| 01-Text | 8.26 MB |
1 Product models and technical specifications
Technical specifications for non-PoE switch models
Technical specifications for PoE switch models
180 W power supply (PSR180-12D-B)
10/100/1000BASE-T autosensing Ethernet port
10/100/1000BASE-T Ethernet port LED
Cloudnet management status LED
Product models
Table1-1 describes the S5136S-EI switch series models.
Table1-1 S5136S switch series models
Model |
Product code (PID) |
Non-PoE switch models |
S5136S-8T4XS-EI-Q |
LS-5136S-8T4XS-EI-Q-GL |
S5136S-10T4X-EI-Q |
LS-5136S-10T4X-EI-Q-GL |
S5136S-16T4X-EI-Q |
LS-5136S-16T4X-EI-Q-GL |
S5136S-24S8T4X-EI |
LS-5136S-24S8T4X-EI-GL |
S5136S-24T4S-EI-Q |
LS-5136S-24T4S-EI-Q-GL |
S5136S-24T4X-EI-Q |
LS-5136S-24T4X-EI-Q-GL |
S5136S-48S2T4X-EI |
LS-5136S-48S2T4X-EI-GL |
S5136S-48ST4X-EI |
LS-5136S-48ST4X-EI-GL |
S5136S-48T4S-EI-Q |
LS-5136S-48T4S-EI-Q-GL |
S5136S-48T4X-EI-Q |
LS-5136S-48T4X-EI-Q-GL |
PoE switch models |
S5136S-8FP4XS-EI-Q |
LS-5136S-8FP4XS-EI-Q-GL |
S5136S-10FPT4X-EI-Q |
LS-5136S-10FPT4X-EI-Q-GL |
S5136S-16FP4X-EI |
LS-5136S-16FP4X-EI-GL |
S5136S-24FP4S4X-EI |
LS-5136S-24FP4S4X-EI-GL |
S5136S-24FP4T4S-EI |
LS-5136S-24FP4T4S-EI-GL |
S5136S-24P4X-EI |
LS-5136S-24P4X-EI-GL |
S5136S-48FP4S-EI |
LS-5136S-48FP4S-EI-GL |
S5136S-48FP4X-EI |
LS-5136S-48FP4X-EI-GL |
S5136S-48P4S-EI |
LS-5136S-48P4S-EI-GL |
S5136S-48P4X-EI |
LS-5136S-48P4X-EI-GL |
NOTE: · To obtain the purchase information, see the product data sheet at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch product lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/. · For information about product and software compatibility, see the release notes. |
Table1-2 Technical specifications for non-PoE switch models (1)
Item |
S5136S-8T4XS-EI-Q |
S5136S-10T4X-EI-Q |
S5136S-16T4X-EI-Q |
Physical specifications |
Dimensions (H × W × D, without package materials) |
44 × 266 × 161 mm (1.73 × 10.47 × 6.34 in) |
44 × 440 × 160 mm (1.73 × 17.32 × 6.30 in) |
Dimensions (H × W × D, with package materials) |
85 × 368 × 275 mm (3.35 × 14.49 × 10.83 in) |
85 × 368 × 277 mm (3.35 × 14.49 ×10.91 in) |
86 × 540 × 280 mm (3.39 × 21.26 × 11.02 in) |
Weight |
≤ 1.1 kg (2.43 lb) |
≤ 1.2 kg (2.65 lb) |
≤ 1.8 kg (3.97 lb) |
Technical specifications |
Memory (RAM) |
2 GB |
Flash |
1 GB |
Port types and quantity |
Console port |
· 1 × serial console port · 1 ×Type-C USB console port Only the Type-C USB console port is available when you connect both ports. |
USB port |
1 |
10/100/1000BASE-T autosensing Ethernet port |
8 |
10 |
16 |
SFP port |
2 |
N/A |
N/A |
SFP+ port |
2 |
4 |
4 |
Power supply specifications |
Power input |
AC input |
· Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz · Max voltage range: 90 VAC to 264 VAC @ 47 Hz to 63 Hz |
Melting current of power supply fuse |
3.15 A/250 V |
10A/250V |
10 A/250 V |
Power consumption |
Power consumption (static) Data collection standard: no load |
5 W |
5 W |
6 W |
Power consumption (with typical configuration) Data collection standard: fully configured with DAC cables or twisted pair cables, 30% loaded |
8 W |
16 W |
13 W |
Power consumption (fully configured) Data collection standard: fully configured with transceiver modules or twisted pair cables, 100% loaded |
16 W |
16 W |
17 W |
Thermal consumption |
Static thermal consumption Data collection standard: no load |
15 BTU/hr |
18 BTU/hr |
20 BTU/hr |
Typical thermal consumption Data collection standard: fully configured with DAC cables or twisted pair cables, 30% loaded |
28 BTU/hr |
55 BTU/hr |
43 BTU/hr |
Maximum thermal consumption Data collection standard: fully configured with transceiver modules or twisted pair cables, 100% loaded |
53 BTU/hr |
55 BTU/hr |
57 BTU/hr |
Heat dissipation |
Heat dissipation method |
Fanless, passive cooling |
Mean Time Between Failure (MTBF) (Year) |
141.230741 |
182.211 |
145.53 |
Mean time to repair (MTTR) (Hour) |
1 |
Availability |
99.999919% |
99.999937% |
99.9999% |
Environment specifications |
Altitude |
5000 m (16404.20 ft) |
Operating temperature |
–5°C to +50°C (23°F to 122°F) Note: The maximum acceptable temperature decreases by 0.33°C (32.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft). |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Relative humidity |
