PSTN causes and SIP status.
display voice sip map { pstn-sip | sip-pstn }
pstn-sip: Displays PSTN cause-to-SIP status mappings.
sip-pstn: Displays SIP status-to-PSTN cause mappings.
# Display PSTN cause-to-SIP status mappings.
<Sysname> display voice sip map pstn-sip
 The PSTN Cause to SIP Status code mapping table:
 Index       PSTN-Cause     SIP-Status     Default
  1              1            400*           404
  2              2            400*           404
  3              3            404            404
  4             16            ---            ---
  5             17            486            486
  6             18            408            408
  7             19            480            480
  8             20            480            480
  9             21            403            403
 10             22            410            410
 11             23            410            410
 12             25            500            500
 13             26            404            404
 14             27            502            502
 15             28            484            484
 16             29            501            501
 17             31            480            480
 18             34            503            503
 19             38            503            503
 20             41            503            503
 21             42            503            503
 22             47            503            503
 23             55            403            403
 24             57            403            403
 25             58            503            503
 26             63            500            500
 27             65            488            488
 28             70            488            488
 29             79            501            501
 30             87            403            403
 31             88            503            503
 32            102            504            504
 33            111            500            500
 34            127            500            500
PSTN-Cause
PSTN cause code.
SIP-Status
SIP status code.
If the configured SIP status code is different from the default, it is highlighted with an asterisk.
Default SIP status code.
# Display SIP status-to-PSTN cause mappings.
<Sysname> display voice sip map sip-pstn
 The SIP Status code to PSTN Cause mapping table:
 Index       SIP-Status     PSTN-Cause     Default
  1            400             41             41
  2            401             21             21
  3            402             21             21
  4            403             21             21
  5            404              1              1
  6            405             63             63
  7            406             79             79
  8            407             21             21
  9            408            102            102
 10            410             22             22
 11            413            127            127
 12            414            127            127
 13            415             79             79
 14            416            127            127
 15            420            127            127
 16            421            127            127
 17            423            127            127
 18            480             18             18
 19            481             41             41
 20            482             25             25
 21            483             25             25
 22            484             28             28
 23            485              1              1
 24            486             17             17
 25            487            127            127
 26            488            127            127
 27            500             41             41
 28            501             79             79
 29            502             38             38
 30            503             41             41
 31            504            102            102
 32            505            127            127
 33            513            127            127
 34            600             17             17
 35            603             21             21
 36            604              1              1
 37            606             58             58
Table 5 Command output
SIP-Status
SIP status code.
PSTN-Cause
PSTN cause code.
If the configured PSTN cause code is different from the default, it is highlighted with an asterisk.
Default PSTN cause code.
display voice sip register-status
Use display voice sip register-status to display SIP UA registration status information.
# Display SIP UA registration status information.
<Sysname> display voice sip register-status
Number                          Entity     Registrar Server      Expires Status
98                              98         192.168.4.240:5060    N/A     Offline
1000                            0          192.168.4.240:5060    2877    Online
Table 6 Command output
Number
Phone number.
Entity
Entity number. This field displays 0 if a SIP trunk account is configured by using the credentials command.
Registrar Server
Address of the registrar.
Expires
Aging time for the phone number, in seconds. This field displays N/A if the phone number is registering or fails to register.
Status
State of the phone number:
·     Offline.
·     Online.
·     Login.
·     Logout.
·     DNS-in—DNS query is being performed before the number is registered.
·     DNS-out—DNS query is being performed before the number is deregistered.
early-media enable
Use early-media enable to enable early media negotiation.
Use undo early-media enable to disable early media negotiation.
early-media enable
Early media negotiation is enabled.
SIP view
If this feature is enabled, the terminating device sends a 183 session progress response with media information to the originating device after receiving the request to establish a call. If this feature is disabled, the device sends a 180 ringing response without media information to the originating device.
# Enable early media negotiation.
[Sysname-voice] sip
[Sysname-voice-sip] early-media enable
ip
Use ip to specify a trusted node.
Use undo ip to delete trusted nodes.
ip ipv4-address [ mask ]
undo ip ipv4-address [ mask ]
No trusted nodes exist.
Trusted node list view
ipv4-address: Specifies a trusted node by its IPv4 address.
mask: Specifies the mask of the IPv4 address. If you do not specify a mask, the 32-bit mask is used.
# Specify the devices on subnet 1.1.1.0/24 as trusted nodes.
[Sysname-voice] sip-server
[Sysname-voice-server] trusted-point ipv4 100.1.1.125
Use ip address trusted authenticate to enable IP address trusted authentication.
Use undo ip address trusted authenticate to disable IP address trusted authentication.
IP address trusted authentication is disabled. All nodes are regarded as trusted, and the device accepts calls from any nodes.
View
SIP view
After you enable this feature, the device accepts calls only from trusted nodes.
For calls to be successfully established, configure the proxy server, registrars, the DNS server, and the MWI server as trusted nodes.
# Enable IP address trusted authentication.
[Sysname-voice] sip
[Sysname-voice-sip] ip address trusted authenticate
Use ip address trusted list to enter trusted node list view.
Use undo ip address trusted list to restore the default.
No trusted node list exists.
SIP view
# Enter trusted node list view
[Sysname-voice] sip
[Sysname-voice-sip] ip address trusted list
[Sysname-voice-sip-iptrust-list]
ip qos dscp
Use ip qos dscp to set the global DSCP value for IP packets carrying media streams or signaling.
