09-MPLS
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Diagnose & MaintainTroubleshootingH3C MSR5680-X3 Router Troubleshooting Guide(V9)-R9141-6W10009-MPLS
02-Generic MPLS L2VPN and VPLS Troubleshooting Guide
Troubleshooting MPLS
Troubleshooting MPLS L2VPN/VPLS
A PW failed to be pinged
Symptom
Execute the ping mpls pw command to test PW connectivity. However, the remote end cannot be pinged.
Common causes
The following are the common causes of this type of issue:
·     The PW being tested does not exist.
·     The PW template configuration is incorrect.
·     The PW has failed.
·     The PW does not have a valid forwarding path on the public network.
Analysis
To troubleshoot this type of issue, execute the ping mpls pw command, and then identify the cause of the issue depending on the received error message.
·     If you receive the Unknown PW error message, the issue occurs because the PW does not exist. You must modify the configuration to make sure the PW can be created correctly.
·     If the error message is No suitable control channel for the PW, check for VCCV control channel type misconfiguration. Then, execute the vccv cc command to specify the correct VCCV control channel type in the PW template.
·     If the error message is Please configure pseudowire control-word for control channel, execute the control-word enable command to enable the control word feature in the PW template.
·     If the error message is Request time out, identify whether the local PW is up, and then execute the tracert mpls pw command to locate the faulty node.
Figure 1 shows the troubleshooting flowchart.
Figure 1 Flowchart for troubleshooting ping failure
Solution
To resolve the issue:
If you receive the Unknown PW message, modify the configuration to ensure that the PW can be correctly created.
If you receive the No suitable control channel for the PW message, execute the vccv cc command to configure the same VCCV control channel type for both ends.
If you receive the Please configure pseudowire control-word for control channel message, execute the control-word enable command to enable the control word feature in the PW template.
If you receive the Request time out message, perform the following steps:
1.     Execute the display l2vpn pw command to verify that the PW is up.
<Sysname> display l2vpn pw
       N - no split horizon, A - administration, ABY - ac-bypass
       PBY - pw-bypass
Total number of PWs: 2
2 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: ldp
Peer            PWID/RmtSite/SrvID In/Out Label   Proto  Flag Link ID  State
192.3.3.3       500                1299/1299      LDP    M    0        Up
VSI Name: aaa
2.2.2.9         2                  1420/1419      BGP    M    9        Up
¡     If the PW is in Down state, execute the display l2vpn pw verbose command to check for the failure reason and troubleshoot the issue.
<Sysname> display l2vpn pw verbose
VSI Name: aaa
  Peer: 2.2.2.9          Remote Site: 2
    Signaling Protocol  : BGP
    Link ID             : 9          PW State : Down
    In Label            : 1420       Out Label: 1419
    MTU                 : 1500
    PW Attributes       : Main
    VCCV CC             : -
    VCCV BFD            : -
    Flow Label          : Send
    Control Word        : Disabled
    Tunnel Group ID     : 0x800000960000000
    Tunnel NHLFE IDs    : 1038
    Admin PW            : -
    E-Tree Mode         : -
    E-Tree Role         : root
    Root VLAN           : -
    Leaf VLAN           : -
    Down Reasons        : Control word not match
The common causes of this type of issue are as follows:
-     BFD session for PW down—The BFD session for PW detection is down. To resolve this issue, execute the display bfd session command to display BFD session information. Check and edit BFD configuration or check the physical link for link failure or link quality issues.
-     BGP RD was deleted—The BGP RD has been deleted. To resolve this issue, execute the route-distinguisher route-distinguisher command in auto-discovery VSI view.
-     BGP RD was empty—No BGP RD is configured. To resolve this issue, execute the route-distinguisher route-distinguisher command in auto-discovery VSI view.
-     Control word not match—The control word configuration on the two ends of the PW is inconsistent. To resolve this issue, execute the control-word enable command to enable the control word feature on both ends.