5% RH to 95% RH, noncondensing |
Product compliance |
· Safety standards · EMC standards · Environmental protection and eco-friendly standards |
Table1-3 Technical specifications for non-PoE switch models (2)
Item |
S5136S-24T4S-EI-Q |
S5136S-24T4X-EI-Q |
S5136S-48T4S-EI-Q |
S5136S-48T4X-EI-Q |
44 × 440 × 260 mm (1.73 × 17.32 × 10.24 in) |
125 × 550 × 380 mm (4.92 × 21.65 × 14.96 in) |
Weight |
≤ 2 kg (4.41 lb) |
≤ 2 kg (4.41 lb) |
≤ 3.6 kg (7.94 lb) |
Memory (RAM) |
2 GB |
Flash |
1 GB |
Console port |
USB port |
1 |
24 |
24 |
48 |
48 |
SFP port |
4 |
N/A |
4 |
N/A |
SFP+ port |
N/A |
4 |
N/A |
4 |
Power input |
AC input |
10 A/250 V |
10 A/250 V |
3.15 A/250 V |
3.15 A/250 V |
Power consumption |
6 W |
6 W |
13 W |
13 W |
16 W |
16 W |
30 W |
31 W |
18 W |
21 W |
37 W |
42 W |
20 BTU/hr |
20 BTU/hr |
45 BTU/hr |
45 BTU/hr |
52 BTU/hr |
54 BTU/hr |
103 BTU/hr |
106 BTU/hr |
61 BTU/hr |
70 BTU/hr |
127 BTU/hr |
144 BTU/hr |
Heat dissipation |
122.1 |
122.12 |
128.043 |
118.731 |
1 |
Availability |
99.9999% |
99.9999% |
99.999911% |
99.999904% |
Altitude |
Relative humidity |
Table1-4 Technical specifications for non-PoE models switch (3)
Item |
S5136S-24S8T4X-EI |
S5136S-48S2T4X-EI |
S5136S-48ST4X-EI |
44 × 440 × 360 mm (1.73 × 17.32 × 14.17 in) |
125 × 562 × 550 mm (4.92 × 22.13 × 21.65 in) |
Weight |
≤ 5.4 kg (11.90 lb) |
≤ 5.5 kg (12.13 lb) |
Memory (RAM) |
2 GB |
Flash |
1 GB |
Console port |
USB port |
1 |
8 (Each and its corresponding SFP port form a combo interface.) |
2 (Each and its corresponding SFP port form a combo interface.) |
24 |
SFP port |
16 (The eight highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.) |
48 (The two highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.) |
24 |
SFP+ port |
4 |
4 |
4 |
Power input |
· Removable AC power supply input (no support for HVDC input) · Removable DC power supply input · RPS input (RPS1600-A) |
See "Removable power supplies" |
Power consumption |
Single AC: 11 W Dual AC: 13 W Single DC: 15 W Dual DC: 22 W |
Single AC: 19 W Dual AC: 21 W Single DC: 21 W Dual DC: 29 W |
Single AC: 17 W Dual AC: 19 W Single DC: 20 W Dual DC: 27 W |
Single AC: 12 W Dual AC: 14 W Single DC: 16 W Dual DC: 23 W |
Single AC: 20 W Dual AC: 23 W Single DC: 23 W Dual DC: 31 W |
Single AC: 27 W Dual AC: 29 W Single DC: 29 W Dual DC: 29 W |
Single AC: 35 W Dual AC: 37 W Single DC: 37 W Dual DC: 44 W |
Single AC: 54 W Dual AC: 55 W Single DC: 55 W Dual DC: 61 W |
Single AC: 47 W Dual AC: 49 W Single DC: 47 W Dual DC: 53 W |
Single AC: 37 BTU/hr Dual AC: 44 BTU/hr Single DC: 49 BTU/hr Dual DC: 74 BTU/hr |
Single AC: 62 BTU/hr Dual AC: 69 BTU/hr Single DC: 72 BTU/hr Dual DC: 97 BTU/hr |
Single AC: 57 BTU/hr Dual AC: 64 BTU/hr Single DC: 65 BTU/hr Dual DC: 90 BTU/hr |
Single AC: 41 BTU/hr Dual AC: 48 BTU/hr Single DC: 54 BTU/hr Dual DC: 77 BTU/hr |
Single AC: 68 BTU/hr Dual AC: 76 BTU/hr Single DC: 78 BTU/hr Dual DC: 103 BTU/hr |
Single AC: 91 BTU/hr Dual AC: 99 BTU/hr Single DC: 98 BTU/hr Dual DC: 99 BTU/hr |
Single AC: 118 BTU/hr Dual AC: 127 BTU/hr Single DC: 124 BTU/hr Dual DC: 149 BTU/hr |
Single AC: 184 BTU/hr Dual AC: 187 BTU/hr Single DC: 185 BTU/hr Dual DC: 206 BTU/hr |
Single AC: 158 BTU/hr Dual AC: 167 BTU/hr Single DC: 160 BTU/hr Dual DC: 180 BTU/hr |
Heat dissipation |
Fan tray cooling |
Fan tray cooling |
Fan tray cooling |
Ventilation aisles |
Left to right (facing the front panel) |
110.9488 |
70.8247 |
64.52 |
Mean Time Between Failure (MTBF) (Hour) |
971911.8 |
620424.4 |
565195.3 |
1 |
Availability |
99.9999% |
99.9998% |
99.9998% |
Sound pressure level at 27°C (80.6°F) |
35.2 dB |
35.2 dB |
35.2 dB |
Altitude |
Operating relative humidity |
Table1-5 Technical specifications for PoE switch models (1)
Item |
S5136S-16FP4X-EI |
44 × 266 × 160 mm (1.73 × 10.47 × 6.30 in) |
44 × 330 × 230 mm (1.73 ×12.99 × 9.06 in) |
135 × 555 × 385 mm (5.32 × 21.85 × 15.16 in) |
90 × 425 × 365 mm (3.54 ×16.73 ×14.37 in) |
Weight |
≤ 1.5 kg (3.31 lb) |
≤ 3.8 kg (8.38 lb) |
≤2.3kg |
Memory (RAM) |
2 GB |
Flash |
1 GB |
Console port |
USB port |
1 |
8 |
16 |
24 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.) |