Use undo ip qos dscp to restore the default.
ip qos dscp { dscp-value | dscp-value-set } { media | signaling }
undo ip qos dscp { dscp-value | dscp-value-set } { media | signaling }
The DSCP value for IP packets is ef (101110).
SIP view
dscp-value: Specifies a DSCP value in the range of 0 to 63.
dscp-value-set: Specifies a DSCP value, which can be the keyword af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, or ef.
media: Applies the DSCP value to IP packets carrying media streams.
signaling: Applies the DSCP value to IP packets carrying signaling.
Table 7 DSCP values
Keyword
DSCP value in binary
DSCP value in decimal
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
You can configure the ip qos dscp command both globally (in SIP view) and for a specific POTS/VoIP entity (in POTS/VoIP entity view). The configuration in POTS/VoIP entity view takes precedence over the global configuration. A POTS/VoIP entity uses the global configuration only when the ip qos dscp command is not configured in POTS/VoIP entity view.
# Set the global DSCP value to af41 for IP packets carrying signaling.
[Sysname-voice] sip
[Sysname-voice-sip] ip qos dscp af41 signaling
ip qos dscp (VoIP/POTS entity view)
min-se
Use min-se to set the maximum and minimum session expiration timers.
Use undo min-se to restore the default.
min-se time [ session-expires interval ]
undo min-se
Both the maximum and minimum session expiration timers are 1800 seconds.
SIP view
time: Specifies the minimum session expiration time in the range of 90 to 65535 seconds. The minimum session expiration time cannot be greater than the maximum session expiration time.
session-expires interval: Specifies the maximum session expiration time in the range of 90 to 65535 seconds. The default maximum session expiration time equals the minimum session expiration time.
You can use this command to set the values of the Min-SE and Session-Expires header fields on a UAC. If you execute this command on a UAS, only the Min-SE header field is set because the UAS copies the Session-Expires header field from the request to the response.
# Set the minimum session expiration time to 1000 seconds and the maximum session expiration time to 2000 seconds.
[Sysname-voice] sip
[Sysname-voice-sip] min-se 1000 session-expires 2000
session refresh
mki
Use mki to enable support for the Master Key Identifier (MKI) field and set the length of the MKI field.
Use undo mki to restore the default.
mki mki-length
undo mki
The MKI field is not supported.
SIP view
mki-length: Specifies the length of the MKI field, in the range of 1 to 128 bytes.
This command enables the device to add the MKI field to outgoing SRTP and SRTCP packets and to identify the MKI field in incoming SRTP and SRTCP packets.
This command takes effect only when SRTP is the media stream protocol for SIP calls. To specify SRTP as the medial stream protocol for SIP calls, use the srtp command.
For SIP calls to be established, configure this command on both the originating and terminating devices.
# Enable support for the MKI field and set the length of the MKI field to 1 byte.
[Sysname-voice] sip
[Sysname-voice-sip] srtp
[Sysname-voice-sip] mki 1
srtp
options-ping
Use options-ping to globally enable in-dialog keepalive.
Use undo options-ping to globally disable in-dialog keepalive.
options-ping seconds
undo options-ping
In-dialog keepalive is disabled globally.
View
SIP view
Predefined use roles
seconds: Specifies the global interval for sending OPTIONS messages during a session, in the range of 60 to 1200 seconds.
This command enables the device to periodically send OPTIONS messages at the specified interval to monitor the status of the remote SIP UA during a session. It does not take effect when the session refresh negotiation succeeds before a call is established.
If you disable this feature, the device does not send OPTIONS messages after a call is established.
For a VoIP entity, the entity-specific in-dialog keepalive interval takes priority over the global in-dialog keepalive interval set in SIP view.
Example
# Globally enable in-dialog keepalive and set the interval to 60 seconds for sending OPTIONS messages during a session.
[Sysname-voice] sip
[Sysname-voice-sip] options-ping 60
voice-class sip options-ping
outband sip
Use outband sip to enable out-of-band DTMF signaling.
Use undo outband sip to restore the default.
outband sip
undo outband
Inband DTMF signaling is enabled.
POTS entity view
VoIP entity view
If you use out-of-band DTMF signaling, configure the outband sip command on both the calling and called devices.
# Enable out-of-band DTMF signaling for VoIP entity 10.
[Sysname-voice-dial] entity 10 pots
[Sysname-voice-dial-entity10] outband sip
privacy
Use privacy to add the Privacy header field to outgoing INVITE requests.
Use undo privacy to restore the default.
privacy
undo privacy
Outgoing INVITE requests do not include the Privacy header field.
SIP view
# Add the Privacy header field to outgoing INVITE requests.
[Sysname-voice] sip
[Sysname-voice-sip] privacy
proxy
Use proxy to specify a proxy server.
Use undo proxy to restore the default.
proxy { dns domain-name port port-number | ip ip-address [ port port-number ] }
undo proxy { dns | ip }
No proxy servers are specified.
SIP view
dns domain-name: Specifies the domain name of the proxy server, which consists of case-insensitive strings separated by a dot (for example, aabbcc.example.com). Each separated string contains no more than 63 characters. A domain name can include letters, digits, hyphens (-), and underscores (_), and has a maximum length of 253 characters.
ip ip-address: Specifies the IPv4 address of the proxy server.
port port-number: Specifies the port number of the proxy server, in the range of 1 to 65535. If the ip keyword is specified, the default port number is 5060. If the dns keyword is specified, the destination port number must be configured.
