01-OpenFlow configuration | 444.45 KB |
Restrictions: Licensing requirements for OpenFlow
Restrictions and guidelines: OpenFlow configuration
Configuring OpenFlow instances
Configuring the OpenFlow instance mode
Configuring inband management VLANs
Configuring flow tables and flow entries for an OpenFlow instance
Setting the controller connection mode
Preventing an OpenFlow instance from reporting the specified types of ports to controllers
Enabling support for smart group entries
Activating or reactivating an OpenFlow instance
Configuring OpenFlow instance attributes
Configuring controllers for an OpenFlow switch
Configuring an OpenFlow instance to act as an SSL server to listen to controllers
Refreshing all Layer 3 flow entries in the MAC-IP flow tables for an OpenFlow instance
Ignoring the permit flag added by OpenFlow
Shutting down an interface by OpenFlow
Enabling SNMP notifications for OpenFlow
Configuring OpenFlow flow monitor parameters
Display and maintenance commands for OpenFlow
OpenFlow configuration examples
Example: Configuring OpenFlow in VLAN mode
Restrictions for merging the action list into the action set
Packet-out messages restrictions
Packet-in messages restrictions
Flow table modification messages restrictions
Capabilities supported by the MAC-IP flow table
MAC-IP flow table restrictions
Table-miss flow entry of MAC-IP flow tables
MAC-IP flow table cooperating with extensibility flow table
Capabilities supported by the VLAN tagging flow table
Capabilities supported by the VLAN untagging flow table
Multi-level table-based TTP pipeline
Table-miss flow entry of TTP flow tables
Capabilities supported by the TTP-ingress-port flow table
Capabilities supported by the TTP-VLAN flow table
Capabilities supported by the TTP-termination-MAC flow table
Capabilities supported by the TTP-unicast-routing flow table
Capabilities supported by the TTP-bridging flow table
Capabilities supported by the TTP-ingress-ACL flow table
Capabilities supported by the TTP-egress-ACL flow table
Capabilities supported by the TTP-L2-interface-group flow table
Capabilities supported by the TTP-L3-unicast-group flow table
Capabilities supported by the TTP-L3-ECMP-group table
About OpenFlow
OpenFlow is the communications interface defined between the control and forwarding layers of a Software-Defined Networking architecture. With OpenFlow, you can perform centralized data forwarding management for physical and virtual devices through controllers.
OpenFlow network components
OpenFlow separates the data forwarding and routing decision functions. It keeps the flow-based forwarding function and employs a separate controller to make routing decisions. An OpenFlow switch communicates with the controller through an OpenFlow channel. An OpenFlow channel can be encrypted by using TLS or run directly over TCP. An OpenFlow switch exchanges control messages with the controller through an OpenFlow channel to perform the following operations:
· Receive flow table entries or data from the controller.
· Report information to the controller.
Unless otherwise stated, a switch refers to an OpenFlow switch throughout this document.
Figure 1 OpenFlow network diagram
OpenFlow switch
OpenFlow switches include the following types:
· OpenFlow-only—Supports only OpenFlow operation.
· OpenFlow-hybrid—Supports both OpenFlow operation and traditional Ethernet switching operation.
OpenFlow port
OpenFlow supports the following types of ports:
· Physical port—Corresponds to a hardware interface, such as an Ethernet interface. A physical port can be either an ingress port or an output port.
· Logical port—Does not correspond to a hardware interface and might be defined by non-OpenFlow methods. For example, aggregate interfaces are logical ports. A Layer 2 aggregate interface can be an ingress port or an output port. A Layer 3 aggregate interface can be an ingress port.
· Reserved port—Defined by OpenFlow to specify forwarding actions. Reserved ports include the following types:
¡ Controller—OpenFlow controller.
¡ Local—Local CPU.
¡ Normal—Normal forwarding process.
OpenFlow instance
Unless otherwise stated, an OpenFlow switch refers to an OpenFlow instance throughout this document.
You can configure one or more OpenFlow instances on the same device. A controller considers each OpenFlow instance as a separate OpenFlow switch and deploys forwarding instructions to it.
An OpenFlow instance operates in one of the following modes:
· Global mode—When the global mode is enabled for an OpenFlow instance, the flow entries take effect on packets within the network. All service interfaces on the device belong to the OpenFlow instance.
· VLAN mode—When the VLAN mode is enabled for an OpenFlow instance, the flow entries take effect only on packets within VLANs associated with the OpenFlow instance. You must associate the OpenFlow instance with VLANs. All interfaces in the associated VLANs belong to the OpenFlow instance.
Activation and reactivation
The configurations for an OpenFlow instance take effect only after the OpenFlow instance is activated.
The controller can deploy flow entries to an OpenFlow instance only after the OpenFlow instance reports the following device information to the controller:
· Capabilities supported by OpenFlow.
· Information about ports that belong to the OpenFlow instance.
An activated OpenFlow instance must be reactivated when any of the OpenFlow instance configurations are changed.
After reactivation, the OpenFlow instance is disconnected from all controllers and then reconnected to them.
OpenFlow instance port
An OpenFlow switch sends information about the following ports to the controller:
· Physical ports.
· Logical ports.
· Reserved ports of the Local type.
In loosen mode, a port belongs to the OpenFlow instance when VLANs associated with the OpenFlow instance overlap with the port's allowed VLANs. Otherwise, a port belongs to an OpenFlow instance only when VLANs associated with the OpenFlow instance are within the port's allowed VLAN list.
OpenFlow flow table
An OpenFlow switch matches packets with one or more flow tables. A flow table contains flow entries, and packets are matched based on the matching precedence of flow entries.
Flow table types
OpenFlow flow tables include the following types:
· MAC-IP—Combines the MAC address table and FIB table.
A MAC-IP flow table provides the following match fields:
¡ Destination MAC address.
¡ VLAN.
¡ Destination IP address.
A MAC-IP flow table provides the following actions:
¡ Modifying the destination MAC address.
¡ Modifying the source MAC address.
¡ Modifying the VLAN.
¡ Modifying the tunnel ID.
¡ Specifying the output port.
For more information, see "Appendix B MAC-IP flow table."
· Extensibility—Uses ACLs to match packets.
Flow entry
A flow entry contains the following fields:
· Match fields—Matching rules of the flow entry. These contain the ingress port, packet headers, and metadata specified by the previous table.
· Priority—Matching precedence of the flow entry. When a packet is matched with the flow table, only the highest priority flow entry that matches the packet is selected.
· Counters—Counts of the packets and bytes that match the flow entry.
· Instructions—Used to modify the action set or pipeline processing. Instructions include the following types:
¡ Meter—Directs the packets to the specified meter to rate limit the packets.
¡ Apply-Actions—Applies the specified actions in the action list immediately.
¡ Clear-Actions—Clears all actions in the action set immediately.
¡ Write-Actions—Modifies all actions in the action set immediately.
¡ Write-Metadata—Modifies packets between two flow tables if multiple flow tables exist.
¡ Goto-Table—Indicates the next flow table in the processing pipeline.
Actions are executed in one of the following ways:
¡ Action Set—When the instruction set of a flow entry does not contain a Goto-Table instruction, pipeline processing stops. Then, the actions in the action set are executed in the order specified by the instruction list. An action set contains a maximum of one action of each type.
¡ Action List—The actions in the action list are executed immediately in the order specified by the action list. The effect of those actions is cumulative.
Actions include the following types:
¡ (Required.) Output—The Output action forwards a packet to the specified OpenFlow port. OpenFlow switches must support forwarding packets to physical ports, logical ports, and reserved ports.
¡ (Required.) Drop—No explicit action exists to represent drops. Packets whose action sets have no output actions are dropped. Typically, packets are dropped due to empty instruction sets, empty action sets, or the executing a Clear-Actions instruction.
¡ (Required.) Group—Process the packet through the specified group. The exact interpretation depends on group type.
¡ (Optional.) Set-Queue—The Set-Queue action sets the queue ID for a packet. When the packet is forwarded to a port by the output action, the packet is assigned to the queue attached to this port for scheduling and forwarding. The forwarding behavior is dictated by the configuration of the queue and provides basic QoS support.
¡ (Optional.) Push-Tag/Pop-Tag—Switches support the ability to push or pop tags, such as VLAN tags.
¡ (Optional.) Set-Field—The Set-Field actions are identified by their field type and modify the values of corresponding header fields in the packet. Set-Field actions are always applied to the outermost header. For example, a Set VLAN ID action always sets the ID of the outermost VLAN tag.
