12-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10212-Security Command Reference
07-User profile commands
07-User profile commands 62.10 KB
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
In standalone mode:
display user-profile [ name profile-name ]
In IRF mode:
display user-profile [ name profile-name ] [ slot slot-number ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, hyphens (-), and underscores (_). The name must start with an English letter or digit, and cannot contain only digits. The name must be globally unique. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user profile configuration and online user information for all member devices. (In IRF mode.)
# (In standalone mode.) Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
  User-Profile: aaa
    Inbound:
      Committed Access Rate:
        Rule: If-match any
          CIR 64 (kbps), CBS 512 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
        Rule: If-match acl 2000
          CIR 3000 (kbps), CBS 187500 (Bytes), EBS 0 (Bytes)
      Policy: p1
    Outbound:
        Rule: If-match acl 3000
          CIR 1000 (kbps), CBS 62500 (Bytes), EBS 0 (Bytes)
        Rule: If-match any
      Line Rate:
        CIR 32 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
    Priority queuing: pql 1
    General Traffic Shaping:
      CIR 200 (kbps), CBS 12500 (Bytes), EBS 0 (Bytes)
    Overhead compensation length: 18
    User user_1:
      Authentication type: Portal
      Network attributes:
        Interface    : GigabitEthernet1/0/1
        MAC address  : 0000-1111-2222
      Failed action list:
        Inbound: Policy p1
        Inbound: CIR 64 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
# (In IRF mode.) Display configuration and online user information for user profile aaa.
  User-Profile: aaa
    Inbound:
        Rule: If-match any
      Policy: p1
    Outbound:
        Rule: If-match any
      Line Rate:
    slot 1:
      User user_1:
        User ID: 0x10000002
        Network attributes:
          IP address   : 172.16.187.16
          Service VLAN : 100
User-Profile
User profile name.
Inbound
Policy applied to incoming traffic.
Outbound
Policy applied to outgoing traffic.
CIR
Committed information rate, in kbps.
CBS
Committed burst size, in bytes.
EBS
Excess burst size, in bytes.
PIR
Peak information rate, in kbps.
Policy
Policy name.
Line Rate
Information about user profile-based rate limiting. When the peer-advertise-bandwidth keyword is specified in the qos lr outbound command, this field displays the peer-advertise-bandwidth configuration information.
Priority queuing
Information about priority queuing applied to a user profile.
Information about GTS applied to a user profile.
User user_1
Username of a user account with which a user profile is associated.
Authentication type
·     802.1X—802.1X authentication.
·     Portal—Portal authentication.
·     PPP—PPP authentication.
·     MACA—MAC authentication.
Network attributes
Online user information.
Failed action list
Actions that failed to be applied to the user.
Packet compensation length in bytes for outbound traffic policing.
Rule
Match criteria.
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name
undo user-profile profile-name
No user profiles exist.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters (a-z, A-Z), digits (0-9), hyphens (-), and underscores (_). The name must start with an English letter or digit, and cannot contain only digits. The name must be globally unique.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
[Sysname-user-profile-a123]
