HomeSupportConfigure & DeployConfiguration GuidesH3C MSR610[810][830][1000S][2600][3600] Routers Configuration Guides(V7)-R6749-6W10201-Fundamentals Configuration Guide
07-Software upgrade configuration
07-Software upgrade configuration 240.00 KB
Upgrading software
About software upgrade
Software upgrade enables you to upgrade a software version, add new features, and fix software bugs. This chapter describes software types and release forms, compares software upgrade methods, and provides the procedures for upgrading software from the CLI.
Software types
The following software types are available:
·     BootWare image—Also called the Boot ROM image. This image contains a basic segment and an extended segment.
¡     The basic segment is the minimum code that bootstraps the system.
¡     The extended segment enables hardware initialization and provides system management menus. When the device cannot start up correctly, you can use the menus to load software and the startup configuration file or manage files.
Typically, the BootWare image is integrated into the Boot image to avoid software compatibility errors.
·     Comware image—Includes the following image subcategories:
¡     Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡     System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
¡     Feature image—A .bin file that contains advanced or customized software features. You can purchase feature images as needed.
¡     Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
Patch images have the following types:
-     Incremental patch images—A new incremental patch image can cover all, part, or none of the functions provided by an old incremental patch image. A new incremental patch image can coexist with an old incremental patch image on the device only when the former covers none of the functions provided by the latter.
-     Non-incremental patch images—A new non-incremental patch image covers all functions provided by an old non-incremental patch image. Each of the boot, system, and feature images can have one non-incremental patch image, and these patch images can coexist on the device. The device uninstalls the old non-incremental patch image before installing a new non-incremental patch image.
An incremental patch image and a non-incremental patch image can coexist on the device.
Comware images that have been loaded are called current software images. Comware images specified to load at the next startup are called startup software images.
BootWare image, boot image, and system image are required for the device to operate.
You can install up to 32 .bin files on the device, including one boot image file, one system image file, and up to 30 feature and patch image files.
Software release forms
Software images are released in one of the following forms:
·     Separate .bin files. You must verify compatibility between software images.
·     As a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
Software image file names use the model-comware version-image type-release format. This document uses boot.bin and system.bin as boot and system image file names.
Upgrade methods
Upgrade method
Software types
Remarks
Upgrading from the CLI by using the boot loader method
·     BootWare image
·     Comware images (excluding patches)
This method is disruptive. You must reboot the entire device to complete the upgrade.
Performing an upgrade by using install commands
Comware images
This method installs new features or patches or upgrades the boot, system, or feature images.
Upgrading from the BootWare menu
·     BootWare image
·     Comware images
Use this method when the device device, PEX, or security engine cannot start up correctly.
To use this method, first connect to the console port and power cycle the device, PEX, or security engine. Then, press Ctrl+B at prompt to access the BootWare menu.
For more information about upgrading software from the BootWare menu, see the release notes for the software version.
IMPORTANT IMPORTANT:
Use this method only when you do not have any other choice.
This chapter covers only upgrading software from the CLI by using the boot loader method.
Software image loading
Startup software images
To upgrade software, you must specify the upgrade files as the startup software images for the device to load at next startup. You can specify two lists of software images: one main and one backup. The device first loads the main startup software images. If the main startup software images are not available, the devices loads the backup startup software images.
Image loading process at startup
At startup, the device performs the following operations after loading and initializing BootWare:
1.     Loads main images.
2.     If any main image does not exist or is invalid, loads the backup images.
3.     If any backup image does not exist or is invalid, checks the main or backup boot image.
4.     If the main or backup boot image exist and is valid, enters the emergency shell.
5.     If both the main and backup boot images do not exist or are invalid, the device cannot start up.
Handling the emergency shell process or image loading failure
After the device enters the emergency shell, connect to the console port and load a system image so you can access the Comware system. For more information about using the emergency shell, see "Using the emergency shell."
If the device fails to load the images, connect to the console port, power cycle the device, and use the BootWare menu to load new startup images.
