- 12-Security Configuration Guide
- 01-Security zone configuration
- 02-AAA configuration
- 03-802.1X configuration
- 04-MAC authentication configuration
- 05-Portal configuration
- 06-Port security configuration
- 07-User profile configuration
- 08-Password control configuration
- 09-Keychain configuration
- 10-Public key management
- 11-PKI configuration
- 12-IPsec configuration
- 13-Group domain VPN configuration
- 14-SSH configuration
- 15-SSL configuration
- 16-SSL VPN configuration
- 17-ASPF configuration
- 18-APR configuration
- 19-mGRE configuration
- 20-Session management
- 21-Connection limit configuration
- 22-Object group configuration
- 23-Object policy configuration
- 24-Security policy configuration
- 25-Attack detection and prevention configuration
- 26-IP source guard configuration
- 27-ARP attack protection configuration
- 28-ND attack defense configuration
- 29-uRPF configuration
- 30-SAVA configuration
- 31-Crypto engine configuration
- 32-FIPS configuration
- 33-MACsec configuration
08-Password control configuration | 177.63 KB |
Password updating and expiration
Password not displayed in any form
Restrictions and guidelines: Password control configuration
Password control tasks at a glance
Setting global password control parameters
Setting user group password control parameters
Setting local user password control parameters
Setting super password control parameters
Display and maintenance commands for password control
Password control configuration examples
Example: Configuring password control
About password control
Password control allows you to implement the following features:
· Manage login and super password setup, expirations, and updates for device management users.
· Control user login status based on predefined policies.
For more information about local users, see "Configuring AAA." For information about super passwords, see RBAC in Fundamentals Configuration Guide.
Password setting
Minimum password length
You can define the minimum length of user passwords. The system rejects the setting of a password that is shorter than the configured minimum length.
Password composition policy
A password can be a combination of characters from the following types:
· Uppercase letters A to Z.
· Lowercase letters a to z.
· Digits 0 to 9.
· Special characters in Table 1.
Character name |
Symbol |
Character name |
Symbol |
Ampersand sign |
Apostrophe |
Asterisk |
At sign |
Back quote |
Back slash |
Blank space |
N/A |
Caret |
Colon |
Comma |
Dollar sign |
Dot |
Equal sign |
Exclamation point |
Left angle bracket |
Left brace |
Left bracket |
Left parenthesis |
Minus sign |
Percent sign |
Plus sign |
Pound sign |
Quotation marks |
Right angle bracket |
Right brace |
Right bracket |
Right parenthesis |
Semi-colon |
Slash |
Tilde |
Underscore |
_ |
Vertical bar |
Depending on the system's security requirements, you can set the minimum number of character types a password must contain and the minimum number of characters for each type, as shown in Table 2.
Table 2 Password composition policy
Password combination level |
Minimum number of character types |
Minimum number of characters for each type |
Level 1 |
One |
One |
Level 2 |
Two |
One |
Level 3 |
Three |
One |
Level 4 |
Four |
One |
When a user sets or changes a password, the system checks if the password meets the combination requirement. If it does not, the operation fails.
Password complexity checking policy
A less complicated password is more likely to be cracked, such as a password containing the username or repeated characters. For higher security, you can configure a password complexity checking policy to ensure that all user passwords are relatively complicated. When a user configures a password, the system checks the complexity of the password. If the password is complexity-incompliant, the configuration will fail.
You can apply the following password complexity requirements:
· A password cannot contain the username, the reverse of the username, or part of the username or the reverse of the username. For example, if the username is abc, a password such as abc982, 2cba, or ab is not complex enough.
· A minimum of three identical consecutive characters is not allowed. For example, password a111 is not complex enough.
Password updating
This feature allows you to set the minimum interval at which users can change their passwords. A user can only change the password once within the specified interval.
The minimum interval does not apply to the following situations:
· A user is prompted to change the password at the first login.
· The password aging time expires.
Password expiration
Password expiration imposes a lifecycle on a user password. After the password expires, the user needs to change the password.
The system displays an error message for a login attempt with an expired password. The user is asked to provide a new password. The new password must be valid, and the user must enter exactly the same password when confirming it.
Web users, Telnet users, SSH users, and console (or AUX) users can change their own passwords. FTP users must have their passwords changed by the administrator.
Early notice on pending password expiration
When a user logs in, the system checks whether the password will expire in a time equal to or less than the specified notification period. If so, the system notifies the user when the password will expire and provides a choice for the user to change the password.
· If the user sets a new valid password, the system records the new password and the setup time.