28 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.) |
10 NOTE: Ports 1 to 8 support PoE. |
SFP port |
2 |
N/A |
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.) |
N/A |
SFP+ port |
2 |
4 |
4 |
N/A |
4 |
Power input |
AC input |
6.3 A/250 V |
8 A/250 V |
10 A/250 V |
10 A/250 V |
6.3A/250V |
PoE power capacity |
Maximum PoE power per port |
30 W |
Total PoE power |
125 W |
248 W |
405 W |
405 W |
125 W |
Power consumption |
8 W |
25 W |
23 W |
19 W |
7 W |
10 W |
38 W |
35 W |
29 W |
18 W |
152 W |
317 W |
465 W |
461 W |
147 W |
28 BTU/hr |
86 BTU/hr |
78 BTU/hr |
65 BTU/hr |
24 BTU/hr |
35 BTU/hr |
130 BTU/hr |
119 BTU/hr |
99 BTU/hr |
62 BTU/hr |
519 BTU/hr |
1055 BTU/hr |
1467 BTU/hr |
1454 BTU/hr |
502 BTU/hr |
Heat dissipation |
Fan tray cooling |
Fan tray cooling |
Fan tray cooling |
N/A |
N/A |
137.985 |
67.616 |
50.001 |
51.111 |
133.708 |
1 |
Availability |
99.999917% |
99.999831% |
99.999772% |
99.999777% |
99.999915% |
N/A |
37.6dB |
37.6dB |
37.6dB |
N/A |
Altitude |
Relative humidity |
Table1-6 Technical specifications for PoE switch models (2)
Item |
S5136S-24P4X-EI |
S5136S-48FP4S-EI |
S5136S-48FP4X-EI |
S5136S-48P4S-EI |
S5136S-48P4X-EI |
Weight |
≤ 4.2 kg (9.26 lb) |
≤ 4.1 kg (9.04 lb) |
Memory (RAM) |
2 GB |
Flash |
1 GB |
Console port |
USB port |
1 |
24 |
48 |
48 |
48 |
48 |
SFP port |
N/A |
4 |
N/A |
4 |
N/A |
SFP+ port |
4 |
N/A |
4 |
N/A |
4 |
Power input |
AC input |
8 A/250 V |
16 A/250 V |
16 A/250 V |
10 A/250 V |
10 A/250 V |
30 W |
Total PoE power |
248 W |
770 W |
770 W |
390 W |
390 W |
Power consumption |
29 W |
35 W |
35 W |
29 W |
29 W |
42 W |
56 W |
56 W |
54 W |
54 W |
321 W |
964 W |
969 W |
517 W |
512 W |
99 BTU/hr |
120 BTU/hr |
120 BTU/hr |
99 BTU/hr |
99 BTU/hr |
144 BTU/hr |
192 BTU/hr |
192 BTU/hr |
185 BTU/hr |
185 BTU/hr |
1069 BTU/hr |
3187 BTU/hr |
3204 BTU/hr |
1696 BTU/hr |
1679 BTU/hr |
Heat dissipation |
Fan tray cooling |
Fan tray cooling |
Fan tray cooling |
Fan tray cooling |
Fan tray cooling |
62.64 |
44.653 |
43.464 |
44.366 |
43.192 |
1 |
Availability |
99.999818% |
99.999744% |
99.999737% |
99.999743% |
99.999736% |
37.6 dB |
32.9 dB |
32.9 dB |
37.6 dB |
37.6 dB |
Altitude |
––5°C to +50°C (23°F to 122°F) Note: The maximum acceptable temperature decreases by 0.33°C (32.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft). |
Relative humidity |
2 Chassis views
S5136S-8T4XS-EI-Q
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port |
(2) SFP port |
(3) SFP+ port |
(4) Console port |
(5) USB port |
(6) Type-C USB console port |
(7) Reset button (RESET) |
(8) Mode button (Cloudnet management status LED) |
(9) Location LED (ID) |
(10) System status LED (SYS) |
(11) Mode LED (MODE) |
(12) Management Ethernet port LED (LINK/ACT) |
(13) Management Ethernet port |
(14) SFP+ port LED |
(15) SFP port LED |
(16) 10/100/1000BASE-T autosensing Ethernet port LED |
Figure2-2 Rear panel
(1) Grounding screw |
(2) AC power receptacle |
S5136S-10T4X-EI-Q
Figure2-3 Front panel
(2) SFP+ port |
(3) Console port |
(4) Type-C USB console port |
(5) Reset button (RESET) |
(6) USB port |
(7) Mode button (Cloudnet management status LED) |
(8) Location LED (ID) |
(9) System status LED (SYS) |
(10) Mode LED (MODE) |
(11) Management Ethernet port LED (LINK/ACT) |
(12) Management Ethernet port |
(13) SFP+ port LED |
(14) 10/100/1000BASE-T autosensing Ethernet port LED |
Figure2-4 Rear panel
S5136S-16T4X-EI-Q
Figure2-5 Front panel
(2) SFP+ port |
(3) Management Ethernet port |
(4) USB port |
(5) Type-C USB console port |
(6) Mode LED (MODE) |
(12) Console port |
(13) LED SFP+ port LED |
S5136S-24S8T4X-EI
Figure2-7 Front panel
(1) SFP port |
(2) 10/100/1000BASE-T autosensing Ethernet port |
(3) SFP+ port |
(4) Console port |
(5) USB port |
(8) Reset button (RESET) |
(12) Power supply 2 status LED (PWR2) |
(13) Power supply 1 status LED (PWR1) |
(14) LED Management Ethernet port LED (LINK/ACT) |
(15) Management Ethernet port |
(16) SFP+ port LED |
(17) 10/100/1000BASE-T autosensing Ethernet port LED |
(18) SFP port LED |
(2) Power supply 1 (PWR1) |
(3) Power supply 2 (PWR2) |
The S5136S-24S8T4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-8, two CA-70A12 AC power supplies are installed.