Digitally signed software images
The software images for the device are digitally signed for authenticity and integrity verification. This mechanism ensures that the software installed on the system is from a trusted source and has not been tampered with in the transfer, storage, or installation phase.
The system performs software digital signature verification for authenticity and integrity in the following situations:
·     Before the system loads a software image during startup. If the digital signature verification fails, the system will not load the image and you will receive a digital signature verification failure message.
·     When you specify a software image to upgrade the device from the BootWare menu. If the digital signature verification fails, the system will not set the image for upgrade and you will receive a digital signature verification failure message.
·     Before the system loads a BootWare image to the Normal area of BootWare. If the digital signature verification fails, the system will not load the image and you will receive a digital signature verification failure message.
·     When you specify a software image as a startup image through the boot loader. The system will verify the digital signature of the image before it updates the startup image list with the specified image. If the digital signature verification fails, the system will not update the startup image list and you will receive a digital signature verification failure message.
·     When you specify remote startup images for a security engine. The system will verify the digital signatures of the specified images before it copies them to each MPU. If the digital signature verification fails, the system will not copy the images to the MPUs and you will receive a digital signature verification failure message.
·     Before the system activates a feature or patch image. If the digital signature verification fails, the system will not activate the image and you will receive a digital signature verification failure message.
Restrictions and guidelines: Software upgrade
Do not execute the install, issu, or boot-loader command before the current upgrade action completes.
As a best practice, store the startup images in a fixed storage medium. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
Upgrading device software by using the boot loader method (in standalone mode)
1.     Use the display version command to verify the current BootWare image version and startup software version.
2.     Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡     Software and hardware compatibility.
¡     Version and size of the upgrade software.
¡     Compatibility of the upgrade software with the current BootWare image and startup software image.
3.     Use the release notes to verify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image. For more information about licensing, see "Managing licenses."
4.     Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing file systems."
5.     Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system. For more information about FTP and TFTP, see "Configuring FTP" or "Configuring TFTP." For more information about file systems, see "Managing file systems."
Preloading the BootWare image to BootWare
6.     Load the upgrade BootWare image to the Normal area of BootWare.
bootrom update file file  [ subslot subslot-number-list ] [ all | part ]
Specify the downloaded software image file for the file argument.
Support for this command depends on the device model. For more information, see the command reference.
Support for the subslot subslot-number-list option depends on the device model. For more information, see the command reference.
The new BootWare image takes effect at a reboot.
Specifying startup images and completing the upgrade
Perform the following steps in user view:
1.     Specify main or backup startup images.
¡     Use an .ipe file:
boot-loader file ipe-filename { backup | main [ undecompressed ] }
¡     Use .bin files:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { backup | main }
The system will verify the digital signature of the specified images before it updates the startup image list with the specified images. If the digital signature verification fails, the system will not update the startup image list and you will receive a digital signature verification failure message.
2.     Save the running configuration.
save
This step ensures that any configuration you have made can survive a reboot.
3.     Reboot the device.
reboot
4.     (Optional.) Verify the software image settings.
display boot-loader
Verify that the current software images are the same as the startup software images.
Upgrading device software by using the boot loader method (in IRF mode)
4.     Use the dir command to verify that all IRF member devices have sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing file systems."
bootrom update file file slot slot-number-list [ subslot subslot-number-list ] [ all | part ]
The system will verify the digital signature of a BootWare image before it loads it to the Normal area of BootWare. If the digital signature verification fails, the system will not load the image and you will receive a digital signature verification failure message.
1.     Specify main or backup startup images for all member devices.
¡     Use an .ipe file:
boot-loader file ipe-filename { all | slot slot-number } { backup | main [ undecompressed ] }
¡     Use .bin files:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { all | slot slot-number } { backup | main }
As a best practice in a multichassis IRF fabric, specify the all keyword for the command. If you use the slot slot-number option to upgrade member devices one by one, version inconsistencies occur among the member devices during the upgrade.
save
3.     Reboot the IRF fabric.
reboot
display boot-loader [ slot slot-number ]
Synchronizing startup images from the master device to subordinate devices
Perform this task when the startup images on subordinate devices are not the same version as those on the master device.