· If the user does not or fails to change the password, the system allows the user to log in by using the current password until the password expires.
Login with an expired password
You can allow a user to log in a certain number of times within a period of time after the password expires. For example, if you set the maximum number of logins with an expired password to 3 and the time period to 15 days, a user can log in three times within 15 days after the password expires.
Password history
This feature allows the system to store passwords that a user has used.
When a network access user changes the password, the system compares the new password with the current password and those stored in the password history records. The new password must be different from the current one and those stored in the history records by a minimum of four different characters. Otherwise, the system will display an error message, and the new password is not successfully set.
The local passwords and super passwords for device management users are stored in hash form and cannot be converted to plain texts. When a device management user changes a local password or super password, follow these rules:
· If the new password is set by using the hash method, the system will not compare the new password with the current one and those stored in the history password records.
· If the new password is set in plain text, the system compares the new password with the current password and those stored in the password history records. A new password must be different from those stored in the history password records. If the current password is required, the new password must also be different from the current one by a minimum of four different characters. Otherwise, the system will display an error message, and the new password is not successfully set.
You can set the maximum number of history password records for the system to maintain for each user. When the number of history password records exceeds the setting, the most recent record overwrites the earliest one.
Current login passwords are not stored in the password history for device management users. Device management users have their passwords saved in cipher text, which cannot be recovered to plaintext passwords.
User login control
First login
By default, if the global password control feature is enabled, users must change the password at first login before they can access the system. In this situation, password changes are not subject to the minimum password update interval. If it is not necessary for users to change the password at first login, disable the password change at first login feature.
Password control blacklist
The password control blacklist prevents abnormal users from logging in by recording the login failures and maintaining the status of blacklisted user accounts.
The system adds the information of the following users that fail to log in to the password control blacklist:
· FTP, Web, or VTY users.
· Users logging in to the device through console, AUX, TTY, or USB user lines.
The system does not add the user accounts of nonexistent users (users not configured on the device) to the password control blacklist if they fail to log in.
The device supports the following recording modes for adding the user information to the blacklist for users failing authentication:
· Username only—Adds only usernames to the blacklist. In this mode, a user account matches a blacklist entry as long as the username matches the entry.
· Username and IP address—Adds both usernames and IP addresses to the blacklist. In this mode, a user account matches a blacklist entry only when both the username and the login IP address match the entry.
The device will create a blacklist entry for each IP address for a user account when the following conditions are both met:
· Both usernames and IP addresses are added to the password control blacklist.
· A user uses the same user account to log in to the device from different IP addresses and fails the logins.
When the maximum number of blacklist entries for the user account is reached, a blacklist entry for a new IP address of the user account will overwrite the earliest blacklist entry for the user account.
Login attempt limit
Limiting the number of consecutive login failures can effectively prevent password guessing.
When the user fails the maximum number of consecutive attempts, login attempt limit limits the user and user account in any of the following ways:
· For an FTP, Web, or VTY user, the system prohibits the user from using the user account to log in through the user's IP address. For a console, AUX, TTY, or USB user, the system prohibits the user from logging in through console, AUX, TTY, or USB user line. The locked user can use their own account to log in to the device only after the account is manually removed from the password control blacklist.
· Allows the user to continue using the user account. The user's IP address and user account are removed from the password control blacklist when the user uses this account to successfully log in to the device.
· Locks the user account and the user's IP address for a period of time.
The user can use the account to log in when either of the following conditions exists:
¡ The locking timer expires.
¡ The account is manually removed from the password control blacklist before the locking timer expires.
NOTE: This account is locked only for the user at the locked IP address. A user from an unlocked IP address can still use this account, and the user at the locked IP address can use other unlocked user accounts. |
Maximum account idle time
You can set the maximum account idle time for user accounts. When an account is idle for this period of time since the last successful login, the account becomes invalid.
Login control with a weak password
The system checks for weak passwords for Telnet, SSH, HTTP, or HTTPS device management users. A password is weak if it does not meet the following requirements:
· Password composition restriction.
· Minimum password length restriction.
· Password complexity checking policy.
By default, the system displays a message about a weak password but does not force the user to change it. To improve the device security, you can enable the mandatory weak password change feature, which forces the users to change the identified weak passwords. The users can log in to the device only after their passwords meet the password requirements.
First login with a default username and password
The factory defaults contain a default username and password. If the device starts up with factory defaults, Telnet, SSH, HTTP, or HTTPS device management users can use the default username and password to access the system.
For security purposes, nothing is displayed when a user enters a password.