¡ (Optional.) Change-TTL—The Change-TTL actions modify the values of the IPv4 TTL or IPv6 Hop Limit in the packet. Change-TTL actions are always applied to the outermost header. The Change-TTL actions include the following the actions: Set TTL, Decrement TTL, and Copy TTL (outwards or inwards).
· Timeouts—Maximum amount of idle time or hard time for the flow entry.
¡ idle time—The flow entry is removed if it has matched no packets within the idle time.
¡ hard time—The flow entry is removed when the hard time timeout is exceeded, regardless of whether or not it has matched packets.
· Cookie—Custom data specified by the controller. The data is not used for processing packets, and might be used by the controller for matching flow entries.
Figure 2 Flow entry components
OpenFlow pipeline
The OpenFlow pipeline processing defines how packets interact with flow tables contained by a switch.
The flow tables of an OpenFlow switch are sequentially numbered, starting at 0. The packet is first matched with flow entries of the first flow table, which is flow table 0. A flow entry can only direct a packet to a flow table number that is greater than its own flow table number.
When a packet matches a flow entry, the OpenFlow switch updates the action set for the packet and passes the packet to the next flow table. In the last flow table, the OpenFlow switch executes all actions to modify packet contents and specify the output port for packet forwarding. If the instruction set of a flow table contains an action list, the OpenFlow switch immediately executes the actions for a copy of the packet in this table.
Figure 3 OpenFlow forwarding workflow
Every flow table must support a table-miss flow entry to process table misses. The table-miss flow entry specifies how to process packets that were not matched by other flow entries in the flow table.
The table-miss flow entry wildcards all match fields (all fields omitted) and has the lowest priority 0.
The table-miss flow entry behaves in most ways like any other flow entry.
Group table
The ability for a flow entry to point to a group enables OpenFlow to represent additional methods of forwarding. A group table contains group entries.
Figure 4 Group entry components
A group entry contains the following fields:
· Group Identifier—A 32 bit unsigned integer uniquely identifying the group.
· Group Type—Type of the group:
¡ All—Execute all buckets in the group. This group is used for multicast or broadcast forwarding.
¡ Select—Execute one bucket in the group.
¡ Indirect—Execute the one defined bucket in the group.
¡ Fast failover—Execute the first live bucket.
· Counters—Updated when packets are processed by a group.
· Action Buckets—An ordered list of action buckets, where each action bucket contains a set of actions to execute and associated parameters. Table 1 shows the actions supported by action buckets.
Table 1 Actions supported by action buckets
Action |
Type |
Output |
Required |
Forwards a packet to a specific OpenFlow port, for example, physical port, logical port, and reserved port. |
Meter table
Meters enable OpenFlow to implement various simple QoS operations, such as rate-limiting. A meter table contains meter entries.
A meter entry contains the following fields:
· Meter Identifier—A 32 bit unsigned integer uniquely identifying the meter.
· Meter Bands—Each meter can have one meter band, which specifies the rate at which the band applies and the way packets should be processed. If the current rate of packets exceeds the rate of the band, packets are processed according to the method defined in the band.
· Counters—Updated when packets are processed by a meter.
Figure 5 Meter entry components
A meter band contains the following fields:
· Band Type—(Optional.) Packet processing methods. Options are:
¡ Drop—Discards the packet when the rate of the packet exceeds the band rate.
¡ DSCP Remark—Remarks the DSCP field in the IP header of the packet.
· Rate—Defines the lowest rate at which the band can apply.
· Counters—Updated when packets are processed by a band.
· Type Specific Arguments—Some band types have specific arguments.
Figure 6 Band components
OpenFlow channel
The OpenFlow channel is the interface that connects each OpenFlow switch to a controller. The controller uses the OpenFlow channel to exchange control messages with the switch to perform the following operations:
· Configure and manage the switch.
· Receive events from the switch.
· Send packets out the switch.
The OpenFlow channel is usually encrypted by using TLS. Also, an OpenFlow channel can be run directly over TCP.
The OpenFlow protocol supports the following message types: controller-to-switch, asynchronous, and symmetric. Each message type has its own subtypes.
Controller-to-switch messages
Controller-to-switch messages are initiated by the controller and used to directly manage or inspect the state of the switch. Controller-to-switch messages might or might not require a response from the switch.
The controller-to-switch messages include the following subtypes:
· Features—The controller requests the basic capabilities of a switch by sending a features request. The switch must respond with a features reply that specifies the basic capabilities of the switch.
· Configuration—The controller sets and queries configuration parameters in the switch. The switch only responds to a query from the controller.
· Modify-State—The controller sends Modify-State messages to manage state on the switches. Their primary purpose is to add, delete, and modify flow or group entries in the OpenFlow tables and to set switch port properties.
· Read-State—The controller sends Read-State messages to collect various information from the switch, such as current configuration and statistics.
· Packet-out—These are used by the controller to send packets out of the specified port on the switch, or to forward packets received through packet-in messages. Packet-out messages must contain a full packet or a buffer ID representing a packet stored in the switch. The message must also contain a list of actions to be applied in the order they are specified. An empty action list drops the packet.
· Barrier—Barrier messages are used to confirm the completion of the previous operations. The controller send s Barrier request. The switch must send a Barrier reply when all the previous operations are complete.
· Role-Request—Role-Request messages are used by the controller to set the role of its OpenFlow channel, or query that role. It is typically used when the switch connects to multiple controllers.
· Asynchronous-Configuration—These are used by the controller to set an additional filter on the asynchronous messages that it wants to receive, or to query that filter. It is typically used when the switch connects to multiple controllers.
Asynchronous messages
Switches send asynchronous messages to controllers to inform a packet arrival or switch state change. For example, when a flow entry is removed due to timeout, the switch sends a flow-removed message to inform the controller.
The asynchronous messages include the following subtypes:
· Packet-In—Transfer the control of a packet to the controller. For all packets forwarded to the Controller reserved port using a flow entry or the table-miss flow entry, a packet-in event is always sent to controllers. Other processing, such as TTL checking, can also generate packet-in events to send packets to the controller. The packet-in events can include the full packet or can be configured to buffer packets in the switch. If the packet-in event is configured to buffer packets, the packet-in events contain only some fraction of the packet header and a buffer ID. The controller processes the full packet or the combination of the packet header and the buffer ID. Then, the controller sends a packet-out message to direct the switch to process the packet.
· Flow-Removed—Inform the controller about the removal of a flow entry from a flow table. These are generated due to a controller flow delete request or the switch flow expiry process when one of the flow timeouts is exceeded.
· Port-status—Inform the controller of a state or setting change on a port.
· Error—Inform the controller of a problem or error.
Symmetric messages
Symmetric messages are sent without solicitation, in either direction.
The symmetric messages contain the following subtypes:
· Hello—Hello messages are exchanged between the switch and controller upon connection startup.
· Echo—Echo request or reply messages can be sent from either the switch or the controller, and must return an echo reply. They are mainly used to verify the liveness of a controller-switch connection, and might also be used to measure its latency or bandwidth.
· Experimenter—This is a staging area for features meant for future OpenFlow revisions.
OpenFlow timers
An OpenFlow switch supports the following timers:
· Connection detection interval—Interval at which the OpenFlow switch sends an Echo Request message to a controller. When the OpenFlow switch receives no Echo Reply message within three intervals, the OpenFlow switch is disconnected from the controller.
· Reconnection interval—Interval for the OpenFlow switch to wait before it attempts to reconnect to a controller.
OpenFlow controller
Controller roles
A switch can establish connections with multiple controllers. When OpenFlow operation is initiated, a switch is simultaneously connected to multiple controllers in Equal state. A controller can request its role to be changed at any time. The controller role contains the following types:
· Equal—In this role, the controller has full access to the switch and is equal to other controllers in the same role. By default, the controller receives all switch asynchronous messages such as packet-in and flow-removed messages. The controller can send controller-to-switch messages to modify the state of the switch.
· Master—This role is similar to the Equal role and has full access to the switch. The difference is that up to one controller in this role is allowed for a switch.
· Slave—In this role, the controller has read-only access to the switch.
The controller cannot send controller-to-switch messages to perform the following operations:
¡ Deploy flow entries, group entries, and meter entries.
¡ Modify the port and switch configurations.
¡ Send packet-out messages.