# Specify the proxy server with IP address 169.54.5.10 and port number 1120.
[Sysname-voice] sip
[Sysname-voice-sip] proxy ipv4 169.54.5.10 port 1120
# Specify the proxy server with the domain name abc.example.com and port number 1100.
[Sysname-voice] sip
[Sysname-voice-sip] proxy dns abc.example.com port 1100
register-number
Use register-number to configure a POTS entity to register the phone number with the registrar.
Use undo register-number to configure a POTS entity to deregister the phone number with the registrar.
register-number
After you complete the SIP registration configuration, a POTS entity registers the phone number with the registrar.
POTS entity view
A registrar cannot store multiple entries for one phone number. If multiple POTS entities on a device have the same phone number, only one POTS entity can register that number with the registrar.
# Configure POTS entity 10 to deregister the phone number with the registrar.
[Sysname-voice-dial-entity10] match-template 1000
[Sysname-voice-dial-entity10] line 2/1/1
[Sysname-voice-dial-entity10] undo register-number
match-template
registrar
Use registrar to specify a registrar.
Use undo registrar to remove the configuration of a registrar and to notify the registrar to deregister the SIP UA.
registrar registrar-index { dns domain-name port port-number | ip ip-address [ port port-number ] } [ expires seconds ] [ refresh-ratio ratio-percentage ] [ scheme { sip | sips } ] [ tcp [ tls ] ]
undo registrar registrar-index
No registrars are specified.
SIP view
registrar-index: Specifies the index for a registrar, in the range of 1 to 6.
dns domain-name: Specifies a registrar by its domain name, which consists of case-insensitive strings separated by dots (for example, aabbcc.example.com). Each separated string contains no more than 63 characters. A domain name can include letters, digits, hyphens (-), and underscores (_), and has a maximum length of 253 characters.
ip ip-address: Specifies a registrar by its IP address.
port port-number: Specifies the port number of a registrar, in the range of 1 to 65535. If the ip keyword is specified, the default port number is 5060 for TCP and UDP and 5061 for TLS. If the dns keyword is specified, the port number must be configured.
expires seconds: Specifies the registration expiration time in the range of 60 to 65535 seconds. The default registration expiration time is 3600 seconds.
refresh-ratio ratio-percentage: Specifies the refresh percentage in the range of 50 to 100. The default refresh percentage is 80%.
tcp: Uses TCP as the transport protocol. By default, UDP is used.
tls: Uses TLS as the transport protocol.
scheme: Specifies a URL scheme.
sip: Specifies SIP as the URL scheme. By default, SIP is used.
sips: Specifies SIPS as the URL scheme.
When the registration time reaches the registration expiration time multiplied by the refresh percentage, a voice entity or SIP trunk re-registers the number with the registrar to avoid expiration.
If you use TLS as the transport protocol for registration, the port number specified in this command must be the same as the one configured on the registrar.
# Configure a registrar with the IP address 169.54.5.10 and port number 1120, and set the registration expiration time to 120 seconds.
[Sysname-voice] sip
[Sysname-voice-sip] registrar 1 ip 169.54.5.10 port 1120 expires 120
# Configure a registrar with domain name cc.example.com and port number 1100, and set the registration expiration time to 520 seconds.
[Sysname-voice] sip
[Sysname-voice-sip] registrar 2 dns cc.example.com port 1100 expires 520
credentials
transport
rel1xx
Use rel1xx to configure reliable provisional responses.
Use undo rel1xx to restore the default.
rel1xx { disable | require value | supported value }
undo rel1xx
The UAC sends INVITE requests with the Supported: 100rel header field. The UAS sends 18x responses with the Require: 100rel header field.
SIP view
disable: Disables reliable provisional responses.
require value: Enables reliable provisional responses by adding the Required: value header field to outgoing INVITE requests or outgoing 18x responses. The value argument is a case-sensitive string of 1 to 49 characters.
supported value: Enables reliable provisional responses by adding the Supported: value header field to outgoing INVITE requests or the Require: value header field to outgoing 18x responses. The value argument is a case-sensitive string of 1 to 49 characters.
To implement reliable provisional responses, enable this feature and configure the same value for the value argument on both the UAC and UAS.
# Enable the device to send INVITE requests with the Supported: 100rel header field or 18x responses with the Require: rel100 header field.
[Sysname-voice] sip
[Sysname-voice-sip] rel1xx require 100rel
remote-party-id
Use remote-party-id to add the Remote-Party-ID header field to outgoing INVITE requests.
Use remote-party-id to not add the Remote-Party-ID header field to outgoing INVITE requests.
remote-party-id
undo remote-party-id
Outgoing INVITE requests include the Remote-Party-ID header field.
SIP view
# Add the Remote-Party-ID header field to outgoing INVITE requests.
[Sysname-voice] sip
[Sysname-voice-sip] remote-party-id
Use reset voice sip connection to disconnect a SIP connection.
reset voice sip connection { tcp | tls } id conn-id
id conn-id: Specifies a connection by its connection ID in the range of 0 to 2147483647. You can use the display voice sip connection command to determine connection IDs.