Logging
The system generates a log each time a user changes its password successfully or is added to the password control blacklist because of login failures.
FIPS compliance
The device supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and parameters might differ in FIPS mode (see "Configuring FIPS") and non-FIPS mode.
IMPORTANT: To successfully enable the global password control feature and allow device management users to log in to the device, make sure the device have sufficient storage space. |
The password control features can be configured in several different views, and different views support different features. The settings configured in different views or for different objects have the following application ranges:
· Settings for super passwords apply only to super passwords.
· Settings in local user view apply only to the password of the local user.
· Settings in user group view apply to the passwords of the local users in the user group if you do not configure password policies for these users in local user view.
· Global settings in system view apply to the passwords of the local users in all user groups if you do not configure password policies for these users in both local user view and user group view.
For local user passwords, the settings with a smaller application scope have higher priority. The system prefers to use the non-default setting in local user view for a local user.
· If the default setting is configured for the local user, the system uses the non-default setting for the user group to which the local user belongs.
· If the default setting is configured for the user group, the system uses the global setting.
To configure password control, perform the following tasks:
2. (Optional.) Setting global password control parameters
3. (Optional.) Setting user group password control parameters
4. (Optional.) Setting local user password control parameters
5. (Optional.) Setting super password control parameters
Enabling password control
For device management users, enabling global password control is a prerequisite for password control functions to take effect except for the following functions:
· Password composition policy.
· Minimum password length.
· Username checking.
For a specific password restriction setting (password expiration or password history management) to take effect, make sure you enable both the global password control feature and the specific password restriction.
For network access users, all password control functions take effect only after the global password control feature is enabled.
After global password control is enabled, follow these restrictions and guidelines:
· You cannot display the password and super password configurations for device management users by using the corresponding display commands.
· You cannot display the password configuration for network access users by using the corresponding display command.
· The passwords configured for local users must contain a minimum of four different characters.
· In FIPS mode, the global password control feature is enabled for device management users and cannot be disabled.
· To ensure correct function of password control, configure the device to use NTP to obtain the UTC time. After global password control is enabled, password control will record the UTC time when the password is set. The recorded UTC time might not be consistent with the actual UTC time due to power failure or device reboot. The inconsistency will cause the password expiration feature to malfunction. For information about NTP, see Network Management and Monitoring Configuration Guide.
· The device automatically generates a .dat file and saves the file to the storage media. The file is used to record authentication and login information of the local users. Do not manually delete or modify the file.
1. Enter system view.
2. Enable the global password control feature.
In non-FIPS mode:
password-control enable [ network-class ]
By default, the global password control feature is disabled for device management and network access users.
In FIPS mode:
By default, the global password control feature is enabled for device management users and cannot be disabled. The global password control feature is disabled for network access users.
3. (Optional.) Enable a specific password control feature.
password-control { aging | composition | history | length } enable
By default, all four password restriction features are enabled.
The global password control parameters in system view apply to all device management and network access local users.
You can configure all password control features for device management users. The password aging time, minimum password length, password complexity policy, password composition policy, and user login attempt limit can be configured in system view, user group view, and local user view.
You can configure only the following password control features for network access users:
· Password complexity policy.
· Minimum password update interval.
· Maximum number of history password records for each user.
Where, the minimum password length, password complexity policy, and password composition policy can be configured in system view, user group view, and local user view.
The password settings with a smaller application scope have higher priority. For local users, password settings configured in local user view have the highest priority, and global settings in system view have the lowest priority.
The global password control feature enables the system to record history passwords. When the number of history password records of a user reaches the maximum number, the newest history record overwrites the earliest one. To delete the existing history password records, use one of the following methods:
· Use the undo password-control enable command to disable the password control feature globally.
· Use the reset password-control history-record command to clear the passwords manually.
The password-control login-attempt command takes effect immediately and can affect the users already in the password control blacklist. If the user information items to add to the password control blacklist change, the system will clear the password control blacklist and restart the recording. Other password control configurations do not take effect on users that have been logged in or passwords that have been configured.
2. Configure password settings.
¡ Set the minimum password length.
In non-FIPS mode:
The default length is 10 characters.
In FIPS mode:
The default length is 15 characters.
¡ Configure the password composition policy.
In non-FIPS mode:
By default, a password must contain a minimum of two character types and a minimum of one character for each type.
In FIPS mode:
By default, a password must contain a minimum of four character types and a minimum of one character for each type.
¡ Configure the password complexity checking policy.
In non-FIPS mode:
By default, username checking is enabled but repeated characters checking is disabled.