By default, the controller does not receive switch asynchronous messages except Port-status messages. The controller can send Asynchronous-Configuration messages to set the asynchronous message types it wants to receive.
Controller connection modes
An OpenFlow instance can connect to one or more controllers, depending on the controller connection mode the OpenFlow instance uses:
· Single—The OpenFlow instance connects to only one controller at a time. When communication with the current controller fails, the OpenFlow instance uses another controller.
· Multiple—The OpenFlow instance can simultaneously connect to multiple controllers. When communication with any controller fails, the OpenFlow instance attempts to reconnect to the controller after a reconnection interval.
Main and auxiliary connections
The OpenFlow channel can have one main connection and multiple auxiliary connections.
· Main connection—Processes control messages to complete operations such as deploying entries, obtaining data, and sending information. The main connection must be a reliable TCP or SSL connection.
· Auxiliary connection—Improves the communication performance between the controller and OpenFlow switches. An auxiliary connection can have the different destination IP address and port number than the main connection.
Connection interruption mode
When an OpenFlow switch is disconnected from all controllers, the OpenFlow switch is set to either of the following modes:
· Secure—The OpenFlow switch forwards traffic based on flow tables and does not remove unexpired flow entries. If the output action in a matching flow entry is to forward traffic to a controller, the traffic is discarded. This is the default forwarding mode.
· Smart—The OpenFlow switch forwards traffic based on flow tables and does not remove unexpired flow entries. If the output action in a matching flow entry is to forward traffic to a controller, the traffic is forwarded in normal process.
· Standalone—The OpenFlow switch uses the normal forwarding process.
The OpenFlow switch forwards traffic based on flow tables when it reconnects to a controller successfully.
Protocols and standards
OpenFlow Switch Specification Version 1.3.3
OpenFlow requires an MC-NAT license to run on the device for receiving group entries that contain Set-Field actions. For more information about the Set-Field actions, see Table 1. For more information about licenses, see license management in Fundamentals Configuration Guide.
Layer 3 Ethernet interfaces, Layer 3 aggregate interfaces, Layer 3 Ethernet subinterfaces, and Layer 3 aggregate subinterfaces do not support OpenFlow in the current software version.
The device does not support group entries with the output ports as Layer 3 Ethernet interfaces, Layer 3 aggregate interfaces, Layer 3 Ethernet subinterfaces, or Layer 3 aggregate subinterfaces.
The device does not support extensibility flow entries with the Set-Field action of setting the ip_ecn (the ECN field in IP packets). For more information about ECN, see ACL and QoS Configuration Guide.
When configuring a global instance, follow these restrictions and guidelines:
· When the action of a flow entry is output, the output port cannot be Flood or All.
· When the action of a flow entry is to set the destination MAC or source MAC, you must specify the output action and the output port must be an Ethernet interface or aggregate interface.
· When local first load sharing is enabled for Ethernet link aggregation, the OpenFlow controller cannot create group entries on the device. The two features are mutually exclusive. For more information about load sharing for Ethernet link aggregation, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide.
· The OpenFlow controller supports creating only group entries with the output port as physical ports or aggregate interfaces.
· The OpenFlow controller does not support creating group entries with the action of setting the IPv6 address.
· A group entry with the action of setting the UDP port number takes effect only on IPv4 UDP packets.
· When the OpenFlow controller creates a group entry on the device, the packets sent out of the output port might carry VLAN tags. Modify the VLAN configuration of the output port as needed. For more information about port VLAN configuration, see VLAN in Layer 2—LAN Switching Configuration Guide.
If the output port is also the input port for a packet matching an OpenFlow flow entry, you must execute the port bridge enable command on the output port to enable bridging. Otherwise, traffic cannot be forwarded properly. For more information about bridging, see Ethernet interface in Layer 2—LAN Switching Configuration Guide.
Group entries are mutually exclusive with the link-aggregation load-sharing mode local-first command. For the group table to operate normally, do not execute the link-aggregation load-sharing mode local-first command on the device.
OpenFlow tasks at a glance
To configure OpenFlow, perform the following tasks:
1. Configuring OpenFlow instances
a. Creating an OpenFlow instance
b. Configuring the OpenFlow instance mode
c. (Optional.) Configuring inband management VLANs
d. (Optional.) Configuring flow tables and flow entries for an OpenFlow instance
This task is applicable if the OpenFlow instance does not use TTP flow tables.
e. (Optional.) Setting the controller connection mode
f. (Optional.) Preventing an OpenFlow instance from reporting the specified types of ports to controllers
g. (Optional.) Enabling support for smart group entries
Perform this task to optimize the IPTV service. A controller supporting smart group entries is required to cooperate with the OpenFlow instance.
h. Activating or reactivating an OpenFlow instance
i. (Optional.) Configuring OpenFlow instance attributes
2. Configuring controllers for an OpenFlow switch
3. (Optional.) Configuring an OpenFlow instance to act as an SSL server to listen to controllers
4. (Optional.) Refreshing all Layer 3 flow entries in the MAC-IP flow tables for an OpenFlow instance
5. (Optional.) Ignoring the permit flag added by OpenFlow
6. (Optional.) Shutting down an interface by OpenFlow
7. (Optional.) Enabling SNMP notifications for OpenFlow
8. (Optional.) Configuring OpenFlow flow monitor parameters
1. Enter system view.
2. Create an OpenFlow instance and enter its view.
openflow instance instance-id
3. (Optional) Set the datapath ID.
datapath-id id
By default, the datapath ID of an OpenFlow instance contains the instance ID and the bridge MAC address of the device. The upper 16 bits are the instance ID and the lower 48 bits are the bridge MAC address of the device.
The datapath ID uniquely identifies an OpenFlow switch (OpenFlow instance). Do not set the same datapath ID for different OpenFlow switches.
4. Set a DSCP value for OpenFlow packets.
tcp dscp dscp-value
By default, no DSCP value is set for OpenFlow packets.
When you associate an OpenFlow instance with VLANs, follow these guidelines:
· For VLAN traffic to be processed correctly, associate different OpenFlow instances with different VLANs.
· When you activate an OpenFlow instance that is associated with nonexistent VLANs, the system automatically creates the VLANs.
· Do not associate VLANs permitted on a port with different OpenFlow instances. Otherwise, port modification messages of different OpenFlow instances deployed from different controllers overwrite each other.
· Do not configure BFD MAD on the VLAN interface for a VLAN that is associated with an OpenFlow instance. For more information about BFD MAD, see Virtual Technologies Configuration Guide.
Enabling the global mode for an OpenFlow instance
2. Enter OpenFlow instance view.
3. Enable the global mode for the OpenFlow instance.
Classification global
By default, the OpenFlow instance mode is not configured.
Enabling the VLAN mode for an OpenFlow instance
3. Configure the OpenFlow instance mode.
classification vlan vlan-id [ mask vlan-mask ] [ loosen ]
Traffic in the inband management VLANs are forwarded in the normal forwarding process instead of the OpenFlow forwarding process. Inband management VLANs are used by an OpenFlow instance to establish OpenFlow channels to controllers.
The ports that are assigned only to inband management VLANs are not OpenFlow ports.
Inband management VLANs configured for an OpenFlow instance in VLAN mode must be within the list of the VLANs associated with the OpenFlow instance.
If an OpenFlow instance in global or VLAN mode connects to a controller through a non-management Ethernet interface, configure the VLAN to which the interface belongs as an inband management VLAN.
3. Configure inband management VLANs for the OpenFlow instance.
in-band management vlan vlan-id-list
By default, no inband management VLANs are configured for an OpenFlow instance.
The extensibility flow table ID must be greater than the MAC-IP flow table ID.
3. Configure flow tables for the OpenFlow instance.
flow-table { mac-ip mac-ip-table-id | extensibility extensibility-table-id&<1-2> }*
By default, an OpenFlow instance contains one extensibility flow table with an ID of 0.
4. Set the maximum number of flow entries that each extensibility flow table supports.
flow-entry max-limit limit-value
By default, each extensibility flow table supports a maximum of 65535 flow entries.
When the maximum number is reached, the OpenFlow instance does not accept new flow entries for that table and sends a deployment failure notification to the controller.
When multiple extensibility flow tables exist, the limit applies to each extensibility flow table separately.
5. Configure the OpenFlow instance to allow dynamic ARP entries to overwrite OpenFlow ARP entries.
precedence dynamic arp
By default, an OpenFlow instance does not allow dynamic ARP entries to overwrite OpenFlow ARP entries.