This command disconnects either an established SIP connection or a SIP connection that is being established.
# Disconnect the TCP connection with a connection ID of 1.
<Sysname> reset voice sip connection tcp id 1
retry invite
Use retry invite to set the maximum number of INVITE request retries.
Use undo retry invite to restore the default.
retry invite times
undo retry invite
The maximum number of INVITE request retries is 6.
SIP view
times: Specifies the maximum number of INVITE request retries, in the range of 1 to 10.
The originating device starts an INVITE retry timer when sending an INVITE request. If no 100 response arrives when the timer expires, the originating device retransmits the INVITE request. If no 100 response arrives when the maximum number of INVITE retries is reached, the originating device clears the call.
# Set the maximum number of INVITE request retries to 5.
[Sysname-voice] sip
[Sysname-voice-sip] retry invite 5
timers trying
session refresh
Use session refresh to enable SIP session refresh globally.
Use undo session refresh to disable SIP session refresh globally.
session refresh
SIP session refresh is globally disabled if the device acts as a UAC, and is globally enabled if the device acts as a UAS.
SIP view
Use this command on a UAC.
# Globally enable SIP session refresh.
[Sysname-voice] sip
[Sysname-voice-sip] session refresh
min-se
session transport
Use session transport to specify a transport protocol for outgoing SIP calls.
Use undo session transport to restore the default.
session transport { tcp [ tls ] | udp }
The global transport protocol for outgoing SIP calls is UDP. The transport protocol for outgoing SIP calls on a VoIP entity is the same as the global default.
SIP view
VoIP entity view
udp: Specifies UDP as the transport protocol.
tcp: Specifies TCP as the transport protocol.
tls: Specifies TLS as the transport protocol.
You can configure the transport protocol both globally (in SIP view) and for a specific VoIP entity (in VoIP entity view). The configuration in VoIP entity view takes precedence over the global configuration. A VoIP entity uses the global configuration only when no transport protocol is configured in VoIP entity view.
Configure the same transport protocol on the called and calling devices. For example, if you configure the session transport tcp command on the calling device, you must configure the transport tcp command on the called device.
You must configure the SSL client and server policies by using the crypto command before you can use TLS to initiate SIP calls.
# Specify TLS as the global transport protocol for outgoing SIP calls.
[Sysname-voice] sip
[Sysname-voice-sip] session transport tcp tls
crypto
transport
set pstn-cause
Use set pstn-cause to configure a PSTN cause-to-SIP status mapping.
Use undo set pstn-cause to restore the default.
set pstn-cause pstn-cause sip-status sip-status
undo set pstn-cause pstn-cause
Table 8 Default PSTN cause-to-SIP status mappings
PSTN cause code
PSTN cause description
SIP status code
SIP status description
1
Unallocated (unassigned) number!
404
Not Found.
2
No route to specified transit network!
404
Not Found.
3
No route to destination!
404
Not Found.
16
Normal clearing!
N/A
BYE or CANCEL.
17
User busy!
486
Busy here.
18
No user responding!
408
Request Timeout.
19
No answer from user!
480
Temporarily unavailable.
20
Subscriber absent!
480
21
Call rejected!
403
Forbidden.
22
Number changed!
410
Gone.
23
Redirection to new destination!
410
Gone.
25
Exchange routing error!
500
Server internal error.
26
Non-selected user clearing!
404
Not Found.
27
Destination out of order!
502
Bad Gateway.
28
Invalid number format (address incomplete)!
484
Address incomplete.
29
Facility rejected!
501
Not implemented.
31
Normal, unspecified!
480
34
No circuit/channel available!
503
Service unavailable.
38
Network out of order!
503
41
Temporary failure!
503
42
Switching equipment congestion!
503
47
Resource unavailable, unspecified!
503
55
Incoming class barred within Closed User Group (CUG)!
403
Forbidden.
57
Bearer capability not authorized!
403
Forbidden.
58
Bearer capability not presently available!
503
63
Service or option not available, unspecified!
500
65
Bearer capability not implemented!
488
Not Acceptable Here.
70
Only restricted digital information bearer capability is available!
488
79
Service or option not implemented, unspecified!
501
Not implemented.
87
User not member of Closed User Group (CUG)!
403
Forbidden.
88
Incompatible destination!
503
102
Recovery on timer expiry!
504
Gateway timeout.
111
Protocol error, unspecified!
500
127
Interworking, unspecified!
500
SIP view
pstn-code: Specifies a PSTN cause code in Table 8. The PSTN cause code 16 is invalid.
sip-code: Specifies a SIP status code in Table 8.
# Map the PSTN cause code 17 to the SIP status code 408.
[Sysname-voice] sip
[Sysname-voice-sip] set pstn-cause 17 sip-status 408
set sip-status
Use set sip-status to configure a SIP status-to-PSTN cause mapping.
Use undo set sip-status to restore the default.
set sip-status sip-status pstn-cause pstn-cause
undo set sip-status sip-status
Table 9 Default SIP status-to-PSTN cause mappings
SIP status code
PSTN cause code
400
Bad Request.
41
Temporary failure!
401
Unauthorized.
21
Call rejected!
402
Payment required.
21
Call rejected!
403
Forbidden.
21
Call rejected!
404
Not found.
1
405
Method not allowed.
63
406
Not acceptable.
79
407
Proxy authentication required.