This task synchronizes startup images that are running on the master device to subordinate devices. If any of the startup images does not exist or is invalid, the synchronization fails.
The startup images synchronized to subordinate devices are set as main startup images, regardless of whether the source startup images are main or backup.
Hardware and feature compatibility
Hardware
Feature compatibility
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G, MSR1004S-5G-CN
No
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL
No
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
Yes
MSR2600-10-X1
No
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
Yes
MSR3600-28-G-DP, MSR3600-51-G-DP
No
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660
Yes
MSR3610-G, MSR3620-G
Yes
MSR3640-G
Yes
MSR3640-X1-HI
Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
If a patch installation has been performed on the master device, use the install commit command to update the set of main startup images on the master device before software synchronization. This command ensures startup image consistency between the master and subordinate devices.
1.     Synchronize startup images from the master to subordinate devices.
boot-loader update { all | slot slot-number }
2.     Reboot the subordinate devices.
reboot slot slot-number [ force ]
Upgrading device software by using install commands
Upgrade tasks at a glance
1.     (Optional.) Decompressing an .ipe file
2.     Installing or upgrading software images
3.     (Optional.) Deactivating software images
4.     (Optional.) Verifying software images
5.     Committing software changes
6.     (Optional.) Deleting inactive software images
1.     (Optional.) Identify images that are included in the .ipe file.
display install ipe-info
2.     Decompress the .ipe file.
install add ipe-filename filesystem
About installing or upgrading software images
You can install a new feature or patch image, or upgrade an existing boot, system, or feature image.
The device requires a boot image and a system image to operate correctly. You can uninstall only feature and patch images.
Software image installation and upgrade methods
Use one of the following methods to activate software images:
·     Slot by slot—Activate all the images on one slot, and then move to the next slot.
·     Image by image—Activate one image on all slots before activating another image. Before using this method, read the release notes to make sure the upgrade images are compatible with the current images. If the upgrade images are not compatible with the current images, the upgrade might fail.
(In IRF mode.) To install an image, you must begin with the master device. To upgrade an image, you must begin with a subordinate device.
The activate operation only updates the current software image list. For the image changes to take effect after a reboot, you must perform a commit operation to update the main startup image list.
Installing or upgrading boot, system, and feature images
To activate boot, system, and feature images, execute the following commands in user view:
1.     Verify that the system is stable.
display system stable state
The system is stable if the System State field displays Stable. For a successful installation or upgrade, you must make sure the system is stable before you proceed to the next step.
2.     Activate images.
In standalone mode:
install activate { boot filename | system filename | feature filename&<1-30> }
In IRF mode:
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number
Installing patch images
To activate patch images, execute the following commands in user view:
The system is stable if the System State field displays Stable. For a successful installation, you must make sure the system is stable before you proceed to the next step.
2.     Activate patch images.
In standalone mode:
install activate patch filename
You can specify only one patch image file for this command at a time. However, you can execute this command multiple times to install multiple patch image files.
In IRF mode:
install activate patch filename { all | slot slot-number }
The install activate patch filename all command installs the specified patch images on all hardware and the images can survive a reboot. You do not need to execute the install commit command for the installation.
You can deactivate only feature and patch images.
The deactivate operation only removes images from the current software image list. For the image changes to take effect after a reboot, you must perform a commit operation to remove the images from the main startup image list.
Deactivated images are still stored on the storage medium. To permanently delete the images, execute the install remove command. For more information, see "Deleting inactive software images."
Deactivating feature images
To deactivate feature images, execute the following commands in user view:
The system is stable if the System State field displays Stable. For a successful deactivate operation, you must make sure the system is stable before you proceed to the next step.
2.     Deactivate feature images.
In standalone mode:
install deactivate feature filename&<1-30>
In IRF mode:
install deactivate feature filename&<1-30> slot slot-number
Deactivating patch images
To deactivate patch images, execute the following commands in user view:
2.     Deactivate patch images.
In standalone mode:
install deactivate patch filename
You can specify only one patch image file for this command at a time. However, you can execute this command multiple times to deactivate multiple patch image files.