Only MAC-IP flow tables support this feature.
6. Allow the deployed flow tables to include link aggregation member ports.
permit-port-type member-port
By default, the deployed flow tables cannot include link aggregation member ports.
7. Configure the default action of table-miss flow entries to forward packets to the normal pipeline.
default table-miss permit
By default, the default action of table-miss flow entries is to drop packets.
3. Set the controller connection mode.
By default, the multiple mode is used.
Perform this task to prevent an OpenFlow instance from reporting controllers information about the following types of interfaces that belong to the OpenFlow instance:
· Layer 3 Ethernet interface.
· Layer 3 aggregate interface.
· VLAN interface.
· Virtual switch instance (VSI) interface.
3. Prevent an OpenFlow instance from reporting the specified types of ports to controllers.
forbidden port { l3-physical-interface | vlan-interface | vsi-interface } *
By default, no port types are prevented from being reported to the controllers. All ports that belong to an OpenFlow instance are reported to the controllers.
On an IPTV service network, the traffic of an IPTV program might contain multiple types of traffic, such as flows of videos, audios in different languages, and subtitles in different languages. The controller needs to issue multiple flow entries for the OpenFlow instance to forward the traffic flows of an IPTV program to target users. The speed of program switchover might be affected due to the controller performance, which will further decrease the user experience.
To address this issue, support for smart group entries is introduced. The controller can issue smart group entries that define all possible forwarding actions for the IPTV service in advance. Once a program switchover occurs, the controller sends only a controller-to-switch message instead of multiple flow entries to the OpenFlow switch. This message will instruct the switch to combine smart group entries to forward the traffic flows of the new program to the target user.
Smart group entries include the following types:
· Program group entry—Identifies forwarding actions for flows of an IPTV program. A program group entry can be used by an OpenFlow flow entry to provide extra forwarding functions. By default, a program group entry does not contain any buckets. To include buckets in the program group entry, bind the program group entry to target group entries.
· Target group entry—Identifies a target user for an IPTV program. A target group entry contains only a bucket, which defines the output port. Target group entries cannot be used by OpenFlow flow entries but they can be bound to a program group entry. A program group entry can be bound to multiple target group entries to forward flows of an IPTV program to multiple target users.
Figure 7 Smart group entry components
A smart group entry contains the following fields:
· Class Type—Identifies the type of a smart group entry. This field contains one byte. 0x00 indicates a program group entry and 0x01 indicates a target group entry.
· Program/Target ID—Identifies the ID of a program or target user. This field contains two bytes.
· Flow ID—Identifies the ID of a flow for a program or target user. This field contains one byte.
To modify a target group entry issued to an OpenFlow instance, the controller must first delete the target group entry and then re-issue the target group entry.
3. Enable the OpenFlow instance to support smart group entries.
smart-group enable
By default, support for smart group entries is disabled for an OpenFlow instance.
To avoid failure to activate an OpenFlow instance containing a MAC-IP flow table, first execute the default table-miss permit command.
3. Activate or reactivate the OpenFlow instance.
active instance
By default, an OpenFlow instance is not activated.
The OpenFlow instance attribute configurations of an OpenFlow instance can take effect without activation for the OpenFlow instance.
openflow instance { instance-id }
3. Configure a description for the OpenFlow instance.
By default, an OpenFlow instance does not have a description.
4. Set OpenFlow timers.
¡ Set the connection detection interval.
controller echo-request interval interval
The default setting is 5 seconds.
¡ Set the reconnection interval.
controller connect interval interval
The default setting is 60 seconds.
5. Configure MAC address-related features.
¡ Forbid MAC address learning for VLANs associated with the OpenFlow instance.
mac-learning forbidden
By default, MAC address learning is allowed for VLANs associated with an OpenFlow instance.
The configuration does not take effect on inband management VLANs.
¡ Configure the OpenFlow instance to support matching the dynamic MAC addresses in the query and deletion flow entry instructions sent from controllers.
mac-ip dynamic-mac aware
By default, an OpenFlow instance ignores dynamic MAC addresses in the query and deletion flow entry instructions sent from controllers.
6. Prevent the OpenFlow instance from reporting ARP packets to the specified controllers.
forbidden packet-in arp controller controller-id-list
By default, no controllers to which ARP packets are forbidden to be reported are configured.
This feature forbids an OpenFlow instance to report ARP packets to the specified controllers to prevent the controllers from being affected by a large number of packets.
7. Disable logging for successful flow table modifications.
flow-log disable
By default, logging for successful flow table modifications is enabled.
8. Enable loop guard for the OpenFlow instance.
loop-protection enable
By default, loop guard is disabled for an OpenFlow instance.
After an OpenFlow instance is deactivated, you can enable loop guard for the OpenFlow instance to avoid loops. This feature enables the deactivated OpenFlow instance to create a flow entry for dropping all traffic in these VLANs.
Make sure the configuration of an auxiliary connection does not conflict with the configuration of the main connection. Otherwise, the auxiliary connection cannot be established.
3. Specify a controller and configure the main connection to the controller.
controller controller-id address { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ local address { ip local-ipv4-address | ipv6 local-ipv6-address } [ port local-port- number ] ] [ ssl ssl-policy-name [ access-control-policy acp-policy-name ] ] [ vrf vrf-name ]
By default, an OpenFlow instance does not have a main connection to a controller.
The source IP address must be the IP address of a port belonging to an OpenFlow instance. Otherwise, the OpenFlow switch might fail to establish a connection with the controller.
4. (Optional) Specify a controller and configure an auxiliary connection to the controller.
controller id auxiliary auxiliary-id transport { tcp | udp | ssl ssl-policy-name } [ address { ip ipv4-address | ipv6 ipv6-address } ] [ port port-number ]
By default, an OpenFlow instance does not have auxiliary connections to a controller.
If no destination IP address and port number are specified, the auxiliary connection uses the destination IP address and port number configured for the main connection.
5. (Optional) Set the connection interruption mode.
fail-open mode { secure | smart| standalone }
By default, the secure mode is used.
6. (Optional) Enable OpenFlow connection backup.
tcp-connection backup
By default, OpenFlow connection backup is enabled.
This feature prevents connection interruption when an active/standby switchover occurs.
This feature is available only on an IRF fabric with two member devices.
This feature is available for only OpenFlow connections established over TCP.
Typically, an OpenFlow instance actively connects to the controller acting as a TCP/SSL client. After the SSL server is enabled for an OpenFlow instance, the controller acts as the SSL client and actively connects to the OpenFlow instance. For more information about SSL, see Security Configuration Guide.
This feature can take effect without activation for an OpenFlow instance.
To re-configure the SSL server, first execute the undo form of the command to delete the existing SSL server configuration.
3. Configure an OpenFlow instance to act as an SSL server to listen to controllers.
listening port port-number ssl ssl-policy-name
By default, an OpenFlow instance is not configured to acts as an SSL server listen to controllers.
Perform this task to obtain all Layer 3 flow entries in the MAC-IP flow tables from the controller again if the Layer 3 flow entries have been overwritten.
3. Refresh all Layer 3 flow entries in the MAC-IP flow tables.
refresh ip-flow
Packets matching an OpenFlow flow entry with the output action as Normal are permitted to pass through and marked with a permit flag. Packets with a permit flag are not dropped by a discard action in a QoS policy (for example, a CAR discard action).
This feature allows the device to drop packets with a permit flag by using a discard action in a QoS policy.
2. Ignore the permit flag added by OpenFlow.
openflow permit-flag ignore
By default, the permit flag added by OpenFlow is not ignored.
After an interface is shut down by OpenFlow, the Current state field displays OFP DOWN in the display interface command output.
You can use the undo openflow shutdown command to bring up an interface shut down by OpenFlow. The interface can also be brought up by port modification messages from controllers.
2. Enter interface view.
3. Shut down an interface by OpenFlow.
openflow shutdown
By default, an interface is not shut down by OpenFlow.
This feature enables OpenFlow to generate SNMP notifications for important OpenFlow events. For the notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for OpenFlow.
snmp-agent trap enable openflow [ connect-state ]
By default, SNMP notifications are enabled for OpenFlow.
The controller can use NETCONF to enable the flow monitor feature for flow entries on the device. On the device, you can configure flow monitor parameters at the CLI.