21
Call rejected!
408
Request timeout.
102
410
Gone.
22
Number changed!
413
Request Entity too long.
127
414
Request-URI too long.
127
415
Unsupported media type.
79
416
Unsupported URI Scheme.
127
420
Bad extension.
127
421
Extension Required.
127
423
Interval Too Brief.
127
480
18
No user responding!
481
Call/Transaction Does not Exist.
41
Temporary failure!
482
Loop Detected.
25
483
Too many hops.
25
484
Address incomplete.
28
485
Ambiguous.
1
486
Busy here.
17
User busy!
487
Request Terminated.
127
488
Not Acceptable here.
127
500
41
Temporary failure!
501
Not implemented.
79
502
Bad gateway.
38
503
41
Temporary failure!
504
Server time-out.
102
505
Version Not Supported.
127
513
Message Too Large.
127
600
Busy everywhere.
17
User busy!
603
Decline.
21
Call rejected!
604
Does not exist anywhere.
1
606
Not acceptable.
58
SIP view
sip-code: Specifies a SIP status code in Table 9.
pstn-code: Specifies a PSTN cause code in Table 9.
# Map the SIP status code 486 to the PSTN cause code 18.
[Sysname-voice] sip
[Sysname-voice-sip] set sip-status 486 pstn-cause 18
signaling forward rawmsg
Use signaling forward rawmsg to enable QSIG tunneling over SIP-T.
Use undo signaling forward rawmsg to disable QSIG tunneling over SIP-T.
QSIG tunneling over SIP-T is disabled.
VoIP entity view
This command enables sending QSIG signaling in SIP messages. In the SIP messages, the Content-type field is application/qsig, and the message body is the QSIG signaling received from the ISDN side.
The device does not support QSIG tunneling over SIP-T when the ISDN network uses overlap sending.
The SIP server might fail to interpret SIP messages carrying QSIG signaling. As a best practice, do not enable QSIG tunneling over SIP-T on a network where the device communicates with the SIP server.
# Enable QSIG tunneling over SIP-T.
[Sysname-voice-dial-entity10] signaling forward rawmsg
sip
Use sip to enter SIP view.
Use undo sip to remove the settings from SIP view.
sip
undo sip
Voice view
# Enter SIP view.
[Sysname-voice] sip
[Sysname-voice-sip]
sip-compatible
Use sip-compatible to configure SIP compatibility with a third-party device.
Use undo sip-compatible to restore the default.
sip-compatible { cause-code | early-media | t38 | x-param }
undo sip-compatible { cause-code | early-media | t38 | x-param }
SIP compatibility is not configured.
SIP view
cause-code: Configures SIP compatibility for SIP cause code interaction. With this keyword specified, the device uses Cause 27 instead of Cause 38 as the cause code for disconnecting a call.
early-media: Configures SIP compatibility for early media channels. With this keyword specified, the device does not disconnect the established early media channel upon receiving an 18x message without SDP from the terminating side.
t38: Configures SIP compatibility for standard T.38 fax. With this keyword specified, the device excludes :0 from the following SDP parameters in the originated re-INVITE messages:
·     T38FaxTranscodingJBIG.
·     T38FaxTranscodingMMR.
·     T38FaxFillBitRemoval.
This keyword is required when the device interoperates with a third-party softswitch device to exchange T.38 fax messages.
x-param: Configures SIP compatibility for fax pass-through and modem pass-through. With this keyword specified, the device adds SDP description information for fax pass-through and modem pass-through to outgoing re-INVITE messages. This keyword is required when the device interoperates with a third-party softswitch device to perform fax pass-through and modem pass-through.
If SIP implementations of a third-party device are special, you can configure SIP compatibility for the device to interoperate with the third-party device.
You can execute this command multiple times to specify multiple parameters.
# Configure SIP compatibility for standard T.38 fax.
[Sysname-voice] sip
[Sysname-voice-sip] sip-compatible t38
sip-domain
Use sip-domain to configure a SIP domain name for the device.
Use undo sip-domain to restore the default.
sip-domain domain-name
undo sip-domain
No SIP domain name is configured. The device inserts the IP address of the outgoing interface in the Contact header field of an outgoing SIP packet.
SIP view
domain-name: Specifies the SIP domain name, a case-insensitive string of 1 to 31 characters. Valid characters are letters, digits, underscore (_), hyphen (-), and dot (.).
Use this command to enable the device to insert the SIP domain name in the Contact header field of outgoing SIP packets.
# Configure the SIP domain name as abc.example.com.
[Sysname-voice] sip
[Sysname-voice-sip] sip-domain abc.example.com
srtp
Use srtp to configure SRTP as the media stream protocol for SIP calls.
Use undo srtp to restore the default.
srtp [ fallback ]
undo srtp
The global media stream protocol for SIP calls is RTP. The media stream protocol for SIP calls on a VoIP entity is the same as the global default.
SIP view
VoIP entity view
fallback: Supports fallback to RTP if the peer does not support SRTP.
The differences between the srtp and srtp fallback commands are as follows:
·     If the srtp command is configured, the following conditions exist:
¡     The device includes crypto and RTP/SAVP parameters in outgoing INVITE requests and disconnects the call after receiving a 488 response.
¡     The device can accept only calls using SRTP.