In IRF mode:
install deactivate patch filename { all | slot slot-number }
The install deactivate patch filename all command deactivates the specified patch images on all hardware and the image changes can survive a reboot. You do not need to execute the install commit command for the deactivation.
About committing software changes
When you activate or deactivate images for an incremental upgrade, or activate or deactivate patch images, the main startup image list does not update with the changes. The software changes are lost at reboot. For the changes to take effect after a reboot, you must commit the changes.
To commit software changes, execute the following command in user view:
install commit
About software image verification
Perform this task to verify the following items:
·     Integrity—Verify that the boot, system, and feature images are integral.
·     Consistency—Verify that the same active images are running across the entire system.
·     Software commit status—Verify that the active images are committed as needed.
To verify software images, execute the following commands in user view:
1.     Verify software images.
install verify
2.     Activate or deactivate images as required.
install { activate | deactivate }
3.     Commit the software changes.
install commit
About deleting inactive software images
After completing an upgrade, you can use this task to delete old image files permanently.
This task deletes image files permanently.
To delete inactive software image files, execute the following command in user view:
In standalone mode:
install remove { filename | inactive }
In IRF mode:
install remove [ slot slot-number ] { filename | inactive }
Upgrading firmware
Perform this task to upgrade firmware for components that cannot be upgraded when you upgrade Comware. Examples of these components include complex programmable logical devices (CPLDs) and field programmable gate arrays (FPGAs).
After you upgrade firmware for a component, you must power cycle the card where the component resides for the upgrade to take effect.
You can power cycle a card by using one of the following methods:
·     Power cycle the device that holds the card.
·     Remove and reinstall the card.
·     Power cycle the card from the CLI:
¡     power-supply off
¡     power-supply on
Support for these methods depends on the card model.
To upgrade firmware, execute the following command in user view:
In standalone mode:
firmware update [ subslot subslot-number ]  { cpld cpld-number | fpga fpga-number | module module-number } file filename
In IRF mode:
firmware update slot slot-number [ subslot subslot-number ] { cpld cpld-number | fpga fpga-number | module module-number } file filename
Support for this command and the subslot, cpld, fpga, and module parameters depends on the device model. For more information, see the command reference.
Display and maintenance commands for software images
(In standalone mode.) Execute display commands in any view and execute reset commands in user view.
Display running software images and startup software images.
display boot-loader
Display active software images.
display install active [ verbose ]
Display backup startup software images.
display install backup [ verbose ]
Display main startup software images.
display install committed [ verbose ]
Display inactive software images in the root directories of file systems.
display install inactive [ verbose ]
Display the software images included in an .ipe file.
display install ipe-info ipe-filename
Display ongoing activate and deactivate operations.
display install job
Display software image file information.
display install package { filename | all } [ verbose ]
Display the software image file that includes a specific component or file.
display install which { component name | file filename }
(In IRF mode.) Execute display commands in any view and reset commands in user view.
display install active [ slot slot-number ] [ verbose ]
display install backup [ slot slot-number ] [ verbose ]
display install committed [ slot slot-number ] [ verbose ]
display install inactive [ slot slot-number ] [ verbose ]
display install job
display install which { component name | file filename } [ slot slot-number ]
Software upgrade examples
Example: Upgrading device software (in standalone mode)
As shown in Figure 1, use the file startup-a2105.ipe to upgrade software images for the device.
Figure 1 Network diagram
# Configure IP addresses and routes. Make sure the device and the TFTP server can reach each other. (Details not shown.)
# Configure TFTP settings on both the device and the TFTP server. (Details not shown.)
# Display information about the current software images.
<Sysname> display version
# Back up the current software images.
<Sysname> copy boot.bin boot_backup.bin
<Sysname> copy system.bin system_backup.bin
# Specify boot_backup.bin and system_backup.bin as the backup startup image files.
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin backup
# Use TFTP to download the startup-a2105.ipe image file from the TFTP server to the root directory of the flash memory.
<Sysname> tftp 2.2.2.2 get startup-a2105.ipe
# Specify startup-a2105.ipe as the main startup image file.
<Sysname> boot-loader file flash:/startup-a2105.ipe main
# Verify the startup image settings.
<Sysname> display boot-loader
# Reboot the device to complete the upgrade.
<Sysname> reboot
# Verify that the device is running the correct software.
Example: Upgrading device software (in IRF mode)
As shown in Figure 2, use the file startup-a2105.ipe to upgrade software images for the IRF fabric.