For an OpenFlow flow entry with flow monitor enabled, the device monitors the changes in the numbers of bytes and packets matching the flow entry at the flow monitor interval. If these counters do not change consecutively for the specified times, the device uses NETCONF to report to the controller the event that the traffic matching the flow entry does not increase. If these counters increase later, the device uses NETCONF to report to the controller the event that the traffic matching the flow entry increases.
NOTE: Use the display openflow flow-table command to view flow entries. In the command output, the byte count and packet count fields for a flow entry represent the number of bytes matching the flow entry and the number of packets matching the flow entry. |
The controller deploys the <action> operation to enable flow monitor for a flow entry on the device. The following NETCONF message enables flow monitor for all flow entries with CookieID 1 in flow table 0 for the OpenFlow instance corresponding to the specified datapath ID.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<action>
<error-option>stop-on-error</error-option>
<top xmlns="https://www.h3c.com/netconf/action:1.0">
<OFP>
<FlowMonitor>
<Application>
<DatapathID>410026760491999</DatapathID>
<TableID>0</TableID>
<CookieID>1</CookieID>
<Enable>1</Enable>
</Application>
</FlowMonitor>
</OFP>
</top>
</action>
</rpc>
With OpenFlow flow monitor enabled for a large number of flow entries, the CPU load of the device might be too heavy if the configured flow monitor interval is small.
The OpenFlow flow monitor feature monitors only the traffic matching the flow entries deployed by the controller to an OpenFlow instance, and does not monitor flow entries with the default and local attributes.
After the OpenFlow flow monitor feature is enabled for a flow entry, the idle time attribute (the flow entry is removed if the flow entry does not match any data stream during the idle time) that the controller deploys to the flow entry does not take effect.
3. Configure the flow monitor interval.
flow-monitor interval interval
By default, the flow monitor interval is not configured.
If you do not configure the flow monitor interval, the OpenFlow flow monitor feature does not take effect.
4. (Optional.) Set the monitor threshold for consecutive traffic interruptions.
flow-monitor threshold threshold
By default, the monitor threshold for consecutive traffic interruptions is 2.
Task |
Command |
Display the detailed information for an OpenFlow instance. |
display openflow instance [ instance-id ] |
Display controller information for an OpenFlow instance. |
display openflow instance instance-id { controller [ controller-id ] | listened } |
Display auxiliary connection information. |
display openflow instance instance-id auxiliary [ controller-id [ auxiliary auxiliary-id ] ] |
Display flow table entries for an OpenFlow instance. |
display openflow instance instance-id flow-table [ table-id ] |
Display group table information for an OpenFlow instance. |
display openflow instance instance-id group [ group-id ] |
Display meter table information for an OpenFlow instance. |
display openflow instance instance-id meter [ meter-id ] |
Display smart group entry information for an OpenFlow instance. |
display openflow instance instance-id smart-group { program-group [ program-id ] | target-group [ target-id ] } |
Display summary OpenFlow instance information. |
display openflow summary |
Clear statistics on packets that a controller sends and receives for an OpenFlow instance. |
reset openflow instance instance-id { controller [ controller-id ] | listened } statistics |
As shown in Figure 8, an OpenFlow switch communicates with the controller. Perform the following tasks on the OpenFlow switch:
· Create OpenFlow instance 1, associate VLANs 4092 and 4094 with the OpenFlow instance, and activate the OpenFlow instance.
· Configure the IP address for controller 1 to have the controller manage the OpenFlow switch.
# Create VLANs 4092 and 4094.
<Switch> system-view
[Switch] vlan 4092
[Switch-vlan4092] quit
[Switch] vlan 4094
[Switch-vlan4094] quit
# Create OpenFlow instance 1 and associate VLANs with it.
[Switch] openflow instance 1
[Switch-of-inst-1] classification vlan 4092 mask 4093
# Specify controller 1 for OpenFlow instance 1 and activate the instance.
[Switch-of-inst-1] controller 1 address ip 192.168.49.49
[Switch-of-inst-1] active instance
[Switch-of-inst-1] quit
# View detailed information about the OpenFlow instance.
[Switch] display openflow instance 1
Instance 1 information:
Configuration information:
Description : --
Active status : Active
Inactive configuration:
None
Active configuration:
Classification VLAN, total VLANs(2)
4092, 4094
Port information:
Ten-GigabitEthernet1/0/3
Active channel information:
Controller 1 IP address: 192.168.49.49 port: 6633
Flow entry restrictions
Matching restrictions
VLAN matching
Table 2 describes the VLAN matching restrictions when an OpenFlow instance is associated with VLANs.
VLAN |
Mask |
Matching packets |
All packets in the VLANs that are associated with the OpenFlow instance. |
0 |
Packets without a VLAN tag. The PVID of the ingress port must be associated with the OpenFlow instance. |
0 |
Value |
Unsupported. |
Valid VLAN |
-/value |
Unsupported. |
0x1000 |
-/value (except 0x1000) |
Unsupported. |
0x1000 |
0x1000 |
Packets with a VLAN tag. The VLAN ID of the VLAN tag must be associated with the OpenFlow instance. |
Valid VLAN | 0x1000 |
-/value |
Matching packets by the combination of the VLAN ID and VLAN mask. The VLANs obtained through the combination of the VLAN ID and VLAN mask must be associated with the OpenFlow instance. |
Other |
Other |
Unsupported. |
Protocol packet matching
If protocols are enabled, protocol packets (except LLDP frames) are processed by the corresponding protocols instead of the OpenFlow protocol.
For more information about LLDP frame matching, see "LLDP frame matching."
Metadata matching
Metadata passes matching information between flow tables. The controller deploys metadata matching entries only to non-first flow tables. If the controller deploys a metadata matching entry to the first flow table, the switch returns an unsupported flow error.
Instruction restrictions
Table 3 Instruction restrictions
Instruction type |
Restrictions |
Clear-Actions |
The Clear-Actions instruction has the following restrictions: · For the single flow table, the flow entries of the table cannot include this instruction and other instructions at the same time. · For multiple flow tables of the pipeline, only the flow entries of the first flow table can include this instruction and other instructions at the same time. |
Apply-Actions |
The action list of the Apply-Actions instruction cannot include multiple Output actions. When the action list includes only one Output action, the switch processes the action list as described in "Restrictions for merging the action list into the action set." |
Write-Metadata/mask |
The flow entries of the last table of the pipeline cannot include this instruction. Otherwise, the switch returns an unsupported flow error. |
Goto-Table |
The switch follows the following restrictions to merge the action list into the action set.
Non-output actions
When the action set and the action list do not contain the Output or Group action, the following rules apply:
· If actions in the action set do not conflict with actions in the action list, the switch merges the action list into the action set.
· If actions in the action set conflict with actions in the action list, actions in the action list are replaced with actions in the action set.
Output actions
When the action set and the action list contain the Output action or the Group action, the following rules apply:
· If both the action list and the action set contain an Output action, the Output action in the action list takes precedence. The Output action in the action list does not modify the packet. The Output action in the action set is executed at the last step of the pipeline processing to modify the packet.
· If either the action list or the action set contains an Output action, the port specified by the Output action is treated as the output port. The actions are executed in the order defined by the action set rules.
· If the action list contains an Output action and the action set contains a Group action, the following rules apply:
¡ The Output action does not modify the packet.
¡ The Group action is executed.
Ingress port
The ingress port must be a physical or logical port when one of the following reserved ports is the output port in a packet-out message:
· Normal.
· Local.
· In Port.
· Controller.
Buffer ID co-existing with packet
If a packet-out message contains both the packet and the buffer ID representing the packet stored in the switch, the switch processes only the buffered packet. The switch ignores the packet in the message.
If the packet contained in a packet-out message has no VLAN tag, the switch performs the following operations:
· Tags the packet with the PVID of the ingress port.
· Forwards the packet within the VLAN.
The switch processes the packet as follows when the ingress port is a reserved port:
· If the output port is a physical or logical port, the switch tags the packet with the PVID of the output port and forwards the packet within the VLAN.
· If the output port is the Flood or All reserved port, the switch processes the packet as described in "Output port."
Output port
If the output port in a packet-out message is the Flood or All reserved port, the switch processes the packet contained in the packet-out message as follows:
· When the output port is the Flood reserved port:
¡ If the packet has a VLAN tag, the switch broadcasts the packet within the VLAN.
¡ If the packet has no VLAN tag and the ingress port is a physical or logical port, the switch tags the packet with the PVID of the ingress port. The switch then forwards the packet within the VLAN.
¡ If the packet has no VLAN tag and the ingress port is the Controller reserved port, the switch forwards the packet out all OpenFlow ports.