·     If the srtp fallback command is configured, the following conditions exist:
¡     The device includes crypto and RTP/SAVP parameters in outgoing INVITE requests and retransmits INVITE requests with RTP/AVP parameters after receiving a 488 response.
¡     The device can accept calls using SRTP or RTP. SRTP is preferred for media stream protocol negotiation. If the negotiation fails, RTP is used.
You can configure the srtp command globally (in SIP view) and for a specific VoIP entity (in VoIP entity view). The configuration in VoIP entity view takes precedence over the global configuration. A VoIP entity uses the global configuration only when the srtp command is not configured in VoIP entity view.
# Configure SRTP as the media stream protocol for SIP calls.
[Sysname-voice] sip
timers connection aging
Use timers connection aging to set the aging time for TCP or TLS connections.
Use undo timers connection aging to restore the default.
timers connection aging { tcp tcp-age-time | tls tls-age-time }
undo timers connection aging { tcp | tls }
The aging time for TCP connections is 5 minutes. The aging time for TLS connections is 30 minutes.
SIP view
tcp tcp-age-time: Specifies the amount of idle time that elapses before a TCP connection is removed. The value range for the tcp-age-time argument is 5 to 30 minutes.
tls tls-age-time: Specifies the amount of idle time that elapses before a TLS connection is removed. The value range for the tls-age-time argument is 30 to 180 minutes.
# Set the aging time to 6 minutes for TCP connections and 60 minutes for TLS connections.
[Sysname-voice] sip
[Sysname-voice-sip] timers connection aging tcp 6
[Sysname-voice-sip] timers connection aging tls 60
timers options
Use timers options to set the interval for sending out-of-dialog OPTIONS messages.
Use undo timers options to restore the default.
timers options value
undo timers options
The interval for sending out-of-dialog OPTIONS messages is 500 milliseconds.
SIP view
value: Specifies the interval for sending out-of-dialog OPTIONS messages, in the range of 100 to 1000 milliseconds.
This command takes effect only when the out-of-dialog keepalive feature has been enabled by using the voice-class sip options-keepalive command. For more information about the interval, see the usage guidelines for the voice-class sip options-keepalive command.
# Set the interval to 600 milliseconds for sending out-of-dialog OPTIONS messages.
[Sysname-voice] sip
[Sysname-voice-sip] timer registration expires 600
timers trying
Use timers trying to set the INVITE retry timer.
Use undo timers trying to restore the default.
timers trying timer-length
undo timers trying
The INVITE retry timer is 500 milliseconds.
SIP view
timer-length: Specifies the INVITE retry timer value in the range of 100 to 1000 milliseconds.
The INVITE retry timer defines the amount of time to wait for a 100 response to an INVITE request. The originating device starts an INVITE retry timer when sending an INVITE request. If it does not receive a 100 response when the timer expires, it retransmits the INVITE request.
# Set the INVITE retry timer to 600 milliseconds.
[Sysname-voice] sip
[Sysname-voice-sip] timers trying 600
retry invite
transport
Use transport to enable the listening port for a transport protocol.
Use undo transport to disable the listening port for a transport protocol.
undo transport { tcp [ tls ] | udp }
The UDP and TCP listening ports are enabled. The TLS listening port is disabled.
SIP view
udp: Enables the UDP listening port (port 5060).
tcp: Enables the TCP listening port (port 5060).
tls: Enables the TLS listening port (port 5061).
You can use this command multiple times to enable multiple listening ports for different protocols. The protocols do not interfere with each other.
For the device to receive calls and initiate registrations or subscriptions, configure this command to enable the corresponding listening port.
You must configure the SSL client and server policies by using the crypto command before you can enable the TLS listening port.
The undo transport command removes established connections.
# Enable the TLS listening port.
[Sysname-voice] sip
[Sysname-voice-sip] transport tcp tls
crypto
mwi
registrar
url
Use url to configure a global URL scheme for outgoing SIP calls.
Use undo url to restore the default.
url { sip | sips }
undo url
The SIP scheme is used.
SIP view
sip: Specifies the SIP scheme.
sips: Specifies the SIPS scheme.
You can configure the URL scheme both globally (by using the url command in SIP view) and for a specific VoIP entity (by using the voice-class sip url command in VoIP entity view). The configuration in VoIP entity view takes precedence over the global configuration. A VoIP entity uses the global configuration only when no URL scheme is configured in VoIP entity view.
# Specify SIPS as the global URL scheme.
[Sysname-voice] sip
[Sysname-voice-sip] url sips
voice-class sip url (in VoIP entity view)
user
Use user to configure SIP credentials.
Use undo user to delete SIP credentials.
user username password { cipher | simple } string [ realm realm ]
undo user [ username password { cipher | simple } string [ realm realm ] ]
No SIP credentials exist.
SIP view
POTS entity view
username: Specifies a username, a case-sensitive string of 1 to 63 characters.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters.
realm realm: Specifies a realm, a case-sensitive string of 1 to 50 characters. If you do not specify a realm, the credentials can be used to respond to any registrars.
A SIP UA can register with a maximum of six registrars, and it uses the domain name in the 401/407 response from a registrar to identify the credentials to be sent to the registrar.