Figure 2 Network diagram
# Specify boot_backup.bin and system_backup.bin as the backup startup image files for all IRF member devices.
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin slot 1 backup
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin slot 2 backup
# Use TFTP to download the startup-a2105.ipe image file from the TFTP server to the root directory of the flash memory on the master device.
# Specify startup-a2105.ipe as the main startup image file for all IRF member devices.
<Sysname> boot-loader file flash:/startup-a2105.ipe slot 1 main
<Sysname> boot-loader file flash:/startup-a2105.ipe slot 2 main
<Sysname> reboot
Example: Upgrading a feature by using install commands (in standalone mode)
Upgrade requirements
On the device shown in Figure 3, upgrade the Feature1 feature from T0001015 to T0001016. The two versions are compatible.
Figure 3 Network diagram
Upgrade procedure
# Download the .ipe file that contains the T0001016 Feature1 feature image from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-t0001016.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   256  100  256     0     0    764      0 --:--:-- --:--:-- --:--:--   810
Writing file...Done.
# Decompress the .ipe file.
<Sysname> install add flash:/feature1-t0001016.ipe flash:
Verifying the file flash:/feature1-t0001016.ipe on the device...Done.
Decompressing file feature1-t0001016.bin to flash:/feature1-t0001016.bin.......................Done.
# Display active software images.
<Sysname> display install active
Active packages on the device:
  flash:/boot-t0001015.bin
  flash:/system-t0001015.bin
  flash:/feature1-t0001015.bin
# Identify the recommended upgrade method and possible impact of the upgrade.
<Sysname> install activate feature flash:/feature1-t0001016.bin test
Verifying the file flash:/feature1-t0001016.bin on the device...Done.
  Running Version             New Version
  Test 0001015                Test 0001016
Upgrade Way: Service Upgrade
Influenced service according to following table on the device:
         Feature1
The output shows that a service upgrade is recommended and the Feature1 module will be rebooted during the upgrade process.
# Activate the new Feature1 image to upgrade the Feature1 feature.
This operation might take several minutes, please wait...Done.
# Verify that the new Feature1 image has been activated.
# Commit the software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
Example: Upgrading a feature by using install commands (in IRF mode)
As shown in Figure 4, the IRF fabric has two members.
Upgrade the Feature1 feature from T0001015 to T0001016. The two versions are compatible.
Figure 4 Network diagram
Upgrade procedure
Verifying the file flash:/feature1-t0001016.ipe on slot 1...Done.
Active packages on slot 1:
Active packages on slot 2:
# Identify the recommended upgrade methods and possible impact of the upgrade.
<Sysname> install activate feature flash:/feature1-t0001016.bin slot 2 test
Copying file flash:/feature1-t0001016.bin to slot2#flash:/feature1-t0001016.bin......Done.
Verifying the file flash:/feature1-t0001016.bin on slot 2...Done.
  Slot                        Upgrade Way
  2                           Service Upgrade
Influenced service according to following table on slot 2:
         Feature1
<Sysname> install activate feature flash:/feature1-t0001016.bin slot 1 test
Verifying the file flash:/feature1-t0001016.bin on slot 1...Done.
  Slot                        Upgrade Way
  1                           Service Upgrade
Influenced service according to following table on slot 1:
         Feature1
The output shows that both members need a service upgrade and the Feature1 module will be rebooted during the upgrade.
flash:/feature1-t0001016.bin already exists on slot 2.
Overwrite it?[Y/N]:y
  Slot                        Upgrade Way
  2                           Service Upgrade
  Slot                        Upgrade Way
  1                           Service Upgrade