· When the output port is the All reserved port:
¡ If the packet has no VLAN tag, the switch forwards the packet out of all OpenFlow ports regardless of the ingress port type.
Processing VLAN tags
When sending a packet-in message to the controller, the switch processes the VLAN tag of the packet contained in the packet-out message as follows:
· If the VLAN tag of the packet is the same as the PVID of the ingress port, the switch removes the VLAN tag.
· If the VLAN tag of the packet is different from the PVID of the ingress port, the switch does not remove the VLAN tag.
Packet buffer
If a packet-in message is sent to controller due to no matching flow entry, the switch supports buffering the packet contained in the packet-in message. The buffer size is 1K packets.
If a packet-in message is sent to controller for other reasons, the switch does not support buffering the packet contained in the packet-in message. The switch must send the full packet to the controller, and the cookie field of the packet is set to 0xFFFFFFFFFFFFFFFF.
LLDP frame matching
LLDP is used to perform topology discovery in an OpenFlow network. LLDP must be enabled globally on a device. A switch sends a LLDP frame to the controller through the packet-in message when the following conditions exist:
· The port that receives the LLDP frame from the controller belongs to OpenFlow instances.
· The flow tables in the OpenFlow instance have a flow entry that matches the LLDP frame (the output port is the Controller reserved port).
The flow table modification messages have the following restrictions for the table-miss flow entry and common flow entries.
The controller deploys the table-miss flow entry (the action is Drop) to an OpenFlow instance after the OpenFlow instance is activated.
The controller cannot query the table-miss flow entry through Multipart messages.
The controller cannot modify the table-miss flow entry through the Modify request. The controller can only modify the table-miss flow entry through the Add request.
The controller can modify or delete the table-miss flow entry only through the strict version of the Modify or Delete request. The controller cannot modify or remove the table-miss flow entry through the non-strict version of the Modify or Delete request despite that the match fields are wildcarded.
The controller deploys a table-miss flow entry (the action is Drop) to an OpenFlow instance after the current table-miss flow entry is deleted.
Common flow entries
The controller cannot modify or remove all common flow entries through the non-strict version of the Modify or Delete request despite that the match fields are wildcarded.
The controller must include the required match fields and actions and can include the optional match fields and actions in the flow entries deployed to the MAC-IP flow table. If the controller does not include the optional match fields and actions in the flow entries, the switch adds them to the flow entries by default.
The Layer 2 flow entries are implemented by using MAC address entries. Table 4 describes the capabilities supported by Layer 2 flow entries.
Table 4 Capabilities supported by Layer 2 flow entries
Item |
Capabilities |
Required match fields |
The MAC-IP flow table must support the following match fields: · VLAN ID. · Unicast destination MAC address. |
Optional match fields |
N/A |
Required actions |
Specifying the output port. |
Optional actions |
The MAC-IP flow table can optionally support the following instructions: · Goto-Table—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. · Write-Metadata—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. |
The Layer 3 flow entries are implemented by using routing entries. Table 5 describes the capabilities supported by Layer 3 flow entries.
Table 5 Capabilities supported by Layer 3 flow entries
Item |
Capabilities |
The MAC-IP flow table must support the following match fields: · VLAN ID. · Unicast destination IP address. · Unicast destination MAC address, which must be the MAC address of the VLAN interface for the VLAN that is matched. |
N/A |
Required actions |
Optional actions |
The MAC-IP flow table can optionally support the following actions: · Modify source MAC address—The switch modifies the source MAC address to the MAC address of the VLAN interface for the VLAN to which the output port belongs. · Decrement TTL by one. · Goto-Table—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. · Write-Metadata—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. |
The VXLAN Layer 2 flow entries are implemented by using MAC address entries. Table 6 describes the capabilities supported by VXLAN Layer 2 flow entries.
Table 6 Capabilities supported by VXLAN Layer 2 flow entries
Item |
Capabilities |
N/A |
Required actions |
The MAC-IP flow table must support the following actions: · Specifying a tunnel interface as the output port. · Specifying the tunnel ID. |
Optional actions |
The VXLAN Layer 3 flow entries are implemented by using routing entries. Table 7 describes the capabilities supported by VXLAN Layer 3 flow entries.
Table 7 Capabilities supported by VXLAN Layer 3 flow entries
Item |
Capabilities |
The MAC-IP flow table must support the following match fields: · Ethernet type. · Unicast destination IP address. |
N/A |
Required actions |
The MAC-IP flow table must support the following actions: · Specifying a tunnel interface as the output port. · Specifying the tunnel ID. · Modifying the destination MAC address. |
Optional actions |
The MAC-IP flow table can optionally support the following actions: · Goto-Table—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. · Write-Metadata—When the switch has multiple tables, the switch adds this instruction by default if the controller does not deploy it. |
The VXLAN QinQ flow entries are implemented by using ARP entries. Table 8 describes the capabilities supported by VXLAN QinQ flow entries.
Table 8 Capabilities supported by VXLAN QinQ entries
Item |
Capabilities |
The MAC-IP flow table must support the following match fields: · Ethernet type. · Unicast destination IP address. · Tunnel ID. |
N/A |
Required actions |
The MAC-IP flow table must support the following actions: · Specifying a tunnel interface or interface where an AC resides as the output port. · Modifying the destination MAC address. · Adding a VLAN tag. |
Optional actions |
Adding an inner VLAN tag. |
The routing flow entries are implemented by using routing entries. Table 9 describes the capabilities supported by routing flow entries.
Table 9 Capabilities supported by routing entries
Item |
Capabilities |
The MAC-IP flow table must support the following match fields: · Ethernet type. · Unicast destination IP address and subnet mask. |
Required actions |
Specifying Null 0 as the output port. |
Optional actions |
N/A |
Controller must follow the restrictions in the following tables to deploy flow entries for MAC-IP flow table. Otherwise, forwarding failure might occur.
Table 10 Restrictions for deploying Layer 2 flow entries for the MAC-IP flow table
Item |
Restrictions |
Match fields |
The destination MAC address cannot be the MAC address of the switch to which the flow entry is deployed. |
Actions |
The output port must belong to the VLAN that is matched. |
Table 11 Restrictions for deploying Layer 3 flow entries for the MAC-IP flow table
Item |
Restrictions |
Match fields |
The VLAN interface of the VLAN that is matched is in up state. The destination MAC address is the MAC address of the VLAN interface for the VLAN that is matched. The destination IP address cannot be the IP address of the switch to which the flow entry is deployed. |
Actions |
The specified output port must belong to the destination VLAN. The destination MAC address cannot be the MAC address of the switch to which the flow entry is deployed. If the switch modifies the source MAC address, the source MAC address must be the MAC address of the VLAN interface for the VLAN to which the output port belongs. |
To deploy a Layer 3 flow entry, make sure the following requirements are met:
· The VLAN interface of the matched VLAN is in up state.
· The switch sends the controller a packet that indicates the VLAN interface acts as an OpenFlow port. The link state and the MAC address of the VLAN interface are also included in the packet.
The switch reports the VLAN interface deletion to the controller and the controller removes the corresponding Layer 3 flow entry.
The controller ensures the correctness of Layer 3 flow entries. The switch does not check for the restrictions for Lay 3 flow entries.
Table 12 Restrictions for deploying VXLAN Layer 2 flow entries for the MAC-IP flow table
Item |
Restrictions |
Match fields |
The destination MAC address cannot be MAC address of the switch to which the flow entry is deployed. |
Actions |
The output port must be an existing tunnel interface. The VXLAN that corresponds to the specified tunnel ID (VNI) must exist. |
Table 13 Restrictions for deploying VXLAN Layer 3 flow entries for the MAC-IP flow table
Item |
Restrictions |
Match fields |
Actions |
The output port must be an existing tunnel interface. The VXLAN and the VSI interface that correspond to the specified tunnel ID (VNI) must exist. The destination MAC address cannot be MAC address of the switch to which the flow entry is deployed. |
Table 14 Restrictions for deploying VXLAN QinQ entries for the MAC-IP flow table
Item |
Restrictions |
Match fields |
The tunnel ID must be the VXLAN ID of the VSI mapped to the AC or the VXLAN ID of the VSI associated with the VXLAN-DCI tunnel. |
Actions |
The VXLAN ID of the VSI mapped to the output port must be the same as the tunnel ID. A gateway interface (VSI interface) must be specified for the VSI. On a forwarding-control separated network, the inner VLAN tag and outer VLAN tag must match the frame match criteria of the AC and the interface where the AC resides must be configured with the vtep access port command. |
The table-miss flow entry of a MAC-IP flow table supports the following output actions:
· Goto-Table—Direct the packet to the next table.