In FIPS mode:
By default, the system does not perform password complexity checking.
¡ Set the maximum number of history password records for each user.
password-control history max-record-number
The default setting is 4.
3. Configure password updating and expiration.
¡ Set the minimum password update interval.
password-control update interval interval
The default setting is 24 hours.
¡ Set the password aging time.
The default setting is 90 days.
¡ Set the number of days during which a user is notified of the pending password expiration.
The default setting is 7 days.
¡ Set the maximum number of days and maximum number of times that a user can log in after the password expires.
By default, a user can log in three times within 30 days after the password expires.
4. Configure user login control.
¡ Enable the password control blacklist feature for all user line types.
password-control blacklist all-line
By default, the password control blacklist feature is disabled for all user line types. The password control blacklist feature is enabled only for FTP, Web, and VTY users when you enable the global password control feature.
¡ Set the maximum number of blacklist entries for a user account.
password-control per-user blacklist-limit max-number
By default, the maximum number of blacklist entries for a user account is 32.
¡ Configure the login attempt limit.
password-control login-attempt login-times [ exceed { lock | lock-time time [ autoincrement max-lock-time ] | unlock } ]
By default, the maximum number of login attempts is 3 and a user failing to log in after the specified number of attempts must wait for 1 minute before trying again.
¡ Add only usernames to the password control blacklist for users failing authentication.
password-control blacklist user-info username-only
By default, both usernames and IP addresses are added to the password control blacklist when the users fail authentication.
¡ Set the maximum account idle time.
If a user account is idle for this period of time, the account becomes invalid and can no longer be used to log in to the device. To disable the account idle time restriction, set the idle time value to 0.
¡ Disable password change at first login.
undo password-control change-password first-login enable
By default, the password change at first login is enabled.
In FIPS mode, the password change at first login feature cannot be disabled.
¡ Enable mandatory weak password change.
password-control change-password weak-password enable
In non-FIPS mode:
By default, the mandatory weak password change feature is disabled.
In FIPS mode:
By default, the mandatory weak password change feature is enabled and cannot be disabled.
2. Create a user group and enter its view.
user-group group-name
For information about how to configure a user group, see "Configuring AAA."
3. Enable the password expiration feature for the user group.
password-control aging enable
By default, the password expiration feature is enabled for a user group, and the setting equals the global setting.
4. Configure the password aging time for the user group.
By default, the password aging time of the user group equals the global password aging time.
5. Configure the minimum password length for the user group.
By default, the minimum password length of the user group equals the global minimum password length.
6. Configure the password composition policy for the user group.
By default, the password composition policy of the user group equals the global password composition policy.
7. Configure the password complexity checking policy for the user group.
By default, the password complexity checking policy of the user group equals the global password complexity checking policy.
8. Set the maximum account idle time.
By default, the global account idle time is used.
9. Configure the login attempt limit.
By default, the login-attempt policy of the user group equals the global login-attempt policy.
2. Create a device management or network access user and enter its view.
¡ Create a device management user and enter its view.
local-user user-name class manage
¡ Create a network access user and enter its view.
local-user user-name class network
For information about how to configure a local user, see "Configuring AAA."
3. Enable the password expiration feature for the local user.
By default, the password expiration feature is enabled for a local user, and the setting equals that for the user group to which the local user belongs.
This feature is available only for device management users.
For the setting for a local user to take effect, make sure the password expiration feature is all enabled in system view, user group view, and local user view.
4. Configure the password aging time for the local user.
By default, the setting equals that for the user group to which the local user belongs. If no aging time is configured for the user group, the global setting applies to the local user.
This command is available only for device management users.
5. Configure the minimum password length for the local user.
By default, the setting equals that for the user group to which the local user belongs. If no minimum password length is configured for the user group, the global setting applies to the local user.
6. Configure the password composition policy for the local user.
By default, the settings equal those for the user group to which the local user belongs. If no password composition policy is configured for the user group, the global settings apply to the local user.
7. Configure the password complexity checking policy for the local user.
By default, the settings equal those for the user group to which the local user belongs. If no password complexity checking policy is configured for the user group, the global settings apply to the local user.
By default, the account idle time of the user group to which a local user belongs is used.
By default, the settings equal those for the user group to which the local user belongs. If no login-attempt policy is configured for the user group, the global settings apply to the local user.
2. Set the password aging time for super passwords.
3. Configure the minimum length for super passwords.
In non-FIPS mode:
The default setting is 10 characters.
In FIPS mode:
The default setting is 15 characters.