S5136S-24T4S-EI-Q
Figure2-9 Front panel
(2) SFP port |
(3) Console port |
(4) USB port |
(13) SFP port LED |
S5136S-24T4X-EI-Q
Figure2-11 Front panel
(2) SFP+ port |
(4) Console port |
(5) USB port |
(9) Mode LED (MODE) |
(10) Location LED (ID) |
(11) System status LED (SYS) |
Figure2-12 Rear panel
S5136S-48S2T4X-EI
Figure2-13 Front panel
(1) SFP port |
(2) 10/100/1000BASE-T autosensing Ethernet port LED |
(3) 10/100/1000BASE-T autosensing Ethernet port |
(4) Power supply 2 status LED (PWR2) |
(5) USB port |
(6) Mode button (Cloudnet management status LED) |
(7) Location LED (ID) |
(8) System status LED (SYS) |
(10) Power supply 1 status LED (PWR1) |
(11) SFP+ port LED |
(12) SFP+ port |
(13) SFP port LED |
(2) Management Ethernet port |
(3) Management Ethernet port LED (LINK) |
(4) Management Ethernet port LED (ACT) |
(5) Console port |
(8) Power supply 1 (PWR1) |
(9) Power supply 2 (PWR2) |
The S5136S-48S2T4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-14, two CA-70A12 AC power supplies are installed.
S5136S-48ST4X-EI
Figure2-15 Front panel
(2) SFP port |
(3) Management Ethernet port LED (LINK/ACT) |
(4) Management Ethernet port |
(5) Power supply 1 status LED (PWR1) |
(6) Console port |
(7) System status LED (SYS) |
(8) USB port |
(9) Mode button (Cloudnet management status LED) |
(10) Type-C USB console port |
(11) Reset button (RESET) |
(12) Location LED (ID) |
(13) Mode LED (MODE) |
(14) Power supply 2 status LED (PWR2) |
(15) SFP+ port LED |
(16) SFP+ port |
(17) SFP port LED |
(18) 10/100/1000BASE-T autosensing Ethernet port LED |
The S5136S-48ST4X-EI switch has two power supply slots on the rear panel. You can install one or two power supplies for the switch as needed. In Figure2-16, two CA-70A12 AC power supplies are installed.
S5136S-48T4S-EI-Q
Figure2-17 Front panel
(2) Management Ethernet port LED (LINK/ACT) |
(4) Mode LED (MODE) |
(5) Console port |
(6) System status LED (SYS) |
(7) USB port |
(9) Type-C USB console port |
(10) Reset button (RESET) |
(11) Location LED (ID) |
(12) SFP port LED |
(13) SFP port |
S5136S-48T4X-EI-Q
Figure2-19 Front panel
(5) Console port |
(7) USB port |
(12) SFP+ port |
S5136S-8FP4XS-EI-Q
Figure2-21 Front panel
(2) SFP port |
(3) SFP+ port |
(4) Console port |
(5) USB port |
(15) SFP port LED |
Figure2-22 Rear panel
S5136S-10FPT4X-EI-Q
Figure2-23 Front panel
(2) SFP+ port |
(3) Console port |
(6) USB port |
Figure2-24 Rear panel
(1) AC power receptacle |
(2) Grounding screw |
S5136S-16FP4X-EI
Figure2-25 Front panel
(2) SFP+ port |
(3) Console port |
(4) USB port |
(5) Mode button (Cloudnet management status LED) |
(11) Management Ethernet port |
Figure2-26 Rear panel
S5136S-24FP4S4X-EI
Figure2-27 Front panel
(2) SFP port |
(3) SFP+ port |
(4) Console port |
(5) USB port |
(7) Type-C USB console port |
(15) SFP port LED |
Figure2-28 Rear panel
S5136S-24FP4T4S-EI
Figure2-29 Front panel
(2) SFP port |
(3) Console port |
(4) USB port |
(13) SFP port LED |
Figure2-30 Rear panel
S5136S-24P4X-EI
Figure2-31 Front panel
(2) SFP+ port |
(3) Console port |
(4) USB port |
Figure2-32 Rear panel
S5136S-48FP4S-EI
Figure2-33 Front panel
(5) Console port |
(7) USB port |
(12) SFP port LED |
(13) SFP port |
Figure2-34 Rear panel
S5136S-48FP4X-EI
Figure2-35 Front panel
(5) Console port |
(7) USB port |
(12) SFP+ port LED |
(13) SFP+ port |
Figure2-36 Rear panel
S5136S-48P4S-EI
Figure2-37 Front panel
(5) Console port |
(7) USB port |
(12) SFP port LED |
(13) SFP port |
Figure2-38 Rear panel
S5136S-48P4X-EI
Figure2-39 Front panel
(5) Console port |
(7) USB port |
(12) SFP+ port |
3 Removable components
Some switch models use removable power supplies. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between switches and removable components
Removable component model |
S5136S-24S8T4X-EI S5136S-48ST4X-EI S5136S-48S2T4X-EI |
Removable power supplies |
CA-70A12 |
Supported |
PSR75-12A |
Supported |
PSR180-12D-B |
Supported |
One power supply can meet the power requirement of the switch. You can install two power supplies on the switch for 1+1 redundancy. The device supports installation of both an AC power supply and a DC power supply.