· Drop—Drop the packet.
· Controller—Send the packet to the controller.
· Normal—Forward the packet to the normal pipeline.
Dynamic aware
On an OpenFlow switch that supports MAC-IP flow tables, you can configure OpenFlow to support querying and deleting dynamic MAC address flow entries.
The controller can query and delete dynamic MAC address flow entries by specifying a VLAN, a MAC address, or the combination of a MAC address and a VLAN.
Metadata/mask
The MAC-IP flow table supports the Write Metadata/mask instruction and the extensibility flow table supports metadata/mask matching. The MAC-IP flow table can cooperate with an extensibility flow table to perform the pipeline process of multiple tables by using metadata/mask.
Each metadata mask bit has a different meaning. The corresponding metadata bit being set indicates that the metadata mask bit is matched. When the corresponding metadata bit is not set, the metadata mask bit is wildcarded.
Table 15 Metadata mask meanings
Metadata mask bit |
Meaning |
Metadata |
Bit 0 |
Destination MAC address |
· 1—Set. Matches the destination MAC address. · 0—Not set. Does not match the destination MAC address. |
Bit 1 |
Source MAC address |
· 1—Set. Matches the source MAC address. · 0—Not set. Does not match the source MAC address. |
Bit 2 |
Destination IP address |
· 1—Set. Matches the destination IP address. · 0—Not set. Does not match the destination IP address. |
Others |
Reserved |
Reserved. |
When the output action in an extensibility flow table is not Normal, the following rules apply:
· The MAC-IP flow table does not take effect.
· All actions are executed according to the extensibility flow table.
When the output action in an extensibility flow table is Normal, the following rules apply:
· The output action is executed according to the MAC-IP flow table.
· The other actions are executed according to the extensibility flow table.
Capabilities supported by the VLAN tagging flow table
The controller must include the required match fields and actions and can include the optional match fields and actions in the flow entries deployed to the VLAN tagging flow table. If the controller does not include the optional match fields and actions in the flow entries, the switch adds them to the flow entries by default.
Table 16 describes the capabilities supported by the flow entries in the VLAN tagging flow table.
Table 16 Capabilities supported by flow entries in the VLAN tagging flow table
Item |
Capabilities |
The VLAN tagging flow table must support the following match fields: · input-port. · vlan. |
N/A |
Required actions |
The following actions in the action list of the Apply-Actions instruction must be applied immediately: · Push-Tag. · Set-Field (VLAN). |
Optional actions |
The VLAN tagging flow table can optionally support the following actions: · Output (normal). · Goto-Table. |
The Push-Tag and Set-Field (VLAN) actions must be in the action list of the Apply-Actions instruction. The Push-Tag and Set-Field (VLAN) actions can be used as follows:
· Push-Tag + Set-Field (value1)—Adds a VLAN tag value1.
· Set-Field (value1) + Push-Tag + Set-Field (value2)—Modifies the VLAN tag of the packet to value1 and adds a VLAN tag value2.
· Push-Tag + Set-Field (value1) + Push-Tag + Set-Field (value2)—Adds inner VLAN tag value2 and outer VLAN tag value1.
The Goto-Table instruction is optional and does not take effect. The flow table specified by this instruction can only be the next of the VLAN tagging flow table.
Capabilities supported by the VLAN untagging flow table
Table 17 Capabilities supported by flow entries in the VLAN untagging flow table
Item |
Capabilities |
The VLAN untagging flow table must support the following match fields: · egress port—Matches the egress port of packets. · vlan—Matches the outer VLAN tag of packets. |
The VLAN untagging flow table can optionally support the inner vlan match field that matches the inner VLAN tag of double-tagged packets. |
Required actions |
The following actions in the action list of the Apply-Actions instruction must be applied immediately: · Pop-Tag. · Set-Field (VLAN). |
Optional actions |
The VLAN untagging flow table can optionally support the Output (normal) action. |
The VLAN untagging flow table applies only to double-tagged packets.
The egress port and inner vlan are extended match fields that use the Experimenter ID H3C (0xFE2) and take the private match field values 47 and 48, respectively. To deploy flow entries that contain the extended match fields, make sure the controllers are developed to be compatible with the Experimenter ID and the extended match fields.
The Pop-Tag and Set-Field (VLAN) actions must be in the action list of the Apply-Actions instruction. The Pop-Tag and Set-Field (VLAN) actions can be used as follows:
· Pop-Tag—Removes the outer VLAN tag.
· Pop-Tag + Pop-Tag—Removes the inner and outer VLAN tags.
· Pop-Tag + Set-Field (value)—Removes the outer VLAN tag and modifies the inner VLAN tag to value.
Multi-level table-based TTP pipeline
A TTP pipeline can include multiple types of flow tables and the tables can be cascaded. Figure 9 shows the forwarding workflow of a TTP pipeline.
Figure 9 Multi-level table-based TTP pipeline
Table-miss flow entry of TTP flow tables
The table-miss flow entry of a TTP flow table supports the following output actions:
· Goto-table-50—Direct the packet to table 50 (the TTP-Bridging flow table).
Table 18 describes the instruction supported by the table-miss flow entry of different types in TTP flow tables. The instruction in the table-miss entry of TTP flow tables 0 through 50 cannot be modified.
Table 18 Instruction supported by the table-miss flow entry of TTP flow tables
Table ID |
TTP flow table |
Instruction in the table-miss entry |
0 |
TTP-ingress-port |
Normal |
10 |
TTP-VLAN |
Normal |
20 |
TTP-termination-MAC |
Goto-table-50 |
30 |
TTP-unicast-routing |
Normal |
50 |
TTP-bridging |
Controller |
60 |
TTP-ingress-ACL |
N/A |
61 |
TTP-egress-ACL |
N/A |
Capabilities supported by the TTP-ingress-port flow table
A TTP-ingress-port flow entry is used to identify the type of the input port for a packet and direct the packet to another table.
· Packets arriving at a physical interface are directed to the TTP-VLAN flow table.
· Packets arriving at a VXLAN tunnel interface are directed to a TTP-Bridging flow table and added the VXLAN ID information in metadata.
Table 19 Capabilities supported by TTP-ingress-port flow entries (for packets arriving at physical interfaces)
Item |
Capabilities |
N/A |
In-Port—Type of the input port (physical interface). |
Required actions |
Goto-table-10—Directs the packet to table 10 (TTP-VLAN flow table). |
Optional actions |
N/A |
Item |
Capabilities |
N/A |
· In-Port—Type of the input port (VXLAN tunnel interface). · Tunnel ID—VNI. |
Required actions |
· Write-metadata—Writes VNI and VRF information. · Goto-table-50—Directs the packet to table 50 (TTP-bridging flow table). |
Optional actions |
N/A |
· In-Port—Matches the type of the input port. It contains 4 bytes, where the former 2 bytes indicates the interface type. The following interface types are supported:
¡ 0x0000—Physical interface at the user side.
¡ 0x0001—VLAN tunnel interface on an overlay network.
· Metadata—Transmits the VNI and VRF index information in a pipeline. This field contains 64 bytes, where the lower-order 32 bytes indicate a VNI and the higher-order 32 bytes indicate a VRF index.
Capabilities supported by the TTP-VLAN flow table
A TTP-VLAN flow entry is used to match untagged or tagged packets arriving at a physical interface, direct the packets to the TTP-termination-MAC flow table, and transmit VXLAN ID information.
Table 21 Capabilities supported by TTP-VLAN flow entries (for untagged packets)
Item |
Capabilities |
N/A |
Required actions |
· Write-metadata—Writes the VNI information. · Goto-table-20—Directs the packet to table 20 (TTP-termination-MAC flow table). |
Optional actions |
N/A |
Table 22 Capabilities supported by TTP-VLAN flow entries (for tagged packets)
Item |
Capabilities |
N/A |
· In-Port—Type of the input port (physical interface). · VLAN ID—VLAN ID. |
Required actions |
Optional actions |
N/A |
Capabilities supported by the TTP-termination-MAC flow table
A TTP-termination-MAC flow entry is used to select Layer 2 or 3 forwarding based on the destination MAC address of a packet, direct the packet to a flow table, and transmit the VRF information.