You can configure only one username with the user command in SIP view or voice entity view. The username can contain 12 credentials bindings. A binding that does not include a domain name can be used to respond to a 401/407 response that does not match any domain name-included binding. The following example configures four credentials bindings:
[Sysname-voice-dial-entity100] user 1000 password simple 1000 realm server1
[Sysname-voice-dial-entity100] user 1000 password simple 1000 realm server2
[Sysname-voice-dial-entity100] user 1000 password simple 2000 realm server3
[Sysname-voice-dial-entity100] user 1000 password simple 3000
The first three bindings each contain a domain name, and the last binding contains no domain name. If the SIP UA receives a 401/407 response that includes a domain name server2, the SIP UA responds with the username 1000 and password 1000. If the SIP UA receives a 401/407 response that includes a domain name server4, the SIP UA responds with the username 1000 and password 3000 because no credentials binding contains the domain name server4.
# Configure global SIP credentials that include username abcd and plaintext password 1234.
[Sysname-voice] sip
[Sysname-voice-sip] user abcd password simple 1234
# Configure SIP credentials that include username abcd, plaintext password 1234, and realm abc for POTS entity 100.
[Sysname-voice-dial] entity 100 pots
[Sysname-voice-dial-entity100] user abcd password simple 1234 realm abc
registrar
Use voice-class sip bind to configure source interface binding for a VoIP entity.
Use undo voice-class sip bind to restore the default.
voice-class sip bind { control | media } source-interface interface-type interface-number
undo voice-class sip bind { control | media }
The default global source interface is used.
VoIP entity view
source-interface interface-type interface-number: Uses the specified interface as the source interface of outbound SIP messages or media packets. The specified interface must be a Layer 3 Ethernet interface or dialer interface.
This command uses the IP address of the specified interface as the source address for outgoing SIP or media packets.
For information about how source interface binding works in different conditions, see the usage guidelines for the bind command.
# Specify Dialer 0 as the source interface for outbound SIP messages on VoIP entity 10.
[Sysname-voice-dial-entity10] voice-class sip bind control source-interface dialer 0
bind
Use voice-class sip options-keepalive to enable out-of-dialog keepalive for a VoIP entity and optionally set the out-of-dialog keepalive parameters.
Use undo voice-class sip options-keepalive to disable out-of-dialog keepalive for a VoIP entity.
voice-class sip options-keepalive [ up-interval interval ] [ down-interval interval ] [ retry retries ]
Out-of-dialog keepalive is disabled for a VoIP entity.
VoIP entity view
up-interval interval: Specifies the interval for sending out-of-dialog OPTIONS packets when the VoIP entity is available, in the range of 5 to 1200 seconds. The default value is 60 seconds.
down-interval interval: Specifies the interval for sending out-of-dialog OPTIONS packets when the VoIP entity is not available, in the range of 5 to 1200 seconds. The default value is 30 seconds.
retry retries: Specifies the number of retries to change the state for the VoIP entity.
After you enable the out-of-dialog keepalive feature for a VoIP entity, the UA sends OPTIONS packets at the up-interval. If the UA receives a response within the up-interval, it considers the VoIP entity to be available. If the UA receives no response within the up-interval, or receives an error response, it sends OPTIONS packets at the timers options interval. (Error responses include 408, 499, and 5XX responses except for 500, 501, 502, 503, 504, and 513 responses.) If the UA still receives no responses after the maximum number of retries is reached, it considers the VoIP entity to be unavailable.
Then, the UA sends OPTIONS packets at the down-interval. If the UA receives a response within the down-interval, it sends OPTIONS packets at the timers options interval. If the UA still can receive responses after the number of retries is reached, it considers the VoIP entity to be available.
The keepalive feature does not take effect for a VoIP entity that has been shut down by using the shutdown command.
# Enable out-of-dialog keepalive for VoIP entity 10, and set the up-interval to 50 seconds, the down-interval to 20 seconds, and the number of retries to 2.
[Sysname-voice-dial-entity10] voice-class sip options-keepalive up-interval 50 down-interval 20 retry 2
timers options
Use voice-class sip options-ping to enable in-dialog keepalive for a VoIP entity.
Use voice-class sip options-ping to disable in-dialog keepalive for a VoIP entity.
voice-class sip options-ping { global | seconds }
undo voice-class sip options-ping
A VoIP entity uses the global configuration for in-dialog keepalive.
VoIP entity view
global: Applies the global configuration for in-dialog keepalive to the VoIP entity.
seconds: Specifies the interval for sending OPTIONS messages during a session, in the range of 60 to 1200 seconds.
For a VoIP entity, the entity-specific in-dialog keepalive configuration takes priority over the global in-dialog keepalive configuration set in SIP view.
# Enable in-dialog keepalive for VoIP entity 1 and set the interval to 60 seconds for sending OPTIONS messages during a session.
[Sysname-voice-dial] entity 1 voip
[Sysname-voice-dial-entity1] voice-class sip options-ping 60
# Apply the global configuration for in-dialog keepalive to VoIP entity 1.
[Sysname-voice-dial-entity1] voice-class sip options-ping global
options-ping
voice-class sip session refresh
Use voice-class sip session refresh to enable SIP session refresh for a VoIP entity.
Use undo voice-class sip session refresh to disable SIP session refresh for a VoIP entity.
voice-class sip session refresh [ global ]
A VoIP entity uses the global configuration for SIP session refresh.
VoIP entity view
global: Applies the global configuration for SIP session refresh to the VoIP entity.
The configuration for SIP session refresh in VoIP entity view takes priority over that in SIP view.