The removable components available for the switch are subject to change over time. For the most recent list of the removable components, see the release notes for the switch.
You can use the display device manuinfo power command to read the electrical label information of the power supplies. The CA-70A12 power supply does not support electrical label information reading.
4 Removable power supplies
70 W power supply (CA-70A12)
View
Figure4-1 CA-70A12 power supply view
Functions
The CA-70A12 is an AC and DC input and DC output power supply. It provides a maximum output of 70 W.
Table4-1 CA-70A12 power supply features
Feature |
Protection function |
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions. |
Support for redundancy |
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing. |
Support for hot swapping |
You can remove one of the power supplies in 1+1 redundancy when the switch is operating. |
Table4-2 Technical specifications
Item |
Specification |
Dimensions (H × W × D, including the handle) |
41.1 × 101.6 × 207 mm (1.62 × 4.00 × 8.15 in) |
Weight |
0.6 kg (1.32 lb) |
Rated input voltage range |
AC input: 100 VAC to 240 VAC @ 50 Hz or 60 Hz HVDC input: 240 VDC |
Max input voltage range |
AC input: 90 VAC to 290 VAC @ 47 Hz to 63 Hz HVDC input: 180 VDC to 320 VDC |
Rated input current |
N/A |
Rated output current |
5.83 A |
Rated output voltage |
12 V |
Rated output power |
70 W |
10 A/250 V |
75 W power supply (PSR75-12A)
View
Figure4-2 PSR75-12A power supply view
(1) Mounting screws |
(2) Power input receptacle |
(3) Latch |
(4) Handle |
Functions
The PSR75-12A is an AC and DC input and DC output power supply. It provides a maximum output of 75 W.
Table4-3 PSR75-12A power supply features
Feature |
Table4-4 Technical specifications
Item |
Specification |
Weight |
0.72 kg (1.59 lb) |
N/A |
6.3 A |
12 V |
75 W |
3.15 A/250 V |
View
Figure4-3 PSR180-12D-B power supply view
Functions
The PSR180-12D-B is a DC input and DC output power supply. It provides a maximum output of 180 W.
Table4-5 PSR180-12D-B power supply features (1)
Feature |
The power supply provides protection against output overvoltage, shortcircuit, current limiting, and overtemperature conditions. |
You can remove one of the power supplies in 1+1 redundancy when the switch is operating. Before removing the power supply, disconnect the power supply from the external power supply system. |
Table4-6 PSR180-12D-B power supply features (2)
PSR180-12D-B |
Protection state |
Support for auto-recovery |
The power supply is locked and does not supply power. |
Not supported. |
Shortcircuit protection |
Not supported. |
Overcurrent protection |
Not supported. |
Overtemperature protection |
The power supply does not supply power. |
The power supply automatically restores power supply after the temperature decreases to an acceptable range. |
After a power supply is locked, it cannot automatically restore power supply after the problems are resolved. Follow this procedure to restore the power supply operation:
1. Disconnect the power cord from the external power supply system.
2. Disconnect the power cord from the power supply and then reconnect it.
3. Connect the power cord to the external power supply system.
Table4-7 Technical specifications
Item |
Specification |
101.6 × 41.1 × 177 mm (4.00 × 1.62 × 6.97 in) |
Weight |
0.8 kg (1.76 lb) |
–48 VDC to –60 VDC |
–36 VDC to –72 VDC |
N/A |
15 A |
12 V |
180 W |
8 A/125 V |
5 Ports and LEDs
Ports
Console port
Table5-1 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
Compliant standard |
EIA/TIA-232 |
Transmission baud rate |
9600 bps (default) to 115200 bps |
Services |
· Provides connection to an ASCII terminal · Provides connection to the serial port of a local PC running terminal emulation program |
Compatible switch models |
All switch models |
The switch has one management Ethernet port on the front panel. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table5-2 Management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Transmission rate, duplex mode, and auto MDI/MDI-X |
· 10 Mbps, half/full-duplex · 100 Mbps, half/full-duplex · MDI/MDI-X, autosensing |
Transmission medium |
Category-5 or above twisted pair cable |
Max transmission distance |
100 m (328.08 ft) |
IEEE 802.3i IEEE 802.3u IEEE 802.3ab |
Functions and services |
Used for upgrading and managing applications and Boot ROM |
All switch models |
Table5-3 10/100/1000BASE-T autosensing Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
· 10 Mbps, half/full-duplex · 100 Mbps, half/full-duplex · 1000 Mbps, full-duplex · MDI/MDI-X, autosensing |
100 m (328.08 ft) |
All switch models |
SFP port
Table5-4 SFP port specifications
Item |
Specification |
Available transceiver modules and cables |
· See FE SFP transceiver modules described in Table5-5. · See GE SFP transceiver modules and cables described in Table5-6. |
S5136S-8FP4XS-EI-Q, S5136S-8T4XS-EI-Q, S5136S-24T4S-EI-Q, S5136S-48T4S-EI-Q, S5136S-24FP4S4X-EI, S5136S-24FP4T4S-EI, S5136S-24S8T4X-EI, S5136S-48FP4S-EI, S5136S-48P4S-EI, S5136S-48S2T4X-EI, S5136S-48ST4X-EI |
Restrictions and guidelines |
· To use the SFP-GE-T, SFP-GE-T-D, or transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the following switch models, make sure the ambient temperature does not exceed 40°C (104°F). ¡ S5136S-8T4XS-EI-Q ¡ S5136S-8FP4XS-EI-Q ¡ S5136S-48T4S-EI-Q ¡ S5136S-48S2T4X-EI ¡ S5136S-48ST4X-EI ¡ S5136S-24S8T4X-EI ¡ S5136S-24T4S-EI-Q · When you use the following transceiver modules on an S5136S-48S2T4X-EI or S5136S-48ST4X-EI switch, make sure the number of the transceiver modules does not exceed 30. ¡ SFP-GE-T. ¡ SFP-GE-T-D. ¡ Transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles). · The S5136S-8T4XS-EI-Q, S5136S-8FP4XS-EI-Q, S5136S-48T4S-EI-Q, S5136S-24T4S-EI-Q, S5136S-48P4S-EI, and S5136S-48FP4S-EI switches do not support FE SFP transceiver modules. |
Table5-5 FE SFP transceiver modules available for the SFP ports
FE SFP transceiver module |
Central wavelength (nm) |
Connector |
Fiber type and diameter (µm) |
SFP-FE-SX-MM1310-A |
1310 |
LC |
Multi-mode, 50/125 |
2 km (1.24 miles) |
Multi-mode, 62.5/125 |
SFP-FE-LX-SM1310-A |
1310 |
LC |
Single-mode, 9/125 |
15 km (9.32 miles) |
SFP-FE-LX-SM1310-D |
1310 |
LC |
SFP-FE-LH40-SM1310 |
1310 |
LC |
40 km (24.86 miles) |
SFP-FE-LH80-SM1550 |
1550 |
LC |
80 km (49.71 miles) |
SFP-FE-LX-SM1310-BIDI |
TX: 1310 RX: 1550 |
LC |
SFP-FE-LX-SM1550-BIDI |
TX: 1550 RX: 1310 |
LC |
SFP-FE-BX15-U-SM1310 |
1310 |
LC |
IMPORTANT: The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module. |
Table5-6 GE SFP transceiver modules and cables available for the SFP ports
GE SFP transceiver module/cable |
Connector |
Cable/Fiber type and diameter (µm) |
Modal bandwidth (MHz*km) |
Max. transmission distance |
SFP copper transceiver modules |
SFP-GE-T |
N/A |
RJ-45 |
Twisted pair cable |
N/A |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP optical transceiver modules |
SFP-GE-SX-MM850-A |
850 |
LC |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
500 |
400 |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-S |
850 |
LC |
500 |
400 |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-LX-SM1310-A |
1310 |
LC |
N/A |
10 km (6.21 miles) |
500/400 |
500 |
SFP-GE-LX-SM1310-D |
1310 |
LC |
N/A |
SFP-GE-LX-SM1310-S |
1310 |
LC |
N/A |
SFP-GE-LH40-SM1310 |
1310 |
LC |
N/A |
SFP-GE-LH40-SM1310-D |
1310 |
LC |
N/A |
SFP-GE-LH40-SM1550 |
1550 |
LC |
N/A |
SFP-GE-LH80-SM1550 |
1550 |
LC |
N/A |
SFP-GE-LH80-SM1550-D |
1550 |
LC |
N/A |
SFP-GE-LH100-SM1550 |
1550 |
LC |
N/A |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
TX: 1310 RX: 1490 |
LC |
N/A |
SFP-GE-LX-SM1490-BIDI |
TX: 1490 RX: 1310 |
LC |
N/A |
SFP-GE-LH40-SM1310-BIDI |
TX: 1310 RX: 1550 |
LC |
N/A |