Table 23 Capabilities supported by TTP-termination-MAC flow entries
Item |
Capabilities |
N/A |
· ETH_TYPE—Ethernet type. Value 0x800 indicates Ethernet. · Metadata—VNI. · ETH_DST—Destination MAC address (the MAC address of the local gateway). |
Required actions |
· Write-metadata—Writes VRF index information. Value 0 indicates the public network. · Goto-table—Directs the packet to a table. ¡ If the packet matches the value of the ETH_DST field, the switch directs the packet to table 30 (TTP-unicast-routing flow table) for Layer 3 forwarding. ¡ If the packet does not match the value of the ETH_DST field, the switch directs the packet to table 50 (TTP-bridging flow table) for Layer 2 forwarding. |
Optional actions |
N/A |
Capabilities supported by the TTP-unicast-routing flow table
A TTP-unicast-routing flow entry is used to forward Layer 3 packets.
Table 24 Capabilities supported by TTP-unicast-routing flow entries (for normal IPv4 unicast packets)
Item |
Capabilities |
N/A |
· ETH_TYPE—Ethernet type. Value 0x800 indicates Ethernet. · Metadata—VNI. · IP_DST—Destination IP address. |
Required actions |
The TTP-unicast-routing flow table must support the following actions: · Write-actions—Writes actions in to the action set. ¡ Set L3_Unicast_Group_ID—Specifies actions in a Layer 3 unicast group entry ID. For more information about Layer 3 unicast group entries, see "Capabilities supported by the TTP-L3-unicast-group flow table." ¡ Set L3_ECMP_Group_ID—Specifies actions in a Layer 3 ECMP group entry ID. For more information about Layer 3 ECMP group entries, see "Capabilities supported by the TTP-L3-ECMP-group table." · Set TTL—Decreases the TTL by 1. · Goto-table-60—Directs the packet to table 60 (TTP-ingress-ACL flow table). |
Optional actions |
N/A |
Table 25 Capabilities supported by TTP-unicast-routing flow entries (for IPv4 unicast packets with special destination IP addresses)
Item |
Capabilities |
N/A |
· ETH_TYPE—Ethernet type. Value 0x800 indicates Ethernet. · Metadata—VNI. · IP_DST—Destination IP address (a subnet or an IP address of the switch). |
Required actions |
Controller—Sends the packet to the controller. |
Optional actions |
N/A |
Capabilities supported by the TTP-bridging flow table
A TTP-bridging flow entry is used to forward a Layer 2 packet, determine the type of the output port based on the destination MAC address of the packet, and perform one of the following actions:
· If the output port is a local physical interface, the switch tags or untags the packet before forwarding.
· If the output port is a VXLAN tunnel interface, the switch sets the VNI for the packet and untags the packet before forwarding.
Table 26 Capabilities supported by TTP-bridging flow entries
Item |
Capabilities |
N/A |
· ETH_DST—Destination MAC address. · Metadata—VNI. |
Required actions |
· Write-actions—Writes actions in to the action set by using the Set L2_Interface_Group_ID field. For more information about the action set, see "Capabilities supported by the TTP-L2-interface-group flow table." · Goto-table-60—Directs the packet to table 60 (TTP-ingress-ACL flow table). |
Optional actions |
N/A |
Capabilities supported by the TTP-ingress-ACL flow table
The TTP-ingress-ACL flow entry is used to rate limit, redirect, mirror, or discard matching packets in the inbound direction or send the packets to the controller.
The TTP-ingress-ACL flow table does not contain a table-miss entry and executes all actions in the action set on a packet that does not match any flow entry.
Table 27 Capabilities supported by TTP-ingress-ACL flow entries (for LLDP and ARP packets)
Item |
Capabilities |
N/A |
ETH_TYPE—Ethernet type. |
Required actions |
Optional actions |
N/A |
Table 28 Capabilities supported by TTP-ingress-ACL flow entries (for DHCP packets)
Item |
Capabilities |
N/A |
· ETH_TYPE—Ethernet type. · IP_PROTO—IP protocol type. · UDP_SRC—Source UDP port number. · UDP_DST—Destination UDP port number. |
Required actions |
Optional actions |
N/A |
Table 29 Capabilities supported by TTP-ingress-ACL flow entries (for all packets)
Item |
Capabilities |
N/A |
· In-Port—Input port. · Metadata—VNI or VRF. · IPv4SRC—Source IPv4 address. · IPv4DST—Destination IPv4 address. · IP_PROTO—IP protocol type. · TCP_SRC/UDP_SRC—Source TCP or UDP port number. · TCP_DST/UDP_DST—Destination TCP or UDP port number. |
Required actions |
A TTP-ingress-ACL flow entry must contain one of the following actions: · Write meter-ID—Sets a meter entry for rate limit. · Clear-actions + Output port number—Clears the action set and specifies an output port for packet redirection. · Output port number—Specifies an output port to mirror the packet. · Clear-actions—Clears the action set to discard the packet. |
Optional actions |
N/A |
Capabilities supported by the TTP-egress-ACL flow table
A TTP-egress-ACL flow entry is used to rate limit, mirror, or discard matching packets in the outbound direction.
The TTP-egress-ACL flow table does not contain a table-miss entry and uses the normal forwarding process to forward a packet that does not match any flow entry.
All packets processed by the TTP-ingress-ACL flow table will be directed to the TTP-egress-ACL flow table for processing by default.
Table 30 Capabilities supported by TTP-egress-ACL flow entries
Item |
Capabilities |
N/A |
· Metadata—VNI. · IPv4SRC—Source IPv4 address. · IPv4DST—Destination IPv4 address. · IP_PROTO—IP protocol type. · TCP_SRC/UDP_SRC—Source TCP or UDP port number. · TCP_DST/UDP_DST—Destination TCP or UDP port number. |
Required actions |
A TTP-egress-ACL flow entry must contain one of the following actions: · Write meter-ID—Sets a meter table for rate limit. · Output port number—Specifies an output port to mirror the packet. · Clear-actions—Clears the action set to discard the packet. |
Optional actions |
N/A |
A TTP-L2-interface-group flow entry is used to tag or untag a packet and set the VXLAN ID of the packet.
For a TTP-L2-interface-group flow entry, the group type is indirect and the group entry contains only one action bucket.
Table 31 Capabilities supported by TTP-L2-interface-group flow entries (for VXLAN interfaces)
Item |
Capabilities |
Required actions |
· Set Tunnel_ID—Sets the VNI. · POP VLAN—Untags the packet. Do not execute this action on an untagged packet. · Output-port-number—Sets the output port to the VXLAN tunnel interface. |
Optional actions |
N/A |
Table 32 Capabilities supported by TTP-L2-interface-group flow entries (for untagging physical interfaces)
Item |
Capabilities |
Required actions |
· POP VLAN—Untags the packet. Do not execute this action on an untagged packet. · Output-port-number—Sets the output port. |
Optional actions |
N/A |
Table 33 Capabilities supported by TTP-L2-interface-group flow entries (for tagging physical interfaces)
Item |
Capabilities |
Required actions |
· PUSH VLAN—Tags the packet with a VLAN ID. · POP VLAN—Untags the packet. Do not execute this action on an untagged packet. · Output-port-number—Sets the output port. |
Optional actions |
N/A |
A TTP-L3-unicast-group flow table is used to perform the following actions on a packet:
· Set the destination MAC address and source MAC address.
· Specify a TTP-L2-interface-group entry.
In a TTP-L3-unicast-group flow entry, the group type is indirect and the group entry contains only one action bucket.
Table 34 Capabilities supported by TTP-L3-unicast-group flow entries
Item |
Capabilities |
Required actions |
· Set ETH_DST—Sets the destination MAC address. · Set ETH_SRC—Sets the source MAC address. · Set L2_Interface_Group_ID—Specifies a TTP-L2-interface-group flow table. |
Optional actions |
N/A |
A TTP-L3-ECMP-group table is used to direct a packet to multiple TTP-L3-unicast-group entries for processing.
For a TTP-L3-ECMP-group entry, the group type is select, and the group entry contains multiple action buckets.
Table 35 Capabilities supported by TTP-L3-ECMP-group flow entries
Item |
Capabilities |
Required actions |
· Bucket 1:{Set L3_Unicast_Group_ID} · Bucket 2:{Set L3_Unicast_Group_ID} · … · Bucket n:{Set L3_Unicast_Group_ID} |
Optional actions |
N/A |