# Enable SIP session refresh for VoIP entity 1.
[Sysname-voice-dial-entity1] voice-class sip session refresh
# Apply the global configuration for SIP session refresh to VoIP entity 1.
[Sysname-voice-dial-entity1] voice-class sip session refresh global
min-se
session refresh
voice-class sip url
Use voice-class sip url to configure a URL scheme for outgoing SIP calls on a VoIP entity.
Use undo voice-class sip url to restore the default.
voice-class sip url { sip | sips }
The default global URL scheme (SIP scheme) is used.
VoIP entity view
# Specify the SIP scheme for outgoing SIP calls on VoIP entity 1000.
[Sysname-voice-dial] entity 1000 voip
[Sysname-voice-dial-entity1000] voice-class sip url sips
url
vpn-instance
Use vpn-instance to associate a VPN instance with SIP.
Use undo vpn-instance to remove the association.
undo vpn-instance
No VPN instance is associated with SIP.
SIP view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
The VPN instance to be associated with SIP must be already created.
You cannot associate a VPN instance or remove the association when a SIP service is being used.
# Associate VPN instance vpn-voice with SIP.
[Sysname-voice] sip
[Sysname-voice-sip] vpn-instance vpn-voice
ip binding vpn-instance (MPLS Command Reference)
ip vpn-instance (MPLS Command Reference)
SIP trunk commands
The following compatibility matrixes show the support of hardware platforms for SIP trunk:
Hardware
SIP trunk compatibility
MSR610
No
No
No
No
No
No
No
No
MSR2600-10-X1
Yes
MSR 2630
Yes
Yes
No
No
No
No
MSR-iMC
No
Yes
Yes
No
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
Yes
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3620-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
To support SIP trunk, some device models require the Voice Software License. For more information, see license management in Fundamentals Configuration Guide.
allow-connections sip to sip
Use allow-connections sip to sip to enable SIP-to-SIP calling.
Use undo allow-connections sip to sip to disable SIP-to-SIP calling.
SIP-to-SIP calling is disabled.
Voice view
After you enable SIP-to-SIP calling, the device works as a SIP trunk device. As a best practice, do not use a SIP trunk device as a SIP UA.
# Enable SIP-to-SIP calling.
[Sysname-voice] allow-connections sip to sip
codec transparent
Use codec transparent to enable codec transparent transmission.
Use undo codec transparent to disable codec transparent transmission.
codec transparent
Codec transparent transmission is disabled. The SIP trunk device is involved in the media negotiation between the calling and called parties.
VoIP entity view
If the SIP trunk device does not support any codecs on the calling and called parties, you can enable codec transparent transmission. The SIP trunk device transparently forwards codec capability sets between the two parties without intervening codec negotiation.
# Enable codec transparent transmission for VoIP entity 1.
[Sysname-voice-dial-entity1] codec transparent
credentials
Use credentials to create a SIP trunk account.
Use undo credentials to delete a SIP trunk account.
credentials number number username username password { cipher | simple } string realm realm
undo credentials { number number | number number username username password { cipher | simple } password realm realm }
No SIP trunk accounts exist.
SIP view
number: Specifies a number for the SIP trunk account, a case-sensitive string of 4 to 31 characters.
A SIP trunk account contains a phone number, credentials, and realms assigned by the service provider. SIP can send a REGISTER request for the phone number to a maximum of six registrars specified by using the registrar command. SIP uses the realm value in 401/407 responses from the registrars to identify the matching credentials. You can configure a maximum of 12 realms for a phone number, and a maximum of 128 SIP trunk accounts on the device.
# Configure a SIP trunk account for phone number 1000 that uses the following:
·     Username 1000 and password 1000 for realm server1.
·     Username 2000 and password 2000 for realm server2.
·     Username 3000 and password 3000 for realm server3.
[Sysname-voice] sip
[Sysname-voice-sip] credentials number 1000 username 1000 password simple 1000 realm server1
[Sysname-voice-sip] credentials number 1000 username 2000 password simple 2000 realm server2
[Sysname-voice-sip] credentials number 1000 username 3000 password simple 3000 realm server3
registrar
media flow-around
Use media flow-around to enable media flow-around.
Use undo media flow-around to disable media flow-around.
media flow-around
Media flow-around is disabled. Media packets are relayed by the SIP trunk, and the SIP trunk device changes the media address of a media packet to its own address before forwarding the media packet.
VoIP entity view
This feature enables the SIP trunk device to directly forward media packets between SIP endpoints, without changing the media address for the media packets. Use this feature to improve forwarding performance.
# Enable media flow-around for VoIP entity 1.
[Sysname-voice-dial-entity1] media flow-around
voice-class sip early-offer forced
Use voice-class sip early-offer forced to enable delayed offer to early offer (DO-EO) conversion.
Use undo voice-class sip early-offer forced to disable DO-EO conversion
DO-EO conversion is disabled.
VoIP entity view
An INVITE request with SDP Offer is an early offer, and an INVITE request without SDP Offer is a delayed offer. Some service providers mandate early offer calls for charge security. To meet this requirement, enable DO-EO conversion on the SIP trunk device.
This command does not take effect if codec transparent transmission or media flow-around is enabled.
# Enable DO-EO conversion on the SIP trunk device.
[Sysname-voice-dial-entity1] voice-class sip early-offer forced
codec transparent
media flow-around