-     Encapsulation not match—The encapsulation types on the two ends of the PW are inconsistent. Execute the pw-type command to configure the same encapsulation type for the two ends.
-     LDP interface parameter not match—The LDP negotiation parameters on the two ends of the PW are inconsistent. To resolve this issue, execute the vccv cc command to specify the same VCCV control channel (CC) type. Alternatively, specify the same CEM class for the CEM interfaces on both ends of the PW.
-     Non-existent remote LDP PW—The remote device has deleted the LDP PW. To resolve the issue, reconfigure the LDP PW on the remote device.
-     Local AC Down—The local AC is down. To resolve the issue, check and edit the configuration on the AC interface or troubleshoot the issue on the interface where the AC is located and make Assurance interface is in up state.
-     Local AC was non-existent—The local AC did not exist. To resolve this issue, configure a local AC and associate it with a VSI.
-     MTU not match—The MTU is not the same at the two ends of the PW. To resolve the issue, configure the same MTU at both ends of the PW or use the mtu-negotiate disable command to disable MTU negotiation.
-     Remote AC Down—The remote AC is down. Check and edit the configuration on the AC interface or troubleshoot the issue on the interface where the AC is located and make Assurance interface is in up state.
¡     If the PW is in up state, go to step 2.
2.     Execute the display l2vpn forwarding pw verbose command to verify that the In Label, Out Label, and Tunnel NHLFE IDs related to the tunnel that carries the PW are valid.
<Sysname> display l2vpn forwarding pw verbose
Xconnect-group Name: xcg1
 Connection Name: c1
  Link ID: 0
    PW Type           : VLAN                  PW State : Up
    In Label          : 110126                Out Label: 130126
    MTU               : 1500
    VCCV CC           : Router-Alert
    VCCV BFD          : Fault Detection with BFD
    Flow Label        : -
    Tunnel Group ID   : 0x800000130000001
    Tunnel NHLFE IDs  : 3
VSI Name: aaa
  Link ID: 8
    In Label        : 1272                  Out Label: 1275
    MTU             : 1500
    VCCV CC         : -
    Flow Label      : -
    Tunnel Group ID : 0x960000000
    Tunnel NHLFE IDs: 1034
¡     If the values for the incoming and outgoing labels are empty or a hyphen (-), first execute the display l2vpn pw verbose command to check for the protocol that established the PW and then edit the configuration as follows:
-     If the protocol is BGP, check and edit BGP configuration.
-     If the protocol is LDP, check and edit LDP configuration.
-     If the protocol is Static, check and edit static PW configuration.
For more information about protocol that are used establish PWs, see MPLS L2VPN and VPLS in the MPLS Configuration Guide for your device.
¡     If no value is available for the Tunnel NHLFE IDs field, go to step 3.
¡     If the forwarding information for the PW is normal, go to step 4.
3.     Execute the display mpls lsp command to check for the tunnel that carries the PW. The tunnel is an LSP with the FEC as the PW peer IP address. If it does not exist, establish the tunnel that carries the PW.
<Sysname> display mpls lsp
FEC                         Proto    In/Out Label    Out Inter/NHLFE/LSINDEX
100.100.100.100/24          LDP      -/1049          GE1/0/1
4.     If the issue persists, collect the following information and contact Technical Support:
¡     Results of each step.
¡     The configuration file, log messages, and alarm messages.
¡     Use the display diagnostic-information command to collect diagnostic information.
Related alarm and log messages
Alarm messages
None.
Log messages
·     L2VPN/2/L2VPN_PWSTATE_CHANGE
·     L2VPN/4/L2VPN_BGPVC_CONFLICT_LOCAL
·     L2VPN/4/L2VPN_BGPVC_CONFLICT_REMOTE
·     L2VPN/4/L2VPN_HARD_RESOURCE_NOENOUGH
·     L2VPN/2/L2VPN_HARD_RESOURCE_RESTORE
·     L2VPN/4/L2VPN_LABEL_DUPLICATE