4. Configure the password composition policy for super passwords.
In non-FIPS mode:
By default, a super password must contain a minimum of two character types and a minimum of one character for each type.
In FIPS mode:
By default, a super password must contain a minimum of four character types and a minimum of one character for each type.
Task |
Command |
Display password control configuration. |
display password-control [ super ] |
Display information about users in the password control blacklist. |
display password-control blacklist [ user-name user-name | ip ipv4-address | ipv6 ipv6-address] |
Delete users from the password control blacklist. |
reset password-control blacklist [ user-name user-name ] |
Clear history password records. |
reset password-control history-record [ user-name user-name | super [ role role name ] | network-class [ user-name user-name ] ] |
Configure a global password control policy to meet the following requirements:
· A password must contain a minimum of 16 characters.
· A password must contain a minimum of four character types and a minimum of four characters for each type.
· An FTP or VTY user failing to provide the correct password in two successive login attempts is permanently prohibited from logging in with the current IP address.
· A user can log in five times within 60 days after the password expires.
· A password expires after 30 days.
· The minimum password update interval is 36 hours.
· The maximum account idle time is 30 days.
· A password cannot contain the username or the reverse of the username or part of the username or the reverse of the username.
· A minimum of three identical consecutive characters is not allowed in a password.
Configure a super password control policy for user role network-operator to meet the following requirements:
· A super password must contain a minimum of 24 characters.
· A super password must contain a minimum of four character types and a minimum of five characters for each type.
Configure a password control policy for local Telnet user test to meet the following requirements:
· The password must contain a minimum of 24 characters.
· The password must contain a minimum of four character types and a minimum of five characters for each type.
· The password for the local user expires after 20 days.
# Enable the password control feature globally.
# Allow a maximum of two consecutive login failures on a user account, and lock the user account and the user's IP address permanently if the limit is reached.
[Sysname] password-control login-attempt 2 exceed lock
# Set all passwords to expire after 30 days.
[Sysname] password-control aging 30
# Globally set the minimum password length to 16 characters.
# Set the minimum password update interval to 36 hours.
# Specify that a user can log in five times within 60 days after the password expires.
# Set the maximum account idle time to 30 days.
# Enable username checking for passwords
# Enable repeated characters checking for passwords.
[Sysname] password-control complexity same-character check
# Globally specify that all passwords must each contain a minimum of four character types and a minimum of four characters for each type.
[Sysname] password-control composition type-number 4 type-length 4
# Set the minimum super password length to 24 characters.
[Sysname] password-control super length 24
# Specify that a super password must contain a minimum of four character types and a minimum of five characters for each type.
# Configure a super password used for switching to user role network-operator as 123456789ABGFTweuix@#$%! in plain text.
[Sysname] super password role network-operator simple 123456789ABGFTweuix@#$%!
# Create a device management user named test.
# Set the service type of the user to Telnet.
# Set the minimum password length to 24 for the local user.
[Sysname-luser-manage-test] password-control length 24
# Specify that the password of the local user must contain a minimum of four character types and a minimum of five characters for each type.
[Sysname-luser-manage-test] password-control composition type-number 4 type-length 5
# Set the password for the local user to expire after 20 days.
[Sysname-luser-manage-test] password-control aging 20
# Configure the password of the local user in interactive mode.
Password:
Confirm :
# Display the global password control configuration.
Password control: Enabled(device management users)
Disabled (network access users)
Password aging: Enabled (30 days)
Password length: Enabled (16 characters)
Password composition: Enabled (4 types, 4 characters per type)
Password history: Enabled (max history record:4)
Early notice on password expiration: 7 days
Maximum login attempts: 2
Action for exceeding login attempts: Lock
Minimum interval between two updates: 36 hours
User account idle time: 30 days
Logins with aged password: 5 times in 60 days
Password complexity: Enabled (username checking)
Enabled (repeated characters checking)
Password change: Enabled (first login)
Disabled (mandatory weak password change)
User information in blacklist: Username and IP
All line: Disabled (all line blacklist)
# Display the password control configuration for super passwords.
Password aging: Enabled (90 days)
Password length: Enabled (24 characters)
Password composition: Enabled (4 types, 5 characters per type)
# Display the password control configuration for local user test.
<Sysname> display local-user user-name test class manage
Total 1 local users matched.
Device management user test:
State: Active
Service type: Telnet
User group: system
Bind attributes:
Authorization attributes:
Work directory: flash:
User role list: network-operator
Password aging: Enabled (20 days)
Password length: 24 characters
Password composition: 4 types, 5 characters per type
Disabled (repeated characters checking)