SFP-GE-LH40-SM1550-BIDI |
TX: 1550 RX: 1310 |
LC |
N/A |
SFP-GE-LH70-SM1490-BIDI |
TX: 1490 RX: 1550 |
LC |
N/A |
70 km (43.50 miles) |
SFP-GE-LH70-SM1550-BIDI |
TX: 1550 RX: 1490 |
LC |
N/A |
SFP cable |
SFP-STACK-Kit |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
IMPORTANT: The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module. |
NOTE: · As a best practice, use H3C transceiver modules and cables for the switch. · The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff. · For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide. |
SFP+ port
Table5-7 SFP+ port specifications
Item |
Specification |
· See GE SFP transceiver modules and cables described in Table5-6 · See 10GE SFP+ transceiver modules and cables described in Table5-8 and Table5-9 |
S5136S-8FP4XS-EI-Q, S5136S-10FPT4X-EI-Q, S5136S-8T4XS-EI-Q, S5136S-10T4X-EI-Q, S5136S-16T4X-EI-Q, S5136S-24T4X-EI-Q, S5136S-48T4X-EI-Q, S5136S-16FP4X-EI, S5136S-24FP4S4X-EI, S5136S-24P4X-EI, S5136S-24S8T4X-EI, S5136S-48FP4X-EI, S5136S-48P4X-EI, S5136S-48S2T4X-EI, S5136S-48ST4X-EI |
· To use the SFP-GE-T, SFP-GE-T-D, or transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the following switch models, make sure the ambient temperature does not exceed 40°C (104°F). ¡ S5136S-8T4XS-EI-Q ¡ S5136S-10T4X-EI-Q ¡ S5136S-10FPT4X-EI-Q ¡ S5136S-8FP4XS-EI-Q ¡ S5136S-48T4X-EI-Q ¡ S5136S-48S2T4X-EI ¡ S5136S-48ST4X-EI ¡ S5136S-24S8T4X-EI ¡ S5136S-24T4X-EI-Q ¡ S5136S-16T4X-EI-Q · When you use the following transceiver modules on an S5136S-48S2T4X-EI or S5136S-48ST4X-EI switch, make sure the number of the transceiver modules does not exceed 30. ¡ SFP-GE-T. ¡ SFP-GE-T-D. ¡ Transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles). · The following switches do not support the SFP-XG-CPRI-IR-SM1310 and SFP-XG-CPRI-LR-SM1310 transceiver modules: ¡ S5136S-48S2T4X-EI ¡ S5136S-48ST4X-EI ¡ S5136S-24S8T4X-EI ¡ S5136S-24T4X-EI-Q ¡ S5136S-16T4X-EI-Q ¡ S5136S-24T4S-EI-Q |
Table5-8 10GE SFP+ transceiver modules available for the SFP+ ports
10GE SFP+ transceiver module |
Connector |
SFP-XG-SX-MM850-D |
850 |
LC |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-S |
850 |
LC |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310-D |
1310 |
LC |
N/A |
SFP-XG-LX-SM1310-E |
1310 |
LC |
N/A |
SFP-XG-LX-SM1310-S |
1310 |
LC |
Single-mode |
N/A |
SFP-XG-LH40-SM1550 |
1550 |
LC |
N/A |
SFP-XG-LH40-SM1550-D |
1550 |
LC |
N/A |
SFP-XG-LH80-SM1550 |
1550 |
LC |
N/A |
SFP-XG-LH80-SM1550-D |
1550 |
LC |
N/A |
SFP-XG-LX-SM1270-BIDI |
TX: 1270 RX: 1330 |
LC |
N/A |
SFP-XG-LX-SM1330-BIDI |
TX: 1330 RX: 1270 |
LC |
N/A |
SFP-XG-LH40-SM1270-BIDI |
TX: 1270 RX: 1330 |
LC |
N/A |
SFP-XG-LH40-SM1330-BIDI |
TX: 1330 RX: 1270 |
LC |
N/A |
SFP-XG-CPRI-IR-SM1310 |
1310 |
LC |
N/A |
1.4 km (0.87 miles) |
SFP-XG-CPRI-LR-SM1310 |
1310 |
LC |
N/A |
SFP-XG-LH80-SM1490-BIDI |
Tx: 1490 Rx: 1550 |
LC |
N/A |
SFP-XG-LH80-SM1550-BIDI |
Tx: 1550 Rx: 1490 |
LC |
N/A |
IMPORTANT: The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, and SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module. |
Table5-9 10GE SFP+ copper and fiber cables available for the SFP+ ports
10GE SFP+ cable |
Cable length |
SFP+ copper cable |
LSWM1STK |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
SFP+ fiber cable |
SFP-XG-D-AOC-7M |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
Figure5-1 SFP+ cable
(1) Connector |
(2) Pull latch |
Combo interface
An S5136S-48S2T4X-EI switch provides two fixed combo interfaces on the front panel. An S5136S-24FP4S4X-EI or S5136S-24FP4T4S-EI switch provides four fixed combo interfaces on the front panel. An S5136S-24S8T4X-EI switch provides eight fixed combo interfaces on the front panel.
Each combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports operates at a time.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table5-10 System status LED description
LED mark |
Status |
SYS |
Steady yellow |
Boot ROM booting stage. |
Steady green |
Linux kernel booting stage, or the switch has started up correctly. |
Flashing green (1 Hz) |
Software image loading and decompressing stage, or software booting stage. |
Steady red |
The switch has failed POST or the switch is faulty. |
Off |
The switch is powered off or has not started up correctly. |
Table5-11 Management Ethernet port LED description
LED mark |
Status |
ACT/LINK |
Steady green |
A link is present on the port. |
Flashing green |
The port is receiving or sending data. |
Off |
No link is present on the port. |
Power supply status LED
The S5136S-24S8T4X-EI, S5136S-48S2T4X-EI, and S5136S-48ST4X-EI switches each provide two removable power supply slots on the rear panel. The power supply status LEDs on the front panel indicate the operating status of the power supplies.
Table5-12 Power supply status LED description
LED mark |
Status |
PWR1/PWR2 |
Steady green |
A power supply is installed in the power supply slot, and the power supply is outputting power correctly. |
Steady yellow |
A power supply is installed in the power supply slot, but the power supply is faulty or not powered on. |
Off |
No power supply is installed in the power supply slot. |
Mode LED
The mode LED works in conjunction with the port LEDs to indicate the operating state of the ports and the switch.
· The mode LED indicates the type of information that the port LEDs are showing.
· You can use the mode button to change the indication of the mode LED. After you press the mode button for the mode LED to steady yellow, flashing green, or flashing yellow, the mode LED keeps that state for only 45 seconds and then turns steady green automatically.
· You can use the mode button to change the indication of the mode LED. After you press the mode button for the mode LED to steady yellow, the LED for the uplink port turns off and is not displayed.
· With the push-button mode enable command executed on the device, if you press the mode button for 5 to 10 seconds, the device will be deployed to Cloudnet or will be disconnected from Cloudnet based on the connection status with Cloudnet. Pressing the mode button for up to 5 seconds can change the port information for the port LED. Pressing the mode button for more than 10 seconds does not take effect, because the device is not managed by Cloudnet or has been disconnected from Cloudnet.
Table5-13 Mode LED description
LED mark |
Status |
MODE |
Steady green |
The port LEDs are showing link state of the ports. |
Flashing green |
The port LEDs are showing the PoE status of the ports. |
Steady yellow |
The port LEDs are showing the duplex status of the ports. |
Flashing yellow |
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 3 is steady green, the IRF member ID of the switch is 3. |
SFP/SFP+ port LED
Table5-14 SFP/SFP+ port LED description
LED status |
Steady green |
Flashing green |
Off |
· No link is present on the port. · The mode LED is operating in PoE mode (available only for PoE switch models). · The mode LED is operating in duplex mode. |
The Ethernet port LEDs work in conjunction with the mode LED to indicate the operating state of the Ethernet ports and the switch from different aspects. Table5-15 describes the Ethernet port LEDs on a PoE switch. Table5-16 describes the Ethernet port LEDs on a non-PoE switch.
Table5-15 Ethernet port LED description for PoE switch models
Mode LED status (MODE) |
Ethernet port LED status |
Steady green (Link/Active mode) |
Steady green |
Flashing green |
Off |
Flashing green (PoE mode) |
Steady green |
PoE power supply is normal. |
· The maximum PoE power provided by the port fails to meet the power requirement of the PD. · PoE power supply overcurrent, overvoltage, or shortcircuit occurs. · The remaining power of the switch fails to meet the power supply requirement of the port. |
Off |
The port is not connected to a PD or PoE is not enabled on the port. |
Steady yellow |
Steady green |
The downlink port is operating in half duplex mode. |
Flashing green |
The downlink port is operating in full duplex mode. |
Off |
No link is present on the downlink port. |
Flashing yellow (IRF mode) |
Steady green |
The Ethernet port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green, the IRF member ID of the switch is 5. |
Table5-16 Ethernet port LED description for non-PoE switch models
Steady green |
Flashing green |
Off |
Steady yellow |
Steady green |
Flashing green |
Off |
Steady green |
Table5-17 Cloudnet management status LED description
LED status |
Steady blue |
The switch has been managed by Cloudnet. |
Flashing blue (1 Hz) |
The switch is being connected to Cloudnet. |
Flashing blue (3 Hz) |
Invalid action. The switch is not managed by Cloudnet or has been disconnected from Cloudnet. |
Off |
The switch is not connected to Cloudnet. |
Location LED
To identify the switch location, execute the locator blink blink-time command. This LED will flash blue at 1 Hz.
6 Buttons
Reset button
Figure6-1 Reset button description
Button |
Reset button |
· To reboot the switch, press and hold the button for less than 5 seconds and release the button when the SYS LED flashes red slowly (1 Hz). · To restore the factory default and reboot the switch, press and hold the button for more than 5 seconds and release the button when the SYS LED flashes red rapidly (8 Hz). After the switch joins an IRF fabric, the operation does not take effect and the system generates a message. To restore the factory default and reboot the switch via the reset button, first remove the switch from the IRF fabric. |
7 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
Switch model |
Fan tray type |
Airflow direction |
S5136S-8FP4XS-EI-Q S5136S-8T4XS-EI-Q S5136S-10FPT4X-EI-Q S5136S-10T4X-EI-Q S5136S-16T4X-EI-Q S5136S-24T4S-EI-Q S5136S-24T4X-EI-Q S5136S-48T4S-EI-Q S5136S-48T4X-EI-Q |
Fanless |
Passive cooling |
S5136S-16FP4X-EI S5136S-24FP4S4X-EI S5136S-24FP4T4S-EI S5136S-24P4X-EI S5136S-24S8T4X-EI S5136S-48FP4S-EI S5136S-48FP4X-EI S5136S-48P4S-EI S5136S-48P4X-EI S5136S-48S2T4X-EI S5136S-48ST4X-EI |
Fixed fan trays |
From the left side to the right side |
Figure7-1 Airflow through the S5136S-48S2T4X-EI chassis
